[U-Boot] Pull request: nand flash master
The following changes since commit c851a2458fbc12495f4f786d4eabb612850a5143:
Merge git://git.denx.de/u-boot-socfpga (2015-08-23 20:44:25 -0400)
git://git.denx.de/u-boot-nand-flash.git
for you to fetch changes up to ecfb8768b16ebf6781ee0df45742674bda8a9543:
mtd: nand: mxs invalidate dcache before DMA read (2015-08-25 22:53:59 -0500)
---------------------------------------------------------------- Ezequiel Garcia (1): mtd: Introduce mtd_block_isreserved()
Peng Fan (2): mtd: nand: mxs support oobsize bigger than 512 mtd: nand: mxs invalidate dcache before DMA read
Scott Wood (2): nand: Remove __UBOOT__ ifdefs nand: Sync with Linux v4.1
Siva Durga Prasad Paladugu (1): mtd: nand: Increase max sizes of OOB and Page size
Stefan Roese (2): mtd: nand: Add mvebu (PXA / AXP / A38x) NAND device driver arm: mvebu: Enable NAND on db-mv784mp-gp
arch/arm/include/asm/imx-common/regs-bch.h | 2 + configs/db-mv784mp-gp_defconfig | 1 + drivers/mtd/mtdcore.c | 14 +- drivers/mtd/mtdpart.c | 9 + drivers/mtd/nand/Kconfig | 7 + drivers/mtd/nand/Makefile | 2 + drivers/mtd/nand/atmel_nand_ecc.h | 3 + drivers/mtd/nand/denali.c | 209 ++-- drivers/mtd/nand/denali.h | 8 +- drivers/mtd/nand/docg4.c | 6 +- drivers/mtd/nand/fsl_elbc_nand.c | 14 + drivers/mtd/nand/fsl_ifc_nand.c | 33 +- drivers/mtd/nand/mxs_nand.c | 38 +- drivers/mtd/nand/nand_base.c | 615 +++-------- drivers/mtd/nand/nand_bbt.c | 75 +- drivers/mtd/nand/nand_ids.c | 10 +- drivers/mtd/nand/nand_timings.c | 252 +++++ drivers/mtd/nand/pxa3xx_nand.c | 1621 ++++++++++++++++++++++++++++ drivers/mtd/nand/pxa3xx_nand.h | 64 ++ include/configs/db-mv784mp-gp.h | 5 + include/fsl_ifc.h | 2 + include/linux/mtd/mtd.h | 4 +- include/linux/mtd/nand.h | 126 ++- 23 files changed, 2448 insertions(+), 672 deletions(-) create mode 100644 drivers/mtd/nand/nand_timings.c create mode 100644 drivers/mtd/nand/pxa3xx_nand.c create mode 100644 drivers/mtd/nand/pxa3xx_nand.h
But please note that I now see: +(ph1_sld8,ph1_ld4,ph1_pro4) arm-none-eabi-ld.bfd: SPL image plus BSS too big
Which I'm hoping can be tuned to re-fit size constraints again easily enough.
mtd: nand: mxs invalidate dcache before DMA read (2015-08-25 22:53:59 - 0500)
They built OK for me, so they must be close enough that the toolchain makes a difference.
-Scott
Indeed. I'm using arm-none-eabi from Debian on that test box (since it will also build the armv7m targets).
2015-08-27 3:06 GMT+09:00 Tom Rini trini@konsulko.com:
These are my boards.
I will do something with them.
Hi Tom, Scott,
I've sent a patch to fix the root cause of this problem. http://patchwork.ozlabs.org/patch/511211/
Only my boards (ph1_ld4, ph1_sld8, ph1_pro4) define CONFIG_SPL_NAND_DENALI, and I tested the patch on them.
So, this patch should be safe.
Is it OK to apply it quickly?
On Thu, Aug 27, 2015 at 06:57:13PM +0900, Masahiro Yamada wrote:
Hi Tom, Scott,
Yes it is, thanks!
Masahiro Yamada
Scott Wood
