[U-Boot] [PATCH v2 3/3] Fix video support for vision2 board
Adds arguments to the mx51_fb_init call.
Signed-off-by: Renato Frias renato.frias@freescale.com --- Changes for v2: - Includes fix to vision2 (this commit) on the patch set
board/ttcontrol/vision2/vision2.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/ttcontrol/vision2/vision2.c b/board/ttcontrol/vision2/vision2.c index 071dad6..d818224 100644 --- a/board/ttcontrol/vision2/vision2.c +++ b/board/ttcontrol/vision2/vision2.c @@ -43,7 +43,7 @@ DECLARE_GLOBAL_DATA_PTR;
static u32 system_rev;
-extern int mx51_fb_init(struct fb_videomode *mode); +extern int mx51_fb_init(struct fb_videomode *mode, u32 ipu_di, u32 pix_fmt);
#ifdef CONFIG_HW_WATCHDOG #include <watchdog.h> @@ -675,7 +675,7 @@ void lcd_enable(void) mxc_gpio_set(2, 1); mxc_request_iomux(MX51_PIN_GPIO1_2, IOMUX_CONFIG_ALT0);
- ret = mx51_fb_init(&nec_nl6448bc26_09c); + ret = mx51_fb_init(&nec_nl6448bc26_09c, 0, 18); if (ret) puts("LCD cannot be configured\n"); }
Changes for v2:
- ret = mx51_fb_init(&nec_nl6448bc26_09c, 0, 18);
I think there is aa misunderstanding at this point. You introduce a new parameter (pix_fmt), that is used in the driver only to set up the vl_bpix field of the panel_info structure.The field vl_bpixis the number of bits x pixel that u-boot supports, in the range 1-4 (see defines LCD_COLOR* in lcd.h), as we can display in u-boot bitmaps up to 16 colors. The same apply for the previous patch for mx51evk.
The first question I have is if we really need this parameter. In the driver (bpp_to_pixfmt function) we do not support really less than 16 colors, so setting always panel_info.vl_bpix to LCD_COLOR16 seems to me correct.
And the driver itself does not use internally this parameter and instead of it takes interface_pix_fmt to set up the IPU.
Best regards, Stefano Babic
Renato Frias
Stefano Babic
