Re: [U-Boot] Issues in U-BOOT for OMAPL137
Please don't top post, it really breaks up the flow of the conversation when people look at it later on. And please keep the list on CC.
On 13/05/11 06:31, shilpa jadav wrote:
I tried latest U-BOOT release from git://git.denx.de/u-boot.git or http://git.denx.de/u-boot.git
I am unable to compile it, i think da830/omapl137 support is not their in u-boot. I got the error as mentioned below when i give the command
u-boot# make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- da830_omapl137_config
The target you are after is da830evm_config. I know its there because I'm the board maintainer ;-)
$ grep da830evm boards.cfg da830evm arm arm926ejs da8xxevm davinci davinci
da830 is the name fo the omap-l137 which is not an OMAP but a Davinci device. omap-l137 is its TI marketing name.
Nick.
I get the error as:---
awk '(NF && $1 !~ /^#/) { print $1 ": " $1 "_config; $(MAKE)" }' boards.cfg
.boards.depend
make: *** No rule to make target `da830_omapl137_config'. Stop. make: *** [da830_omapl137_config] Error 1
Can you tell the release which is supporting da830/omapl137 with USB support.
Thanks, Shilpa
On Thu, May 12, 2011 at 2:30 PM, Nick Thompson nick.thompson@ge.com wrote:
On 11/05/11 10:15, shilpa jadav wrote:
Hi , When i am trying to compile u-boot for omapL137 by issuing the following command make da830_omapl137_evm_config CROSS_COMPILE=arm-none-linux-gnueabi-
Our goal is to get USB up on the uboot . We are trying to boot OMAPL137
Evm
using USB mass storage device(Pen drive) I have added the following macros in the /include/configs/da830_evm.h (followed the instructions from CHANGELOG file) #define CONFIG_CMD_USB 1 #define CONFIG_USB_STORAGE 1 #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_IXP4XX 1 #define CONFIG_EHCI_IS_TDI 1 #define CONFIG_EHCI_DESC_BIG_ENDIAN 1 #define CONFIG_EHCI_MMIO_BIG_ENDIAN 1 #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1 #define CONFIG_LEGACY_USB_INIT_SEQ 1
This is the error i am seeing consistently.
make[1]: Leaving directory
`/home/dataway/linux_bkup/kalyan/omapl137/DaVinci-PSP-SDK-03.20.00.08/src/u-boot/uboot-03.20.00.08/drivers/usb/musb'
make -C drivers/usb/host/ make[1]: Entering directory
`/home/dataway/linux_bkup/kalyan/omapl137/DaVinci-PSP-SDK-03.20.00.08/src/u-boot/uboot-03.20.00.08/drivers/usb/host'
make[1]: *** No rule to make target `.depend', needed by `libusb_host.a'. Stop. make[1]: Leaving directory
make: *** [drivers/usb/host/libusb_host.a] Error 2
Please help us solving this issue as this is very critical for our development
This u-boot version (from the DaVinci-PSP) is quite old now (2009.08) and, I believe, its da830/l137 code was never added to the community tree: community support started in Nov 2009 and USB support was added in Dec 2009. As such it can't be supported here.
As mentioned da830 EVM is supported by the community tree and I would encourage you to used the latest release from git://git.denx.de/u-boot.git or http://git.denx.de/u-boot.git
You can download snapshots, with a browser, from: http://git.denx.de/?p=u-boot.git;a=summary
Nick.
Nick Thompson
