[U-Boot] [PATCH V2 1/3] dfu: Fix up the Kconfig mess
Clean up the screaming mess of configuration options that DFU is. It was impossible to configure DFU such that TFTP is enabled and USB is not, this patch fixes that and assures that DFU TFTP and DFU USB can be enabled separatelly and that the correct pieces of code are compiled in.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Lukasz Majewski lukma@denx.de --- V2: Do not imply TFTP if net, we do not want this turned on by default. --- cmd/Kconfig | 2 +- cmd/dfu.c | 18 +++++++++++++----- common/Makefile | 6 ++++-- drivers/dfu/Kconfig | 12 +++++++++++- drivers/dfu/Makefile | 2 +- 5 files changed, 30 insertions(+), 10 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 7368b6df52..1caddc4072 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -582,7 +582,7 @@ config CMD_DEMO
config CMD_DFU bool "dfu" - select USB_FUNCTION_DFU + select DFU help Enables the command "dfu" which is used to have U-Boot create a DFU class device via USB. This command requires that the "dfu_alt_info" diff --git a/cmd/dfu.c b/cmd/dfu.c index 04291f6c08..76b89ca5ed 100644 --- a/cmd/dfu.c +++ b/cmd/dfu.c @@ -25,12 +25,14 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (argc < 4) return CMD_RET_USAGE;
+#ifdef CONFIG_USB_FUNCTION_DFU char *usb_controller = argv[1]; +#endif char *interface = argv[2]; char *devstring = argv[3];
- int ret; -#ifdef CONFIG_DFU_TFTP + int ret = 0; +#ifdef CONFIG_TFTP_FUNCTION_DFU unsigned long addr = 0; if (!strcmp(argv[1], "tftp")) { if (argc == 5) @@ -39,7 +41,7 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return update_tftp(addr, interface, devstring); } #endif - +#ifdef CONFIG_USB_FUNCTION_DFU ret = dfu_init_env_entities(interface, devstring); if (ret) goto done; @@ -56,18 +58,24 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
done: dfu_free_entities(); +#endif return ret; }
U_BOOT_CMD(dfu, CONFIG_SYS_MAXARGS, 1, do_dfu, "Device Firmware Upgrade", +#ifdef CONFIG_USB_FUNCTION_DFU "<USB_controller> <interface> <dev> [list]\n" " - device firmware upgrade via <USB_controller>\n" " on device <dev>, attached to interface\n" " <interface>\n" " [list] - list available alt settings\n" -#ifdef CONFIG_DFU_TFTP - "dfu tftp <interface> <dev> [<addr>]\n" +#endif +#ifdef CONFIG_TFTP_FUNCTION_DFU +#ifdef CONFIG_USB_FUNCTION_DFU + "dfu " +#endif + "tftp <interface> <dev> [<addr>]\n" " - device firmware upgrade via TFTP\n" " on device <dev>, attached to interface\n" " <interface>\n" diff --git a/common/Makefile b/common/Makefile index c7bde239c1..cdd0ab19d8 100644 --- a/common/Makefile +++ b/common/Makefile @@ -66,7 +66,9 @@ endif # !CONFIG_SPL_BUILD obj-$(CONFIG_$(SPL_TPL_)BOOTSTAGE) += bootstage.o
ifdef CONFIG_SPL_BUILD -obj-$(CONFIG_SPL_DFU_SUPPORT) += dfu.o +ifdef CONFIG_SPL_DFU_SUPPORT +obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o +endif obj-$(CONFIG_SPL_DFU_SUPPORT) += cli_hush.o obj-$(CONFIG_SPL_HASH_SUPPORT) += hash.o obj-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o @@ -128,7 +130,7 @@ endif
obj-y += cli.o obj-$(CONFIG_FSL_DDR_INTERACTIVE) += cli_simple.o cli_readline.o -obj-$(CONFIG_CMD_DFU) += dfu.o +obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o obj-y += command.o obj-$(CONFIG_$(SPL_)LOG) += log.o obj-$(CONFIG_$(SPL_)LOG_CONSOLE) += log_console.o diff --git a/drivers/dfu/Kconfig b/drivers/dfu/Kconfig index fa27efbb40..b077444059 100644 --- a/drivers/dfu/Kconfig +++ b/drivers/dfu/Kconfig @@ -1,12 +1,22 @@ menu "DFU support"
+config DFU + bool + imply USB_FUNCTION_DFU if USB_GADGET + config USB_FUNCTION_DFU bool select HASH + depends on USB_GADGET + +config TFTP_FUNCTION_DFU + bool + depends on NET
-if CMD_DFU +if DFU config DFU_TFTP bool "DFU via TFTP" + select TFTP_FUNCTION_DFU help This option allows performing update of DFU-managed medium with data sent via TFTP boot. diff --git a/drivers/dfu/Makefile b/drivers/dfu/Makefile index 61f2b71f91..7f35871ddc 100644 --- a/drivers/dfu/Makefile +++ b/drivers/dfu/Makefile @@ -5,7 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o +obj-$(CONFIG_DFU) += dfu.o obj-$(CONFIG_DFU_MMC) += dfu_mmc.o obj-$(CONFIG_DFU_NAND) += dfu_nand.o obj-$(CONFIG_DFU_RAM) += dfu_ram.o
Do the following to make the symbol names less confusing.
sed -i "s/([TU][^_]+)_FUNCTION_DFU/DFU_OVER_\1/g" \ `git grep _FUNCTION_DFU | cut -d ":" -f 1 | sort -u`
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Lukasz Majewski lukma@denx.de --- README | 2 +- board/siemens/common/factoryset.c | 4 ++-- cmd/dfu.c | 12 ++++++------ common/Makefile | 4 ++-- drivers/dfu/Kconfig | 8 ++++---- drivers/usb/gadget/Makefile | 2 +- include/configs/tegra-common-post.h | 2 +- 7 files changed, 17 insertions(+), 17 deletions(-)
diff --git a/README b/README index 81b7ee1ce8..cb8d5ef24f 100644 --- a/README +++ b/README @@ -1203,7 +1203,7 @@ The following options need to be configured: key for the Replay Protection Memory Block partition in eMMC.
- USB Device Firmware Update (DFU) class support: - CONFIG_USB_FUNCTION_DFU + CONFIG_DFU_OVER_USB This enables the USB portion of the DFU USB class
CONFIG_DFU_MMC diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index 81bbb5758d..7fa2673c2b 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -144,7 +144,7 @@ int factoryset_read_eeprom(int i2c_addr) unsigned char eeprom_buf[0x3c00], hdr[4], buf[MAX_STRING_LENGTH]; unsigned char *cp, *cp1;
-#if defined(CONFIG_USB_FUNCTION_DFU) +#if defined(CONFIG_DFU_OVER_USB) factory_dat.usb_vendor_id = CONFIG_USB_GADGET_VENDOR_NUM; factory_dat.usb_product_id = CONFIG_USB_GADGET_PRODUCT_NUM; #endif @@ -202,7 +202,7 @@ int factoryset_read_eeprom(int i2c_addr) cp1 += 3; }
-#if defined(CONFIG_USB_FUNCTION_DFU) +#if defined(CONFIG_DFU_OVER_USB) /* read vid and pid for dfu mode */ if (0 <= get_factory_record_val(cp, size, (uchar *)"USBD1", (uchar *)"vid", buf, diff --git a/cmd/dfu.c b/cmd/dfu.c index 76b89ca5ed..68b1a7fec9 100644 --- a/cmd/dfu.c +++ b/cmd/dfu.c @@ -25,14 +25,14 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (argc < 4) return CMD_RET_USAGE;
-#ifdef CONFIG_USB_FUNCTION_DFU +#ifdef CONFIG_DFU_OVER_USB char *usb_controller = argv[1]; #endif char *interface = argv[2]; char *devstring = argv[3];
int ret = 0; -#ifdef CONFIG_TFTP_FUNCTION_DFU +#ifdef CONFIG_DFU_OVER_TFTP unsigned long addr = 0; if (!strcmp(argv[1], "tftp")) { if (argc == 5) @@ -41,7 +41,7 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return update_tftp(addr, interface, devstring); } #endif -#ifdef CONFIG_USB_FUNCTION_DFU +#ifdef CONFIG_DFU_OVER_USB ret = dfu_init_env_entities(interface, devstring); if (ret) goto done; @@ -64,15 +64,15 @@ done:
U_BOOT_CMD(dfu, CONFIG_SYS_MAXARGS, 1, do_dfu, "Device Firmware Upgrade", -#ifdef CONFIG_USB_FUNCTION_DFU +#ifdef CONFIG_DFU_OVER_USB "<USB_controller> <interface> <dev> [list]\n" " - device firmware upgrade via <USB_controller>\n" " on device <dev>, attached to interface\n" " <interface>\n" " [list] - list available alt settings\n" #endif -#ifdef CONFIG_TFTP_FUNCTION_DFU -#ifdef CONFIG_USB_FUNCTION_DFU +#ifdef CONFIG_DFU_OVER_TFTP +#ifdef CONFIG_DFU_OVER_USB "dfu " #endif "tftp <interface> <dev> [<addr>]\n" diff --git a/common/Makefile b/common/Makefile index cdd0ab19d8..7011dada99 100644 --- a/common/Makefile +++ b/common/Makefile @@ -67,7 +67,7 @@ obj-$(CONFIG_$(SPL_TPL_)BOOTSTAGE) += bootstage.o
ifdef CONFIG_SPL_BUILD ifdef CONFIG_SPL_DFU_SUPPORT -obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o +obj-$(CONFIG_DFU_OVER_USB) += dfu.o endif obj-$(CONFIG_SPL_DFU_SUPPORT) += cli_hush.o obj-$(CONFIG_SPL_HASH_SUPPORT) += hash.o @@ -130,7 +130,7 @@ endif
obj-y += cli.o obj-$(CONFIG_FSL_DDR_INTERACTIVE) += cli_simple.o cli_readline.o -obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o +obj-$(CONFIG_DFU_OVER_USB) += dfu.o obj-y += command.o obj-$(CONFIG_$(SPL_)LOG) += log.o obj-$(CONFIG_$(SPL_)LOG_CONSOLE) += log_console.o diff --git a/drivers/dfu/Kconfig b/drivers/dfu/Kconfig index b077444059..51ab484c2a 100644 --- a/drivers/dfu/Kconfig +++ b/drivers/dfu/Kconfig @@ -2,21 +2,21 @@ menu "DFU support"
config DFU bool - imply USB_FUNCTION_DFU if USB_GADGET + imply DFU_OVER_USB if USB_GADGET
-config USB_FUNCTION_DFU +config DFU_OVER_USB bool select HASH depends on USB_GADGET
-config TFTP_FUNCTION_DFU +config DFU_OVER_TFTP bool depends on NET
if DFU config DFU_TFTP bool "DFU via TFTP" - select TFTP_FUNCTION_DFU + select DFU_OVER_TFTP help This option allows performing update of DFU-managed medium with data sent via TFTP boot. diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index ee8bc994c5..748366fb9f 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -26,7 +26,7 @@ obj-$(CONFIG_CI_UDC) += ci_udc.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o -obj-$(CONFIG_USB_FUNCTION_DFU) += f_dfu.o +obj-$(CONFIG_DFU_OVER_USB) += f_dfu.o obj-$(CONFIG_USB_FUNCTION_MASS_STORAGE) += f_mass_storage.o obj-$(CONFIG_USB_FUNCTION_FASTBOOT) += f_fastboot.o obj-$(CONFIG_USB_FUNCTION_SDP) += f_sdp.o diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index aea8f1fb8e..3eb9dd2af9 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -11,7 +11,7 @@ /* * Size of malloc() pool */ -#ifdef CONFIG_USB_FUNCTION_DFU +#ifdef CONFIG_DFU_OVER_USB #define CONFIG_SYS_MALLOC_LEN (SZ_4M + \ CONFIG_SYS_DFU_DATA_BUF_SIZE + \ CONFIG_SYS_DFU_MAX_FILE_SIZE)
Fix two build warnings when building for arm64:
drivers/dfu/dfu_tftp.c: In function ‘dfu_tftp_write’: drivers/dfu/dfu_tftp.c:59:37: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] ret = dfu_write_from_mem_addr(dfu, (void *)addr, len); ^ and
drivers/dfu/dfu_tftp.c: In function ‘dfu_tftp_write’: drivers/dfu/dfu_tftp.c:41:8: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 4 has type ‘__kernel_size_t {aka long unsigned int}’ [-Wformat=] debug("%s: image name: %s strlen: %u\n", __func__, sb, strlen(sb)); ^
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Lukasz Majewski lukma@denx.de --- drivers/dfu/dfu_tftp.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/dfu/dfu_tftp.c b/drivers/dfu/dfu_tftp.c index 62bf797dac..f0afbac477 100644 --- a/drivers/dfu/dfu_tftp.c +++ b/drivers/dfu/dfu_tftp.c @@ -38,7 +38,7 @@ int dfu_tftp_write(char *dfu_entity_name, unsigned int addr, unsigned int len, }
strsep(&s, "@"); - debug("%s: image name: %s strlen: %d\n", __func__, sb, strlen(sb)); + debug("%s: image name: %s strlen: %zd\n", __func__, sb, strlen(sb));
alt_setting_num = dfu_get_alt(sb); free(sb); @@ -56,7 +56,7 @@ int dfu_tftp_write(char *dfu_entity_name, unsigned int addr, unsigned int len, goto done; }
- ret = dfu_write_from_mem_addr(dfu, (void *)addr, len); + ret = dfu_write_from_mem_addr(dfu, (void *)(uintptr_t)addr, len);
Hi Marek,
Acked-by: Lukasz Majewski lukma@denx.de Tested-by: Lukasz Majewski lukma@denx.de
Test HW: Beagle Bone Black
- select DFU help Enables the command "dfu" which is used to have U-Boot
- int ret;
- int ret = 0;
+#ifdef CONFIG_USB_FUNCTION_DFU ret = dfu_init_env_entities(interface, devstring); if (ret) goto done; @@ -56,18 +58,24 @@ static int do_dfu(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) done: dfu_free_entities(); +#endif return ret; }
- "dfu "
- "tftp <interface> <dev> [<addr>]\n" " - device firmware upgrade via TFTP\n" " on device <dev>, attached to interface\n" " <interface>\n"
+config DFU
- bool
- depends on USB_GADGET
- bool
- depends on NET
- select TFTP_FUNCTION_DFU help This option allows performing update of DFU-managed medium
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Lukasz Majewski
