[U-Boot] [PATCH v2 0/5] add pinctrl driver for rk3399
This patch set add the pinctrl driver for rk3399 and enable pinctrl for pwm module. Module with pinctrl driver support and with interrupt number and default pinctrl in dts node will get pinctrl initialized when driver probe. Module like pwm which without interrupt number need to call the pinctrl API manually.
Changes in v2: - move and reg value MACRO in C source, and use MASK/SHIFT
Kever Yang (5): rk3399: syscon: add support for pmugrf pinctrl: add driver for rk3399 config: evb-rk3399: enable pinctrl driver rk3399: enable the pwm2/3 pinctrl in board init dts: rk3399: add pinctrl for sdmmc
arch/arm/dts/rk3399.dtsi | 37 ++ arch/arm/include/asm/arch-rockchip/clock.h | 1 + arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 330 ++++++++++++++++++ arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 1 + board/rockchip/evb_rk3399/evb-rk3399.c | 31 +- configs/evb-rk3399_defconfig | 2 + drivers/pinctrl/Kconfig | 9 + drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rk3399.c | 441 ++++++++++++++++++++++++ 9 files changed, 852 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk3399.h create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk3399.c
Kever Yang
