[PATCH v1 0/7] Bring support for Xiaomi Mi Pad 1 (Tegra K1)
This patch set brings support for Xiaomi Mi Pad 1 based on Tegra K1 SoC as original vendor bootloader substitution. All major features are implemented.
Minor stuff that still needs to be tested and fixed includes: - minor image flickering on the right side of the panel - check if U-Boot self-upgrade feature works as intended
Svyatoslav Ryhel (7): pinctrl: tegra: add Tegra K1 support video: tegra20: dc: dsi: add Tegra K1 compatible video: tegra20: mipi: add Tegra K1 support video: add TI LP855x backlight driver video: panel: add Sharp LQ079L1SX01 MIPI DSI panel driver ARM: tegra124: implement BCT patching board: xiaomi: mocha: add Xiaomi Mi Pad A0101 support
arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-xiaomi-mocha.dts | 603 ++++++++++++++++++++ arch/arm/include/asm/arch-tegra124/pinmux.h | 4 + arch/arm/mach-tegra/Kconfig | 2 +- arch/arm/mach-tegra/tegra124/Kconfig | 5 + arch/arm/mach-tegra/tegra124/Makefile | 1 + arch/arm/mach-tegra/tegra124/bct.c | 91 +++ arch/arm/mach-tegra/tegra124/bct.h | 55 ++ board/xiaomi/mocha/Kconfig | 12 + board/xiaomi/mocha/MAINTAINERS | 8 + board/xiaomi/mocha/Makefile | 9 + board/xiaomi/mocha/mocha-spl.c | 49 ++ board/xiaomi/mocha/mocha.c | 41 ++ board/xiaomi/mocha/mocha.env | 23 + configs/mocha_defconfig | 90 +++ doc/board/index.rst | 1 + doc/board/xiaomi/index.rst | 9 + doc/board/xiaomi/mocha.rst | 112 ++++ drivers/pinctrl/tegra/pinctrl-tegra.c | 56 ++ drivers/video/Kconfig | 19 + drivers/video/Makefile | 2 + drivers/video/lp855x_backlight.c | 302 ++++++++++ drivers/video/sharp-lq079l1sx01.c | 275 +++++++++ drivers/video/tegra20/tegra-dc.c | 3 + drivers/video/tegra20/tegra-dsi.c | 12 +- drivers/video/tegra20/tegra-mipi.c | 134 ++++- include/configs/mocha.h | 25 + 27 files changed, 1928 insertions(+), 16 deletions(-) create mode 100644 arch/arm/dts/tegra124-xiaomi-mocha.dts create mode 100644 arch/arm/mach-tegra/tegra124/bct.c create mode 100644 arch/arm/mach-tegra/tegra124/bct.h create mode 100644 board/xiaomi/mocha/Kconfig create mode 100644 board/xiaomi/mocha/MAINTAINERS create mode 100644 board/xiaomi/mocha/Makefile create mode 100644 board/xiaomi/mocha/mocha-spl.c create mode 100644 board/xiaomi/mocha/mocha.c create mode 100644 board/xiaomi/mocha/mocha.env create mode 100644 configs/mocha_defconfig create mode 100644 doc/board/xiaomi/index.rst create mode 100644 doc/board/xiaomi/mocha.rst create mode 100644 drivers/video/lp855x_backlight.c create mode 100644 drivers/video/sharp-lq079l1sx01.c create mode 100644 include/configs/mocha.h
Tegra 124 is fully compatible with existing Tegra pincontrol driver, but it needs a specific MIPI PAD control pinconfig.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/include/asm/arch-tegra124/pinmux.h | 4 ++ drivers/pinctrl/tegra/pinctrl-tegra.c | 56 +++++++++++++++++++++ 2 files changed, 60 insertions(+)
diff --git a/arch/arm/include/asm/arch-tegra124/pinmux.h b/arch/arm/include/asm/arch-tegra124/pinmux.h index 3aba17d21e4..fbe15fc612d 100644 --- a/arch/arm/include/asm/arch-tegra124/pinmux.h +++ b/arch/arm/include/asm/arch-tegra124/pinmux.h @@ -578,6 +578,10 @@ static const char * const tegra_pinctrl_to_drvgrp[] = { [PMUX_DRVGRP_AO4] = "ao4", };
+static const char * const tegra_pinctrl_to_mipipadgrp[] = { + [PMUX_MIPIPADCTRLGRP_DSI_B] = "mipi_pad_ctrl_dsi_b", +}; + static const char * const tegra_pinctrl_to_func[] = { [PMUX_FUNC_DEFAULT] = "default", [PMUX_FUNC_BLINK] = "blink", diff --git a/drivers/pinctrl/tegra/pinctrl-tegra.c b/drivers/pinctrl/tegra/pinctrl-tegra.c index ad7112a05e6..e6b957f5537 100644 --- a/drivers/pinctrl/tegra/pinctrl-tegra.c +++ b/drivers/pinctrl/tegra/pinctrl-tegra.c @@ -67,6 +67,58 @@ exit: kfree(drive_group); }
+#ifdef TEGRA_PMX_SOC_HAS_MIPI_PAD_CTRL_GRPS +static void tegra_pinctrl_set_mipipad(struct udevice *config, int padcnt) +{ + struct pmux_mipipadctrlgrp_config *mipipad_group; + int i, ret, pad_id; + const char *function; + const char **pads; + + mipipad_group = kmalloc_array(padcnt, sizeof(*mipipad_group), GFP_KERNEL); + if (!mipipad_group) { + log_debug("%s: cannot allocate mipi pad group array\n", __func__); + return; + } + + /* decode function id and fill the first copy of pmux_mipipadctrlgrp_config */ + function = dev_read_string(config, "nvidia,function"); + if (function) + for (i = 0; i < PMUX_FUNC_COUNT; i++) + if (tegra_pinctrl_to_func[i]) + if (!strcmp(function, tegra_pinctrl_to_func[i])) + break; + + mipipad_group[0].func = i; + + for (i = 1; i < padcnt; i++) + memcpy(&mipipad_group[i], &mipipad_group[0], sizeof(mipipad_group[0])); + + ret = dev_read_string_list(config, "nvidia,pins", &pads); + if (ret < 0) { + log_debug("%s: could not parse property nvidia,pins\n", __func__); + goto exit; + } + + for (i = 0; i < padcnt; i++) { + for (pad_id = 0; pad_id < PMUX_MIPIPADCTRLGRP_COUNT; pad_id++) + if (tegra_pinctrl_to_mipipadgrp[pad_id]) + if (!strcmp(pads[i], tegra_pinctrl_to_mipipadgrp[pad_id])) { + mipipad_group[i].grp = pad_id; + break; + } + } + + pinmux_config_mipipadctrlgrp_table(mipipad_group, padcnt); + + free(pads); +exit: + kfree(mipipad_group); +} +#else +static void tegra_pinctrl_set_mipipad(struct udevice *config, int padcnt) { } +#endif + static void tegra_pinctrl_set_pin(struct udevice *config, int pincnt) { struct pmux_pingrp_config *pinmux_group; @@ -170,6 +222,9 @@ static int tegra_pinctrl_set_state(struct udevice *dev, struct udevice *config) if (!strncmp(name, "drive_", 6)) /* Drive node is detected */ tegra_pinctrl_set_drive(child, ret); + else if (!strncmp(name, "mipi_pad_ctrl_", 14)) + /* Handle T124 specific pinconfig */ + tegra_pinctrl_set_mipipad(child, ret); else /* Pin node is detected */ tegra_pinctrl_set_pin(child, ret); @@ -236,6 +291,7 @@ static int tegra_pinctrl_bind(struct udevice *dev) static const struct udevice_id tegra_pinctrl_ids[] = { { .compatible = "nvidia,tegra30-pinmux" }, { .compatible = "nvidia,tegra114-pinmux" }, + { .compatible = "nvidia,tegra124-pinmux" }, { }, };
Tegra K1 is fully compatible with existing DC and DSI implementation using Tegra 4 data.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/tegra20/tegra-dc.c | 3 +++ drivers/video/tegra20/tegra-dsi.c | 1 + 2 files changed, 4 insertions(+)
diff --git a/drivers/video/tegra20/tegra-dc.c b/drivers/video/tegra20/tegra-dc.c index e366df9ab51..16a2b5281bf 100644 --- a/drivers/video/tegra20/tegra-dc.c +++ b/drivers/video/tegra20/tegra-dc.c @@ -553,6 +553,9 @@ static const struct udevice_id tegra_lcd_ids[] = { }, { .compatible = "nvidia,tegra114-dc", .data = (ulong)&tegra114_dc_soc_info + }, { + .compatible = "nvidia,tegra124-dc", + .data = (ulong)&tegra114_dc_soc_info }, { /* sentinel */ } diff --git a/drivers/video/tegra20/tegra-dsi.c b/drivers/video/tegra20/tegra-dsi.c index 0b395dbf9fa..b57df6b82bf 100644 --- a/drivers/video/tegra20/tegra-dsi.c +++ b/drivers/video/tegra20/tegra-dsi.c @@ -1073,6 +1073,7 @@ static const struct panel_ops tegra_dsi_bridge_ops = { static const struct udevice_id tegra_dsi_bridge_ids[] = { { .compatible = "nvidia,tegra30-dsi", .data = DSI_V0 }, { .compatible = "nvidia,tegra114-dsi", .data = DSI_V1 }, + { .compatible = "nvidia,tegra124-dsi", .data = DSI_V1 }, { } };
Re-design MIPI calibration driver to fit T124.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/tegra20/tegra-dsi.c | 11 ++- drivers/video/tegra20/tegra-mipi.c | 134 ++++++++++++++++++++++++++--- 2 files changed, 130 insertions(+), 15 deletions(-)
diff --git a/drivers/video/tegra20/tegra-dsi.c b/drivers/video/tegra20/tegra-dsi.c index b57df6b82bf..d066ffc8b9d 100644 --- a/drivers/video/tegra20/tegra-dsi.c +++ b/drivers/video/tegra20/tegra-dsi.c @@ -53,6 +53,7 @@ struct tegra_dsi_priv { int video_fifo_depth; int host_fifo_depth;
+ u32 calibration_pads; u32 version;
/* for ganged-mode support */ @@ -550,7 +551,7 @@ static void tegra_dsi_mipi_calibrate(struct tegra_dsi_priv *priv) DSI_PAD_PREEMP_PD(0x03) | DSI_PAD_PREEMP_PU(0x3); writel(value, &pad->pad_ctrl_3);
- ret = misc_write(priv->mipi, 0, NULL, 0); + ret = misc_write(priv->mipi, priv->calibration_pads, NULL, 0); if (ret) log_debug("%s: MIPI calibration failed %d\n", __func__, ret); } @@ -1033,6 +1034,14 @@ static int tegra_dsi_bridge_probe(struct udevice *dev) log_debug("%s: cannot get MIPI: error %d\n", __func__, ret); return ret; } + + ret = dev_read_u32_index(dev, "nvidia,mipi-calibrate", 1, + &priv->calibration_pads); + if (ret) { + log_debug("%s: cannot get calibration pads: error %d\n", + __func__, ret); + return ret; + } }
panel_get_display_timing(priv->panel, &priv->timing); diff --git a/drivers/video/tegra20/tegra-mipi.c b/drivers/video/tegra20/tegra-mipi.c index 2df3c1a9942..a4f4343d008 100644 --- a/drivers/video/tegra20/tegra-mipi.c +++ b/drivers/video/tegra20/tegra-mipi.c @@ -10,9 +10,10 @@ #include <linux/delay.h> #include <linux/iopoll.h>
+#include <asm/arch/clock.h> #include <asm/io.h>
-/* MIPI control registers 0x00 ~ 0x60 */ +/* MIPI control registers 0x00 ~ 0x74 */ struct mipi_ctlr { uint mipi_cal_ctrl; uint mipi_cal_autocal_ctrl; @@ -38,8 +39,17 @@ struct mipi_ctlr { uint mipi_cal_bias_pad_cfg0; uint mipi_cal_bias_pad_cfg1; uint mipi_cal_bias_pad_cfg2; + + uint mipi_cal_dsia_config_2; + uint mipi_cal_dsib_config_2; + uint mipi_cal_cilc_config_2; + uint mipi_cal_cild_config_2; + uint mipi_cal_csie_config_2; };
+#define MIPI_DSIA_PADS 0x60 +#define MIPI_DSIB_PADS 0x180 + #define MIPI_CAL_CTRL_NOISE_FILTER(x) (((x) & 0xf) << 26) #define MIPI_CAL_CTRL_PRESCALE(x) (((x) & 0x3) << 24) #define MIPI_CAL_CTRL_CLKEN_OVR BIT(4) @@ -64,26 +74,25 @@ struct mipi_ctlr { #define MIPI_CAL_BIAS_PAD_VAUXP(x) (((x) & 0x7) << 4) #define MIPI_CAL_BIAS_PAD_PDVREG BIT(1)
+#define MIPI_CAL_HSCLKPDOSDSI(x) (((x) & 0x1f) << 8) +#define MIPI_CAL_HSCLKPUOSDSI(x) (((x) & 0x1f) << 0) + struct tegra_mipi_priv { struct mipi_ctlr *mipi; struct clk *mipi_cal; + u32 version; };
-static int tegra_mipi_calibrate(struct udevice *dev, int offset, const void *buf, - int size) +enum { + T114, + T124, +}; + +static void tegra114_mipi_pads_cal(struct tegra_mipi_priv *priv, + int calibration_pads) { - struct tegra_mipi_priv *priv = dev_get_priv(dev); u32 value;
- value = MIPI_CAL_BIAS_PAD_DRV_DN_REF(0x2) | - MIPI_CAL_BIAS_PAD_DRV_UP_REF(0x0); - writel(value, &priv->mipi->mipi_cal_bias_pad_cfg1); - - value = readl(&priv->mipi->mipi_cal_bias_pad_cfg2); - value &= ~MIPI_CAL_BIAS_PAD_VCLAMP(0x7); - value &= ~MIPI_CAL_BIAS_PAD_VAUXP(0x7); - writel(value, &priv->mipi->mipi_cal_bias_pad_cfg2); - value = MIPI_CAL_OVERIDE(0x0) | MIPI_CAL_SEL(0x1) | MIPI_CAL_HSPDOS(0x0) | MIPI_CAL_HSPUOS(0x4) | MIPI_CAL_TERMOS(0x5); @@ -99,6 +108,95 @@ static int tegra_mipi_calibrate(struct udevice *dev, int offset, const void *buf value = readl(&priv->mipi->mipi_cal_config_dsid); value &= ~(MIPI_CAL_SEL(0x1)); writel(value, &priv->mipi->mipi_cal_config_dsid); +} + +static void tegra124_mipi_pads_cal(struct tegra_mipi_priv *priv, + int calibration_pads) +{ + u32 value; + + /* Calibrate DSI-A */ + if (calibration_pads == MIPI_DSIA_PADS) { + printf("Calibrating DSI-A pads\n"); + + value = MIPI_CAL_OVERIDE(0x0) | MIPI_CAL_SEL(0x1) | + MIPI_CAL_HSPDOS(0x0) | MIPI_CAL_HSPUOS(0x0) | + MIPI_CAL_TERMOS(0x0); + writel(value, &priv->mipi->mipi_cal_config_dsia); + writel(value, &priv->mipi->mipi_cal_config_dsib); + + value = MIPI_CAL_SEL(0x1) | + MIPI_CAL_HSCLKPDOSDSI(0x1) | + MIPI_CAL_HSCLKPUOSDSI(0x2); + writel(value, &priv->mipi->mipi_cal_dsia_config_2); + writel(value, &priv->mipi->mipi_cal_dsib_config_2); + + /* Deselect PAD C */ + value = readl(&priv->mipi->mipi_cal_cilc_config_2); + value &= ~(MIPI_CAL_SEL(0x1)); + writel(value, &priv->mipi->mipi_cal_cilc_config_2); + + /* Deselect PAD D */ + value = readl(&priv->mipi->mipi_cal_cild_config_2); + value &= ~(MIPI_CAL_SEL(0x1)); + writel(value, &priv->mipi->mipi_cal_cild_config_2); + } + + /* Calibrate DSI-B */ + if (calibration_pads == MIPI_DSIB_PADS) { + printf("Calibrating DSI-B pads\n"); + + value = MIPI_CAL_OVERIDE(0x0) | MIPI_CAL_SEL(0x1) | + MIPI_CAL_HSPDOS(0x0) | MIPI_CAL_HSPUOS(0x0) | + MIPI_CAL_TERMOS(0x0); + writel(value, &priv->mipi->mipi_cal_config_csic); + writel(value, &priv->mipi->mipi_cal_config_csid); + + value = MIPI_CAL_SEL(0x1) | + MIPI_CAL_HSCLKPDOSDSI(0x1) | + MIPI_CAL_HSCLKPUOSDSI(0x2); + writel(value, &priv->mipi->mipi_cal_cilc_config_2); + writel(value, &priv->mipi->mipi_cal_cild_config_2); + + /* Deselect PAD A */ + value = readl(&priv->mipi->mipi_cal_dsia_config_2); + value &= ~(MIPI_CAL_SEL(0x1)); + writel(value, &priv->mipi->mipi_cal_dsia_config_2); + + /* Deselect PAD B */ + value = readl(&priv->mipi->mipi_cal_dsib_config_2); + value &= ~(MIPI_CAL_SEL(0x1)); + writel(value, &priv->mipi->mipi_cal_dsib_config_2); + } +} + +static int tegra_mipi_calibrate(struct udevice *dev, int offset, const void *buf, + int size) +{ + struct tegra_mipi_priv *priv = dev_get_priv(dev); + u32 value; + + value = MIPI_CAL_BIAS_PAD_DRV_DN_REF(0x2) | + MIPI_CAL_BIAS_PAD_DRV_UP_REF(0x0); + writel(value, &priv->mipi->mipi_cal_bias_pad_cfg1); + + value = readl(&priv->mipi->mipi_cal_bias_pad_cfg2); + value &= ~MIPI_CAL_BIAS_PAD_VCLAMP(0x7); + value &= ~MIPI_CAL_BIAS_PAD_VAUXP(0x7); + writel(value, &priv->mipi->mipi_cal_bias_pad_cfg2); + + switch (priv->version) { + case T114: + tegra114_mipi_pads_cal(priv, offset); + break; + + case T124: + tegra124_mipi_pads_cal(priv, offset); + break; + + default: + return -EINVAL; + }
value = readl(&priv->mipi->mipi_cal_ctrl); value &= ~MIPI_CAL_CTRL_NOISE_FILTER(0xf); @@ -134,6 +232,11 @@ static int tegra_mipi_enable(struct udevice *dev, bool val) struct tegra_mipi_priv *priv = dev_get_priv(dev); u32 value;
+ reset_set_enable(priv->mipi_cal->id, 1); + mdelay(100); + reset_set_enable(priv->mipi_cal->id, 0); + mdelay(1); + clk_enable(priv->mipi_cal);
value = readl(&priv->mipi->mipi_cal_bias_pad_cfg0); @@ -157,6 +260,8 @@ static int tegra_mipi_probe(struct udevice *dev) { struct tegra_mipi_priv *priv = dev_get_priv(dev);
+ priv->version = dev_get_driver_data(dev); + priv->mipi = (struct mipi_ctlr *)dev_read_addr_ptr(dev); if (!priv->mipi) { log_debug("%s: no MIPI controller address\n", __func__); @@ -174,7 +279,8 @@ static int tegra_mipi_probe(struct udevice *dev) }
static const struct udevice_id tegra_mipi_ids[] = { - { .compatible = "nvidia,tegra114-mipi" }, + { .compatible = "nvidia,tegra114-mipi", .data = T114 }, + { .compatible = "nvidia,tegra124-mipi", .data = T124 }, { } };
Add support for National Semiconductor/TI LP8550/1/2/3/5/6/7 LED Backlight. Driver is based on Linux version but is reworked and optimised for U-Boot DM framework. Currently only register driven backlight control is supported, PWM driver backlight control may be added later if needed.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/Kconfig | 10 + drivers/video/Makefile | 1 + drivers/video/lp855x_backlight.c | 302 +++++++++++++++++++++++++++++++ 3 files changed, 313 insertions(+) create mode 100644 drivers/video/lp855x_backlight.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 3c3cebaacd0..926dafe7a5a 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -743,6 +743,16 @@ config BACKLIGHT_LM3533 LM3533 Lighting Power chip. Only Bank A is supported as for now. Supported backlight level range is from 2 to 255 with step of 1.
+config BACKLIGHT_LP855x + bool "Backlight Driver for LP855x" + depends on BACKLIGHT + select DM_I2C + help + Say Y to enable the backlight driver for National Semiconductor / TI + LP8550/1/2/3/5/6/7 LED Backlight Driver. Only register driven mode is + supported for now, PWM mode can be added if there will be any need in + it. Supported backlight level range is from 0 to 255 with step of 1. + source "drivers/video/ti/Kconfig"
source "drivers/video/exynos/Kconfig" diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 5a00438ce06..391ef8397bc 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -30,6 +30,7 @@ obj-$(CONFIG_$(PHASE_)BMP) += bmp.o endif
obj-$(CONFIG_BACKLIGHT_LM3533) += lm3533_backlight.o +obj-$(CONFIG_BACKLIGHT_LP855x) += lp855x_backlight.o obj-${CONFIG_EXYNOS_FB} += exynos/ obj-${CONFIG_VIDEO_ROCKCHIP} += rockchip/ obj-${CONFIG_VIDEO_STM32} += stm32/ diff --git a/drivers/video/lp855x_backlight.c b/drivers/video/lp855x_backlight.c new file mode 100644 index 00000000000..5debc0aa453 --- /dev/null +++ b/drivers/video/lp855x_backlight.c @@ -0,0 +1,302 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2011 Texas Instruments + * Copyright (c) 2024 Svyatoslav Ryhel clamor95@gmail.com + */ + +#define LOG_CATEGORY UCLASS_PANEL_BACKLIGHT + +#include <malloc.h> +#include <backlight.h> +#include <dm.h> +#include <dm/devres.h> +#include <i2c.h> +#include <log.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <asm/gpio.h> +#include <power/regulator.h> + +#define LP855x_MIN_BRIGHTNESS 0x00 +#define LP855x_MAX_BRIGHTNESS 0xff + +/* LP8550/1/2/3/6 Registers */ +#define LP855X_BRIGHTNESS_CTRL 0x00 +#define LP855X_DEVICE_CTRL 0x01 +#define LP855X_EEPROM_START 0xa0 +#define LP855X_EEPROM_END 0xa7 +#define LP8556_EPROM_START 0x98 +#define LP8556_EPROM_END 0xaf + +/* LP8555/7 Registers */ +#define LP8557_BL_CMD 0x00 +#define LP8557_BL_MASK 0x01 +#define LP8557_BL_ON 0x01 +#define LP8557_BL_OFF 0x00 +#define LP8557_BRIGHTNESS_CTRL 0x04 +#define LP8557_CONFIG 0x10 +#define LP8555_EPROM_START 0x10 +#define LP8555_EPROM_END 0x7a +#define LP8557_EPROM_START 0x10 +#define LP8557_EPROM_END 0x1e + +struct lp855x_rom_data { + u8 addr; + u8 val; +}; + +struct lp855x_backlight_priv; + +/* + * struct lp855x_device_config + * @pre_init_device: init device function call before updating the brightness + * @reg_brightness: register address for brigthenss control + * @reg_devicectrl: register address for device control + * @post_init_device: late init device function call + */ +struct lp855x_device_config { + int (*pre_init_device)(struct udevice *dev); + u8 reg_brightness; + u8 reg_devicectrl; + u8 reg_eepromstart; + u8 reg_eepromend; + int (*post_init_device)(struct udevice *dev); +}; + +struct lp855x_backlight_priv { + struct udevice *supply; /* regulator for VDD input */ + struct udevice *enable; /* regulator for EN/VDDIO input */ + + u8 device_control; + u8 initial_brightness; + + int size_program; + struct lp855x_rom_data *rom_data; + struct lp855x_device_config *cfg; +}; + +static int lp855x_backlight_enable(struct udevice *dev) +{ + struct lp855x_backlight_priv *priv = dev_get_priv(dev); + int ret; + + ret = regulator_set_enable_if_allowed(priv->supply, 1); + if (ret) { + log_debug("%s: enabling power-supply failed (%d)\n", + __func__, ret); + return ret; + } + + ret = regulator_set_enable_if_allowed(priv->enable, 1); + if (ret) { + log_debug("%s: enabling enable-supply failed (%d)\n", + __func__, ret); + return ret; + } + mdelay(2); + + if (priv->cfg->pre_init_device) { + ret = priv->cfg->pre_init_device(dev); + if (ret) { + log_debug("%s: pre init device err: %d\n", + __func__, ret); + return ret; + } + } + + ret = dm_i2c_reg_write(dev, priv->cfg->reg_brightness, + priv->initial_brightness); + if (ret) + return ret; + + ret = dm_i2c_reg_write(dev, priv->cfg->reg_devicectrl, + priv->device_control); + if (ret) + return ret; + + if (priv->size_program > 0) { + int i; + u8 val, addr; + + for (i = 0; i < priv->size_program; i++) { + addr = priv->rom_data[i].addr; + val = priv->rom_data[i].val; + + if (addr < priv->cfg->reg_eepromstart && + addr > priv->cfg->reg_eepromend) + continue; + + ret = dm_i2c_reg_write(dev, addr, val); + if (ret) + return ret; + } + } + + if (priv->cfg->post_init_device) { + ret = priv->cfg->post_init_device(dev); + if (ret) { + log_debug("%s: post init device err: %d\n", + __func__, ret); + return ret; + } + } + + return 0; +} + +static int lp855x_backlight_set_brightness(struct udevice *dev, int percent) +{ + struct lp855x_backlight_priv *priv = dev_get_priv(dev); + + if (percent == BACKLIGHT_DEFAULT) + percent = priv->initial_brightness; + + if (percent < LP855x_MIN_BRIGHTNESS) + percent = LP855x_MIN_BRIGHTNESS; + + if (percent > LP855x_MAX_BRIGHTNESS) + percent = LP855x_MAX_BRIGHTNESS; + + /* Set brightness level */ + return dm_i2c_reg_write(dev, priv->cfg->reg_brightness, + percent); +} + +static int lp855x_backlight_probe(struct udevice *dev) +{ + struct lp855x_backlight_priv *priv = dev_get_priv(dev); + int rom_length, ret; + + if (device_get_uclass_id(dev->parent) != UCLASS_I2C) + return -EPROTONOSUPPORT; + + priv->cfg = (struct lp855x_device_config *)dev_get_driver_data(dev); + + dev_read_u8(dev, "dev-ctrl", &priv->device_control); + dev_read_u8(dev, "init-brt", &priv->initial_brightness); + + /* Fill ROM platform data if defined */ + rom_length = dev_get_child_count(dev); + if (rom_length > 0) { + struct lp855x_rom_data *rom; + ofnode child; + int i = 0; + + rom = devm_kcalloc(dev, rom_length, sizeof(*rom), GFP_KERNEL); + if (!rom) + return -ENOMEM; + + dev_for_each_subnode(child, dev) { + ofnode_read_u8(child, "rom-addr", &rom[i].addr); + ofnode_read_u8(child, "rom-val", &rom[i].val); + i++; + } + + priv->size_program = rom_length; + priv->rom_data = &rom[0]; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "power-supply", &priv->supply); + if (ret) { + log_err("%s: cannot get power-supply: ret = %d\n", __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "enable-supply", &priv->enable); + if (ret) { + log_err("%s: cannot get enable-supply: ret = %d\n", __func__, ret); + return ret; + } + + return 0; +} + +static const struct backlight_ops lp855x_backlight_ops = { + .enable = lp855x_backlight_enable, + .set_brightness = lp855x_backlight_set_brightness, +}; + +static int lp8556_bl_rst(struct udevice *dev) +{ + int ret; + + /* Reset backlight after updating EPROM settings */ + ret = dm_i2c_reg_clrset(dev, LP855X_DEVICE_CTRL, LP8557_BL_MASK, + LP8557_BL_OFF); + if (ret) + return ret; + + mdelay(10); + + return dm_i2c_reg_clrset(dev, LP855X_DEVICE_CTRL, LP8557_BL_MASK, + LP8557_BL_ON); +} + +static int lp8557_bl_off(struct udevice *dev) +{ + /* BL_ON = 0 before updating EPROM settings */ + return dm_i2c_reg_clrset(dev, LP8557_BL_CMD, LP8557_BL_MASK, + LP8557_BL_OFF); +} + +static int lp8557_bl_on(struct udevice *dev) +{ + /* BL_ON = 1 after updating EPROM settings */ + return dm_i2c_reg_clrset(dev, LP8557_BL_CMD, LP8557_BL_MASK, + LP8557_BL_ON); +} + +static struct lp855x_device_config lp855x_dev_cfg = { + .reg_brightness = LP855X_BRIGHTNESS_CTRL, + .reg_devicectrl = LP855X_DEVICE_CTRL, + .reg_eepromstart = LP855X_EEPROM_START, + .reg_eepromend = LP855X_EEPROM_END, +}; + +static struct lp855x_device_config lp8555_dev_cfg = { + .reg_brightness = LP8557_BRIGHTNESS_CTRL, + .reg_devicectrl = LP8557_CONFIG, + .reg_eepromstart = LP8555_EPROM_START, + .reg_eepromend = LP8555_EPROM_END, + .pre_init_device = lp8557_bl_off, + .post_init_device = lp8557_bl_on, +}; + +static struct lp855x_device_config lp8556_dev_cfg = { + .reg_brightness = LP855X_BRIGHTNESS_CTRL, + .reg_devicectrl = LP855X_DEVICE_CTRL, + .reg_eepromstart = LP8556_EPROM_START, + .reg_eepromend = LP8556_EPROM_END, + .post_init_device = lp8556_bl_rst, +}; + +static struct lp855x_device_config lp8557_dev_cfg = { + .reg_brightness = LP8557_BRIGHTNESS_CTRL, + .reg_devicectrl = LP8557_CONFIG, + .reg_eepromstart = LP8557_EPROM_START, + .reg_eepromend = LP8557_EPROM_END, + .pre_init_device = lp8557_bl_off, + .post_init_device = lp8557_bl_on, +}; + +static const struct udevice_id lp855x_backlight_ids[] = { + { .compatible = "ti,lp8550", .data = (ulong)&lp855x_dev_cfg }, + { .compatible = "ti,lp8551", .data = (ulong)&lp855x_dev_cfg }, + { .compatible = "ti,lp8552", .data = (ulong)&lp855x_dev_cfg }, + { .compatible = "ti,lp8553", .data = (ulong)&lp855x_dev_cfg }, + { .compatible = "ti,lp8555", .data = (ulong)&lp8555_dev_cfg }, + { .compatible = "ti,lp8556", .data = (ulong)&lp8556_dev_cfg }, + { .compatible = "ti,lp8557", .data = (ulong)&lp8557_dev_cfg }, + { } +}; + +U_BOOT_DRIVER(lp855x_backlight) = { + .name = "lp855x_backlight", + .id = UCLASS_PANEL_BACKLIGHT, + .of_match = lp855x_backlight_ids, + .probe = lp855x_backlight_probe, + .ops = &lp855x_backlight_ops, + .priv_auto = sizeof(struct lp855x_backlight_priv), +};
This module is a color active matrix LCD module incorporating Oxide TFT (Thin Film Transistor). It is composed of a color TFT-LCD panel, driver ICs, a control circuit and power supply circuit, and a backlight unit. Graphics and texts can be displayed on a 1536x2048 dots panel with (16,777,216) colors by using MIPI DUAL DSI interface, supplying +3.3V DC supply voltage for TFT-LCD panel driving and supplying DC supply voltage for LED Backlight.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/video/Kconfig | 9 + drivers/video/Makefile | 1 + drivers/video/sharp-lq079l1sx01.c | 275 ++++++++++++++++++++++++++++++ 3 files changed, 285 insertions(+) create mode 100644 drivers/video/sharp-lq079l1sx01.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 926dafe7a5a..b1ef73f3e5c 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -599,6 +599,15 @@ config VIDEO_LCD_SAMSUNG_LTL106HL02 LCD module found in Microsoft Surface 2. The panel has a FullHD resolution (1920x1080).
+config VIDEO_LCD_SHARP_LQ079L1SX01 + tristate "Sharp LQ079L1SX01 1536x2048 DSI video mode panel" + depends on PANEL && BACKLIGHT + select VIDEO_MIPI_DSI + help + Say Y here if you want to enable support for Sharp LQ079L1SX01 + LCD module found in Xiaomi Mi Pad tablet. The panel has a QXGA + resolution (1536x2048). + config VIDEO_LCD_SHARP_LQ101R1SX01 tristate "Sharp LQ101R1SX01 2560x1600 DSI video mode panel" depends on PANEL && BACKLIGHT diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 391ef8397bc..6073bc5234a 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -65,6 +65,7 @@ obj-$(CONFIG_VIDEO_LCD_RAYDIUM_RM68200) += raydium-rm68200.o obj-$(CONFIG_VIDEO_LCD_RENESAS_R61307) += renesas-r61307.o obj-$(CONFIG_VIDEO_LCD_RENESAS_R69328) += renesas-r69328.o obj-$(CONFIG_VIDEO_LCD_SAMSUNG_LTL106HL02) += samsung-ltl106hl02.o +obj-$(CONFIG_VIDEO_LCD_SHARP_LQ079L1SX01) += sharp-lq079l1sx01.o obj-$(CONFIG_VIDEO_LCD_SHARP_LQ101R1SX01) += sharp-lq101r1sx01.o obj-$(CONFIG_VIDEO_LCD_SSD2828) += ssd2828.o obj-$(CONFIG_VIDEO_LCD_TDO_TL070WSH30) += tdo-tl070wsh30.o diff --git a/drivers/video/sharp-lq079l1sx01.c b/drivers/video/sharp-lq079l1sx01.c new file mode 100644 index 00000000000..03ff5d6ced4 --- /dev/null +++ b/drivers/video/sharp-lq079l1sx01.c @@ -0,0 +1,275 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Sharp LQ079L1SX01 DSI panel driver + * + * Copyright (c) 2024 Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <backlight.h> +#include <dm.h> +#include <panel.h> +#include <log.h> +#include <mipi_dsi.h> +#include <linux/delay.h> +#include <asm/gpio.h> +#include <power/regulator.h> + +struct sharp_lq079l1sx01_priv { + struct udevice *backlight; + struct udevice *panel_sec; + + struct udevice *avdd; + struct udevice *vddio; + struct udevice *vsp; + struct udevice *vsn; + + struct gpio_desc reset_gpio; +}; + +static struct display_timing default_timing = { + .pixelclock.typ = 215000000, + .hactive.typ = 1536, + .hfront_porch.typ = 136, + .hback_porch.typ = 28, + .hsync_len.typ = 28, + .vactive.typ = 2048, + .vfront_porch.typ = 14, + .vback_porch.typ = 8, + .vsync_len.typ = 2, +}; + +static int dcs_write_one(struct mipi_dsi_device *dsi, u8 cmd, u8 data) +{ + return mipi_dsi_dcs_write(dsi, cmd, &data, 1); +} + +static int sharp_lq079l1sx01_enable_backlight(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); + struct mipi_dsi_device *dsi = plat->device; + int ret; + + ret = mipi_dsi_dcs_exit_sleep_mode(dsi); + if (ret < 0) { + log_debug("%s: failed to exit sleep mode %s: %d\n", + __func__, dev->parent->name, ret); + } + mdelay(120); + + ret = dcs_write_one(dsi, MIPI_DCS_SET_DISPLAY_BRIGHTNESS, 0xff); + if (ret < 0) { + log_debug("%s: failed to SET_DISPLAY_BRIGHTNESS %s: %d\n", + __func__, dev->parent->name, ret); + } + ret = dcs_write_one(dsi, MIPI_DCS_WRITE_POWER_SAVE, 0x01); + if (ret < 0) { + log_debug("%s: failed to WRITE_POWER_SAVE %s: %d\n", + __func__, dev->parent->name, ret); + } + ret = dcs_write_one(dsi, MIPI_DCS_WRITE_CONTROL_DISPLAY, 0x2c); + if (ret < 0) { + log_debug("%s: failed to WRITE_CONTROL_DISPLAY %s: %d\n", + __func__, dev->parent->name, ret); + } + + ret = mipi_dsi_dcs_set_display_on(dsi); + if (ret < 0) { + log_debug("%s: failed to set panel on %s: %d\n", + __func__, dev->parent->name, ret); + } + + return 0; +} + +static int sharp_lq079l1sx01_set_backlight(struct udevice *dev, int percent) +{ + struct sharp_lq079l1sx01_priv *priv = dev_get_priv(dev); + int ret; + + if (!priv->panel_sec) + return 0; + + ret = backlight_enable(priv->backlight); + if (ret) + return ret; + + return backlight_set_brightness(priv->backlight, percent); +} + +static int sharp_lq079l1sx01_timings(struct udevice *dev, + struct display_timing *timing) +{ + memcpy(timing, &default_timing, sizeof(*timing)); + return 0; +} + +static int sharp_lq079l1sx01_of_to_plat(struct udevice *dev) +{ + struct sharp_lq079l1sx01_priv *priv = dev_get_priv(dev); + int ret; + + /* If node has no link2 it is secondary panel */ + if (!dev_read_bool(dev, "link2")) + return 0; + + ret = uclass_get_device_by_phandle(UCLASS_PANEL, dev, + "link2", &priv->panel_sec); + if (ret) { + log_debug("%s: cannot get secondary panel: ret = %d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_PANEL_BACKLIGHT, dev, + "backlight", &priv->backlight); + if (ret) { + log_debug("%s: cannot get backlight: ret = %d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "avdd-supply", &priv->avdd); + if (ret) { + log_debug("%s: cannot get avdd-supply: ret = %d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "vddio-supply", &priv->vddio); + if (ret) { + log_debug("%s: cannot get vddio-supply: ret = %d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "vsp-supply", &priv->vsp); + if (ret) { + log_debug("%s: cannot get vsp-supply: ret = %d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, + "vsn-supply", &priv->vsn); + if (ret) { + log_debug("%s: cannot get vsn-supply: ret = %d\n", + __func__, ret); + return ret; + } + + ret = gpio_request_by_name(dev, "reset-gpios", 0, + &priv->reset_gpio, GPIOD_IS_OUT); + if (ret) { + log_debug("%s: cannot get reser-gpios (%d)\n", + __func__, ret); + return ret; + } + + return 0; +} + +static int sharp_lq079l1sx01_hw_init(struct udevice *dev) +{ + struct sharp_lq079l1sx01_priv *priv = dev_get_priv(dev); + int ret; + + if (!priv->panel_sec) + return 0; + + ret = regulator_set_enable_if_allowed(priv->vddio, 1); + if (ret) { + log_debug("%s: enabling vddio-supply failed (%d)\n", + __func__, ret); + return ret; + } + + ret = regulator_set_enable_if_allowed(priv->avdd, 1); + if (ret) { + log_debug("%s: enabling avdd-supply failed (%d)\n", + __func__, ret); + return ret; + } + + mdelay(12); + + ret = regulator_set_enable_if_allowed(priv->vsp, 1); + if (ret) { + log_debug("%s: enabling vsp-supply failed (%d)\n", + __func__, ret); + return ret; + } + + mdelay(12); + + ret = regulator_set_enable_if_allowed(priv->vsn, 1); + if (ret) { + log_debug("%s: enabling vsn-supply failed (%d)\n", + __func__, ret); + return ret; + } + + mdelay(24); + + ret = dm_gpio_set_value(&priv->reset_gpio, 0); + if (ret) { + log_debug("%s: error disabling reset-gpios (%d)\n", + __func__, ret); + return ret; + } + udelay(3); + + ret = dm_gpio_set_value(&priv->reset_gpio, 1); + if (ret) { + log_debug("%s: error enabling reset-gpios (%d)\n", + __func__, ret); + return ret; + } + udelay(3); + + ret = dm_gpio_set_value(&priv->reset_gpio, 0); + if (ret) { + log_debug("%s: error disabling reset-gpios (%d)\n", + __func__, ret); + return ret; + } + mdelay(32); + + return 0; +} + +static int sharp_lq079l1sx01_probe(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_plat(dev); + + /* fill characteristics of DSI data link */ + plat->lanes = 4; + plat->format = MIPI_DSI_FMT_RGB888; + plat->mode_flags = MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_LPM; + + return sharp_lq079l1sx01_hw_init(dev); +} + +static const struct panel_ops sharp_lq079l1sx01_ops = { + .enable_backlight = sharp_lq079l1sx01_enable_backlight, + .set_backlight = sharp_lq079l1sx01_set_backlight, + .get_display_timing = sharp_lq079l1sx01_timings, +}; + +static const struct udevice_id sharp_lq079l1sx01_ids[] = { + { .compatible = "sharp,lq079l1sx01" }, + { } +}; + +U_BOOT_DRIVER(sharp_lq079l1sx01) = { + .name = "sharp_lq079l1sx01", + .id = UCLASS_PANEL, + .of_match = sharp_lq079l1sx01_ids, + .ops = &sharp_lq079l1sx01_ops, + .of_to_plat = sharp_lq079l1sx01_of_to_plat, + .probe = sharp_lq079l1sx01_probe, + .plat_auto = sizeof(struct mipi_dsi_panel_plat), + .priv_auto = sizeof(struct sharp_lq079l1sx01_priv), +};
This function allows updating bootloader from u-boot on production devices without need in host PC.
Be aware! It works only with re-crypt BCT and AES encrypted devices.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/mach-tegra/Kconfig | 2 +- arch/arm/mach-tegra/tegra124/Makefile | 1 + arch/arm/mach-tegra/tegra124/bct.c | 91 +++++++++++++++++++++++++++ arch/arm/mach-tegra/tegra124/bct.h | 55 ++++++++++++++++ 4 files changed, 148 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-tegra/tegra124/bct.c create mode 100644 arch/arm/mach-tegra/tegra124/bct.h
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 04612895576..333d432f728 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -247,7 +247,7 @@ config CMD_ENTERRCM
config CMD_EBTUPDATE bool "Enable 'ebtupdate' command" - depends on TEGRA20 || TEGRA30 + depends on TEGRA20 || TEGRA30 || TEGRA124 select TEGRA_CRYPTO help Updating u-boot from within u-boot in rather complex or even diff --git a/arch/arm/mach-tegra/tegra124/Makefile b/arch/arm/mach-tegra/tegra124/Makefile index dee790015a3..7b93db89c0f 100644 --- a/arch/arm/mach-tegra/tegra124/Makefile +++ b/arch/arm/mach-tegra/tegra124/Makefile @@ -6,6 +6,7 @@ #
obj-$(CONFIG_XPL_BUILD) += cpu.o +obj-$(CONFIG_$(XPL_)CMD_EBTUPDATE) += bct.o
obj-y += clock.o obj-y += pmc.o diff --git a/arch/arm/mach-tegra/tegra124/bct.c b/arch/arm/mach-tegra/tegra124/bct.c new file mode 100644 index 00000000000..a71aa87fce1 --- /dev/null +++ b/arch/arm/mach-tegra/tegra124/bct.c @@ -0,0 +1,91 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2022, Ramin raminterex@yahoo.com + * Copyright (c) 2022, Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <command.h> +#include <log.h> +#include <vsprintf.h> +#include <asm/arch-tegra/crypto.h> +#include "bct.h" +#include "uboot_aes.h" + +/* Device with "sbk burned: false" will expose zero key */ +const u8 nosbk[AES128_KEY_LENGTH] = { 0 }; + +/* + * @param bct boot config table start in RAM + * @param ect bootloader start in RAM + * @param ebt_size bootloader file size in bytes + * Return: 0, or 1 if failed + */ +static int bct_patch(u8 *bct, u8 *ebt, u32 ebt_size) +{ + struct nvboot_config_table *bct_tbl = NULL; + u8 ebt_hash[AES128_KEY_LENGTH] = { 0 }; + u8 bct_hash[AES128_KEY_LENGTH] = { 0 }; + u8 sbk[AES128_KEY_LENGTH] = { 0 }; + u8 *sbct = bct + UBCT_LENGTH; + bool encrypted; + int ret; + + ebt_size = roundup(ebt_size, EBT_ALIGNMENT); + + memcpy(sbk, (u8 *)(bct + UBCT_LENGTH + SBCT_LENGTH), + NVBOOT_CMAC_AES_HASH_LENGTH * 4); + + encrypted = memcmp(&sbk, &nosbk, AES128_KEY_LENGTH); + + if (encrypted) { + ret = decrypt_data_block(sbct, SBCT_LENGTH, sbk); + if (ret) + return 1; + + ret = encrypt_data_block(ebt, ebt_size, sbk); + if (ret) + return 1; + } + + ret = sign_enc_data_block(ebt, ebt_size, ebt_hash, sbk); + if (ret) + return 1; + + bct_tbl = (struct nvboot_config_table *)bct; + + memcpy((u8 *)&bct_tbl->bootloader[0].crypto_hash, + ebt_hash, NVBOOT_CMAC_AES_HASH_LENGTH * 4); + bct_tbl->bootloader[0].entry_point = CONFIG_SPL_TEXT_BASE; + bct_tbl->bootloader[0].load_addr = CONFIG_SPL_TEXT_BASE; + bct_tbl->bootloader[0].length = ebt_size; + + if (encrypted) { + ret = encrypt_data_block(sbct, SBCT_LENGTH, sbk); + if (ret) + return 1; + } + + ret = sign_enc_data_block(sbct, SBCT_LENGTH, bct_hash, sbk); + if (ret) + return 1; + + memcpy((u8 *)&bct_tbl->crypto_hash, bct_hash, + NVBOOT_CMAC_AES_HASH_LENGTH * 4); + + return 0; +} + +static int do_ebtupdate(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + u32 bct_addr = hextoul(argv[1], NULL); + u32 ebt_addr = hextoul(argv[2], NULL); + u32 ebt_size = hextoul(argv[3], NULL); + + return bct_patch((u8 *)bct_addr, (u8 *)ebt_addr, ebt_size); +} + +U_BOOT_CMD(ebtupdate, 4, 0, do_ebtupdate, + "update bootloader on re-crypted Tegra124 devices", + "" +); diff --git a/arch/arm/mach-tegra/tegra124/bct.h b/arch/arm/mach-tegra/tegra124/bct.h new file mode 100644 index 00000000000..eb0f712d595 --- /dev/null +++ b/arch/arm/mach-tegra/tegra124/bct.h @@ -0,0 +1,55 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef _BCT_H_ +#define _BCT_H_ + +/* + * Defines the BCT parametres for T124 + */ +#define UBCT_LENGTH 0x6b0 /* bytes */ +#define SBCT_LENGTH 0x1950 /* bytes */ + +#define BCT_HASH 0x10 +#define EBT_ALIGNMENT 0x10 + +/* + * Defines the CMAC-AES-128 hash length in 32 bit words. (128 bits = 4 words) + */ +#define NVBOOT_CMAC_AES_HASH_LENGTH 4 + +/* + * Defines the RSA modulus length in 32 bit words used for PKC secure boot. + */ +#define NVBOOT_SE_RSA_MODULUS_LENGTH 64 + +/* + * Defines the maximum number of bootloader descriptions in the BCT. + */ +#define NVBOOT_MAX_BOOTLOADERS 4 + +struct nv_bootloader_info { + u32 version; + u32 start_blk; + u32 start_page; + u32 length; + u32 load_addr; + u32 entry_point; + u32 attribute; + + /* Specifies the AES-CMAC MAC or RSASSA-PSS signature of the BL. */ + u32 crypto_hash[NVBOOT_CMAC_AES_HASH_LENGTH]; + u32 bl_rsa_sig[NVBOOT_SE_RSA_MODULUS_LENGTH]; +}; + +struct nvboot_config_table { + u32 ubct_unused1[196]; + u32 crypto_hash[NVBOOT_CMAC_AES_HASH_LENGTH]; + u32 ubct_unused2[228]; + + u32 sbct_unused1[1318]; + u32 bootloader_used; + struct nv_bootloader_info bootloader[NVBOOT_MAX_BOOTLOADERS]; + u32 sbct_unused2; +}; + +#endif /* _BCT_H_ */
The Mi Pad is a tablet computer based on Nvidia Tegra K1 SoC which originally ran the Android operating system. The Mi Pad has a 7.9" IPS display with 1536 x 2048 (324 ppi) resolution. 2 GB of RAM and 16/64 GB of internal memory that can be supplemented with a microSDXC card giving up to 128 GB of additional storage.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-xiaomi-mocha.dts | 603 +++++++++++++++++++++++++ arch/arm/mach-tegra/tegra124/Kconfig | 5 + board/xiaomi/mocha/Kconfig | 12 + board/xiaomi/mocha/MAINTAINERS | 8 + board/xiaomi/mocha/Makefile | 9 + board/xiaomi/mocha/mocha-spl.c | 49 ++ board/xiaomi/mocha/mocha.c | 41 ++ board/xiaomi/mocha/mocha.env | 23 + configs/mocha_defconfig | 90 ++++ doc/board/index.rst | 1 + doc/board/xiaomi/index.rst | 9 + doc/board/xiaomi/mocha.rst | 112 +++++ include/configs/mocha.h | 25 + 14 files changed, 988 insertions(+) create mode 100644 arch/arm/dts/tegra124-xiaomi-mocha.dts create mode 100644 board/xiaomi/mocha/Kconfig create mode 100644 board/xiaomi/mocha/MAINTAINERS create mode 100644 board/xiaomi/mocha/Makefile create mode 100644 board/xiaomi/mocha/mocha-spl.c create mode 100644 board/xiaomi/mocha/mocha.c create mode 100644 board/xiaomi/mocha/mocha.env create mode 100644 configs/mocha_defconfig create mode 100644 doc/board/xiaomi/index.rst create mode 100644 doc/board/xiaomi/mocha.rst create mode 100644 include/configs/mocha.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fa8c4d1d3bf..b294d427f4d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -135,6 +135,7 @@ dtb-$(CONFIG_ARCH_TEGRA) += \ tegra124-nyan-big.dtb \ tegra124-cei-tk1-som.dtb \ tegra124-venice2.dtb \ + tegra124-xiaomi-mocha.dtb \ tegra186-p2771-0000-000.dtb \ tegra186-p2771-0000-500.dtb \ tegra210-p2371-0000.dtb \ diff --git a/arch/arm/dts/tegra124-xiaomi-mocha.dts b/arch/arm/dts/tegra124-xiaomi-mocha.dts new file mode 100644 index 00000000000..2b4e220b3bf --- /dev/null +++ b/arch/arm/dts/tegra124-xiaomi-mocha.dts @@ -0,0 +1,603 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include "tegra124.dtsi" + +/ { + model = "Xiaomi Mi Pad A0101"; + compatible = "xiaomi,mocha", "nvidia,tegra124"; + + chosen { + stdout-path = &uartd; + }; + + aliases { + i2c0 = &pwr_i2c; + i2c1 = &gen1_i2c; + + mmc0 = &sdmmc4; /* eMMC */ + mmc1 = &sdmmc3; /* uSD slot */ + + usb0 = &usb1; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x80000000>; + }; + + host1x@50000000 { + dc@54200000 { + clocks = <&tegra_car TEGRA124_CLK_DISP1>, + <&tegra_car TEGRA124_CLK_PLL_D_OUT0>; + + rgb { + status = "okay"; + + nvidia,panel = <&dsia>; + }; + }; + + dsia: dsi@54300000 { + status = "okay"; + + avdd-dsi-csi-supply = <&avdd_dsi_csi>; + nvidia,ganged-mode = <&dsib>; + + panel@0 { + compatible = "sharp,lq079l1sx01"; + reg = <0>; + + link2 = <&panel_secondary>; + + avdd-supply = <&avdd_lcd>; + vddio-supply = <&vdd_lcd_io>; + + vsp-supply = <&vsp_5v5_lcd>; + vsn-supply = <&vsn_5v5_lcd>; + + reset-gpios = <&gpio TEGRA_GPIO(H, 3) GPIO_ACTIVE_LOW>; + + backlight = <&lp8556>; + }; + }; + + dsib: dsi@54400000 { + status = "okay"; + + avdd-dsi-csi-supply = <&avdd_dsi_csi>; + + panel_secondary: panel@0 { + compatible = "sharp,lq079l1sx01"; + reg = <0>; + }; + }; + }; + + pinmux@70000868 { + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pinmux { + /* Keys pinmux */ + keys { + nvidia,pins = "kb_col0_pq0", + "kb_col6_pq6", + "kb_col7_pq7"; + nvidia,function = "rsvd2"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + hall-front { + nvidia,pins = "pi5"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + hall-back { + nvidia,pins = "gpio_w3_aud_pw3"; + nvidia,function = "spi1"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* Leds pinmux */ + bl-en { + nvidia,pins = "pbb4"; + nvidia,function = "vgp4"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + keys-led { + nvidia,pins = "ph1"; + nvidia,function = "pwm1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* Panel pinmux */ + lcd-rst { + nvidia,pins = "ph3"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + lcd-vsp { + nvidia,pins = "pi4"; + nvidia,function = "gmi"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + lcd-vsn { + nvidia,pins = "kb_row10_ps2"; + nvidia,function = "kbc"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + lcd-id { + nvidia,pins = "kb_row6_pr6"; + nvidia,function = "displaya_alt"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + lcd-pwm { + nvidia,pins = "ph2"; + nvidia,function = "pwm2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* SDMMC3 pinmux */ + sdmmc3-clk { + nvidia,pins = "sdmmc3_clk_pa6"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3-cmd { + nvidia,pins = "sdmmc3_cmd_pa7", + "sdmmc3_dat0_pb7", + "sdmmc3_dat1_pb6", + "sdmmc3_dat2_pb5", + "sdmmc3_dat3_pb4", + "sdmmc3_clk_lb_out_pee4", + "sdmmc3_clk_lb_in_pee5"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc3-cd { + nvidia,pins = "sdmmc3_cd_n_pv2"; + nvidia,function = "sdmmc3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + usd-pwr { + nvidia,pins = "kb_row0_pr0"; + nvidia,function = "rsvd4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_DISABLE>; + }; + + /* SDMMC4 pinmux */ + sdmmc4-clk { + nvidia,pins = "sdmmc4_clk_pcc4"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + sdmmc4-cmd { + nvidia,pins = "sdmmc4_cmd_pt7", + "sdmmc4_dat0_paa0", + "sdmmc4_dat1_paa1", + "sdmmc4_dat2_paa2", + "sdmmc4_dat3_paa3", + "sdmmc4_dat4_paa4", + "sdmmc4_dat5_paa5", + "sdmmc4_dat6_paa6", + "sdmmc4_dat7_paa7"; + nvidia,function = "sdmmc4"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + + /* I2C pinmux */ + gen1-i2c { + nvidia,pins = "gen1_i2c_sda_pc5", + "gen1_i2c_scl_pc4"; + nvidia,function = "i2c1"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,lock = <1>; + nvidia,open-drain = <1>; + }; + gen2-i2c { + nvidia,pins = "gen2_i2c_scl_pt5", + "gen2_i2c_sda_pt6"; + nvidia,function = "i2c2"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,lock = <1>; + nvidia,open-drain = <1>; + }; + cam-i2c { + nvidia,pins = "cam_i2c_scl_pbb1", + "cam_i2c_sda_pbb2"; + nvidia,function = "i2c3"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,lock = <1>; + nvidia,open-drain = <1>; + }; + ddc-i2c { + nvidia,pins = "ddc_scl_pv4", + "ddc_sda_pv5"; + nvidia,function = "i2c4"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + }; + pwr-i2c { + nvidia,pins = "pwr_i2c_scl_pz6", + "pwr_i2c_sda_pz7"; + nvidia,function = "i2cpwr"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + nvidia,enable-input = <TEGRA_PIN_ENABLE>; + nvidia,open-drain = <1>; + }; + + dsi-b { + nvidia,pins = "mipi_pad_ctrl_dsi_b"; + nvidia,function = "dsi_b"; + }; + + /* GPIO power/drive control */ + drive-sdio1 { + nvidia,pins = "drive_sdio1"; + nvidia,high-speed-mode = <TEGRA_PIN_ENABLE>; + nvidia,schmitt = <TEGRA_PIN_DISABLE>; + nvidia,low-power-mode = <TEGRA_PIN_LP_DRIVE_DIV_1>; + nvidia,pull-down-strength = <32>; + nvidia,pull-up-strength = <42>; + nvidia,slew-rate-rising = <TEGRA_PIN_SLEW_RATE_FASTEST>; + nvidia,slew-rate-falling = <TEGRA_PIN_SLEW_RATE_FASTEST>; + }; + + drive-sdio3 { + nvidia,pins = "drive_sdio3"; + nvidia,high-speed-mode = <TEGRA_PIN_ENABLE>; + nvidia,schmitt = <TEGRA_PIN_DISABLE>; + nvidia,low-power-mode = <TEGRA_PIN_LP_DRIVE_DIV_1>; + nvidia,pull-down-strength = <20>; + nvidia,pull-up-strength = <36>; + nvidia,slew-rate-rising = <TEGRA_PIN_SLEW_RATE_FASTEST>; + nvidia,slew-rate-falling = <TEGRA_PIN_SLEW_RATE_FASTEST>; + }; + + drive-gma { + nvidia,pins = "drive_gma"; + nvidia,high-speed-mode = <TEGRA_PIN_ENABLE>; + nvidia,schmitt = <TEGRA_PIN_DISABLE>; + nvidia,low-power-mode = <TEGRA_PIN_LP_DRIVE_DIV_1>; + nvidia,pull-down-strength = <1>; + nvidia,pull-up-strength = <2>; + nvidia,slew-rate-rising = <TEGRA_PIN_SLEW_RATE_FASTEST>; + nvidia,slew-rate-falling = <TEGRA_PIN_SLEW_RATE_FASTEST>; + }; + }; + }; + + uartd: serial@70006300 { + status = "okay"; + }; + + gen1_i2c: i2c@7000c000 { + status = "okay"; + clock-frequency = <400000>; + + lp8556: backlight@2c { + compatible = "ti,lp8556"; + reg = <0x2c>; + + dev-ctrl = /bits/ 8 <0x83>; + init-brt = /bits/ 8 <0x1f>; + + power-supply = <&vdd_3v3_sys>; + enable-supply = <&vddio_1v8_bl>; + + rom-98h { + rom-addr = /bits/ 8 <0x98>; + rom-val = /bits/ 8 <0x80>; + }; + + rom-9eh { + rom-addr = /bits/ 8 <0x9e>; + rom-val = /bits/ 8 <0x21>; + }; + + rom-a0h { + rom-addr = /bits/ 8 <0xa0>; + rom-val = /bits/ 8 <0xff>; + }; + + rom-a1h { + rom-addr = /bits/ 8 <0xa1>; + rom-val = /bits/ 8 <0x3f>; + }; + + rom-a2h { + rom-addr = /bits/ 8 <0xa2>; + rom-val = /bits/ 8 <0x20>; + }; + + rom-a3h { + rom-addr = /bits/ 8 <0xa3>; + rom-val = /bits/ 8 <0x00>; + }; + + rom-a4h { + rom-addr = /bits/ 8 <0xa4>; + rom-val = /bits/ 8 <0x72>; + }; + + rom-a5h { + rom-addr = /bits/ 8 <0xa5>; + rom-val = /bits/ 8 <0x24>; + }; + + rom-a6h { + rom-addr = /bits/ 8 <0xa6>; + rom-val = /bits/ 8 <0x80>; + }; + + rom-a7h { + rom-addr = /bits/ 8 <0xa7>; + rom-val = /bits/ 8 <0xf5>; + }; + + rom-a8h { + rom-addr = /bits/ 8 <0xa8>; + rom-val = /bits/ 8 <0x24>; + }; + + rom-a9h { + rom-addr = /bits/ 8 <0xa9>; + rom-val = /bits/ 8 <0xb2>; + }; + + rom-aah { + rom-addr = /bits/ 8 <0xaa>; + rom-val = /bits/ 8 <0x8f>; + }; + + rom-aeh { + rom-addr = /bits/ 8 <0xae>; + rom-val = /bits/ 8 <0x0f>; + }; + }; + }; + + pwr_i2c: i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + /* Texas Instruments TPS65913 PMIC */ + pmic: tps65913@58 { + compatible = "ti,tps65913"; + reg = <0x58>; + + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <2>; + interrupt-controller; + + ti,system-power-controller; + + palmas_gpio: gpio { + compatible = "ti,palmas-gpio"; + gpio-controller; + #gpio-cells = <2>; + }; + + pinmux { + compatible = "ti,tps65913-pinctrl"; + + pinctrl-names = "default"; + pinctrl-0 = <&palmas_default>; + + palmas_default: pinmux { + pin_gpio4 { + pins = "gpio4"; + function = "gpio"; + }; + }; + }; + + pmic { + compatible = "ti,tps65913-pmic"; + + regulators { + vdd_1v8_vio: smps8 { + regulator-name = "vdd_1v8_gen"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_hv_sdmmc: smps9 { + regulator-name = "vdd_hv_sdmmc"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + avdd_lcd: ldo2 { + regulator-name = "avdd_lcd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + }; + + avdd_dsi_csi: ldo5 { + regulator-name = "avdd_dsi_csi"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + }; + + vddio_usd: ldo9 { + regulator-name = "vddio_sdmmc"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + avdd_usb: ldousb { + regulator-name = "vdd_usb"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + }; + }; + }; + }; + + sdmmc3: sdhci@700b0400 { + status = "okay"; + bus-width = <4>; + + cd-gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_HIGH>; + power-gpios = <&gpio TEGRA_GPIO(R, 0) GPIO_ACTIVE_HIGH>; + + vmmc-supply = <&vdd_hv_sdmmc>; + vqmmc-supply = <&vddio_usd>; + }; + + sdmmc4: sdhci@700b0600 { + status = "okay"; + bus-width = <8>; + non-removable; + + vmmc-supply = <&vdd_hv_sdmmc>; + vqmmc-supply = <&vdd_1v8_vio>; + }; + + usb1: usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + }; + + clk32k_in: clock-32k { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "ref-oscillator"; + }; + + extcon-keys { + compatible = "gpio-keys"; + + switch-back-hall-sensor { + label = "Hall sensor (back)"; + gpios = <&gpio TEGRA_GPIO(W, 3) GPIO_ACTIVE_LOW>; + linux,code = <SW_LID>; + }; + + switch-front-hall-sensor { + label = "Hall sensor (front)"; + gpios = <&gpio TEGRA_GPIO(I, 5) GPIO_ACTIVE_LOW>; + linux,code = <SW_LID>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + + key-power { + label = "Power"; + gpios = <&gpio TEGRA_GPIO(Q, 0) GPIO_ACTIVE_LOW>; + linux,code = <KEY_ENTER>; + }; + + key-volume-down { + label = "Volume Down"; + gpios = <&gpio TEGRA_GPIO(Q, 7) GPIO_ACTIVE_LOW>; + linux,code = <KEY_DOWN>; + }; + + key-volume-up { + label = "Volume Up"; + gpios = <&gpio TEGRA_GPIO(Q, 6) GPIO_ACTIVE_LOW>; + linux,code = <KEY_UP>; + }; + }; + + vdd_3v3_sys: regulator-bl-en { + compatible = "regulator-fixed"; + regulator-name = "vdd_5v0_bl"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + enable-active-high; + }; + + vddio_1v8_bl: regulator-bl-io { + compatible = "regulator-fixed"; + regulator-name = "vddio_1v8_bl"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + enable-active-high; + gpio = <&gpio TEGRA_GPIO(BB, 4) GPIO_ACTIVE_HIGH>; + }; + + vdd_lcd_io: regulator-lcdvio { + compatible = "regulator-fixed"; + regulator-name = "dvdd_lcd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + enable-active-high; + gpio = <&palmas_gpio 4 GPIO_ACTIVE_HIGH>; + }; + + vsp_5v5_lcd: regulator-vsp { + compatible = "regulator-fixed"; + regulator-name = "avdd_lcd_vsp"; + regulator-min-microvolt = <5500000>; + regulator-max-microvolt = <5500000>; + enable-active-high; + gpio = <&gpio TEGRA_GPIO(I, 4) GPIO_ACTIVE_HIGH>; + }; + + vsn_5v5_lcd: regulator-vsn { + compatible = "regulator-fixed"; + regulator-name = "avdd_lcd_vsn"; + regulator-min-microvolt = <5500000>; + regulator-max-microvolt = <5500000>; + enable-active-high; + gpio = <&gpio TEGRA_GPIO(S, 2) GPIO_ACTIVE_HIGH>; + }; +}; diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index 84c8f86bad0..a62b055f7e6 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -30,6 +30,10 @@ config TARGET_CEI_TK1_SOM the SoC are assigned to which functions, and the PCIEe configuration.
+config TARGET_MOCHA + bool "Xiaomi Tegra124 Mi Pad board" + select BOARD_LATE_INIT + config TARGET_NYAN_BIG bool "Google/NVIDIA Nyan-big Chromebook" select BOARD_LATE_INIT @@ -54,5 +58,6 @@ source "board/nvidia/jetson-tk1/Kconfig" source "board/nvidia/nyan-big/Kconfig" source "board/nvidia/venice2/Kconfig" source "board/toradex/apalis-tk1/Kconfig" +source "board/xiaomi/mocha/Kconfig"
endif diff --git a/board/xiaomi/mocha/Kconfig b/board/xiaomi/mocha/Kconfig new file mode 100644 index 00000000000..25c61d4169e --- /dev/null +++ b/board/xiaomi/mocha/Kconfig @@ -0,0 +1,12 @@ +if TARGET_MOCHA + +config SYS_BOARD + default "mocha" + +config SYS_VENDOR + default "xiaomi" + +config SYS_CONFIG_NAME + default "mocha" + +endif diff --git a/board/xiaomi/mocha/MAINTAINERS b/board/xiaomi/mocha/MAINTAINERS new file mode 100644 index 00000000000..c3871a15a35 --- /dev/null +++ b/board/xiaomi/mocha/MAINTAINERS @@ -0,0 +1,8 @@ +MOCHA BOARD +M: Svyatoslav Ryhel clamor95@gmail.com +S: Maintained +F: arch/arm/dts/tegra124-xiaomi-mocha.dts +F: board/xiaomi/mocha/ +F: configs/mocha_defconfig +F: doc/board/xiaomi/mocha.rst +F: include/configs/mocha.h diff --git a/board/xiaomi/mocha/Makefile b/board/xiaomi/mocha/Makefile new file mode 100644 index 00000000000..c42e42639b3 --- /dev/null +++ b/board/xiaomi/mocha/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Copyright (c) 2024, Svyatoslav Ryhel clamor95@gmail.com +# + +obj-$(CONFIG_XPL_BUILD) += mocha-spl.o + +obj-y += mocha.o + diff --git a/board/xiaomi/mocha/mocha-spl.c b/board/xiaomi/mocha/mocha-spl.c new file mode 100644 index 00000000000..5fb11df0a93 --- /dev/null +++ b/board/xiaomi/mocha/mocha-spl.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Mocha SPL stage configuration + * + * (C) Copyright 2024 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <asm/arch/tegra.h> +#include <asm/arch-tegra/tegra_i2c.h> +#include <linux/delay.h> + +#define TPS65913_I2C_ADDR (0x58 << 1) + +#define TPS65913_SMPS12_CTRL 0x20 +#define TPS65913_SMPS12_VOLTAGE 0x23 +#define TPS65913_SMPS45_CTRL 0x28 +#define TPS65913_SMPS45_VOLTAGE 0x2B +#define TPS65913_SMPS7_CTRL 0x30 +#define TPS65913_SMPS7_VOLTAGE 0x33 + +#define TPS65913_SMPS12_CTRL_DATA (0x5100 | TPS65913_SMPS12_CTRL) +#define TPS65913_SMPS12_VOLTAGE_DATA (0x3800 | TPS65913_SMPS12_VOLTAGE) +#define TPS65913_SMPS45_CTRL_DATA (0x5100 | TPS65913_SMPS45_CTRL) +#define TPS65913_SMPS45_VOLTAGE_DATA (0x3800 | TPS65913_SMPS45_VOLTAGE) +#define TPS65913_SMPS7_CTRL_DATA (0x5100 | TPS65913_SMPS7_CTRL) +#define TPS65913_SMPS7_VOLTAGE_DATA (0x4700 | TPS65913_SMPS7_VOLTAGE) + +void pmic_enable_cpu_vdd(void) +{ + /* Set CORE VDD to 1.150V. */ + tegra_i2c_ll_write(TPS65913_I2C_ADDR, TPS65913_SMPS7_VOLTAGE_DATA); + udelay(1000); + tegra_i2c_ll_write(TPS65913_I2C_ADDR, TPS65913_SMPS7_CTRL_DATA); + + udelay(1000); + + /* Set CPU VDD to 1.0V. */ + tegra_i2c_ll_write(TPS65913_I2C_ADDR, TPS65913_SMPS12_VOLTAGE_DATA); + udelay(1000); + tegra_i2c_ll_write(TPS65913_I2C_ADDR, TPS65913_SMPS12_CTRL_DATA); + udelay(10 * 1000); + + /* Set GPU VDD to 1.0V. */ + tegra_i2c_ll_write(TPS65913_I2C_ADDR, TPS65913_SMPS45_VOLTAGE_DATA); + udelay(1000); + tegra_i2c_ll_write(TPS65913_I2C_ADDR, TPS65913_SMPS45_CTRL_DATA); + udelay(10 * 1000); +} diff --git a/board/xiaomi/mocha/mocha.c b/board/xiaomi/mocha/mocha.c new file mode 100644 index 00000000000..5026d541a5f --- /dev/null +++ b/board/xiaomi/mocha/mocha.c @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2024 + * Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <dm.h> +#include <fdt_support.h> +#include <i2c.h> +#include <log.h> + +#ifdef CONFIG_MMC_SDHCI_TEGRA + +#define TPS65913_I2C_ADDRESS 0x58 +#define TPS65913_PRIMARY_SECONDARY_PAD2 0xfb +#define GPIO_4 BIT(0) +#define TPS65913_PRIMARY_SECONDARY_PAD3 0xfe +#define DVFS2 BIT(1) +#define DVFS1 BIT(0) + +/* We are using this function only till palmas pinctrl driver is available */ +void pin_mux_mmc(void) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, TPS65913_I2C_ADDRESS, 1, &dev); + if (ret) { + log_debug("%s: cannot find PMIC I2C chip\n", __func__); + return; + } + + /* GPIO4 function has to be GPIO */ + dm_i2c_reg_clrset(dev, TPS65913_PRIMARY_SECONDARY_PAD2, + GPIO_4, 0); + + /* DVFS1 and DVFS2 are disabled */ + dm_i2c_reg_clrset(dev, TPS65913_PRIMARY_SECONDARY_PAD3, + DVFS2 | DVFS1, 0); +} +#endif diff --git a/board/xiaomi/mocha/mocha.env b/board/xiaomi/mocha/mocha.env new file mode 100644 index 00000000000..d93e24316f6 --- /dev/null +++ b/board/xiaomi/mocha/mocha.env @@ -0,0 +1,23 @@ +#include <env/nvidia/prod_upd.env> + +button_cmd_0_name=Volume Down +button_cmd_0=bootmenu +button_cmd_1_name=Hall sensor (back) +button_cmd_1=poweroff +button_cmd_1_name=Hall sensor (front) +button_cmd_1=poweroff + +partitions=name=emmc,start=0,size=-,uuid=${uuid_gpt_rootfs} + +boot_block_size_r=0x400000 +boot_block_size=0x2000 +boot_dev=1 + +bootmenu_0=mount internal storage=usb start && ums 0 mmc 0; bootmenu +bootmenu_1=mount external storage=usb start && ums 0 mmc 1; bootmenu +bootmenu_2=fastboot=echo Starting Fastboot protocol ...; fastboot usb 0; bootmenu +bootmenu_3=update bootloader=run flash_uboot +bootmenu_4=reboot RCM=enterrcm +bootmenu_5=reboot=reset +bootmenu_6=power off=poweroff +bootmenu_delay=-1 diff --git a/configs/mocha_defconfig b/configs/mocha_defconfig new file mode 100644 index 00000000000..fc3af670bbf --- /dev/null +++ b/configs/mocha_defconfig @@ -0,0 +1,90 @@ +CONFIG_ARM=y +CONFIG_ARCH_TEGRA=y +CONFIG_SUPPORT_PASSING_ATAGS=y +CONFIG_CMDLINE_TAG=y +CONFIG_INITRD_TAG=y +CONFIG_TEXT_BASE=0x80110000 +CONFIG_SYS_MALLOC_LEN=0x2500000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SOURCE_FILE="mocha" +CONFIG_ENV_SIZE=0x3000 +CONFIG_ENV_OFFSET=0xFFFFD000 +CONFIG_DEFAULT_DEVICE_TREE="tegra124-xiaomi-mocha" +CONFIG_SPL_STACK=0x800ffffc +CONFIG_SPL_TEXT_BASE=0x80108000 +CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_TEGRA124=y +CONFIG_TARGET_MOCHA=y +CONFIG_TEGRA_ENABLE_UARTD=y +CONFIG_CMD_EBTUPDATE=y +CONFIG_TEGRA_GPU=y +CONFIG_BUTTON_CMD=y +CONFIG_BOOTDELAY=0 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="bootflow scan; poweroff" +CONFIG_SYS_PBSIZE=2086 +CONFIG_SPL_FOOTPRINT_LIMIT=y +CONFIG_SPL_MAX_FOOTPRINT=0x8000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80090000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x10000 +CONFIG_SYS_PROMPT="Tegra124 (Mocha) # " +# CONFIG_CMD_BOOTEFI_BOOTMGR is not set +CONFIG_CMD_BOOTMENU=y +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_UMS_ABORT_KEYED=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PAUSE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_BUTTON=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x91000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_PALMAS_GPIO=y +CONFIG_SYS_I2C_TEGRA=y +CONFIG_BUTTON_KEYBOARD=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_PALMAS=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_PALMAS=y +CONFIG_PWM_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_SYSRESET_PALMAS=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xiaomi" +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd00d +CONFIG_CI_UDC=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_FONT_8X16 is not set +CONFIG_VIDEO_FONT_16X32=y +# CONFIG_VIDEO_LOGO is not set +CONFIG_VIDEO_LCD_SHARP_LQ079L1SX01=y +CONFIG_BACKLIGHT_LP855x=y +CONFIG_VIDEO_DSI_TEGRA30=y diff --git a/doc/board/index.rst b/doc/board/index.rst index a1f2dd6cdb8..b68a309d3c7 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -67,4 +67,5 @@ Board-specific doc variscite/index wexler/index xen/index + xiaomi/index xilinx/index diff --git a/doc/board/xiaomi/index.rst b/doc/board/xiaomi/index.rst new file mode 100644 index 00000000000..109ab4a251f --- /dev/null +++ b/doc/board/xiaomi/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Xiaomi +====== + +.. toctree:: + :maxdepth: 2 + + mocha diff --git a/doc/board/xiaomi/mocha.rst b/doc/board/xiaomi/mocha.rst new file mode 100644 index 00000000000..be3e333127b --- /dev/null +++ b/doc/board/xiaomi/mocha.rst @@ -0,0 +1,112 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot for the Xiaomi Mi Pad tablet +=================================== + +``DISCLAMER!`` Moving your Xiaomi Mi Pad to use U-Boot assumes replacement +of the vendor bootloader. Vendor Android firmwares will no longer be able +to run on the device. This replacement IS reversible. + +Quick Start +----------- + +- Build U-Boot +- Boot U-Boot +- Process and flash U-Boot +- Boot Linux +- Self Upgrading +- Chainload configuration + +Build U-Boot +------------ + +.. code-block:: bash + + $ export CROSS_COMPILE=arm-none-eabi- + $ make mocha_defconfig + $ make + +After the build succeeds, you will obtain the final ``u-boot-dtb-tegra.bin`` +image, ready for booting or further processing. + +Boot U-Boot +----------- +Existing tegrarcm loader can be used to pre-load U-Boot you have build +into RAM and basically perform a tethered cold-boot. + +.. code-block:: bash + + $ tegrarcm --bct mocha.bct --bootloader u-boot-dtb-tegra.bin --loadaddr 0x80108000 + +U-Boot will try to load Linux kernel and if fails, it will turn the +tablet off. While pre-loading U-Boot, hold the ``volume down`` button +which will trigger the bootmenu. + +Process and flash U-Boot +------------------------ + +``DISCLAMER!`` All questions related to the re-crypt work should be asked +in re-crypt repo issues. NOT HERE! + +re-crypt is a tool that processes the ``u-boot-dtb-tegra.bin`` binary into +form usable by device. This process is required only on the first +installation or to recover the device in case of a failed update. + +.. code-block:: bash + + $ git clone https://gitlab.com/grate-driver/re-crypt.git + $ cd re-crypt # place your u-boot-dtb-tegra.bin here + $ ./re-crypt.py --dev mocha + +The script will produce ``bct.img`` and ``ebt.img`` ready to flash. + +Permanent installation can be performed by pre-loading just built U-Boot +into RAM via tegrarcm. While pre-loading U-Boot, hold the ``volume down`` +button which will trigger the bootmenu. There, select ``fastboot`` using +the volume and power buttons. + +After, on host PC, do: + +.. code-block:: bash + + $ fastboot flash 0.1 bct.img + $ fastboot flash 0.2 ebt.img + $ fastboot reboot + +Device will reboot. + +Boot Linux +---------- + +To boot Linux, U-Boot will look for an ``extlinux.conf`` on MicroSD and then on +eMMC. Additionally, if the ``volume down`` button is pressed while booting, the +device will enter bootmenu. Bootmenu contains entries to mount MicroSD and eMMC +as mass storage, fastboot, reboot, reboot RCM, poweroff, enter U-Boot console +and update bootloader (check the next chapter). + +Flashing ``bct.img`` and ``ebt.img`` eliminates vendor restrictions on eMMC and +allows the user to use/partition it in any way the user desires. + +Self Upgrading +-------------- + +Place your ``u-boot-dtb-tegra.bin`` on the first partition of the MicroSD card +and insert it into the tablet. Enter bootmenu, choose update the bootloader +option with the Power button and U-Boot should update itself. Once the process +is completed, U-Boot will ask to press any button to reboot. + +Chainload configuration +----------------------- + +To build U-Boot without SPL suitable for chainloading adjust mocha_defconfig: + +.. code-block:: + + CONFIG_TEXT_BASE=0x80A00000 + CONFIG_SKIP_LOWLEVEL_INIT=y + # CONFIG_OF_BOARD_SETUP is not set + CONFIG_TEGRA_SUPPORT_NON_SECURE=y + +After the build succeeds, you will obtain the final ``u-boot-dtb.bin`` +file, ready for booting using vendor bootloader's fastboot or which can be +further processed into a flashable image. diff --git a/include/configs/mocha.h b/include/configs/mocha.h new file mode 100644 index 00000000000..1c2eb906085 --- /dev/null +++ b/include/configs/mocha.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. + * + * Copyright (c) 2024, Svyatoslav Ryhel clamor95@gmail.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "tegra124-common.h" + +/* High-level configuration options */ +#define CFG_TEGRA_BOARD_STRING "Xiaomi Mocha" + +/* Board-specific serial config */ +#define CFG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE + +#ifdef CONFIG_TEGRA_SUPPORT_NON_SECURE + #define CFG_PRAM 0x38400 /* 225 MB */ +#endif + +#include "tegra-common-post.h" + +#endif /* __CONFIG_H */
Svyatoslav Ryhel
