[U-Boot] [PATCH] tools: Add Marvell recovery image download script
Introduce the recovery image download script for usage with Marvell Armada SoC families (excepting 37xx family). Since Marvell BootROM uses a sliding window in UART buffer for detecting escape sequence during the boot, it's easier to interrupt the normal boot flow by sending a long stream of chained escape sequences to the serial port instead of periodically sending a single escape sequence as it is done by kwboot utility. Additional benefit of using this script is the ability to adjust the escape sequence stream length withoiut need for compilation.
Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Stefan Roese sr@denx.de Cc: Igal Liberman igall@marvell.com --- tools/mrvl_uart.sh | 119 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 119 insertions(+) create mode 100755 tools/mrvl_uart.sh
diff --git a/tools/mrvl_uart.sh b/tools/mrvl_uart.sh new file mode 100755 index 0000000..6b04d7a --- /dev/null +++ b/tools/mrvl_uart.sh @@ -0,0 +1,119 @@ +#!/bin/bash +# +###################################################### +# Copyright (C) 2016 Marvell International Ltd. +# +# SPDX-License-Identifier: GPL-2.0 +# https://spdx.org/licenses +# +# Author: Konstantin Porotchkin kostap@marvell.com +# +# Version 0.3 +# +# UART recovery downloader for Armada SoCs +# +###################################################### + +port=$1 +file=$2 +speed=$3 + +pattern_repeat=1500 +default_baudrate=115200 +tmpfile=/tmp/xmodem.pattern +tools=( dd stty sx minicom ) + +case "$3" in + 2) + fast_baudrate=230400 + prefix="\xF2" + ;; + 4) + fast_baudrate=460800 + prefix="\xF4" + ;; + 8) + fast_baudrate=921600 + prefix="\xF8" + ;; + *) + fast_baudrate=$default_baudrate + prefix="\xBB" +esac + +if [[ -z "$port" || -z "$file" ]] +then + echo -e "\nMarvell recovery image downloader for Armada SoC family." + echo -e "Command syntax:" + echo -e "\t$(basename $0) <port> <file> [2|4|8]" + echo -e "\tport - serial port the target board connected to" + echo -e "\tfile - recovery boot image for target download" + echo -e "\t2|4|8 - times to increase the default serial port speed by" + echo -e "For example - load the image over ttyUSB0 @ 460800 baud:" + echo -e "$(basename $0) /dev/ttyUSB0 /tmp/flash-image.bin 4\n" + echo -e "=====WARNING=====" + echo -e "- The speed-up option is not awailable in SoC families prior to A8K+" + echo -e "- This utility is not compatible with Armada 37xx SoC family\n" +fi + +# Sanity checks +if [ -c "$port" ] +then + echo -e "Using device connected on serial port "$port"" +else + echo "Wrong serial port name!" + exit 1 +fi + +if [ -f "$file" ] +then + echo -e "Loading flash image file "$file"" +else + echo "File $file does not exist!" + exit 1 +fi + +# Verify required tools installation +for tool in ${tools[@]} +do + toolname=`which $tool` + if [ -z "$toolname" ] + then + echo -e "Missing installation of "$tool" --> Exiting" + exit 1 + fi +done + + +echo -e "Recovery will run at $fast_baudrate baud" +echo -e "========================================" + +if [ -f "$tmpfile" ] +then + rm -f $tmpfile +fi + +# Send the escape sequence to target board using default debug port speed +stty -F $port raw ignbrk time 5 $default_baudrate +counter=0 +while [ $counter -lt $pattern_repeat ]; do + echo -n -e "$prefix\x11\x22\x33\x44\x55\x66\x77" >> $tmpfile + let counter=counter+1 +done + +echo -en "Press the "Reset" button on the target board and " +echo -en "the "Enter" key on the host keyboard simultaneously" +read +dd if=$tmpfile of=$port &>/dev/null + +# Speed up the binary image transfer +stty -F $port raw ignbrk time 5 $fast_baudrate +sx -vv $file > $port < $port +#sx-at91 $port $file + +# return the port to the default speed +stty -F $port raw ignbrk time 5 $default_baudrate + +# Optional - fire up Minicom +minicom -D $port +
Applied to u-boot-marvell/master
Thanks, Stefan
kostap@marvell.com
Stefan Roese
