[U-Boot] [PATCH][v2] armv8: ls2080a: Update serdes protocol support
Add serdes protocol support for Serdes1 protocol: 0x39, 0x4B, 0x4C, 0x4D Serdes2 protocol: 0x47, 0x57
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- Changes for v2: Added signed-off-by
arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c | 6 + board/freescale/ls2080aqds/eth.c | 122 +++++++++++++++++++- 2 files changed, 125 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c index eaa44a7..67d605e 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c @@ -34,6 +34,11 @@ static struct serdes_config serdes1_cfg_tbl[] = { {0x33, {PCIE2, PCIE2, PCIE2, PCIE2, QSGMII_D, QSGMII_C, QSGMII_B, QSGMII_A} }, {0x35, {QSGMII_D, QSGMII_C, QSGMII_B, PCIE2, XFI4, XFI3, XFI2, XFI1 } }, + {0x39, {SGMII8, SGMII7, SGMII6, PCIE2, SGMII4, SGMII3, SGMII2, + PCIE1 } }, + {0x4B, {PCIE2, PCIE2, PCIE2, PCIE2, XFI4, XFI3, XFI2, XFI1 } }, + {0x4C, {XFI8, XFI7, XFI6, XFI5, PCIE1, PCIE1, PCIE1, PCIE1 } }, + {0x4D, {SGMII8, SGMII7, PCIE2, PCIE2, SGMII4, SGMII3, PCIE1, PCIE1 } }, {} }; static struct serdes_config serdes2_cfg_tbl[] = { @@ -64,6 +69,7 @@ static struct serdes_config serdes2_cfg_tbl[] = { SATA2 } }, {0x4A, {SGMII9, SGMII10, SGMII11, SGMII12, PCIE4, PCIE4, SATA1, SATA2 } }, + {0x57, {PCIE3, PCIE3, PCIE3, PCIE3, PCIE4, PCIE4, SGMII15, SGMII16 } }, {} };
diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 95ff68b..8618506 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -64,7 +64,7 @@ static int sgmii_riser_phy_addr[] = { };
/* Slot2 does not have EMI connections */ -#define EMI_NONE 0xFFFFFFFF +#define EMI_NONE 0xFF #define EMI1_SLOT1 0 #define EMI1_SLOT2 1 #define EMI1_SLOT3 2 @@ -470,7 +470,49 @@ static void initialize_dpmac_to_slot(void) } break;
+ case 0x39: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + if (hwconfig_f("xqsgmii", env_hwconfig)) { + lane_to_slot_fsm1[0] = EMI1_SLOT3; + lane_to_slot_fsm1[1] = EMI1_SLOT3; + lane_to_slot_fsm1[2] = EMI1_SLOT3; + lane_to_slot_fsm1[3] = EMI_NONE; + } else { + lane_to_slot_fsm1[0] = EMI_NONE; + lane_to_slot_fsm1[1] = EMI_NONE; + lane_to_slot_fsm1[2] = EMI_NONE; + lane_to_slot_fsm1[3] = EMI_NONE; + } + lane_to_slot_fsm1[4] = EMI1_SLOT3; + lane_to_slot_fsm1[5] = EMI1_SLOT3; + lane_to_slot_fsm1[6] = EMI1_SLOT3; + lane_to_slot_fsm1[7] = EMI_NONE; + break; + + case 0x4D: + printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", + serdes1_prtcl); + if (hwconfig_f("xqsgmii", env_hwconfig)) { + lane_to_slot_fsm1[0] = EMI1_SLOT3; + lane_to_slot_fsm1[1] = EMI1_SLOT3; + lane_to_slot_fsm1[2] = EMI_NONE; + lane_to_slot_fsm1[3] = EMI_NONE; + } else { + lane_to_slot_fsm1[0] = EMI_NONE; + lane_to_slot_fsm1[1] = EMI_NONE; + lane_to_slot_fsm1[2] = EMI_NONE; + lane_to_slot_fsm1[3] = EMI_NONE; + } + lane_to_slot_fsm1[4] = EMI1_SLOT3; + lane_to_slot_fsm1[5] = EMI1_SLOT3; + lane_to_slot_fsm1[6] = EMI_NONE; + lane_to_slot_fsm1[7] = EMI_NONE; + break; + case 0x2A: + case 0x4B: + case 0x4C: printf("qds: WRIOP: Supported SerDes1 Protocol 0x%02x\n", serdes1_prtcl); break; @@ -505,6 +547,38 @@ static void initialize_dpmac_to_slot(void) lane_to_slot_fsm2[7] = EMI1_SLOT6; } break; + + case 0x47: + printf("qds: WRIOP: Supported SerDes2 Protocol 0x%02x\n", + serdes2_prtcl); + lane_to_slot_fsm2[0] = EMI_NONE; + lane_to_slot_fsm2[1] = EMI1_SLOT5; + lane_to_slot_fsm2[2] = EMI1_SLOT5; + lane_to_slot_fsm2[3] = EMI1_SLOT5; + + if (hwconfig_f("xqsgmii", env_hwconfig)) { + lane_to_slot_fsm2[4] = EMI_NONE; + lane_to_slot_fsm2[5] = EMI1_SLOT5; + lane_to_slot_fsm2[6] = EMI1_SLOT5; + lane_to_slot_fsm2[7] = EMI1_SLOT5; + } + break; + + case 0x57: + printf("qds: WRIOP: Supported SerDes2 Protocol 0x%02x\n", + serdes2_prtcl); + if (hwconfig_f("xqsgmii", env_hwconfig)) { + lane_to_slot_fsm2[0] = EMI_NONE; + lane_to_slot_fsm2[1] = EMI_NONE; + lane_to_slot_fsm2[2] = EMI_NONE; + lane_to_slot_fsm2[3] = EMI_NONE; + } + lane_to_slot_fsm2[4] = EMI_NONE; + lane_to_slot_fsm2[5] = EMI_NONE; + lane_to_slot_fsm2[6] = EMI1_SLOT5; + lane_to_slot_fsm2[7] = EMI1_SLOT5; + break; + default: printf(" %s qds: WRIOP: Unsupported SerDes2 Protocol 0x%02x\n", __func__ , serdes2_prtcl); @@ -537,8 +611,10 @@ void ls2080a_handle_phy_interface_sgmii(int dpmac_id)
switch (serdes1_prtcl) { case 0x07: + case 0x39: + case 0x4D: + lane = serdes_get_first_lane(FSL_SRDS_1, SGMII1 + dpmac_id - 1);
- lane = serdes_get_first_lane(FSL_SRDS_1, SGMII1 + dpmac_id); slot = lane_to_slot_fsm1[lane];
switch (++slot) { @@ -559,6 +635,26 @@ void ls2080a_handle_phy_interface_sgmii(int dpmac_id) wriop_set_mdio(dpmac_id, bus); break; case 3: + if (slot == EMI_NONE) + return; + if (serdes1_prtcl == 0x39) { + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 2]); + if (dpmac_id >= 6 && hwconfig_f("xqsgmii", + env_hwconfig)) + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 3]); + } else { + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 2]); + if (dpmac_id >= 7 && hwconfig_f("xqsgmii", + env_hwconfig)) + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 3]); + } + dpmac_info[dpmac_id].board_mux = EMI1_SLOT3; + bus = mii_dev_for_muxval(EMI1_SLOT3); + wriop_set_mdio(dpmac_id, bus); break; case 4: break; @@ -579,6 +675,8 @@ serdes2: case 0x07: case 0x08: case 0x49: + case 0x47: + case 0x57: lane = serdes_get_first_lane(FSL_SRDS_2, SGMII9 + (dpmac_id - 9)); slot = lane_to_slot_fsm2[lane]; @@ -597,7 +695,23 @@ serdes2: wriop_set_mdio(dpmac_id, bus); break; case 5: - break; + if (slot == EMI_NONE) + return; + if (serdes2_prtcl == 0x47) { + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 10]); + if (dpmac_id >= 14 && hwconfig_f("xqsgmii", + env_hwconfig)) + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 11]); + } else { + wriop_set_phy_address(dpmac_id, + riser_phy_addr[dpmac_id - 11]); + } + dpmac_info[dpmac_id].board_mux = EMI1_SLOT5; + bus = mii_dev_for_muxval(EMI1_SLOT5); + wriop_set_mdio(dpmac_id, bus); + break; case 6: /* Slot housing a SGMII riser card? */ wriop_set_phy_address(dpmac_id, @@ -691,6 +805,8 @@ void ls2080a_handle_phy_interface_xsgmii(int i)
switch (serdes1_prtcl) { case 0x2A: + case 0x4B: + case 0x4C: /* * XFI does not need a PHY to work, but to avoid U-Boot use * default PHY address which is zero to a MAC when it found
Revised commit message slightly. Applied to fsl-qoriq, awaiting upstream. Thanks.
York
Priyanka Jain
york sun
