[U-Boot] [PATCH 01/11 v2] snowball: Add support for ux500 based snowball board
From: "Mathieu J. Poirier" mathieu.poirier@linaro.org
Signed-off-by: Mathieu Poirier mathieu.poirier@linaro.org Signed-off-by: John Rigby john.rigby@linaro.org --- Changes for v2: - Got rid of obsolete "prcmu.o". - Using "get_ram_size" to determine memory size. - Got rid of "__iomem" in favor of "compiler.h" - Removed baudrate and prompt #defines in "snowball.h". --- MAINTAINERS | 4 + arch/arm/include/asm/arch-u8500/db8500_gpio.h | 42 ++ arch/arm/include/asm/arch-u8500/db8500_pincfg.h | 170 +++++ board/st-ericsson/snowball/Makefile | 49 ++ board/st-ericsson/snowball/db8500_pins.h | 745 +++++++++++++++++++++++ board/st-ericsson/snowball/snowball.c | 166 +++++ boards.cfg | 1 + drivers/gpio/Makefile | 1 + drivers/gpio/db8500_gpio.c | 221 +++++++ drivers/serial/serial_pl01x.c | 2 + include/configs/snowball.h | 256 ++++++++ 11 files changed, 1657 insertions(+), 0 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index fd0c65c..8a16b12 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -959,6 +959,10 @@ Vladimir Zapolskiy vz@mleia.com
devkit3250 lpc32xx
+Mathieu Poirier mathieu.poirier@linaro.org + + snowball ARM ARMV7 (u8500 SoC) + -------------------------------------------------------------------------
Unknown / orphaned boards: diff --git a/arch/arm/include/asm/arch-u8500/db8500_gpio.h b/arch/arm/include/asm/arch-u8500/db8500_gpio.h new file mode 100644 index 0000000..7c85a89 --- /dev/null +++ b/arch/arm/include/asm/arch-u8500/db8500_gpio.h @@ -0,0 +1,42 @@ +/* + * Structures and registers for GPIO access in the Nomadik SoC + * + * Code ported from Nomadik GPIO driver in ST-Ericsson Linux kernel code. + * The purpose is that GPIO config found in kernel should work by simply + * copy-paste it to U-boot. + * + * Ported to U-boot by: + * Copyright (C) 2010 Joakim Axelsson <joakim.axelsson AT stericsson.com> + * Copyright (C) 2008 STMicroelectronics + * Author: Prafulla WADASKAR prafulla.wadaskar@st.com + * Copyright (C) 2009 Alessandro Rubini rubini@unipv.it + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef __DB8500_GPIO_H__ +#define __DB8500_GPIO_H__ + +/* Alternate functions: function C is set in hw by setting both A and B */ +enum db8500_gpio_alt { + DB8500_GPIO_ALT_GPIO = 0, + DB8500_GPIO_ALT_A = 1, + DB8500_GPIO_ALT_B = 2, + DB8500_GPIO_ALT_C = (DB8500_GPIO_ALT_A | DB8500_GPIO_ALT_B) +}; + +enum db8500_gpio_pull { + DB8500_GPIO_PULL_NONE, + DB8500_GPIO_PULL_UP, + DB8500_GPIO_PULL_DOWN +}; + +void db8500_gpio_set_pull(unsigned gpio, enum db8500_gpio_pull pull); +void db8500_gpio_make_input(unsigned gpio); +int db8500_gpio_get_input(unsigned gpio); +void db8500_gpio_make_output(unsigned gpio, int val); +void db8500_gpio_set_output(unsigned gpio, int val); + +#endif /* __DB8500_GPIO_H__ */ diff --git a/arch/arm/include/asm/arch-u8500/db8500_pincfg.h b/arch/arm/include/asm/arch-u8500/db8500_pincfg.h new file mode 100644 index 0000000..6495701 --- /dev/null +++ b/arch/arm/include/asm/arch-u8500/db8500_pincfg.h @@ -0,0 +1,170 @@ +/* + * Copyright (C) ST-Ericsson SA 2010 + * + * Code ported from Nomadik GPIO driver in ST-Ericsson Linux kernel code. + * The purpose is that GPIO config found in kernel should work by simply + * copy-paste it to U-boot. Ported 2010 to U-boot by: + * Author: Joakim Axelsson <joakim.axelsson AT stericsson.com> + * + * License terms: GNU General Public License, version 2 + * Author: Rabin Vincent rabin.vincent@stericsson.com for ST-Ericsson + * + * + * Based on arch/arm/mach-pxa/include/mach/mfp.h: + * Copyright (C) 2007 Marvell International Ltd. + * eric miao eric.miao@marvell.com + */ + +#ifndef __DB8500_PINCFG_H +#define __DB8500_PINCFG_H + +#include "db8500_gpio.h" + +/* + * U-boot info: + * SLPM (sleep mode) config will be ignored by U-boot but it is still + * possible to configure it in order to keep cut-n-paste compability + * with Linux kernel config. + * + * pin configurations are represented by 32-bit integers: + * + * bit 0.. 8 - Pin Number (512 Pins Maximum) + * bit 9..10 - Alternate Function Selection + * bit 11..12 - Pull up/down state + * bit 13 - Sleep mode behaviour (not used in U-boot) + * bit 14 - Direction + * bit 15 - Value (if output) + * bit 16..18 - SLPM pull up/down state (not used in U-boot) + * bit 19..20 - SLPM direction (not used in U-boot) + * bit 21..22 - SLPM Value (if output) (not used in U-boot) + * + * to facilitate the definition, the following macros are provided + * + * PIN_CFG_DEFAULT - default config (0): + * pull up/down = disabled + * sleep mode = input/wakeup + * direction = input + * value = low + * SLPM direction = same as normal + * SLPM pull = same as normal + * SLPM value = same as normal + * + * PIN_CFG - default config with alternate function + * PIN_CFG_PULL - default config with alternate function and pull up/down + */ + +/* Sleep mode */ +enum db8500_gpio_slpm { + DB8500_GPIO_SLPM_INPUT, + DB8500_GPIO_SLPM_WAKEUP_ENABLE = DB8500_GPIO_SLPM_INPUT, + DB8500_GPIO_SLPM_NOCHANGE, + DB8500_GPIO_SLPM_WAKEUP_DISABLE = DB8500_GPIO_SLPM_NOCHANGE, +}; + +#define PIN_NUM_MASK 0x1ff +#define PIN_NUM(x) ((x) & PIN_NUM_MASK) + +#define PIN_ALT_SHIFT 9 +#define PIN_ALT_MASK (0x3 << PIN_ALT_SHIFT) +#define PIN_ALT(x) (((x) & PIN_ALT_MASK) >> PIN_ALT_SHIFT) +#define PIN_GPIO (DB8500_GPIO_ALT_GPIO << PIN_ALT_SHIFT) +#define PIN_ALT_A (DB8500_GPIO_ALT_A << PIN_ALT_SHIFT) +#define PIN_ALT_B (DB8500_GPIO_ALT_B << PIN_ALT_SHIFT) +#define PIN_ALT_C (DB8500_GPIO_ALT_C << PIN_ALT_SHIFT) + +#define PIN_PULL_SHIFT 11 +#define PIN_PULL_MASK (0x3 << PIN_PULL_SHIFT) +#define PIN_PULL(x) (((x) & PIN_PULL_MASK) >> PIN_PULL_SHIFT) +#define PIN_PULL_NONE (DB8500_GPIO_PULL_NONE << PIN_PULL_SHIFT) +#define PIN_PULL_UP (DB8500_GPIO_PULL_UP << PIN_PULL_SHIFT) +#define PIN_PULL_DOWN (DB8500_GPIO_PULL_DOWN << PIN_PULL_SHIFT) + +#define PIN_SLPM_SHIFT 13 +#define PIN_SLPM_MASK (0x1 << PIN_SLPM_SHIFT) +#define PIN_SLPM(x) (((x) & PIN_SLPM_MASK) >> PIN_SLPM_SHIFT) +#define PIN_SLPM_MAKE_INPUT (DB8500_GPIO_SLPM_INPUT << PIN_SLPM_SHIFT) +#define PIN_SLPM_NOCHANGE (DB8500_GPIO_SLPM_NOCHANGE << PIN_SLPM_SHIFT) +/* These two replace the above in DB8500v2+ */ +#define PIN_SLPM_WAKEUP_ENABLE \ + (DB8500_GPIO_SLPM_WAKEUP_ENABLE << PIN_SLPM_SHIFT) +#define PIN_SLPM_WAKEUP_DISABLE \ + (DB8500_GPIO_SLPM_WAKEUP_DISABLE << PIN_SLPM_SHIFT) + +#define PIN_DIR_SHIFT 14 +#define PIN_DIR_MASK (0x1 << PIN_DIR_SHIFT) +#define PIN_DIR(x) (((x) & PIN_DIR_MASK) >> PIN_DIR_SHIFT) +#define PIN_DIR_INPUT (0 << PIN_DIR_SHIFT) +#define PIN_DIR_OUTPUT (1 << PIN_DIR_SHIFT) + +#define PIN_VAL_SHIFT 15 +#define PIN_VAL_MASK (0x1 << PIN_VAL_SHIFT) +#define PIN_VAL(x) (((x) & PIN_VAL_MASK) >> PIN_VAL_SHIFT) +#define PIN_VAL_LOW (0 << PIN_VAL_SHIFT) +#define PIN_VAL_HIGH (1 << PIN_VAL_SHIFT) + +#define PIN_SLPM_PULL_SHIFT 16 +#define PIN_SLPM_PULL_MASK (0x7 << PIN_SLPM_PULL_SHIFT) +#define PIN_SLPM_PULL(x) \ + (((x) & PIN_SLPM_PULL_MASK) >> PIN_SLPM_PULL_SHIFT) +#define PIN_SLPM_PULL_NONE \ + ((1 + DB8500_GPIO_PULL_NONE) << PIN_SLPM_PULL_SHIFT) +#define PIN_SLPM_PULL_UP \ + ((1 + DB8500_GPIO_PULL_UP) << PIN_SLPM_PULL_SHIFT) +#define PIN_SLPM_PULL_DOWN \ + ((1 + DB8500_GPIO_PULL_DOWN) << PIN_SLPM_PULL_SHIFT) + +#define PIN_SLPM_DIR_SHIFT 19 +#define PIN_SLPM_DIR_MASK (0x3 << PIN_SLPM_DIR_SHIFT) +#define PIN_SLPM_DIR(x) \ + (((x) & PIN_SLPM_DIR_MASK) >> PIN_SLPM_DIR_SHIFT) +#define PIN_SLPM_DIR_INPUT ((1 + 0) << PIN_SLPM_DIR_SHIFT) +#define PIN_SLPM_DIR_OUTPUT ((1 + 1) << PIN_SLPM_DIR_SHIFT) + +#define PIN_SLPM_VAL_SHIFT 21 +#define PIN_SLPM_VAL_MASK (0x3 << PIN_SLPM_VAL_SHIFT) +#define PIN_SLPM_VAL(x) \ + (((x) & PIN_SLPM_VAL_MASK) >> PIN_SLPM_VAL_SHIFT) +#define PIN_SLPM_VAL_LOW ((1 + 0) << PIN_SLPM_VAL_SHIFT) +#define PIN_SLPM_VAL_HIGH ((1 + 1) << PIN_SLPM_VAL_SHIFT) + +/* Shortcuts. Use these instead of separate DIR, PULL, and VAL. */ +#define PIN_INPUT_PULLDOWN (PIN_DIR_INPUT | PIN_PULL_DOWN) +#define PIN_INPUT_PULLUP (PIN_DIR_INPUT | PIN_PULL_UP) +#define PIN_INPUT_NOPULL (PIN_DIR_INPUT | PIN_PULL_NONE) +#define PIN_OUTPUT_LOW (PIN_DIR_OUTPUT | PIN_VAL_LOW) +#define PIN_OUTPUT_HIGH (PIN_DIR_OUTPUT | PIN_VAL_HIGH) + +#define PIN_SLPM_INPUT_PULLDOWN (PIN_SLPM_DIR_INPUT | PIN_SLPM_PULL_DOWN) +#define PIN_SLPM_INPUT_PULLUP (PIN_SLPM_DIR_INPUT | PIN_SLPM_PULL_UP) +#define PIN_SLPM_INPUT_NOPULL (PIN_SLPM_DIR_INPUT | PIN_SLPM_PULL_NONE) +#define PIN_SLPM_OUTPUT_LOW (PIN_SLPM_DIR_OUTPUT | PIN_SLPM_VAL_LOW) +#define PIN_SLPM_OUTPUT_HIGH (PIN_SLPM_DIR_OUTPUT | PIN_SLPM_VAL_HIGH) + +#define PIN_CFG_DEFAULT (0) + +#define PIN_CFG(num, alt) \ + (PIN_CFG_DEFAULT |\ + (PIN_NUM(num) | PIN_##alt)) + +#define PIN_CFG_INPUT(num, alt, pull) \ + (PIN_CFG_DEFAULT |\ + (PIN_NUM(num) | PIN_##alt | PIN_INPUT_##pull)) + +#define PIN_CFG_OUTPUT(num, alt, val) \ + (PIN_CFG_DEFAULT |\ + (PIN_NUM(num) | PIN_##alt | PIN_OUTPUT_##val)) + +#define PIN_CFG_PULL(num, alt, pull) \ + ((PIN_CFG_DEFAULT & ~PIN_PULL_MASK) |\ + (PIN_NUM(num) | PIN_##alt | PIN_PULL_##pull)) + +/** + * db8500_gpio_config_pins - configure several pins at once + * @cfgs: array of pin configurations + * @num: number of elments in the array + * + * Configures several GPIO pins. + */ +void db8500_gpio_config_pins(unsigned long *cfgs, size_t num); + +#endif diff --git a/board/st-ericsson/snowball/Makefile b/board/st-ericsson/snowball/Makefile new file mode 100644 index 0000000..a26dadc --- /dev/null +++ b/board/st-ericsson/snowball/Makefile @@ -0,0 +1,49 @@ +# +# Copyright (C) ST-Ericsson SA 2009 +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +CFLAGS += -D__RELEASE -D__STN_8500 +LIB = $(obj)lib$(BOARD).o + +COBJS := snowball.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/st-ericsson/snowball/db8500_pins.h b/board/st-ericsson/snowball/db8500_pins.h new file mode 100644 index 0000000..e339cb8 --- /dev/null +++ b/board/st-ericsson/snowball/db8500_pins.h @@ -0,0 +1,745 @@ +/* + * Copyright (C) ST-Ericsson SA 2010 + * Code ported from Nomadik GPIO driver in ST-Ericsson Linux kernel code. + * The purpose is that GPIO config found in kernel should work by simply + * copy-paste it to U-boot. + * + * Ported to U-boot by: + * Copyright (C) 2010 Joakim Axelsson <joakim.axelsson AT stericsson.com> + ** + * License terms: GNU General Public License, version 2 + * Author: Rabin Vincent rabin.vincent@stericsson.com + */ + +#ifndef __DB8500_PINS_H +#define __DB8500_PINS_H + +#include <asm/arch/db8500_pincfg.h> + +#define GPIO0_GPIO PIN_CFG(0, GPIO) +#define GPIO0_U0_CTSn PIN_CFG(0, ALT_A) +#define GPIO0_TRIG_OUT PIN_CFG(0, ALT_B) +#define GPIO0_IP_TDO PIN_CFG(0, ALT_C) + +#define GPIO1_GPIO PIN_CFG(1, GPIO) +#define GPIO1_U0_RTSn PIN_CFG(1, ALT_A) +#define GPIO1_TRIG_IN PIN_CFG(1, ALT_B) +#define GPIO1_IP_TDI PIN_CFG(1, ALT_C) + +#define GPIO2_GPIO PIN_CFG(2, GPIO) +#define GPIO2_U0_RXD PIN_CFG(2, ALT_A) +#define GPIO2_NONE PIN_CFG(2, ALT_B) +#define GPIO2_IP_TMS PIN_CFG(2, ALT_C) + +#define GPIO3_GPIO PIN_CFG(3, GPIO) +#define GPIO3_U0_TXD PIN_CFG(3, ALT_A) +#define GPIO3_NONE PIN_CFG(3, ALT_B) +#define GPIO3_IP_TCK PIN_CFG(3, ALT_C) + +#define GPIO4_GPIO PIN_CFG(4, GPIO) +#define GPIO4_U1_RXD PIN_CFG(4, ALT_A) +#define GPIO4_I2C4_SCL PIN_CFG_PULL(4, ALT_B, UP) +#define GPIO4_IP_TRSTn PIN_CFG(4, ALT_C) + +#define GPIO5_GPIO PIN_CFG(5, GPIO) +#define GPIO5_U1_TXD PIN_CFG(5, ALT_A) +#define GPIO5_I2C4_SDA PIN_CFG_PULL(5, ALT_B, UP) +#define GPIO5_IP_GPIO6 PIN_CFG(5, ALT_C) + +#define GPIO6_GPIO PIN_CFG(6, GPIO) +#define GPIO6_U1_CTSn PIN_CFG(6, ALT_A) +#define GPIO6_I2C1_SCL PIN_CFG_PULL(6, ALT_B, UP) +#define GPIO6_IP_GPIO0 PIN_CFG(6, ALT_C) + +#define GPIO7_GPIO PIN_CFG(7, GPIO) +#define GPIO7_U1_RTSn PIN_CFG(7, ALT_A) +#define GPIO7_I2C1_SDA PIN_CFG_PULL(7, ALT_B, UP) +#define GPIO7_IP_GPIO1 PIN_CFG(7, ALT_C) + +#define GPIO8_GPIO PIN_CFG(8, GPIO) +#define GPIO8_IPI2C_SDA PIN_CFG_PULL(8, ALT_A, UP) +#define GPIO8_I2C2_SDA PIN_CFG_PULL(8, ALT_B, UP) + +#define GPIO9_GPIO PIN_CFG(9, GPIO) +#define GPIO9_IPI2C_SCL PIN_CFG_PULL(9, ALT_A, UP) +#define GPIO9_I2C2_SCL PIN_CFG_PULL(9, ALT_B, UP) + +#define GPIO10_GPIO PIN_CFG(10, GPIO) +#define GPIO10_IPI2C_SDA PIN_CFG_PULL(10, ALT_A, UP) +#define GPIO10_I2C2_SDA PIN_CFG_PULL(10, ALT_B, UP) +#define GPIO10_IP_GPIO3 PIN_CFG(10, ALT_C) + +#define GPIO11_GPIO PIN_CFG(11, GPIO) +#define GPIO11_IPI2C_SCL PIN_CFG_PULL(11, ALT_A, UP) +#define GPIO11_I2C2_SCL PIN_CFG_PULL(11, ALT_B, UP) +#define GPIO11_IP_GPIO2 PIN_CFG(11, ALT_C) + +#define GPIO12_GPIO PIN_CFG(12, GPIO) +#define GPIO12_MSP0_TXD PIN_CFG(12, ALT_A) +#define GPIO12_MSP0_RXD PIN_CFG(12, ALT_B) + +#define GPIO13_GPIO PIN_CFG(13, GPIO) +#define GPIO13_MSP0_TFS PIN_CFG(13, ALT_A) + +#define GPIO14_GPIO PIN_CFG(14, GPIO) +#define GPIO14_MSP0_TCK PIN_CFG(14, ALT_A) + +#define GPIO15_GPIO PIN_CFG(15, GPIO) +#define GPIO15_MSP0_RXD PIN_CFG(15, ALT_A) +#define GPIO15_MSP0_TXD PIN_CFG(15, ALT_B) + +#define GPIO16_GPIO PIN_CFG(16, GPIO) +#define GPIO16_MSP0_RFS PIN_CFG(16, ALT_A) +#define GPIO16_I2C1_SCL PIN_CFG_PULL(16, ALT_B, UP) +#define GPIO16_SLIM0_DAT PIN_CFG(16, ALT_C) + +#define GPIO17_GPIO PIN_CFG(17, GPIO) +#define GPIO17_MSP0_RCK PIN_CFG(17, ALT_A) +#define GPIO17_I2C1_SDA PIN_CFG_PULL(17, ALT_B, UP) +#define GPIO17_SLIM0_CLK PIN_CFG(17, ALT_C) + +#define GPIO18_GPIO PIN_CFG(18, GPIO) +#define GPIO18_MC0_CMDDIR PIN_CFG(18, ALT_A) +#define GPIO18_U2_RXD PIN_CFG(18, ALT_B) +#define GPIO18_MS_IEP PIN_CFG(18, ALT_C) + +#define GPIO19_GPIO PIN_CFG(19, GPIO) +#define GPIO19_MC0_DAT0DIR PIN_CFG(19, ALT_A) +#define GPIO19_U2_TXD PIN_CFG(19, ALT_B) +#define GPIO19_MS_DAT0DIR PIN_CFG(19, ALT_C) + +#define GPIO20_GPIO PIN_CFG(20, GPIO) +#define GPIO20_MC0_DAT2DIR PIN_CFG(20, ALT_A) +#define GPIO20_UARTMOD_TXD PIN_CFG(20, ALT_B) +#define GPIO20_IP_TRIGOUT PIN_CFG(20, ALT_C) + +#define GPIO21_GPIO PIN_CFG(21, GPIO) +#define GPIO21_MC0_DAT31DIR PIN_CFG(21, ALT_A) +#define GPIO21_MSP0_SCK PIN_CFG(21, ALT_B) +#define GPIO21_MS_DAT31DIR PIN_CFG(21, ALT_C) + +#define GPIO22_GPIO PIN_CFG(22, GPIO) +#define GPIO22_MC0_FBCLK PIN_CFG(22, ALT_A) +#define GPIO22_UARTMOD_RXD PIN_CFG(22, ALT_B) +#define GPIO22_MS_FBCLK PIN_CFG(22, ALT_C) + +#define GPIO23_GPIO PIN_CFG(23, GPIO) +#define GPIO23_MC0_CLK PIN_CFG(23, ALT_A) +#define GPIO23_STMMOD_CLK PIN_CFG(23, ALT_B) +#define GPIO23_MS_CLK PIN_CFG(23, ALT_C) + +#define GPIO24_GPIO PIN_CFG(24, GPIO) +#define GPIO24_MC0_CMD PIN_CFG(24, ALT_A) +#define GPIO24_UARTMOD_RXD PIN_CFG(24, ALT_B) +#define GPIO24_MS_BS PIN_CFG(24, ALT_C) + +#define GPIO25_GPIO PIN_CFG(25, GPIO) +#define GPIO25_MC0_DAT0 PIN_CFG(25, ALT_A) +#define GPIO25_STMMOD_DAT0 PIN_CFG(25, ALT_B) +#define GPIO25_MS_DAT0 PIN_CFG(25, ALT_C) + +#define GPIO26_GPIO PIN_CFG(26, GPIO) +#define GPIO26_MC0_DAT1 PIN_CFG(26, ALT_A) +#define GPIO26_STMMOD_DAT1 PIN_CFG(26, ALT_B) +#define GPIO26_MS_DAT1 PIN_CFG(26, ALT_C) + +#define GPIO27_GPIO PIN_CFG(27, GPIO) +#define GPIO27_MC0_DAT2 PIN_CFG(27, ALT_A) +#define GPIO27_STMMOD_DAT2 PIN_CFG(27, ALT_B) +#define GPIO27_MS_DAT2 PIN_CFG(27, ALT_C) + +#define GPIO28_GPIO PIN_CFG(28, GPIO) +#define GPIO28_MC0_DAT3 PIN_CFG(28, ALT_A) +#define GPIO28_STMMOD_DAT3 PIN_CFG(28, ALT_B) +#define GPIO28_MS_DAT3 PIN_CFG(28, ALT_C) + +#define GPIO29_GPIO PIN_CFG(29, GPIO) +#define GPIO29_MC0_DAT4 PIN_CFG(29, ALT_A) +#define GPIO29_SPI3_CLK PIN_CFG(29, ALT_B) +#define GPIO29_U2_RXD PIN_CFG(29, ALT_C) + +#define GPIO30_GPIO PIN_CFG(30, GPIO) +#define GPIO30_MC0_DAT5 PIN_CFG(30, ALT_A) +#define GPIO30_SPI3_RXD PIN_CFG(30, ALT_B) +#define GPIO30_U2_TXD PIN_CFG(30, ALT_C) + +#define GPIO31_GPIO PIN_CFG(31, GPIO) +#define GPIO31_MC0_DAT6 PIN_CFG(31, ALT_A) +#define GPIO31_SPI3_FRM PIN_CFG(31, ALT_B) +#define GPIO31_U2_CTSn PIN_CFG(31, ALT_C) + +#define GPIO32_GPIO PIN_CFG(32, GPIO) +#define GPIO32_MC0_DAT7 PIN_CFG(32, ALT_A) +#define GPIO32_SPI3_TXD PIN_CFG(32, ALT_B) +#define GPIO32_U2_RTSn PIN_CFG(32, ALT_C) + +#define GPIO33_GPIO PIN_CFG(33, GPIO) +#define GPIO33_MSP1_TXD PIN_CFG(33, ALT_A) +#define GPIO33_MSP1_RXD PIN_CFG(33, ALT_B) +#define GPIO33_U0_DTRn PIN_CFG(33, ALT_C) + +#define GPIO34_GPIO PIN_CFG(34, GPIO) +#define GPIO34_MSP1_TFS PIN_CFG(34, ALT_A) +#define GPIO34_NONE PIN_CFG(34, ALT_B) +#define GPIO34_U0_DCDn PIN_CFG(34, ALT_C) + +#define GPIO35_GPIO PIN_CFG(35, GPIO) +#define GPIO35_MSP1_TCK PIN_CFG(35, ALT_A) +#define GPIO35_NONE PIN_CFG(35, ALT_B) +#define GPIO35_U0_DSRn PIN_CFG(35, ALT_C) + +#define GPIO36_GPIO PIN_CFG(36, GPIO) +#define GPIO36_MSP1_RXD PIN_CFG(36, ALT_A) +#define GPIO36_MSP1_TXD PIN_CFG(36, ALT_B) +#define GPIO36_U0_RIn PIN_CFG(36, ALT_C) + +#define GPIO64_GPIO PIN_CFG(64, GPIO) +#define GPIO64_LCDB_DE PIN_CFG(64, ALT_A) +#define GPIO64_KP_O1 PIN_CFG(64, ALT_B) +#define GPIO64_IP_GPIO4 PIN_CFG(64, ALT_C) + +#define GPIO65_GPIO PIN_CFG(65, GPIO) +#define GPIO65_LCDB_HSO PIN_CFG(65, ALT_A) +#define GPIO65_KP_O0 PIN_CFG(65, ALT_B) +#define GPIO65_IP_GPIO5 PIN_CFG(65, ALT_C) + +#define GPIO66_GPIO PIN_CFG(66, GPIO) +#define GPIO66_LCDB_VSO PIN_CFG(66, ALT_A) +#define GPIO66_KP_I1 PIN_CFG(66, ALT_B) +#define GPIO66_IP_GPIO6 PIN_CFG(66, ALT_C) + +#define GPIO67_GPIO PIN_CFG(67, GPIO) +#define GPIO67_LCDB_CLK PIN_CFG(67, ALT_A) +#define GPIO67_KP_I0 PIN_CFG(67, ALT_B) +#define GPIO67_IP_GPIO7 PIN_CFG(67, ALT_C) + +#define GPIO68_GPIO PIN_CFG(68, GPIO) +#define GPIO68_LCD_VSI0 PIN_CFG(68, ALT_A) +#define GPIO68_KP_O7 PIN_CFG(68, ALT_B) +#define GPIO68_SM_CLE PIN_CFG(68, ALT_C) + +#define GPIO69_GPIO PIN_CFG(69, GPIO) +#define GPIO69_LCD_VSI1 PIN_CFG(69, ALT_A) +#define GPIO69_KP_I7 PIN_CFG(69, ALT_B) +#define GPIO69_SM_ALE PIN_CFG(69, ALT_C) + +#define GPIO70_GPIO PIN_CFG(70, GPIO) +#define GPIO70_LCD_D0 PIN_CFG(70, ALT_A) +#define GPIO70_KP_O5 PIN_CFG(70, ALT_B) +#define GPIO70_STMAPE_CLK PIN_CFG(70, ALT_C) + +#define GPIO71_GPIO PIN_CFG(71, GPIO) +#define GPIO71_LCD_D1 PIN_CFG(71, ALT_A) +#define GPIO71_KP_O4 PIN_CFG(71, ALT_B) +#define GPIO71_STMAPE_DAT3 PIN_CFG(71, ALT_C) + +#define GPIO72_GPIO PIN_CFG(72, GPIO) +#define GPIO72_LCD_D2 PIN_CFG(72, ALT_A) +#define GPIO72_KP_O3 PIN_CFG(72, ALT_B) +#define GPIO72_STMAPE_DAT2 PIN_CFG(72, ALT_C) + +#define GPIO73_GPIO PIN_CFG(73, GPIO) +#define GPIO73_LCD_D3 PIN_CFG(73, ALT_A) +#define GPIO73_KP_O2 PIN_CFG(73, ALT_B) +#define GPIO73_STMAPE_DAT1 PIN_CFG(73, ALT_C) + +#define GPIO74_GPIO PIN_CFG(74, GPIO) +#define GPIO74_LCD_D4 PIN_CFG(74, ALT_A) +#define GPIO74_KP_I5 PIN_CFG(74, ALT_B) +#define GPIO74_STMAPE_DAT0 PIN_CFG(74, ALT_C) + +#define GPIO75_GPIO PIN_CFG(75, GPIO) +#define GPIO75_LCD_D5 PIN_CFG(75, ALT_A) +#define GPIO75_KP_I4 PIN_CFG(75, ALT_B) +#define GPIO75_U2_RXD PIN_CFG(75, ALT_C) + +#define GPIO76_GPIO PIN_CFG(76, GPIO) +#define GPIO76_LCD_D6 PIN_CFG(76, ALT_A) +#define GPIO76_KP_I3 PIN_CFG(76, ALT_B) +#define GPIO76_U2_TXD PIN_CFG(76, ALT_C) + +#define GPIO77_GPIO PIN_CFG(77, GPIO) +#define GPIO77_LCD_D7 PIN_CFG(77, ALT_A) +#define GPIO77_KP_I2 PIN_CFG(77, ALT_B) +#define GPIO77_NONE PIN_CFG(77, ALT_C) + +#define GPIO78_GPIO PIN_CFG(78, GPIO) +#define GPIO78_LCD_D8 PIN_CFG(78, ALT_A) +#define GPIO78_KP_O6 PIN_CFG(78, ALT_B) +#define GPIO78_IP_GPIO2 PIN_CFG(78, ALT_C) + +#define GPIO79_GPIO PIN_CFG(79, GPIO) +#define GPIO79_LCD_D9 PIN_CFG(79, ALT_A) +#define GPIO79_KP_I6 PIN_CFG(79, ALT_B) +#define GPIO79_IP_GPIO3 PIN_CFG(79, ALT_C) + +#define GPIO80_GPIO PIN_CFG(80, GPIO) +#define GPIO80_LCD_D10 PIN_CFG(80, ALT_A) +#define GPIO80_KP_SKA0 PIN_CFG(80, ALT_B) +#define GPIO80_IP_GPIO4 PIN_CFG(80, ALT_C) + +#define GPIO81_GPIO PIN_CFG(81, GPIO) +#define GPIO81_LCD_D11 PIN_CFG(81, ALT_A) +#define GPIO81_KP_SKB0 PIN_CFG(81, ALT_B) +#define GPIO81_IP_GPIO5 PIN_CFG(81, ALT_C) + +#define GPIO82_GPIO PIN_CFG(82, GPIO) +#define GPIO82_LCD_D12 PIN_CFG(82, ALT_A) +#define GPIO82_KP_O5 PIN_CFG(82, ALT_B) + +#define GPIO83_GPIO PIN_CFG(83, GPIO) +#define GPIO83_LCD_D13 PIN_CFG(83, ALT_A) +#define GPIO83_KP_O4 PIN_CFG(83, ALT_B) + +#define GPIO84_GPIO PIN_CFG_PULL(84, GPIO, UP) +#define GPIO84_LCD_D14 PIN_CFG(84, ALT_A) +#define GPIO84_KP_I5 PIN_CFG(84, ALT_B) + +#define GPIO85_GPIO PIN_CFG(85, GPIO) +#define GPIO85_LCD_D15 PIN_CFG(85, ALT_A) +#define GPIO85_KP_I4 PIN_CFG(85, ALT_B) + +#define GPIO86_GPIO PIN_CFG(86, GPIO) +#define GPIO86_LCD_D16 PIN_CFG(86, ALT_A) +#define GPIO86_SM_ADQ0 PIN_CFG(86, ALT_B) +#define GPIO86_MC5_DAT0 PIN_CFG(86, ALT_C) + +#define GPIO87_GPIO PIN_CFG(87, GPIO) +#define GPIO87_LCD_D17 PIN_CFG(87, ALT_A) +#define GPIO87_SM_ADQ1 PIN_CFG(87, ALT_B) +#define GPIO87_MC5_DAT1 PIN_CFG(87, ALT_C) + +#define GPIO88_GPIO PIN_CFG(88, GPIO) +#define GPIO88_LCD_D18 PIN_CFG(88, ALT_A) +#define GPIO88_SM_ADQ2 PIN_CFG(88, ALT_B) +#define GPIO88_MC5_DAT2 PIN_CFG(88, ALT_C) + +#define GPIO89_GPIO PIN_CFG(89, GPIO) +#define GPIO89_LCD_D19 PIN_CFG(89, ALT_A) +#define GPIO89_SM_ADQ3 PIN_CFG(89, ALT_B) +#define GPIO89_MC5_DAT3 PIN_CFG(89, ALT_C) + +#define GPIO90_GPIO PIN_CFG(90, GPIO) +#define GPIO90_LCD_D20 PIN_CFG(90, ALT_A) +#define GPIO90_SM_ADQ4 PIN_CFG(90, ALT_B) +#define GPIO90_MC5_CMD PIN_CFG(90, ALT_C) + +#define GPIO91_GPIO PIN_CFG(91, GPIO) +#define GPIO91_LCD_D21 PIN_CFG(91, ALT_A) +#define GPIO91_SM_ADQ5 PIN_CFG(91, ALT_B) +#define GPIO91_MC5_FBCLK PIN_CFG(91, ALT_C) + +#define GPIO92_GPIO PIN_CFG(92, GPIO) +#define GPIO92_LCD_D22 PIN_CFG(92, ALT_A) +#define GPIO92_SM_ADQ6 PIN_CFG(92, ALT_B) +#define GPIO92_MC5_CLK PIN_CFG(92, ALT_C) + +#define GPIO93_GPIO PIN_CFG(93, GPIO) +#define GPIO93_LCD_D23 PIN_CFG(93, ALT_A) +#define GPIO93_SM_ADQ7 PIN_CFG(93, ALT_B) +#define GPIO93_MC5_DAT4 PIN_CFG(93, ALT_C) + +#define GPIO94_GPIO PIN_CFG(94, GPIO) +#define GPIO94_KP_O7 PIN_CFG(94, ALT_A) +#define GPIO94_SM_ADVn PIN_CFG(94, ALT_B) +#define GPIO94_MC5_DAT5 PIN_CFG(94, ALT_C) + +#define GPIO95_GPIO PIN_CFG(95, GPIO) +#define GPIO95_KP_I7 PIN_CFG(95, ALT_A) +#define GPIO95_SM_CS0n PIN_CFG(95, ALT_B) +#define GPIO95_SM_PS0n PIN_CFG(95, ALT_C) + +#define GPIO96_GPIO PIN_CFG(96, GPIO) +#define GPIO96_KP_O6 PIN_CFG(96, ALT_A) +#define GPIO96_SM_OEn PIN_CFG(96, ALT_B) +#define GPIO96_MC5_DAT6 PIN_CFG(96, ALT_C) + +#define GPIO97_GPIO PIN_CFG(97, GPIO) +#define GPIO97_KP_I6 PIN_CFG(97, ALT_A) +#define GPIO97_SM_WEn PIN_CFG(97, ALT_B) +#define GPIO97_MC5_DAT7 PIN_CFG(97, ALT_C) + +#define GPIO128_GPIO PIN_CFG(128, GPIO) +#define GPIO128_MC2_CLK PIN_CFG(128, ALT_A) +#define GPIO128_SM_CKO PIN_CFG(128, ALT_B) + +#define GPIO129_GPIO PIN_CFG(129, GPIO) +#define GPIO129_MC2_CMD PIN_CFG(129, ALT_A) +#define GPIO129_SM_WAIT0n PIN_CFG(129, ALT_B) + +#define GPIO130_GPIO PIN_CFG(130, GPIO) +#define GPIO130_MC2_FBCLK PIN_CFG(130, ALT_A) +#define GPIO130_SM_FBCLK PIN_CFG(130, ALT_B) +#define GPIO130_MC2_RSTN PIN_CFG(130, ALT_C) + +#define GPIO131_GPIO PIN_CFG(131, GPIO) +#define GPIO131_MC2_DAT0 PIN_CFG(131, ALT_A) +#define GPIO131_SM_ADQ8 PIN_CFG(131, ALT_B) + +#define GPIO132_GPIO PIN_CFG(132, GPIO) +#define GPIO132_MC2_DAT1 PIN_CFG(132, ALT_A) +#define GPIO132_SM_ADQ9 PIN_CFG(132, ALT_B) + +#define GPIO133_GPIO PIN_CFG(133, GPIO) +#define GPIO133_MC2_DAT2 PIN_CFG(133, ALT_A) +#define GPIO133_SM_ADQ10 PIN_CFG(133, ALT_B) + +#define GPIO134_GPIO PIN_CFG(134, GPIO) +#define GPIO134_MC2_DAT3 PIN_CFG(134, ALT_A) +#define GPIO134_SM_ADQ11 PIN_CFG(134, ALT_B) + +#define GPIO135_GPIO PIN_CFG(135, GPIO) +#define GPIO135_MC2_DAT4 PIN_CFG(135, ALT_A) +#define GPIO135_SM_ADQ12 PIN_CFG(135, ALT_B) + +#define GPIO136_GPIO PIN_CFG(136, GPIO) +#define GPIO136_MC2_DAT5 PIN_CFG(136, ALT_A) +#define GPIO136_SM_ADQ13 PIN_CFG(136, ALT_B) + +#define GPIO137_GPIO PIN_CFG(137, GPIO) +#define GPIO137_MC2_DAT6 PIN_CFG(137, ALT_A) +#define GPIO137_SM_ADQ14 PIN_CFG(137, ALT_B) + +#define GPIO138_GPIO PIN_CFG(138, GPIO) +#define GPIO138_MC2_DAT7 PIN_CFG(138, ALT_A) +#define GPIO138_SM_ADQ15 PIN_CFG(138, ALT_B) + +#define GPIO139_GPIO PIN_CFG(139, GPIO) +#define GPIO139_SSP1_RXD PIN_CFG(139, ALT_A) +#define GPIO139_SM_WAIT1n PIN_CFG(139, ALT_B) +#define GPIO139_KP_O8 PIN_CFG(139, ALT_C) + +#define GPIO140_GPIO PIN_CFG(140, GPIO) +#define GPIO140_SSP1_TXD PIN_CFG(140, ALT_A) +#define GPIO140_IP_GPIO7 PIN_CFG(140, ALT_B) +#define GPIO140_KP_SKA1 PIN_CFG(140, ALT_C) + +#define GPIO141_GPIO PIN_CFG(141, GPIO) +#define GPIO141_SSP1_CLK PIN_CFG(141, ALT_A) +#define GPIO141_IP_GPIO2 PIN_CFG(141, ALT_B) +#define GPIO141_KP_O9 PIN_CFG(141, ALT_C) + +#define GPIO142_GPIO PIN_CFG(142, GPIO) +#define GPIO142_SSP1_FRM PIN_CFG(142, ALT_A) +#define GPIO142_IP_GPIO3 PIN_CFG(142, ALT_B) +#define GPIO142_KP_SKB1 PIN_CFG(142, ALT_C) + +#define GPIO143_GPIO PIN_CFG(143, GPIO) +#define GPIO143_SSP0_CLK PIN_CFG(143, ALT_A) + +#define GPIO144_GPIO PIN_CFG(144, GPIO) +#define GPIO144_SSP0_FRM PIN_CFG(144, ALT_A) + +#define GPIO145_GPIO PIN_CFG(145, GPIO) +#define GPIO145_SSP0_RXD PIN_CFG(145, ALT_A) + +#define GPIO146_GPIO PIN_CFG(146, GPIO) +#define GPIO146_SSP0_TXD PIN_CFG(146, ALT_A) + +#define GPIO147_GPIO PIN_CFG(147, GPIO) +#define GPIO147_I2C0_SCL PIN_CFG_PULL(147, ALT_A, UP) + +#define GPIO148_GPIO PIN_CFG(148, GPIO) +#define GPIO148_I2C0_SDA PIN_CFG_PULL(148, ALT_A, UP) + +#define GPIO149_GPIO PIN_CFG(149, GPIO) +#define GPIO149_IP_GPIO0 PIN_CFG(149, ALT_A) +#define GPIO149_SM_CS1n PIN_CFG(149, ALT_B) +#define GPIO149_SM_PS1n PIN_CFG(149, ALT_C) + +#define GPIO150_GPIO PIN_CFG(150, GPIO) +#define GPIO150_IP_GPIO1 PIN_CFG(150, ALT_A) +#define GPIO150_LCDA_CLK PIN_CFG(150, ALT_B) + +#define GPIO151_GPIO PIN_CFG(151, GPIO) +#define GPIO151_KP_SKA0 PIN_CFG(151, ALT_A) +#define GPIO151_LCD_VSI0 PIN_CFG(151, ALT_B) +#define GPIO151_KP_O8 PIN_CFG(151, ALT_C) + +#define GPIO152_GPIO PIN_CFG(152, GPIO) +#define GPIO152_KP_SKB0 PIN_CFG(152, ALT_A) +#define GPIO152_LCD_VSI1 PIN_CFG(152, ALT_B) +#define GPIO152_KP_O9 PIN_CFG(152, ALT_C) + +#define GPIO153_GPIO PIN_CFG(153, GPIO) +#define GPIO153_KP_I7 PIN_CFG_PULL(153, ALT_A, DOWN) +#define GPIO153_LCD_D24 PIN_CFG(153, ALT_B) +#define GPIO153_U2_RXD PIN_CFG(153, ALT_C) + +#define GPIO154_GPIO PIN_CFG(154, GPIO) +#define GPIO154_KP_I6 PIN_CFG_PULL(154, ALT_A, DOWN) +#define GPIO154_LCD_D25 PIN_CFG(154, ALT_B) +#define GPIO154_U2_TXD PIN_CFG(154, ALT_C) + +#define GPIO155_GPIO PIN_CFG(155, GPIO) +#define GPIO155_KP_I5 PIN_CFG_PULL(155, ALT_A, DOWN) +#define GPIO155_LCD_D26 PIN_CFG(155, ALT_B) +#define GPIO155_STMAPE_CLK PIN_CFG(155, ALT_C) + +#define GPIO156_GPIO PIN_CFG(156, GPIO) +#define GPIO156_KP_I4 PIN_CFG_PULL(156, ALT_A, DOWN) +#define GPIO156_LCD_D27 PIN_CFG(156, ALT_B) +#define GPIO156_STMAPE_DAT3 PIN_CFG(156, ALT_C) + +#define GPIO157_GPIO PIN_CFG(157, GPIO) +#define GPIO157_KP_O7 PIN_CFG_PULL(157, ALT_A, UP) +#define GPIO157_LCD_D28 PIN_CFG(157, ALT_B) +#define GPIO157_STMAPE_DAT2 PIN_CFG(157, ALT_C) + +#define GPIO158_GPIO PIN_CFG(158, GPIO) +#define GPIO158_KP_O6 PIN_CFG_PULL(158, ALT_A, UP) +#define GPIO158_LCD_D29 PIN_CFG(158, ALT_B) +#define GPIO158_STMAPE_DAT1 PIN_CFG(158, ALT_C) + +#define GPIO159_GPIO PIN_CFG(159, GPIO) +#define GPIO159_KP_O5 PIN_CFG_PULL(159, ALT_A, UP) +#define GPIO159_LCD_D30 PIN_CFG(159, ALT_B) +#define GPIO159_STMAPE_DAT0 PIN_CFG(159, ALT_C) + +#define GPIO160_GPIO PIN_CFG(160, GPIO) +#define GPIO160_KP_O4 PIN_CFG_PULL(160, ALT_A, UP) +#define GPIO160_LCD_D31 PIN_CFG(160, ALT_B) +#define GPIO160_NONE PIN_CFG(160, ALT_C) + +#define GPIO161_GPIO PIN_CFG(161, GPIO) +#define GPIO161_KP_I3 PIN_CFG_PULL(161, ALT_A, DOWN) +#define GPIO161_LCD_D32 PIN_CFG(161, ALT_B) +#define GPIO161_UARTMOD_RXD PIN_CFG(161, ALT_C) + +#define GPIO162_GPIO PIN_CFG(162, GPIO) +#define GPIO162_KP_I2 PIN_CFG_PULL(162, ALT_A, DOWN) +#define GPIO162_LCD_D33 PIN_CFG(162, ALT_B) +#define GPIO162_UARTMOD_TXD PIN_CFG(162, ALT_C) + +#define GPIO163_GPIO PIN_CFG(163, GPIO) +#define GPIO163_KP_I1 PIN_CFG_PULL(163, ALT_A, DOWN) +#define GPIO163_LCD_D34 PIN_CFG(163, ALT_B) +#define GPIO163_STMMOD_CLK PIN_CFG(163, ALT_C) + +#define GPIO164_GPIO PIN_CFG(164, GPIO) +#define GPIO164_KP_I0 PIN_CFG_PULL(164, ALT_A, UP) +#define GPIO164_LCD_D35 PIN_CFG(164, ALT_B) +#define GPIO164_STMMOD_DAT3 PIN_CFG(164, ALT_C) + +#define GPIO165_GPIO PIN_CFG(165, GPIO) +#define GPIO165_KP_O3 PIN_CFG_PULL(165, ALT_A, UP) +#define GPIO165_LCD_D36 PIN_CFG(165, ALT_B) +#define GPIO165_STMMOD_DAT2 PIN_CFG(165, ALT_C) + +#define GPIO166_GPIO PIN_CFG(166, GPIO) +#define GPIO166_KP_O2 PIN_CFG_PULL(166, ALT_A, UP) +#define GPIO166_LCD_D37 PIN_CFG(166, ALT_B) +#define GPIO166_STMMOD_DAT1 PIN_CFG(166, ALT_C) + +#define GPIO167_GPIO PIN_CFG(167, GPIO) +#define GPIO167_KP_O1 PIN_CFG_PULL(167, ALT_A, UP) +#define GPIO167_LCD_D38 PIN_CFG(167, ALT_B) +#define GPIO167_STMMOD_DAT0 PIN_CFG(167, ALT_C) + +#define GPIO168_GPIO PIN_CFG(168, GPIO) +#define GPIO168_KP_O0 PIN_CFG_PULL(168, ALT_A, UP) +#define GPIO168_LCD_D39 PIN_CFG(168, ALT_B) +#define GPIO168_NONE PIN_CFG(168, ALT_C) + +#define GPIO169_GPIO PIN_CFG(169, GPIO) +#define GPIO169_RF_PURn PIN_CFG(169, ALT_A) +#define GPIO169_LCDA_DE PIN_CFG(169, ALT_B) +#define GPIO169_USBSIM_PDC PIN_CFG(169, ALT_C) + +#define GPIO170_GPIO PIN_CFG(170, GPIO) +#define GPIO170_MODEM_STATE PIN_CFG(170, ALT_A) +#define GPIO170_LCDA_VSO PIN_CFG(170, ALT_B) +#define GPIO170_KP_SKA1 PIN_CFG(170, ALT_C) + +#define GPIO171_GPIO PIN_CFG(171, GPIO) +#define GPIO171_MODEM_PWREN PIN_CFG(171, ALT_A) +#define GPIO171_LCDA_HSO PIN_CFG(171, ALT_B) +#define GPIO171_KP_SKB1 PIN_CFG(171, ALT_C) + +#define GPIO192_GPIO PIN_CFG(192, GPIO) +#define GPIO192_MSP2_SCK PIN_CFG(192, ALT_A) + +#define GPIO193_GPIO PIN_CFG(193, GPIO) +#define GPIO193_MSP2_TXD PIN_CFG(193, ALT_A) + +#define GPIO194_GPIO PIN_CFG(194, GPIO) +#define GPIO194_MSP2_TCK PIN_CFG(194, ALT_A) + +#define GPIO195_GPIO PIN_CFG(195, GPIO) +#define GPIO195_MSP2_TFS PIN_CFG(195, ALT_A) + +#define GPIO196_GPIO PIN_CFG(196, GPIO) +#define GPIO196_MSP2_RXD PIN_CFG(196, ALT_A) + +#define GPIO197_GPIO PIN_CFG(197, GPIO) +#define GPIO197_MC4_DAT3 PIN_CFG(197, ALT_A) + +#define GPIO198_GPIO PIN_CFG(198, GPIO) +#define GPIO198_MC4_DAT2 PIN_CFG(198, ALT_A) + +#define GPIO199_GPIO PIN_CFG(199, GPIO) +#define GPIO199_MC4_DAT1 PIN_CFG(199, ALT_A) + +#define GPIO200_GPIO PIN_CFG(200, GPIO) +#define GPIO200_MC4_DAT0 PIN_CFG(200, ALT_A) + +#define GPIO201_GPIO PIN_CFG(201, GPIO) +#define GPIO201_MC4_CMD PIN_CFG(201, ALT_A) + +#define GPIO202_GPIO PIN_CFG(202, GPIO) +#define GPIO202_MC4_FBCLK PIN_CFG(202, ALT_A) +#define GPIO202_PWL PIN_CFG(202, ALT_B) +#define GPIO202_MC4_RSTN PIN_CFG(202, ALT_C) + +#define GPIO203_GPIO PIN_CFG(203, GPIO) +#define GPIO203_MC4_CLK PIN_CFG(203, ALT_A) + +#define GPIO204_GPIO PIN_CFG(204, GPIO) +#define GPIO204_MC4_DAT7 PIN_CFG(204, ALT_A) + +#define GPIO205_GPIO PIN_CFG(205, GPIO) +#define GPIO205_MC4_DAT6 PIN_CFG(205, ALT_A) + +#define GPIO206_GPIO PIN_CFG(206, GPIO) +#define GPIO206_MC4_DAT5 PIN_CFG(206, ALT_A) + +#define GPIO207_GPIO PIN_CFG(207, GPIO) +#define GPIO207_MC4_DAT4 PIN_CFG(207, ALT_A) + +#define GPIO208_GPIO PIN_CFG(208, GPIO) +#define GPIO208_MC1_CLK PIN_CFG(208, ALT_A) + +#define GPIO209_GPIO PIN_CFG(209, GPIO) +#define GPIO209_MC1_FBCLK PIN_CFG(209, ALT_A) +#define GPIO209_SPI1_CLK PIN_CFG(209, ALT_B) + +#define GPIO210_GPIO PIN_CFG(210, GPIO) +#define GPIO210_MC1_CMD PIN_CFG(210, ALT_A) + +#define GPIO211_GPIO PIN_CFG(211, GPIO) +#define GPIO211_MC1_DAT0 PIN_CFG(211, ALT_A) + +#define GPIO212_GPIO PIN_CFG(212, GPIO) +#define GPIO212_MC1_DAT1 PIN_CFG(212, ALT_A) +#define GPIO212_SPI1_FRM PIN_CFG(212, ALT_B) + +#define GPIO213_GPIO PIN_CFG(213, GPIO) +#define GPIO213_MC1_DAT2 PIN_CFG(213, ALT_A) +#define GPIO213_SPI1_TXD PIN_CFG(213, ALT_B) + +#define GPIO214_GPIO PIN_CFG(214, GPIO) +#define GPIO214_MC1_DAT3 PIN_CFG(214, ALT_A) +#define GPIO214_SPI1_RXD PIN_CFG(214, ALT_B) + +#define GPIO215_GPIO PIN_CFG(215, GPIO) +#define GPIO215_MC1_CMDDIR PIN_CFG(215, ALT_A) +#define GPIO215_MC3_DAT2DIR PIN_CFG(215, ALT_B) +#define GPIO215_CLKOUT1 PIN_CFG(215, ALT_C) + +#define GPIO216_GPIO PIN_CFG(216, GPIO) +#define GPIO216_MC1_DAT2DIR PIN_CFG(216, ALT_A) +#define GPIO216_MC3_CMDDIR PIN_CFG(216, ALT_B) +#define GPIO216_I2C3_SDA PIN_CFG_PULL(216, ALT_C, UP) + +#define GPIO217_GPIO PIN_CFG(217, GPIO) +#define GPIO217_MC1_DAT0DIR PIN_CFG(217, ALT_A) +#define GPIO217_MC3_DAT31DIR PIN_CFG(217, ALT_B) +#define GPIO217_CLKOUT2 PIN_CFG(217, ALT_C) + +#define GPIO218_GPIO PIN_CFG(218, GPIO) +#define GPIO218_MC1_DAT31DIR PIN_CFG(218, ALT_A) +#define GPIO218_MC3_DAT0DIR PIN_CFG(218, ALT_B) +#define GPIO218_I2C3_SCL PIN_CFG_PULL(218, ALT_C, UP) + +#define GPIO219_GPIO PIN_CFG(219, GPIO) +#define GPIO219_HSIR_FLA0 PIN_CFG(219, ALT_A) +#define GPIO219_MC3_CLK PIN_CFG(219, ALT_B) + +#define GPIO220_GPIO PIN_CFG(220, GPIO) +#define GPIO220_HSIR_DAT0 PIN_CFG(220, ALT_A) +#define GPIO220_MC3_FBCLK PIN_CFG(220, ALT_B) +#define GPIO220_SPI0_CLK PIN_CFG(220, ALT_C) + +#define GPIO221_GPIO PIN_CFG(221, GPIO) +#define GPIO221_HSIR_RDY0 PIN_CFG(221, ALT_A) +#define GPIO221_MC3_CMD PIN_CFG(221, ALT_B) + +#define GPIO222_GPIO PIN_CFG(222, GPIO) +#define GPIO222_HSIT_FLA0 PIN_CFG(222, ALT_A) +#define GPIO222_MC3_DAT0 PIN_CFG(222, ALT_B) + +#define GPIO223_GPIO PIN_CFG(223, GPIO) +#define GPIO223_HSIT_DAT0 PIN_CFG(223, ALT_A) +#define GPIO223_MC3_DAT1 PIN_CFG(223, ALT_B) +#define GPIO223_SPI0_FRM PIN_CFG(223, ALT_C) + +#define GPIO224_GPIO PIN_CFG(224, GPIO) +#define GPIO224_HSIT_RDY0 PIN_CFG(224, ALT_A) +#define GPIO224_MC3_DAT2 PIN_CFG(224, ALT_B) +#define GPIO224_SPI0_TXD PIN_CFG(224, ALT_C) + +#define GPIO225_GPIO PIN_CFG(225, GPIO) +#define GPIO225_HSIT_CAWAKE0 PIN_CFG(225, ALT_A) +#define GPIO225_MC3_DAT3 PIN_CFG(225, ALT_B) +#define GPIO225_SPI0_RXD PIN_CFG(225, ALT_C) + +#define GPIO226_GPIO PIN_CFG(226, GPIO) +#define GPIO226_HSIT_ACWAKE0 PIN_CFG(226, ALT_A) +#define GPIO226_PWL PIN_CFG(226, ALT_B) +#define GPIO226_USBSIM_PDC PIN_CFG(226, ALT_C) + +#define GPIO227_GPIO PIN_CFG(227, GPIO) +#define GPIO227_CLKOUT1 PIN_CFG(227, ALT_A) + +#define GPIO228_GPIO PIN_CFG(228, GPIO) +#define GPIO228_CLKOUT2 PIN_CFG(228, ALT_A) + +#define GPIO229_GPIO PIN_CFG(229, GPIO) +#define GPIO229_CLKOUT1 PIN_CFG(229, ALT_A) +#define GPIO229_PWL PIN_CFG(229, ALT_B) +#define GPIO229_I2C3_SDA PIN_CFG_PULL(229, ALT_C, UP) + +#define GPIO230_GPIO PIN_CFG(230, GPIO) +#define GPIO230_CLKOUT2 PIN_CFG(230, ALT_A) +#define GPIO230_PWL PIN_CFG(230, ALT_B) +#define GPIO230_I2C3_SCL PIN_CFG_PULL(230, ALT_C, UP) + +#define GPIO256_GPIO PIN_CFG(256, GPIO) +#define GPIO256_USB_NXT PIN_CFG(256, ALT_A) + +#define GPIO257_GPIO PIN_CFG(257, GPIO) +#define GPIO257_USB_STP PIN_CFG(257, ALT_A) + +#define GPIO258_GPIO PIN_CFG(258, GPIO) +#define GPIO258_USB_XCLK PIN_CFG(258, ALT_A) +#define GPIO258_NONE PIN_CFG(258, ALT_B) +#define GPIO258_DDR_TRIG PIN_CFG(258, ALT_C) + +#define GPIO259_GPIO PIN_CFG(259, GPIO) +#define GPIO259_USB_DIR PIN_CFG(259, ALT_A) + +#define GPIO260_GPIO PIN_CFG(260, GPIO) +#define GPIO260_USB_DAT7 PIN_CFG(260, ALT_A) + +#define GPIO261_GPIO PIN_CFG(261, GPIO) +#define GPIO261_USB_DAT6 PIN_CFG(261, ALT_A) + +#define GPIO262_GPIO PIN_CFG(262, GPIO) +#define GPIO262_USB_DAT5 PIN_CFG(262, ALT_A) + +#define GPIO263_GPIO PIN_CFG(263, GPIO) +#define GPIO263_USB_DAT4 PIN_CFG(263, ALT_A) + +#define GPIO264_GPIO PIN_CFG(264, GPIO) +#define GPIO264_USB_DAT3 PIN_CFG(264, ALT_A) + +#define GPIO265_GPIO PIN_CFG(265, GPIO) +#define GPIO265_USB_DAT2 PIN_CFG(265, ALT_A) + +#define GPIO266_GPIO PIN_CFG(266, GPIO) +#define GPIO266_USB_DAT1 PIN_CFG(266, ALT_A) + +#define GPIO267_GPIO PIN_CFG(267, GPIO) +#define GPIO267_USB_DAT0 PIN_CFG(267, ALT_A) + +#endif diff --git a/board/st-ericsson/snowball/snowball.c b/board/st-ericsson/snowball/snowball.c new file mode 100644 index 0000000..4bcc649 --- /dev/null +++ b/board/st-ericsson/snowball/snowball.c @@ -0,0 +1,166 @@ +/* + * Copyright (C) ST-Ericsson SA 2009 + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <config.h> +#include <common.h> +#include <malloc.h> +#include <i2c.h> +#include <mmc.h> +#include <asm/types.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/db8500_pincfg.h> + +#include "db8500_pins.h" + +/* + * Get a global data pointer + */ +DECLARE_GLOBAL_DATA_PTR; + +/* + * Memory controller register + */ +#define DMC_BASE_ADDR 0x80156000 +#define DMC_CTL_97 (DMC_BASE_ADDR + 0x184) + +/* + * GPIO pin config common for MOP500/HREF boards + */ +unsigned long gpio_cfg_common[] = { + /* I2C */ + GPIO147_I2C0_SCL, + GPIO148_I2C0_SDA, + GPIO16_I2C1_SCL, + GPIO17_I2C1_SDA, + GPIO10_I2C2_SDA, + GPIO11_I2C2_SCL, + GPIO229_I2C3_SDA, + GPIO230_I2C3_SCL, + + /* SSP0, to AB8500 */ + GPIO143_SSP0_CLK, + GPIO144_SSP0_FRM, + GPIO145_SSP0_RXD | PIN_PULL_DOWN, + GPIO146_SSP0_TXD, + + /* MMC0 (MicroSD card) */ + GPIO18_MC0_CMDDIR | PIN_OUTPUT_HIGH, + GPIO19_MC0_DAT0DIR | PIN_OUTPUT_HIGH, + GPIO20_MC0_DAT2DIR | PIN_OUTPUT_HIGH, + GPIO21_MC0_DAT31DIR | PIN_OUTPUT_HIGH, + GPIO22_MC0_FBCLK | PIN_INPUT_NOPULL, + GPIO23_MC0_CLK | PIN_OUTPUT_LOW, + GPIO24_MC0_CMD | PIN_INPUT_PULLUP, + GPIO25_MC0_DAT0 | PIN_INPUT_PULLUP, + GPIO26_MC0_DAT1 | PIN_INPUT_PULLUP, + GPIO27_MC0_DAT2 | PIN_INPUT_PULLUP, + GPIO28_MC0_DAT3 | PIN_INPUT_PULLUP, + + /* MMC4 (On-board eMMC) */ + GPIO197_MC4_DAT3 | PIN_INPUT_PULLUP, + GPIO198_MC4_DAT2 | PIN_INPUT_PULLUP, + GPIO199_MC4_DAT1 | PIN_INPUT_PULLUP, + GPIO200_MC4_DAT0 | PIN_INPUT_PULLUP, + GPIO201_MC4_CMD | PIN_INPUT_PULLUP, + GPIO202_MC4_FBCLK | PIN_INPUT_NOPULL, + GPIO203_MC4_CLK | PIN_OUTPUT_LOW, + GPIO204_MC4_DAT7 | PIN_INPUT_PULLUP, + GPIO205_MC4_DAT6 | PIN_INPUT_PULLUP, + GPIO206_MC4_DAT5 | PIN_INPUT_PULLUP, + GPIO207_MC4_DAT4 | PIN_INPUT_PULLUP, + + /* UART2, console */ + GPIO29_U2_RXD | PIN_INPUT_PULLUP, + GPIO30_U2_TXD | PIN_OUTPUT_HIGH, + GPIO31_U2_CTSn | PIN_INPUT_PULLUP, + GPIO32_U2_RTSn | PIN_OUTPUT_HIGH, + + /* + * USB, pin 256-267 USB, Is probably already setup correctly from + * BootROM/boot stages, but we don't trust that and set it up anyway + */ + GPIO256_USB_NXT, + GPIO257_USB_STP, + GPIO258_USB_XCLK, + GPIO259_USB_DIR, + GPIO260_USB_DAT7, + GPIO261_USB_DAT6, + GPIO262_USB_DAT5, + GPIO263_USB_DAT4, + GPIO264_USB_DAT3, + GPIO265_USB_DAT2, + GPIO266_USB_DAT1, + GPIO267_USB_DAT0, +}; + +unsigned long gpio_cfg_snowball[] = { + /* MMC0 (MicroSD card) */ + GPIO217_GPIO | PIN_OUTPUT_HIGH, /* MMC_EN */ + GPIO218_GPIO | PIN_INPUT_NOPULL, /* MMC_CD */ + GPIO228_GPIO | PIN_OUTPUT_HIGH, /* SD_SEL */ + + /* eMMC */ + GPIO167_GPIO | PIN_OUTPUT_HIGH, /* RSTn_MLC */ + + /* LAN */ + GPIO131_SM_ADQ8, + GPIO132_SM_ADQ9, + GPIO133_SM_ADQ10, + GPIO134_SM_ADQ11, + GPIO135_SM_ADQ12, + GPIO136_SM_ADQ13, + GPIO137_SM_ADQ14, + GPIO138_SM_ADQ15, + + /* RSTn_LAN */ + GPIO141_GPIO | PIN_OUTPUT_HIGH, +}; + +/* + * Miscellaneous platform dependent initialisations + */ + +int board_init(void) +{ + /* + * Setup board (bd) and board-info (bi). + * bi_arch_number: Unique id for this board. It will passed in r1 to + * Linux startup code and is the machine_id. + * bi_boot_params: Where this board expects params. + */ + gd->bd->bi_arch_number = MACH_TYPE_SNOWBALL; + gd->bd->bi_boot_params = 0x00000100; + + /* Configure GPIO pins needed by U-boot */ + db8500_gpio_config_pins(gpio_cfg_common, ARRAY_SIZE(gpio_cfg_common)); + + db8500_gpio_config_pins(gpio_cfg_snowball, + ARRAY_SIZE(gpio_cfg_snowball)); + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->ram_size = gd->bd->bi_dram[0].size = + get_ram_size(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_MAX_RAM_SIZE); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 2d36d83..ba3e30c 100644 --- a/boards.cfg +++ b/boards.cfg @@ -256,6 +256,7 @@ seaboard arm armv7 seaboard nvidia ventana arm armv7 ventana nvidia tegra2 whistler arm armv7 whistler nvidia tegra2 u8500_href arm armv7 u8500 st-ericsson u8500 +snowball arm armv7 snowball st-ericsson u8500 actux1_4_16 arm ixp actux1 - - actux1:FLASH2X2 actux1_4_32 arm ixp actux1 - - actux1:FLASH2X2,RAM_32MB actux1_8_16 arm ixp actux1 - - actux1:FLASH1X8 diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 32a2474..1a7412f 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -40,6 +40,7 @@ COBJS-$(CONFIG_TEGRA_GPIO) += tegra_gpio.o COBJS-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o COBJS-$(CONFIG_ALTERA_PIO) += altera_pio.o COBJS-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o +COBJS-$(CONFIG_DB8500_GPIO) += db8500_gpio.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/gpio/db8500_gpio.c b/drivers/gpio/db8500_gpio.c new file mode 100644 index 0000000..d5cb383 --- /dev/null +++ b/drivers/gpio/db8500_gpio.c @@ -0,0 +1,221 @@ +/* + * Code ported from Nomadik GPIO driver in ST-Ericsson Linux kernel code. + * The purpose is that GPIO config found in kernel should work by simply + * copy-paste it to U-boot. + * + * Original Linux authors: + * Copyright (C) 2008,2009 STMicroelectronics + * Copyright (C) 2009 Alessandro Rubini rubini@unipv.it + * Rewritten based on work by Prafulla WADASKAR prafulla.wadaskar@st.com + * + * Ported to U-boot by: + * Copyright (C) 2010 Joakim Axelsson <joakim.axelsson AT stericsson.com> + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include <common.h> +#include <asm/io.h> + +#include <asm/arch/db8500_gpio.h> +#include <asm/arch/db8500_pincfg.h> +#include <linux/compiler.h> + +#define IO_ADDR(x) (void *) (x) + +/* + * The GPIO module in the db8500 Systems-on-Chip is an + * AMBA device, managing 32 pins and alternate functions. The logic block + * is currently only used in the db8500. + */ + +#define GPIO_TOTAL_PINS 268 +#define GPIO_PINS_PER_BLOCK 32 +#define GPIO_BLOCKS_COUNT (GPIO_TOTAL_PINS/GPIO_PINS_PER_BLOCK + 1) +#define GPIO_BLOCK(pin) (((pin + GPIO_PINS_PER_BLOCK) >> 5) - 1) +#define GPIO_PIN_WITHIN_BLOCK(pin) ((pin)%(GPIO_PINS_PER_BLOCK)) + +/* Register in the logic block */ +#define DB8500_GPIO_DAT 0x00 +#define DB8500_GPIO_DATS 0x04 +#define DB8500_GPIO_DATC 0x08 +#define DB8500_GPIO_PDIS 0x0c +#define DB8500_GPIO_DIR 0x10 +#define DB8500_GPIO_DIRS 0x14 +#define DB8500_GPIO_DIRC 0x18 +#define DB8500_GPIO_SLPC 0x1c +#define DB8500_GPIO_AFSLA 0x20 +#define DB8500_GPIO_AFSLB 0x24 + +#define DB8500_GPIO_RIMSC 0x40 +#define DB8500_GPIO_FIMSC 0x44 +#define DB8500_GPIO_IS 0x48 +#define DB8500_GPIO_IC 0x4c +#define DB8500_GPIO_RWIMSC 0x50 +#define DB8500_GPIO_FWIMSC 0x54 +#define DB8500_GPIO_WKS 0x58 + +static void __iomem *get_gpio_addr(unsigned gpio) +{ + /* Our list of GPIO chips */ + static void __iomem *gpio_addrs[GPIO_BLOCKS_COUNT] = { + IO_ADDR(CFG_GPIO_0_BASE), + IO_ADDR(CFG_GPIO_1_BASE), + IO_ADDR(CFG_GPIO_2_BASE), + IO_ADDR(CFG_GPIO_3_BASE), + IO_ADDR(CFG_GPIO_4_BASE), + IO_ADDR(CFG_GPIO_5_BASE), + IO_ADDR(CFG_GPIO_6_BASE), + IO_ADDR(CFG_GPIO_7_BASE), + IO_ADDR(CFG_GPIO_8_BASE) + }; + + return gpio_addrs[GPIO_BLOCK(gpio)]; +} + +static unsigned get_gpio_offset(unsigned gpio) +{ + return GPIO_PIN_WITHIN_BLOCK(gpio); +} + +/* Can only be called from config_pin. Don't configure alt-mode directly */ +static void gpio_set_mode(unsigned gpio, enum db8500_gpio_alt mode) +{ + void __iomem *addr = get_gpio_addr(gpio); + unsigned offset = get_gpio_offset(gpio); + u32 bit = 1 << offset; + u32 afunc, bfunc; + + afunc = readl(addr + DB8500_GPIO_AFSLA) & ~bit; + bfunc = readl(addr + DB8500_GPIO_AFSLB) & ~bit; + if (mode & DB8500_GPIO_ALT_A) + afunc |= bit; + if (mode & DB8500_GPIO_ALT_B) + bfunc |= bit; + writel(afunc, addr + DB8500_GPIO_AFSLA); + writel(bfunc, addr + DB8500_GPIO_AFSLB); +} + +/** + * db8500_gpio_set_pull() - enable/disable pull up/down on a gpio + * @gpio: pin number + * @pull: one of DB8500_GPIO_PULL_DOWN, DB8500_GPIO_PULL_UP, + * and DB8500_GPIO_PULL_NONE + * + * Enables/disables pull up/down on a specified pin. This only takes effect if + * the pin is configured as an input (either explicitly or by the alternate + * function). + * + * NOTE: If enabling the pull up/down, the caller must ensure that the GPIO is + * configured as an input. Otherwise, due to the way the controller registers + * work, this function will change the value output on the pin. + */ +void db8500_gpio_set_pull(unsigned gpio, enum db8500_gpio_pull pull) +{ + void __iomem *addr = get_gpio_addr(gpio); + unsigned offset = get_gpio_offset(gpio); + u32 bit = 1 << offset; + u32 pdis; + + pdis = readl(addr + DB8500_GPIO_PDIS); + if (pull == DB8500_GPIO_PULL_NONE) + pdis |= bit; + else + pdis &= ~bit; + writel(pdis, addr + DB8500_GPIO_PDIS); + + if (pull == DB8500_GPIO_PULL_UP) + writel(bit, addr + DB8500_GPIO_DATS); + else if (pull == DB8500_GPIO_PULL_DOWN) + writel(bit, addr + DB8500_GPIO_DATC); +} + +void db8500_gpio_make_input(unsigned gpio) +{ + void __iomem *addr = get_gpio_addr(gpio); + unsigned offset = get_gpio_offset(gpio); + + writel(1 << offset, addr + DB8500_GPIO_DIRC); +} + +int db8500_gpio_get_input(unsigned gpio) +{ + void __iomem *addr = get_gpio_addr(gpio); + unsigned offset = get_gpio_offset(gpio); + u32 bit = 1 << offset; + + printf("db8500_gpio_get_input gpio=%u addr=%p offset=%u bit=%#x\n", + gpio, addr, offset, bit); + + return (readl(addr + DB8500_GPIO_DAT) & bit) != 0; +} + +void db8500_gpio_make_output(unsigned gpio, int val) +{ + void __iomem *addr = get_gpio_addr(gpio); + unsigned offset = get_gpio_offset(gpio); + + writel(1 << offset, addr + DB8500_GPIO_DIRS); + db8500_gpio_set_output(gpio, val); +} + +void db8500_gpio_set_output(unsigned gpio, int val) +{ + void __iomem *addr = get_gpio_addr(gpio); + unsigned offset = get_gpio_offset(gpio); + + if (val) + writel(1 << offset, addr + DB8500_GPIO_DATS); + else + writel(1 << offset, addr + DB8500_GPIO_DATC); +} + +/** + * config_pin - configure a pin's mux attributes + * @cfg: pin confguration + * + * Configures a pin's mode (alternate function or GPIO), its pull up status, + * and its sleep mode based on the specified configuration. The @cfg is + * usually one of the SoC specific macros defined in mach/<soc>-pins.h. These + * are constructed using, and can be further enhanced with, the macros in + * plat/pincfg.h. + * + * If a pin's mode is set to GPIO, it is configured as an input to avoid + * side-effects. The gpio can be manipulated later using standard GPIO API + * calls. + */ +static void config_pin(unsigned long cfg) +{ + int pin = PIN_NUM(cfg); + int pull = PIN_PULL(cfg); + int af = PIN_ALT(cfg); + int output = PIN_DIR(cfg); + int val = PIN_VAL(cfg); + + if (output) + db8500_gpio_make_output(pin, val); + else { + db8500_gpio_make_input(pin); + db8500_gpio_set_pull(pin, pull); + } + + gpio_set_mode(pin, af); +} + +/** + * db8500_config_pins - configure several pins at once + * @cfgs: array of pin configurations + * @num: number of elments in the array + * + * Configures several pins using config_pin(). Refer to that function for + * further information. + */ +void db8500_gpio_config_pins(unsigned long *cfgs, size_t num) +{ + size_t i; + + for (i = 0; i < num; i++) + config_pin(cfgs[i]); +} diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index ed581ae..d4c5137 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -156,6 +156,8 @@ int serial_init (void) writel(lcr, ®s->fr);
writel(lcr, ®s->pl011_rlcr); + /* lcrh needs to be set again for change to be effective */ + writel(lcr, ®s->pl011_lcrh); } #endif /* Finally, enable the UART */ diff --git a/include/configs/snowball.h b/include/configs/snowball.h new file mode 100644 index 0000000..9877513 --- /dev/null +++ b/include/configs/snowball.h @@ -0,0 +1,256 @@ +/* + * Copyright (C) ST-Ericsson SA 2009 + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * #define DEBUG 1 + */ + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SNOWBALL +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF + +/* + * High Level Configuration Options + * (easy to change) + */ +#define CONFIG_U8500 +#define CONFIG_L2_OFF + +#define CONFIG_SYS_MEMTEST_START 0x00000000 +#define CONFIG_SYS_MEMTEST_END 0x1FFFFFFF +#define CONFIG_SYS_HZ 1000 /* must be 1000 */ + +/*----------------------------------------------------------------------- + * Size of environment and malloc() pool + */ +/* + * If you use U-Boot as crash kernel, make sure that it does not overwrite + * information saved by kexec during panic. Kexec expects the start + * address of the executable 32K above "crashkernel" address. + */ +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE (8*1024) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 256*1024) + +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */ + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_CMD_ENV +#define CONFIG_CMD_SAVEENV +#define CONFIG_ENV_OFFSET 0x0118000 +#define CONFIG_SYS_MMC_ENV_DEV 0 /* SLOT2: eMMC */ + +/* + * PL011 Configuration + */ +#define CONFIG_PL011_SERIAL +#define CONFIG_PL011_SERIAL_RLCR +#define CONFIG_PL011_SERIAL_FLUSH_ON_INIT + +/* + * U8500 UART registers base for 3 serial devices + */ +#define CFG_UART0_BASE 0x80120000 +#define CFG_UART1_BASE 0x80121000 +#define CFG_UART2_BASE 0x80007000 +#define CFG_SERIAL0 CFG_UART0_BASE +#define CFG_SERIAL1 CFG_UART1_BASE +#define CFG_SERIAL2 CFG_UART2_BASE +#define CONFIG_PL011_CLOCK 38400000 +#define CONFIG_PL01x_PORTS { (void *)CFG_SERIAL0, (void *)CFG_SERIAL1, \ + (void *)CFG_SERIAL2 } +#define CONFIG_CONS_INDEX 2 +#define CONFIG_BAUDRATE 115200 + +/* + * Devices and file systems + */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION + +/* + * Commands + */ +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_BOOTD +#define CONFIG_CMD_BDI +#define CONFIG_CMD_IMI +#define CONFIG_CMD_MISC +#define CONFIG_CMD_RUN +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_CONSOLE +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_MMC +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_SOURCE + +#ifndef CONFIG_BOOTDELAY +#define CONFIG_BOOTDELAY 1 +#endif +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ + +#undef CONFIG_BOOTARGS +#define CONFIG_BOOTCOMMAND \ +"mmc dev 1; " \ + "if run loadbootscript; " \ + "then run bootscript; " \ + "else " \ + "if run mmcload; " \ + "then run mmcboot; " \ + "else " \ + "mmc dev 0; " \ + "if run emmcloadbootscript; " \ + "then run bootscript; " \ + "else " \ + "if run emmcload; " \ + "then run emmcboot; " \ + "else " \ + "echo No media to boot from; " \ + "fi; " \ + "fi; " \ + "fi; " \ + "fi; " + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "verify=n\0" \ + "loadaddr=0x00100000\0" \ + "console=ttyAMA2,115200n8\0" \ + "loadbootscript=fatload mmc 1:1 ${loadaddr} boot.scr\0" \ + "emmcloadbootscript=fatload mmc 0:2 ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript " \ + "from mmc ...; source ${loadaddr}\0" \ + "memargs256=mem=96M@0 mem_modem=32M@96M mem=32M@128M " \ + "hwmem=22M@160M pmem_hwb=42M@182M mem_mali=32@224M\0" \ + "memargs512=mem=96M@0 mem_modem=32M@96M hwmem=32M@128M " \ + "mem=64M@160M mem_mali=32M@224M " \ + "pmem_hwb=128M@256M mem=128M@384M\0" \ + "memargs1024=mem=128M@0 mali.mali_mem=32M@128M " \ + "hwmem=168M@M160M mem=48M@328M " \ + "mem_issw=1M@383M mem=640M@384M\0" \ + "memargs=setenv bootargs ${bootargs} ${memargs1024}\0" \ + "emmcload=fatload mmc 0:2 ${loadaddr} uImage\0" \ + "mmcload=fatload mmc 1:1 ${loadaddr} uImage\0" \ + "commonargs=setenv bootargs console=${console} " \ + "vmalloc=300M\0" \ + "emmcargs=setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p3 " \ + "rootwait\0" \ + "addcons=setenv bootargs ${bootargs} " \ + "console=${console}\0" \ + "emmcboot=echo Booting from eMMC ...; " \ + "run commonargs emmcargs memargs; " \ + "bootm ${loadaddr}\0" \ + "mmcargs=setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk1p2 " \ + "rootwait earlyprintk\0" \ + "mmcboot=echo Booting from external MMC ...; " \ + "run commonargs mmcargs memargs; " \ + "bootm ${loadaddr}\0" \ + "fdt_high=0x2BC00000\0" \ + "stdout=serial,usbtty\0" \ + "stdin=serial,usbtty\0" \ + "stderr=serial,usbtty\0" + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + */ + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "U8500 $ " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Arg Buffer Size */ + +#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ +#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 + +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_SETUP_MEMORY_TAGS 2 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ + +/* + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x00000000 /* DDR-SDRAM Bank #1 */ + +/* + * additions for new relocation code + */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_MAX_RAM_SIZE 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x100000 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET + +/* landing address before relocation */ +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0x0 +#endif + +/* + * FLASH and environment organization + */ +#define CONFIG_SYS_NO_FLASH + +/* + * base register values for U8500 + */ +#define CFG_PRCMU_BASE 0x80157000 /* Power, reset and clock */ + + +/* + * U8500 GPIO register base for 9 banks + */ +#define CONFIG_DB8500_GPIO +#define CFG_GPIO_0_BASE 0x8012E000 +#define CFG_GPIO_1_BASE 0x8012E080 +#define CFG_GPIO_2_BASE 0x8000E000 +#define CFG_GPIO_3_BASE 0x8000E080 +#define CFG_GPIO_4_BASE 0x8000E100 +#define CFG_GPIO_5_BASE 0x8000E180 +#define CFG_GPIO_6_BASE 0x8011E000 +#define CFG_GPIO_7_BASE 0x8011E080 +#define CFG_GPIO_8_BASE 0xA03FE000 + +#define CFG_FSMC_BASE 0x80000000 /* FSMC Controller */ + +#endif /* __CONFIG_H */
Changes for v2:
Acked-by: Tom Rini trini@ti.com
Acked-by: Linus Walleij linus.walleij@linaro.org
For this entire series.
Yours, Linus Walleij
[snip]
devkit3250 lpc32xx
- snowball ARM ARMV7 (u8500 SoC)
This list is supposed to be sorted by name. I've sorted it and applied to u-boot-staging/trini@ti.com, thanks!
Linus Walleij
