[U-Boot] [PATCH] unzip: return uncompressed size in `filesize', and print it.
The unzip command did not provide a way for the caller to get any information about the uncompressed size. To make it better usable in scripts, we now store the uncompressed size in the `filesize' variable, like we do when for example loading a file over the network or when reading it from a file system. Following that analogy, it is only consequent to also print the size.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_mem.c | 10 +++++++++- 1 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index ccf420a..54e581a 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -1212,6 +1212,8 @@ int do_unzip ( cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { unsigned long src, dst; unsigned long src_len = ~0UL, dst_len = ~0UL; + int rc; + char buf[32];
switch (argc) { case 4: @@ -1225,7 +1227,13 @@ int do_unzip ( cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return cmd_usage(cmdtp); }
- return !!gunzip((void *) dst, dst_len, (void *) src, &src_len); + rc = gunzip((void *) dst, dst_len, (void *) src, &src_len); + + printf("Uncompressed size: %ld = 0x%lX\n", src_len, src_len); + sprintf(buf, "%lX", src_len); + setenv("filesize", buf); + + return !!rc; } #endif /* CONFIG_CMD_UNZIP */
Hi Wolfgang,
- rc = gunzip((void *) dst, dst_len, (void *) src, &src_len);
- printf("Uncompressed size: %ld = 0x%lX\n", src_len, src_len);
- sprintf(buf, "%lX", src_len);
- setenv("filesize", buf);
- return !!rc;
What about: if (rc) return rc;
printf("Uncompressed size: %ld = 0x%lX\n", src_len, src_len); sprintf(buf, "%lX", src_len); setenv("filesize", buf);
This will prevent printing and setting of bogus values when an invalid or overly large image is unzipped.
Best, Peter
Dear Peter Tyser,
- return !!rc;
Good point, will fix. Thanks!
Signed-off-by: Wolfgang Denk wd@denx.de --- v2: return early in case of errors, set 'filesize' only on success. This also avoids the new 'rc' variable. Courtesy to Peter Tyser for pointing out.
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index ccf420a..4b524cf 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -1212,6 +1212,7 @@ int do_unzip ( cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { unsigned long src, dst; unsigned long src_len = ~0UL, dst_len = ~0UL; + char buf[32];
switch (argc) { case 4: @@ -1225,7 +1226,14 @@ int do_unzip ( cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return cmd_usage(cmdtp); }
- return !!gunzip((void *) dst, dst_len, (void *) src, &src_len); + if (gunzip((void *) dst, dst_len, (void *) src, &src_len) != 0) + return 1; + + printf("Uncompressed size: %ld = 0x%lX\n", src_len, src_len); + sprintf(buf, "%lX", src_len); + setenv("filesize", buf); + + return 0; } #endif /* CONFIG_CMD_UNZIP */
Dear Wolfgang Denk,
Applied, thanks.
Peter Tyser
