[U-Boot] [PATCH 0/9] sh: Convert generic board
Hello. This patch series convert generic board for SH. Tested on r2dplus target.
Yoshinori Sato (9): board_f: Add relocate_code stub board_f: Add SH specific timer_init board_f: if SKIP_RELOC is ture, return from board_init_f board_f: Add SH specific mon_len sh: Add missing symbol for generic board sh: Remove arch specific board.c sh: generic board support - startup sh: generic board support - header sh: generic board support - Kconfig
arch/Kconfig | 2 + arch/sh/cpu/sh2/cpu.c | 9 +++ arch/sh/cpu/sh2/start.S | 22 +++-- arch/sh/cpu/sh3/cpu.c | 9 +++ arch/sh/cpu/sh3/start.S | 21 +++-- arch/sh/cpu/sh4/cpu.c | 9 +++ arch/sh/cpu/sh4/start.S | 23 ++++-- arch/sh/cpu/u-boot.lds | 1 + arch/sh/include/asm/u-boot.h | 11 +-- arch/sh/lib/Makefile | 1 - arch/sh/lib/board.c | 189 ------------------------------------------- common/board_f.c | 12 ++- 12 files changed, 86 insertions(+), 223 deletions(-) delete mode 100644 arch/sh/lib/board.c
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- common/board_f.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/board_f.c b/common/board_f.c index 109025a..bf768d1 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -826,6 +826,11 @@ __weak int arch_cpu_init_dm(void) return 0; }
+__weak void relocate_code(ulong sp, gd_t *new_gd, ulong reloc) +{ + for(;;); +} + static init_fnc_t init_sequence_f[] = { #ifdef CONFIG_SANDBOX setup_ram_buf,
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- common/board_f.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index bf768d1..fcc69b8 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -870,7 +870,7 @@ static init_fnc_t init_sequence_f[] = { #endif #if defined(CONFIG_ARM) || defined(CONFIG_MIPS) || \ defined(CONFIG_BLACKFIN) || defined(CONFIG_NDS32) || \ - defined(CONFIG_SPARC) + defined(CONFIG_SPARC) || defined(CONFIG_SH) timer_init, /* initialize timer */ #endif #ifdef CONFIG_SYS_ALLOC_DPRAM
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- common/board_f.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index fcc69b8..e1122e3 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -1067,7 +1067,8 @@ void board_init_f(ulong boot_flags) #if !defined(CONFIG_ARM) && !defined(CONFIG_SANDBOX) && \ !defined(CONFIG_EFI_APP) /* NOTREACHED - jump_to_copy() does not return */ - hang(); + if (!(gd->flags & GD_FLG_SKIP_RELOC)) + hang(); #endif }
diff --git a/common/board_f.c b/common/board_f.c index e1122e3..f31f2de 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -270,7 +270,7 @@ static int setup_mon_len(void) gd->mon_len = (ulong)&__bss_end - (ulong)_start; #elif defined(CONFIG_SANDBOX) || defined(CONFIG_EFI_APP) gd->mon_len = (ulong)&_end - (ulong)_init; -#elif defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) +#elif defined(CONFIG_BLACKFIN) || defined(CONFIG_NIOS2) || defined(CONFIG_SH) gd->mon_len = CONFIG_SYS_MONITOR_LEN; #elif defined(CONFIG_NDS32) gd->mon_len = (ulong)(&__bss_end) - (ulong)(&_start);
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/cpu/u-boot.lds | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/sh/cpu/u-boot.lds b/arch/sh/cpu/u-boot.lds index 30c7a9d..4e8b718 100644 --- a/arch/sh/cpu/u-boot.lds +++ b/arch/sh/cpu/u-boot.lds @@ -80,4 +80,5 @@ SECTIONS PROVIDE (bss_end = .);
PROVIDE (__bss_end = .); + PROVIDE (__init_end = .); }
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/lib/Makefile | 1 - arch/sh/lib/board.c | 189 --------------------------------------------------- 2 files changed, 190 deletions(-) delete mode 100644 arch/sh/lib/board.c
diff --git a/arch/sh/lib/Makefile b/arch/sh/lib/Makefile index f7ae4f8..c5cf89f 100644 --- a/arch/sh/lib/Makefile +++ b/arch/sh/lib/Makefile @@ -6,7 +6,6 @@ #
-obj-y += board.o obj-$(CONFIG_CMD_BOOTM) += bootm.o ifeq ($(CONFIG_CPU_SH2),y) obj-y += time_sh2.o diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c deleted file mode 100644 index 69cdca3..0000000 --- a/arch/sh/lib/board.c +++ /dev/null @@ -1,189 +0,0 @@ -/* - * Copyright (C) 2007, 2008, 2010 - * Nobuhiro Iwamatsu iwamatsu@nigauri.org - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <console.h> -#include <malloc.h> -#include <stdio_dev.h> -#include <version.h> -#include <watchdog.h> -#include <net.h> -#include <mmc.h> -#include <environment.h> - -#ifdef CONFIG_BITBANGMII -#include <miiphy.h> -#endif - -DECLARE_GLOBAL_DATA_PTR; - -extern int cpu_init(void); -extern int board_init(void); -extern int dram_init(void); -extern int timer_init(void); - -unsigned long monitor_flash_len = CONFIG_SYS_MONITOR_LEN; - -#ifndef CONFIG_SYS_NO_FLASH -static int sh_flash_init(void) -{ - gd->bd->bi_flashsize = flash_init(); - - if (gd->bd->bi_flashsize >= (1024 * 1024)) - printf("Flash: %ldMB\n", gd->bd->bi_flashsize / (1024*1024)); - else - printf("Flash: %ldKB\n", gd->bd->bi_flashsize / 1024); - - return 0; -} -#endif /* CONFIG_SYS_NO_FLASH */ - -#if defined(CONFIG_CMD_NAND) -# include <nand.h> -# define INIT_FUNC_NAND_INIT nand_init, -#else -# define INIT_FUNC_NAND_INIT -#endif /* CONFIG_CMD_NAND */ - -#if defined(CONFIG_WATCHDOG) -extern int watchdog_init(void); -extern int watchdog_disable(void); -# undef INIT_FUNC_WATCHDOG_INIT -# define INIT_FUNC_WATCHDOG_INIT watchdog_init, -# define WATCHDOG_DISABLE watchdog_disable -#else -# define INIT_FUNC_WATCHDOG_INIT -# define WATCHDOG_DISABLE -#endif /* CONFIG_WATCHDOG */ - -#if defined(CONFIG_CMD_IDE) -# include <ide.h> -# define INIT_FUNC_IDE_INIT ide_init, -#else -# define INIT_FUNC_IDE_INIT -#endif /* CONFIG_CMD_IDE */ - -#if defined(CONFIG_PCI) -#include <pci.h> -static int sh_pci_init(void) -{ - pci_init(); - return 0; -} -# define INIT_FUNC_PCI_INIT sh_pci_init, -#else -# define INIT_FUNC_PCI_INIT -#endif /* CONFIG_PCI */ - -static int sh_mem_env_init(void) -{ - mem_malloc_init(CONFIG_SYS_TEXT_BASE - GENERATED_GBL_DATA_SIZE - - CONFIG_SYS_MALLOC_LEN, CONFIG_SYS_MALLOC_LEN - 16); - env_relocate(); - jumptable_init(); - return 0; -} - -#if defined(CONFIG_CMD_MMC) -static int sh_mmc_init(void) -{ - puts("MMC: "); - mmc_initialize(gd->bd); - return 0; -} -#endif - -typedef int (init_fnc_t) (void); - -init_fnc_t *init_sequence[] = -{ - cpu_init, /* basic cpu dependent setup */ - board_init, /* basic board dependent setup */ - interrupt_init, /* set up exceptions */ - env_init, /* event init */ - serial_init, /* SCIF init */ - INIT_FUNC_WATCHDOG_INIT /* watchdog init */ - console_init_f, - display_options, - checkcpu, - checkboard, /* Check support board */ - dram_init, /* SDRAM init */ - timer_init, /* SuperH Timer (TCNT0 only) init */ - sh_mem_env_init, -#ifndef CONFIG_SYS_NO_FLASH - sh_flash_init, /* Flash memory init*/ -#endif - INIT_FUNC_NAND_INIT/* Flash memory (NAND) init */ - INIT_FUNC_PCI_INIT /* PCI init */ - stdio_init, - console_init_r, - interrupt_init, -#ifdef CONFIG_BOARD_LATE_INIT - board_late_init, -#endif -#if defined(CONFIG_CMD_MMC) - sh_mmc_init, -#endif - NULL /* Terminate this list */ -}; - -void sh_generic_init(void) -{ - bd_t *bd; - init_fnc_t **init_fnc_ptr; - - memset(gd, 0, GENERATED_GBL_DATA_SIZE); - - gd->flags |= GD_FLG_RELOC; /* tell others: relocation done */ - - gd->bd = (bd_t *)(gd + 1); /* At end of global data */ - gd->baudrate = CONFIG_BAUDRATE; - - gd->cpu_clk = CONFIG_SYS_CLK_FREQ; - - bd = gd->bd; - bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; - bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; -#ifndef CONFIG_SYS_NO_FLASH - bd->bi_flashstart = CONFIG_SYS_FLASH_BASE; -#endif -#if defined(CONFIG_SYS_SRAM_BASE) && defined(CONFIG_SYS_SRAM_SIZE) - bd->bi_sramstart = CONFIG_SYS_SRAM_BASE; - bd->bi_sramsize = CONFIG_SYS_SRAM_SIZE; -#endif - - for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) { - WATCHDOG_RESET(); - if ((*init_fnc_ptr) () != 0) - hang(); - } - -#ifdef CONFIG_WATCHDOG - /* disable watchdog if environment is set */ - { - char *s = getenv("watchdog"); - if (s != NULL) - if (strncmp(s, "off", 3) == 0) - WATCHDOG_DISABLE(); - } -#endif /* CONFIG_WATCHDOG*/ - - -#ifdef CONFIG_BITBANGMII - bb_miiphy_init(); -#endif -#if defined(CONFIG_CMD_NET) - puts("Net: "); - eth_initialize(); -#endif /* CONFIG_CMD_NET */ - - while (1) { - WATCHDOG_RESET(); - main_loop(); - } -}
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/cpu/sh2/cpu.c | 9 +++++++++ arch/sh/cpu/sh2/start.S | 22 ++++++++++++++++------ arch/sh/cpu/sh3/cpu.c | 9 +++++++++ arch/sh/cpu/sh3/start.S | 21 +++++++++++++++------ arch/sh/cpu/sh4/cpu.c | 9 +++++++++ arch/sh/cpu/sh4/start.S | 23 +++++++++++++++-------- 6 files changed, 73 insertions(+), 20 deletions(-)
diff --git a/arch/sh/cpu/sh2/cpu.c b/arch/sh/cpu/sh2/cpu.c index a2f856f..8119893 100644 --- a/arch/sh/cpu/sh2/cpu.c +++ b/arch/sh/cpu/sh2/cpu.c @@ -10,6 +10,8 @@ #include <asm/processor.h> #include <asm/io.h>
+DECLARE_GLOBAL_DATA_PTR; + #define STBCR4 0xFFFE040C #define cmt_clock_enable() do {\ writeb(readb(STBCR4) & ~0x04, STBCR4);\ @@ -83,3 +85,10 @@ int dcache_status(void) { return 0; } + +int arch_cpu_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} diff --git a/arch/sh/cpu/sh2/start.S b/arch/sh/cpu/sh2/start.S index ebf731a..0ee771c 100644 --- a/arch/sh/cpu/sh2/start.S +++ b/arch/sh/cpu/sh2/start.S @@ -7,6 +7,7 @@
#include <asm-offsets.h> #include <config.h> +#include <asm-generic/global_data.h>
.text .align 2 @@ -43,12 +44,18 @@ _init: cmp/hs r5, r4 bf 3b
- mov.l ._gd_init, r13 /* global data */ - mov.l ._stack_init, r15 /* stack */ + mov.l ._stack_init, r15 + mov.l ._board_init_f_init_reserve, r0 + jsr @r0 + mov r15, r4
- mov.l ._sh_generic_init, r0 + mov.l ._board_init_f, r0 jsr @r0 - nop + mov ._bootflag ,r4 + + mov.l ._board_init_r, r0 + jsr @r0 + mov r13,r4
loop: bra loop @@ -61,5 +68,8 @@ loop: ._bss_start: .long bss_start ._bss_end: .long bss_end ._gd_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE) -._stack_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) -._sh_generic_init: .long sh_generic_init +._stack_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - CONFIG_ENV_SIZE- 16) +._board_init_f: .long board_init_f +._board_init_r: .long board_init_r +._board_init_f_init_reserve: .long board_init_f_init_reserve +._bootflag: .long GD_FLG_SKIP_RELOC diff --git a/arch/sh/cpu/sh3/cpu.c b/arch/sh/cpu/sh3/cpu.c index ea0006a..85cb6a3 100644 --- a/arch/sh/cpu/sh3/cpu.c +++ b/arch/sh/cpu/sh3/cpu.c @@ -12,6 +12,8 @@ #include <command.h> #include <asm/processor.h>
+DECLARE_GLOBAL_DATA_PTR; + int checkcpu(void) { puts("CPU: SH3\n"); @@ -66,3 +68,10 @@ int dcache_status(void) { return 0; } + +int arch_cpu_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} diff --git a/arch/sh/cpu/sh3/start.S b/arch/sh/cpu/sh3/start.S index 7a934e2..a1633a7 100644 --- a/arch/sh/cpu/sh3/start.S +++ b/arch/sh/cpu/sh3/start.S @@ -10,6 +10,7 @@
.text .align 2 @@ -42,13 +43,18 @@ _sh_start: cmp/hs r5, r4 bf 3b
- mov.l ._sh_generic_init, r0 + mov.l ._board_init_f, r0 jsr @r0 - nop + mov #._bootflag, r4
+ mov.l ._board_init_r, r0 + jsr @r0 + mov r13,r4 loop: bra loop
@@ -60,5 +66,8 @@ loop: ._bss_start: .long bss_start ._bss_end: .long bss_end ._gd_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE) -._stack_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) -._sh_generic_init: .long sh_generic_init +._stack_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - CONFIG_ENV_SIZE - 16) +._board_init_f: .long board_init_f +._board_init_r: .long board_init_r +._board_init_f_init_reserve: .long board_init_f_init_reserve +._bootflag: .long GD_FLG_SKIP_RELOC diff --git a/arch/sh/cpu/sh4/cpu.c b/arch/sh/cpu/sh4/cpu.c index e8ee0a4..fea8e59 100644 --- a/arch/sh/cpu/sh4/cpu.c +++ b/arch/sh/cpu/sh4/cpu.c @@ -11,6 +11,8 @@ #include <asm/processor.h> #include <asm/cache.h>
+DECLARE_GLOBAL_DATA_PTR; + int checkcpu(void) { puts("CPU: SH4\n"); @@ -75,3 +77,10 @@ int cpu_eth_init(bd_t *bis) #endif return 0; } + +int arch_cpu_init(void) +{ + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} diff --git a/arch/sh/cpu/sh4/start.S b/arch/sh/cpu/sh4/start.S index 21644b5..52f960c 100644 --- a/arch/sh/cpu/sh4/start.S +++ b/arch/sh/cpu/sh4/start.S @@ -7,6 +7,7 @@
.text .align 2 @@ -39,16 +40,20 @@ _sh_start: cmp/hs r5, r4 bf 3b
- mov.l ._sh_generic_init, r0 + mov.l ._board_init_f, r0 jsr @r0 - nop + mov.l ._bootflag, r4
+ mov.l ._board_init_r, r0 + jsr @r0 + mov r13,r4 loop: bra loop - .align 2
._lowlevel_init: .long (lowlevel_init - (100b + 4)) @@ -56,6 +61,8 @@ loop: ._reloc_dst_end: .long reloc_dst_end ._bss_start: .long bss_start ._bss_end: .long bss_end -._gd_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE) -._stack_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) -._sh_generic_init: .long sh_generic_init +._stack_init: .long (_sh_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - CONFIG_ENV_SIZE - 16) +._board_init_f: .long board_init_f +._board_init_r: .long board_init_r +._board_init_f_init_reserve: .long board_init_f_init_reserve +._bootflag: .long GD_FLG_SKIP_RELOC
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/include/asm/u-boot.h | 11 +---------- 1 file changed, 1 insertion(+), 10 deletions(-)
diff --git a/arch/sh/include/asm/u-boot.h b/arch/sh/include/asm/u-boot.h index ea37c24..9e578a6 100644 --- a/arch/sh/include/asm/u-boot.h +++ b/arch/sh/include/asm/u-boot.h @@ -12,16 +12,7 @@ #ifndef __ASM_SH_U_BOOT_H_ #define __ASM_SH_U_BOOT_H_
-typedef struct bd_info { - unsigned long bi_memstart; /* start of DRAM memory */ - phys_size_t bi_memsize; /* size of DRAM memory in bytes */ - unsigned long bi_flashstart; /* start of FLASH memory */ - unsigned long bi_flashsize; /* size of FLASH memory */ - unsigned long bi_flashoffset; /* reserved area for startup monitor */ - unsigned long bi_sramstart; /* start of SRAM memory */ - unsigned long bi_sramsize; /* size of SRAM memory */ - unsigned long bi_boot_params; /* where this board expects params */ -} bd_t; +#include <asm-generic/u-boot.h>
/* For image.h:image_check_target_arch() */ #define IH_ARCH_DEFAULT IH_ARCH_SH
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/Kconfig b/arch/Kconfig index ec12013..291e1dc 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -96,6 +96,8 @@ config SANDBOX config SH bool "SuperH architecture" select HAVE_PRIVATE_LIBGCC + select HAVE_GENERIC_BOARD + select SYS_GENERIC_BOARD
config SPARC bool "SPARC architecture"
On Sat, 21 May 2016 10:28:42 +0900, Tom Rini wrote:
[1 <text/plain; us-ascii (quoted-printable)>] On Thu, May 19, 2016 at 09:26:46PM +0900, Yoshinori Sato wrote:
Since I believe you said before this was QEMU, how did you start it off? Thanks!
Yes. I tested comannd bellow $ qemu-system-sh4 -M r2d -kernel u-boot.bin -serial null -serial vc
You can see banner for serial1 console (crtl - alt - 3).
Thanks.
-- Tom [2 Digital signature <application/pgp-signature (7bit)>] No public key for 87F9F635D31D7652 created at 2016-05-21T10:28:42+0900 using RSA
OK, thanks!
Please can you add a README.sh showing how to do this? It would be good to have the instructions in the source tree for future reference.
Thanks.
Regards, SImon
Sorry, my reply was too late. And thanks for your work.
2016-05-19 21:26 GMT+09:00 Yoshinori Sato ysato@users.sourceforge.jp:
Please add more infomation to commit log. This patch contains the fixes that are referenced by other architectures.
Best regards, Nobuhiro
Hi, again.
Same fixes and you had already been taken up by Simon. I'm sorry to reply and confirmation slow.
2016-06-07 9:14 GMT+09:00 Nobuhiro Iwamatsu iwamatsu@nigauri.org:
-- Nobuhiro Iwamatsu iwamatsu at {nigauri.org / debian.org} GPG ID: 40AD1FA6
On Tue, 07 Jun 2016 09:21:38 +0900, Nobuhiro Iwamatsu wrote:
Hi, again.
OK. I'll sent V2.
Nobuhiro Iwamatsu
Yoshinori Sato
