[PATCH RESEND] sunxi: add axp313a support
There is no response from previous post, I think this patch is not reached to suitable person and not reviewed yet.
axp313a code is a part of power/sunxi. This is needed for Mango Pi MQ-Quad and Orange Pi Zero3.
From 9127de42691f86ef5ed22dcf5fa0b44b03288a07 Mon Sep 17 00:00:00 2001 From: SASANO Takayoshi uaa@uaa.org.uk Date: Thu, 13 Jul 2023 20:41:40 +0900 Subject: [PATCH] add axp313a support
Signed-off-by: SASANO Takayoshi uaa@uaa.org.uk ---
arch/arm/mach-sunxi/pmic_bus.c | 4 +- board/sunxi/board.c | 9 +- drivers/power/Kconfig | 16 ++- drivers/power/Makefile | 1 + drivers/power/axp313a.c | 171 +++++++++++++++++++++++++++++++++ drivers/power/pmic/axp.c | 1 + include/axp313a.h | 31 ++++++ include/axp_pmic.h | 2 + 8 files changed, 226 insertions(+), 9 deletions(-) create mode 100644 drivers/power/axp313a.c create mode 100644 include/axp313a.h
diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index c090840637..3e7bb5a5d1 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -21,7 +21,7 @@
#define AXP209_I2C_ADDR 0x34
-#define AXP305_I2C_ADDR 0x36 +#define AXP305_I2C_ADDR 0x36 /* AXP305 and AXP313A */
#define AXP221_CHIP_ADDR 0x68
@@ -32,7 +32,7 @@ static int pmic_i2c_address(void) { if (IS_ENABLED(CONFIG_AXP152_POWER)) return AXP152_I2C_ADDR; - if (IS_ENABLED(CONFIG_AXP305_POWER)) + if (IS_ENABLED(CONFIG_AXP305_POWER) || IS_ENABLED(CONFIG_AXP313A_POWER)) return AXP305_I2C_ADDR;
/* Other AXP2xx and AXP8xx variants */ diff --git a/board/sunxi/board.c b/board/sunxi/board.c index f321cd58a6..9b0069cd52 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -584,6 +584,7 @@ void sunxi_board_init(void)
#if defined CONFIG_AXP152_POWER || defined CONFIG_AXP209_POWER || \ defined CONFIG_AXP221_POWER || defined CONFIG_AXP305_POWER || \ + defined CONFIG_AXP313A_POWER || \ defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER power_failed = axp_init();
@@ -605,7 +606,8 @@ void sunxi_board_init(void) power_failed |= axp_set_dcdc2(CONFIG_AXP_DCDC2_VOLT); power_failed |= axp_set_dcdc3(CONFIG_AXP_DCDC3_VOLT); #endif -#if !defined(CONFIG_AXP209_POWER) && !defined(CONFIG_AXP818_POWER) +#if !defined(CONFIG_AXP209_POWER) && !defined(CONFIG_AXP818_POWER) && \ + !defined(CONFIG_AXP313A_POWER) power_failed |= axp_set_dcdc4(CONFIG_AXP_DCDC4_VOLT); #endif #if defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || \ @@ -617,10 +619,11 @@ void sunxi_board_init(void) defined CONFIG_AXP818_POWER power_failed |= axp_set_aldo1(CONFIG_AXP_ALDO1_VOLT); #endif -#if !defined(CONFIG_AXP305_POWER) +#if !defined(CONFIG_AXP305_POWER) && !defined(CONFIG_AXP313A_POWER) power_failed |= axp_set_aldo2(CONFIG_AXP_ALDO2_VOLT); #endif -#if !defined(CONFIG_AXP152_POWER) && !defined(CONFIG_AXP305_POWER) +#if !defined(CONFIG_AXP152_POWER) && !defined(CONFIG_AXP305_POWER) && \ + !defined(CONFIG_AXP313A_POWER) power_failed |= axp_set_aldo3(CONFIG_AXP_ALDO3_VOLT); #endif #ifdef CONFIG_AXP209_POWER diff --git a/drivers/power/Kconfig b/drivers/power/Kconfig index 7f3b990d23..12189eec9f 100644 --- a/drivers/power/Kconfig +++ b/drivers/power/Kconfig @@ -101,6 +101,14 @@ config AXP305_POWER Select this to enable support for the axp305 pmic found on most H616 boards.
+config AXP313A_POWER + bool "axp313a pmic support" + select AXP_PMIC_BUS + select CMD_POWEROFF + ---help--- + Select this to enable support for the axp313a pmic found on some + H616 boards. + config AXP809_POWER bool "axp809 pmic support" depends on MACH_SUN9I @@ -143,8 +151,8 @@ config AXP_DCDC1_VOLT
config AXP_DCDC2_VOLT int "axp pmic dcdc2 voltage" - depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER - default 900 if AXP818_POWER + depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER || AXP313A_POWER + default 900 if AXP818_POWER || AXP313A_POWER default 1400 if AXP152_POWER || AXP209_POWER default 1200 if MACH_SUN6I default 1100 if MACH_SUN8I @@ -161,8 +169,8 @@ config AXP_DCDC2_VOLT
config AXP_DCDC3_VOLT int "axp pmic dcdc3 voltage" - depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER - default 900 if AXP809_POWER || AXP818_POWER + depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER || AXP313A_POWER + default 900 if AXP809_POWER || AXP818_POWER || AXP313A_POWER default 1500 if AXP152_POWER default 1250 if AXP209_POWER default 1100 if MACH_SUN8I_R40 diff --git a/drivers/power/Makefile b/drivers/power/Makefile index ba64b2c593..f851f4a94e 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -12,6 +12,7 @@ obj-$(CONFIG_AXP152_POWER) += axp152.o obj-$(CONFIG_AXP209_POWER) += axp209.o obj-$(CONFIG_AXP221_POWER) += axp221.o obj-$(CONFIG_AXP305_POWER) += axp305.o +obj-$(CONFIG_AXP313A_POWER) += axp313a.o obj-$(CONFIG_AXP809_POWER) += axp809.o obj-$(CONFIG_AXP818_POWER) += axp818.o obj-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o diff --git a/drivers/power/axp313a.c b/drivers/power/axp313a.c new file mode 100644 index 0000000000..90be8942bb --- /dev/null +++ b/drivers/power/axp313a.c @@ -0,0 +1,171 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * AXP313A driver based on AXP221 driver + * + * + * (C) Copyright 2023 SASANO Takayoshi uaa@uaa.org.uk + * + * Based on axp221.c + * (C) Copyright 2014 Hans de Goede hdegoede@redhat.com + * (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl + */ + +#include <common.h> +#include <command.h> +#include <errno.h> +#include <asm/arch/pmic_bus.h> +#include <axp_pmic.h> + +static u8 axp313a_mvolt_to_cfg(int mvolt, int min, int max, int div) +{ + if (mvolt < min) + mvolt = min; + else if (mvolt > max) + mvolt = max; + + return (mvolt - min) / div; +} + +int axp_set_dcdc1(unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (mvolt >= 1600) + cfg = 88 + axp313a_mvolt_to_cfg(mvolt, 1600, 3400, 100); + else if (mvolt >= 1220) + cfg = 71 + axp313a_mvolt_to_cfg(mvolt, 1220, 1540, 20); + else + cfg = axp313a_mvolt_to_cfg(mvolt, 500, 1200, 10); + + if (mvolt == 0) + return pmic_bus_clrbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_DCDC1); + + ret = pmic_bus_write(AXP313A_DCDC1_CTRL, cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_DCDC1); +} + +int axp_set_dcdc2(unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (mvolt >= 1220) + cfg = 71 + axp313a_mvolt_to_cfg(mvolt, 1220, 1540, 20); + else + cfg = axp313a_mvolt_to_cfg(mvolt, 500, 1200, 10); + + if (mvolt == 0) + return pmic_bus_clrbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_DCDC2); + + ret = pmic_bus_write(AXP313A_DCDC2_CTRL, cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_DCDC2); +} + +int axp_set_dcdc3(unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (mvolt >= 1220) + cfg = 71 + axp313a_mvolt_to_cfg(mvolt, 1220, 1840, 20); + else + cfg = axp313a_mvolt_to_cfg(mvolt, 500, 1200, 10); + + if (mvolt == 0) + return pmic_bus_clrbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_DCDC3); + + ret = pmic_bus_write(AXP313A_DCDC3_CTRL, cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_DCDC3); +} + +int axp_set_aldo1(unsigned int mvolt) +{ + int ret; + u8 cfg = axp313a_mvolt_to_cfg(mvolt, 500, 3500, 100); + + if (mvolt == 0) + return pmic_bus_clrbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_ALDO1); + + ret = pmic_bus_write(AXP313A_ALDO1_CTRL, cfg); + if (cfg) + return ret; + + return pmic_bus_setbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_ALDO1); +} + +int axp_set_dldo(int dldo_num, unsigned int mvolt) +{ + int ret; + u8 cfg = axp313a_mvolt_to_cfg(mvolt, 500, 3500, 100); + + if (dldo_num != 1) + return -EINVAL; + + if (mvolt == 0) + return pmic_bus_clrbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_DLDO1); + + ret = pmic_bus_write(AXP313A_DLDO1_CTRL, cfg); + if (cfg) + return ret; + + return pmic_bus_setbits(AXP313A_OUTPUT_CTRL, + AXP313A_OUTPUT_CTRL_DLDO1); +} + +int axp_init(void) +{ + int ret; + u8 axp_chip_id; + + ret = pmic_bus_init(); + if (ret) + return ret; + + ret = pmic_bus_read(AXP313A_CHIP_VERSION, &axp_chip_id); + if (ret) + return ret; + + axp_chip_id &= AXP313A_CHIP_VERSION_MASK; + switch (axp_chip_id) { + case AXP313A_CHIP_VERSION_AXP1530: + case AXP313A_CHIP_VERSION_AXP313A: + case AXP313A_CHIP_VERSION_AXP313B: + break; + default: + return -EINVAL; + } + + return ret; +} + +#if !IS_ENABLED(CONFIG_SYSRESET_CMD_POWEROFF) +int do_poweroff(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + pmic_bus_write(AXP313A_SHUTDOWN, AXP313A_POWEROFF); + + /* infinite loop during shutdown */ + while (1); + + /* not reached */ + return 0; +} +#endif diff --git a/drivers/power/pmic/axp.c b/drivers/power/pmic/axp.c index 025dac24f2..d23c16d996 100644 --- a/drivers/power/pmic/axp.c +++ b/drivers/power/pmic/axp.c @@ -87,6 +87,7 @@ static const struct udevice_id axp_pmic_ids[] = { { .compatible = "x-powers,axp209", .data = AXP209_ID }, { .compatible = "x-powers,axp221", .data = AXP221_ID }, { .compatible = "x-powers,axp223", .data = AXP223_ID }, + { .compatible = "x-powers,axp313a", .data = AXP313A_ID }, { .compatible = "x-powers,axp803", .data = AXP803_ID }, { .compatible = "x-powers,axp806", .data = AXP806_ID }, { .compatible = "x-powers,axp809", .data = AXP809_ID }, diff --git a/include/axp313a.h b/include/axp313a.h new file mode 100644 index 0000000000..a61a11a53c --- /dev/null +++ b/include/axp313a.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2023 SASANO Takayoshi uaa@uaa.org.uk + */ + +enum axp313a_reg { + AXP313A_POWER_STATUS = 0x00, + AXP313A_CHIP_VERSION = 0x03, + AXP313A_OUTPUT_CTRL = 0x10, + AXP313A_DCDC1_CTRL = 0x13, + AXP313A_DCDC2_CTRL = 0x14, + AXP313A_DCDC3_CTRL = 0x15, + AXP313A_ALDO1_CTRL = 0x16, + AXP313A_DLDO1_CTRL = 0x17, + AXP313A_SHUTDOWN = 0x1a, + AXP313A_IRQ_ENABLE = 0x20, + AXP313A_IRQ_STATUS = 0x21, +}; + +#define AXP313A_CHIP_VERSION_MASK 0xcf +#define AXP313A_CHIP_VERSION_AXP1530 0x48 +#define AXP313A_CHIP_VERSION_AXP313A 0x4b +#define AXP313A_CHIP_VERSION_AXP313B 0x4c + +#define AXP313A_OUTPUT_CTRL_DCDC1 BIT(0) +#define AXP313A_OUTPUT_CTRL_DCDC2 BIT(1) +#define AXP313A_OUTPUT_CTRL_DCDC3 BIT(2) +#define AXP313A_OUTPUT_CTRL_ALDO1 BIT(3) +#define AXP313A_OUTPUT_CTRL_DLDO1 BIT(4) + +#define AXP313A_POWEROFF BIT(7) diff --git a/include/axp_pmic.h b/include/axp_pmic.h index 4ac6486583..9b6d7d900c 100644 --- a/include/axp_pmic.h +++ b/include/axp_pmic.h @@ -13,6 +13,7 @@ #include <axp209.h> #include <axp221.h> #include <axp305.h> +#include <axp313a.h> #include <axp809.h> #include <axp818.h>
@@ -32,6 +33,7 @@ enum { AXP209_ID, AXP221_ID, AXP223_ID, + AXP313A_ID, AXP803_ID, AXP806_ID, AXP809_ID,
On Fri, 01 Sep 2023 06:05:10 +0900 SASANO Takayoshi uaa@mx5.nisiq.net wrote:
Hi Takayoshi,
thanks for sending this patch to the list, and for sticking to it!
Running scripts/get_maintainer.pl on your patch file helps to get a list of people that would take care of your patch - and get quicker responses ;-)
So superficially this looks alright, and I had some similar, though more minimal version hacked up somewhere for my OPi Zero3 experiments. However you might have realised that this is a complete mess, especially the part with the #if selection of which regulator to program, depending on the AXP PMIC selected (in board.c).
So I started some experiments on how to improve the situation, starting with cleaning up the sunxi_board_init() function, so it becomes easier to follow what happens there and to extend. I am thinking we don't need to program all the regulators at this point (SPL), all we need is probably the DRAM and maybe the CPU rail. Every other regulator needed can be programmed on demand, via the DT in U-Boot proper. Which brings me to the next point: You might have noticed that we have a proper UCLASS_REGULATOR driver, in drivers/power/regulator/axp_regulator.c. Given the nature of the AXP313a (with most rails always-on) this might not be needed anytime soon, but you could make a patch to support the AXP313a in there. I am playing with the idea of somehow re-using the data structures in there for the SPL driver as well, so we need that anyway.
Anyway, my plan is to not add anything to the SPL code in its current shape anymore, instead do some refactoring first, then have a much cleaner and smaller patch with the AXP313a support. I am more than halfway through with that, just stuck on some nasty preprocessor problem. I will post something once that's ready, and will then CC: you, so you can add the AXP313 parts on top, if you like.
Thanks! Andre
- defined CONFIG_AXP313A_POWER || \ defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER power_failed = axp_init();
- !defined(CONFIG_AXP313A_POWER) power_failed |= axp_set_dcdc4(CONFIG_AXP_DCDC4_VOLT);
- !defined(CONFIG_AXP313A_POWER) power_failed |= axp_set_aldo3(CONFIG_AXP_ALDO3_VOLT);
- bool "axp313a pmic support"
- select AXP_PMIC_BUS
- select CMD_POWEROFF
- ---help---
- Select this to enable support for the axp313a pmic found on some
- H616 boards.
- depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER || AXP313A_POWER
- default 900 if AXP818_POWER || AXP313A_POWER default 1400 if AXP152_POWER || AXP209_POWER default 1200 if MACH_SUN6I default 1100 if MACH_SUN8I
- default 900 if AXP809_POWER || AXP818_POWER || AXP313A_POWER default 1500 if AXP152_POWER default 1250 if AXP209_POWER default 1100 if MACH_SUN8I_R40
- AXP313A driver based on AXP221 driver
- (C) Copyright 2023 SASANO Takayoshi uaa@uaa.org.uk
- Based on axp221.c
- (C) Copyright 2014 Hans de Goede hdegoede@redhat.com
- (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl
- if (mvolt < min)
mvolt = min;
- else if (mvolt > max)
mvolt = max;
- return (mvolt - min) / div;
- int ret;
- u8 cfg;
- if (mvolt >= 1600)
- else if (mvolt >= 1220)
- else
- if (mvolt == 0)
- ret = pmic_bus_write(AXP313A_DCDC1_CTRL, cfg);
- if (ret)
return ret;
- return pmic_bus_setbits(AXP313A_OUTPUT_CTRL,
- int ret;
- u8 cfg;
- if (mvolt >= 1220)
- else
- if (mvolt == 0)
- ret = pmic_bus_write(AXP313A_DCDC2_CTRL, cfg);
- if (ret)
return ret;
- int ret;
- u8 cfg;
- else
- if (mvolt == 0)
- ret = pmic_bus_write(AXP313A_DCDC3_CTRL, cfg);
- if (ret)
return ret;
- int ret;
- u8 cfg = axp313a_mvolt_to_cfg(mvolt, 500, 3500, 100);
- if (mvolt == 0)
- ret = pmic_bus_write(AXP313A_ALDO1_CTRL, cfg);
- if (cfg)
return ret;
- int ret;
- if (dldo_num != 1)
return -EINVAL;
- if (mvolt == 0)
- ret = pmic_bus_write(AXP313A_DLDO1_CTRL, cfg);
- if (cfg)
return ret;
- int ret;
- u8 axp_chip_id;
- ret = pmic_bus_init();
- if (ret)
return ret;
- ret = pmic_bus_read(AXP313A_CHIP_VERSION, &axp_chip_id);
- if (ret)
return ret;
- axp_chip_id &= AXP313A_CHIP_VERSION_MASK;
- switch (axp_chip_id) {
- case AXP313A_CHIP_VERSION_AXP1530:
- case AXP313A_CHIP_VERSION_AXP313A:
- case AXP313A_CHIP_VERSION_AXP313B:
break;
- default:
return -EINVAL;
- return ret;
- pmic_bus_write(AXP313A_SHUTDOWN, AXP313A_POWEROFF);
- /* infinite loop during shutdown */
- while (1);
- /* not reached */
- { .compatible = "x-powers,axp313a", .data = AXP313A_ID }, { .compatible = "x-powers,axp803", .data = AXP803_ID }, { .compatible = "x-powers,axp806", .data = AXP806_ID }, { .compatible = "x-powers,axp809", .data = AXP809_ID },
+enum axp313a_reg {
- AXP313A_POWER_STATUS = 0x00,
- AXP313A_CHIP_VERSION = 0x03,
- AXP313A_OUTPUT_CTRL = 0x10,
- AXP313A_DCDC1_CTRL = 0x13,
- AXP313A_DCDC2_CTRL = 0x14,
- AXP313A_DCDC3_CTRL = 0x15,
- AXP313A_ALDO1_CTRL = 0x16,
- AXP313A_DLDO1_CTRL = 0x17,
- AXP313A_SHUTDOWN = 0x1a,
- AXP313A_IRQ_ENABLE = 0x20,
- AXP313A_IRQ_STATUS = 0x21,
- AXP313A_ID, AXP803_ID, AXP806_ID, AXP809_ID,
Hello, sorry for late reply!
Sounds good, current complicated PMIC should be cleaned I think. If a testing staff is needed, please tell me.
By the way, do you have any memory controller information when Allwinner H616 connects DDR4?
Simply adding AXP313a code make MangoPi MQ-Quad working, but OrangePi Zero3 requires setting up memory controller for DDR4.
At least sunxi's binary blob (boot0) can do this, no source code.
no worries, glad you came back!
Thanks! I have something easy ready, just the final touches needed. Will CC: on the post.
Yes, we have been looking at this for a while, and there is code out there. The latest drop is from Mikhail: https://lore.kernel.org/u-boot/20231016053441.3197087-2-iuncuim@gmail.com/ If you can try this, maybe even review it, that would be great.
Cheers, Andre
hi,
I got mail from Mikhail and received patchset. I will try.
Andre Przywara
SASANO Takayoshi
