[U-Boot] [PATCH 0/8] rockchip: enable spl/tpl for px5-evb
This patch set enable spl/tpl and also suppot ATF elf, and the timer is using rockchip timer, we may switch to stimer based ARM generic timer later if we get STIMER patches mergerd.
Kever Yang (8): rockchip: rk3368: support UART2/4 in board_debug_uart_init() rockchip: px5 update dts for spl/tpl rockchip: px5: update SPL size for spl/tpl rockchip: px5: update defconfig for TPL/SPL rockchip: boot0: update CONFIG_ROCKCHIP_SPL_RESERVE_IRAM for SPL only rockchip: dmc: rk3368: update rank number for evb-px5 rockchip: rk3368: remove uart iomux init in SPL rockchip: px5: add timer0 dts node as tick timer
arch/arm/dts/rk3368-px5-evb-u-boot.dtsi | 36 ++++++++++++++ arch/arm/include/asm/arch-rockchip/boot0.h | 3 +- arch/arm/mach-rockchip/rk3368-board-spl.c | 13 ----- arch/arm/mach-rockchip/rk3368/rk3368.c | 40 ++++++++++++++++ configs/evb-px5_defconfig | 56 +++++++++++++++++++++- drivers/ram/rockchip/dmc-rk3368.c | 4 ++ include/configs/evb_px5.h | 1 + include/configs/rk3368_common.h | 3 +- 8 files changed, 139 insertions(+), 17 deletions(-)
evb-rk3368 is using UART2 and PX5 evb is using UART4
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/rk3368/rk3368.c | 40 ++++++++++++++++++++++++++ 1 file changed, 40 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index 1ed06c5352..f06d27717d 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -124,6 +124,46 @@ void board_debug_uart_init(void) GPIO2D0_MASK, GPIO2D0_UART0_SIN); rk_clrsetreg(&grf->gpio2d_iomux, GPIO2D1_MASK, GPIO2D1_UART0_SOUT); +#elif defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff1c0000) + struct rk3368_pmu_grf * const pmugrf __maybe_unused = + (struct rk3368_pmu_grf * const)0xff738000; + + enum { + /* UART4 */ + GPIO0D2_MASK = GENMASK(5, 4), + GPIO0D2_GPIO = 0, + GPIO0D2_UART4_SOUT = (3 << 4), + + GPIO0D3_MASK = GENMASK(7, 6), + GPIO0D3_GPIO = 0, + GPIO0D3_UART4_SIN = (3 << 6), + }; + + /* Enable early UART4 on the PX5 */ + rk_clrsetreg(&pmugrf->gpio0d_iomux, + GPIO0D2_MASK | GPIO0D3_MASK, + GPIO0D2_UART4_SOUT | GPIO0D3_UART4_SIN); +#elif defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff690000) + struct rk3368_grf * const grf = + (struct rk3368_grf * const)0xff770000; + + enum { + GPIO2A6_SHIFT = 12, + GPIO2A6_MASK = GENMASK(13, 12), + GPIO2A6_GPIO = 0, + GPIO2A6_UART2_SIN = (2 << GPIO2A6_SHIFT), + + GPIO2A5_SHIFT = 10, + GPIO2A5_MASK = GENMASK(11, 10), + GPIO2A5_GPIO = 0, + GPIO2A5_UART2_SOUT = (2 << GPIO2A5_SHIFT), + }; + + /* Enable early UART2 on the RK3368 */ + rk_clrsetreg(&grf->gpio2a_iomux, + GPIO2A6_MASK, GPIO2A6_UART2_SIN); + rk_clrsetreg(&grf->gpio2a_iomux, + GPIO2A5_MASK, GPIO2A5_UART2_SOUT); #endif } #endif
Kever Yang kever.yang@rock-chips.com 于2019年3月29日周五 下午10:54写道:
Tested-by: Andy Yan andy.yan@rock-chips.com
enum {
/* UART4 */
GPIO0D2_GPIO = 0,
GPIO0D3_GPIO = 0,
enum {
GPIO2A6_SHIFT = 12,
GPIO2A6_GPIO = 0,
GPIO2A5_SHIFT = 10,
GPIO2A5_GPIO = 0,
#endif }
#endif
2.20.1
TPL need dmc to init ddr sdram, and emmc, boot-order.
arch/arm/dts/rk3368-px5-evb-u-boot.dtsi | 29 +++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi b/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi index 7495781454..18b841864c 100644 --- a/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi @@ -2,6 +2,27 @@ /* * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH */ +/ { + chosen { + u-boot,spl-boot-order = &emmc; + }; +}; + +&dmc { + u-boot,dm-pre-reloc; + + /* + * PX5-evb(2GB) need to use CBRD mode, or else the dram is not correct + * See doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt for + * details on the 'rockchip,memory-schedule' property and how it + * affects the physical-address to device-address mapping. + */ + rockchip,memory-schedule = <DMC_MSCH_CBRD>; + rockchip,ddr-frequency = <800000000>; + rockchip,ddr-speed-bin = <DDR3_1600K>; + + status = "okay"; +};
&pinctrl { u-boot,dm-pre-reloc; @@ -20,6 +41,10 @@ u-boot,dm-pre-reloc; };
+&sgrf { + u-boot,dm-pre-reloc; +}; + &cru { u-boot,dm-pre-reloc; }; @@ -31,3 +56,7 @@ &uart4 { u-boot,dm-pre-reloc; }; + +&emmc { + u-boot,dm-pre-reloc; +};
Kever Yang kever.yang@rock-chips.com 于2019年3月29日周五 下午10:52写道:
- (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH
chosen {
+&dmc {
correct
status = "okay";
+&sgrf {
+&emmc {
2.20.1
include/configs/evb_px5.h | 1 + include/configs/rk3368_common.h | 3 ++- 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/evb_px5.h b/include/configs/evb_px5.h index e67bee1721..e9304206bb 100644 --- a/include/configs/evb_px5.h +++ b/include/configs/evb_px5.h @@ -9,5 +9,6 @@ #include <configs/rk3368_common.h>
#define CONFIG_CONSOLE_SCROLL_LINES 10 +#define CONFIG_SYS_MMC_ENV_DEV 0
#endif diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 5aa598287a..bb5490c3c2 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -28,9 +28,10 @@ #define CONFIG_SYS_LOAD_ADDR 0x00280000
#define CONFIG_SPL_TEXT_BASE 0x00000000 -#define CONFIG_SPL_MAX_SIZE 0x40000 +#define CONFIG_SPL_MAX_SIZE 0x60000 #define CONFIG_SPL_BSS_START_ADDR 0x400000 #define CONFIG_SPL_BSS_MAX_SIZE 0x20000 +#define CONFIG_SPL_STACK 0x00188000
#ifndef CONFIG_SPL_BUILD #define ENV_MEM_LAYOUT_SETTINGS \
Kever Yang kever.yang@rock-chips.com 于2019年3月29日周五 下午10:55写道:
2.20.1
configs/evb-px5_defconfig | 56 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 54 insertions(+), 2 deletions(-)
diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 1d428e7ac8..f99943de08 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -1,30 +1,82 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 -CONFIG_SYS_MALLOC_F_LEN=0x1000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3368=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x40000 +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_TARGET_EVB_PX5=y +CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xFF1c0000 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ANDROID_BOOT_IMAGE=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_BOOTSTAGE=y +CONFIG_SPL_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_BOOTSTAGE_FDT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-px5-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_SPL_BOOTROM_SUPPORT=y +# CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL=y +CONFIG_TPL_LDSCRIPT="arch/arm/mach-rockchip/u-boot-tpl-v8.lds" +CONFIG_TPL_BOOTROM_SUPPORT=y CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="rk3368-px5-evb" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_TPL_CLK=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DM_RESET=y CONFIG_DEBUG_UART_SHIFT=2 -CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_SYSRESET=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_TPL_TIMER=y +CONFIG_ROCKCHIP_TIMER=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_PANIC_HANG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y
diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 1d428e7ac8..f99943de08 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -1,30 +1,82 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 -CONFIG_SYS_MALLOC_F_LEN=0x1000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3368=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x40000 +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_TARGET_EVB_PX5=y +CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xFF1c0000 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ANDROID_BOOT_IMAGE=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_BOOTSTAGE=y +CONFIG_SPL_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_BOOTSTAGE_FDT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-px5-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_SPL_BOOTROM_SUPPORT=y +# CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL=y +CONFIG_TPL_LDSCRIPT="arch/arm/mach-rockchip/u-boot-tpl-v8.lds" +CONFIG_TPL_BOOTROM_SUPPORT=y CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="rk3368-px5-evb" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_TPL_CLK=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DM_RESET=y CONFIG_DEBUG_UART_SHIFT=2 -CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_SYSRESET=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_TPL_TIMER=y +CONFIG_ROCKCHIP_TIMER=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_PANIC_HANG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y -- 2.20.1
The CONFIG_ROCKCHIP_SPL_RESERVE_IRAM is for SPL only, add condition to limit it not affect TPL.
arch/arm/include/asm/arch-rockchip/boot0.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-rockchip/boot0.h b/arch/arm/include/asm/arch-rockchip/boot0.h index 9ea4708ada..0c375e543a 100644 --- a/arch/arm/include/asm/arch-rockchip/boot0.h +++ b/arch/arm/include/asm/arch-rockchip/boot0.h @@ -54,6 +54,7 @@ _start: ARM_VECTORS #endif
-#if defined(CONFIG_SPL_BUILD) && (CONFIG_ROCKCHIP_SPL_RESERVE_IRAM > 0) +#if !defined(CONFIG_TPL_BUILD) && defined(CONFIG_SPL_BUILD) && \ + (CONFIG_ROCKCHIP_SPL_RESERVE_IRAM > 0) .space CONFIG_ROCKCHIP_SPL_RESERVE_IRAM /* space for the ATF data */ #endif
evb-px5 has only 1 CS, update for it.
drivers/ram/rockchip/dmc-rk3368.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/ram/rockchip/dmc-rk3368.c b/drivers/ram/rockchip/dmc-rk3368.c index 92f584fadc..e52fc3baad 100644 --- a/drivers/ram/rockchip/dmc-rk3368.c +++ b/drivers/ram/rockchip/dmc-rk3368.c @@ -842,7 +842,11 @@ static int setup_sdram(struct udevice *dev) move_to_access_state(pctl);
/* TODO(prt): could detect rank in training... */ +#ifdef CONFIG_TARGET_EVB_PX5 + params->chan.rank = 1; +#else params->chan.rank = 2; +#endif /* TODO(prt): bus width is not auto-detected (yet)... */ params->chan.bw = 2; /* 32bit wide bus */ params->chan.dbw = params->chan.dbw; /* 32bit wide bus */
Kever Yang kever.yang@rock-chips.com 于2019年3月29日周五 下午10:53写道:
+#else params->chan.rank = 2; +#endif /* TODO(prt): bus width is not auto-detected (yet)... */ params->chan.bw = 2; /* 32bit wide bus */ params->chan.dbw = params->chan.dbw; /* 32bit wide bus */ -- 2.20.1
The iomux should have been set in board_debug_uart_init(), do not set in board_init_f(), remove it.
arch/arm/mach-rockchip/rk3368-board-spl.c | 13 ------------- 1 file changed, 13 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3368-board-spl.c b/arch/arm/mach-rockchip/rk3368-board-spl.c index b055ed4aee..9cb5eab8ae 100644 --- a/arch/arm/mach-rockchip/rk3368-board-spl.c +++ b/arch/arm/mach-rockchip/rk3368-board-spl.c @@ -24,19 +24,6 @@ void board_init_f(ulong dummy) hang(); }
- /* Set up our preloader console */ - ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); - if (ret) { - pr_err("%s: pinctrl init failed: %d\n", __func__, ret); - hang(); - } - - ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_UART0); - if (ret) { - pr_err("%s: failed to set up console UART\n", __func__); - hang(); - } - preloader_console_init();
ret = uclass_get_device(UCLASS_RAM, 0, &dev);
Hi Kever:
the struct udevice* pinctrl definition should also be removed.
if (ret) {
hang();
if (ret) {
hang();
preloader_console_init(); ret = uclass_get_device(UCLASS_RAM, 0, &dev);
-- 2.20.1
Let's use rockchip timer before stimer patches can be merged.
arch/arm/dts/rk3368-px5-evb-u-boot.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi b/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi index 18b841864c..f5406d4c7e 100644 --- a/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3368-px5-evb-u-boot.dtsi @@ -5,6 +5,7 @@ / { chosen { u-boot,spl-boot-order = &emmc; + tick-timer = "/timer@ff810000"; }; };
@@ -60,3 +61,9 @@ &emmc { u-boot,dm-pre-reloc; }; + +&timer0 { + u-boot,dm-pre-reloc; + clock-frequency = <24000000>; + status = "okay"; +};
+&timer0 {
status = "okay";
2.20.1
Andy Yan
Kever Yang
