[U-Boot-Users] [PATCH 0/6] updates for the TQM8xx board family
The following series implements some patches and updates for the TQM8xx board family. The patches should be independent from each other, but it is propably a good idea to apply them in the given order, to avoid merge conflicts.
CAS-Latency=2, Write Recovery Time tWR=2 The max. supported bus frequency is 66 MHz. Therefore, changed threshold to switch from 1:1 mode to 2:1 from 80 MHz to 66 MHz.
Signed-off-by: Jens Gehrlein jens.gehrlein@tqs.de ---
board/tqm8xx/tqm8xx.c | 11 ++++++----- cpu/mpc8xx/speed.c | 5 +---- include/configs/TQM885D.h | 2 +- 3 files changed, 8 insertions(+), 10 deletions(-)
diff --git a/board/tqm8xx/tqm8xx.c b/board/tqm8xx/tqm8xx.c index ed1d692..8ef812f 100644 --- a/board/tqm8xx/tqm8xx.c +++ b/board/tqm8xx/tqm8xx.c @@ -37,6 +37,7 @@ static long int dram_size (long int, long int *, long int);
#define _NOT_USED_ 0xFFFFFFFF
+/* UPM initialization table for SDRAM: 40, 50, 66 MHz CLKOUT @ CAS latency 2, tWR=2 */ const uint sdram_table[] = { /* @@ -63,14 +64,14 @@ const uint sdram_table[] = /* * Single Write. (Offset 18 in UPMA RAM) */ - 0x1F0DFC04, 0xEEABBC00, 0x01B27C04, 0x1FF5FC47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, + 0x1F0DFC04, 0xEEABBC00, 0x11B77C04, 0xEFFAFC44, + 0x1FF5FC47, /* last */ + _NOT_USED_, _NOT_USED_, _NOT_USED_, /* * Burst Write. (Offset 20 in UPMA RAM) */ 0x1F0DFC04, 0xEEABBC00, 0x10A77C00, 0xF0AFFC00, - 0xF0AFFC00, 0xE1BAFC04, 0x1FF5FC47, /* last */ - _NOT_USED_, + 0xF0AFFC00, 0xF0AFFC04, 0xE1BAFC44, 0x1FF5FC47, /* last */ _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, /* @@ -83,7 +84,7 @@ const uint sdram_table[] = /* * Exception. (Offset 3c in UPMA RAM) */ - 0x7FFFFC07, /* last */ + 0xFFFFFC07, /* last */ _NOT_USED_, _NOT_USED_, _NOT_USED_, };
diff --git a/cpu/mpc8xx/speed.c b/cpu/mpc8xx/speed.c index 4173092..f23040f 100644 --- a/cpu/mpc8xx/speed.c +++ b/cpu/mpc8xx/speed.c @@ -271,11 +271,8 @@ int get_clocks_866 (void) */ sccr_reg = immr->im_clkrst.car_sccr; sccr_reg &= ~SCCR_EBDF11; -#if defined(CONFIG_TQM885D) - if (gd->cpu_clk <= 80000000) { -#else + if (gd->cpu_clk <= 66000000) { -#endif sccr_reg |= SCCR_EBDF00; /* bus division factor = 1 */ gd->bus_clk = gd->cpu_clk; } else { diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index 9ef0abe..c406df6 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -42,7 +42,7 @@ #define CONFIG_8xx_OSCLK 10000000 /* 10 MHz - PLL input clock */ #define CFG_8xx_CPUCLK_MIN 15000000 /* 15 MHz - CPU minimum clock */ #define CFG_8xx_CPUCLK_MAX 133000000 /* 133 MHz - CPU maximum clock */ -#define CONFIG_8xx_CPUCLK_DEFAULT 66000000 /* 50 MHz - CPU default clock */ +#define CONFIG_8xx_CPUCLK_DEFAULT 66000000 /* 66 MHz - CPU default clock */ /* (it will be used if there is no */ /* 'cpuclk' variable with valid value) */
- 0x1F0DFC04, 0xEEABBC00, 0x11B77C04, 0xEFFAFC44,
- 0x1FF5FC47, /* last */
Please indent to keep consistent with rest of file.
-#else
- if (gd->cpu_clk <= 66000000) {
-#endif
Thanks!
board/tqm8xx/tqm8xx.c | 16 +++++++++------- 1 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/board/tqm8xx/tqm8xx.c b/board/tqm8xx/tqm8xx.c index 8ef812f..ae3b760 100644 --- a/board/tqm8xx/tqm8xx.c +++ b/board/tqm8xx/tqm8xx.c @@ -355,6 +355,8 @@ long int initdram (int board_type) udelay (10000);
#ifdef CONFIG_CAN_DRIVER + /* UPM initialization for CAN @ CLKOUT <= 66 MHz */ + /* Initialize OR3 / BR3 */ memctl->memc_or3 = CFG_OR3_CAN; memctl->memc_br3 = CFG_BR3_CAN; @@ -363,7 +365,7 @@ long int initdram (int board_type) memctl->memc_mbmr = MBMR_GPL_B4DIS; /* GPL_B4 ouput line Disable */
/* Initialize UPMB for CAN: single read */ - memctl->memc_mdr = 0xFFFFC004; + memctl->memc_mdr = 0xFFFFCC04; memctl->memc_mcr = 0x0100 | UPMB;
memctl->memc_mdr = 0x0FFFD004; @@ -375,23 +377,23 @@ long int initdram (int board_type) memctl->memc_mdr = 0x3FFFC004; memctl->memc_mcr = 0x0103 | UPMB;
- memctl->memc_mdr = 0xFFFFDC05; + memctl->memc_mdr = 0xFFFFDC07; memctl->memc_mcr = 0x0104 | UPMB;
/* Initialize UPMB for CAN: single write */ - memctl->memc_mdr = 0xFFFCC004; + memctl->memc_mdr = 0xFFFCCC04; memctl->memc_mcr = 0x0118 | UPMB;
- memctl->memc_mdr = 0xCFFCD004; + memctl->memc_mdr = 0xCFFCDC04; memctl->memc_mcr = 0x0119 | UPMB;
- memctl->memc_mdr = 0x0FFCC000; + memctl->memc_mdr = 0x3FFCC000; memctl->memc_mcr = 0x011A | UPMB;
- memctl->memc_mdr = 0x7FFCC004; + memctl->memc_mdr = 0xFFFCC004; memctl->memc_mcr = 0x011B | UPMB;
- memctl->memc_mdr = 0xFFFDCC05; + memctl->memc_mdr = 0xFFFDC405; memctl->memc_mcr = 0x011C | UPMB; #endif /* CONFIG_CAN_DRIVER */
NAK by Wolfgang Denk.
- /* UPM initialization for CAN @ CLKOUT <= 66 MHz */
Indentation by TABs, please.
Signed-off-by: Martin Krause martin.krause@tqs.de ---
board/tqm8xx/Makefile | 2 +- include/configs/FPS850L.h | 17 ++++++++++------- include/configs/FPS860L.h | 16 ++++++++++------ include/configs/HMI10.h | 16 ++++++++++------ include/configs/NSCU.h | 18 +++++++++++------- include/configs/SM850.h | 16 ++++++++++------ include/configs/TQM823L.h | 16 ++++++++++------ include/configs/TQM823M.h | 18 +++++++++++------- include/configs/TQM850L.h | 16 ++++++++++------ include/configs/TQM850M.h | 18 +++++++++++------- include/configs/TQM855L.h | 16 ++++++++++------ include/configs/TQM855M.h | 18 +++++++++++------- include/configs/TQM860L.h | 16 ++++++++++------ include/configs/TQM860M.h | 23 +++++++++++++---------- include/configs/TQM862L.h | 17 ++++++++++------- include/configs/TQM862M.h | 19 +++++++++++-------- include/configs/TQM866M.h | 19 +++++++++++-------- include/configs/TQM885D.h | 12 ++++++++---- include/configs/virtlab2.h | 16 ++++++++++------ 19 files changed, 188 insertions(+), 121 deletions(-)
diff --git a/board/tqm8xx/Makefile b/board/tqm8xx/Makefile index b48934b..280982d 100644 --- a/board/tqm8xx/Makefile +++ b/board/tqm8xx/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS = $(BOARD).o flash.o load_sernum_ethaddr.o +COBJS = $(BOARD).o load_sernum_ethaddr.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/include/configs/FPS850L.h b/include/configs/FPS850L.h old mode 100644 new mode 100755 index 0dd21bc..2d8b50b --- a/include/configs/FPS850L.h +++ b/include/configs/FPS850L.h @@ -135,15 +135,18 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
+/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 +#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ #define CFG_ENV_IS_IN_FLASH 1 -#define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CFG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ +#define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ +#define CFG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SIZE) diff --git a/include/configs/FPS860L.h b/include/configs/FPS860L.h old mode 100644 new mode 100755 index 423d74e..715e2d8 --- a/include/configs/FPS860L.h +++ b/include/configs/FPS860L.h @@ -135,15 +135,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 67 /* max number of sectors on one chip */
-#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 +#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 67 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SIZE) diff --git a/include/configs/HMI10.h b/include/configs/HMI10.h old mode 100644 new mode 100755 index 7cce876..1c4a278 --- a/include/configs/HMI10.h +++ b/include/configs/HMI10.h @@ -222,15 +222,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
-#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 +#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SIZE) diff --git a/include/configs/NSCU.h b/include/configs/NSCU.h old mode 100644 new mode 100755 index d994420..cce7194 --- a/include/configs/NSCU.h +++ b/include/configs/NSCU.h @@ -175,16 +175,20 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
-#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 -#define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ -#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ -#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */ +#define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ +#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment */ +#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SECT_SIZE) diff --git a/include/configs/SM850.h b/include/configs/SM850.h old mode 100644 new mode 100755 index 4977629..2446b46 --- a/include/configs/SM850.h +++ b/include/configs/SM850.h @@ -146,15 +146,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 67 /* max number of sectors on one chip */
/*----------------------------------------------------------------------- * Hardware Information Block diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 247f705..84e05e6 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -187,15 +187,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 -#define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CFG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ +#define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ +#define CFG_ENV_SIZE 0x4000 /* Total Size of Environment */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SIZE) diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 1461b5f..d307038 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -176,16 +176,20 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SECT_SIZE) diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 90ecbad..e112e4d 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -168,15 +168,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SIZE) diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index b3f8f8d..b2b8069 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -166,16 +166,20 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SECT_SIZE) diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h old mode 100644 new mode 100755 index 49aaeea..2775d36 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -171,15 +171,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SIZE) diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index 50df49e..17ed77b 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -205,16 +205,20 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SECT_SIZE) diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index 9be5db1..bd2be66 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -174,15 +174,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SIZE) diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 37f6c98..df622d4 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -172,16 +172,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CFG_ENV_IS_IN_FLASH 1 -#define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ -#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ -#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */ +/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ + +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ +#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ +#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SECT_SIZE) diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index f03690a..fb8358b 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -174,16 +174,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 - -#define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CFG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ +#define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ +#define CFG_ENV_SIZE 0x4000 /* Total Size of Environment */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SIZE) diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index 4959340..46ef5d6 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -174,17 +174,20 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 - -#define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ -#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ -#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */ +#define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ +#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ +#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SECT_SIZE) diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 148490b..30489a4 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -215,16 +215,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ #define CFG_ENV_OFFSET_REDUND (CFG_ENV_OFFSET+CFG_ENV_SECT_SIZE) diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index c406df6..2b60eaa 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -237,11 +237,15 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ diff --git a/include/configs/virtlab2.h b/include/configs/virtlab2.h old mode 100644 new mode 100755 index 06d8536..b26286c --- a/include/configs/virtlab2.h +++ b/include/configs/virtlab2.h @@ -189,15 +189,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
Please feel free to implement such a change on boards for which TQ is repsonsible, or which you can test. But it is definitely NOT a good idea to modify boards which are NOT under your control, especially without even trying to talk with the board maintainers.
wd@denx.de wrote on Monday, July 30, 2007 5:49 PM:
Ups, sorry for that! We had a discussion about the TQM885D a year ago (wow, time is running ...), there you suggested to switch all TQM8xx boards to CFI driver. Now preparing the TQM885D patches, I thought this is a nice opportunity to do that. Shortly bevor submitting the patch I recognized, that other boards than the TQM8xx also use the code in /boards/tqm8xx. So I changed their configuration too, without thinking about it ...
Now I thought a bit about it. But didn't find a solution to only switch the TQM8xx boards to CFI and not the other boards using the code in /boards/tqm8xx.
The problem is, that all of the above boards use the same Makefile /boards/tqm8xx/Makefile. There the board specific flash driver is listed for compilation:
... include $(TOPDIR)/config.mk
COBJS = $(BOARD).o flash.o load_sernum_ethaddr.o ^^^^^^^ SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS))
$(LIB): $(obj).depend $(OBJS) $(AR) $(ARFLAGS) $@ $(OBJS) ...
If I don't want this driver compiled for the TQM8xx boards (because I want to use the CFI driver), I had to remove it from the COBJS list. But then it is removed on all other boards using this Makefile, too.
Is there a way to distinguish in the Makefile, for wich board the code ist compiled? Can the CONFIG_xxx definitions be used in the Makefile? IMHO not. Any ideas?
Best Regards,
Martin Krause
-- TQ-Systems GmbH Muehlstrasse 2, Gut Delling, D-82229 Seefeld Amtsgericht Muenchen, HRB 105 018, UST-IdNr. DE 811 607 913 Geschaeftsfuehrer: Dipl.-Ing. (FH) Detlef Schneider, Dipl.-Ing. (FH) Ruediger Stahl http://www.tq-group.com
In message 47F3F98010FF784EBEE6526EAAB078D1024F8673@tq-mailsrv.tq-net.de you wrote:
Agreed.
Then at least you have to discuss this with the respective board maintainers.
Maybe we can make this board dependent, if necessary...
... or make it conditional.
Hm.... don't know of an elegant way at first thinking....
Adjust flash map to support the new S29GLxxN (N-Type) Flashes with doubled sector size.
include/configs/TQM866M.h | 13 +++++++++---- 1 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 30489a4..eba4f33 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -81,8 +81,13 @@ "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ "rootpath=/opt/eldk/ppc_8xx\0" \ "bootfile=/tftpboot/TQM866M/uImage\0" \ - "kernel_addr=40080000\0" \ - "ramdisk_addr=40180000\0" \ + "kernel_addr=400C0000\0" \ + "ramdisk_addr=401C0000\0" \ + "load=tftp 200000 ${u-boot}\0" \ + "update=protect off 40000000 4003FFFF;" \ + "erase 40000000 4003FFFF;" \ + "cp.b 200000 40000000 ${filesize};" \ + "protect on 40000000 4003FFFF\0" \ "" #define CONFIG_BOOTCOMMAND "run flash_self"
@@ -203,7 +208,7 @@ #define CFG_FLASH_BASE 0x40000000 #define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ #define CFG_MONITOR_BASE CFG_FLASH_BASE -#define CFG_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ +#define CFG_MALLOC_LEN (256 << 10) /* Reserve 256 kB for malloc() */
/* * For booting Linux, the board info and command line data @@ -227,7 +232,7 @@ #define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ #define CFG_ENV_SIZE 0x08000 /* Total Size of Environment */ -#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */ +#define CFG_ENV_SECT_SIZE 0x40000 /* Total Size of Environment Sector */
include/configs/TQM860M.h | 13 +++++++++---- 1 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index df622d4..7530f62 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -69,8 +69,13 @@ "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ "rootpath=/opt/eldk/ppc_8xx\0" \ "bootfile=/tftpboot/TQM860M/uImage\0" \ - "kernel_addr=40080000\0" \ - "ramdisk_addr=40180000\0" \ + "kernel_addr=400C0000\0" \ + "ramdisk_addr=401C0000\0" \ + "load=tftp 200000 ${u-boot}\0" \ + "update=protect off 40000000 4003FFFF;" \ + "erase 40000000 4003FFFF;" \ + "cp.b 200000 40000000 ${filesize};" \ + "protect on 40000000 4003FFFF\0" \ "" #define CONFIG_BOOTCOMMAND "run flash_self"
@@ -160,7 +165,7 @@ #define CFG_FLASH_BASE 0x40000000 #define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ #define CFG_MONITOR_BASE CFG_FLASH_BASE -#define CFG_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ +#define CFG_MALLOC_LEN (256 << 10) /* Reserve 256 kB for malloc() */
/* * For booting Linux, the board info and command line data @@ -184,7 +189,7 @@ #define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ #define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ -#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */ +#define CFG_ENV_SECT_SIZE 0x40000 /* Total Size of Environment Sector */
- "kernel_addr=400C0000\0" \
- "ramdisk_addr=401C0000\0" \
- "load=tftp 200000 ${u-boot}\0" \
- "update=protect off 40000000 4003FFFF;" \
See previous comments about using +${filesize} instead of hard coded end addesses.
include/configs/TQM860M.h | 7 +++++-- 1 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 7530f62..0888383 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -357,7 +357,7 @@ */ #define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ #define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ +#define SDRAM_MAX_SIZE 0x08000000 /* max 128 MB per bank */
/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ #define CFG_OR_TIMING_SDRAM 0x00000A00 @@ -433,7 +433,10 @@ #define CFG_MAMR_9COL ((CFG_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - +/* 10 column SDRAM */ +#define CFG_MAMR_10COL ((CFG_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ + MAMR_AMA_TYPE_2 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A9 | \ + MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X)
/* * Internal Definitions
the following patches are updates of patches for the TQM8xx board family, which received a NAK in the first try.
If the patches are ok this time, or I didn't get negative feedback, I will push it to the u-boot-tq-group.git custodian tree and send a please-pull request once the merge window is open again.
Best Regards, Martin Krause
Signed-off-by: Martin Krause martin.krause@tqs.de --- board/tqm8xx/tqm8xx.c | 16 +++++++++------- 1 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/board/tqm8xx/tqm8xx.c b/board/tqm8xx/tqm8xx.c index 7d1c63d..06bf5f8 100644 --- a/board/tqm8xx/tqm8xx.c +++ b/board/tqm8xx/tqm8xx.c @@ -355,6 +355,8 @@ long int initdram (int board_type) udelay (10000);
Signed-off-by: Martin Krause martin.krause@tqs.de --- include/configs/TQM860M.h | 13 +++++++++---- 1 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 684b86f..fe3a2f0 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -69,9 +69,14 @@ "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ "rootpath=/opt/eldk/ppc_8xx\0" \ "bootfile=/tftpboot/TQM860M/uImage\0" \ - "fdt_addr=40080000\0" \ - "kernel_addr=400A0000\0" \ + "fdt_addr=400C0000\0" \ + "kernel_addr=40100000\0" \ "ramdisk_addr=40280000\0" \ + "load=tftp 200000 ${u-boot}\0" \ + "update=protect off 40000000 +${filesize};" \ + "erase 40000000 +${filesize};" \ + "cp.b 200000 40000000 ${filesize};" \ + "protect on 40000000 +${filesize}\0" \ "" #define CONFIG_BOOTCOMMAND "run flash_self"
@@ -172,7 +177,7 @@ #define CFG_FLASH_BASE 0x40000000 #define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ #define CFG_MONITOR_BASE CFG_FLASH_BASE -#define CFG_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ +#define CFG_MALLOC_LEN (256 << 10) /* Reserve 256 kB for malloc() */
/* * For booting Linux, the board info and command line data @@ -193,7 +198,7 @@ #define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ #define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ -#define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */ +#define CFG_ENV_SECT_SIZE 0x40000 /* Total Size of Environment Sector */
Signed-off-by: Martin Krause martin.krause@tqs.de --- board/tqm8xx/flash.c | 4 ++++ include/configs/HMI10.h | 12 ++++++++---- include/configs/TQM823L.h | 12 ++++++++---- include/configs/TQM823M.h | 14 +++++++++----- include/configs/TQM850L.h | 12 ++++++++---- include/configs/TQM850M.h | 14 +++++++++----- include/configs/TQM855L.h | 12 ++++++++---- include/configs/TQM855M.h | 14 +++++++++----- include/configs/TQM860L.h | 12 ++++++++---- include/configs/TQM860M.h | 13 ++++++++----- include/configs/TQM862L.h | 13 ++++++++----- include/configs/TQM862M.h | 15 +++++++++------ include/configs/TQM866M.h | 13 ++++++++----- include/configs/TQM885D.h | 12 ++++++++---- include/configs/virtlab2.h | 12 ++++++++---- 15 files changed, 120 insertions(+), 64 deletions(-)
diff --git a/board/tqm8xx/flash.c b/board/tqm8xx/flash.c index db0a7e5..4342ebc 100644 --- a/board/tqm8xx/flash.c +++ b/board/tqm8xx/flash.c @@ -33,6 +33,8 @@
DECLARE_GLOBAL_DATA_PTR;
+#if !defined(CFG_FLASH_CFI_DRIVER) /* do not use if CFI driver is configured */ + #if defined(CONFIG_TQM8xxL) && !defined(CONFIG_TQM866M) \ && !defined(CONFIG_TQM885D) # ifndef CFG_OR_TIMING_FLASH_AT_50MHZ @@ -828,3 +830,5 @@ static int write_word (flash_info_t *info, ulong dest, ulong data)
/*----------------------------------------------------------------------- */ + +#endif /* !defined(CFG_FLASH_CFI_DRIVER) */ diff --git a/include/configs/HMI10.h b/include/configs/HMI10.h index 02ae5d0..f8b0262 100644 --- a/include/configs/HMI10.h +++ b/include/configs/HMI10.h @@ -224,11 +224,15 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 7a38010..be5b4d3 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -192,11 +192,15 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index e8b6a80..a0c01b6 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -188,15 +188,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ -#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ +#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment */ #define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index beeca63..f51b12e 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -179,11 +179,15 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index d5609c1..a725e71 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -177,15 +177,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index e35b5b2..16dc3eb 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -183,11 +183,15 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index cd5212e..c4b4599 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -217,15 +217,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
/* Address and size of Redundant Environment Sector */ diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index d5838db..ac22c1e 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -186,11 +186,15 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index fe3a2f0..6424b2d 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -189,11 +189,14 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index f09d3d1..2bf4a2a 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -186,14 +186,17 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 - #define CFG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ #define CFG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */
diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index 039aa3a..d42ffc9 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -186,16 +186,19 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 - #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ -#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment Sector */ +#define CFG_ENV_SIZE 0x08000 /* Total Size of Environment */ #define CFG_ENV_SECT_SIZE 0x20000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 0d77891..c5ce4d6 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -227,11 +227,14 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CFG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index 95ab1c9..4c97863 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -241,11 +241,15 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
#define CFG_ENV_IS_IN_FLASH 1 #define CFG_ENV_OFFSET 0x40000 /* Offset of Environment Sector */ diff --git a/include/configs/virtlab2.h b/include/configs/virtlab2.h index edae6f4..827a28f 100644 --- a/include/configs/virtlab2.h +++ b/include/configs/virtlab2.h @@ -193,11 +193,15 @@ /*----------------------------------------------------------------------- * FLASH organization */ -#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
Martin Krause
Martin Krause
