[U-Boot] [PATCH] NET: Base support for etsec2.0
1. Modified the tsec_mdio structure to include the new regs 2. Modified the MDIO_BASE_ADDR so that it will handle both older version and new version of etsec.
Signed-off-by: Sandeep Gopalpet sandeep.kumar@freescale.com --- include/asm-ppc/immap_85xx.h | 7 ++++++- include/configs/P1_P2_RDB.h | 5 +++++ include/tsec.h | 11 +++++++++++ 3 files changed, 22 insertions(+), 1 deletions(-)
diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index ad3910c..9a5326a 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -1933,10 +1933,15 @@ typedef struct ccsr_gur { (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_USB_OFFSET)
/* TSEC and MDIO OFFSETS */ +#ifdef CONFIG_TSECV2 +#define CONFIG_SYS_TSEC1_OFFSET 0xB0000 +#else #define CONFIG_SYS_TSEC1_OFFSET 0x24000 +#endif + #define TSEC_SIZE 0x01000
-#define CONFIG_SYS_MDIO1_OFFSET 0x24520 +#define CONFIG_SYS_MDIO1_OFFSET 0x24000 #define MDIO_OFFSET 0x01000
#define TSEC_BASE_ADDR (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 8e97ad0..77c43e7 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -68,6 +68,11 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_MP #endif
+/* TSECV2 */ +#if defined(CONFIG_P1020) +#define CONFIG_TSECV2 +#endif + /* * These can be toggled for performance analysis, otherwise use default. */ diff --git a/include/tsec.h b/include/tsec.h index 2b9c9c3..e881082 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -451,14 +451,25 @@ typedef struct tsec_hash_regs uint res2[24]; } tsec_hash_t;
+/* MDIO structure for etsec2.0. + * Backward compatible to etsec1.x + */ + typedef struct tsec_mdio { + uint res1[4]; + uint ieventm; /* MDIO Interrupt event register */ + uint imaskm; /* MDIO Interrupt mask register */ + uint res2; + uint emapm; /* MDIO Event mapping register */ + uint res3[320]; uint miimcfg; /* MII Management: Configuration */ uint miimcom; /* MII Management: Command */ uint miimadd; /* MII Management: Address */ uint miimcon; /* MII Management: Control */ uint miimstat; /* MII Management: Status */ uint miimind; /* MII Management: Indicators */ + uint res4[690]; } tsec_mdio_t;
typedef struct tsec
Sandeep Gopalpet
