[U-Boot] [PATCH v2] Makefile: Do not create empty autoconf.mk on error
The build rules of - include/autoconf.mk.dep - include/autoconf.mk - include/spl-autoconf.mk - include/tpl-autoconf.mk were not nice.
They created empty files (which are never updated) if an error occurs during preprocessing.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Before this commit, Makefile created empty files such as - include/autoconf.mk - include/spl-autoconf.mk - include/tpl-autoconf.mk - include/autoconf.mk.dep on error.
For example, try "make" with wrong CROSS_COMPILE like follows:
$ make mrproper $ make omap4_panda_config Configuring for omap4_panda board... $ make CROSS_COMPILE=foobar- all ---<snip>--- /bin/bash: foobar-gcc: command not found make[1]: *** [lib/asm-offsets.s] Error 127
Of cource, make fails.
And just check include/autoconf.mk, include/spl-autoconf.mk, etc. They exist and are all empty.
And then, try "make" with correct CROSS_COMPILE:
$ make CROSS_COMPILE=arm-linux-gnueabi- all
make will proceed with empty include/autoconf.mk and fail again.
A build rule of include/autoconf.mk does not work as we expect:
$(obj)include/autoconf.mk: $(obj)include/config.h @$(XECHO) Generating $@ ; \ set -e ; \ : Extract the config macros ; \ $(CPP) $(CFLAGS) -DDO_DEPS_ONLY -dM include/common.h | \ sed -n -f tools/scripts/define2mk.sed > $@.tmp && \ mv $@.tmp $@
Above code does not detect the error of $(CPP). An error usually occurs during $(CPP), whereas sed always succeeds. ( "set -e" is also meaningless, here. ) A empty include/autoconf.mk is created on error. (And it is never updated because it is newer than include/config.h)
FYI: A series of commands connected with a "pipe" returns the exit status of the last command.
For example,
$ command1 | command2
returns exit status of "command2", not "command1".
Changes in v2: - delete *.tmp file on success
Makefile | 25 +++++++++++-------------- 1 file changed, 11 insertions(+), 14 deletions(-)
diff --git a/Makefile b/Makefile index a2fb037..4be871f 100644 --- a/Makefile +++ b/Makefile @@ -637,36 +637,33 @@ checkdtc: # to regenerate the autoconf.mk file. $(obj)include/autoconf.mk.dep: $(obj)include/config.h include/common.h @$(XECHO) Generating $@ ; \ - set -e ; \ : Generate the dependancies ; \ $(CC) -x c -DDO_DEPS_ONLY -M $(CFLAGS) $(CPPFLAGS) \ - -MQ $(obj)include/autoconf.mk include/common.h > $@ + -MQ $(obj)include/autoconf.mk include/common.h > $@ || \ + rm $@
$(obj)include/autoconf.mk: $(obj)include/config.h @$(XECHO) Generating $@ ; \ - set -e ; \ : Extract the config macros ; \ - $(CPP) $(CFLAGS) -DDO_DEPS_ONLY -dM include/common.h | \ - sed -n -f tools/scripts/define2mk.sed > $@.tmp && \ - mv $@.tmp $@ + $(CPP) $(CFLAGS) -DDO_DEPS_ONLY -dM include/common.h > $@.tmp && \ + sed -n -f tools/scripts/define2mk.sed $@.tmp > $@; \ + rm $@.tmp
# Auto-generate the spl-autoconf.mk file (which is included by all makefiles for SPL) $(obj)include/tpl-autoconf.mk: $(obj)include/config.h @$(XECHO) Generating $@ ; \ - set -e ; \ : Extract the config macros ; \ $(CPP) $(CFLAGS) -DCONFIG_TPL_BUILD -DCONFIG_SPL_BUILD\ - -DDO_DEPS_ONLY -dM include/common.h | \ - sed -n -f tools/scripts/define2mk.sed > $@.tmp && \ - mv $@.tmp $@ + -DDO_DEPS_ONLY -dM include/common.h > $@.tmp && \ + sed -n -f tools/scripts/define2mk.sed $@.tmp > $@; \ + rm $@.tmp
$(obj)include/spl-autoconf.mk: $(obj)include/config.h @$(XECHO) Generating $@ ; \ - set -e ; \ : Extract the config macros ; \ - $(CPP) $(CFLAGS) -DCONFIG_SPL_BUILD -DDO_DEPS_ONLY -dM include/common.h | \ - sed -n -f tools/scripts/define2mk.sed > $@.tmp && \ - mv $@.tmp $@ + $(CPP) $(CFLAGS) -DCONFIG_SPL_BUILD -DDO_DEPS_ONLY -dM include/common.h > $@.tmp && \ + sed -n -f tools/scripts/define2mk.sed $@.tmp > $@; \ + rm $@.tmp
$(obj)include/generated/generic-asm-offsets.h: $(obj)include/autoconf.mk.dep \ $(obj)include/spl-autoconf.mk \
On Mon, Dec 02, 2013 at 02:57:29PM +0900, Masahiro Yamada wrote:
The build rules of
were not nice.
Masahiro Yamada
