[U-Boot] [PATCH v2] imx: Use a convenient default value for SYS_MALLOC_F_LEN
Commit 3a7c45f6a772 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver") causes some i.MX boards that were converted to DM, such as warp7, to fail to boot.
As explained by Lukas Auer:
"With the patch, U-Boot probes the drivers for devices under simple-bus device tree nodes in the pre-relocation device model. The default value of CONFIG_SYS_MALLOC_F_LEN (0x400) leaves U-Boot with not enough memory to do this, causing it to hang."
Fix this problem by providing a convenient default value for CONFIG_SYS_MALLOC_F_LEN.
Reported-by: Pierre-Jean Texier pjtexier@koncepto.io Suggested-by: Lukas Auer lukas.auer@aisec.fraunhofer.de Signed-off-by: Fabio Estevam festevam@gmail.com --- Changes since v1: - Move the default setting to the main Kconfig and make it depend on i.MX
Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/Kconfig b/Kconfig index 7a5491bd67..fd4ff42c17 100644 --- a/Kconfig +++ b/Kconfig @@ -138,6 +138,8 @@ config SYS_MALLOC_F_LEN depends on SYS_MALLOC_F default 0x1000 if AM33XX default 0x2800 if SANDBOX + default 0x2000 if (ARCH_IMX8 || ARCH_IMX8M || ARCH_MX7 || \ + ARCH_MX7ULP || ARCH_MX6 || ARCH_MX5) default 0x400 help Before relocation, memory is very limited on many platforms. Still,
Hi Fabio,
Changes since v1:
on i.MX
- default 0x2000 if (ARCH_IMX8 || ARCH_IMX8M || ARCH_MX7 || \
default 0x400 help Before relocation, memory is very limited on many platforms. Still,ARCH_MX7ULP || ARCH_MX6 || ARCH_MX5)
Tested-by: Pierre-Jean Texier pjtexier@koncepto.io
Thanks
Pierre-Jean
Hi Fabio,
Tested-by Joris Offouga offougajoris@gmail.com
BR,
Joris
Le ven. 3 mai 2019 à 19:20, Pierre-Jean Texier pjtexier@koncepto.io a écrit :
Hi Fabio,
to
Changes since v1:
on i.MX
Still,
Thanks
Pierre-Jean
Hi Fabio
Tested-by Joris Offouga <offougajoris@gmail.com >
BR
Joris
Changes since v1:
on i.MX
Still,
2.17.1
Good work.
Tested: warp7_bl33, warp7
Tested-by: Bryan O'Donoghue bryan.odonoghue@linaro.org
Changes since v1:
on i.MX
Thank you for sending the patch!
Reviewed-by: Lukas Auer lukas.auer@aisec.fraunhofer.de
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: 2019年5月4日 1:05 To: sbabic@denx.de Cc: dl-uboot-imx uboot-imx@nxp.com; u-boot@lists.denx.de; pjtexier@koncepto.io; lukas.auer@aisec.fraunhofer.de; offougajoris@gmail.com; trini@konsulko.com; Fabio Estevam festevam@gmail.com Subject: [PATCH v2] imx: Use a convenient default value for SYS_MALLOC_F_LEN
Changes since v1:
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.17.1
Hello Fabio,
Am 03.05.2019 um 19:05 schrieb Fabio Estevam:
Changes since v1:
on i.MX
Thanks for this fix! This solves my issue with patch [PATCH] simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver
on a not yet mainlined imx6ull based board.
Tested-by: Heiko Schocher hs@denx.de
bye, Heiko
Commit 3a7c45f6a772 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver") causes some i.MX boards that were converted to DM, such as warp7, to fail to boot. As explained by Lukas Auer: "With the patch, U-Boot probes the drivers for devices under simple-bus device tree nodes in the pre-relocation device model. The default value of CONFIG_SYS_MALLOC_F_LEN (0x400) leaves U-Boot with not enough memory to do this, causing it to hang." Fix this problem by providing a convenient default value for CONFIG_SYS_MALLOC_F_LEN. Reported-by: Pierre-Jean Texier pjtexier@koncepto.io Suggested-by: Lukas Auer lukas.auer@aisec.fraunhofer.de Signed-off-by: Fabio Estevam festevam@gmail.com Tested-by: Pierre-Jean Texier pjtexier@koncepto.io Tested-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Reviewed-by: Lukas Auer lukas.auer@aisec.fraunhofer.de Reviewed-by: Peng Fan peng.fan@nxp.com Tested-by: Heiko Schocher hs@denx.de
Best regards, Stefano Babic
participants (8)
Auer, Lukas
Bryan O'Donoghue
Fabio Estevam
Heiko Schocher
Joris OFFOUGA
Peng Fan
Pierre-Jean Texier
sbabic@denx.de
