[PATCH 0/2] Fix dependencies of USB Kconfig options
When USB device driver CONFIG_USB and CONFIG_CMD_USB are disabled, some compilation issues are seen. Also CMD_THOR_DOWNLOAD should depend on CONFIG_CMD_USB. Add dependencies to resolve those issues and compile properly. Also remove unused config CONFIG_ZYNQMP_USB.
Ashok Reddy Soma (2): cmd: thordown: Add proper dependency for CMD_THOR_DOWNLOAD zynqmp: config: Add proper dependencies for USB
arch/arm/mach-zynqmp/Kconfig | 3 --- cmd/Kconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 - include/configs/xilinx_zynqmp.h | 4 ++-- 4 files changed, 3 insertions(+), 6 deletions(-)
When CONFIG_CMD_USB and CONFIG_USB are disabled some compilation errors are seen as below.
cmd/thordown.o: in function `usb_gadget_initialize': include/linux/usb/gadget.h:981: undefined reference to `board_usb_init' cmd/thordown.o: in function `do_thor_down': cmd/thordown.c:68: undefined reference to `g_dnl_unregister' cmd/thordown.o: in function `usb_gadget_release': include/linux/usb/gadget.h:986: undefined reference to `board_usb_cleanup' cmd/thordown.o: in function `do_thor_down': cmd/thordown.c:41: undefined reference to `g_dnl_register' cmd/thordown.c:48: undefined reference to `thor_init' cmd/thordown.c:56: undefined reference to `thor_handle' gnu/aarch64/lin/aarch64-linux/bin/aarch64-linux-gnu-ld.bfd: line 4: 8485 Segmentation fault (core dumped) $CC --sysroot=$LIBC --no-warn-rwx-segment "$@" Makefile:1779: recipe for target 'u-boot' failed make: *** [u-boot] Error 139 make: *** Deleting file 'u-boot'
Add dependency of CMD_USB for CONFIG_CMD_THOR_DOWNLOAD to fix the errors.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com ---
cmd/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 02e54f1e50..b44df9d67a 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -526,6 +526,7 @@ config CMD_SPL_WRITE_SIZE
config CMD_THOR_DOWNLOAD bool "thor - TIZEN 'thor' download" + depends on CMD_USB select DFU help Implements the 'thor' download protocol. This is a way of
Am 9. Juli 2023 15:09:57 MESZ schrieb Ashok Reddy Soma ashok.reddy.soma@amd.com:
Thanks for your patch.
Currently we have no documentation for the thordown command. We should create a man page in /docs/usage/cmd/.
Do you have any description of the usage of the command?
Best regards
Heinrich
- depends on CMD_USB select DFU help Implements the 'thor' download protocol. This is a way of
Hi Heinrich,
-----Original Message----- From: Heinrich Schuchardt xypron.glpk@gmx.de Sent: Sunday, July 9, 2023 7:09 PM To: Soma, Ashok Reddy ashok.reddy.soma@amd.com; u- boot@lists.denx.de Cc: sjg@chromium.org; ilias.apalodimas@linaro.org; rfried.dev@gmail.com; seanedmond@microsoft.com; tobias@waldekranz.com; sr@denx.de; john@metanate.com; Simek, Michal michal.simek@amd.com; git (AMD- Xilinx) git@amd.com Subject: Re: [PATCH 1/2] cmd: thordown: Add proper dependency for CMD_THOR_DOWNLOAD
errors
are seen as below.
No, I was not working with thor download command I was disabling CONFIG_CMD_USB and CONFIG_USB and saw some compilation errors from cmd/thordown.c. So, added dependency and sent patch.
Thanks, Ashok
Best regards
Heinrich
`board_usb_cleanup'
the errors.
This isn't right, and removes the command from s5p_goni. The issue is that CMD_USB is for host support, and this is a gadget command. Likely the best answer is to make this depend on USB_FUNCTION_THOR, or select USB_FUNCTION_THOR but depend on USB_GADGET_DOWNLOAD.
No, no I didn't apply this still, I just forgot to remove it from the bundle before making all the applied messages.
At least I'm not also tagging a release today, sigh.
When CONFIG_CMD_USB and CONFIG_USB are disabled, still some compilation errors are seen as below.
In file included from include/configs/xilinx_zynqmp.h:173, from include/config.h:3, from include/common.h:16, from env/common.c:10: include/config_distro_bootcmd.h:302:9: error: expected '}' before 'BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB' 302 | BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ include/config_distro_bootcmd.h:302:9: note: in definition of macro 'BOOTENV_DEV_NAME_USB' 302 | BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ include/configs/xilinx_zynqmp.h:77:41: note: in expansion of macro 'BOOTENV_DEV_NAME' 77 | # define BOOT_TARGET_DEVICES_USB(func) func(USB, usb, 0) func(USB, usb, 1) | ^~~~ include/configs/xilinx_zynqmp.h:168:9: note: in expansion of macro 'BOOT_TARGET_DEVICES_USB' 168 | BOOT_TARGET_DEVICES_USB(func) \ | ^~~~~~~~~~~~~~~~~~~~~~~ include/config_distro_bootcmd.h:454:25: note: in expansion of macro 'BOOT_TARGET_DEVICES' 454 | "boot_targets=" BOOT_TARGET_DEVICES(BOOTENV_DEV_NAME) "\0" | ^~~~~~~~~~~~~~~~~~~ include/config_distro_bootcmd.h:474:9: note: in expansion of macro 'BOOTENV_BOOT_TARGETS' 474 | BOOTENV_BOOT_TARGETS \ | ^~~~~~~~~~~~~~~~~~~~ include/configs/xilinx_zynqmp.h:179:9: note: in expansion of macro 'BOOTENV' 179 | BOOTENV | ^~~~~~~ include/env_default.h:120:9: note: in expansion of macro 'CFG_EXTRA_ENV_SETTINGS' 120 | CFG_EXTRA_ENV_SETTINGS | ^~~~~~~~~~~~~~~~~~~~~~ In file included from env/common.c:32: include/env_default.h:27:36: note: to match this '{' 27 | const char default_environment[] = { | ^ scripts/Makefile.build:256: recipe for target 'env/common.o' failed make[1]: *** [env/common.o] Error 1 Makefile:1853: recipe for target 'env' failed make: *** [env] Error 2 make: *** Waiting for unfinished jobs....
Add CONFIG_USB_STORAGE as dependency for USB related macro's such as BOOT_TARGET_DEVICES_USB() and DFU_DEFAULT_POLL_TIMEOUT and CONFIG_THOR_RESET_OFF.
Remove CONFIG_ZYNQMP_USB from Kconfig and also from defconfig since it is not used anywhere else.
arch/arm/mach-zynqmp/Kconfig | 3 --- configs/xilinx_zynqmp_virt_defconfig | 1 - include/configs/xilinx_zynqmp.h | 4 ++-- 3 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-zynqmp/Kconfig b/arch/arm/mach-zynqmp/Kconfig index fd6f07715a..26b80b7882 100644 --- a/arch/arm/mach-zynqmp/Kconfig +++ b/arch/arm/mach-zynqmp/Kconfig @@ -84,9 +84,6 @@ config ZYNQMP_SPL_PM_CFG_OBJ_FILE Leave this option empty if your PMU firmware has a hard-coded configuration object or you are loading it by any other means.
-config ZYNQMP_USB - bool "Configure ZynqMP USB" - config ZYNQMP_NO_DDR bool "Disable DDR MMU mapping" help diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index c4bbde2206..6bda4f8453 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -17,7 +17,6 @@ CONFIG_ENV_OFFSET_REDUND=0x1E80000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_CMD_FRU=y -CONFIG_ZYNQMP_USB=y CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_AHCI=y CONFIG_SYS_MEMTEST_START=0x00000000 diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 011f0034c5..44f8914b80 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -29,7 +29,7 @@
/* Miscellaneous configurable options */
-#if defined(CONFIG_ZYNQMP_USB) +#if defined(CONFIG_USB_STORAGE) #define DFU_DEFAULT_POLL_TIMEOUT 300
# define PARTS_DEFAULT \ @@ -73,7 +73,7 @@ # define BOOT_TARGET_DEVICES_SCSI(func) #endif
-#if defined(CONFIG_ZYNQMP_USB) +#if defined(CONFIG_USB_STORAGE) # define BOOT_TARGET_DEVICES_USB(func) func(USB, usb, 0) func(USB, usb, 1) #else # define BOOT_TARGET_DEVICES_USB(func)
Ashok Reddy Soma
Soma, Ashok Reddy
