[PATCH] fs: btrfs: Select SHA256 in Kconfig
Since commit 565a4147d17a ("fs: btrfs: Add more checksum algorithms") btrfs uses the sha256 checksum algorithm. But Kconfig lacks to select it. This leads to compilation errors: fs/built-in.o: In function `hash_sha256': fs/btrfs/crypto/hash.c:25: undefined reference to `sha256_starts' fs/btrfs/crypto/hash.c:26: undefined reference to `sha256_update' fs/btrfs/crypto/hash.c:27: undefined reference to `sha256_finish'
Signed-off-by: Matthias Brugger mbrugger@suse.com
fs/btrfs/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/fs/btrfs/Kconfig b/fs/btrfs/Kconfig index f302b1fbef..2a32f42ad1 100644 --- a/fs/btrfs/Kconfig +++ b/fs/btrfs/Kconfig @@ -4,6 +4,7 @@ config FS_BTRFS select LZO select ZSTD select RBTREE + select SHA256 help This provides a single-device read-only BTRFS support. BTRFS is a next-generation Linux file system based on the copy-on-write
Oh, forgot to select sha256.
Thanks for the fix.
Reviewed-by: Qu Wenruo wqu@suse.com
Thanks, Qu
- select SHA256 help This provides a single-device read-only BTRFS support. BTRFS is a next-generation Linux file system based on the copy-on-write
So this is a fix for u-boot, got me confused and not for the first time as there's Kconfig and the same fs/btrfs/ directory structure.
Well, sometimes too unified file structure/code base can also be a problem.
Considering I'm also going to continue cross-porting more code to U-boot, any recommendation on this? Using different prefix?
Thanks, Qu
If it's a series then please mention u-boot in the cover letter, no need to change the patches, I'll go check CC if I'm too confused about the patch.
I would suggest using subject prefix [PATCH u-boot]
Signed-off-by: Matthias Brugger mbrugger@suse.com Reviewed-by: Qu Wenruo wqu@suse.com
participants (6)
David Sterba
Marek Behun
Qu Wenruo
Qu Wenruo
