Re: [U-Boot] "Writing to MMC(%d)... failed"
Hello Nathan,
Sorry, I didn't reply last time, becouse I'm quite busy.
On 04/28/2015 07:39 AM, Nathan wrote:
Still not sure where the problem lies. I thought I found an issue, but it didn't fix anything and caused a different issue.
At first, after plugging in a bunch of printfs, I thought it was a simple issue in the dts (it appears not to be the issue):
Getting a little back into it, I find an issue in: "./lib/libfdt/fdt_ro.c" "fdt_path_offset()" where "-FDT_ERR_BADPATH" is returned for "path" = "sdhci@12530000" when: "./lib/fdtdec.c" "fdtdec_add_aliases_for_id()" is examining "mmc2"
"fdt_path_offset()" "_fdt_nodename_eq()" finds "aliases"
But the issue comes from "./lib/libfdt/fdt_ro.c" "_fdt_string_eq()" where "p" = "mmc2" <> "s" = "sdhci@12530000"
What I'm noticing different in the "exynos4412-odroid.dts" (odroid u2) and "exynos54xx.dtsi" is the "/" for the alias paths "mmc2" and "mmc4".
If I good remember, Exynos 54xx doesn't support sdhci, it has only dw mmc.
The problem with that "finding" was: "fdtdec_add_aliases_for_id: warning: alias 'mmc2' points to a node 'sdhci@12530000' that is missing or is not compatible with 'samsung,exynos-dwmmc'" Not sure why it would even mention dwmmc for mmc2 when it is specified "exynos-mmc" in "exynos4.dtsi"
A common issue with or without the slash is: "_gpio_request_by_name_nodev: Node 'sdhci@12530000', property 'pwr-gpios', failed to request GPIO index 0: -2"
The "pwr-gpio" is okay - the pin is not defined and not required here.
For this board's config, there are two mmc drivers: - exynos dwmmc(mmc/exynos_dw_mmc.c) - channel 0 - for eMMC card slot - s5p sdhci(mmc/s5p_sdhci.c) - channel 2 - for SD card slot Each driver has it's own compatible id, which you can see in the array: lib/fdtdec.c - > compat_names[COMPAT_COUNT]
Note: This is quite different like for the drivers, which support the driver model. We don't bind those drivers with the driver model yet.
So now we init those drivers, by call the board_mmc_init() in board/samsung/common/board.c - as you probably know - most of samsung boards in U-Boot uses this common file, beside it's own board file. If you not sure where to find the function, you can check, which common files are compiled for your config: cd board/samsung find -name "*.o"
I think the kicker is "No match for node 'sdhci@12530000'". I even manually set/forced the "status=okay" in the dts, but it still says it's disabled.
I shall continue to pursue this, working my way back from "lists_bind_fdt()" in "lists.c"
And now, back to the issue with the warning, which you mentioned. This is okay. I'm sure, that sdhci driver init is fine. You can study the function: fdtdec_add_aliases_for_id() from lib/fdtdec.c Remember, that this is the first introduced method for init the drivers with the FDT support. But we are going to move all subsystems into the driver model.
Let's look at the fdtdec_add_aliases_for_id(): - first we find all compatible nodes, - next we have an array "nodes[maxcount]" with the compatible nodes only - and next we look for the "path" for our "mmc*" aliases, but only for the compatible we can meet the condition: if (nodes[j] == node). This is way you get the warning when init DWMMC driver. This is ok.
Which compiler are you using? We often use this U-Boot with SD cards and no one have such issue before. What about your power supply? Do you have eMMC card? Any other accessory is connected?
Can you send me your binary (u-boot-dtb.bin)?
Przemyslaw Marczak
