[U-Boot] [PATCH V6] sf: Add clear flag status register operation support
The clear flag status register operation was required by Micron SPI flash chips, which support FSR. And if an error bit of FSR have been set, it must be cleared by the clear FSR operation.
Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Mingkai.Hu Mingkai.Hu@freescale.com --- Tested on T1042RDB board. V6: Generate the patch based on the latest wait ready logic. Depend on patch http://patchwork.ozlabs.org/patch/508166/ V5: 1. Removed #ifdef for STMICRO. 2. Add checking Protection and Voltage error bits. 3. Only if there is any error bit set, issue the clear FSR command. V4: Split the the patch to 2 patches for clear FSR and SPI flash address mode. V3: Generate the patch based on the latest tree git://git.denx.de/u-boot.git. V2: Add the operation of enter 3 Byte address mode in probe. V1: Based on git://git.denx.de/u-boot.git. drivers/mtd/spi/sf_internal.h | 15 +++++++++++++++ drivers/mtd/spi/sf_ops.c | 7 +++++++ 2 files changed, 22 insertions(+)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 8a3e5ec..fc6d751 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -82,6 +82,7 @@ enum spi_nor_option_flags { #define CMD_WRITE_ENABLE 0x06 #define CMD_READ_CONFIG 0x35 #define CMD_FLAG_STATUS 0x70 +#define CMD_CLEAR_FLAG_STATUS 0x50
/* Read commands */ #define CMD_READ_ARRAY_SLOW 0x03 @@ -104,7 +105,15 @@ enum spi_nor_option_flags { #define STATUS_WIP (1 << 0) #define STATUS_QEB_WINSPAN (1 << 1) #define STATUS_QEB_MXIC (1 << 6) + +/* Flag status for STMICRO */ +#define STATUS_PROT_ERR (1 << 1) +#define STATUS_VOLT_ERR (1 << 3) +#define STATUS_PROG_ERR (1 << 4) +#define STATUS_ERASE_ERR (1 << 5) #define STATUS_PEC (1 << 7) +#define FLAG_ERR_MASK (STATUS_PROT_ERR | STATUS_VOLT_ERR | \ + STATUS_PROG_ERR | STATUS_ERASE_ERR)
/* Flash timeout values */ #define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) @@ -191,6 +200,12 @@ static inline int spi_flash_cmd_write_disable(struct spi_flash *flash) return spi_flash_cmd(flash->spi, CMD_WRITE_DISABLE, NULL, 0); }
+/* Clear flag status register */ +static inline int spi_flash_cmd_clear_flag_status(struct spi_flash *flash) +{ + return spi_flash_cmd(flash->spi, CMD_CLEAR_FLAG_STATUS, NULL, 0); +} + /* * Send the read status command to the device and wait for the wip * (write-in-progress) bit to clear itself. diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index ba5ff0c..78ef08b 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -174,6 +174,13 @@ static inline int spi_flash_fsr_ready(struct spi_flash *flash) if (ret < 0) return ret;
+ if (fsr & FLAG_ERR_MASK) { + printf("SF: flag status(0x%x) error occured\n", fsr); + ret = spi_flash_cmd_clear_flag_status(flash); + if (ret < 0) + printf("SF: clear flag status failed\n"); + return -1; + } return fsr & STATUS_PEC; }
Reviewed-by: Jagan Teki jteki@openedev.com
- Send the read status command to the device and wait for the wip
- (write-in-progress) bit to clear itself.
if (ret < 0)
return -1;
-- 2.1.0.27.g96db324
thanks!
Jagan Teki
Zhiqiang Hou
