[U-Boot-Users] Relocating code problem
I have a problem durinf relocating of code from sdram. The uboot hangs. My sdram initialization is correct as it has passed ddr test. Kindly help me in solving this. I am using Jtag to download uboot to flash.
Regards,
Aruna, Project leader, DEEOPL, BAngalore
Uboot version ? Platform/Processor ?
Do u see any Uboot Init or startup messages. Using Jtag you can debug and check where the Processor Hangs. May be the sdram location where uboot is about to relocate is not accessible.
Regards Guruaja
Regards,
Aruna,
Hi Aruna,
This is a FAQ. http://www.denx.de/wiki/view/DULG/UBootCrashAfterRelocation
Just because your SDRAM configuration passes the ddr test doesn't necessarily mean it is working 100% correctly. Misconfigured SDRAM will "work" if it isn't driven hard (i.e. pipelining effectively not being used). http://www.denx.de/wiki/DULG/SDRAM
If your SDRAM *is* working as you claim, you found a new problem and will have to update the FAQ. :-/
HTH, gvb
Aruna Kumari
Hebbar
Jerry Van Baren
