[U-Boot] [PATCH 1/2] spi: Zap ep93xx_spi driver and related code
Dropped becuase - driver and related configs not used any board. - no dm conversion.
Cc: Heiko Schocher hs@denx.de Cc: Sergey Kostanbaev sergey.kostanbaev@gmail.com Signed-off-by: Jagan Teki jagan@openedev.com --- board/cirrus/edb93xx/edb93xx.c | 98 --------------- drivers/spi/Makefile | 1 - drivers/spi/ep93xx_spi.c | 272 ----------------------------------------- include/configs/edb93xx.h | 10 -- scripts/config_whitelist.txt | 4 - 5 files changed, 385 deletions(-) delete mode 100644 drivers/spi/ep93xx_spi.c
diff --git a/board/cirrus/edb93xx/edb93xx.c b/board/cirrus/edb93xx/edb93xx.c index 8963d3a..51ff162 100644 --- a/board/cirrus/edb93xx/edb93xx.c +++ b/board/cirrus/edb93xx/edb93xx.c @@ -282,101 +282,3 @@ int dram_init(void) gd->ram_size = dram_init_banksize_int(1); return 0; } - - -#ifdef CONFIG_EP93XX_SPI -#include <spi.h> - -/* - * EGIO0-EGIPO7 -> port A - * EGIO8-EGIP15 -> port B - */ - -static void ep93xx_set_epgio(unsigned num) -{ - struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE; - if (num < 8) - writel(readl(®s->padr) | (1<<num), ®s->padr); - else - writel(readl(®s->pbdr) | (1<<(num-8)), ®s->pbdr); -} - -static void ep93xx_clear_epgio(unsigned num) -{ - struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE; - if (num < 8) - writel(readl(®s->padr) & (~(1<<num)), ®s->padr); - else - writel(readl(®s->pbdr) & (~(1<<(num-8))), ®s->pbdr); -} - -static void ep93xx_dir_epgio_out(unsigned num) -{ - struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE; - if (num < 8) - writel(readl(®s->paddr) | (1<<num), ®s->paddr); - else - writel(readl(®s->pbddr) | (1<<(num-8)), ®s->pbddr); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - if (bus == 0 && cs < 16) - return 1; - - return 0; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - ep93xx_clear_epgio(slave->cs); -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - ep93xx_set_epgio(slave->cs); -} - -#ifdef CONFIG_MMC_SPI -#include <mmc.h> - -#ifndef CONFIG_MMC_SPI_CS_EPGIO -# define CONFIG_MMC_SPI_CS_EPGIO 4 -#endif - -#ifndef CONFIG_MMC_SPI_SPEED -# define CONFIG_MMC_SPI_SPEED 25000000 -#endif - -#ifndef CONFIG_MMC_SPI_MODE -# define CONFIG_MMC_SPI_MODE SPI_MODE_0 -#endif - -int board_mmc_init(bd_t *bis) -{ - struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE; - - ep93xx_set_epgio(CONFIG_MMC_SPI_CS_EPGIO); - ep93xx_dir_epgio_out(CONFIG_MMC_SPI_CS_EPGIO); - -#ifdef CONFIG_MMC_SPI_POWER_EGPIO - ep93xx_dir_epgio_out(CONFIG_MMC_SPI_POWER_EGPIO); - ep93xx_set_epgio(CONFIG_MMC_SPI_POWER_EGPIO); -#elif defined(CONFIG_MMC_SPI_NPOWER_EGPIO) - ep93xx_dir_epgio_out(CONFIG_MMC_SPI_NPOWER_EGPIO); - ep93xx_clear_epgio(CONFIG_MMC_SPI_NPOWER_EGPIO); -#endif - struct mmc *mmc = mmc_spi_init(0, CONFIG_MMC_SPI_CS_EPGIO, - CONFIG_MMC_SPI_SPEED, CONFIG_MMC_SPI_MODE); - - if (!mmc) { - printf("Failed to create MMC Device\n"); - return 1; - } - mmc_init(mmc); - return 0; -} - - -#endif /* CONFIG_MMC_SPI */ -#endif /* CONFIG_EP93XX_SPI */ diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index c1ce158..521911b 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -26,7 +26,6 @@ obj-$(CONFIG_CF_SPI) += cf_spi.o obj-$(CONFIG_CF_QSPI) += cf_qspi.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o obj-$(CONFIG_DESIGNWARE_SPI) += designware_spi.o -obj-$(CONFIG_EP93XX_SPI) += ep93xx_spi.o obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o obj-$(CONFIG_FSL_DSPI) += fsl_dspi.o obj-$(CONFIG_FSL_ESPI) += fsl_espi.o diff --git a/drivers/spi/ep93xx_spi.c b/drivers/spi/ep93xx_spi.c deleted file mode 100644 index cb682dd..0000000 --- a/drivers/spi/ep93xx_spi.c +++ /dev/null @@ -1,272 +0,0 @@ -/* - * SPI Driver for EP93xx - * - * Copyright (C) 2013 Sergey Kostanabev <sergey.kostanbaev <at> fairwaves.ru> - * - * Inspired form linux kernel driver and atmel uboot driver - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <spi.h> -#include <malloc.h> - -#include <asm/io.h> - -#include <asm/arch/ep93xx.h> - -#define SSPBASE SPI_BASE - -#define SSPCR0 0x0000 -#define SSPCR0_MODE_SHIFT 6 -#define SSPCR0_SCR_SHIFT 8 -#define SSPCR0_SPH BIT(7) -#define SSPCR0_SPO BIT(6) -#define SSPCR0_FRF_SPI 0 -#define SSPCR0_DSS_8BIT 7 - -#define SSPCR1 0x0004 -#define SSPCR1_RIE BIT(0) -#define SSPCR1_TIE BIT(1) -#define SSPCR1_RORIE BIT(2) -#define SSPCR1_LBM BIT(3) -#define SSPCR1_SSE BIT(4) -#define SSPCR1_MS BIT(5) -#define SSPCR1_SOD BIT(6) - -#define SSPDR 0x0008 - -#define SSPSR 0x000c -#define SSPSR_TFE BIT(0) -#define SSPSR_TNF BIT(1) -#define SSPSR_RNE BIT(2) -#define SSPSR_RFF BIT(3) -#define SSPSR_BSY BIT(4) -#define SSPCPSR 0x0010 - -#define SSPIIR 0x0014 -#define SSPIIR_RIS BIT(0) -#define SSPIIR_TIS BIT(1) -#define SSPIIR_RORIS BIT(2) -#define SSPICR SSPIIR - -#define SSPCLOCK 14745600 -#define SSP_MAX_RATE (SSPCLOCK / 2) -#define SSP_MIN_RATE (SSPCLOCK / (254 * 256)) - -/* timeout in milliseconds */ -#define SPI_TIMEOUT 5 -/* maximum depth of RX/TX FIFO */ -#define SPI_FIFO_SIZE 8 - -struct ep93xx_spi_slave { - struct spi_slave slave; - - unsigned sspcr0; - unsigned sspcpsr; -}; - -static inline struct ep93xx_spi_slave *to_ep93xx_spi(struct spi_slave *slave) -{ - return container_of(slave, struct ep93xx_spi_slave, slave); -} - -void spi_init() -{ -} - -static inline void ep93xx_spi_write_u8(u16 reg, u8 value) -{ - writel(value, (unsigned int *)(SSPBASE + reg)); -} - -static inline u8 ep93xx_spi_read_u8(u16 reg) -{ - return readl((unsigned int *)(SSPBASE + reg)); -} - -static inline void ep93xx_spi_write_u16(u16 reg, u16 value) -{ - writel(value, (unsigned int *)(SSPBASE + reg)); -} - -static inline u16 ep93xx_spi_read_u16(u16 reg) -{ - return (u16)readl((unsigned int *)(SSPBASE + reg)); -} - -static int ep93xx_spi_init_hw(unsigned int rate, unsigned int mode, - struct ep93xx_spi_slave *slave) -{ - unsigned cpsr, scr; - - if (rate > SSP_MAX_RATE) - rate = SSP_MAX_RATE; - - if (rate < SSP_MIN_RATE) - return -1; - - /* Calculate divisors so that we can get speed according the - * following formula: - * rate = spi_clock_rate / (cpsr * (1 + scr)) - * - * cpsr must be even number and starts from 2, scr can be any number - * between 0 and 255. - */ - for (cpsr = 2; cpsr <= 254; cpsr += 2) { - for (scr = 0; scr <= 255; scr++) { - if ((SSPCLOCK / (cpsr * (scr + 1))) <= rate) { - /* Set CHPA and CPOL, SPI format and 8bit */ - unsigned sspcr0 = (scr << SSPCR0_SCR_SHIFT) | - SSPCR0_FRF_SPI | SSPCR0_DSS_8BIT; - if (mode & SPI_CPHA) - sspcr0 |= SSPCR0_SPH; - if (mode & SPI_CPOL) - sspcr0 |= SSPCR0_SPO; - - slave->sspcr0 = sspcr0; - slave->sspcpsr = cpsr; - return 0; - } - } - } - - return -1; -} - -void spi_set_speed(struct spi_slave *slave, unsigned int hz) -{ - struct ep93xx_spi_slave *as = to_ep93xx_spi(slave); - - unsigned int mode = 0; - if (as->sspcr0 & SSPCR0_SPH) - mode |= SPI_CPHA; - if (as->sspcr0 & SSPCR0_SPO) - mode |= SPI_CPOL; - - ep93xx_spi_init_hw(hz, mode, as); -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct ep93xx_spi_slave *as; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - as = spi_alloc_slave(struct ep93xx_spi_slave, bus, cs); - if (!as) - return NULL; - - if (ep93xx_spi_init_hw(max_hz, mode, as)) { - free(as); - return NULL; - } - - return &as->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct ep93xx_spi_slave *as = to_ep93xx_spi(slave); - - free(as); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct ep93xx_spi_slave *as = to_ep93xx_spi(slave); - - /* Enable the SPI hardware */ - ep93xx_spi_write_u8(SSPCR1, SSPCR1_SSE); - - - ep93xx_spi_write_u8(SSPCPSR, as->sspcpsr); - ep93xx_spi_write_u16(SSPCR0, as->sspcr0); - - debug("Select CS:%d SSPCPSR=%02x SSPCR0=%04x\n", - slave->cs, as->sspcpsr, as->sspcr0); - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ - /* Disable the SPI hardware */ - ep93xx_spi_write_u8(SSPCR1, 0); -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - unsigned int len_tx; - unsigned int len_rx; - unsigned int len; - u32 status; - const u8 *txp = dout; - u8 *rxp = din; - u8 value; - - debug("spi_xfer: slave %u:%u dout %p din %p bitlen %u\n", - slave->bus, slave->cs, (uint *)dout, (uint *)din, bitlen); - - - if (bitlen == 0) - /* Finish any previously submitted transfers */ - goto out; - - if (bitlen % 8) { - /* Errors always terminate an ongoing transfer */ - flags |= SPI_XFER_END; - goto out; - } - - len = bitlen / 8; - - - if (flags & SPI_XFER_BEGIN) { - /* Empty RX FIFO */ - while ((ep93xx_spi_read_u8(SSPSR) & SSPSR_RNE)) - ep93xx_spi_read_u8(SSPDR); - - spi_cs_activate(slave); - } - - for (len_tx = 0, len_rx = 0; len_rx < len; ) { - status = ep93xx_spi_read_u8(SSPSR); - - if ((len_tx < len) && (status & SSPSR_TNF)) { - if (txp) - value = *txp++; - else - value = 0xff; - - ep93xx_spi_write_u8(SSPDR, value); - len_tx++; - } - - if (status & SSPSR_RNE) { - value = ep93xx_spi_read_u8(SSPDR); - - if (rxp) - *rxp++ = value; - len_rx++; - } - } - -out: - if (flags & SPI_XFER_END) { - /* - * Wait until the transfer is completely done before - * we deactivate CS. - */ - do { - status = ep93xx_spi_read_u8(SSPSR); - } while (status & SSPSR_BSY); - - spi_cs_deactivate(slave); - } - - return 0; -} diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index a83c617..9080b9a 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -229,16 +229,6 @@ #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
-/* Define to enable MMC on SPI support */ -/* #define CONFIG_EP93XX_SPI_MMC */ - -#ifdef CONFIG_EP93XX_SPI_MMC -#define CONFIG_EP93XX_SPI -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC_SPI -#define CONFIG_MMC_SPI_NPOWER_EGPIO 9 -#endif - #define CONFIG_USB_OHCI_NEW #define CONFIG_USB_OHCI_EP93XX #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 6d614c6..2533e26 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1098,8 +1098,6 @@ CONFIG_EP9312 CONFIG_EP9315 CONFIG_EP93XX CONFIG_EP93XX_NO_FLASH_CFG -CONFIG_EP93XX_SPI -CONFIG_EP93XX_SPI_MMC CONFIG_EPH_POWER_EN CONFIG_EPOLL CONFIG_ESBC_ADDR_64BIT @@ -3078,8 +3076,6 @@ CONFIG_MMC_SPI_CRC_ON CONFIG_MMC_SPI_CS CONFIG_MMC_SPI_CS_EPGIO CONFIG_MMC_SPI_MODE -CONFIG_MMC_SPI_NPOWER_EGPIO -CONFIG_MMC_SPI_POWER_EGPIO CONFIG_MMC_SPI_SPEED CONFIG_MMC_SUNXI CONFIG_MMC_SUNXI_SLOT
Dropped becuase - driver not used any board. - no dm conversion.
Cc: Angelo Dureghello angelo@sysam.it Cc: Richard Retanubun richardretanubun@ruggedcom.com Signed-off-by: Jagan Teki jagan@openedev.com --- arch/m68k/cpu/mcf52x2/cpu_init.c | 12 -- drivers/spi/Makefile | 1 - drivers/spi/cf_qspi.c | 354 --------------------------------------- drivers/spi/cf_spi.c | 4 - scripts/config_whitelist.txt | 1 - 5 files changed, 372 deletions(-) delete mode 100644 drivers/spi/cf_qspi.c
diff --git a/arch/m68k/cpu/mcf52x2/cpu_init.c b/arch/m68k/cpu/mcf52x2/cpu_init.c index edcb092..7b66720 100644 --- a/arch/m68k/cpu/mcf52x2/cpu_init.c +++ b/arch/m68k/cpu/mcf52x2/cpu_init.c @@ -318,18 +318,6 @@ int fecpin_setclear(struct eth_device *dev, int setclear) } #endif /* CONFIG_CMD_NET */
-#if defined(CONFIG_CF_QSPI) - -/* Configure PIOs for SIN, SOUT, and SCK */ -void cfspi_port_conf(void) -{ - mbar_writeByte(MCF_GPIO_PAR_QSPI, - MCF_GPIO_PAR_QSPI_SIN_SIN | - MCF_GPIO_PAR_QSPI_SOUT_SOUT | - MCF_GPIO_PAR_QSPI_SCK_SCK); -} -#endif /* CONFIG_CF_QSPI */ - #endif /* CONFIG_M5271 */
#if defined(CONFIG_M5272) diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 521911b..896b093 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -23,7 +23,6 @@ obj-$(CONFIG_BFIN_SPI) += bfin_spi.o obj-$(CONFIG_BFIN_SPI6XX) += bfin_spi6xx.o obj-$(CONFIG_CADENCE_QSPI) += cadence_qspi.o cadence_qspi_apb.o obj-$(CONFIG_CF_SPI) += cf_spi.o -obj-$(CONFIG_CF_QSPI) += cf_qspi.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o obj-$(CONFIG_DESIGNWARE_SPI) += designware_spi.o obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o diff --git a/drivers/spi/cf_qspi.c b/drivers/spi/cf_qspi.c deleted file mode 100644 index e57e63e..0000000 --- a/drivers/spi/cf_qspi.c +++ /dev/null @@ -1,354 +0,0 @@ -/* - * Freescale Coldfire Queued SPI driver - * - * NOTE: - * This driver is written to transfer 8 bit at-a-time and uses the dedicated - * SPI slave select pins as bit-banged GPIO to work with spi_flash subsystem. - * - * Copyright (C) 2011 Ruggedcom, Inc. - * Richard Retanubun (richardretanubun@freescale.com) - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <malloc.h> -#include <spi.h> -#include <asm/immap.h> -#include <asm/io.h> - -DECLARE_GLOBAL_DATA_PTR; - -#define to_cf_qspi_slave(s) container_of(s, struct cf_qspi_slave, slave) - -struct cf_qspi_slave { - struct spi_slave slave; /* Specific bus:cs ID for each device */ - qspi_t *regs; /* Pointer to SPI controller registers */ - u16 qmr; /* QMR: Queued Mode Register */ - u16 qwr; /* QWR: Queued Wrap Register */ - u16 qcr; /* QCR: Queued Command Ram */ -}; - -/* Register write wrapper functions */ -static void write_qmr(volatile qspi_t *qspi, u16 val) { qspi->mr = val; } -static void write_qdlyr(volatile qspi_t *qspi, u16 val) { qspi->dlyr = val; } -static void write_qwr(volatile qspi_t *qspi, u16 val) { qspi->wr = val; } -static void write_qir(volatile qspi_t *qspi, u16 val) { qspi->ir = val; } -static void write_qar(volatile qspi_t *qspi, u16 val) { qspi->ar = val; } -static void write_qdr(volatile qspi_t *qspi, u16 val) { qspi->dr = val; } -/* Register read wrapper functions */ -static u16 read_qdlyr(volatile qspi_t *qspi) { return qspi->dlyr; } -static u16 read_qwr(volatile qspi_t *qspi) { return qspi->wr; } -static u16 read_qir(volatile qspi_t *qspi) { return qspi->ir; } -static u16 read_qdr(volatile qspi_t *qspi) { return qspi->dr; } - -/* These call points may be different for each ColdFire CPU */ -extern void cfspi_port_conf(void); -static void cfspi_cs_activate(uint bus, uint cs, uint cs_active_high); -static void cfspi_cs_deactivate(uint bus, uint cs, uint cs_active_high); - -int spi_claim_bus(struct spi_slave *slave) -{ - return 0; -} -void spi_release_bus(struct spi_slave *slave) -{ -} - -__attribute__((weak)) -void spi_init(void) -{ - cfspi_port_conf(); -} - -__attribute__((weak)) -void spi_cs_activate(struct spi_slave *slave) -{ - struct cf_qspi_slave *dev = to_cf_qspi_slave(slave); - - cfspi_cs_activate(slave->bus, slave->cs, !(dev->qwr & QSPI_QWR_CSIV)); -} - -__attribute__((weak)) -void spi_cs_deactivate(struct spi_slave *slave) -{ - struct cf_qspi_slave *dev = to_cf_qspi_slave(slave); - - cfspi_cs_deactivate(slave->bus, slave->cs, !(dev->qwr & QSPI_QWR_CSIV)); -} - -__attribute__((weak)) -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - /* Only 1 bus and 4 chipselect per controller */ - if (bus == 0 && (cs >= 0 && cs < 4)) - return 1; - else - return 0; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct cf_qspi_slave *dev = to_cf_qspi_slave(slave); - - free(dev); -} - -/* Translate information given by spi_setup_slave to members of cf_qspi_slave */ -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct cf_qspi_slave *dev = NULL; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - dev = spi_alloc_slave(struct cf_qspi_slave, bus, cs); - if (!dev) - return NULL; - - /* Initialize to known value */ - dev->regs = (qspi_t *)MMAP_QSPI; - dev->qmr = 0; - dev->qwr = 0; - dev->qcr = 0; - - - /* Map max_hz to QMR[BAUD] */ - if (max_hz == 0) /* Go as fast as possible */ - dev->qmr = 2u; - else /* Get the closest baud rate */ - dev->qmr = clamp(((gd->bus_clk >> 2) + max_hz - 1)/max_hz, - 2lu, 255lu); - - /* Map mode to QMR[CPOL] and QMR[CPHA] */ - if (mode & SPI_CPOL) - dev->qmr |= QSPI_QMR_CPOL; - - if (mode & SPI_CPHA) - dev->qmr |= QSPI_QMR_CPHA; - - /* Hardcode bit length to 8 bit per transter */ - dev->qmr |= QSPI_QMR_BITS_8; - - /* Set QMR[MSTR] to enable QSPI as master */ - dev->qmr |= QSPI_QMR_MSTR; - - /* - * Set QCR and QWR to default values for spi flash operation. - * If more custom QCR and QRW are needed, overload mode variable - */ - dev->qcr = (QSPI_QDR_CONT | QSPI_QDR_BITSE); - - if (!(mode & SPI_CS_HIGH)) - dev->qwr |= QSPI_QWR_CSIV; - - return &dev->slave; -} - -/* Transfer 8 bit at a time */ -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, - void *din, unsigned long flags) -{ - struct cf_qspi_slave *dev = to_cf_qspi_slave(slave); - volatile qspi_t *qspi = dev->regs; - u8 *txbuf = (u8 *)dout; - u8 *rxbuf = (u8 *)din; - u32 count = DIV_ROUND_UP(bitlen, 8); - u32 n, i = 0; - - /* Sanitize arguments */ - if (slave == NULL) { - printf("%s: NULL slave ptr\n", __func__); - return -1; - } - - if (flags & SPI_XFER_BEGIN) - spi_cs_activate(slave); - - /* There is something to send, lets process it. spi_xfer is also called - * just to toggle chip select, so bitlen of 0 is valid */ - if (count > 0) { - /* - * NOTE: Since chip select is driven as a bit-bang-ed GPIO - * using spi_cs_activate() and spi_cs_deactivate(), - * the chip select settings inside the controller - * (i.e. QCR[CONT] and QWR[CSIV]) are moot. The bits are set to - * keep the controller settings consistent with the actual - * operation of the bus. - */ - - /* Write the slave device's settings for the controller.*/ - write_qmr(qspi, dev->qmr); - write_qwr(qspi, dev->qwr); - - /* Limit transfer to 16 at a time */ - n = min(count, 16u); - do { - /* Setup queue end point */ - write_qwr(qspi, ((read_qwr(qspi) & QSPI_QWR_ENDQP_MASK) - | QSPI_QWR_ENDQP((n-1)))); - - /* Write Command RAM */ - write_qar(qspi, QSPI_QAR_CMD); - for (i = 0; i < n; ++i) - write_qdr(qspi, dev->qcr); - - /* Write TxBuf, if none given, fill with ZEROes */ - write_qar(qspi, QSPI_QAR_TRANS); - if (txbuf) { - for (i = 0; i < n; ++i) - write_qdr(qspi, *txbuf++); - } else { - for (i = 0; i < n; ++i) - write_qdr(qspi, 0); - } - - /* Clear QIR[SPIF] by writing a 1 to it */ - write_qir(qspi, read_qir(qspi) | QSPI_QIR_SPIF); - /* Set QDLYR[SPE] to start sending */ - write_qdlyr(qspi, read_qdlyr(qspi) | QSPI_QDLYR_SPE); - - /* Poll QIR[SPIF] for transfer completion */ - while ((read_qir(qspi) & QSPI_QIR_SPIF) != 1) - udelay(1); - - /* If given read RxBuf, load data to it */ - if (rxbuf) { - write_qar(qspi, QSPI_QAR_RECV); - for (i = 0; i < n; ++i) - *rxbuf++ = read_qdr(qspi); - } - - /* Decrement count */ - count -= n; - } while (count); - } - - if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); - - return 0; -} - -/* Each MCF CPU may have different pin assignments for chip selects. */ -#if defined(CONFIG_M5271) -/* Assert chip select, val = [1|0] , dir = out, mode = GPIO */ -void cfspi_cs_activate(uint bus, uint cs, uint cs_active_high) -{ - debug("%s: bus %d cs %d cs_active_high %d\n", - __func__, bus, cs, cs_active_high); - - switch (cs) { - case 0: /* QSPI_CS[0] = PQSPI[3] */ - if (cs_active_high) - mbar_writeByte(MCF_GPIO_PPDSDR_QSPI, 0x08); - else - mbar_writeByte(MCF_GPIO_PCLRR_QSPI, 0xF7); - - mbar_writeByte(MCF_GPIO_PDDR_QSPI, - mbar_readByte(MCF_GPIO_PDDR_QSPI) | 0x08); - - mbar_writeByte(MCF_GPIO_PAR_QSPI, - mbar_readByte(MCF_GPIO_PAR_QSPI) & 0xDF); - break; - case 1: /* QSPI_CS[1] = PQSPI[4] */ - if (cs_active_high) - mbar_writeByte(MCF_GPIO_PPDSDR_QSPI, 0x10); - else - mbar_writeByte(MCF_GPIO_PCLRR_QSPI, 0xEF); - - mbar_writeByte(MCF_GPIO_PDDR_QSPI, - mbar_readByte(MCF_GPIO_PDDR_QSPI) | 0x10); - - mbar_writeByte(MCF_GPIO_PAR_QSPI, - mbar_readByte(MCF_GPIO_PAR_QSPI) & 0x3F); - break; - case 2: /* QSPI_CS[2] = PTIMER[7] */ - if (cs_active_high) - mbar_writeByte(MCF_GPIO_PPDSDR_TIMER, 0x80); - else - mbar_writeByte(MCF_GPIO_PCLRR_TIMER, 0x7F); - - mbar_writeByte(MCF_GPIO_PDDR_TIMER, - mbar_readByte(MCF_GPIO_PDDR_TIMER) | 0x80); - - mbar_writeShort(MCF_GPIO_PAR_TIMER, - mbar_readShort(MCF_GPIO_PAR_TIMER) & 0x3FFF); - break; - case 3: /* QSPI_CS[3] = PTIMER[3] */ - if (cs_active_high) - mbar_writeByte(MCF_GPIO_PPDSDR_TIMER, 0x08); - else - mbar_writeByte(MCF_GPIO_PCLRR_TIMER, 0xF7); - - mbar_writeByte(MCF_GPIO_PDDR_TIMER, - mbar_readByte(MCF_GPIO_PDDR_TIMER) | 0x08); - - mbar_writeShort(MCF_GPIO_PAR_TIMER, - mbar_readShort(MCF_GPIO_PAR_TIMER) & 0xFF3F); - break; - } -} - -/* Deassert chip select, val = [1|0], dir = in, mode = GPIO - * direction set as IN to undrive the pin, external pullup/pulldown will bring - * bus to deassert state. - */ -void cfspi_cs_deactivate(uint bus, uint cs, uint cs_active_high) -{ - debug("%s: bus %d cs %d cs_active_high %d\n", - __func__, bus, cs, cs_active_high); - - switch (cs) { - case 0: /* QSPI_CS[0] = PQSPI[3] */ - if (cs_active_high) - mbar_writeByte(MCF_GPIO_PCLRR_QSPI, 0xF7); - else - mbar_writeByte(MCF_GPIO_PPDSDR_QSPI, 0x08); - - mbar_writeByte(MCF_GPIO_PDDR_QSPI, - mbar_readByte(MCF_GPIO_PDDR_QSPI) & 0xF7); - - mbar_writeByte(MCF_GPIO_PAR_QSPI, - mbar_readByte(MCF_GPIO_PAR_QSPI) & 0xDF); - break; - case 1: /* QSPI_CS[1] = PQSPI[4] */ - if (cs_active_high) - mbar_writeByte(MCF_GPIO_PCLRR_QSPI, 0xEF); - else - mbar_writeByte(MCF_GPIO_PPDSDR_QSPI, 0x10); - - mbar_writeByte(MCF_GPIO_PDDR_QSPI, - mbar_readByte(MCF_GPIO_PDDR_QSPI) & 0xEF); - - mbar_writeByte(MCF_GPIO_PAR_QSPI, - mbar_readByte(MCF_GPIO_PAR_QSPI) & 0x3F); - break; - case 2: /* QSPI_CS[2] = PTIMER[7] */ - if (cs_active_high) - mbar_writeByte(MCF_GPIO_PCLRR_TIMER, 0x7F); - else - mbar_writeByte(MCF_GPIO_PPDSDR_TIMER, 0x80); - - mbar_writeByte(MCF_GPIO_PDDR_TIMER, - mbar_readByte(MCF_GPIO_PDDR_TIMER) & 0x7F); - - mbar_writeShort(MCF_GPIO_PAR_TIMER, - mbar_readShort(MCF_GPIO_PAR_TIMER) & 0x3FFF); - break; - case 3: /* QSPI_CS[3] = PTIMER[3] */ - if (cs_active_high) - mbar_writeByte(MCF_GPIO_PCLRR_TIMER, 0xF7); - else - mbar_writeByte(MCF_GPIO_PPDSDR_TIMER, 0x08); - - mbar_writeByte(MCF_GPIO_PDDR_TIMER, - mbar_readByte(MCF_GPIO_PDDR_TIMER) & 0xF7); - - mbar_writeShort(MCF_GPIO_PAR_TIMER, - mbar_readShort(MCF_GPIO_PAR_TIMER) & 0xFF3F); - break; - } -} -#endif /* CONFIG_M5271 */ diff --git a/drivers/spi/cf_spi.c b/drivers/spi/cf_spi.c index 6ce1101..7be9427 100644 --- a/drivers/spi/cf_spi.c +++ b/drivers/spi/cf_spi.c @@ -279,10 +279,6 @@ static struct spi_slave *cfspi_setup_slave(struct cf_spi_slave *cfslave, } #endif /* CONFIG_CF_DSPI */
-#ifdef CONFIG_CF_QSPI -/* 52xx, 53xx */ -#endif /* CONFIG_CF_QSPI */ - #ifdef CONFIG_CMD_SPI int spi_cs_is_valid(unsigned int bus, unsigned int cs) { diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2533e26..5fbb7b1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -490,7 +490,6 @@ CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS CONFIG_CF_ATASEL_DIS CONFIG_CF_ATASEL_ENA CONFIG_CF_DSPI -CONFIG_CF_QSPI CONFIG_CF_SBF CONFIG_CF_SPI CONFIG_CF_V2
Hi Jagan,
On 02/01/2017 23:29, Jagan Teki wrote:
Dropped becuase
- no dm conversion.
- Freescale Coldfire Queued SPI driver
- NOTE:
- This driver is written to transfer 8 bit at-a-time and uses the dedicated
- SPI slave select pins as bit-banged GPIO to work with spi_flash subsystem.
- Copyright (C) 2011 Ruggedcom, Inc.
- Richard Retanubun (richardretanubun@freescale.com)
return 1;
- else
- free(dev);
return NULL;
- if (!dev)
return NULL;
- dev->qmr = 0;
- dev->qwr = 0;
- dev->qcr = 0;
dev->qmr = 2u;
2lu, 255lu);
- u32 n, i = 0;
return -1;
- if (count > 0) {
do {
if (txbuf) {
} else {
write_qdr(qspi, 0);
udelay(1);
if (rxbuf) {
count -= n;
} while (count);
- switch (cs) {
if (cs_active_high)
else
break;
if (cs_active_high)
else
break;
if (cs_active_high)
else
break;
if (cs_active_high)
else
break;
- direction set as IN to undrive the pin, external pullup/pulldown will bring
- bus to deassert state.
- switch (cs) {
if (cs_active_high)
else
break;
if (cs_active_high)
else
break;
if (cs_active_high)
else
break;
if (cs_active_high)
else
break;
Good cleanup for me. Thanks. I just verified that no Coldfire board is actually using this driver.
Acked-by: Angelo Dureghello angelo@sysam.it
Best regards, Angelo Dureghello
Angelo Dureghello
Jagan Teki
