[U-Boot] [v4 18/29] arm: socfpga: stratix10: Add SOCFPGA Stratix10 base address
Add base address header file for Stratix10 SoC
Signed-off-by: Chin Liang See clsee@altera.com Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 48 ++++++++++++++++++++ 1 files changed, 48 insertions(+), 0 deletions(-) create mode 100755 arch/arm/mach-socfpga/include/mach/base_addr_s10.h
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_s10.h b/arch/arm/mach-socfpga/include/mach/base_addr_s10.h new file mode 100755 index 0000000..411518d --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/base_addr_s10.h @@ -0,0 +1,48 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SOCFPGA_S10_BASE_HARDWARE_H_ +#define _SOCFPGA_S10_BASE_HARDWARE_H_ + +#define SOCFPGA_SMMU_ADDRESS 0xfa000000 +#define SOCFPGA_EMAC0_ADDRESS 0xff800000 +#define SOCFPGA_EMAC1_ADDRESS 0xff802000 +#define SOCFPGA_EMAC2_ADDRESS 0xff804000 +#define SOCFPGA_SDMMC_ADDRESS 0xff808000 +#define SOCFPGA_USB0_ADDRESS 0xffb00000 +#define SOCFPGA_USB1_ADDRESS 0xffb40000 +#define SOCFPGA_NANDREGS_ADDRESS 0xffb80000 +#define SOCFPGA_NANDDATA_ADDRESS 0xffb90000 +#define SOCFPGA_UART0_ADDRESS 0xffc02000 +#define SOCFPGA_UART1_ADDRESS 0xffc02100 +#define SOCFPGA_I2C0_ADDRESS 0xffc02800 +#define SOCFPGA_I2C1_ADDRESS 0xffc02900 +#define SOCFPGA_I2C2_ADDRESS 0xffc02a00 +#define SOCFPGA_I2C3_ADDRESS 0xffc02b00 +#define SOCFPGA_I2C4_ADDRESS 0xffc02c00 +#define SOCFPGA_SPTIMER0_ADDRESS 0xffc03000 +#define SOCFPGA_SPTIMER1_ADDRESS 0xffc03100 +#define SOCFPGA_GPIO0_ADDRESS 0xffc03200 +#define SOCFPGA_GPIO1_ADDRESS 0xffc03300 +#define SOCFPGA_SYSTIMER0_ADDRESS 0xffd00000 +#define SOCFPGA_SYSTIMER0_ADDRESS 0xffd00100 +#define SOCFPGA_L4WD0_ADDRESS 0xffd00200 +#define SOCFPGA_L4WD0_ADDRESS 0xffd00300 +#define SOCFPGA_L4WD0_ADDRESS 0xffd00400 +#define SOCFPGA_L4WD0_ADDRESS 0xffd00500 +#define SOCFPGA_CLKMGR_ADDRESS 0xffd10000 +#define SOCFPGA_RSTMGR_ADDRESS 0xffd11000 +#define SOCFPGA_SYSMGR_ADDRESS 0xffd12000 +#define SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS 0xffd13000 +#define SOCFPGA_DMANONSECURE_ADDRESS 0xffda0000 +#define SOCFPGA_DMASECURE_ADDRESS 0xffda1000 +#define SOCFPGA_SPIS0_ADDRESS 0xffda2000 +#define SOCFPGA_SPIS1_ADDRESS 0xffda3000 +#define SOCFPGA_SPIM0_ADDRESS 0xffda4000 +#define SOCFPGA_SPIM1_ADDRESS 0xffda5000 +#define SOCFPGA_OCRAM_ADDRESS 0xffe00000 + +#endif /* _SOCFPGA_S10_BASE_HARDWARE_H_ */
This is initial version of device tree for the Intel socfpga arria10 development kit with sdmmc.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/socfpga_arria10.dtsi | 859 ++++++++++++++++++++ arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 30 + .../dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi | 479 +++++++++++ 4 files changed, 1370 insertions(+), 1 deletions(-) create mode 100644 arch/arm/dts/socfpga_arria10.dtsi create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts create mode 100644 arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3ee608b..024aa5f 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -137,7 +137,8 @@ dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_cyclone5_sockit.dtb \ socfpga_cyclone5_socrates.dtb \ socfpga_cyclone5_sr1500.dtb \ - socfpga_cyclone5_vining_fpga.dtb + socfpga_cyclone5_vining_fpga.dtb \ + socfpga_arria10_socdk_sdmmc.dtb
dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb \ dra72-evm-revc.dtb dra71-evm.dtb diff --git a/arch/arm/dts/socfpga_arria10.dtsi b/arch/arm/dts/socfpga_arria10.dtsi new file mode 100644 index 0000000..f63c4b4 --- /dev/null +++ b/arch/arm/dts/socfpga_arria10.dtsi @@ -0,0 +1,859 @@ +/* + * Copyright (C) 2016 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include "skeleton.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/altr,rst-mgr-a10.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + + aliases { + ethernet0 = &gmac0; + ethernet1 = &gmac1; + ethernet2 = &gmac2; + serial0 = &uart0; + serial1 = &uart1; + timer0 = &timer0; + timer1 = &timer1; + timer2 = &timer2; + timer3 = &timer3; + spi0 = &spi0; + spi1 = &spi1; + }; + + memory { + name = "memory"; + device_type = "memory"; + reg = <0x0 0x40000000>; /* 1GB */ + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <0>; + next-level-cache = <&L2>; + }; + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + reg = <1>; + next-level-cache = <&L2>; + }; + }; + + intc: intc@ffffd000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0xffffd000 0x1000>, + <0xffffc100 0x100>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + device_type = "soc"; + interrupt-parent = <&intc>; + ranges; + + amba { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + pdma: pdma@ffda1000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xffda1000 0x1000>; + interrupts = <0 83 IRQ_TYPE_LEVEL_HIGH>, + <0 84 IRQ_TYPE_LEVEL_HIGH>, + <0 85 IRQ_TYPE_LEVEL_HIGH>, + <0 86 IRQ_TYPE_LEVEL_HIGH>, + <0 87 IRQ_TYPE_LEVEL_HIGH>, + <0 88 IRQ_TYPE_LEVEL_HIGH>, + <0 89 IRQ_TYPE_LEVEL_HIGH>, + <0 90 IRQ_TYPE_LEVEL_HIGH>, + <0 91 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + #dma-channels = <8>; + #dma-requests = <32>; + clocks = <&l4_main_clk>; + clock-names = "apb_pclk"; + }; + }; + + clkmgr@ffd04000 { + compatible = "altr,clk-mgr"; + reg = <0xffd04000 0x1000>; + reg-names = "soc_clock_manager_OCP_SLV"; + + clocks { + #address-cells = <1>; + #size-cells = <0>; + + cb_intosc_hs_div2_clk: cb_intosc_hs_div2_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + cb_intosc_ls_clk: cb_intosc_ls_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + f2s_free_clk: f2s_free_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + osc1: osc1 { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + + main_pll: main_pll { + #address-cells = <1>; + #size-cells = <0>; + #clock-cells = <0>; + compatible = "altr,socfpga-a10-pll-clock"; + clocks = <&osc1>, <&cb_intosc_ls_clk>, + <&f2s_free_clk>; + reg = <0x40>; + + main_mpu_base_clk: main_mpu_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + div-reg = <0x140 0 11>; + }; + + main_noc_base_clk: main_noc_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + div-reg = <0x144 0 11>; + }; + + main_emaca_clk: main_emaca_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x68>; + }; + + main_emacb_clk: main_emacb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x6C>; + }; + + main_emac_ptp_clk: main_emac_ptp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x70>; + }; + + main_gpio_db_clk: main_gpio_db_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x74>; + }; + + main_sdmmc_clk: main_sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x78>; + }; + + main_s2f_usr0_clk: main_s2f_usr0_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x7C>; + }; + + main_s2f_usr1_clk: main_s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x80>; + }; + + main_hmc_pll_ref_clk: main_hmc_pll_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x84>; + }; + + main_periph_ref_clk: main_periph_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_pll>; + reg = <0x9C>; + }; + }; + + periph_pll: periph_pll { + #address-cells = <1>; + #size-cells = <0>; + #clock-cells = <0>; + compatible = "altr,socfpga-a10-pll-clock"; + clocks = <&osc1>, <&cb_intosc_ls_clk>, + <&f2s_free_clk>, <&main_periph_ref_clk>; + reg = <0xC0>; + + peri_mpu_base_clk: peri_mpu_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + div-reg = <0x140 16 11>; + }; + + peri_noc_base_clk: peri_noc_base_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + div-reg = <0x144 16 11>; + }; + + peri_emaca_clk: peri_emaca_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xE8>; + }; + + peri_emacb_clk: peri_emacb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xEC>; + }; + + peri_emac_ptp_clk: peri_emac_ptp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF0>; + }; + + peri_gpio_db_clk: peri_gpio_db_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF4>; + }; + + peri_sdmmc_clk: peri_sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xF8>; + }; + + peri_s2f_usr0_clk: peri_s2f_usr0_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0xFC>; + }; + + peri_s2f_usr1_clk: peri_s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0x100>; + }; + + peri_hmc_pll_ref_clk: peri_hmc_pll_ref_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&periph_pll>; + reg = <0x104>; + }; + }; + + mpu_free_clk: mpu_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_mpu_base_clk>, <&peri_mpu_base_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x60>; + }; + + noc_free_clk: noc_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_noc_base_clk>, <&peri_noc_base_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x64>; + }; + + s2f_user1_free_clk: s2f_user1_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_s2f_usr1_clk>, <&peri_s2f_usr1_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + reg = <0x104>; + }; + + sdmmc_free_clk: sdmmc_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&main_sdmmc_clk>, <&peri_sdmmc_clk>, + <&osc1>, <&cb_intosc_hs_div2_clk>, + <&f2s_free_clk>; + fixed-divider = <4>; + reg = <0xF8>; + }; + + l4_sys_free_clk: l4_sys_free_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-perip-clk"; + clocks = <&noc_free_clk>; + fixed-divider = <4>; + }; + + l4_main_clk: l4_main_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 0 2>; + clk-gate = <0x48 1>; + }; + + l4_mp_clk: l4_mp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 8 2>; + clk-gate = <0x48 2>; + }; + + l4_sp_clk: l4_sp_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&noc_free_clk>; + div-reg = <0xA8 16 2>; + clk-gate = <0x48 3>; + }; + + mpu_periph_clk: mpu_periph_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&mpu_free_clk>; + fixed-divider = <4>; + clk-gate = <0x48 0>; + }; + + sdmmc_clk: sdmmc_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&sdmmc_free_clk>; + clk-gate = <0xC8 5>; + clk-phase = <0 135>; + }; + + qspi_clk: qspi_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_main_clk>; + clk-gate = <0xC8 11>; + }; + + nand_clk: nand_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_mp_clk>; + clk-gate = <0xC8 10>; + }; + + spi_m_clk: spi_m_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_main_clk>; + clk-gate = <0xC8 9>; + }; + + usb_clk: usb_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&l4_mp_clk>; + clk-gate = <0xC8 8>; + }; + + s2f_usr1_clk: s2f_usr1_clk { + #clock-cells = <0>; + compatible = "altr,socfpga-a10-gate-clk"; + clocks = <&peri_s2f_usr1_clk>; + clk-gate = <0xC8 6>; + }; + }; + }; + + gmac0: ethernet@ff800000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x44 0>; + reg = <0xff800000 0x2000>; + interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + resets = <&rst EMAC0_RESET>; + reset-names = "stmmaceth"; + status = "disabled"; + }; + + gmac1: ethernet@ff802000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x48 0>; + reg = <0xff802000 0x2000>; + interrupts = <0 93 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + resets = <&rst EMAC1_RESET>; + reset-names = "stmmaceth"; + status = "disabled"; + }; + + gmac2: ethernet@ff804000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; + altr,sysmgr-syscon = <&sysmgr 0x4C 0>; + reg = <0xff804000 0x2000>; + interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + /* Filled in by bootloader */ + mac-address = [00 00 00 00 00 00]; + snps,multicast-filter-bins = <256>; + snps,perfect-filter-entries = <128>; + tx-fifo-depth = <4096>; + rx-fifo-depth = <16384>; + clocks = <&l4_mp_clk>; + clock-names = "stmmaceth"; + status = "disabled"; + }; + + gpio0: gpio@ffc02900 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02900 0x100>; + status = "disabled"; + + porta: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <29>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 112 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + gpio1: gpio@ffc02a00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02a00 0x100>; + status = "disabled"; + + portb: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <29>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 113 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + gpio2: gpio@ffc02b00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-gpio"; + reg = <0xffc02b00 0x100>; + status = "disabled"; + + portc: gpio-controller@0 { + compatible = "snps,dw-apb-gpio-port"; + gpio-controller; + #gpio-cells = <2>; + snps,nr-gpios = <27>; + reg = <0>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <0 114 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + fpga_mgr: fpga-mgr@ffd03000 { + compatible = "altr,socfpga-a10-fpga-mgr"; + reg = <0xffd03000 0x100 + 0xffcfe400 0x20>; + clocks = <&l4_mp_clk>; + resets = <&rst FPGAMGR_RESET>; + reset-names = "fpgamgr"; + }; + + i2c0: i2c@ffc02200 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02200 0x100>; + interrupts = <0 105 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c1: i2c@ffc02300 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02300 0x100>; + interrupts = <0 106 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c2: i2c@ffc02400 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02400 0x100>; + interrupts = <0 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c3: i2c@ffc02500 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02500 0x100>; + interrupts = <0 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + i2c4: i2c@ffc02600 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xffc02600 0x100>; + interrupts = <0 109 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + sdr: sdr@0xffcfb100 { + compatible = "syscon"; + reg = <0xffcfb100 0x80>; + }; + + spi0: spi@ffda4000 { + compatible = "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xffda4000 0x100>; + interrupts = <0 101 IRQ_TYPE_LEVEL_HIGH>; + num-chipselect = <4>; + bus-num = <0>; + tx-dma-channel = <&pdma 16>; + rx-dma-channel = <&pdma 17>; + clocks = <&spi_m_clk>; + status = "disabled"; + }; + + spi1: spi@ffda5000 { + compatible = "snps,dw-apb-ssi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xffda5000 0x100>; + interrupts = <0 102 IRQ_TYPE_LEVEL_HIGH>; + num-chipselect = <4>; + bus-num = <0>; + tx-dma-channel = <&pdma 20>; + rx-dma-channel = <&pdma 21>; + clocks = <&spi_m_clk>; + status = "disabled"; + }; + + L2: l2-cache@fffff000 { + compatible = "arm,pl310-cache"; + reg = <0xfffff000 0x1000>; + interrupts = <0 18 IRQ_TYPE_LEVEL_HIGH>; + cache-unified; + cache-level = <2>; + }; + + mmc: dwmmc0@ff808000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "altr,socfpga-dw-mshc"; + reg = <0xff808000 0x1000>; + interrupts = <0 98 IRQ_TYPE_LEVEL_HIGH>; + fifo-depth = <0x400>; + bus-width = <4>; + clocks = <&l4_mp_clk>, <&sdmmc_clk>; + clock-names = "biu", "ciu"; + status = "disabled"; + }; + + ocram: sram@ffe00000 { + compatible = "mmio-sram"; + reg = <0xffe00000 0x40000>; + }; + + eccmgr: eccmgr@ffd06000 { + compatible = "altr,socfpga-a10-ecc-manager"; + altr,sysmgr-syscon = <&sysmgr>; + #address-cells = <1>; + #size-cells = <1>; + interrupts = <0 2 IRQ_TYPE_LEVEL_HIGH>, + <0 0 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <2>; + ranges; + + sdramedac { + compatible = "altr,sdram-edac-a10"; + altr,sdr-syscon = <&sdr>; + interrupts = <17 IRQ_TYPE_LEVEL_HIGH>, + <49 IRQ_TYPE_LEVEL_HIGH>; + }; + + l2-ecc@ffd06010 { + compatible = "altr,socfpga-a10-l2-ecc"; + reg = <0xffd06010 0x4>; + interrupts = <0 IRQ_TYPE_LEVEL_HIGH>, + <32 IRQ_TYPE_LEVEL_HIGH>; + }; + + ocram-ecc@ff8c3000 { + compatible = "altr,socfpga-a10-ocram-ecc"; + reg = <0xff8c3000 0x400>; + interrupts = <1 IRQ_TYPE_LEVEL_HIGH>, + <33 IRQ_TYPE_LEVEL_HIGH>; + }; + + sdmmca-ecc@ff8c2c00 { + compatible = "altr,socfpga-sdmmc-ecc"; + reg = <0xff8c2c00 0x400>; + altr,ecc-parent = <&mmc>; + interrupts = <15 IRQ_TYPE_LEVEL_HIGH>, + <47 IRQ_TYPE_LEVEL_HIGH>, + <16 IRQ_TYPE_LEVEL_HIGH>, + <48 IRQ_TYPE_LEVEL_HIGH>; + }; + + emac0-rx-ecc@ff8c0800 { + compatible = "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0800 0x400>; + altr,ecc-parent = <&gmac0>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH>, + <36 IRQ_TYPE_LEVEL_HIGH>; + }; + + emac0-tx-ecc@ff8c0c00 { + compatible = "altr,socfpga-eth-mac-ecc"; + reg = <0xff8c0c00 0x400>; + altr,ecc-parent = <&gmac0>; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH>, + <37 IRQ_TYPE_LEVEL_HIGH>; + }; + + dma-ecc@ff8c8000 { + compatible = "altr,socfpga-dma-ecc"; + reg = <0xff8c8000 0x400>; + altr,ecc-parent = <&pdma>; + interrupts = <10 IRQ_TYPE_LEVEL_HIGH>, + <42 IRQ_TYPE_LEVEL_HIGH>; + }; + + usb0-ecc@ff8c8800 { + compatible = "altr,socfpga-usb-ecc"; + reg = <0xff8c8800 0x400>; + altr,ecc-parent = <&usb0>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH>, + <34 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + qspi: qspi@ff809000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "cadence,qspi"; + reg = <0xff809000 0x100>, + <0xffa00000 0x100000>; + interrupts = <0 100 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_main_clk>; + ext-decoder = <0>; /* external decoder */ + num-chipselect = <4>; + fifo-depth = <128>; + sram-size = <512>; + bus-num = <2>; + status = "disabled"; + }; + + rst: rstmgr@ffd05000 { + #reset-cells = <1>; + compatible = "altr,rst-mgr"; + reg = <0xffd05000 0x100>; + altr,modrst-offset = <0x20>; + }; + + scu: snoop-control-unit@ffffc000 { + compatible = "arm,cortex-a9-scu"; + reg = <0xffffc000 0x100>; + }; + + sysmgr: sysmgr@ffd06000 { + compatible = "altr,sys-mgr", "syscon"; + reg = <0xffd06000 0x300>; + cpu1-start-addr = <0xffd06230>; + }; + + /* Local timer */ + timer@ffffc600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0xffffc600 0x100>; + interrupts = <1 13 0xf04>; + clocks = <&mpu_periph_clk>; + }; + + timer0: timer0@ffc02700 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 115 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffc02700 0x100>; + clocks = <&l4_sp_clk>; + clock-names = "timer"; + }; + + timer1: timer1@ffc02800 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 116 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffc02800 0x100>; + clocks = <&l4_sp_clk>; + clock-names = "timer"; + }; + + timer2: timer2@ffd00000 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 117 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffd00000 0x100>; + clocks = <&l4_sys_free_clk>; + clock-names = "timer"; + }; + + timer3: timer3@ffd00100 { + compatible = "snps,dw-apb-timer"; + interrupts = <0 118 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xffd01000 0x100>; + clocks = <&l4_sys_free_clk>; + clock-names = "timer"; + }; + + uart0: serial0@ffc02000 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02000 0x100>; + interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + uart1: serial1@ffc02100 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02100 0x100>; + interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&l4_sp_clk>; + status = "disabled"; + }; + + usbphy0: usbphy@0 { + #phy-cells = <0>; + compatible = "usb-nop-xceiv"; + status = "okay"; + }; + + usb0: usb@ffb00000 { + compatible = "snps,dwc2"; + reg = <0xffb00000 0xffff>; + interrupts = <0 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usb_clk>; + clock-names = "otg"; + resets = <&rst USB0_RESET>; + reset-names = "dwc2"; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + usb1: usb@ffb40000 { + compatible = "snps,dwc2"; + reg = <0xffb40000 0xffff>; + interrupts = <0 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&usb_clk>; + clock-names = "otg"; + resets = <&rst USB1_RESET>; + reset-names = "dwc2"; + phys = <&usbphy0>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + + watchdog0: watchdog@ffd00200 { + compatible = "snps,dw-wdt"; + reg = <0xffd00200 0x100>; + interrupts = <0 119 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sys_free_clk>; + status = "disabled"; + }; + + watchdog1: watchdog@ffd00300 { + compatible = "snps,dw-wdt"; + reg = <0xffd00300 0x100>; + interrupts = <0 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l4_sys_free_clk>; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts new file mode 100644 index 0000000..fdd581b --- /dev/null +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2016 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +/dts-v1/; +#include "socfpga_arria10_socdk_sdmmc_handoff.dtsi" + +/ { + chosen { + bootargs = "console=ttyS0,115200"; + }; +}; + +&uart1 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&mmc { + u-boot,dm-pre-reloc; + status = "okay"; + num-slots = <1>; + cap-sd-highspeed; + broken-cd; + bus-width = <4>; + altr,dw-mshc-ciu-div = <3>; + altr,dw-mshc-sdr-timing = <0 3>; +}; diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi b/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi new file mode 100644 index 0000000..0778141 --- /dev/null +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc_handoff.dtsi @@ -0,0 +1,479 @@ +/* + * Copyright (C) 2016 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + * + *<auto-generated> + * This code was generated by a tool based on + * handoffs from both Qsys and Quartus. + * + * Changes to this file may be lost if + * the code is regenerated. + *</auto-generated> + */ + +#include "socfpga_arria10.dtsi" + +/ { + model = "Altera SOCFPGA Arria 10"; + compatible = "altr,socfpga-arria10", "altr,socfpga"; + + chosen { + /* Bootloader setting: uboot.rbf_filename */ + cff-file = "ghrd_10as066n2.periph.rbf"; + early-release-fpga-config; + }; + + soc { + u-boot,dm-pre-reloc; + clkmgr@ffd04000 { + u-boot,dm-pre-reloc; + clocks { + u-boot,dm-pre-reloc; + osc1 { + u-boot,dm-pre-reloc; + clock-frequency = <25000000>; + clock-output-names = "altera_arria10_hps_eosc1-clk"; + }; + + cb_intosc_ls_clk { + u-boot,dm-pre-reloc; + clock-frequency = <60000000>; + clock-output-names = "altera_arria10_hps_cb_intosc_ls-clk"; + }; + + f2s_free_clk { + u-boot,dm-pre-reloc; + clock-frequency = <200000000>; + clock-output-names = "altera_arria10_hps_f2h_free-clk"; + }; + + main_pll { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_mainpllgrp + */ + altr,of_reg_value = < + 0 /* Field: vco0.psrc */ + 1 /* Field: vco1.denom */ + 191 /* Field: vco1.numer */ + 0 /* Field: mpuclk */ + 0 /* Field: mpuclk.cnt */ + 0 /* Field: mpuclk.src */ + 0 /* Field: nocclk */ + 0 /* Field: nocclk.cnt */ + 0 /* Field: nocclk.src */ + 900 /* Field: cntr2clk.cnt */ + 900 /* Field: cntr3clk.cnt */ + 900 /* Field: cntr4clk.cnt */ + 900 /* Field: cntr5clk.cnt */ + 900 /* Field: cntr6clk.cnt */ + 900 /* Field: cntr7clk.cnt */ + 0 /* Field: cntr7clk.src */ + 900 /* Field: cntr8clk.cnt */ + 900 /* Field: cntr9clk.cnt */ + 0 /* Field: cntr9clk.src */ + 900 /* Field: cntr15clk.cnt */ + 0 /* Field: nocdiv.l4mainclk */ + 0 /* Field: nocdiv.l4mpclk */ + 2 /* Field: nocdiv.l4spclk */ + 0 /* Field: nocdiv.csatclk */ + 1 /* Field: nocdiv.cstraceclk */ + 1 /* Field: nocdiv.cspdbgclk */ + >; + }; + + periph_pll { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_perpllgrp + */ + altr,of_reg_value = < + 0 /* Field: vco0.psrc */ + 1 /* Field: vco1.denom */ + 159 /* Field: vco1.numer */ + 7 /* Field: cntr2clk.cnt */ + 1 /* Field: cntr2clk.src */ + 900 /* Field: cntr3clk.cnt */ + 1 /* Field: cntr3clk.src */ + 19 /* Field: cntr4clk.cnt */ + 1 /* Field: cntr4clk.src */ + 499 /* Field: cntr5clk.cnt */ + 1 /* Field: cntr5clk.src */ + 9 /* Field: cntr6clk.cnt */ + 1 /* Field: cntr6clk.src */ + 900 /* Field: cntr7clk.cnt */ + 900 /* Field: cntr8clk.cnt */ + 0 /* Field: cntr8clk.src */ + 900 /* Field: cntr9clk.cnt */ + 0 /* Field: emacctl.emac0sel */ + 0 /* Field: emacctl.emac1sel */ + 0 /* Field: emacctl.emac2sel */ + 32000 /* Field: gpiodiv.gpiodbclk */ + >; + }; + + altera { + u-boot,dm-pre-reloc; + /* + * Address Block: soc_clock_manager_OCP_SLV. + * i_clk_mgr_alteragrp + */ + altr,of_reg_value = < + 0x0384000b /* Register: nocclk */ + 0x03840001 /* Register: mpuclk */ + >; + }; + }; + }; + + /* + * Driver: altera_arria10_soc_3v_io48_pin_mux_arria10_uboot_driver + * Binding: pinmux + */ + i_io48_pin_mux: pinmux@0xffd07000 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "pinctrl-single"; + reg = <0xffd07000 0x00000800>; + reg-names = "soc_3v_io48_pin_mux_OCP_SLV"; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_shared_3v_io_grp + */ + shared { + u-boot,dm-pre-reloc; + reg = <0xffd07000 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000f>; + pinctrl-single,pins = + /* Reg: pinmux_shared_io_q1_1 */ + <0x00000000 0x00000008>, + /* Reg: pinmux_shared_io_q1_2 */ + <0x00000004 0x00000008>, + /* Reg: pinmux_shared_io_q1_3 */ + <0x00000008 0x00000008>, + /* Reg: pinmux_shared_io_q1_4 */ + <0x0000000c 0x00000008>, + /* Reg: pinmux_shared_io_q1_5 */ + <0x00000010 0x00000008>, + /* Reg: pinmux_shared_io_q1_6 */ + <0x00000014 0x00000008>, + /* Reg: pinmux_shared_io_q1_7 */ + <0x00000018 0x00000008>, + /* Reg: pinmux_shared_io_q1_8 */ + <0x0000001c 0x00000008>, + /* Reg: pinmux_shared_io_q1_9 */ + <0x00000020 0x00000008>, + /* Reg: pinmux_shared_io_q1_10 */ + <0x00000024 0x00000008>, + /* Reg: pinmux_shared_io_q1_11 */ + <0x00000028 0x00000008>, + /* Reg: pinmux_shared_io_q1_12 */ + <0x0000002c 0x00000008>, + /* Reg: pinmux_shared_io_q2_1 */ + <0x00000030 0x00000004>, + /* Reg: pinmux_shared_io_q2_2 */ + <0x00000034 0x00000004>, + /* Reg: pinmux_shared_io_q2_3 */ + <0x00000038 0x00000004>, + /* Reg: pinmux_shared_io_q2_4 */ + <0x0000003c 0x00000004>, + /* Reg: pinmux_shared_io_q2_5 */ + <0x00000040 0x00000004>, + /* Reg: pinmux_shared_io_q2_6 */ + <0x00000044 0x00000004>, + /* Reg: pinmux_shared_io_q2_7 */ + <0x00000048 0x00000004>, + /* Reg: pinmux_shared_io_q2_8 */ + <0x0000004c 0x00000004>, + /* Reg: pinmux_shared_io_q2_9 */ + <0x00000050 0x00000004>, + /* Reg: pinmux_shared_io_q2_10 */ + <0x00000054 0x00000004>, + /* Reg: pinmux_shared_io_q2_11 */ + <0x00000058 0x00000004>, + /* Reg: pinmux_shared_io_q2_12 */ + <0x0000005c 0x00000004>, + /* Reg: pinmux_shared_io_q3_1 */ + <0x00000060 0x00000003>, + /* Reg: pinmux_shared_io_q3_2 */ + <0x00000064 0x00000003>, + /* Reg: pinmux_shared_io_q3_3 */ + <0x00000068 0x00000003>, + /* Reg: pinmux_shared_io_q3_4 */ + <0x0000006c 0x00000003>, + /* Reg: pinmux_shared_io_q3_5 */ + <0x00000070 0x00000003>, + /* Reg: pinmux_shared_io_q3_6 */ + <0x00000074 0x0000000f>, + /* Reg: pinmux_shared_io_q3_7 */ + <0x00000078 0x0000000a>, + /* Reg: pinmux_shared_io_q3_8 */ + <0x0000007c 0x0000000a>, + /* Reg: pinmux_shared_io_q3_9 */ + <0x00000080 0x0000000a>, + /* Reg: pinmux_shared_io_q3_10 */ + <0x00000084 0x0000000a>, + /* Reg: pinmux_shared_io_q3_11 */ + <0x00000088 0x00000001>, + /* Reg: pinmux_shared_io_q3_12 */ + <0x0000008c 0x00000001>, + /* Reg: pinmux_shared_io_q4_1 */ + <0x00000090 0x00000000>, + /* Reg: pinmux_shared_io_q4_2 */ + <0x00000094 0x00000000>, + /* Reg: pinmux_shared_io_q4_3 */ + <0x00000098 0x0000000f>, + /* Reg: pinmux_shared_io_q4_4 */ + <0x0000009c 0x0000000c>, + /* Reg: pinmux_shared_io_q4_5 */ + <0x000000a0 0x0000000f>, + /* Reg: pinmux_shared_io_q4_6 */ + <0x000000a4 0x0000000f>, + /* Reg: pinmux_shared_io_q4_7 */ + <0x000000a8 0x0000000a>, + /* Reg: pinmux_shared_io_q4_8 */ + <0x000000ac 0x0000000a>, + /* Reg: pinmux_shared_io_q4_9 */ + <0x000000b0 0x0000000c>, + /* Reg: pinmux_shared_io_q4_10 */ + <0x000000b4 0x0000000c>, + /* Reg: pinmux_shared_io_q4_11 */ + <0x000000b8 0x0000000c>, + /* Reg: pinmux_shared_io_q4_12 */ + <0x000000bc 0x0000000c>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_dedicated_io_grp + */ + dedicated { + u-boot,dm-pre-reloc; + reg = <0xffd07200 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000f>; + pinctrl-single,pins = + /* Reg: pinmux_dedicated_io_4 */ + <0x0000000c 0x00000008>, + /* Reg: pinmux_dedicated_io_5 */ + <0x00000010 0x00000008>, + /* Reg: pinmux_dedicated_io_6 */ + <0x00000014 0x00000008>, + /* Regi: pinmux_dedicated_io_7 */ + <0x00000018 0x00000008>, + /* Reg: pinmux_dedicated_io_8 */ + <0x0000001c 0x00000008>, + /* Reg: pinmux_dedicated_io_9 */ + <0x00000020 0x00000008>, + /* Reg: pinmux_dedicated_io_10 */ + <0x00000024 0x0000000a>, + /* Reg: pinmux_dedicated_io_11 */ + <0x00000028 0x0000000a>, + /* Reg: pinmux_dedicated_io_12 */ + <0x0000002c 0x00000008>, + /* Reg: pinmux_dedicated_io_13 */ + <0x00000030 0x00000008>, + /* Reg: pinmux_dedicated_io_14 */ + <0x00000034 0x00000008>, + /* Reg: pinmux_dedicated_io_15 */ + <0x00000038 0x00000008>, + /* Reg: pinmux_dedicated_io_16 */ + <0x0000003c 0x0000000d>, + /* Reg: pinmux_dedicated_io_17 */ + <0x00000040 0x0000000d>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_dedicated_io_grp + */ + dedicated_cfg { + u-boot,dm-pre-reloc; + reg = <0xffd07200 0x00000200>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x003f3f3f>; + pinctrl-single,pins = + /* Reg: cfg_dedicated_io_bank */ + <0x00000100 0x00000101>, + /* Reg: cfg_dedicated_io_1 */ + <0x00000104 0x000b080a>, + /* Reg: cfg_dedicated_io_2 */ + <0x00000108 0x000b080a>, + /* Reg: cfg_dedicated_io_3 */ + <0x0000010c 0x000b080a>, + /* Reg: cfg_dedicated_io_4 */ + <0x00000110 0x000a282a>, + /* Reg: cfg_dedicated_io_5 */ + <0x00000114 0x000a282a>, + /* Reg: cfg_dedicated_io_6 */ + <0x00000118 0x0008282a>, + /* Reg: cfg_dedicated_io_7 */ + <0x0000011c 0x000a282a>, + /* Reg: cfg_dedicated_io_8 */ + <0x00000120 0x000a282a>, + /* Reg: cfg_dedicated_io_9 */ + <0x00000124 0x000a282a>, + /* Reg: cfg_dedicated_io_10 */ + <0x00000128 0x00090000>, + /* Reg: cfg_dedicated_io_11 */ + <0x0000012c 0x00090000>, + /* Reg: cfg_dedicated_io_12 */ + <0x00000130 0x000b282a>, + /* Reg: cfg_dedicated_io_13 */ + <0x00000134 0x000b282a>, + /* Reg: cfg_dedicated_io_14 */ + <0x00000138 0x000b282a>, + /* Reg: cfg_dedicated_io_15 */ + <0x0000013c 0x000b282a>, + /* Reg: cfg_dedicated_io_16 */ + <0x00000140 0x0008282a>, + /* Reg: cfg_dedicated_io_17 */ + <0x00000144 0x000a282a>; + }; + + /* + * Address Block: soc_3v_io48_pin_mux_OCP_SLV. + * i_io48_pin_mux_fpga_interface_grp + */ + fpga { + u-boot,dm-pre-reloc; + reg = <0xffd07400 0x00000100>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x00000001>; + pinctrl-single,pins = + /* Reg: pinmux_emac0_usefpga */ + <0x00000000 0x00000000>, + /* Reg: pinmux_emac1_usefpga */ + <0x00000004 0x00000000>, + /* Reg: pinmux_emac2_usefpga */ + <0x00000008 0x00000000>, + /* Reg: pinmux_i2c0_usefpga */ + <0x0000000c 0x00000000>, + /* Reg: pinmux_i2c1_usefpga */ + <0x00000010 0x00000000>, + /* Reg: pinmux_i2c_emac0_usefpga */ + <0x00000014 0x00000000>, + /* Reg: pinmux_i2c_emac1_usefpga */ + <0x00000018 0x00000000>, + /* Reg: pinmux_i2c_emac2_usefpga */ + <0x0000001c 0x00000000>, + /* Reg: pinmux_nand_usefpga */ + <0x00000020 0x00000000>, + /* Reg: pinmux_qspi_usefpga */ + <0x00000024 0x00000000>, + /* Reg: pinmux_sdmmc_usefpga */ + <0x00000028 0x00000000>, + /* Reg: pinmux_spim0_usefpga */ + <0x0000002c 0x00000000>, + /* Reg: pinmux_spim1_usefpga */ + <0x00000030 0x00000000>, + /* Reg: pinmux_spis0_usefpga */ + <0x00000034 0x00000000>, + /* Reg: pinmux_spis1_usefpga */ + <0x00000038 0x00000000>, + /* Reg: pinmux_uart0_usefpga */ + <0x0000003c 0x00000000>, + /* Reg: pinmux_uart1_usefpga */ + <0x00000040 0x00000000>; + }; + }; + + i_noc: noc@0xffd10000 { + compatible = "altr,socfpga-a10-noc"; + reg = <0xffd10000 0x00008000>; + reg-names = "mpu_m0"; + + firewall { + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * mpuregion0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * mpuregion0addr.limit + */ + altr,mpu0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0.noc_fw_ddr_l3_ddr_scr. + * hpsregion0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0.noc_fw_ddr_l3_ddr_scr. + * hpsregion0addr.limit + */ + altr,l3-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram0region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram0region0addr.limit + */ + altr,fpga2sdram0-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram1region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram1region0addr.limit + */ + altr,fpga2sdram1-0 = <0x00000000 0x0000ffff>; + /* + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram2region0addr.base + * Driver setting: altera_arria10_soc_noc_arria10_uboot_driver. + * I_NOC.mpu_m0. + * noc_fw_ddr_mpu_fpga2sdram_ddr_scr. + * fpga2sdram2region0addr.limit + */ + altr,fpga2sdram2-0 = <0x00000000 0x0000ffff>; + }; + }; + + hps_fpgabridge0: fpgabridge@0 { + compatible = "altr,socfpga-hps2fpga-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge1: fpgabridge@1 { + compatible = "altr,socfpga-lwhps2fpga-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge2: fpgabridge@2 { + compatible = "altr,socfpga-fpga2hps-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge3: fpgabridge@3 { + compatible = "altr,socfpga-fpga2sdram0-bridge"; + altr,init-val = <1>; + }; + + hps_fpgabridge4: fpgabridge@4 { + compatible = "altr,socfpga-fpga2sdram1-bridge"; + altr,init-val = <0>; + }; + + hps_fpgabridge5: fpgabridge@5 { + compatible = "altr,socfpga-fpga2sdram2-bridge"; + altr,init-val = <1>; + }; + }; +};
This patch enables SPL build and implementation for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/Kconfig | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 80c5992..0ed36cd 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -561,9 +561,9 @@ config ARCH_SNAPDRAGON config ARCH_SOCFPGA bool "Altera SOCFPGA family" select CPU_V7 - select SUPPORT_SPL if !TARGET_SOCFPGA_ARRIA10 + select SUPPORT_SPL select OF_CONTROL - select SPL_OF_CONTROL if !TARGET_SOCFPGA_ARRIA10 + select SPL_OF_CONTROL select DM select DM_SPI_FLASH select DM_SPI
These compat macros would be used by clock manager and pin mux drivers to look the required HW info from DTS for hardware initialization.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- include/fdtdec.h | 8 ++++++++ lib/fdtdec.c | 8 ++++++++ 2 files changed, 16 insertions(+), 0 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index d074478..73e3a46 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -155,6 +155,14 @@ enum fdt_compat_id { COMPAT_INTEL_BAYTRAIL_FSP_MDP, /* Intel FSP memory-down params */ COMPAT_INTEL_IVYBRIDGE_FSP, /* Intel Ivy Bridge FSP */ COMPAT_SUNXI_NAND, /* SUNXI NAND controller */ + COMPAT_ALTERA_SOCFPGA_CLK, /* SoCFPGA Clock initialization */ + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE, /* pinctrl-single */ + COMPAT_ALTERA_SOCFPGA_H2F_BRG, /* Arria10 hps2fpga bridge */ + COMPAT_ALTERA_SOCFPGA_LWH2F_BRG, /* Arria10 lwhps2fpga bridge */ + COMPAT_ALTERA_SOCFPGA_F2H_BRG, /* Arria10 fpga2hps bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR0, /* Arria10 fpga2SDRAM0 bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR1, /* Arria10 fpga2SDRAM1 bridge */ + COMPAT_ALTERA_SOCFPGA_F2SDR2, /* Arria10 fpga2SDRAM2 bridge */
COMPAT_COUNT, }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 81f47ef..ebe4a9a 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -66,6 +66,14 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(INTEL_BAYTRAIL_FSP_MDP, "intel,baytrail-fsp-mdp"), COMPAT(INTEL_IVYBRIDGE_FSP, "intel,ivybridge-fsp"), COMPAT(COMPAT_SUNXI_NAND, "allwinner,sun4i-a10-nand"), + COMPAT(ALTERA_SOCFPGA_CLK, "altr,clk-mgr"), + COMPAT(ALTERA_SOCFPGA_PINCTRL_SINGLE, "pinctrl-single"), + COMPAT(ALTERA_SOCFPGA_H2F_BRG, "altr,socfpga-hps2fpga-bridge"), + COMPAT(ALTERA_SOCFPGA_LWH2F_BRG, "altr,socfpga-lwhps2fpga-bridge"), + COMPAT(ALTERA_SOCFPGA_F2H_BRG, "altr,socfpga-fpga2hps-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR0, "altr,socfpga-fpga2sdram0-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR1, "altr,socfpga-fpga2sdram1-bridge"), + COMPAT(ALTERA_SOCFPGA_F2SDR2, "altr,socfpga-fpga2sdram2-bridge"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/include/mach/base_addr_a10.h | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h index 902c321..2d66580 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2014 Altera Corporation <www.altera.com> + * Copyright (C) 2014-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -36,10 +36,13 @@ #define SOCFPGA_ECC_OCRAM_ADDRESS 0xff8c3000 #define SOCFPGA_UART0_ADDRESS 0xffc02000 #define SOCFPGA_OSC1TIMER0_ADDRESS 0xffd00000 +#define SOCFPGA_OSC1TIMER1_ADDRESS 0xffd00100 #define SOCFPGA_CLKMGR_ADDRESS 0xffd04000 #define SOCFPGA_RSTMGR_ADDRESS 0xffd05000
#define SOCFPGA_SDR_ADDRESS 0xffcfb000 +#define SOCFPGA_NOC_L4_PRIV_FLT_OFST 0xffd11000 +#define SOCFPGA_NOC_FW_H2F_SCR_OFST 0xffd13500 #define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xffd12400 #define SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS 0xffd13200 #define SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS 0xffd13300
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/system_manager.c | 4 ++- drivers/fpga/socfpga.c | 7 +++- include/configs/socfpga_arria10_socdk.h | 56 +++++++++++++++++++------------ include/configs/socfpga_common.h | 33 ++++++++++++++++-- 4 files changed, 71 insertions(+), 29 deletions(-)
diff --git a/arch/arm/mach-socfpga/system_manager.c b/arch/arm/mach-socfpga/system_manager.c index 9e1c3fd..e1f0082 100644 --- a/arch/arm/mach-socfpga/system_manager.c +++ b/arch/arm/mach-socfpga/system_manager.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -11,8 +11,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; +#endif
/* * Populate the value for SYSMGR.FPGAINTF.MODULE based on pinmux setting. diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index bfefafd..7fd922e 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2016 Altera Corporation <www.altera.com> * All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause @@ -19,8 +19,10 @@ DECLARE_GLOBAL_DATA_PTR;
static struct socfpga_fpga_manager *fpgamgr_regs = (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; +#endif
/* Set CD ratio */ static void fpgamgr_set_cd_ratio(unsigned long ratio) @@ -267,9 +269,10 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) }
/* Prior programming the FPGA, all bridges need to be shut off */ - +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* Disable all signals from hps peripheral controller to fpga */ writel(0, &sysmgr_regs->fpgaintfgrp_module); +#endif
/* Disable all signals from FPGA to HPS SDRAM */ #define SDR_CTRLGRP_FPGAPORTRST_ADDRESS 0x5080 diff --git a/include/configs/socfpga_arria10_socdk.h b/include/configs/socfpga_arria10_socdk.h index 577f60f..105c4c0 100644 --- a/include/configs/socfpga_arria10_socdk.h +++ b/include/configs/socfpga_arria10_socdk.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2015 Altera Corporation <www.altera.com> + * Copyright (C) 2015-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0 */ @@ -8,31 +8,20 @@ #define __CONFIG_SOCFGPA_ARRIA10_H__
#include <asm/arch/base_addr_a10.h> + /* U-Boot Commands */ -#define CONFIG_SYS_NO_FLASH #define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE #define CONFIG_HW_WATCHDOG
#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MMC #define CONFIG_CMD_PING
-/* - * Memory configurations - */ -#define PHYS_SDRAM_1_SIZE 0x2000000 - /* Booting Linux */ -#define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTFILE "zImage" #define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) #define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" @@ -40,24 +29,30 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
/* - * Display CPU and Board Info + * U-Boot general configurations + */ +/* Cache options */ +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE + +/* + * U-Boot console configurations */ -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_DISPLAY_BOARDINFO_LATE +#define CONFIG_DOS_PARTITION + +/* Memory configurations */ +#define PHYS_SDRAM_1_SIZE 0x80000000
/* Ethernet on SoC (EMAC) */ #if defined(CONFIG_CMD_NET) - -/* PHY */ #define CONFIG_PHY_MICREL #define CONFIG_PHY_MICREL_KSZ9031 - #endif
+/* + * U-Boot environment configurations + */ #define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0/* device 0 */ -#define CONFIG_ENV_OFFSET 512/* just after the MBR */
/* * arguments passed to the bootz command. The value of @@ -89,6 +84,23 @@ " root=${qspiroot} rw rootfstype=${qspirootfstype};"\ "bootm ${loadaddr} - ${fdt_addr}\0"
+/* + * Serial / UART configurations + */ +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} + +/* + * L4 OSC1 Timer 0 + */ +/* reload value when timer count to zero */ +#define TIMER_LOAD_VAL 0xFFFFFFFF + +/* + * Flash configurations + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 + /* The rest of the configuration is shared */ #include <configs/socfpga_common.h> #endif /* __CONFIG_H */ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bbbde1e..fde9a51 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -15,7 +15,9 @@ * High level configuration */ #define CONFIG_DISPLAY_BOARDINFO_LATE +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_ARCH_MISC_INIT +#endif #define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_SYS_NO_FLASH #define CONFIG_CLOCKS @@ -37,9 +39,13 @@ #define CONFIG_SYS_MALLOC_LEN (64 * 1024 * 1024) #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 #define CONFIG_SYS_MEMTEST_END PHYS_SDRAM_1_SIZE - +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_SYS_INIT_RAM_ADDR 0xFFFF0000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x40000 /* 256KB */ +#endif #define CONFIG_SYS_INIT_SP_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR \ @@ -213,11 +219,14 @@ unsigned int cm_get_qspi_controller_clk_hz(void); */ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE -4 -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS #ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET #define CONFIG_SYS_NS16550_CLK 1000000 -#else +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) +#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS #define CONFIG_SYS_NS16550_CLK 100000000 +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS +#define CONFIG_SYS_NS16550_CLK 50000000 #endif #define CONFIG_CONS_INDEX 1 #define CONFIG_BAUDRATE 115200 @@ -295,23 +304,39 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* * SPL * - * SRAM Memory layout: + * SRAM Memory layout(TARGET_SOCFPGA_GEN5): * * 0xFFFF_0000 ...... Start of SRAM * 0xFFFF_xxxx ...... Top of stack (grows down) * 0xFFFF_yyyy ...... Malloc area * 0xFFFF_zzzz ...... Global Data * 0xFFFF_FF00 ...... End of SRAM + * + * SRAM Memory layout(TARGET_SOCFPGA_ARRIA10): + * + * 0xFFE0_0000 ...... Start of SRAM + * 0xFFE0_xxxx ...... Top of stack (grows down) + * 0xFFE0_yyyy ...... Malloc area + * 0xFFE0_zzzz ...... Global Data + * 0xFFE3_FFFF ...... End of SRAM */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_RAM_DEVICE #define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_SPL_MAX_SIZE (64 * 1024) +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE +#endif
/* SPL SDMMC boot support */ #ifdef CONFIG_SPL_MMC_SUPPORT #if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 2 +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#endif #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" #else #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION 1
Drivers for reset manager is restructured such that common functions, gen5 drivers and Arria10 drivers are moved to reset_manager.c, reset_manager_gen5.c and reset_manager_arria10.c respectively.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/Makefile | 16 +- arch/arm/mach-socfpga/include/mach/reset_manager.h | 155 ++++++-- arch/arm/mach-socfpga/reset_manager.c | 112 +------ arch/arm/mach-socfpga/reset_manager_arria10.c | 407 ++++++++++++++++++++ .../{reset_manager.c => reset_manager_gen5.c} | 94 ++--- 5 files changed, 570 insertions(+), 214 deletions(-) create mode 100644 arch/arm/mach-socfpga/reset_manager_arria10.c copy arch/arm/mach-socfpga/{reset_manager.c => reset_manager_gen5.c} (58%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 809cd47..b8fcf6e 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -2,21 +2,27 @@ # (C) Copyright 2000-2003 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # -# Copyright (C) 2012 Altera Corporation <www.altera.com> +# Copyright (C) 2012-2016 Altera Corporation <www.altera.com> # # SPDX-License-Identifier: GPL-2.0+ #
obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ fpga_manager.o board.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ + reset_manager_gen5.o
-obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += freeze_controller.o wrap_iocsr_config.o \ + wrap_pinmux_config.o wrap_sdram_config.o +endif
+ifdef CONFIG_TARGET_SOCFPGA_GEN5 # QTS-generated config file wrappers -obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o -obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ - wrap_sdram_config.o CFLAGS_wrap_iocsr_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_pinmux_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_pll_config.o += -I$(srctree)/board/$(BOARDDIR) CFLAGS_wrap_sdram_config.o += -I$(srctree)/board/$(BOARDDIR) +endif diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 6225118..13f9731 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -7,15 +7,27 @@ #ifndef _RESET_MANAGER_H_ #define _RESET_MANAGER_H_
+/* Common function prototypes */ void reset_cpu(ulong addr); -void reset_deassert_peripherals_handoff(void); - void socfpga_bridges_reset(int enable); - void socfpga_per_reset(u32 reset, int set); void socfpga_per_reset_all(void);
#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +void reset_deassert_peripherals_handoff(void); +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +void watchdog_disable(void); +void reset_deassert_noc_ddr_scheduler(void); +int is_wdt_in_reset(void); +void emac_manage_reset(ulong emacbase, uint state); +int reset_deassert_bridges_handoff(void); +void reset_assert_fpga_connected_peripherals(void); +void reset_deassert_osc1wd0(void); +void reset_assert_uart(void); +void reset_deassert_uart(void); +#endif + +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct socfpga_reset_manager { u32 status; u32 ctrl; @@ -29,40 +41,40 @@ struct socfpga_reset_manager { u32 padding2[12]; u32 tstscratch; }; -#else +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) struct socfpga_reset_manager { - u32 stat; - u32 ramstat; - u32 miscstat; - u32 ctrl; - u32 hdsken; - u32 hdskreq; - u32 hdskack; - u32 counts; - u32 mpu_mod_reset; - u32 per_mod_reset; /* stated as per0_mod_reset in A10 datasheet */ - u32 per2_mod_reset; /* stated as per1_mod_reset in A10 datasheet */ - u32 brg_mod_reset; - u32 misc_mod_reset; /* stated as sys_mod_reset in A10 datasheet */ - u32 coldmodrst; - u32 nrstmodrst; - u32 dbgmodrst; - u32 mpuwarmmask; - u32 per0warmmask; - u32 per1warmmask; - u32 brgwarmmask; - u32 syswarmmask; - u32 nrstwarmmask; - u32 l3warmmask; - u32 tststa; - u32 tstscratch; - u32 hdsktimeout; - u32 hmcintr; - u32 hmcintren; - u32 hmcintrens; - u32 hmcintrenr; - u32 hmcgpout; - u32 hmcgpin; + uint32_t stat; + uint32_t ramstat; + uint32_t miscstat; + uint32_t ctrl; + uint32_t hdsken; + uint32_t hdskreq; + uint32_t hdskack; + uint32_t counts; + uint32_t mpumodrst; + uint32_t per0modrst; + uint32_t per1modrst; + uint32_t brgmodrst; + uint32_t sysmodrst; + uint32_t coldmodrst; + uint32_t nrstmodrst; + uint32_t dbgmodrst; + uint32_t mpuwarmmask; + uint32_t per0warmmask; + uint32_t per1warmmask; + uint32_t brgwarmmask; + uint32_t syswarmmask; + uint32_t nrstwarmmask; + uint32_t l3warmmask; + uint32_t tststa; + uint32_t tstscratch; + uint32_t hdsktimeout; + uint32_t hmcintr; + uint32_t hmcintren; + uint32_t hmcintrens; + uint32_t hmcintrenr; + uint32_t hmcgpout; + uint32_t hmcgpin; }; #endif
@@ -113,7 +125,7 @@ struct socfpga_reset_manager { #define RSTMGR_SDMMC RSTMGR_DEFINE(1, 22) #define RSTMGR_DMA RSTMGR_DEFINE(1, 28) #define RSTMGR_SDR RSTMGR_DEFINE(1, 29) -#else +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) /* * SocFPGA Arria10 reset IDs, bank mapping is as follows: * 0 ... mpumodrst @@ -144,4 +156,71 @@ struct socfpga_reset_manager { /* Create a human-readable reference to SoCFPGA reset. */ #define SOCFPGA_RESET(_name) RSTMGR_##_name
+/* Create a human-readable reference to SoCFPGA reset. */ +#define SOCFPGA_RESET(_name) RSTMGR_##_name + +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define ALT_RSTMGR_CTL_SWWARMRSTREQ_SET_MSK 0x00000002 +#define ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK 0x00000001 +#define ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK 0x00000002 +#define ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK 0x00000004 +#define ALT_RSTMGR_PER0MODRST_USB0_SET_MSK 0x00000008 +#define ALT_RSTMGR_PER0MODRST_USB1_SET_MSK 0x00000010 +#define ALT_RSTMGR_PER0MODRST_NAND_SET_MSK 0x00000020 +#define ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK 0x00000040 +#define ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK 0x00000080 +#define ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK 0x00000100 +#define ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK 0x00000200 +#define ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK 0x00000400 +#define ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK 0x00000800 +#define ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK 0x00001000 +#define ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK 0x00002000 +#define ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK 0x00004000 +#define ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK 0x00008000 +#define ALT_RSTMGR_PER0MODRST_DMA_SET_MSK 0x00010000 +#define ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK 0x00020000 +#define ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK 0x00040000 +#define ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK 0x00080000 +#define ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK 0x00100000 +#define ALT_RSTMGR_PER0MODRST_DMAECC_SET_MSK 0x00200000 +#define ALT_RSTMGR_PER0MODRST_EMACPTP_SET_MSK 0x00400000 +#define ALT_RSTMGR_PER0MODRST_DMAIF0_SET_MSK 0x01000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF1_SET_MSK 0x02000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF2_SET_MSK 0x04000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF3_SET_MSK 0x08000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF4_SET_MSK 0x10000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF5_SET_MSK 0x20000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF6_SET_MSK 0x40000000 +#define ALT_RSTMGR_PER0MODRST_DMAIF7_SET_MSK 0x80000000 + +#define ALT_RSTMGR_PER1MODRST_WD0_SET_MSK 0x00000001 +#define ALT_RSTMGR_PER1MODRST_WD1_SET_MSK 0x00000002 +#define ALT_RSTMGR_PER1MODRST_L4SYSTMR0_SET_MSK 0x00000004 +#define ALT_RSTMGR_PER1MODRST_L4SYSTMR1_SET_MSK 0x00000008 +#define ALT_RSTMGR_PER1MODRST_SPTMR0_SET_MSK 0x00000010 +#define ALT_RSTMGR_PER1MODRST_SPTMR1_SET_MSK 0x00000020 +#define ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK 0x00000100 +#define ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK 0x00000200 +#define ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK 0x00000400 +#define ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK 0x00000800 +#define ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK 0x00001000 +#define ALT_RSTMGR_PER1MODRST_UART0_SET_MSK 0x00010000 +#define ALT_RSTMGR_PER1MODRST_UART1_SET_MSK 0x00020000 +#define ALT_RSTMGR_PER1MODRST_GPIO0_SET_MSK 0x01000000 +#define ALT_RSTMGR_PER1MODRST_GPIO1_SET_MSK 0x02000000 +#define ALT_RSTMGR_PER1MODRST_GPIO2_SET_MSK 0x04000000 + +#define ALT_RSTMGR_BRGMODRST_H2F_SET_MSK 0x00000001 +#define ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK 0x00000002 +#define ALT_RSTMGR_BRGMODRST_F2H_SET_MSK 0x00000004 +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK 0x00000008 +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK 0x00000010 +#define ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK 0x00000020 +#define ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK 0x00000040 + +#define ALT_RSTMGR_HDSKEN_SDRSELFREFEN_SET_MSK 0x00000001 +#define ALT_RSTMGR_HDSKEN_FPGAMGRHSEN_SET_MSK 0x00000002 +#define ALT_RSTMGR_HDSKEN_FPGAHSEN_SET_MSK 0x00000004 +#define ALT_RSTMGR_HDSKEN_ETRSTALLEN_SET_MSK 0x00000008 +#endif #endif /* _RESET_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index d0ff6c4..cc370dc 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -7,71 +7,12 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/fpga_manager.h> #include <asm/arch/reset_manager.h> -#include <asm/arch/system_manager.h>
static const struct socfpga_reset_manager *reset_manager_base = (void *)SOCFPGA_RSTMGR_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - -/* - * Assert or de-assert SoCFPGA reset manager reset. - */ -void socfpga_per_reset(u32 reset, int set) -{ - const void *reg; - - if (RSTMGR_BANK(reset) == 0) - reg = &reset_manager_base->mpu_mod_reset; - else if (RSTMGR_BANK(reset) == 1) - reg = &reset_manager_base->per_mod_reset; - else if (RSTMGR_BANK(reset) == 2) - reg = &reset_manager_base->per2_mod_reset; - else if (RSTMGR_BANK(reset) == 3) - reg = &reset_manager_base->brg_mod_reset; - else if (RSTMGR_BANK(reset) == 4) - reg = &reset_manager_base->misc_mod_reset; - else /* Invalid reset register, do nothing */ - return; - - if (set) - setbits_le32(reg, 1 << RSTMGR_RESET(reset)); - else - clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); -} - -/* - * Assert reset on every peripheral but L4WD0. - * Watchdog must be kept intact to prevent glitches - * and/or hangs. - * For the Arria10, we disable all the peripherals except L4 watchdog0, - * L4 Timer 0, and ECC. - */ -void socfpga_per_reset_all(void) -{ -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) - const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)); - - writel(~l4wd0, &reset_manager_base->per_mod_reset); - writel(0xffffffff, &reset_manager_base->per2_mod_reset); -#else - const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | - (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); - - unsigned mask_ecc_ocp = 0x0000FF00; - - /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ - writel(~l4wd0, &reset_manager_base->per1_mod_reset); - setbits_le32(&reset_manager_base->per0_mod_reset, ~mask_ecc_ocp); - - /* Finally disable the ECC_OCP */ - setbits_le32(&reset_manager_base->per0_mod_reset, mask_ecc_ocp); -#endif -}
/* * Write the reset manager register to cause reset @@ -89,54 +30,3 @@ void reset_cpu(ulong addr) ; }
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -/* - * Release peripherals from reset based on handoff - */ -void reset_deassert_peripherals_handoff(void) -{ - writel(0, &reset_manager_base->per_mod_reset); -} -#endif - -#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) -void socfpga_bridges_reset(int enable) -{ - /* For SoCFPGA-VT, this is NOP. */ -} -#else - -#define L3REGS_REMAP_LWHPS2FPGA_MASK 0x10 -#define L3REGS_REMAP_HPS2FPGA_MASK 0x08 -#define L3REGS_REMAP_OCRAM_MASK 0x01 - -void socfpga_bridges_reset(int enable) -{ -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) - const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | - L3REGS_REMAP_HPS2FPGA_MASK | - L3REGS_REMAP_OCRAM_MASK; - - if (enable) { - /* brdmodrst */ - writel(0xffffffff, &reset_manager_base->brg_mod_reset); - } else { - writel(0, &sysmgr_regs->iswgrp_handoff[0]); - writel(l3mask, &sysmgr_regs->iswgrp_handoff[1]); - - /* Check signal from FPGA. */ - if (!fpgamgr_test_fpga_ready()) { - /* FPGA not ready, do nothing. */ - printf("%s: FPGA not ready, aborting.\n", __func__); - return; - } - - /* brdmodrst */ - writel(0, &reset_manager_base->brg_mod_reset); - - /* Remap the bridges into memory map */ - writel(l3mask, SOCFPGA_L3REGS_ADDRESS); - } -#endif -} -#endif diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c new file mode 100644 index 0000000..66ccebc --- /dev/null +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -0,0 +1,407 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/fpga_manager.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <fdtdec.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_reset_manager *reset_manager_base = + (void *)SOCFPGA_RSTMGR_ADDRESS; +static const struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +static int get_bridge_init_val(const void *blob, int compat_id); + +#define ECC_MASK (ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK|\ + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK) + +void reset_assert_uart(void) +{ + u32 mask = 0; + unsigned int com_port; + + com_port = uart_com_port(gd->fdt_blob); + + if (SOCFPGA_UART1_ADDRESS == com_port) + mask |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + else if (SOCFPGA_UART0_ADDRESS == com_port) + mask |= ALT_RSTMGR_PER1MODRST_UART0_SET_MSK; + + setbits_le32(&reset_manager_base->per1modrst, mask); +} + +void reset_deassert_uart(void) +{ + u32 mask = 0; + unsigned int com_port; + + com_port = uart_com_port(gd->fdt_blob); + + if (SOCFPGA_UART1_ADDRESS == com_port) + mask |= ALT_RSTMGR_PER1MODRST_UART1_SET_MSK; + else if (SOCFPGA_UART0_ADDRESS == com_port) + mask |= ALT_RSTMGR_PER1MODRST_UART0_SET_MSK; + + clrbits_le32(&reset_manager_base->per1modrst, mask); +} + +static const uint32_t per0fpgamasks[] = { + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK, + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK, + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK, + 0, /* i2c0 per1mod */ + 0, /* i2c1 per1mod */ + 0, /* i2c0_emac */ + 0, /* i2c1_emac */ + 0, /* i2c2_emac */ + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_NAND_SET_MSK, + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPI_SET_MSK, + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMC_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIM0_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIM1_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIS0_SET_MSK, + ALT_RSTMGR_PER0MODRST_SPIS1_SET_MSK, + 0, /* uart0 per1mod */ + 0, /* uart1 per1mod */ +}; + +static const uint32_t per1fpgamasks[] = { + 0, /* emac0 per0mod */ + 0, /* emac1 per0mod */ + 0, /* emac2 per0mod */ + ALT_RSTMGR_PER1MODRST_I2C0_SET_MSK, + ALT_RSTMGR_PER1MODRST_I2C1_SET_MSK, + ALT_RSTMGR_PER1MODRST_I2C2_SET_MSK, /* i2c0_emac */ + ALT_RSTMGR_PER1MODRST_I2C3_SET_MSK, /* i2c1_emac */ + ALT_RSTMGR_PER1MODRST_I2C4_SET_MSK, /* i2c2_emac */ + 0, /* nand per0mod */ + 0, /* qspi per0mod */ + 0, /* sdmmc per0mod */ + 0, /* spim0 per0mod */ + 0, /* spim1 per0mod */ + 0, /* spis0 per0mod */ + 0, /* spis1 per0mod */ + ALT_RSTMGR_PER1MODRST_UART0_SET_MSK, + ALT_RSTMGR_PER1MODRST_UART1_SET_MSK, +}; + +struct bridge_cfg { + int compat_id; + u32 mask_noc; + u32 mask_rstmgr; +}; + +static const struct bridge_cfg bridge_cfg_tbl[] = { + { + COMPAT_ALTERA_SOCFPGA_H2F_BRG, + ALT_SYSMGR_NOC_H2F_SET_MSK, + ALT_RSTMGR_BRGMODRST_H2F_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_LWH2F_BRG, + ALT_SYSMGR_NOC_LWH2F_SET_MSK, + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2H_BRG, + ALT_SYSMGR_NOC_F2H_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR0, + ALT_SYSMGR_NOC_F2SDR0_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR1, + ALT_SYSMGR_NOC_F2SDR1_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK, + }, + { + COMPAT_ALTERA_SOCFPGA_F2SDR2, + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK, + }, +}; + +/* Disable the watchdog (toggle reset to watchdog) */ +void watchdog_disable(void) +{ + /* assert reset for watchdog */ + setbits_le32(&reset_manager_base->per1modrst, + ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); + +} + +/* Release NOC ddr scheduler from reset */ +void reset_deassert_noc_ddr_scheduler(void) +{ + clrbits_le32(&reset_manager_base->brgmodrst, + ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK); +} + +/* Check whether Watchdog in reset state? */ +int is_wdt_in_reset(void) +{ + unsigned long val; + + val = readl(&reset_manager_base->per1modrst); + val &= ALT_RSTMGR_PER1MODRST_WD0_SET_MSK; + + /* return 0x1 if watchdog in reset */ + return val; +} + +/* emacbase: base address of emac to enable/disable reset + * state: 0 - disable reset, !0 - enable reset + */ +void emac_manage_reset(ulong emacbase, uint state) +{ + ulong eccmask; + ulong emacmask; + switch (emacbase) { + case SOCFPGA_EMAC0_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC0_SET_MSK; + break; + case SOCFPGA_EMAC1_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC1_SET_MSK; + break; + case SOCFPGA_EMAC2_ADDRESS: + eccmask = ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK; + emacmask = ALT_RSTMGR_PER0MODRST_EMAC2_SET_MSK; + break; + default: + error("emac base address unexpected! %lx", emacbase); + hang(); + break; + } + + if (state) { + /* Enable ECC OCP first */ + setbits_le32(&reset_manager_base->per0modrst, eccmask); + setbits_le32(&reset_manager_base->per0modrst, emacmask); + } else { + /* Disable ECC OCP first */ + clrbits_le32(&reset_manager_base->per0modrst, emacmask); + clrbits_le32(&reset_manager_base->per0modrst, eccmask); + } +} + +static int get_bridge_init_val(const void *blob, int compat_id) +{ + int rval = 0; + int node; + u32 val; + + node = fdtdec_next_compatible(blob, 0, compat_id); + if (node >= 0) { + if (!fdtdec_get_int_array(blob, node, "init-val", &val, 1)) { + if (val == 1) + rval = val; + } + } + return rval; +} + +/* Enable bridges (hps2fpga, lwhps2fpga, fpga2hps, fpga2sdram) per handoff */ +int reset_deassert_bridges_handoff(void) +{ + u32 mask_noc = 0, mask_rstmgr = 0; + int i; + unsigned start = get_timer(0); + + for (i = 0; i < ARRAY_SIZE(bridge_cfg_tbl); i++) { + if (get_bridge_init_val(gd->fdt_blob, + bridge_cfg_tbl[i].compat_id)) { + mask_noc |= bridge_cfg_tbl[i].mask_noc; + mask_rstmgr |= bridge_cfg_tbl[i].mask_rstmgr; + } + } + + /* clear idle request to all bridges */ + setbits_le32(&sysmgr_regs->noc_idlereq_clr, mask_noc); + + /* Release bridges from reset state per handoff value */ + clrbits_le32(&reset_manager_base->brgmodrst, mask_rstmgr); + + /* Poll until all idleack to 0, timeout at 1000ms */ + while (readl(&sysmgr_regs->noc_idleack) & mask_noc) { + if (get_timer(start) > 1000) { + printf("Fail: noc_idleack = 0x%08x mask_noc = 0x%08x\n", + readl(&sysmgr_regs->noc_idleack), + mask_noc); + return -ETIMEDOUT; + } + } + return 0; +} + +void reset_assert_fpga_connected_peripherals(void) +{ + uint32_t mask0 = 0; + uint32_t mask1 = 0; + uint32_t fpga_pinux_addr = SOCFPGA_PINMUX_FPGA_INTERFACE_ADDRESS; + int i; + + for (i = 0; i < ARRAY_SIZE(per1fpgamasks); i++) { + if (readl(fpga_pinux_addr)) { + mask0 |= per0fpgamasks[i]; + mask1 |= per1fpgamasks[i]; + } + fpga_pinux_addr += sizeof(uint32_t); + } + + setbits_le32(&reset_manager_base->per0modrst, mask0 & ECC_MASK); + setbits_le32(&reset_manager_base->per1modrst, mask1); + setbits_le32(&reset_manager_base->per0modrst, mask0); +} + +/* Release L4 OSC1 Watchdog Timer 0 from reset through reset manager */ +void reset_deassert_osc1wd0(void) +{ + clrbits_le32(&reset_manager_base->per1modrst, + ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); +} + +/* + * Assert or de-assert SoCFPGA reset manager reset. + */ +void socfpga_per_reset(u32 reset, int set) +{ + const volatile uint32_t *reg; + uint32_t rstmgr_bank = RSTMGR_BANK(reset); + + switch (rstmgr_bank) { + case 0: + reg = &reset_manager_base->mpumodrst; + break; + case 1: + reg = &reset_manager_base->per0modrst; + break; + case 2: + reg = &reset_manager_base->per1modrst; + break; + case 3: + reg = &reset_manager_base->brgmodrst; + break; + case 4: + reg = &reset_manager_base->sysmodrst; + break; + + default: + return; + } + + if (set) + setbits_le32(reg, 1 << RSTMGR_RESET(reset)); + else + clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); +} + +/* + * Assert reset on every peripheral but L4WD0. + * Watchdog must be kept intact to prevent glitches + * and/or hangs. + * For the Arria10, we disable all the peripherals except L4 watchdog0, + * L4 Timer 0, and ECC. + */ +void socfpga_per_reset_all(void) +{ + const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | + (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); + + unsigned mask_ecc_ocp = + ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMACECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_EMACECC2_SET_MSK | + ALT_RSTMGR_PER0MODRST_USBECC0_SET_MSK | + ALT_RSTMGR_PER0MODRST_USBECC1_SET_MSK | + ALT_RSTMGR_PER0MODRST_NANDECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | + ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK; + + /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ + writel(~l4wd0, &reset_manager_base->per1modrst); + setbits_le32(&reset_manager_base->per0modrst, ~mask_ecc_ocp); + + /* Finally disable the ECC_OCP */ + setbits_le32(&reset_manager_base->per0modrst, mask_ecc_ocp); +} + +#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) +void socfpga_bridges_reset(int enable) +{ + /* For SoCFPGA-VT, this is NOP. */ +} +#else +void socfpga_bridges_reset(int enable) +{ +/* Disable all the bridges (hps2fpga, lwhps2fpga, fpga2hps, fpga2sdram) */ + /* set idle request to all bridges */ + writel(ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK, + &sysmgr_regs->noc_idlereq_set); + + /* Enable the NOC timeout */ + writel(ALT_SYSMGR_NOC_TMO_EN_SET_MSK, + &sysmgr_regs->noc_timeout); + + /* Poll until all idleack to 1 */ + while ((readl(&sysmgr_regs->noc_idleack) ^ + (ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK))) + ; + + /* Poll until all idlestatus to 1 */ + while ((readl(&sysmgr_regs->noc_idlestatus) ^ + (ALT_SYSMGR_NOC_H2F_SET_MSK | + ALT_SYSMGR_NOC_LWH2F_SET_MSK | + ALT_SYSMGR_NOC_F2H_SET_MSK | + ALT_SYSMGR_NOC_F2SDR0_SET_MSK | + ALT_SYSMGR_NOC_F2SDR1_SET_MSK | + ALT_SYSMGR_NOC_F2SDR2_SET_MSK))) + ; + + /* Put all bridges (except NOR DDR scheduler) into reset state */ + setbits_le32(&reset_manager_base->brgmodrst, + (ALT_RSTMGR_BRGMODRST_H2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2H_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM0_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM1_SET_MSK | + ALT_RSTMGR_BRGMODRST_F2SSDRAM2_SET_MSK)); + + /* Disable NOC timeout */ + writel(0, &sysmgr_regs->noc_timeout); +} +#endif diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager_gen5.c similarity index 58% copy from arch/arm/mach-socfpga/reset_manager.c copy to arch/arm/mach-socfpga/reset_manager_gen5.c index d0ff6c4..8c1f96e 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager_gen5.c @@ -1,10 +1,9 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2016, Intel Corporation * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0 */
- #include <common.h> #include <asm/io.h> #include <asm/arch/fpga_manager.h> @@ -15,28 +14,45 @@ DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_reset_manager *reset_manager_base = (void *)SOCFPGA_RSTMGR_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = +static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
/* + * Release peripherals from reset based on handoff + */ +void reset_deassert_peripherals_handoff(void) +{ + writel(0, &reset_manager_base->per_mod_reset); +} + +/* * Assert or de-assert SoCFPGA reset manager reset. */ void socfpga_per_reset(u32 reset, int set) { - const void *reg; - - if (RSTMGR_BANK(reset) == 0) - reg = &reset_manager_base->mpu_mod_reset; - else if (RSTMGR_BANK(reset) == 1) - reg = &reset_manager_base->per_mod_reset; - else if (RSTMGR_BANK(reset) == 2) - reg = &reset_manager_base->per2_mod_reset; - else if (RSTMGR_BANK(reset) == 3) - reg = &reset_manager_base->brg_mod_reset; - else if (RSTMGR_BANK(reset) == 4) - reg = &reset_manager_base->misc_mod_reset; - else /* Invalid reset register, do nothing */ - return; + const volatile uint32_t *reg; + uint32_t rstmgr_bank = RSTMGR_BANK(reset); + + switch (rstmgr_bank) { + case 0: + reg = &reset_manager_base->mpu_mod_reset; + break; + case 1: + reg = &reset_manager_base->per_mod_reset; + break; + case 2: + reg = &reset_manager_base->per2_mod_reset; + break; + case 3: + reg = &reset_manager_base->brg_mod_reset; + break; + case 4: + reg = &reset_manager_base->misc_mod_reset; + break; + + default: + return; + }
if (set) setbits_le32(reg, 1 << RSTMGR_RESET(reset)); @@ -53,52 +69,12 @@ void socfpga_per_reset(u32 reset, int set) */ void socfpga_per_reset_all(void) { -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0));
writel(~l4wd0, &reset_manager_base->per_mod_reset); writel(0xffffffff, &reset_manager_base->per2_mod_reset); -#else - const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | - (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); - - unsigned mask_ecc_ocp = 0x0000FF00; - - /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ - writel(~l4wd0, &reset_manager_base->per1_mod_reset); - setbits_le32(&reset_manager_base->per0_mod_reset, ~mask_ecc_ocp); - - /* Finally disable the ECC_OCP */ - setbits_le32(&reset_manager_base->per0_mod_reset, mask_ecc_ocp); -#endif }
-/* - * Write the reset manager register to cause reset - */ -void reset_cpu(ulong addr) -{ - /* request a warm reset */ - writel((1 << RSTMGR_CTRL_SWWARMRSTREQ_LSB), - &reset_manager_base->ctrl); - /* - * infinite loop here as watchdog will trigger and reset - * the processor - */ - while (1) - ; -} - -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -/* - * Release peripherals from reset based on handoff - */ -void reset_deassert_peripherals_handoff(void) -{ - writel(0, &reset_manager_base->per_mod_reset); -} -#endif - #if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) void socfpga_bridges_reset(int enable) { @@ -112,7 +88,6 @@ void socfpga_bridges_reset(int enable)
void socfpga_bridges_reset(int enable) { -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | L3REGS_REMAP_HPS2FPGA_MASK | L3REGS_REMAP_OCRAM_MASK; @@ -137,6 +112,5 @@ void socfpga_bridges_reset(int enable) /* Remap the bridges into memory map */ writel(l3mask, SOCFPGA_L3REGS_ADDRESS); } -#endif } #endif
The drivers is restructured such common functions, gen5 functions. and arria10 functions are moved to misc.c, misc_gen5 and misc_arria10 respectively.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Ching Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/Makefile | 6 +- arch/arm/mach-socfpga/include/mach/misc.h | 32 ++ arch/arm/mach-socfpga/misc.c | 427 +------------------------ arch/arm/mach-socfpga/misc_arria10.c | 255 +++++++++++++++ arch/arm/mach-socfpga/{misc.c => misc_gen5.c} | 232 ++------------ 5 files changed, 337 insertions(+), 615 deletions(-) create mode 100644 arch/arm/mach-socfpga/include/mach/misc.h create mode 100644 arch/arm/mach-socfpga/misc_arria10.c copy arch/arm/mach-socfpga/{misc.c => misc_gen5.c} (66%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index b8fcf6e..1ab68be 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -9,9 +9,11 @@
obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ fpga_manager.o board.o -obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += reset_manager_arria10.o misc_arria10.o \ + clock_manager_arria10.o pinmux.o obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o \ - reset_manager_gen5.o + reset_manager_gen5.o misc_gen5.o \ + clock_manager_gen5.o
ifdef CONFIG_SPL_BUILD obj-y += spl.o diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h new file mode 100644 index 0000000..045268d --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -0,0 +1,32 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _MISC_H_ +#define _MISC_H_ + +extern void dwmac_deassert_reset(const unsigned int of_reset_id, + const u32 phymode); + +struct bsel{ + const char *mode; + const char *name; +}; + +extern struct bsel bsel_str[]; + +#ifdef CONFIG_FPGA +extern void socfpga_fpga_add(void); +#else +inline void socfpga_fpga_add(void) {} +#endif + +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +unsigned int dedicated_uart_com_port(const void *blob); +unsigned int shared_uart_com_port(const void *blob); +unsigned int uart_com_port(const void *blob); +#endif + +#endif /* _MISC_H_ */ diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 510aa1d..7fd5c0e 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -7,45 +7,33 @@ #include <common.h> #include <asm/io.h> #include <errno.h> -#include <fdtdec.h> -#include <libfdt.h> #include <altera.h> #include <miiphy.h> #include <netdev.h> #include <watchdog.h> +#include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> -#include <asm/arch/scan_manager.h> #include <asm/arch/sdram_a10.h> #include <asm/arch/system_manager.h> #include <asm/arch/nic301.h> #include <asm/arch/scu.h> #include <asm/pl310.h>
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -#include <dt-bindings/reset/altr,rst-mgr.h> -#else -#include <dt-bindings/reset/altr,rst-mgr-a10.h> -#endif - DECLARE_GLOBAL_DATA_PTR;
-static struct pl310_regs *const pl310 = +static const struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; -static struct socfpga_reset_manager *reset_manager_base = - (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -static struct nic301_registers *nic301_regs = - (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -#else -static const struct socfpga_noc_fw_ocram *noc_fw_ocram_base = - (void *)SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS; -static const struct socfpga_noc_fw_ddr_l3 *noc_fw_ddr_l3_base = - (void *)SOCFPGA_SDR_FIREWALL_L3_ADDRESS; -#endif -static struct scu_registers *scu_regs = - (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; + +struct bsel bsel_str[] = { + { "rsvd", "Reserved", }, + { "fpga", "FPGA (HPS2FPGA Bridge)", }, + { "nand", "NAND Flash (1.8V)", }, + { "nand", "NAND Flash (3.0V)", }, + { "sd", "SD/MMC External Transceiver (1.8V)", }, + { "sd", "SD/MMC Internal Transceiver (3.0V)", }, + { "qspi", "QSPI Flash (1.8V)", }, + { "qspi", "QSPI Flash (3.0V)", }, +};
int dram_init(void) { @@ -84,219 +72,6 @@ void v7_outer_cache_disable(void) clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); }
-/* - * DesignWare Ethernet initialization - */ -#ifdef CONFIG_ETH_DESIGNWARE -static void dwmac_deassert_reset(const unsigned int of_reset_id, - const u32 phymode) -{ - u32 physhift, reset; - - if (of_reset_id == EMAC0_RESET) { - physhift = SYSMGR_EMACGRP_CTRL_PHYSEL0_LSB; - reset = SOCFPGA_RESET(EMAC0); - } else if (of_reset_id == EMAC1_RESET) { - physhift = SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB; - reset = SOCFPGA_RESET(EMAC1); -#ifndef CONFIG_TARGET_SOCFPGA_GEN5 - } else if (of_reset_id == EMAC2_RESET) { - reset = SOCFPGA_RESET(EMAC2); -#endif - } else { - printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); - return; - } - -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) - /* configure to PHY interface select choosed */ - clrsetbits_le32(&sysmgr_regs->emacgrp_ctrl, - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift, - phymode << physhift); -#else - clrsetbits_le32(&sysmgr_regs->emac[of_reset_id - EMAC0_RESET], - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, - phymode); -#endif - - /* Release the EMAC controller from reset */ - socfpga_per_reset(reset, 0); -} - -static u32 dwmac_phymode_to_modereg(const char *phymode, u32 *modereg) -{ - if (!phymode) - return -EINVAL; - - if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; - return 0; - } - - if (!strcmp(phymode, "rgmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII; - return 0; - } - - if (!strcmp(phymode, "rmii")) { - *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RMII; - return 0; - } - - return -EINVAL; -} - -static int socfpga_eth_reset(void) -{ - const void *fdt = gd->fdt_blob; - struct fdtdec_phandle_args args; - const char *phy_mode; - u32 phy_modereg; - int nodes[2]; /* Max. two GMACs */ - int ret, count; - int i, node; - - /* Put both GMACs into RESET state. */ - socfpga_per_reset(SOCFPGA_RESET(EMAC0), 1); - socfpga_per_reset(SOCFPGA_RESET(EMAC1), 1); - - count = fdtdec_find_aliases_for_id(fdt, "ethernet", - COMPAT_ALTERA_SOCFPGA_DWMAC, - nodes, ARRAY_SIZE(nodes)); - for (i = 0; i < count; i++) { - node = nodes[i]; - if (node <= 0) - continue; - - ret = fdtdec_parse_phandle_with_args(fdt, node, "resets", - "#reset-cells", 1, 0, - &args); - if (ret || (args.args_count != 1)) { - debug("GMAC%i: Failed to parse DT 'resets'!\n", i); - continue; - } - - phy_mode = fdt_getprop(fdt, node, "phy-mode", NULL); - ret = dwmac_phymode_to_modereg(phy_mode, &phy_modereg); - if (ret) { - debug("GMAC%i: Failed to parse DT 'phy-mode'!\n", i); - continue; - } - - dwmac_deassert_reset(args.args[0], phy_modereg); - } - - return 0; -} -#else -static int socfpga_eth_reset(void) -{ - return 0; -}; -#endif - -struct { - const char *mode; - const char *name; -} bsel_str[] = { - { "rsvd", "Reserved", }, - { "fpga", "FPGA (HPS2FPGA Bridge)", }, - { "nand", "NAND Flash (1.8V)", }, - { "nand", "NAND Flash (3.0V)", }, - { "sd", "SD/MMC External Transceiver (1.8V)", }, - { "sd", "SD/MMC Internal Transceiver (3.0V)", }, - { "qspi", "QSPI Flash (1.8V)", }, - { "qspi", "QSPI Flash (3.0V)", }, -}; - -static const struct { - const u16 pn; - const char *name; - const char *var; -} const socfpga_fpga_model[] = { - /* Cyclone V E */ - { 0x2b15, "Cyclone V, E/A2", "cv_e_a2" }, - { 0x2b05, "Cyclone V, E/A4", "cv_e_a4" }, - { 0x2b22, "Cyclone V, E/A5", "cv_e_a5" }, - { 0x2b13, "Cyclone V, E/A7", "cv_e_a7" }, - { 0x2b14, "Cyclone V, E/A9", "cv_e_a9" }, - /* Cyclone V GX/GT */ - { 0x2b01, "Cyclone V, GX/C3", "cv_gx_c3" }, - { 0x2b12, "Cyclone V, GX/C4", "cv_gx_c4" }, - { 0x2b02, "Cyclone V, GX/C5 or GT/D5", "cv_gx_c5" }, - { 0x2b03, "Cyclone V, GX/C7 or GT/D7", "cv_gx_c7" }, - { 0x2b04, "Cyclone V, GX/C9 or GT/D9", "cv_gx_c9" }, - /* Cyclone V SE/SX/ST */ - { 0x2d11, "Cyclone V, SE/A2 or SX/C2", "cv_se_a2" }, - { 0x2d01, "Cyclone V, SE/A4 or SX/C4", "cv_se_a4" }, - { 0x2d12, "Cyclone V, SE/A5 or SX/C5 or ST/D5", "cv_se_a5" }, - { 0x2d02, "Cyclone V, SE/A6 or SX/C6 or ST/D6", "cv_se_a6" }, - /* Arria V */ - { 0x2d03, "Arria V, D5", "av_d5" }, -}; - -static int socfpga_fpga_id(const bool print_id) -{ - const u32 altera_mi = 0x6e; - const u32 id = scan_mgr_get_fpga_id(); - - const u32 lsb = id & 0x00000001; - const u32 mi = (id >> 1) & 0x000007ff; - const u32 pn = (id >> 12) & 0x0000ffff; - const u32 version = (id >> 28) & 0x0000000f; - int i; - - if ((mi != altera_mi) || (lsb != 1)) { - printf("FPGA: Not Altera chip ID\n"); - return -EINVAL; - } - - for (i = 0; i < ARRAY_SIZE(socfpga_fpga_model); i++) - if (pn == socfpga_fpga_model[i].pn) - break; - - if (i == ARRAY_SIZE(socfpga_fpga_model)) { - printf("FPGA: Unknown Altera chip, ID 0x%08x\n", id); - return -EINVAL; - } - - if (print_id) - printf("FPGA: Altera %s, version 0x%01x\n", - socfpga_fpga_model[i].name, version); - return i; -} - -/* - * Print CPU information - */ -#if defined(CONFIG_DISPLAY_CPUINFO) -int print_cpuinfo(void) -{ - const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> - SYSMGR_BOOTINFO_BSEL_SHIFT) & 0x7; -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) - puts("CPU: Altera SoCFPGA Platform\n"); - socfpga_fpga_id(1); -#else - puts("CPU: Altera SoCFPGA Arria 10\n"); -#endif - printf("BOOT: %s\n", bsel_str[bsel].name); - return 0; -} -#endif - -#ifdef CONFIG_ARCH_MISC_INIT -int arch_misc_init(void) -{ - const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; - const int fpga_id = socfpga_fpga_id(0); - setenv("bootmode", bsel_str[bsel].mode); - if (fpga_id >= 0) - setenv("fpgatype", socfpga_fpga_model[fpga_id].var); - return socfpga_eth_reset(); -} -#endif - #if defined(CONFIG_SYS_CONSOLE_IS_IN_ENV) && \ defined(CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE) int overwrite_console(void) @@ -327,15 +102,13 @@ static Altera_desc altera_fpga[] = { };
/* add device descriptor to FPGA device table */ -static void socfpga_fpga_add(void) +void socfpga_fpga_add(void) { int i; fpga_init(); for (i = 0; i < ARRAY_SIZE(altera_fpga); i++) fpga_add(fpga_altera, &altera_fpga[i]); } -#else -static inline void socfpga_fpga_add(void) {} #endif
int arch_cpu_init(void) @@ -361,173 +134,3 @@ int arch_cpu_init(void)
return 0; } - -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -/* - * Convert all NIC-301 AMBA slaves from secure to non-secure - */ -static void socfpga_nic301_slave_ns(void) -{ - writel(0x1, &nic301_regs->lwhps2fpgaregs); - writel(0x1, &nic301_regs->hps2fpgaregs); - writel(0x1, &nic301_regs->acp); - writel(0x1, &nic301_regs->rom); - writel(0x1, &nic301_regs->ocram); - writel(0x1, &nic301_regs->sdrdata); -} - -static uint32_t iswgrp_handoff[8]; - -int arch_early_init_r(void) -{ - int i; - - /* - * Write magic value into magic register to unlock support for - * issuing warm reset. The ancient kernel code expects this - * value to be written into the register by the bootloader, so - * to support that old code, we write it here instead of in the - * reset_cpu() function just before resetting the CPU. - */ - writel(0xae9efebc, &sysmgr_regs->romcodegrp_warmramgrp_enable); - - for (i = 0; i < 8; i++) /* Cache initial SW setting regs */ - iswgrp_handoff[i] = readl(&sysmgr_regs->iswgrp_handoff[i]); - - socfpga_bridges_reset(1); - socfpga_nic301_slave_ns(); - - /* - * Private components security: - * U-Boot : configure private timer, global timer and cpu component - * access as non secure for kernel stage (as required by Linux) - */ - setbits_le32(&scu_regs->sacr, 0xfff); - - /* Configure the L2 controller to make SDRAM start at 0 */ -#ifdef CONFIG_SOCFPGA_VIRTUAL_TARGET - writel(0x2, &nic301_regs->remap); -#else - writel(0x1, &nic301_regs->remap); /* remap.mpuzero */ - writel(0x1, &pl310->pl310_addr_filter_start); -#endif - - /* Add device descriptor to FPGA device table */ - socfpga_fpga_add(); - -#ifdef CONFIG_DESIGNWARE_SPI - /* Get Designware SPI controller out of reset */ - socfpga_per_reset(SOCFPGA_RESET(SPIM0), 0); - socfpga_per_reset(SOCFPGA_RESET(SPIM1), 0); -#endif - -#ifdef CONFIG_NAND_DENALI - socfpga_per_reset(SOCFPGA_RESET(NAND), 0); -#endif - - return 0; -} - -static void socfpga_sdram_apply_static_cfg(void) -{ - const uint32_t staticcfg = SOCFPGA_SDR_ADDRESS + 0x505c; - const uint32_t applymask = 0x8; - uint32_t val = readl(staticcfg) | applymask; - - /* - * SDRAM staticcfg register specific: - * When applying the register setting, the CPU must not access - * SDRAM. Luckily for us, we can abuse i-cache here to help us - * circumvent the SDRAM access issue. The idea is to make sure - * that the code is in one full i-cache line by branching past - * it and back. Once it is in the i-cache, we execute the core - * of the code and apply the register settings. - * - * The code below uses 7 instructions, while the Cortex-A9 has - * 32-byte cachelines, thus the limit is 8 instructions total. - */ - asm volatile( - ".align 5 \n" - " b 2f \n" - "1: str %0, [%1] \n" - " dsb \n" - " isb \n" - " b 3f \n" - "2: b 1b \n" - "3: nop \n" - : : "r"(val), "r"(staticcfg) : "memory", "cc"); -} - -int do_bridge(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - if (argc != 2) - return CMD_RET_USAGE; - - argv++; - - switch (*argv[0]) { - case 'e': /* Enable */ - writel(iswgrp_handoff[2], &sysmgr_regs->fpgaintfgrp_module); - socfpga_sdram_apply_static_cfg(); - writel(iswgrp_handoff[3], SOCFPGA_SDR_ADDRESS + 0x5080); - writel(iswgrp_handoff[0], &reset_manager_base->brg_mod_reset); - writel(iswgrp_handoff[1], &nic301_regs->remap); - break; - case 'd': /* Disable */ - writel(0, &sysmgr_regs->fpgaintfgrp_module); - writel(0, SOCFPGA_SDR_ADDRESS + 0x5080); - socfpga_sdram_apply_static_cfg(); - writel(0, &reset_manager_base->brg_mod_reset); - writel(1, &nic301_regs->remap); - break; - default: - return CMD_RET_USAGE; - } - - return 0; -} -#else -/* -+ * This function initializes security policies to be consistent across -+ * all logic units in the Arria 10. -+ * -+ * The idea is to set all security policies to be normal, nonsecure -+ * for all units. -+ */ -static void initialize_security_policies(void) -{ - /* Put OCRAM in non-secure */ - writel(0x003f0000, &noc_fw_ocram_base->region0); - writel(0x1, &noc_fw_ocram_base->enable); - - /* Put DDR in non-secure */ - writel(0xffff0000, &noc_fw_ddr_l3_base->hpsregion0addr); - writel(0x1, &noc_fw_ddr_l3_base->enable); -} - -int arch_early_init_r(void) -{ - initialize_security_policies(); - - /* Configure the L2 controller to make SDRAM start at 0 */ - writel(0x1, &pl310->pl310_addr_filter_start); - - /* assert reset to all except L4WD0 and L4TIMER0 */ - socfpga_per_reset_all(); - - /* configuring the clock based on handoff */ - /* TODO: Add call to cm_basic_init() */ - - /* Add device descriptor to FPGA device table */ - socfpga_fpga_add(); - return 0; -} -#endif - -U_BOOT_CMD( - bridge, 2, 1, do_bridge, - "SoCFPGA HPS FPGA bridge control", - "enable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" - "bridge disable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" - "" -); diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach-socfpga/misc_arria10.c new file mode 100644 index 0000000..6c50515 --- /dev/null +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -0,0 +1,255 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <altera.h> +#include <miiphy.h> +#include <netdev.h> +#include <watchdog.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/sdram_a10.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/nic301.h> +#include <asm/pl310.h> +#include <fdtdec.h> +#include <ns16550.h> + +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q1_3 0x08 +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q2_11 0x58 +#define PINMUX_UART0_TX_SHARED_IO_OFFSET_Q3_3 0x68 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q1_7 0x18 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q3_7 0x78 +#define PINMUX_UART1_TX_SHARED_IO_OFFSET_Q4_3 0x98 + +DECLARE_GLOBAL_DATA_PTR; + +static int find_peripheral_uart(const void *blob, + int child, const char *node_name); +static int is_peripheral_uart_true(const void *blob, + int node, const char *child_name); + +static struct pl310_regs *const pl310 = + (struct pl310_regs *)CONFIG_SYS_PL310_BASE; +static struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; +static const struct socfpga_noc_fw_ocram *noc_fw_ocram_base = + (void *)SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS; +static const struct socfpga_noc_fw_ddr_l3 *noc_fw_ddr_l3_base = + (void *)SOCFPGA_SDR_FIREWALL_L3_ADDRESS; + +/* + * DesignWare Ethernet initialization + */ +#ifdef CONFIG_ETH_DESIGNWARE +void dwmac_deassert_reset(const unsigned int of_reset_id, + const u32 phymode) +{ + u32 reset; + + if (of_reset_id == EMAC0_RESET) { + reset = SOCFPGA_RESET(EMAC0); + } else if (of_reset_id == EMAC1_RESET) { + reset = SOCFPGA_RESET(EMAC1); + } else if (of_reset_id == EMAC2_RESET) { + reset = SOCFPGA_RESET(EMAC2); + } else { + printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); + return; + } + + clrsetbits_le32(&sysmgr_regs->emac[of_reset_id - EMAC0_RESET], + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, + phymode); + + /* Release the EMAC controller from reset */ + socfpga_per_reset(reset, 0); +} +#endif + +/* ++ * This function initializes security policies to be consistent across ++ * all logic units in the Arria 10. ++ * ++ * The idea is to set all security policies to be normal, nonsecure ++ * for all units. ++ */ +static void initialize_security_policies(void) +{ + /* Put OCRAM in non-secure */ + writel(0x003f0000, &noc_fw_ocram_base->region0); + writel(0x1, &noc_fw_ocram_base->enable); + + /* Put DDR in non-secure */ + writel(0xffff0000, &noc_fw_ddr_l3_base->hpsregion0addr); + writel(0x1, &noc_fw_ddr_l3_base->enable); +} + +int arch_early_init_r(void) +{ + initialize_security_policies(); + + /* Configure the L2 controller to make SDRAM start at 0 */ + writel(0x1, &pl310->pl310_addr_filter_start); + + /* assert reset to all except L4WD0 and L4TIMER0 */ + socfpga_per_reset_all(); + + /* configuring the clock based on handoff */ + /* TODO: Add call to cm_basic_init() */ + + /* Add device descriptor to FPGA device table */ + socfpga_fpga_add(); + return 0; +} + +/* + * This function looking the 1st encounter UART peripheral, + * and then return its offset of the dedicated/shared IO pin + * mux. offset value (zero and above). + */ +static int find_peripheral_uart(const void *blob, + int child, const char *node_name) +{ + int len; + fdt_addr_t base_addr = 0; + fdt_size_t size; + const u32 *cell; + u32 value, offset = 0; + + base_addr = fdtdec_get_addr_size(blob, child, "reg", &size); + if (base_addr != FDT_ADDR_T_NONE) { + cell = fdt_getprop(blob, child, "pinctrl-single,pins", + &len); + if (cell != NULL) { + for (; len > 0; len -= (2 * sizeof(u32))) { + offset = fdt32_to_cpu(*cell++); + value = fdt32_to_cpu(*cell++); + /* Found UART peripheral */ + if (0x0D == value) + return offset; + } + } + } + return -1; +} + +/* + * This function looking the 1st encounter UART peripheral, + * and then return its offset of the dedicated/shared IO pin + * mux. UART peripheral is found if the offset is not in negative + * value. + */ +static int is_peripheral_uart_true(const void *blob, + int node, const char *child_name) +{ + int child, len; + const char *node_name; + + child = fdt_first_subnode(blob, node); + + if (child < 0) + return -1; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(child_name, node_name)) + return find_peripheral_uart(blob, child, node_name); + + child = fdt_next_subnode(blob, child); + + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return -1; +} + +/* + * This function looking the 1st encounter UART dedicated IO peripheral, + * and then return based address of the 1st encounter UART dedicated + * IO peripheral. + */ +unsigned int dedicated_uart_com_port(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + + if (node < 0) + return 0; + + if (0 <= is_peripheral_uart_true(blob, node, "dedicated")) + return SOCFPGA_UART1_ADDRESS; + else + return 0; +} + +/* + * This function looking the 1st encounter UART shared IO peripheral, and then + * return based address of the 1st encounter UART shared IO peripheral. + */ +unsigned int shared_uart_com_port(const void *blob) +{ + int node, ret; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + + if (node < 0) + return 0; + + ret = is_peripheral_uart_true(blob, node, "shared"); + + if (PINMUX_UART0_TX_SHARED_IO_OFFSET_Q1_3 == ret || + PINMUX_UART0_TX_SHARED_IO_OFFSET_Q2_11 == ret || + PINMUX_UART0_TX_SHARED_IO_OFFSET_Q3_3 == ret) + return SOCFPGA_UART0_ADDRESS; + else if (PINMUX_UART1_TX_SHARED_IO_OFFSET_Q1_7 == ret || + PINMUX_UART1_TX_SHARED_IO_OFFSET_Q3_7 == ret || + PINMUX_UART1_TX_SHARED_IO_OFFSET_Q4_3 == ret) + return SOCFPGA_UART1_ADDRESS; + else + return 0; +} + +/* + * This function looking the 1st encounter UART peripheral, and then return + * base address of the 1st encounter UART peripheral. + */ +unsigned int uart_com_port(const void *blob) +{ + unsigned int ret; + + ret = dedicated_uart_com_port(blob); + + if (ret) + return ret; + + return shared_uart_com_port(blob); +} + +/* + * Print CPU information + */ +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> + SYSMGR_BOOTINFO_BSEL_SHIFT) & 0x7; + + puts("CPU: Altera SoCFPGA Arria 10\n"); + + printf("BOOT: %s\n", bsel_str[bsel].name); + return 0; +} +#endif diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc_gen5.c similarity index 66% copy from arch/arm/mach-socfpga/misc.c copy to arch/arm/mach-socfpga/misc_gen5.c index 510aa1d..b91aeb1 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -1,7 +1,7 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2016, Intel Corporation * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0 */
#include <common.h> @@ -13,6 +13,7 @@ #include <miiphy.h> #include <netdev.h> #include <watchdog.h> +#include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/scan_manager.h> #include <asm/arch/sdram_a10.h> @@ -20,12 +21,7 @@ #include <asm/arch/nic301.h> #include <asm/arch/scu.h> #include <asm/pl310.h> - -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <dt-bindings/reset/altr,rst-mgr.h> -#else -#include <dt-bindings/reset/altr,rst-mgr-a10.h> -#endif
@@ -35,94 +31,47 @@ static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; static struct socfpga_reset_manager *reset_manager_base = (struct socfpga_reset_manager *)SOCFPGA_RSTMGR_ADDRESS; -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -#else -static const struct socfpga_noc_fw_ocram *noc_fw_ocram_base = - (void *)SOCFPGA_SDR_FIREWALL_OCRAM_ADDRESS; -static const struct socfpga_noc_fw_ddr_l3 *noc_fw_ddr_l3_base = - (void *)SOCFPGA_SDR_FIREWALL_L3_ADDRESS; -#endif static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS;
-int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); - return 0; -} - -void enable_caches(void) -{ -#ifndef CONFIG_SYS_ICACHE_OFF - icache_enable(); -#endif -#ifndef CONFIG_SYS_DCACHE_OFF - dcache_enable(); -#endif -} - -void v7_outer_cache_enable(void) -{ - /* Disable the L2 cache */ - clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); - - /* enable BRESP, instruction and data prefetch, full line of zeroes */ - setbits_le32(&pl310->pl310_aux_ctrl, - L310_AUX_CTRL_DATA_PREFETCH_MASK | - L310_AUX_CTRL_INST_PREFETCH_MASK | - L310_SHARED_ATT_OVERRIDE_ENABLE); - - /* Enable the L2 cache */ - setbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); -} - -void v7_outer_cache_disable(void) -{ - /* Disable the L2 cache */ - clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); -} - /* * DesignWare Ethernet initialization */ #ifdef CONFIG_ETH_DESIGNWARE -static void dwmac_deassert_reset(const unsigned int of_reset_id, +void dwmac_deassert_reset(const unsigned int of_reset_id, const u32 phymode) { - u32 physhift, reset; + u32 physhift; + u32 reset;
if (of_reset_id == EMAC0_RESET) { physhift = SYSMGR_EMACGRP_CTRL_PHYSEL0_LSB; + reset = SOCFPGA_RESET(EMAC0); } else if (of_reset_id == EMAC1_RESET) { physhift = SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB; + reset = SOCFPGA_RESET(EMAC1); -#ifndef CONFIG_TARGET_SOCFPGA_GEN5 - } else if (of_reset_id == EMAC2_RESET) { - reset = SOCFPGA_RESET(EMAC2); -#endif - } else { + } + else { printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); return; }
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* configure to PHY interface select choosed */ clrsetbits_le32(&sysmgr_regs->emacgrp_ctrl, SYSMGR_EMACGRP_CTRL_PHYSEL_MASK << physhift, phymode << physhift); -#else - clrsetbits_le32(&sysmgr_regs->emac[of_reset_id - EMAC0_RESET], - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, - phymode); -#endif
/* Release the EMAC controller from reset */ socfpga_per_reset(reset, 0); }
+/* + * DesignWare Ethernet initialization + */ static u32 dwmac_phymode_to_modereg(const char *phymode, u32 *modereg) { if (!phymode) @@ -195,20 +144,6 @@ static int socfpga_eth_reset(void) }; #endif
-struct { - const char *mode; - const char *name; -} bsel_str[] = { - { "rsvd", "Reserved", }, - { "fpga", "FPGA (HPS2FPGA Bridge)", }, - { "nand", "NAND Flash (1.8V)", }, - { "nand", "NAND Flash (3.0V)", }, - { "sd", "SD/MMC External Transceiver (1.8V)", }, - { "sd", "SD/MMC Internal Transceiver (3.0V)", }, - { "qspi", "QSPI Flash (1.8V)", }, - { "qspi", "QSPI Flash (3.0V)", }, -}; - static const struct { const u16 pn; const char *name; @@ -266,25 +201,6 @@ static int socfpga_fpga_id(const bool print_id) return i; }
-/* - * Print CPU information - */ -#if defined(CONFIG_DISPLAY_CPUINFO) -int print_cpuinfo(void) -{ - const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> - SYSMGR_BOOTINFO_BSEL_SHIFT) & 0x7; -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) - puts("CPU: Altera SoCFPGA Platform\n"); - socfpga_fpga_id(1); -#else - puts("CPU: Altera SoCFPGA Arria 10\n"); -#endif - printf("BOOT: %s\n", bsel_str[bsel].name); - return 0; -} -#endif - #ifdef CONFIG_ARCH_MISC_INIT int arch_misc_init(void) { @@ -297,72 +213,6 @@ int arch_misc_init(void) } #endif
-#if defined(CONFIG_SYS_CONSOLE_IS_IN_ENV) && \ -defined(CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE) -int overwrite_console(void) -{ - return 0; -} -#endif - -#ifdef CONFIG_FPGA -/* - * FPGA programming support for SoC FPGA Cyclone V - */ -static Altera_desc altera_fpga[] = { - { - /* Family */ - Altera_SoCFPGA, - /* Interface type */ - fast_passive_parallel, - /* No limitation as additional data will be ignored */ - -1, - /* No device function table */ - NULL, - /* Base interface address specified in driver */ - NULL, - /* No cookie implementation */ - 0 - }, -}; - -/* add device descriptor to FPGA device table */ -static void socfpga_fpga_add(void) -{ - int i; - fpga_init(); - for (i = 0; i < ARRAY_SIZE(altera_fpga); i++) - fpga_add(fpga_altera, &altera_fpga[i]); -} -#else -static inline void socfpga_fpga_add(void) {} -#endif - -int arch_cpu_init(void) -{ -#ifdef CONFIG_HW_WATCHDOG - /* - * In case the watchdog is enabled, make sure to (re-)configure it - * so that the defined timeout is valid. Otherwise the SPL (Perloader) - * timeout value is still active which might too short for Linux - * booting. - */ - hw_watchdog_init(); -#else - /* - * If the HW watchdog is NOT enabled, make sure it is not running, - * for example because it was enabled in the preloader. This might - * trigger a watchdog-triggered reboot of Linux kernel later. - * Toggle watchdog reset, so watchdog in not running state. - */ - socfpga_per_reset(SOCFPGA_RESET(L4WD0), 1); - socfpga_per_reset(SOCFPGA_RESET(L4WD0), 0); -#endif - - return 0; -} - -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* * Convert all NIC-301 AMBA slaves from secure to non-secure */ @@ -387,7 +237,7 @@ int arch_early_init_r(void) * issuing warm reset. The ancient kernel code expects this * value to be written into the register by the bootloader, so * to support that old code, we write it here instead of in the - * reset_cpu() function just before resetting the CPU. + * reset_cpu() function just before reseting the CPU. */ writel(0xae9efebc, &sysmgr_regs->romcodegrp_warmramgrp_enable);
@@ -486,43 +336,6 @@ int do_bridge(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return 0; } -#else -/* -+ * This function initializes security policies to be consistent across -+ * all logic units in the Arria 10. -+ * -+ * The idea is to set all security policies to be normal, nonsecure -+ * for all units. -+ */ -static void initialize_security_policies(void) -{ - /* Put OCRAM in non-secure */ - writel(0x003f0000, &noc_fw_ocram_base->region0); - writel(0x1, &noc_fw_ocram_base->enable); - - /* Put DDR in non-secure */ - writel(0xffff0000, &noc_fw_ddr_l3_base->hpsregion0addr); - writel(0x1, &noc_fw_ddr_l3_base->enable); -} - -int arch_early_init_r(void) -{ - initialize_security_policies(); - - /* Configure the L2 controller to make SDRAM start at 0 */ - writel(0x1, &pl310->pl310_addr_filter_start); - - /* assert reset to all except L4WD0 and L4TIMER0 */ - socfpga_per_reset_all(); - - /* configuring the clock based on handoff */ - /* TODO: Add call to cm_basic_init() */ - - /* Add device descriptor to FPGA device table */ - socfpga_fpga_add(); - return 0; -} -#endif
U_BOOT_CMD( bridge, 2, 1, do_bridge, @@ -531,3 +344,20 @@ U_BOOT_CMD( "bridge disable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" "" ); + +/* + * Print CPU information + */ +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + const u32 bsel = (readl(&sysmgr_regs->bootinfo) >> + SYSMGR_BOOTINFO_BSEL_SHIFT) & 0x7; + + puts("CPU: Altera SoCFPGA Platform\n"); + socfpga_fpga_id(1); + + printf("BOOT: %s\n", bsel_str[bsel].name); + return 0; +} +#endif
The drivers is restructured such common functions, gen5 functions, and arria10 functions are moved to clock_manager.c, clock_manager_gen5 and clock_manager_arria10 respectively.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dingnuyen@kernel.org Cc: Ching Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/clock_manager.c | 752 +++++++--------- arch/arm/mach-socfpga/clock_manager_arria10.c | 954 ++++++++++++++++++++ .../{clock_manager.c => clock_manager_gen5.c} | 240 +----- arch/arm/mach-socfpga/include/mach/clock_manager.h | 356 ++++++-- 4 files changed, 1573 insertions(+), 729 deletions(-) create mode 100644 arch/arm/mach-socfpga/clock_manager_arria10.c copy arch/arm/mach-socfpga/{clock_manager.c => clock_manager_gen5.c} (62%)
diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index aa71636..d209f7d 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -7,416 +7,287 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/clock_manager.h> +#include <fdtdec.h>
+/* Function prototypes */ +/* Common prototypes */ +unsigned int cm_get_l4_sp_clk_hz(void); +unsigned int cm_get_qspi_controller_clk_hz(void); +unsigned int cm_get_mmc_controller_clk_hz(void); +unsigned int cm_get_spi_controller_clk_hz(void); +static void cm_print_clock_quick_summary(void); +int do_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +void cm_wait_for_lock(uint32_t mask); +void cm_wait_for_fsm(void); +unsigned int cm_get_main_vco_clk_hz(void); +unsigned int cm_get_per_vco_clk_hz(void); +unsigned long cm_get_mpu_clk_hz(void); + static const struct socfpga_clock_manager *clock_manager_base = (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS;
-static void cm_wait_for_lock(uint32_t mask) +/* Common functions */ +int set_cpu_clk_info(void) { - register uint32_t inter_val; - uint32_t retry = 0; - do { - inter_val = readl(&clock_manager_base->inter) & mask; - if (inter_val == mask) - retry++; - else - retry = 0; - if (retry >= 10) - break; - } while (1); -} + /* Calculate the clock frequencies required for drivers */ + cm_get_l4_sp_clk_hz(); + cm_get_mmc_controller_clk_hz();
-/* function to poll in the fsm busy bit */ -static void cm_wait_for_fsm(void) -{ - while (readl(&clock_manager_base->stat) & CLKMGR_STAT_BUSY) - ; -} + gd->bd->bi_arm_freq = cm_get_mpu_clk_hz() / 1000000; + gd->bd->bi_dsp_freq = 0;
-/* - * function to write the bypass register which requires a poll of the - * busy bit - */ -static void cm_write_bypass(uint32_t val) -{ - writel(val, &clock_manager_base->bypass); - cm_wait_for_fsm(); -} +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + gd->bd->bi_ddr_freq = cm_get_sdram_clk_hz() / 1000000; +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + gd->bd->bi_ddr_freq = 0; +#endif
-/* function to write the ctrl register which requires a poll of the busy bit */ -static void cm_write_ctrl(uint32_t val) -{ - writel(val, &clock_manager_base->ctrl); - cm_wait_for_fsm(); + return 0; }
-/* function to write a clock register that has phase information */ -static void cm_write_with_phase(uint32_t value, - uint32_t reg_address, uint32_t mask) +unsigned int cm_get_spi_controller_clk_hz(void) { - /* poll until phase is zero */ - while (readl(reg_address) & mask) - ; + uint32_t clock = 0;
- writel(value, reg_address); +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + uint32_t reg; + clock = cm_get_per_vco_clk_hz();
- while (readl(reg_address) & mask) - ; -} + /* get the clock prior L4 SP divider (periph_base_clk) */ + reg = readl(&clock_manager_base->per_pll.perbaseclk); + clock /= (reg + 1); +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + clock = cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB); +#endif
-/* - * Setup clocks while making no assumptions about previous state of the clocks. - * - * Start by being paranoid and gate all sw managed clocks - * Put all plls in bypass - * Put all plls VCO registers back to reset value (bandgap power down). - * Put peripheral and main pll src to reset value to avoid glitch. - * Delay 5 us. - * Deassert bandgap power down and set numerator and denominator - * Start 7 us timer. - * set internal dividers - * Wait for 7 us timer. - * Enable plls - * Set external dividers while plls are locking - * Wait for pll lock - * Assert/deassert outreset all. - * Take all pll's out of bypass - * Clear safe mode - * set source main and peripheral clocks - * Ungate clocks - */ + return clock; +}
-void cm_basic_init(const struct cm_config * const cfg) +unsigned int cm_get_qspi_controller_clk_hz(void) { - unsigned long end; - - /* Start by being paranoid and gate all sw managed clocks */ - - /* - * We need to disable nandclk - * and then do another apb access before disabling - * gatting off the rest of the periperal clocks. - */ - writel(~CLKMGR_PERPLLGRP_EN_NANDCLK_MASK & - readl(&clock_manager_base->per_pll.en), - &clock_manager_base->per_pll.en); - - /* DO NOT GATE OFF DEBUG CLOCKS & BRIDGE CLOCKS */ - writel(CLKMGR_MAINPLLGRP_EN_DBGTIMERCLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGTRACECLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGCLK_MASK | - CLKMGR_MAINPLLGRP_EN_DBGATCLK_MASK | - CLKMGR_MAINPLLGRP_EN_S2FUSER0CLK_MASK | - CLKMGR_MAINPLLGRP_EN_L4MPCLK_MASK, - &clock_manager_base->main_pll.en); - - writel(0, &clock_manager_base->sdr_pll.en); - - /* now we can gate off the rest of the peripheral clocks */ - writel(0, &clock_manager_base->per_pll.en); - - /* Put all plls in bypass */ - cm_write_bypass(CLKMGR_BYPASS_PERPLL | CLKMGR_BYPASS_SDRPLL | - CLKMGR_BYPASS_MAINPLL); - - /* Put all plls VCO registers back to reset value. */ - writel(CLKMGR_MAINPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_MAINPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->main_pll.vco); - writel(CLKMGR_PERPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_PERPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->per_pll.vco); - writel(CLKMGR_SDRPLLGRP_VCO_RESET_VALUE & - ~CLKMGR_SDRPLLGRP_VCO_REGEXTSEL_MASK, - &clock_manager_base->sdr_pll.vco); - - /* - * The clocks to the flash devices and the L4_MAIN clocks can - * glitch when coming out of safe mode if their source values - * are different from their reset value. So the trick it to - * put them back to their reset state, and change input - * after exiting safe mode but before ungating the clocks. - */ - writel(CLKMGR_PERPLLGRP_SRC_RESET_VALUE, - &clock_manager_base->per_pll.src); - writel(CLKMGR_MAINPLLGRP_L4SRC_RESET_VALUE, - &clock_manager_base->main_pll.l4src); - - /* read back for the required 5 us delay. */ - readl(&clock_manager_base->main_pll.vco); - readl(&clock_manager_base->per_pll.vco); - readl(&clock_manager_base->sdr_pll.vco); - - - /* - * We made sure bgpwr down was assert for 5 us. Now deassert BG PWR DN - * with numerator and denominator. - */ - writel(cfg->main_vco_base, &clock_manager_base->main_pll.vco); - writel(cfg->peri_vco_base, &clock_manager_base->per_pll.vco); - writel(cfg->sdram_vco_base, &clock_manager_base->sdr_pll.vco); - - /* - * Time starts here. Must wait 7 us from - * BGPWRDN_SET(0) to VCO_ENABLE_SET(1). - */ - end = timer_get_us() + 7; - - /* main mpu */ - writel(cfg->mpuclk, &clock_manager_base->main_pll.mpuclk); - - /* main main clock */ - writel(cfg->mainclk, &clock_manager_base->main_pll.mainclk); - - /* main for dbg */ - writel(cfg->dbgatclk, &clock_manager_base->main_pll.dbgatclk); - - /* main for cfgs2fuser0clk */ - writel(cfg->cfg2fuser0clk, - &clock_manager_base->main_pll.cfgs2fuser0clk); - - /* Peri emac0 50 MHz default to RMII */ - writel(cfg->emac0clk, &clock_manager_base->per_pll.emac0clk); - - /* Peri emac1 50 MHz default to RMII */ - writel(cfg->emac1clk, &clock_manager_base->per_pll.emac1clk); - - /* Peri QSPI */ - writel(cfg->mainqspiclk, &clock_manager_base->main_pll.mainqspiclk); - - writel(cfg->perqspiclk, &clock_manager_base->per_pll.perqspiclk); - - /* Peri pernandsdmmcclk */ - writel(cfg->mainnandsdmmcclk, - &clock_manager_base->main_pll.mainnandsdmmcclk); - - writel(cfg->pernandsdmmcclk, - &clock_manager_base->per_pll.pernandsdmmcclk); - - /* Peri perbaseclk */ - writel(cfg->perbaseclk, &clock_manager_base->per_pll.perbaseclk); - - /* Peri s2fuser1clk */ - writel(cfg->s2fuser1clk, &clock_manager_base->per_pll.s2fuser1clk); - - /* 7 us must have elapsed before we can enable the VCO */ - while (timer_get_us() < end) - ; - - /* Enable vco */ - /* main pll vco */ - writel(cfg->main_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->main_pll.vco); + uint32_t clock = 0;
- /* periferal pll */ - writel(cfg->peri_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->per_pll.vco); - - /* sdram pll vco */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->sdr_pll.vco); - - /* L3 MP and L3 SP */ - writel(cfg->maindiv, &clock_manager_base->main_pll.maindiv); - - writel(cfg->dbgdiv, &clock_manager_base->main_pll.dbgdiv); - - writel(cfg->tracediv, &clock_manager_base->main_pll.tracediv); - - /* L4 MP, L4 SP, can0, and can1 */ - writel(cfg->perdiv, &clock_manager_base->per_pll.div); - - writel(cfg->gpiodiv, &clock_manager_base->per_pll.gpiodiv); - -#define LOCKED_MASK \ - (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ - CLKMGR_INTER_PERPLLLOCKED_MASK | \ - CLKMGR_INTER_MAINPLLLOCKED_MASK) - - cm_wait_for_lock(LOCKED_MASK); - - /* write the sdram clock counters before toggling outreset all */ - writel(cfg->ddrdqsclk & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddrdqsclk); +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + uint32_t reg; + /* identify the source of QSPI clock */ + reg = readl(&clock_manager_base->per_pll.src); + reg = (reg & CLKMGR_PERPLLGRP_SRC_QSPI_MASK) >> + CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET;
- writel(cfg->ddr2xdqsclk & CLKMGR_SDRPLLGRP_DDR2XDQSCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddr2xdqsclk); + if (reg == CLKMGR_QSPI_CLK_SRC_F2S) { + clock = cm_get_f2s_per_ref_clk_hz(); + } else if (reg == CLKMGR_QSPI_CLK_SRC_MAIN) { + clock = cm_get_main_vco_clk_hz();
- writel(cfg->ddrdqclk & CLKMGR_SDRPLLGRP_DDRDQCLK_CNT_MASK, - &clock_manager_base->sdr_pll.ddrdqclk); + /* get the qspi clock */ + reg = readl(&clock_manager_base->main_pll.mainqspiclk); + clock /= (reg + 1); + } else if (reg == CLKMGR_QSPI_CLK_SRC_PER) { + clock = cm_get_per_vco_clk_hz();
- writel(cfg->s2fuser2clk & CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK, - &clock_manager_base->sdr_pll.s2fuser2clk); + /* get the qspi clock */ + reg = readl(&clock_manager_base->per_pll.perqspiclk); + clock /= (reg + 1); + } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + clock = cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB); +#endif
- /* - * after locking, but before taking out of bypass - * assert/deassert outresetall - */ - uint32_t mainvco = readl(&clock_manager_base->main_pll.vco); + return clock; +}
- /* assert main outresetall */ - writel(mainvco | CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll.vco); +void cm_wait_for_lock(uint32_t mask) +{ + register uint32_t inter_val; + uint32_t retry = 0; + do { +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + inter_val = readl(&clock_manager_base->stat) & mask; +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) + inter_val = readl(&clock_manager_base->inter) & mask; +#endif + /* Wait for stable lock */ + if (inter_val == mask) + retry++; + else + retry = 0; + if (retry >= 10) + break; + } while (1); +}
- uint32_t periphvco = readl(&clock_manager_base->per_pll.vco); +unsigned long cm_get_mpu_clk_hz(void) +{ + uint32_t reg, clk_hz; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + clk_hz = cm_get_main_vco_clk_hz();
- /* assert pheriph outresetall */ - writel(periphvco | CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll.vco); + /* get the MPU clock */ + reg = readl(&clock_manager_base->altera.mpuclk); + clk_hz /= (reg + 1); + reg = readl(&clock_manager_base->main_pll.mpuclk); + clk_hz /= (reg + 1); +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + uint32_t clk_src, mainmpuclk_reg;
- /* assert sdram outresetall */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN| - CLKMGR_SDRPLLGRP_VCO_OUTRESETALL, - &clock_manager_base->sdr_pll.vco); + mainmpuclk_reg = readl(&clock_manager_base->main_pll.mpuclk);
- /* deassert main outresetall */ - writel(mainvco & ~CLKMGR_MAINPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->main_pll.vco); + clk_src = (mainmpuclk_reg >> CLKMGR_MAINPLL_MPUCLK_SRC_LSB) & + CLKMGR_MAINPLL_MPUCLK_SRC_MSK;
- /* deassert pheriph outresetall */ - writel(periphvco & ~CLKMGR_PERPLLGRP_VCO_OUTRESETALL_MASK, - &clock_manager_base->per_pll.vco); + reg = readl(&clock_manager_base->altera.mpuclk); + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (clk_src) { + case CLKMGR_MAINPLL_MPUCLK_SRC_MAIN: + clk_hz = cm_get_main_vco_clk_hz(); + clk_hz /= ((reg & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_PERI: + clk_hz = cm_get_per_vco_clk_hz(); + clk_hz /= (((reg >> CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + printf("cm_get_mpu_clk_hz invalid clk_src %d\n", clk_src); + return 0; + }
- /* deassert sdram outresetall */ - writel(cfg->sdram_vco_base | CLKMGR_MAINPLLGRP_VCO_EN, - &clock_manager_base->sdr_pll.vco); + clk_hz /= ((mainmpuclk_reg & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1); +#endif
- /* - * now that we've toggled outreset all, all the clocks - * are aligned nicely; so we can change any phase. - */ - cm_write_with_phase(cfg->ddrdqsclk, - (uint32_t)&clock_manager_base->sdr_pll.ddrdqsclk, - CLKMGR_SDRPLLGRP_DDRDQSCLK_PHASE_MASK); + return clk_hz; +}
- /* SDRAM DDR2XDQSCLK */ - cm_write_with_phase(cfg->ddr2xdqsclk, - (uint32_t)&clock_manager_base->sdr_pll.ddr2xdqsclk, - CLKMGR_SDRPLLGRP_DDR2XDQSCLK_PHASE_MASK); +unsigned int cm_get_per_vco_clk_hz(void) +{ + uint32_t src_hz = 0; + uint32_t clk_src = 0; + uint32_t numer = 0; + uint32_t denom = 0; + uint32_t vco = 0;
- cm_write_with_phase(cfg->ddrdqclk, - (uint32_t)&clock_manager_base->sdr_pll.ddrdqclk, - CLKMGR_SDRPLLGRP_DDRDQCLK_PHASE_MASK); +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + /* identify PER PLL clock source */ + clk_src = readl(&clock_manager_base->per_pll.vco); + clk_src = (clk_src & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> + CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; + if (clk_src == CLKMGR_VCO_SSRC_EOSC1) + src_hz = cm_get_osc_clk_hz(1); + else if (clk_src == CLKMGR_VCO_SSRC_EOSC2) + src_hz = cm_get_osc_clk_hz(2); + else if (clk_src == CLKMGR_VCO_SSRC_F2S) + src_hz = cm_get_f2s_per_ref_clk_hz();
- cm_write_with_phase(cfg->s2fuser2clk, - (uint32_t)&clock_manager_base->sdr_pll.s2fuser2clk, - CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK); + /* get the PER VCO clock */ + vco = readl(&clock_manager_base->per_pll.vco); + + numer = (vco & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> + CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET; + + denom = (vco & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> + CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET; + +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + clk_src = readl(&clock_manager_base->per_pll.vco0); + + clk_src = (clk_src >> CLKMGR_PERPLL_VCO0_PSRC_LSB) & + CLKMGR_PERPLL_VCO0_PSRC_MSK; + + if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_EOSC) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_F2S) { + src_hz = f2s_free_hz; + } else if (clk_src == CLKMGR_PERPLL_VCO0_PSRC_MAIN) { + src_hz = cm_get_main_vco_clk_hz(); + src_hz /= (readl + (&clock_manager_base->main_pll.cntr15clk) & + CLKMGR_MAINPLL_CNTRCLK_MSK) + 1; + } else { + printf("cm_get_per_vco_clk_hz invalid clk_src %d\n", clk_src); + return 0; + }
- /* Take all three PLLs out of bypass when safe mode is cleared. */ - cm_write_bypass(0); + vco = readl(&clock_manager_base->per_pll.vco1);
- /* clear safe mode */ - cm_write_ctrl(readl(&clock_manager_base->ctrl) | CLKMGR_CTRL_SAFEMODE); + numer = vco & CLKMGR_PERPLL_VCO1_NUMER_MSK;
- /* - * now that safe mode is clear with clocks gated - * it safe to change the source mux for the flashes the the L4_MAIN - */ - writel(cfg->persrc, &clock_manager_base->per_pll.src); - writel(cfg->l4src, &clock_manager_base->main_pll.l4src); + denom = (vco >> CLKMGR_PERPLL_VCO1_DENOM_LSB) & + CLKMGR_PERPLL_VCO1_DENOM_MSK; +#endif
- /* Now ungate non-hw-managed clocks */ - writel(~0, &clock_manager_base->main_pll.en); - writel(~0, &clock_manager_base->per_pll.en); - writel(~0, &clock_manager_base->sdr_pll.en); + vco = src_hz; + vco /= (1 + denom); + vco *= (1 + numer);
- /* Clear the loss of lock bits (write 1 to clear) */ - writel(CLKMGR_INTER_SDRPLLLOST_MASK | CLKMGR_INTER_PERPLLLOST_MASK | - CLKMGR_INTER_MAINPLLLOST_MASK, - &clock_manager_base->inter); + return vco; }
-static unsigned int cm_get_main_vco_clk_hz(void) +unsigned int cm_get_main_vco_clk_hz(void) { - uint32_t reg, clock; + uint32_t src_hz, numer, denom, vco;
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* get the main VCO clock */ - reg = readl(&clock_manager_base->main_pll.vco); - clock = cm_get_osc_clk_hz(1); - clock /= ((reg & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET) + 1; - - return clock; -} - -static unsigned int cm_get_per_vco_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify PER PLL clock source */ - reg = readl(&clock_manager_base->per_pll.vco); - reg = (reg & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> - CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; - if (reg == CLKMGR_VCO_SSRC_EOSC1) - clock = cm_get_osc_clk_hz(1); - else if (reg == CLKMGR_VCO_SSRC_EOSC2) - clock = cm_get_osc_clk_hz(2); - else if (reg == CLKMGR_VCO_SSRC_F2S) - clock = cm_get_f2s_per_ref_clk_hz(); - - /* get the PER VCO clock */ - reg = readl(&clock_manager_base->per_pll.vco); - clock /= ((reg & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET) + 1; - - return clock; -} + vco = readl(&clock_manager_base->main_pll.vco); + + numer = ((vco & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >> + CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET); + denom = ((vco & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> + CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET); + + src_hz = cm_get_osc_clk_hz(1); +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + uint32_t clk_src = readl(&clock_manager_base->main_pll.vco0); + + clk_src = (clk_src >> CLKMGR_MAINPLL_VCO0_PSRC_LSB) & + CLKMGR_MAINPLL_VCO0_PSRC_MSK; + + if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_EOSC) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_MAINPLL_VCO0_PSRC_F2S) { + src_hz = f2s_free_hz; + } else { + printf("cm_get_main_vco_clk_hz invalid clk_src %d\n", clk_src); + return 0; + }
-unsigned long cm_get_mpu_clk_hz(void) -{ - uint32_t reg, clock; + vco = readl(&clock_manager_base->main_pll.vco1);
- clock = cm_get_main_vco_clk_hz(); + numer = vco & CLKMGR_MAINPLL_VCO1_NUMER_MSK;
- /* get the MPU clock */ - reg = readl(&clock_manager_base->altera.mpuclk); - clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mpuclk); - clock /= (reg + 1); - return clock; -} + denom = (vco >> CLKMGR_MAINPLL_VCO1_DENOM_LSB) & + CLKMGR_MAINPLL_VCO1_DENOM_MSK; +#endif
-unsigned long cm_get_sdram_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify SDRAM PLL clock source */ - reg = readl(&clock_manager_base->sdr_pll.vco); - reg = (reg & CLKMGR_SDRPLLGRP_VCO_SSRC_MASK) >> - CLKMGR_SDRPLLGRP_VCO_SSRC_OFFSET; - if (reg == CLKMGR_VCO_SSRC_EOSC1) - clock = cm_get_osc_clk_hz(1); - else if (reg == CLKMGR_VCO_SSRC_EOSC2) - clock = cm_get_osc_clk_hz(2); - else if (reg == CLKMGR_VCO_SSRC_F2S) - clock = cm_get_f2s_sdr_ref_clk_hz(); - - /* get the SDRAM VCO clock */ - reg = readl(&clock_manager_base->sdr_pll.vco); - clock /= ((reg & CLKMGR_SDRPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_SDRPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_SDRPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_SDRPLLGRP_VCO_NUMER_OFFSET) + 1; - - /* get the SDRAM (DDR_DQS) clock */ - reg = readl(&clock_manager_base->sdr_pll.ddrdqsclk); - reg = (reg & CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_MASK) >> - CLKMGR_SDRPLLGRP_DDRDQSCLK_CNT_OFFSET; - clock /= (reg + 1); + vco = src_hz; + vco /= (1 + denom); + vco *= (1 + numer);
- return clock; + return vco; }
unsigned int cm_get_l4_sp_clk_hz(void) { - uint32_t reg, clock = 0; + uint32_t clock = 0;
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + uint32_t reg; /* identify the source of L4 SP clock */ reg = readl(&clock_manager_base->main_pll.l4src); reg = (reg & CLKMGR_MAINPLLGRP_L4SRC_L4SP) >> @@ -443,106 +314,117 @@ unsigned int cm_get_l4_sp_clk_hz(void) reg = (reg & CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK) >> CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET; clock = clock / (1 << reg); - +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + clock = cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB); +#endif return clock; }
-unsigned int cm_get_mmc_controller_clk_hz(void) +/* function to poll in the fsm busy bit */ +void cm_wait_for_fsm(void) { - uint32_t reg, clock = 0; - - /* identify the source of MMC clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> - CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET; - - if (reg == CLKMGR_SDMMC_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); - - /* get the SDMMC clock */ - reg = readl(&clock_manager_base->main_pll.mainnandsdmmcclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); - - /* get the SDMMC clock */ - reg = readl(&clock_manager_base->per_pll.pernandsdmmcclk); - clock /= (reg + 1); - } - - /* further divide by 4 as we have fixed divider at wrapper */ - clock /= 4; - return clock; + while (readl(&clock_manager_base->stat) & + CLKMGR_CLKMGR_STAT_BUSY_SET_MSK); }
-unsigned int cm_get_qspi_controller_clk_hz(void) +unsigned int cm_get_mmc_controller_clk_hz(void) { - uint32_t reg, clock = 0; - - /* identify the source of QSPI clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_QSPI_MASK) >> - CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET; + uint32_t clk_hz = 0; + uint32_t clk_input = 0; + +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + clk_input = readl(&clock_manager_base->per_pll.cntr6clk); + clk_input = (clk_input >> CLKMGR_PERPLL_CNTR6CLK_SRC_LSB) & + CLKMGR_PERPLLGRP_SRC_MSK; +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) + clk_input = readl(&clock_manager_base->per_pll.src); + clk_input = (clk_input & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> + CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET; +#endif + + switch (clk_input) { +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + case CLKMGR_PERPLLGRP_SRC_MAIN: + clk_hz = cm_get_main_vco_clk_hz(); + clk_hz /= 1 + + (readl + (&clock_manager_base->main_pll.cntr6clk) & + CLKMGR_MAINPLL_CNTRCLK_MSK); + break; + + case CLKMGR_PERPLLGRP_SRC_PERI: + clk_hz = cm_get_per_vco_clk_hz(); + clk_hz /= 1 + (readl + (&clock_manager_base->per_pll.cntr6clk) & + CLKMGR_PERPLL_CNTRCLK_MSK); + break; + + case CLKMGR_PERPLLGRP_SRC_OSC1: + clk_hz = eosc1_hz; + break; + + case CLKMGR_PERPLLGRP_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + + case CLKMGR_PERPLLGRP_SRC_FPGA: + clk_hz = f2s_free_hz; + break; +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) + case CLKMGR_SDMMC_CLK_SRC_F2S: + clk_hz = cm_get_f2s_per_ref_clk_hz(); + break; + + case CLKMGR_SDMMC_CLK_SRC_MAIN: + clk_hz = cm_get_main_vco_clk_hz();
- if (reg == CLKMGR_QSPI_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_QSPI_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); + /* get the SDMMC clock */ + clk_input = + readl(&clock_manager_base->main_pll.mainnandsdmmcclk); + clk_hz /= (clk_input + 1); + break;
- /* get the qspi clock */ - reg = readl(&clock_manager_base->main_pll.mainqspiclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_QSPI_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); + case CLKMGR_SDMMC_CLK_SRC_PER: + clk_hz = cm_get_per_vco_clk_hz();
- /* get the qspi clock */ - reg = readl(&clock_manager_base->per_pll.perqspiclk); - clock /= (reg + 1); + /* get the SDMMC clock */ + clk_input = + readl(&clock_manager_base->per_pll.pernandsdmmcclk); + clk_hz /= (clk_input + 1); + break; +#endif } - - return clock; -} - -unsigned int cm_get_spi_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - clock = cm_get_per_vco_clk_hz(); - - /* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); - clock /= (reg + 1); - - return clock; + return clk_hz/4; }
static void cm_print_clock_quick_summary(void) { printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); + printf("MMC %8d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); + printf("QSPI %8d kHz\n", + cm_get_qspi_controller_clk_hz() / 1000); + printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + printf("EOSC1 %8d kHz\n", eosc1_hz / 1000); + printf("cb_intosc %8d kHz\n", cb_intosc_hz / 1000); + printf("f2s_free %8d kHz\n", f2s_free_hz / 1000); + printf("Main VCO %8d kHz\n", cm_get_main_vco_clk_hz()/1000); + printf("NOC %8d kHz\n", cm_get_noc_clk_hz()/1000); + printf("L4 Main %8d kHz\n", + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB)/1000); + printf("L4 MP %8d kHz\n", + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB)/1000); + printf("L4 SP %8d kHz\n", + cm_get_l4_sp_clk_hz()/1000); + printf("L4 sys free %8d kHz\n", cm_l4_sys_free_clk_hz/1000); +#elif defined(CONFIG_TARGET_SOCFPGA_GEN5) printf("DDR %10ld kHz\n", cm_get_sdram_clk_hz() / 1000); printf("EOSC1 %8d kHz\n", cm_get_osc_clk_hz(1) / 1000); printf("EOSC2 %8d kHz\n", cm_get_osc_clk_hz(2) / 1000); printf("F2S_SDR_REF %8d kHz\n", cm_get_f2s_sdr_ref_clk_hz() / 1000); printf("F2S_PER_REF %8d kHz\n", cm_get_f2s_per_ref_clk_hz() / 1000); - printf("MMC %8d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); - printf("QSPI %8d kHz\n", cm_get_qspi_controller_clk_hz() / 1000); printf("UART %8d kHz\n", cm_get_l4_sp_clk_hz() / 1000); - printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); -} - -int set_cpu_clk_info(void) -{ - /* Calculate the clock frequencies required for drivers */ - cm_get_l4_sp_clk_hz(); - cm_get_mmc_controller_clk_hz(); - - gd->bd->bi_arm_freq = cm_get_mpu_clk_hz() / 1000000; - gd->bd->bi_dsp_freq = 0; - gd->bd->bi_ddr_freq = cm_get_sdram_clk_hz() / 1000000; - - return 0; +#endif }
int do_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git a/arch/arm/mach-socfpga/clock_manager_arria10.c b/arch/arm/mach-socfpga/clock_manager_arria10.c new file mode 100644 index 0000000..93165b4 --- /dev/null +++ b/arch/arm/mach-socfpga/clock_manager_arria10.c @@ -0,0 +1,954 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock_manager.h> +#include <fdtdec.h> + +DECLARE_GLOBAL_DATA_PTR; + +int cm_basic_init(const void* blob); +uint32_t eosc1_hz; +uint32_t cb_intosc_hz; +uint32_t f2s_free_hz; +unsigned int cm_l4_main_clk_hz; +unsigned int cm_l4_sp_clk_hz; +unsigned int cm_l4_mp_clk_hz; +unsigned int cm_l4_sys_free_clk_hz; + +struct strtopu32 { + const char *str; + uint32_t *p; +}; + +struct mainpll_cfg { + uint32_t vco0_psrc; + uint32_t vco1_denom; + uint32_t vco1_numer; + uint32_t mpuclk; + uint32_t mpuclk_cnt; + uint32_t mpuclk_src; + uint32_t nocclk; + uint32_t nocclk_cnt; + uint32_t nocclk_src; + uint32_t cntr2clk_cnt; + uint32_t cntr3clk_cnt; + uint32_t cntr4clk_cnt; + uint32_t cntr5clk_cnt; + uint32_t cntr6clk_cnt; + uint32_t cntr7clk_cnt; + uint32_t cntr7clk_src; + uint32_t cntr8clk_cnt; + uint32_t cntr9clk_cnt; + uint32_t cntr9clk_src; + uint32_t cntr15clk_cnt; + uint32_t nocdiv_l4mainclk; + uint32_t nocdiv_l4mpclk; + uint32_t nocdiv_l4spclk; + uint32_t nocdiv_csatclk; + uint32_t nocdiv_cstraceclk; + uint32_t nocdiv_cspdbclk; +}; + +struct perpll_cfg { + uint32_t vco0_psrc; + uint32_t vco1_denom; + uint32_t vco1_numer; + uint32_t cntr2clk_cnt; + uint32_t cntr2clk_src; + uint32_t cntr3clk_cnt; + uint32_t cntr3clk_src; + uint32_t cntr4clk_cnt; + uint32_t cntr4clk_src; + uint32_t cntr5clk_cnt; + uint32_t cntr5clk_src; + uint32_t cntr6clk_cnt; + uint32_t cntr6clk_src; + uint32_t cntr7clk_cnt; + uint32_t cntr8clk_cnt; + uint32_t cntr8clk_src; + uint32_t cntr9clk_cnt; + uint32_t emacctl_emac0sel; + uint32_t emacctl_emac1sel; + uint32_t emacctl_emac2sel; + uint32_t gpiodiv_gpiodbclk; +}; + +struct alteragrp_cfg { + uint32_t nocclk; + uint32_t mpuclk; +}; + +unsigned int cm_get_noc_clk_hz(void); +unsigned int cm_get_l4_noc_hz(unsigned int nocdivshift); +static int of_to_struct(const void *blob, int node, int cfg__len, void *cfg); +static int of_get_input_clks(const void *blob, int node, void *cfg); +static int of_get_clk_cfg(const void *blob, struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, struct alteragrp_cfg *altrgrp_cfg); +static unsigned int cm_calc_handoff_main_vco_clk_hz( + struct mainpll_cfg *main_cfg); +static unsigned int cm_calc_handoff_periph_vco_clk_hz( + struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg); +static unsigned int cm_calc_handoff_mpu_clk_hz(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg); +static unsigned int cm_calc_handoff_noc_clk_hz(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg); +static int cm_is_pll_ramp_required(int main0periph1, + struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg); +static unsigned int cm_calc_safe_pll_numer(int main0periph1, + struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg, + unsigned int safe_hz); +static void cm_pll_ramp_main(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, unsigned int pll_ramp_main_hz); +static void cm_pll_ramp_periph(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, unsigned int pll_ramp_periph_hz); +static int cm_full_cfg(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg); + +static const struct socfpga_clock_manager *clock_manager_base = + (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; + +void cm_use_intosc(void) +{ + setbits_le32(&clock_manager_base->ctrl, + CLKMGR_CLKMGR_CTL_BOOTCLK_INTOSC_SET_MSK); +} + +unsigned int cm_get_noc_clk_hz(void) +{ + unsigned int clk_src, dividor, nocclk, src_hz; + + nocclk = readl(&clock_manager_base->main_pll.nocclk); + clk_src = (nocclk >> CLKMGR_MAINPLL_NOCCLK_SRC_LSB) & + CLKMGR_MAINPLL_NOCCLK_SRC_MSK; + + dividor = 1 + (nocclk & CLKMGR_MAINPLL_NOCDIV_MSK); + + if (clk_src == CLKMGR_PERPLLGRP_SRC_MAIN) { + src_hz = cm_get_main_vco_clk_hz(); + src_hz /= 1 + + (readl(SOCFPGA_CLKMGR_ADDRESS+CLKMGR_MAINPLL_NOC_CLK_OFFSET)& + CLKMGR_MAINPLL_NOCCLK_CNT_MSK); + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_PERI) { + src_hz = cm_get_per_vco_clk_hz(); + src_hz /= 1 + + ((readl(SOCFPGA_CLKMGR_ADDRESS+CLKMGR_MAINPLL_NOC_CLK_OFFSET)>> + CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB)& + CLKMGR_MAINPLL_NOCCLK_CNT_MSK); + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_OSC1) { + src_hz = eosc1_hz; + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_INTOSC) { + src_hz = cb_intosc_hz; + } else if (clk_src == CLKMGR_PERPLLGRP_SRC_FPGA) { + src_hz = f2s_free_hz; + } else { + src_hz = 0; + } + return src_hz/dividor; +} + +unsigned int cm_get_l4_noc_hz(unsigned int nocdivshift) +{ + unsigned int dividor2 = 1 << + ((readl(&clock_manager_base->main_pll.nocdiv) >> + nocdivshift) & CLKMGR_MAINPLL_NOCDIV_MSK); + + return cm_get_noc_clk_hz()/dividor2; +} + +int of_to_struct(const void *blob, int node, int cfg_len, void *cfg) +{ + if (fdtdec_get_int_array(blob, node, "altr,of_reg_value", + (u32*)cfg, cfg_len)) { + /* could not find required property */ + return 100; + } + + return 0; +} + +static int of_get_input_clks(const void *blob, int node, void *cfg) +{ + if (fdtdec_get_int_array(blob, node, "clock-frequency", + (u32*)cfg, 1)) { + /* could not find required property */ + return 100; + } + + return 0; +} + +int of_get_clk_cfg(const void *blob, struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, struct alteragrp_cfg *altrgrp_cfg) +{ + int node, child, len; + const char *node_name; + + node = fdtdec_next_compatible(blob, 0, COMPAT_ALTERA_SOCFPGA_CLK); + + if (node < 0) + return 1; + + child = fdt_first_subnode(blob, node); + + if (child < 0) + return 2; + + child = fdt_first_subnode(blob, child); + + if (child < 0) + return 3; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(node_name, "osc1")) { + if (of_get_input_clks(blob, child, &eosc1_hz)) + return 101; + } else if (!strcmp(node_name, "cb_intosc_ls_clk")) { + if (of_get_input_clks(blob, child, &cb_intosc_hz)) + return 102; + } else if (!strcmp(node_name, "f2s_free_clk")) { + if (of_get_input_clks(blob, child, &f2s_free_hz)) + return 103; + } else if (!strcmp(node_name, "main_pll")) { + if (of_to_struct(blob, child, sizeof(*main_cfg)/sizeof(uint32_t), + main_cfg)) + return 104; + } else if (!strcmp(node_name, "periph_pll")) { + if (of_to_struct(blob, child, sizeof(*per_cfg)/sizeof(uint32_t), + per_cfg)) + return 105; + } else if (!strcmp(node_name, "altera")) { + if (of_to_struct(blob, child, + sizeof(*altrgrp_cfg)/sizeof(uint32_t), altrgrp_cfg)) + return 106; + + main_cfg->mpuclk = altrgrp_cfg->mpuclk; + main_cfg->nocclk = altrgrp_cfg->nocclk; + } + child = fdt_next_subnode(blob, child); + + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return 0; +} + +/* calculate the intended main VCO frequency based on handoff */ +static unsigned int cm_calc_handoff_main_vco_clk_hz + (struct mainpll_cfg *main_cfg) +{ + unsigned int clk_hz; + + /* Check main VCO clock source: eosc, intosc or f2s? */ + switch (main_cfg->vco0_psrc) { + case CLKMGR_MAINPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + /* calculate the VCO frequency */ + clk_hz /= (1 + main_cfg->vco1_denom); + clk_hz *= (1 + main_cfg->vco1_numer); + + return clk_hz; +} + +/* calculate the intended periph VCO frequency based on handoff */ +static unsigned int cm_calc_handoff_periph_vco_clk_hz + (struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check periph VCO clock source: eosc, intosc, f2s or mainpll? */ + switch (per_cfg->vco0_psrc) { + case CLKMGR_PERPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= main_cfg->cntr15clk_cnt; + break; + default: + return 0; + } + + /* calculate the VCO frequency */ + clk_hz /= (1 + per_cfg->vco1_denom); + clk_hz *= (1 + per_cfg->vco1_numer); + + return clk_hz; +} + +/* calculate the intended MPU clock frequency based on handoff */ +static unsigned int cm_calc_handoff_mpu_clk_hz(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (main_cfg->mpuclk_src) { + case CLKMGR_MAINPLL_MPUCLK_SRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= ((main_cfg->mpuclk & CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_PERI: + clk_hz = cm_calc_handoff_periph_vco_clk_hz(main_cfg, per_cfg); + clk_hz /= (((main_cfg->mpuclk >> + CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1); + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_MPUCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + clk_hz /= (main_cfg->mpuclk_cnt + 1); + return clk_hz; +} + +/* calculate the intended NOC clock frequency based on handoff */ +static unsigned int cm_calc_handoff_noc_clk_hz(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + unsigned int clk_hz; + + /* Check MPU clock source: main, periph, osc1, intosc or f2s? */ + switch (main_cfg->nocclk_src) { + case CLKMGR_MAINPLL_NOCCLK_SRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz(main_cfg); + clk_hz /= ((main_cfg->nocclk & CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + + 1); + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_PERI: + clk_hz = cm_calc_handoff_periph_vco_clk_hz(main_cfg, per_cfg); + clk_hz /= (((main_cfg->nocclk >> + CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + 1); + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_OSC1: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_NOCCLK_SRC_FPGA: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + + clk_hz /= (main_cfg->nocclk_cnt + 1); + return clk_hz; +} + +/* return 1 if PLL ramp is required */ +static int cm_is_pll_ramp_required(int main0periph1, + struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg) +{ + + /* Check for main PLL */ + if (main0periph1 == 0) { + /* + * PLL ramp is not required if both MPU clock and NOC clock are + * not sourced from main PLL + */ + if (main_cfg->mpuclk_src != CLKMGR_MAINPLL_MPUCLK_SRC_MAIN && + main_cfg->nocclk_src != CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) + return 0; + + /* + * PLL ramp is required if MPU clock is sourced from main PLL + * and MPU clock is over 900MHz (as advised by HW team) + */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN && + (cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ)) + return 1; + + /* + * PLL ramp is required if NOC clock is sourced from main PLL + * and NOC clock is over 300MHz (as advised by HW team) + */ + if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_MAIN && + (cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ)) + return 2; + + } else if (main0periph1 == 1) { + /* + * PLL ramp is not required if both MPU clock and NOC clock are + * not sourced from periph PLL + */ + if (main_cfg->mpuclk_src != CLKMGR_MAINPLL_MPUCLK_SRC_PERI && + main_cfg->nocclk_src != CLKMGR_MAINPLL_NOCCLK_SRC_PERI) + return 0; + + /* + * PLL ramp is required if MPU clock are source from periph PLL + * and MPU clock is over 900MHz (as advised by HW team) + */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI && + (cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ)) + return 1; + + /* + * PLL ramp is required if NOC clock are source from periph PLL + * and NOC clock is over 300MHz (as advised by HW team) + */ + if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_PERI && + (cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg) > + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ)) + return 2; + } + return 0; +} + +/* + * Calculate the new PLL numerator which is based on existing DTS hand off and + * intended safe frequency (safe_hz). Note that PLL ramp is only modifying the + * numerator while maintaining denominator as denominator will influence the + * jitter condition. Please refer A10 HPS TRM for the jitter guide. Note final + * value for numerator is minus with 1 to cater our register value + * representation. + */ +static unsigned int cm_calc_safe_pll_numer(int main0periph1, + struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int safe_hz) +{ + unsigned int clk_hz = 0; + + /* Check for main PLL */ + if (main0periph1 == 0) { + /* Check main VCO clock source: eosc, intosc or f2s? */ + switch (main_cfg->vco0_psrc) { + case CLKMGR_MAINPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_MAINPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + default: + return 0; + } + /* Applicable if MPU clock is from main PLL */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN) { + /* calculate the safe numer value */ + clk_hz = (safe_hz / clk_hz) * + (main_cfg->mpuclk_cnt + 1) * + ((main_cfg->mpuclk & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1) * + (1 + main_cfg->vco1_denom) - 1; + } + /* Reach here if MPU clk not from main PLL but NOC clk is */ + else if (main_cfg->nocclk_src == + CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) { + /* calculate the safe numer value */ + clk_hz = (safe_hz / clk_hz) * + (main_cfg->nocclk_cnt + 1) * + ((main_cfg->nocclk & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + 1) * + (1 + main_cfg->vco1_denom) - 1; + } else + clk_hz = 0; + + } else if (main0periph1 == 1) { + /* Check periph VCO clock source: eosc, intosc, f2s, mainpll */ + switch (per_cfg->vco0_psrc) { + case CLKMGR_PERPLL_VCO0_PSRC_EOSC: + clk_hz = eosc1_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC: + clk_hz = cb_intosc_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_F2S: + clk_hz = f2s_free_hz; + break; + case CLKMGR_PERPLL_VCO0_PSRC_MAIN: + clk_hz = cm_calc_handoff_main_vco_clk_hz( + main_cfg); + clk_hz /= main_cfg->cntr15clk_cnt; + break; + default: + return 0; + } + /* Applicable if MPU clock is from periph PLL */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI) { + /* calculate the safe numer value */ + clk_hz = (safe_hz / clk_hz) * + (main_cfg->mpuclk_cnt + 1) * + (((main_cfg->mpuclk >> + CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_MPUCLK_CNT_MSK) + 1) * + (1 + per_cfg->vco1_denom) - 1; + } + /* Reach here if MPU clk not from periph PLL but NOC clk is */ + else if (main_cfg->nocclk_src == + CLKMGR_MAINPLL_NOCCLK_SRC_PERI) { + /* calculate the safe numer value */ + clk_hz = (safe_hz / clk_hz) * + (main_cfg->nocclk_cnt + 1) * + (((main_cfg->nocclk >> + CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB) & + CLKMGR_MAINPLL_NOCCLK_CNT_MSK) + 1) * + (1 + per_cfg->vco1_denom) - 1; + } else + clk_hz = 0; + } + return clk_hz; +} + +/* ramping the main PLL to final value */ +static void cm_pll_ramp_main(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int pll_ramp_main_hz) +{ + unsigned int clk_hz = 0, clk_incr_hz = 0, clk_final_hz = 0; + + /* find out the increment value */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_MAIN) { + clk_incr_hz = CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg); + } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_MAIN) { + clk_incr_hz = CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg); + } + /* execute the ramping here */ + for (clk_hz = pll_ramp_main_hz + clk_incr_hz; + clk_hz < clk_final_hz; clk_hz += clk_incr_hz) { + writel((main_cfg->vco1_denom << + CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(0, main_cfg, per_cfg, clk_hz), + &clock_manager_base->main_pll.vco1); + udelay(1000); + cm_wait_for_lock(LOCKED_MASK); + } + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + main_cfg->vco1_numer, + &clock_manager_base->main_pll.vco1); + udelay(1000); + cm_wait_for_lock(LOCKED_MASK); +} + +/* ramping the periph PLL to final value */ +static void cm_pll_ramp_periph(struct mainpll_cfg *main_cfg, + struct perpll_cfg *per_cfg, + unsigned int pll_ramp_periph_hz) +{ + unsigned int clk_hz = 0, clk_incr_hz = 0, clk_final_hz = 0; + + /* find out the increment value */ + if (main_cfg->mpuclk_src == CLKMGR_MAINPLL_MPUCLK_SRC_PERI) { + clk_incr_hz = CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_mpu_clk_hz(main_cfg, per_cfg); + } else if (main_cfg->nocclk_src == CLKMGR_MAINPLL_NOCCLK_SRC_PERI) { + clk_incr_hz = CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ; + clk_final_hz = cm_calc_handoff_noc_clk_hz(main_cfg, per_cfg); + } + /* execute the ramping here */ + for (clk_hz = pll_ramp_periph_hz + clk_incr_hz; + clk_hz < clk_final_hz; clk_hz += clk_incr_hz) { + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(1, main_cfg, per_cfg, clk_hz), + &clock_manager_base->per_pll.vco1); + udelay(1000); + cm_wait_for_lock(LOCKED_MASK); + } + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + per_cfg->vco1_numer, + &clock_manager_base->per_pll.vco1); + udelay(1000); + cm_wait_for_lock(LOCKED_MASK); +} + +/* + * Setup clocks while making no assumptions of the + * previous state of the clocks. + * + * Start by being paranoid and gate all sw managed clocks + * + * Put all plls in bypass + * + * Put all plls VCO registers back to reset value (bgpwr dwn). + * + * Put peripheral and main pll src to reset value to avoid glitch. + * + * Delay 5 us. + * + * Deassert bg pwr dn and set numerator and denominator + * + * Start 7 us timer. + * + * set internal dividers + * + * Wait for 7 us timer. + * + * Enable plls + * + * Set external dividers while plls are locking + * + * Wait for pll lock + * + * Assert/deassert outreset all. + * + * Take all pll's out of bypass + * + * Clear safe mode + * + * set source main and peripheral clocks + * + * Ungate clocks + */ + +static int cm_full_cfg(struct mainpll_cfg *main_cfg, struct perpll_cfg *per_cfg) +{ + unsigned int pll_ramp_main_hz = 0, pll_ramp_periph_hz = 0, + ramp_required; + + /* gate off all mainpll clock excpet HW managed clock */ + writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | + CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, + &clock_manager_base->main_pll.enr); + + /* now we can gate off the rest of the peripheral clocks */ + writel(0, &clock_manager_base->per_pll.en); + + /* Put all plls in external bypass */ + writel(CLKMGR_MAINPLL_BYPASS_RESET, + &clock_manager_base->main_pll.bypasss); + writel(CLKMGR_PERPLL_BYPASS_RESET, + &clock_manager_base->per_pll.bypasss); + + /* + * Put all plls VCO registers back to reset value. + * Some code might have messed with them. At same time set the + * desired clock source + */ + writel(CLKMGR_MAINPLL_VCO0_RESET | + CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK | + (main_cfg->vco0_psrc << + CLKMGR_MAINPLL_VCO0_PSRC_LSB), + &clock_manager_base->main_pll.vco0); + + writel(CLKMGR_PERPLL_VCO0_RESET | + CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK | + (per_cfg->vco0_psrc << + CLKMGR_PERPLL_VCO0_PSRC_LSB), + &clock_manager_base->per_pll.vco0); + + writel(CLKMGR_MAINPLL_VCO1_RESET, + &clock_manager_base->main_pll.vco1); + writel(CLKMGR_PERPLL_VCO1_RESET, + &clock_manager_base->per_pll.vco1); + + /* clear the interrupt register status register */ + writel(CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLACHIEVED_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLACHIEVED_SET_MSK, + &clock_manager_base->intr); + + /* Program VCO �Numerator� and �Denominator� for main PLL */ + ramp_required = cm_is_pll_ramp_required(0, main_cfg, per_cfg); + if (ramp_required) { + /* set main PLL to safe starting threshold frequency */ + if (ramp_required == 1) + pll_ramp_main_hz = CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ; + else if (ramp_required == 2) + pll_ramp_main_hz = CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ; + + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(0, main_cfg, per_cfg, + pll_ramp_main_hz), + &clock_manager_base->main_pll.vco1); + } else + writel((main_cfg->vco1_denom << CLKMGR_MAINPLL_VCO1_DENOM_LSB) | + main_cfg->vco1_numer, + &clock_manager_base->main_pll.vco1); + + /* Program VCO �Numerator� and �Denominator� for periph PLL */ + ramp_required = cm_is_pll_ramp_required(1, main_cfg, per_cfg); + if (ramp_required) { + /* set periph PLL to safe starting threshold frequency */ + if (ramp_required == 1) + pll_ramp_periph_hz = + CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ; + else if (ramp_required == 2) + pll_ramp_periph_hz = + CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ; + + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + cm_calc_safe_pll_numer(1, main_cfg, per_cfg, + pll_ramp_periph_hz), + &clock_manager_base->per_pll.vco1); + } else + writel((per_cfg->vco1_denom << CLKMGR_PERPLL_VCO1_DENOM_LSB) | + per_cfg->vco1_numer, + &clock_manager_base->per_pll.vco1); + + /* Wait for at least 5 us */ + udelay(5); + + /* Now deassert BGPWRDN and PWRDN */ + clrbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_BGPWRDN_SET_MSK | + CLKMGR_MAINPLL_VCO0_PWRDN_SET_MSK); + clrbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_BGPWRDN_SET_MSK | + CLKMGR_PERPLL_VCO0_PWRDN_SET_MSK); + + /* Wait for at least 7 us */ + udelay(7); + + /* enable the VCO and disable the external regulator to PLL */ + writel((readl(&clock_manager_base->main_pll.vco0) & + ~CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK) | + CLKMGR_MAINPLL_VCO0_EN_SET_MSK, + &clock_manager_base->main_pll.vco0); + writel((readl(&clock_manager_base->per_pll.vco0) & + ~CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK) | + CLKMGR_PERPLL_VCO0_EN_SET_MSK, + &clock_manager_base->per_pll.vco0); + + /* setup all the main PLL counter and clock source */ + writel(main_cfg->nocclk, + SOCFPGA_CLKMGR_ADDRESS + CLKMGR_MAINPLL_NOC_CLK_OFFSET); + writel(main_cfg->mpuclk, + SOCFPGA_CLKMGR_ADDRESS + CLKMGR_ALTERAGRP_MPU_CLK_OFFSET); + + /* main_emaca_clk divider */ + writel(main_cfg->cntr2clk_cnt, + &clock_manager_base->main_pll.cntr2clk); + /* main_emacb_clk divider */ + writel(main_cfg->cntr3clk_cnt, + &clock_manager_base->main_pll.cntr3clk); + /* main_emac_ptp_clk divider */ + writel(main_cfg->cntr4clk_cnt, + &clock_manager_base->main_pll.cntr4clk); + /* main_gpio_db_clk divider */ + writel(main_cfg->cntr5clk_cnt, + &clock_manager_base->main_pll.cntr5clk); + /* main_sdmmc_clk divider */ + writel(main_cfg->cntr6clk_cnt, + &clock_manager_base->main_pll.cntr6clk); + /* main_s2f_user0_clk divider */ + writel(main_cfg->cntr7clk_cnt | + (main_cfg->cntr7clk_src << + CLKMGR_MAINPLL_CNTR7CLK_SRC_LSB), + &clock_manager_base->main_pll.cntr7clk); + /* main_s2f_user1_clk divider */ + writel(main_cfg->cntr8clk_cnt, + &clock_manager_base->main_pll.cntr8clk); + /* main_hmc_pll_clk divider */ + writel(main_cfg->cntr9clk_cnt | + (main_cfg->cntr9clk_src << + CLKMGR_MAINPLL_CNTR9CLK_SRC_LSB), + &clock_manager_base->main_pll.cntr9clk); + /* main_periph_ref_clk divider */ + writel(main_cfg->cntr15clk_cnt, + &clock_manager_base->main_pll.cntr15clk); + + /* setup all the peripheral PLL counter and clock source */ + /* peri_emaca_clk divider */ + writel(per_cfg->cntr2clk_cnt | + (per_cfg->cntr2clk_src << CLKMGR_PERPLL_CNTR2CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr2clk); + /* peri_emacb_clk divider */ + writel(per_cfg->cntr3clk_cnt | + (per_cfg->cntr3clk_src << CLKMGR_PERPLL_CNTR3CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr3clk); + /* peri_emac_ptp_clk divider */ + writel(per_cfg->cntr4clk_cnt | + (per_cfg->cntr4clk_src << CLKMGR_PERPLL_CNTR4CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr4clk); + /* peri_gpio_db_clk divider */ + writel(per_cfg->cntr5clk_cnt | + (per_cfg->cntr5clk_src << CLKMGR_PERPLL_CNTR5CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr5clk); + /* peri_sdmmc_clk divider */ + writel(per_cfg->cntr6clk_cnt | + (per_cfg->cntr6clk_src << CLKMGR_PERPLL_CNTR6CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr6clk); + /* peri_s2f_user0_clk divider */ + writel(per_cfg->cntr7clk_cnt, + &clock_manager_base->per_pll.cntr7clk); + /* peri_s2f_user1_clk divider */ + writel(per_cfg->cntr8clk_cnt | + (per_cfg->cntr8clk_src << CLKMGR_PERPLL_CNTR8CLK_SRC_LSB), + &clock_manager_base->per_pll.cntr8clk); + /* peri_hmc_pll_clk divider */ + writel(per_cfg->cntr9clk_cnt, + &clock_manager_base->per_pll.cntr9clk); + + /* setup all the external PLL counter */ + /* mpu wrapper / external divider */ + writel(main_cfg->mpuclk_cnt | + (main_cfg->mpuclk_src << + CLKMGR_MAINPLL_MPUCLK_SRC_LSB), + &clock_manager_base->main_pll.mpuclk); + /* NOC wrapper / external divider */ + writel(main_cfg->nocclk_cnt | + (main_cfg->nocclk_src << CLKMGR_MAINPLL_NOCCLK_SRC_LSB), + &clock_manager_base->main_pll.nocclk); + /* NOC subclock divider such as l4 */ + writel(main_cfg->nocdiv_l4mainclk | + (main_cfg->nocdiv_l4mpclk << + CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB) | + (main_cfg->nocdiv_l4spclk << + CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB) | + (main_cfg->nocdiv_csatclk << + CLKMGR_MAINPLL_NOCDIV_CSATCLK_LSB) | + (main_cfg->nocdiv_cstraceclk << + CLKMGR_MAINPLL_NOCDIV_CSTRACECLK_LSB) | + (main_cfg->nocdiv_cspdbclk << + CLKMGR_MAINPLL_NOCDIV_CSPDBGCLK_LSB), + &clock_manager_base->main_pll.nocdiv); + /* gpio_db external divider */ + writel(per_cfg->gpiodiv_gpiodbclk, + &clock_manager_base->per_pll.gpiodiv); + + /* setup the EMAC clock mux select */ + writel((per_cfg->emacctl_emac0sel << + CLKMGR_PERPLL_EMACCTL_EMAC0SEL_LSB) | + (per_cfg->emacctl_emac1sel << + CLKMGR_PERPLL_EMACCTL_EMAC1SEL_LSB) | + (per_cfg->emacctl_emac2sel << + CLKMGR_PERPLL_EMACCTL_EMAC2SEL_LSB), + &clock_manager_base->per_pll.emacctl); + + /* at this stage, check for PLL lock status */ + cm_wait_for_lock(LOCKED_MASK); + + /* + * after locking, but before taking out of bypass, + * assert/deassert outresetall + */ + /* assert mainpll outresetall */ + setbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); + /* assert perpll outresetall */ + setbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK); + /* de-assert mainpll outresetall */ + clrbits_le32(&clock_manager_base->main_pll.vco0, + CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK); + /* de-assert perpll outresetall */ + clrbits_le32(&clock_manager_base->per_pll.vco0, + CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK); + + /* Take all PLLs out of bypass when boot mode is cleared. */ + /* release mainpll from bypass */ + writel(CLKMGR_MAINPLL_BYPASS_RESET, + &clock_manager_base->main_pll.bypassr); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* release perpll from bypass */ + writel(CLKMGR_PERPLL_BYPASS_RESET, + &clock_manager_base->per_pll.bypassr); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* clear boot mode */ + clrbits_le32(&clock_manager_base->ctrl, + CLKMGR_CLKMGR_CTL_BOOTMOD_SET_MSK); + /* wait till Clock Manager is not busy */ + cm_wait_for_fsm(); + + /* At here, we need to ramp to final value if needed */ + if (pll_ramp_main_hz != 0) + cm_pll_ramp_main(main_cfg, per_cfg, pll_ramp_main_hz); + if (pll_ramp_periph_hz != 0) + cm_pll_ramp_periph(main_cfg, per_cfg, pll_ramp_periph_hz); + + /* Now ungate non-hw-managed clocks */ + writel(CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK | + CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK, + &clock_manager_base->main_pll.ens); + writel(CLKMGR_PERPLL_EN_RESET, + &clock_manager_base->per_pll.ens); + + /* Clear the loss lock and slip bits as they might set during + clock reconfiguration */ + writel(CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK | + CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK, + &clock_manager_base->intr); + + return 0; +} + +int cm_basic_init(const void *blob) +{ + struct mainpll_cfg main_cfg; + struct perpll_cfg per_cfg; + struct alteragrp_cfg altrgrp_cfg; + int rval; + + /* initialize to zero for use case of optional node */ + memset(&main_cfg, 0, sizeof(main_cfg)); + memset(&per_cfg, 0, sizeof(per_cfg)); + memset(&altrgrp_cfg, 0, sizeof(altrgrp_cfg)); + + if (of_get_clk_cfg(blob, &main_cfg, &per_cfg, &altrgrp_cfg)) { + return 1; + } + + rval = cm_full_cfg(&main_cfg, &per_cfg); + + cm_l4_main_clk_hz = + cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB); + + cm_l4_mp_clk_hz = cm_get_l4_noc_hz(CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB); + + cm_l4_sp_clk_hz = cm_get_l4_sp_clk_hz(); + + cm_l4_sys_free_clk_hz = cm_get_noc_clk_hz()/4; + + return rval; +} diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager_gen5.c similarity index 62% copy from arch/arm/mach-socfpga/clock_manager.c copy to arch/arm/mach-socfpga/clock_manager_gen5.c index aa71636..f4bb02b 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager_gen5.c @@ -1,7 +1,7 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2016, Intel Corporation * - * SPDX-License-Identifier: GPL-2.0+ + * SPDX-License-Identifier: GPL-2.0 */
#include <common.h> @@ -10,31 +10,19 @@
+const unsigned int cm_get_osc_clk_hz(const int osc); +const unsigned int cm_get_f2s_per_ref_clk_hz(void); +const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); +static void cm_write_bypass(uint32_t val); +static void cm_write_ctrl(uint32_t val); +static void cm_write_with_phase(uint32_t value, + uint32_t reg_address, uint32_t mask); +unsigned long cm_get_sdram_clk_hz(void); +int set_cpu_clk_info(void); + static const struct socfpga_clock_manager *clock_manager_base = (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS;
-static void cm_wait_for_lock(uint32_t mask) -{ - register uint32_t inter_val; - uint32_t retry = 0; - do { - inter_val = readl(&clock_manager_base->inter) & mask; - if (inter_val == mask) - retry++; - else - retry = 0; - if (retry >= 10) - break; - } while (1); -} - -/* function to poll in the fsm busy bit */ -static void cm_wait_for_fsm(void) -{ - while (readl(&clock_manager_base->stat) & CLKMGR_STAT_BUSY) - ; -} - /* * function to write the bypass register which requires a poll of the * busy bit @@ -87,7 +75,6 @@ static void cm_write_with_phase(uint32_t value, * set source main and peripheral clocks * Ungate clocks */ - void cm_basic_init(const struct cm_config * const cfg) { unsigned long end; @@ -230,11 +217,6 @@ void cm_basic_init(const struct cm_config * const cfg)
-#define LOCKED_MASK \ - (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ - CLKMGR_INTER_PERPLLLOCKED_MASK | \ - CLKMGR_INTER_MAINPLLLOCKED_MASK) - cm_wait_for_lock(LOCKED_MASK);
/* write the sdram clock counters before toggling outreset all */ @@ -328,60 +310,6 @@ void cm_basic_init(const struct cm_config * const cfg) &clock_manager_base->inter); }
-static unsigned int cm_get_main_vco_clk_hz(void) -{ - uint32_t reg, clock; - - /* get the main VCO clock */ - reg = readl(&clock_manager_base->main_pll.vco); - clock = cm_get_osc_clk_hz(1); - clock /= ((reg & CLKMGR_MAINPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_MAINPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_MAINPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_MAINPLLGRP_VCO_NUMER_OFFSET) + 1; - - return clock; -} - -static unsigned int cm_get_per_vco_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify PER PLL clock source */ - reg = readl(&clock_manager_base->per_pll.vco); - reg = (reg & CLKMGR_PERPLLGRP_VCO_SSRC_MASK) >> - CLKMGR_PERPLLGRP_VCO_SSRC_OFFSET; - if (reg == CLKMGR_VCO_SSRC_EOSC1) - clock = cm_get_osc_clk_hz(1); - else if (reg == CLKMGR_VCO_SSRC_EOSC2) - clock = cm_get_osc_clk_hz(2); - else if (reg == CLKMGR_VCO_SSRC_F2S) - clock = cm_get_f2s_per_ref_clk_hz(); - - /* get the PER VCO clock */ - reg = readl(&clock_manager_base->per_pll.vco); - clock /= ((reg & CLKMGR_PERPLLGRP_VCO_DENOM_MASK) >> - CLKMGR_PERPLLGRP_VCO_DENOM_OFFSET) + 1; - clock *= ((reg & CLKMGR_PERPLLGRP_VCO_NUMER_MASK) >> - CLKMGR_PERPLLGRP_VCO_NUMER_OFFSET) + 1; - - return clock; -} - -unsigned long cm_get_mpu_clk_hz(void) -{ - uint32_t reg, clock; - - clock = cm_get_main_vco_clk_hz(); - - /* get the MPU clock */ - reg = readl(&clock_manager_base->altera.mpuclk); - clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mpuclk); - clock /= (reg + 1); - return clock; -} - unsigned long cm_get_sdram_clk_hz(void) { uint32_t reg, clock = 0; @@ -412,147 +340,3 @@ unsigned long cm_get_sdram_clk_hz(void)
return clock; } - -unsigned int cm_get_l4_sp_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of L4 SP clock */ - reg = readl(&clock_manager_base->main_pll.l4src); - reg = (reg & CLKMGR_MAINPLLGRP_L4SRC_L4SP) >> - CLKMGR_MAINPLLGRP_L4SRC_L4SP_OFFSET; - - if (reg == CLKMGR_L4_SP_CLK_SRC_MAINPLL) { - clock = cm_get_main_vco_clk_hz(); - - /* get the clock prior L4 SP divider (main clk) */ - reg = readl(&clock_manager_base->altera.mainclk); - clock /= (reg + 1); - reg = readl(&clock_manager_base->main_pll.mainclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_L4_SP_CLK_SRC_PERPLL) { - clock = cm_get_per_vco_clk_hz(); - - /* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); - clock /= (reg + 1); - } - - /* get the L4 SP clock which supplied to UART */ - reg = readl(&clock_manager_base->main_pll.maindiv); - reg = (reg & CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_MASK) >> - CLKMGR_MAINPLLGRP_MAINDIV_L4SPCLK_OFFSET; - clock = clock / (1 << reg); - - return clock; -} - -unsigned int cm_get_mmc_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of MMC clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_SDMMC_MASK) >> - CLKMGR_PERPLLGRP_SRC_SDMMC_OFFSET; - - if (reg == CLKMGR_SDMMC_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); - - /* get the SDMMC clock */ - reg = readl(&clock_manager_base->main_pll.mainnandsdmmcclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_SDMMC_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); - - /* get the SDMMC clock */ - reg = readl(&clock_manager_base->per_pll.pernandsdmmcclk); - clock /= (reg + 1); - } - - /* further divide by 4 as we have fixed divider at wrapper */ - clock /= 4; - return clock; -} - -unsigned int cm_get_qspi_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - /* identify the source of QSPI clock */ - reg = readl(&clock_manager_base->per_pll.src); - reg = (reg & CLKMGR_PERPLLGRP_SRC_QSPI_MASK) >> - CLKMGR_PERPLLGRP_SRC_QSPI_OFFSET; - - if (reg == CLKMGR_QSPI_CLK_SRC_F2S) { - clock = cm_get_f2s_per_ref_clk_hz(); - } else if (reg == CLKMGR_QSPI_CLK_SRC_MAIN) { - clock = cm_get_main_vco_clk_hz(); - - /* get the qspi clock */ - reg = readl(&clock_manager_base->main_pll.mainqspiclk); - clock /= (reg + 1); - } else if (reg == CLKMGR_QSPI_CLK_SRC_PER) { - clock = cm_get_per_vco_clk_hz(); - - /* get the qspi clock */ - reg = readl(&clock_manager_base->per_pll.perqspiclk); - clock /= (reg + 1); - } - - return clock; -} - -unsigned int cm_get_spi_controller_clk_hz(void) -{ - uint32_t reg, clock = 0; - - clock = cm_get_per_vco_clk_hz(); - - /* get the clock prior L4 SP divider (periph_base_clk) */ - reg = readl(&clock_manager_base->per_pll.perbaseclk); - clock /= (reg + 1); - - return clock; -} - -static void cm_print_clock_quick_summary(void) -{ - printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); - printf("DDR %10ld kHz\n", cm_get_sdram_clk_hz() / 1000); - printf("EOSC1 %8d kHz\n", cm_get_osc_clk_hz(1) / 1000); - printf("EOSC2 %8d kHz\n", cm_get_osc_clk_hz(2) / 1000); - printf("F2S_SDR_REF %8d kHz\n", cm_get_f2s_sdr_ref_clk_hz() / 1000); - printf("F2S_PER_REF %8d kHz\n", cm_get_f2s_per_ref_clk_hz() / 1000); - printf("MMC %8d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); - printf("QSPI %8d kHz\n", cm_get_qspi_controller_clk_hz() / 1000); - printf("UART %8d kHz\n", cm_get_l4_sp_clk_hz() / 1000); - printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); -} - -int set_cpu_clk_info(void) -{ - /* Calculate the clock frequencies required for drivers */ - cm_get_l4_sp_clk_hz(); - cm_get_mmc_controller_clk_hz(); - - gd->bd->bi_arm_freq = cm_get_mpu_clk_hz() / 1000000; - gd->bd->bi_dsp_freq = 0; - gd->bd->bi_ddr_freq = cm_get_sdram_clk_hz() / 1000000; - - return 0; -} - -int do_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - cm_print_clock_quick_summary(); - return 0; -} - -U_BOOT_CMD( - clocks, CONFIG_SYS_MAXARGS, 1, do_showclocks, - "display clocks", - "" -); diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index 2675951..45943ea 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -8,21 +8,9 @@ #define _CLOCK_MANAGER_H_
#ifndef __ASSEMBLER__ -/* Clock speed accessors */ -unsigned long cm_get_mpu_clk_hz(void); -unsigned long cm_get_sdram_clk_hz(void); -unsigned int cm_get_l4_sp_clk_hz(void); -unsigned int cm_get_mmc_controller_clk_hz(void); -unsigned int cm_get_qspi_controller_clk_hz(void); -unsigned int cm_get_spi_controller_clk_hz(void); -const unsigned int cm_get_osc_clk_hz(const int osc); -const unsigned int cm_get_f2s_per_ref_clk_hz(void); -const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); - -/* Clock configuration accessors */ -const struct cm_config * const cm_get_default_config(void); -#endif +#include <linux/types.h>
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct cm_config { /* main group */ uint32_t main_vco_base; @@ -57,74 +45,196 @@ struct cm_config { uint32_t s2fuser2clk; };
+struct socfpga_clock_manager_sdr_pll { + uint32_t vco; + uint32_t ctrl; + uint32_t ddrdqsclk; + uint32_t ddr2xdqsclk; + uint32_t ddrdqclk; + uint32_t s2fuser2clk; + uint32_t en; + uint32_t stat; +}; +#endif + +/* Common prototypes */ +unsigned int cm_get_l4_sp_clk_hz(void); +unsigned int cm_get_qspi_controller_clk_hz(void); +unsigned int cm_get_mmc_controller_clk_hz(void); +unsigned int cm_get_spi_controller_clk_hz(void); +void cm_use_intosc(void); +void cm_wait_for_lock(uint32_t mask); +void cm_wait_for_fsm(void); +unsigned int cm_get_main_vco_clk_hz(void); +unsigned int cm_get_per_vco_clk_hz(void); +unsigned long cm_get_mpu_clk_hz(void); +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +/* Clock speed accessors */ +const unsigned int cm_get_osc_clk_hz(const int osc); +const unsigned int cm_get_f2s_per_ref_clk_hz(void); +const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); void cm_basic_init(const struct cm_config * const cfg); +unsigned long cm_get_sdram_clk_hz(void); +/* Clock configuration accessors */ +const struct cm_config * const cm_get_default_config(void); +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +unsigned int cm_get_noc_clk_hz(void); +unsigned int cm_get_l4_noc_hz(unsigned int nocdivshift); +int cm_basic_init(const void* blob); +extern unsigned int cm_l4_main_clk_hz; +extern unsigned int cm_l4_sp_clk_hz; +extern unsigned int cm_l4_mp_clk_hz; +extern unsigned int cm_l4_sys_free_clk_hz; +extern uint32_t eosc1_hz; +extern uint32_t cb_intosc_hz; +extern uint32_t f2s_free_hz; +#endif +#endif
struct socfpga_clock_manager_main_pll { - u32 vco; - u32 misc; - u32 mpuclk; - u32 mainclk; - u32 dbgatclk; - u32 mainqspiclk; - u32 mainnandsdmmcclk; - u32 cfgs2fuser0clk; - u32 en; - u32 maindiv; - u32 dbgdiv; - u32 tracediv; - u32 l4src; - u32 stat; - u32 _pad_0x38_0x40[2]; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + uint32_t vco; + uint32_t misc; + uint32_t mpuclk; + uint32_t mainclk; + uint32_t dbgatclk; + uint32_t mainqspiclk; + uint32_t mainnandsdmmcclk; + uint32_t cfgs2fuser0clk; + uint32_t en; + uint32_t maindiv; + uint32_t dbgdiv; + uint32_t tracediv; + uint32_t l4src; + uint32_t stat; + uint32_t _pad_0x38_0x40[2]; +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + uint32_t vco0; + uint32_t vco1; + uint32_t en; + uint32_t ens; + uint32_t enr; + uint32_t bypass; + uint32_t bypasss; + uint32_t bypassr; + uint32_t mpuclk; + uint32_t nocclk; + uint32_t cntr2clk; + uint32_t cntr3clk; + uint32_t cntr4clk; + uint32_t cntr5clk; + uint32_t cntr6clk; + uint32_t cntr7clk; + uint32_t cntr8clk; + uint32_t cntr9clk; + uint32_t pad_0x48_0x5b[5]; + uint32_t cntr15clk; + uint32_t outrst; + uint32_t outrststat; + uint32_t nocdiv; + uint32_t pad_0x6c_0x80[5]; +#endif };
struct socfpga_clock_manager_per_pll { - u32 vco; - u32 misc; - u32 emac0clk; - u32 emac1clk; - u32 perqspiclk; - u32 pernandsdmmcclk; - u32 perbaseclk; - u32 s2fuser1clk; - u32 en; - u32 div; - u32 gpiodiv; - u32 src; - u32 stat; - u32 _pad_0x34_0x40[3]; -}; - -struct socfpga_clock_manager_sdr_pll { - u32 vco; - u32 ctrl; - u32 ddrdqsclk; - u32 ddr2xdqsclk; - u32 ddrdqclk; - u32 s2fuser2clk; - u32 en; - u32 stat; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + uint32_t vco; + uint32_t misc; + uint32_t emac0clk; + uint32_t emac1clk; + uint32_t perqspiclk; + uint32_t pernandsdmmcclk; + uint32_t perbaseclk; + uint32_t s2fuser1clk; + uint32_t en; + uint32_t div; + uint32_t gpiodiv; + uint32_t src; + uint32_t stat; + uint32_t _pad_0x34_0x40[3]; +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + uint32_t vco0; + uint32_t vco1; + uint32_t en; + uint32_t ens; + uint32_t enr; + uint32_t bypass; + uint32_t bypasss; + uint32_t bypassr; + uint32_t pad_0x20_0x27[2]; + uint32_t cntr2clk; + uint32_t cntr3clk; + uint32_t cntr4clk; + uint32_t cntr5clk; + uint32_t cntr6clk; + uint32_t cntr7clk; + uint32_t cntr8clk; + uint32_t cntr9clk; + uint32_t pad_0x48_0x5f[6]; + uint32_t outrst; + uint32_t outrststat; + uint32_t emacctl; + uint32_t gpiodiv; + uint32_t pad_0x70_0x80[4]; +#endif };
struct socfpga_clock_manager_altera { - u32 mpuclk; - u32 mainclk; + uint32_t mpuclk; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + uint32_t mainclk; +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + uint32_t nocclk; + uint32_t mainmisc0; + uint32_t mainmisc1; + uint32_t perimisc0; + uint32_t perimisc1; +#endif };
struct socfpga_clock_manager { - u32 ctrl; - u32 bypass; - u32 inter; - u32 intren; - u32 dbctrl; - u32 stat; - u32 _pad_0x18_0x3f[10]; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + uint32_t ctrl; + uint32_t bypass; + uint32_t inter; + uint32_t intren; + uint32_t dbctrl; + uint32_t stat; + uint32_t _pad_0x18_0x3f[10]; struct socfpga_clock_manager_main_pll main_pll; struct socfpga_clock_manager_per_pll per_pll; struct socfpga_clock_manager_sdr_pll sdr_pll; struct socfpga_clock_manager_altera altera; - u32 _pad_0xe8_0x200[70]; + uint32_t _pad_0xe8_0x200[70]; +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) + /* clkmgr */ + uint32_t ctrl; + uint32_t intr; + uint32_t intrs; + uint32_t intrr; + uint32_t intren; + uint32_t intrens; + uint32_t intrenr; + uint32_t stat; + uint32_t testioctrl; + uint32_t _pad_0x24_0x40[7]; + /* mainpllgrp */ + struct socfpga_clock_manager_main_pll main_pll; + /* perpllgrp */ + struct socfpga_clock_manager_per_pll per_pll; + struct socfpga_clock_manager_altera altera; +#endif };
+/* Common mask */ +#define CLKMGR_CLKMGR_STAT_BUSY_SET_MSK 0x00000001 + +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#define LOCKED_MASK \ + (CLKMGR_INTER_SDRPLLLOCKED_MASK | \ + CLKMGR_INTER_PERPLLLOCKED_MASK | \ + CLKMGR_INTER_MAINPLLLOCKED_MASK) + #define CLKMGR_CTRL_SAFEMODE (1 << 0) #define CLKMGR_CTRL_SAFEMODE_OFFSET 0
@@ -310,5 +420,119 @@ struct socfpga_clock_manager { #define CLKMGR_SDRPLLGRP_S2FUSER2CLK_CNT_MASK 0x000001ff #define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_OFFSET 9 #define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK 0x00000e00 - +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define CLKMGR_ALTERAGRP_MPU_CLK_OFFSET 0x140 +#define CLKMGR_MAINPLL_NOC_CLK_OFFSET 0x144 +#define LOCKED_MASK \ + (CLKMGR_CLKMGR_STAT_MAINPLLLOCKED_SET_MSK | \ + CLKMGR_CLKMGR_STAT_PERPLLLOCKED_SET_MSK) + +/* value */ +#define CLKMGR_MAINPLL_BYPASS_RESET 0x0000003f +#define CLKMGR_PERPLL_BYPASS_RESET 0x000000ff +#define CLKMGR_MAINPLL_VCO0_RESET 0x00010053 +#define CLKMGR_MAINPLL_VCO1_RESET 0x00010001 +#define CLKMGR_PERPLL_VCO0_RESET 0x00010053 +#define CLKMGR_PERPLL_VCO1_RESET 0x00010001 +#define CLKMGR_MAINPLL_VCO0_PSRC_EOSC 0x0 +#define CLKMGR_MAINPLL_VCO0_PSRC_E_INTOSC 0x1 +#define CLKMGR_MAINPLL_VCO0_PSRC_F2S 0x2 +#define CLKMGR_PERPLL_VCO0_PSRC_EOSC 0x0 +#define CLKMGR_PERPLL_VCO0_PSRC_E_INTOSC 0x1 +#define CLKMGR_PERPLL_VCO0_PSRC_F2S 0x2 +#define CLKMGR_PERPLL_VCO0_PSRC_MAIN 0x3 + +/* mask */ +#define CLKMGR_MAINPLL_EN_S2FUSER0CLKEN_SET_MSK 0x00000040 +#define CLKMGR_MAINPLL_EN_HMCPLLREFCLKEN_SET_MSK 0x00000080 +#define CLKMGR_CLKMGR_STAT_MAINPLLLOCKED_SET_MSK 0x00000100 +#define CLKMGR_CLKMGR_STAT_PERPLLLOCKED_SET_MSK 0x00000200 +#define CLKMGR_CLKMGR_STAT_BOOTCLKSRC_SET_MSK 0x00020000 +#define CLKMGR_MAINPLL_VCO0_BGPWRDN_SET_MSK 0x00000001 +#define CLKMGR_MAINPLL_VCO0_PWRDN_SET_MSK 0x00000002 +#define CLKMGR_MAINPLL_VCO0_EN_SET_MSK 0x00000004 +#define CLKMGR_MAINPLL_VCO0_OUTRSTALL_SET_MSK 0x00000008 +#define CLKMGR_MAINPLL_VCO0_REGEXTSEL_SET_MSK 0x00000010 +#define CLKMGR_PERPLL_VCO0_BGPWRDN_SET_MSK 0x00000001 +#define CLKMGR_PERPLL_VCO0_PWRDN_SET_MSK 0x00000002 +#define CLKMGR_PERPLL_VCO0_EN_SET_MSK 0x00000004 +#define CLKMGR_PERPLL_VCO0_OUTRSTALL_SET_MSK 0x00000008 +#define CLKMGR_PERPLL_VCO0_REGEXTSEL_SET_MSK 0x00000010 +#define CLKMGR_CLKMGR_INTR_PERPLLFBSLIP_SET_MSK 0x00000800 +#define CLKMGR_CLKMGR_INTR_MAINPLLFBSLIP_SET_MSK 0x00000400 +#define CLKMGR_CLKMGR_INTR_PERPLLRFSLIP_SET_MSK 0x00000200 +#define CLKMGR_CLKMGR_INTR_MAINPLLRFSLIP_SET_MSK 0x00000100 +#define CLKMGR_CLKMGR_INTR_PERPLLLOST_SET_MSK 0x00000008 +#define CLKMGR_CLKMGR_INTR_MAINPLLLOST_SET_MSK 0x00000004 +#define CLKMGR_CLKMGR_INTR_MAINPLLACHIEVED_SET_MSK 0x00000001 +#define CLKMGR_CLKMGR_INTR_PERPLLACHIEVED_SET_MSK 0x00000002 +#define CLKMGR_CLKMGR_CTL_BOOTMOD_SET_MSK 0x00000001 +#define CLKMGR_CLKMGR_CTL_BOOTCLK_INTOSC_SET_MSK 0x00000300 +#define CLKMGR_PERPLL_EN_RESET 0x00000f7f +#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK 0x00000020 +#define CLKMGR_MAINPLL_VCO0_PSRC_MSK 0x00000003 +#define CLKMGR_MAINPLL_VCO1_NUMER_MSK 0x00001fff +#define CLKMGR_MAINPLL_VCO1_DENOM_MSK 0x0000003f +#define CLKMGR_MAINPLL_CNTRCLK_MSK 0x000003ff +#define CLKMGR_PERPLL_VCO0_PSRC_MSK 0x00000003 +#define CLKMGR_PERPLL_VCO1_NUMER_MSK 0x00001fff +#define CLKMGR_PERPLL_VCO1_DENOM_MSK 0x0000003f +#define CLKMGR_PERPLL_CNTRCLK_MSK 0x000003ff +#define CLKMGR_MAINPLL_MPUCLK_SRC_MSK 0x00000007 +#define CLKMGR_MAINPLL_MPUCLK_CNT_MSK 0x000003ff +#define CLKMGR_MAINPLL_MPUCLK_SRC_MAIN 0 +#define CLKMGR_MAINPLL_MPUCLK_SRC_PERI 1 +#define CLKMGR_MAINPLL_MPUCLK_SRC_OSC1 2 +#define CLKMGR_MAINPLL_MPUCLK_SRC_INTOSC 3 +#define CLKMGR_MAINPLL_MPUCLK_SRC_FPGA 4 +#define CLKMGR_MAINPLL_NOCDIV_MSK 0x00000003 +#define CLKMGR_MAINPLL_NOCCLK_CNT_MSK 0x000003ff +#define CLKMGR_MAINPLL_NOCCLK_SRC_MSK 0x00000007 +#define CLKMGR_MAINPLL_NOCCLK_SRC_MAIN 0 +#define CLKMGR_MAINPLL_NOCCLK_SRC_PERI 1 +#define CLKMGR_MAINPLL_NOCCLK_SRC_OSC1 2 +#define CLKMGR_MAINPLL_NOCCLK_SRC_INTOSC 3 +#define CLKMGR_MAINPLL_NOCCLK_SRC_FPGA 4 + +#define CLKMGR_PERPLLGRP_SRC_MSK 0x00000007 +#define CLKMGR_PERPLLGRP_SRC_MAIN 0 +#define CLKMGR_PERPLLGRP_SRC_PERI 1 +#define CLKMGR_PERPLLGRP_SRC_OSC1 2 +#define CLKMGR_PERPLLGRP_SRC_INTOSC 3 +#define CLKMGR_PERPLLGRP_SRC_FPGA 4 + +/* bit shifting macro */ +#define CLKMGR_MAINPLL_VCO0_PSRC_LSB 8 +#define CLKMGR_PERPLL_VCO0_PSRC_LSB 8 +#define CLKMGR_MAINPLL_VCO1_DENOM_LSB 16 +#define CLKMGR_PERPLL_VCO1_DENOM_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_PERICNT_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_NOCDIV_L4MAINCLK_LSB 0 +#define CLKMGR_MAINPLL_NOCDIV_L4MPCLK_LSB 8 +#define CLKMGR_MAINPLL_NOCDIV_L4SPCLK_LSB 16 +#define CLKMGR_MAINPLL_NOCDIV_CSATCLK_LSB 24 +#define CLKMGR_MAINPLL_NOCDIV_CSTRACECLK_LSB 26 +#define CLKMGR_MAINPLL_NOCDIV_CSPDBGCLK_LSB 28 +#define CLKMGR_MAINPLL_MPUCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_MPUCLK_PERICNT_LSB 16 +#define CLKMGR_MAINPLL_NOCCLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_CNTR7CLK_SRC_LSB 16 +#define CLKMGR_MAINPLL_CNTR9CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR2CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR3CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR4CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR5CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR6CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_CNTR8CLK_SRC_LSB 16 +#define CLKMGR_PERPLL_EMACCTL_EMAC0SEL_LSB 26 +#define CLKMGR_PERPLL_EMACCTL_EMAC1SEL_LSB 27 +#define CLKMGR_PERPLL_EMACCTL_EMAC2SEL_LSB 28 + +/* PLL ramping work around */ +#define CLKMGR_PLL_RAMP_MPUCLK_THRESHOLD_HZ 900000000 +#define CLKMGR_PLL_RAMP_NOCCLK_THRESHOLD_HZ 300000000 +#define CLKMGR_PLL_RAMP_MPUCLK_INCREMENT_HZ 100000000 +#define CLKMGR_PLL_RAMP_NOCCLK_INCREMENT_HZ 33000000 +#endif #endif /* _CLOCK_MANAGER_H_ */
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/include/mach/pinmux.h | 17 +++++ arch/arm/mach-socfpga/pinmux.c | 104 +++++++++++++++++++++++++++ 2 files changed, 121 insertions(+), 0 deletions(-) create mode 100644 arch/arm/mach-socfpga/include/mach/pinmux.h create mode 100644 arch/arm/mach-socfpga/pinmux.c
diff --git a/arch/arm/mach-socfpga/include/mach/pinmux.h b/arch/arm/mach-socfpga/include/mach/pinmux.h new file mode 100644 index 0000000..ff54caa --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/pinmux.h @@ -0,0 +1,17 @@ +/* + * Copyright (C) 2016 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _PINMUX_H_ +#define _PINMUX_H_ + +#ifndef __ASSEMBLY__ +int config_dedicated_pins(const void *blob); +int config_pins(const void *blob, const char *pin_grp); +#endif + + + +#endif /* _PINMUX_H_ */ diff --git a/arch/arm/mach-socfpga/pinmux.c b/arch/arm/mach-socfpga/pinmux.c new file mode 100644 index 0000000..d45722f --- /dev/null +++ b/arch/arm/mach-socfpga/pinmux.c @@ -0,0 +1,104 @@ +/* + * Copyright (C) 2016 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <fdtdec.h> +#include <asm/arch/pinmux.h> + +int config_dedicated_pins(const void *blob); +int config_pins(const void *blob, const char *pin_grp); +static int __do_pinctr_pins(const void *blob, int child, const char *node_name); +static int do_pinctrl_pins(const void *blob, int node, const char *child_name); + +static int __do_pinctr_pins(const void *blob, int child, const char *node_name) +{ + int len; + fdt_addr_t base_addr; + fdt_size_t size; + const u32 *cell; + u32 offset, value; + + base_addr = fdtdec_get_addr_size(blob, child, "reg", &size); + if (base_addr != FDT_ADDR_T_NONE) { + cell = fdt_getprop(blob, child, "pinctrl-single,pins", + &len); + if (cell != NULL) { + debug("%p %d\n", cell, len); + for (;len > 0; len -= (2*sizeof(u32))) { + offset = fdt32_to_cpu(*cell++); + value = fdt32_to_cpu(*cell++); + debug("<0x%x 0x%x>\n", offset, value); + writel(value, base_addr + offset); + } + return 0; + } + } + return 1; +} + +static int do_pinctrl_pins(const void *blob, int node, const char *child_name) +{ + int child, len; + const char *node_name; + + child = fdt_first_subnode(blob, node); + + if (child < 0) + return 2; + + node_name = fdt_get_name(blob, child, &len); + + while (node_name) { + if (!strcmp(child_name, node_name)) { + __do_pinctr_pins(blob, child, node_name); + return(0); + } + child = fdt_next_subnode(blob, child); + + if (child < 0) + break; + + node_name = fdt_get_name(blob, child, &len); + } + + return 1; +} + +int config_dedicated_pins(const void *blob) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + + if (node < 0) + return 1; + + if (do_pinctrl_pins(blob, node, "dedicated_cfg")) + return 2; + + if (do_pinctrl_pins(blob, node, "dedicated")) + return 3; + + return 0; +} + +int config_pins(const void *blob, const char *pin_grp) +{ + int node; + + node = fdtdec_next_compatible(blob, 0, + COMPAT_ALTERA_SOCFPGA_PINCTRL_SINGLE); + + if (node < 0) + return 1; + + if (do_pinctrl_pins(blob, node, pin_grp)) + return 2; + + return 0; +}
This patch adding the Arria10 critical hardware initialization before enabling console print out in spl.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- arch/arm/mach-socfpga/spl.c | 79 +++++++++++++++++++++++++++++++++++++++++-- 1 files changed, 76 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach-socfpga/spl.c index fec4c7a..d381904 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -19,37 +19,58 @@ #include <asm/arch/sdram.h> #include <asm/arch/scu.h> #include <asm/arch/nic301.h> +#include <asm/sections.h> +#include <watchdog.h> +#include <fdtdec.h> +#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <asm/arch/pinmux.h> +#endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#define BOOTINFO_BSEL_SHIFT 0 +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#define BOOTINFO_BSEL_SHIFT 12 +#endif + +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = +#endif + +static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
u32 spl_boot_device(void) { const u32 bsel = readl(&sysmgr_regs->bootinfo);
- switch (bsel & 0x7) { + switch ((bsel >> BOOTINFO_BSEL_SHIFT) & 0x7) { case 0x1: /* FPGA (HPS2FPGA Bridge) */ return BOOT_DEVICE_RAM; case 0x2: /* NAND Flash (1.8V) */ case 0x3: /* NAND Flash (3.0V) */ +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) socfpga_per_reset(SOCFPGA_RESET(NAND), 0); +#endif return BOOT_DEVICE_NAND; case 0x4: /* SD/MMC External Transceiver (1.8V) */ case 0x5: /* SD/MMC Internal Transceiver (3.0V) */ +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) socfpga_per_reset(SOCFPGA_RESET(SDMMC), 0); socfpga_per_reset(SOCFPGA_RESET(DMA), 0); +#endif return BOOT_DEVICE_MMC1; case 0x6: /* QSPI Flash (1.8V) */ case 0x7: /* QSPI Flash (3.0V) */ +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) socfpga_per_reset(SOCFPGA_RESET(QSPI), 0); +#endif return BOOT_DEVICE_SPI; default: printf("Invalid boot device (bsel=%08x)!\n", bsel); @@ -68,6 +89,7 @@ u32 spl_boot_mode(const u32 boot_device) } #endif
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { writel(0x1, &nic301_regs->lwhps2fpgaregs); @@ -182,3 +204,54 @@ void board_init_f(ulong dummy) /* Configure simple malloc base pointer into RAM. */ gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); } +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +void board_init_f(ulong dummy) +{ + memset(__bss_start, 0, __bss_end - __bss_start); + /* + * Configure Clock Manager to use intosc clock instead external osc to + * ensure success watchdog operation. We do it as early as possible. + */ + cm_use_intosc(); + + watchdog_disable(); + + arch_early_init_r(); + +#ifdef CONFIG_HW_WATCHDOG + /* release osc1 watchdog timer 0 from reset */ + reset_deassert_osc1wd0(); + + /* reconfigure and enable the watchdog */ + hw_watchdog_init(); + WATCHDOG_RESET(); +#endif /* CONFIG_HW_WATCHDOG */ + +#ifdef CONFIG_OF_CONTROL + /* We need to access to FDT as this stage */ + /* FDT is at end of image */ + gd->fdt_blob = (void *)(__bss_end); + /* Check whether we have a valid FDT or not. */ + if (fdtdec_prepare_fdt()) { + panic("** CONFIG_OF_CONTROL defined but no FDT - please see " + "doc/README.fdt-control"); + } +#endif /* CONFIG_OF_CONTROL */ + + /* Initialize the timer */ + timer_init(); + + /* configuring the clock based on handoff */ + cm_basic_init(gd->fdt_blob); + WATCHDOG_RESET(); + + config_dedicated_pins(gd->fdt_blob); + WATCHDOG_RESET(); + + /* Release UART from reset */ + reset_deassert_uart(); + + /* enable console uart printing */ + preloader_console_init(); +} +#endif
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@kernel.org Cc: Chin Liang See chin.liang.see@intel.com Cc: Tien Fong skywindctf@gmail.com --- drivers/Makefile | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/Makefile b/drivers/Makefile index c19fa14..c15796b 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -9,7 +9,7 @@ obj-$(CONFIG_$(SPL_)PINCTRL) += pinctrl/ obj-$(CONFIG_$(SPL_)RAM) += ram/
ifdef CONFIG_SPL_BUILD - +obj-$(CONFIG_FPGA) += fpga/ obj-$(CONFIG_SPL_CRYPTO_SUPPORT) += crypto/ obj-$(CONFIG_SPL_I2C_SUPPORT) += i2c/ obj-$(CONFIG_SPL_GPIO_SUPPORT) += gpio/
On 01/09/2017 05:31 AM, Chee Tien Fong wrote:
Add base address header file for Stratix10 SoC
Signed-off-by: Chin Liang See clsee@altera.com Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com
arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 48 ++++++++++++++++++++ 1 files changed, 48 insertions(+), 0 deletions(-) create mode 100755 arch/arm/mach-socfpga/include/mach/base_addr_s10.h
While this is really nice to see, but can you separate this patch out from the Arria10 series. It's already confusing enough.
Dinh
arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 48 ++++++++++++++++++++ 1 files changed, 48 insertions(+), 0 deletions(-) create mode 100755 arch/arm/mach- socfpga/include/mach/base_addr_s10.h
Dinh
Ahh....this was rebased from 01-arria10. Okay, i will remove this patch.
Chee Tien Fong
Chee, Tien Fong
Dinh Nguyen
