[U-Boot-Users] [PATCH] Cleanup cpu/arm920t using SoC
Hi there,
Since the cpu/ directory gets clobbered with peripheral driver code I started cleaning up cpu/arm920t. I introduced the concept of Soc (system on a chip) into the ./cpu directory. That means that code that is cpu (i.e. core) specific resides in
cpu/$(CPU)/
and code that is specific to some SoC (i.e. vendor specific peripherals around the core) is moved into
cpu/$(CPU)/$(SOC)/
Thus a library/archive "cpu/$(CPU)/$(SOC)/lib$(SOC).a" will be build and linked. Examples will be
cpu/arm920t/imx/ cpu/arm920t/s3c24x0
One can select an SoC by passing the name of it to ./mkconfig just like
@./mkconfig $(@:_config=) arm arm920t vcma9 mpl s3c24x0
If there's no VENDOR field (like "mpl" in the above line) one has to pass NULL instead:
@./mkconfig $(@:_config=) arm arm920t mx1ads NULL imx
========================================================================= CHANGELOG
* Patch by Steven Scholz, 16 Aug 2004: - Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)" - creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0 - moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/ - moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/ into cpu/arm920t/$(SOC)/ =========================================================================
Since the patch is quite big I'll send it to Wolfgang directly. If it gets applied I'd like to do the same with cpu/at91rm9200. That is introducing "SOC = at91rm9200" and moving all at91rm9200 code ./cpu/arm920t/at91rm9200.
The patch does not break the build process for ARM9. I tested "./MAKEALL ARM9"
Thanks.
Steven Scholz
