[PATCH v2 00/12] TI: Add support for AM62 SoC
This adds basic support for TI's new AM62 family of SoCs and AM625 Starter Kit EVM with SD boot and UART boot.
Board support, dts and configs are intentionally kept small to serve as example for future board bringups based on this SoC.
Additional peripheral support will be posted separately
All bindings and DT patches are in linux-next
I have dropped review tags from previous version due to quite a few changes as mentioned below
v2: * Patch 9,10,11 are trimmed down to bare minimum * Introduce patch to setup DMA static data for R5 SPL TISCI (patch 7) * Sync with kernel dts. * Drop unnecessary header inclusions (<common.h>)
v1: lore.kernel.org/r/20220415140931.490047-1-vigneshr@ti.com
Aswath Govindraju (1): drivers: mmc: am654_sdhci: Add new compatible for AM62 SoC
Nishanth Menon (1): arm: dts: Add support for AM62-SK
Suman Anna (6): dt-bindings: pinctrl: k3: Introduce pinmux definitions for AM62 soc: ti: k3-socinfo: Add entry for AM62X SoC family arm: mach-k3: Introduce the basic files to support AM62 arm: mach-k3: am62: Introduce autogenerated SoC data arm: dts: Introduce base AM62 SoC dtsi files board: ti: Introduce the basic files to support AM62 SK board
Vignesh Raghavendra (4): dma: ti: Add PSIL data for AM62x DMASS firmware: ti_sci_static_data: add static DMA chan data configs: Add configs for AM62x SK doc: ti: Add readme for AM62x SK
arch/arm/dts/Makefile | 3 + arch/arm/dts/k3-am62-ddr.dtsi | 11 + arch/arm/dts/k3-am62-main.dtsi | 533 ++++ arch/arm/dts/k3-am62-mcu.dtsi | 56 + arch/arm/dts/k3-am62-wakeup.dtsi | 41 + arch/arm/dts/k3-am62.dtsi | 105 + arch/arm/dts/k3-am625-r5-sk.dts | 140 ++ arch/arm/dts/k3-am625-sk-u-boot.dtsi | 100 + arch/arm/dts/k3-am625-sk.dts | 150 ++ arch/arm/dts/k3-am625.dtsi | 103 + arch/arm/dts/k3-am62x-sk-ddr4-1600MTs.dtsi | 2189 +++++++++++++++++ arch/arm/mach-k3/Kconfig | 10 +- arch/arm/mach-k3/Makefile | 1 + arch/arm/mach-k3/am625_init.c | 271 ++ arch/arm/mach-k3/am62x/Makefile | 6 + arch/arm/mach-k3/am62x/clk-data.c | 366 +++ arch/arm/mach-k3/am62x/dev-data.c | 78 + arch/arm/mach-k3/arm64-mmu.c | 4 +- arch/arm/mach-k3/include/mach/am62_hardware.h | 75 + arch/arm/mach-k3/include/mach/am62_spl.h | 48 + arch/arm/mach-k3/include/mach/hardware.h | 4 + arch/arm/mach-k3/include/mach/spl.h | 5 + board/ti/am62x/Kconfig | 59 + board/ti/am62x/MAINTAINERS | 8 + board/ti/am62x/Makefile | 8 + board/ti/am62x/evm.c | 39 + configs/am62x_evm_a53_defconfig | 71 + configs/am62x_evm_r5_defconfig | 91 + doc/board/ti/am62x_sk.rst | 231 ++ doc/board/ti/index.rst | 1 + drivers/clk/ti/clk-k3.c | 6 + drivers/dma/ti/Makefile | 1 + drivers/dma/ti/k3-psil-am62.c | 50 + drivers/dma/ti/k3-psil-priv.h | 1 + drivers/dma/ti/k3-psil.c | 2 + drivers/firmware/ti_sci_static_data.h | 13 + drivers/mmc/am654_sdhci.c | 4 + drivers/power/domain/ti-power-domain.c | 6 + drivers/ram/Kconfig | 1 + drivers/soc/soc_ti_k3.c | 4 + include/configs/am62x_evm.h | 106 + include/dt-bindings/pinctrl/k3.h | 3 + include/k3-clk.h | 1 + include/k3-dev.h | 1 + 44 files changed, 5003 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/k3-am62-ddr.dtsi create mode 100644 arch/arm/dts/k3-am62-main.dtsi create mode 100644 arch/arm/dts/k3-am62-mcu.dtsi create mode 100644 arch/arm/dts/k3-am62-wakeup.dtsi create mode 100644 arch/arm/dts/k3-am62.dtsi create mode 100644 arch/arm/dts/k3-am625-r5-sk.dts create mode 100644 arch/arm/dts/k3-am625-sk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-sk.dts create mode 100644 arch/arm/dts/k3-am625.dtsi create mode 100644 arch/arm/dts/k3-am62x-sk-ddr4-1600MTs.dtsi create mode 100644 arch/arm/mach-k3/am625_init.c create mode 100644 arch/arm/mach-k3/am62x/Makefile create mode 100644 arch/arm/mach-k3/am62x/clk-data.c create mode 100644 arch/arm/mach-k3/am62x/dev-data.c create mode 100644 arch/arm/mach-k3/include/mach/am62_hardware.h create mode 100644 arch/arm/mach-k3/include/mach/am62_spl.h create mode 100644 board/ti/am62x/Kconfig create mode 100644 board/ti/am62x/MAINTAINERS create mode 100644 board/ti/am62x/Makefile create mode 100644 board/ti/am62x/evm.c create mode 100644 configs/am62x_evm_a53_defconfig create mode 100644 configs/am62x_evm_r5_defconfig create mode 100644 doc/board/ti/am62x_sk.rst create mode 100644 drivers/dma/ti/k3-psil-am62.c create mode 100644 include/configs/am62x_evm.h
The phy used in the 8 bit instance has been changed to the phy used in 4 bit instance on AM62 SoC. This implies the phy configuration required for both the instances of mmc are similar. Therefore, add a new compatible for AM62 SoC using the driver data of am64 4 bit instance.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/mmc/am654_sdhci.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mmc/am654_sdhci.c b/drivers/mmc/am654_sdhci.c index 4305967d78..42a6134364 100644 --- a/drivers/mmc/am654_sdhci.c +++ b/drivers/mmc/am654_sdhci.c @@ -670,6 +670,10 @@ static const struct udevice_id am654_sdhci_ids[] = { .compatible = "ti,am64-sdhci-4bit", .data = (ulong)&sdhci_am64_4bit_drvdata, }, + { + .compatible = "ti,am62-sdhci", + .data = (ulong)&sdhci_am64_4bit_drvdata, + }, { } };
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
For the series, applied to u-boot/next, thanks!
Add pinctrl macros for AM62x SoCs. These macro definitions are similar to that of previous platforms, but adding new definitions to avoid any naming confusions in the SoC dts files.
checkpatch insists the following error exists: ERROR: Macros with complex values should be enclosed in parentheses
However, we do not need parentheses enclosing the values for this macro as we do intend it to generate two separate values as has been done for other similar platforms.
Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- include/dt-bindings/pinctrl/k3.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/dt-bindings/pinctrl/k3.h b/include/dt-bindings/pinctrl/k3.h index 63e038e36c..a5204ab91d 100644 --- a/include/dt-bindings/pinctrl/k3.h +++ b/include/dt-bindings/pinctrl/k3.h @@ -41,4 +41,7 @@ #define J721S2_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) #define J721S2_WKUP_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode))
+#define AM62X_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define AM62X_MCU_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) + #endif
Add support for AM62x SoC identification.
Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/soc/soc_ti_k3.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/soc/soc_ti_k3.c b/drivers/soc/soc_ti_k3.c index 965728e818..42344145f9 100644 --- a/drivers/soc/soc_ti_k3.c +++ b/drivers/soc/soc_ti_k3.c @@ -15,6 +15,7 @@ #define J7200 0xbb6d #define AM64X 0xbb38 #define J721S2 0xbb75 +#define AM62X 0xbb7e
#define JTAG_ID_VARIANT_SHIFT 28 #define JTAG_ID_VARIANT_MASK (0xf << 28) @@ -49,6 +50,9 @@ static const char *get_family_string(u32 idreg) case J721S2: family = "J721S2"; break; + case AM62X: + family = "AM62X"; + break; default: family = "Unknown Silicon"; };
The AM62 SoC family is the follow on AM335x built on K3 Multicore SoC architecture platform, providing ultra-low-power modes, dual display, multi-sensor edge compute, security and other BOM-saving integration. The AM62 SoC targets broad market to enable applications such as Industrial HMI, PLC/CNC/Robot control, Medical Equipment, Building Automation, Appliances and more.
Some highlights of this SoC are:
* Quad-Cortex-A53s (running up to 1.4GHz) in a single cluster. Pin-to-pin compatible options for single and quad core are available. * Cortex-M4F for general-purpose or safety usage. * Dual display support, providing 24-bit RBG parallel interface and OLDI/LVDS-4 Lane x2, up to 200MHz pixel clock support for 2K display resolution. * Selectable GPUsupport, up to 8GFLOPS, providing better user experience in 3D graphic display case and Android. * PRU(Programmable Realtime Unit) support for customized programmable interfaces/IOs. * Integrated Giga-bit Ethernet switch supporting up to a total of two external ports (TSN capable). * 9xUARTs, 5xSPI, 6xI2C, 2xUSB2, 3xCAN-FD, 3x eMMC and SD, GPMC for NAND/FPGA connection, OSPI memory controller, 3xMcASP for audio, 1x CSI-RX-4L for Camera, eCAP/eQEP, ePWM, among other peripherals. * Dedicated Centralized System Controller for Security, Power, and Resource Management. * Multiple low power modes support, ex: Deep sleep,Standby, MCU-only, enabling battery powered system design.
AM625 is the first device of the family. Add DT bindings for the same.
More details can be found in the Technical Reference Manual: https://www.ti.com/lit/pdf/spruiv7
Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Gowtham Tammana g-tammana@ti.com Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- arch/arm/mach-k3/Kconfig | 9 +- arch/arm/mach-k3/Makefile | 1 + arch/arm/mach-k3/am625_init.c | 271 ++++++++++++++++++ arch/arm/mach-k3/arm64-mmu.c | 4 +- arch/arm/mach-k3/include/mach/am62_hardware.h | 75 +++++ arch/arm/mach-k3/include/mach/am62_spl.h | 48 ++++ arch/arm/mach-k3/include/mach/hardware.h | 4 + arch/arm/mach-k3/include/mach/spl.h | 5 + drivers/ram/Kconfig | 1 + 9 files changed, 415 insertions(+), 3 deletions(-) create mode 100644 arch/arm/mach-k3/am625_init.c create mode 100644 arch/arm/mach-k3/include/mach/am62_hardware.h create mode 100644 arch/arm/mach-k3/include/mach/am62_spl.h
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index a01bf23514..0dc4f44fdd 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -16,6 +16,9 @@ config SOC_K3_J721S2 config SOC_K3_AM642 bool "TI's K3 based AM642 SoC Family Support"
+config SOC_K3_AM625 + bool "TI's K3 based AM625 SoC Family Support" + endchoice
config SYS_SOC @@ -26,6 +29,7 @@ config SYS_K3_NON_SECURE_MSRAM_SIZE default 0x80000 if SOC_K3_AM6 default 0x100000 if SOC_K3_J721E || SOC_K3_J721S2 default 0x1c0000 if SOC_K3_AM642 + default 0x3c000 if SOC_K3_AM625 help Describes the total size of the MCU or OCMC MSRAM present on the SoC in use. This doesn't specify the total size of SPL as @@ -37,6 +41,7 @@ config SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE default 0x58000 if SOC_K3_AM6 default 0xc0000 if SOC_K3_J721E || SOC_K3_J721S2 default 0x180000 if SOC_K3_AM642 + default 0x38000 if SOC_K3_AM625 help Describes the maximum size of the image that ROM can download from any boot media. @@ -61,6 +66,7 @@ config SYS_K3_BOOT_PARAM_TABLE_INDEX default 0x41cffbfc if SOC_K3_J721E default 0x41cfdbfc if SOC_K3_J721S2 default 0x701bebfc if SOC_K3_AM642 + default 0x43c3f290 if SOC_K3_AM625 help Address at which ROM stores the value which determines if SPL is booted up by primary boot media or secondary boot media. @@ -129,6 +135,7 @@ config K3_SYSFW_IMAGE_MMCSD_RAW_MODE_PART config K3_SYSFW_IMAGE_SIZE_MAX int "Amount of memory dynamically allocated for loading SYSFW blob" depends on K3_LOAD_SYSFW + default 163840 if SOC_K3_AM625 default 278000 help Amount of memory (in bytes) reserved through dynamic allocation at @@ -160,7 +167,7 @@ config K3_ATF_LOAD_ADDR
config K3_DM_FW bool "Separate DM firmware image" - depends on SPL && CPU_V7R && (SOC_K3_J721E || SOC_K3_J721S2) && !CLK_TI_SCI && !TI_SCI_POWER_DOMAIN + depends on SPL && CPU_V7R && (SOC_K3_J721E || SOC_K3_J721S2 || SOC_K3_AM625) && !CLK_TI_SCI && !TI_SCI_POWER_DOMAIN default y help Enabling this will indicate that the system has separate DM diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index c0a6a9c87d..8459bef93b 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -7,6 +7,7 @@ obj-$(CONFIG_SOC_K3_AM6) += am6_init.o obj-$(CONFIG_SOC_K3_J721E) += j721e_init.o j721e/ j7200/ obj-$(CONFIG_SOC_K3_J721S2) += j721s2_init.o j721s2/ obj-$(CONFIG_SOC_K3_AM642) += am642_init.o +obj-$(CONFIG_SOC_K3_AM625) += am625_init.o am62x/ obj-$(CONFIG_ARM64) += arm64-mmu.o obj-$(CONFIG_CPU_V7R) += r5_mpu.o lowlevel_init.o obj-$(CONFIG_TI_SECURE_DEVICE) += security.o diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c new file mode 100644 index 0000000000..0d9525992b --- /dev/null +++ b/arch/arm/mach-k3/am625_init.c @@ -0,0 +1,271 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * AM625: SoC specific initialization + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + * Suman Anna s-anna@ti.com + */ + +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sysfw-loader.h> +#include "common.h" +#include <dm.h> +#include <dm/uclass-internal.h> +#include <dm/pinctrl.h> + +#if defined(CONFIG_SPL_BUILD) + +/* + * This uninitialized global variable would normal end up in the .bss section, + * but the .bss is cleared between writing and reading this variable, so move + * it to the .data section. + */ +u32 bootindex __section(".data"); +static struct rom_extended_boot_data bootdata __section(".data"); + +static void store_boot_info_from_rom(void) +{ + bootindex = *(u32 *)(CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX); + memcpy(&bootdata, (uintptr_t *)ROM_ENTENDED_BOOT_DATA_INFO, + sizeof(struct rom_extended_boot_data)); +} + +static void ctrl_mmr_unlock(void) +{ + /* Unlock all WKUP_CTRL_MMR0 module registers */ + mmr_unlock(WKUP_CTRL_MMR0_BASE, 0); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 1); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 2); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 3); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 4); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 5); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 6); + mmr_unlock(WKUP_CTRL_MMR0_BASE, 7); + + /* Unlock all CTRL_MMR0 module registers */ + mmr_unlock(CTRL_MMR0_BASE, 0); + mmr_unlock(CTRL_MMR0_BASE, 1); + mmr_unlock(CTRL_MMR0_BASE, 2); + mmr_unlock(CTRL_MMR0_BASE, 4); + mmr_unlock(CTRL_MMR0_BASE, 6); + + /* Unlock all MCU_CTRL_MMR0 module registers */ + mmr_unlock(MCU_CTRL_MMR0_BASE, 0); + mmr_unlock(MCU_CTRL_MMR0_BASE, 1); + mmr_unlock(MCU_CTRL_MMR0_BASE, 2); + mmr_unlock(MCU_CTRL_MMR0_BASE, 3); + mmr_unlock(MCU_CTRL_MMR0_BASE, 4); + mmr_unlock(MCU_CTRL_MMR0_BASE, 6); + + /* Unlock PADCFG_CTRL_MMR padconf registers */ + mmr_unlock(PADCFG_MMR0_BASE, 1); + mmr_unlock(PADCFG_MMR1_BASE, 1); +} + +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + +#if defined(CONFIG_CPU_V7R) + setup_k3_mpu_regions(); +#endif + + /* + * Cannot delay this further as there is a chance that + * K3_BOOT_PARAM_TABLE_INDEX can be over written by SPL MALLOC section. + */ + store_boot_info_from_rom(); + + ctrl_mmr_unlock(); + + /* Init DM early */ + spl_early_init(); + + /* + * Process pinctrl for the serial0 and serial3, aka WKUP_UART0 and + * MAIN_UART1 modules and continue regardless of the result of pinctrl. + * Do this without probing the device, but instead by searching the + * device that would request the given sequence number if probed. The + * UARTs will be used by the DM firmware and TIFS firmware images + * respectively and the firmware depend on SPL to initialize the pin + * settings. + */ + ret = uclass_find_device_by_seq(UCLASS_SERIAL, 0, &dev); + if (!ret) + pinctrl_select_state(dev, "default"); + + ret = uclass_find_device_by_seq(UCLASS_SERIAL, 3, &dev); + if (!ret) + pinctrl_select_state(dev, "default"); + + preloader_console_init(); + +#ifdef CONFIG_K3_EARLY_CONS + /* + * Allow establishing an early console as required for example when + * doing a UART-based boot. Note that this console may not "survive" + * through a SYSFW PM-init step and will need a re-init in some way + * due to changing module clock frequencies. + */ + early_console_init(); +#endif + +#if defined(CONFIG_K3_LOAD_SYSFW) + /* + * Configure and start up system controller firmware. Provide + * the U-Boot console init function to the SYSFW post-PM configuration + * callback hook, effectively switching on (or over) the console + * output. + */ + ret = is_rom_loaded_sysfw(&bootdata); + if (!ret) + panic("ROM has not loaded TIFS firmware\n"); + + k3_sysfw_loader(true, NULL, NULL); +#endif + + /* + * Force probe of clk_k3 driver here to ensure basic default clock + * configuration is always done. + */ + if (IS_ENABLED(CONFIG_SPL_CLK_K3)) { + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_DRIVER_GET(ti_clk), + &dev); + if (ret) + printf("Failed to initialize clk-k3!\n"); + } + + /* Output System Firmware version info */ + k3_sysfw_print_ver(); + +#if defined(CONFIG_K3_AM64_DDRSS) + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) + panic("DRAM init failed: %d\n", ret); +#endif +} + +u32 spl_mmc_boot_mode(struct mmc *mmc, const u32 boot_device) +{ + u32 devstat = readl(CTRLMMR_MAIN_DEVSTAT); + u32 bootmode_cfg = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT; + + switch (boot_device) { + case BOOT_DEVICE_MMC1: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_FS_RAW_MASK) >> + MAIN_DEVSTAT_PRIMARY_MMC_FS_RAW_SHIFT) + return MMCSD_MODE_EMMCBOOT; + return MMCSD_MODE_FS; + + case BOOT_DEVICE_MMC2: + return MMCSD_MODE_FS; + + default: + return MMCSD_MODE_RAW; + } +} + +static u32 __get_backup_bootmedia(u32 devstat) +{ + u32 bkup_bootmode = (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_MASK) >> + MAIN_DEVSTAT_BACKUP_BOOTMODE_SHIFT; + u32 bkup_bootmode_cfg = + (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_SHIFT; + + switch (bkup_bootmode) { + case BACKUP_BOOT_DEVICE_UART: + return BOOT_DEVICE_UART; + + case BACKUP_BOOT_DEVICE_USB: + return BOOT_DEVICE_USB; + + case BACKUP_BOOT_DEVICE_ETHERNET: + return BOOT_DEVICE_ETHERNET; + + case BACKUP_BOOT_DEVICE_MMC: + if (bkup_bootmode_cfg) + return BOOT_DEVICE_MMC2; + return BOOT_DEVICE_MMC1; + + case BACKUP_BOOT_DEVICE_SPI: + return BOOT_DEVICE_SPI; + + case BACKUP_BOOT_DEVICE_I2C: + return BOOT_DEVICE_I2C; + + case BACKUP_BOOT_DEVICE_DFU: + if (bkup_bootmode_cfg & MAIN_DEVSTAT_BACKUP_USB_MODE_MASK) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + }; + + return BOOT_DEVICE_RAM; +} + +static u32 __get_primary_bootmedia(u32 devstat) +{ + u32 bootmode = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_SHIFT; + u32 bootmode_cfg = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT; + + switch (bootmode) { + case BOOT_DEVICE_OSPI: + fallthrough; + case BOOT_DEVICE_QSPI: + fallthrough; + case BOOT_DEVICE_XSPI: + fallthrough; + case BOOT_DEVICE_SPI: + return BOOT_DEVICE_SPI; + + case BOOT_DEVICE_ETHERNET_RGMII: + fallthrough; + case BOOT_DEVICE_ETHERNET_RMII: + return BOOT_DEVICE_ETHERNET; + + case BOOT_DEVICE_EMMC: + return BOOT_DEVICE_MMC1; + + case BOOT_DEVICE_MMC: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK) >> + MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT) + return BOOT_DEVICE_MMC2; + return BOOT_DEVICE_MMC1; + + case BOOT_DEVICE_DFU: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + + case BOOT_DEVICE_NOBOOT: + return BOOT_DEVICE_RAM; + } + + return bootmode; +} + +u32 spl_boot_device(void) +{ + u32 devstat = readl(CTRLMMR_MAIN_DEVSTAT); + u32 bootmedia; + + if (bootindex == K3_PRIMARY_BOOTMODE) + bootmedia = __get_primary_bootmedia(devstat); + else + bootmedia = __get_backup_bootmedia(devstat); + + debug("am625_init: %s: devstat = 0x%x bootmedia = 0x%x bootindex = %d\n", + __func__, devstat, bootmedia, bootindex); + + return bootmedia; +} + +#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/mach-k3/arm64-mmu.c b/arch/arm/mach-k3/arm64-mmu.c index 527e664318..12cb89335a 100644 --- a/arch/arm/mach-k3/arm64-mmu.c +++ b/arch/arm/mach-k3/arm64-mmu.c @@ -222,7 +222,7 @@ struct mm_region *mem_map = j721s2_mem_map;
#endif /* CONFIG_SOC_K3_J721S2 */
-#ifdef CONFIG_SOC_K3_AM642 +#if (CONFIG_IS_ENABLED(SOC_K3_AM642) || CONFIG_IS_ENABLED(SOC_K3_AM625)) /* NR_DRAM_BANKS + 32bit IO + 64bit IO + terminator */ #define NR_MMU_REGIONS (CONFIG_NR_DRAM_BANKS + 3)
@@ -261,4 +261,4 @@ struct mm_region am64_mem_map[NR_MMU_REGIONS] = { };
struct mm_region *mem_map = am64_mem_map; -#endif /* CONFIG_SOC_K3_AM642 */ +#endif /* CONFIG_SOC_K3_AM642 || CONFIG_SOC_K3_AM625 */ diff --git a/arch/arm/mach-k3/include/mach/am62_hardware.h b/arch/arm/mach-k3/include/mach/am62_hardware.h new file mode 100644 index 0000000000..cfabd20cbd --- /dev/null +++ b/arch/arm/mach-k3/include/mach/am62_hardware.h @@ -0,0 +1,75 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * K3: AM62 SoC definitions, structures etc. + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + * Suman Anna s-anna@ti.com + */ + +#ifndef __ASM_ARCH_AM62_HARDWARE_H +#define __ASM_ARCH_AM62_HARDWARE_H + +#include <config.h> +#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#endif + +#define PADCFG_MMR0_BASE 0x04080000 +#define PADCFG_MMR1_BASE 0x000f0000 +#define CTRL_MMR0_BASE 0x00100000 +#define MCU_CTRL_MMR0_BASE 0x04500000 +#define WKUP_CTRL_MMR0_BASE 0x43000000 + +#define CTRLMMR_MAIN_DEVSTAT (WKUP_CTRL_MMR0_BASE + 0x30) +#define MAIN_DEVSTAT_PRIMARY_BOOTMODE_MASK GENMASK(6, 3) +#define MAIN_DEVSTAT_PRIMARY_BOOTMODE_SHIFT 3 +#define MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK GENMASK(9, 7) +#define MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT 7 +#define MAIN_DEVSTAT_BACKUP_BOOTMODE_MASK GENMASK(12, 10) +#define MAIN_DEVSTAT_BACKUP_BOOTMODE_SHIFT 10 +#define MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_MASK BIT(13) +#define MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_SHIFT 13 + +/* Primary Bootmode MMC Config macros */ +#define MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK 0x4 +#define MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT 2 +#define MAIN_DEVSTAT_PRIMARY_MMC_FS_RAW_MASK 0x1 +#define MAIN_DEVSTAT_PRIMARY_MMC_FS_RAW_SHIFT 0 + +/* Primary Bootmode USB Config macros */ +#define MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT 1 +#define MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK 0x02 + +/* Backup Bootmode USB Config macros */ +#define MAIN_DEVSTAT_BACKUP_USB_MODE_MASK 0x01 + +/* + * The CTRL_MMR0 memory space is divided into several equally-spaced + * partitions, so defining the partition size allows us to determine + * register addresses common to those partitions. + */ +#define CTRL_MMR0_PARTITION_SIZE 0x4000 + +/* + * CTRL_MMR0, WKUP_CTRL_MMR0, and MCU_CTRL_MMR0 lock/kick-mechanism + * shared register definitions. The same registers are also used for + * PADCFG_MMR lock/kick-mechanism. + */ +#define CTRLMMR_LOCK_KICK0 0x1008 +#define CTRLMMR_LOCK_KICK0_UNLOCK_VAL 0x68ef3490 +#define CTRLMMR_LOCK_KICK1 0x100c +#define CTRLMMR_LOCK_KICK1_UNLOCK_VAL 0xd172bc5a + +#define MCU_CTRL_LFXOSC_CTRL (MCU_CTRL_MMR0_BASE + 0x8038) +#define MCU_CTRL_LFXOSC_TRIM (MCU_CTRL_MMR0_BASE + 0x803c) +#define MCU_CTRL_LFXOSC_32K_DISABLE_VAL BIT(7) + +#define MCU_CTRL_DEVICE_CLKOUT_32K_CTRL (MCU_CTRL_MMR0_BASE + 0x8058) +#define MCU_CTRL_DEVICE_CLKOUT_LFOSC_SELECT_VAL (0x3) + +#define ROM_ENTENDED_BOOT_DATA_INFO 0x43c3f1e0 + +/* Use Last 2K as Scratch pad */ +#define TI_SRAM_SCRATCH_BOARD_EEPROM_START 0x70000000 + +#endif /* __ASM_ARCH_AM62_HARDWARE_H */ diff --git a/arch/arm/mach-k3/include/mach/am62_spl.h b/arch/arm/mach-k3/include/mach/am62_spl.h new file mode 100644 index 0000000000..2c9139d2cc --- /dev/null +++ b/arch/arm/mach-k3/include/mach/am62_spl.h @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + * Suman Anna s-anna@ti.com + */ + +#ifndef _ASM_ARCH_AM62_SPL_H_ +#define _ASM_ARCH_AM62_SPL_H_ + +/* Primary BootMode devices */ +#define BOOT_DEVICE_RAM 0x00 +#define BOOT_DEVICE_OSPI 0x01 +#define BOOT_DEVICE_QSPI 0x02 +#define BOOT_DEVICE_SPI 0x03 +#define BOOT_DEVICE_CPGMAC 0x04 +#define BOOT_DEVICE_ETHERNET_RGMII 0x04 +#define BOOT_DEVICE_ETHERNET_RMII 0x05 +#define BOOT_DEVICE_I2C 0x06 +#define BOOT_DEVICE_UART 0x07 +#define BOOT_DEVICE_MMC 0x08 +#define BOOT_DEVICE_EMMC 0x09 + +#define BOOT_DEVICE_USB 0x2A +#define BOOT_DEVICE_DFU 0x0A +#define BOOT_DEVICE_GPMC_NAND 0x0B +#define BOOT_DEVICE_GPMC_NOR 0x0C +#define BOOT_DEVICE_XSPI 0x0E +#define BOOT_DEVICE_NOBOOT 0x0F + +/* U-Boot used aliases */ +#define BOOT_DEVICE_ETHERNET 0x04 +#define BOOT_DEVICE_MMC2 0x08 +#define BOOT_DEVICE_MMC1 0x09 +/* Invalid */ +#define BOOT_DEVICE_MMC2_2 0x1F + +/* Backup BootMode devices */ +#define BACKUP_BOOT_DEVICE_DFU 0x01 +#define BACKUP_BOOT_DEVICE_UART 0x03 +#define BACKUP_BOOT_DEVICE_ETHERNET 0x04 +#define BACKUP_BOOT_DEVICE_MMC 0x05 +#define BACKUP_BOOT_DEVICE_SPI 0x06 +#define BACKUP_BOOT_DEVICE_I2C 0x07 +#define BACKUP_BOOT_DEVICE_USB 0x09 + +#define K3_PRIMARY_BOOTMODE 0x0 + +#endif /* _ASM_ARCH_AM62_SPL_H_ */ diff --git a/arch/arm/mach-k3/include/mach/hardware.h b/arch/arm/mach-k3/include/mach/hardware.h index 5c1265ffe9..7c6928d5da 100644 --- a/arch/arm/mach-k3/include/mach/hardware.h +++ b/arch/arm/mach-k3/include/mach/hardware.h @@ -22,6 +22,10 @@ #include "am64_hardware.h" #endif
+#ifdef CONFIG_SOC_K3_AM625 +#include "am62_hardware.h" +#endif + /* Assuming these addresses and definitions stay common across K3 devices */ #define CTRLMMR_WKUP_JTAG_ID 0x43000014 #define JTAG_ID_VARIANT_SHIFT 28 diff --git a/arch/arm/mach-k3/include/mach/spl.h b/arch/arm/mach-k3/include/mach/spl.h index 8a61398529..17996f2938 100644 --- a/arch/arm/mach-k3/include/mach/spl.h +++ b/arch/arm/mach-k3/include/mach/spl.h @@ -21,4 +21,9 @@ #ifdef CONFIG_SOC_K3_AM642 #include "am64_spl.h" #endif + +#ifdef CONFIG_SOC_K3_AM625 +#include "am62_spl.h" +#endif + #endif /* _ASM_ARCH_SPL_H_ */ diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index 709c916a2a..a4f9f1aad2 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -64,6 +64,7 @@ choice
default K3_J721E_DDRSS if SOC_K3_J721E || SOC_K3_J721S2 default K3_AM64_DDRSS if SOC_K3_AM642 + default K3_AM64_DDRSS if SOC_K3_AM625
config K3_J721E_DDRSS bool "Enable J721E DDRSS support"
- Quad-Cortex-A53s (running up to 1.4GHz) in a single cluster. Pin-to-pin compatible options for single and quad core are available.
- Cortex-M4F for general-purpose or safety usage.
- Dual display support, providing 24-bit RBG parallel interface and OLDI/LVDS-4 Lane x2, up to 200MHz pixel clock support for 2K display resolution.
- Selectable GPUsupport, up to 8GFLOPS, providing better user experience in 3D graphic display case and Android.
- PRU(Programmable Realtime Unit) support for customized programmable interfaces/IOs.
- Integrated Giga-bit Ethernet switch supporting up to a total of two external ports (TSN capable).
- 9xUARTs, 5xSPI, 6xI2C, 2xUSB2, 3xCAN-FD, 3x eMMC and SD, GPMC for NAND/FPGA connection, OSPI memory controller, 3xMcASP for audio, 1x CSI-RX-4L for Camera, eCAP/eQEP, ePWM, among other peripherals.
- Dedicated Centralized System Controller for Security, Power, and Resource Management.
- Multiple low power modes support, ex: Deep sleep,Standby, MCU-only, enabling battery powered system design.
Introduce autogenerated SoC data support clk and device data for the AM62. Hook it upto to power-domain and clk frameworks of U-Boot.
Signed-off-by: Dave Gerlach d-gerlach@ti.com Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- arch/arm/mach-k3/am62x/Makefile | 6 + arch/arm/mach-k3/am62x/clk-data.c | 366 +++++++++++++++++++++++++ arch/arm/mach-k3/am62x/dev-data.c | 78 ++++++ drivers/clk/ti/clk-k3.c | 6 + drivers/power/domain/ti-power-domain.c | 6 + include/k3-clk.h | 1 + include/k3-dev.h | 1 + 7 files changed, 464 insertions(+) create mode 100644 arch/arm/mach-k3/am62x/Makefile create mode 100644 arch/arm/mach-k3/am62x/clk-data.c create mode 100644 arch/arm/mach-k3/am62x/dev-data.c
diff --git a/arch/arm/mach-k3/am62x/Makefile b/arch/arm/mach-k3/am62x/Makefile new file mode 100644 index 0000000000..d6c876df66 --- /dev/null +++ b/arch/arm/mach-k3/am62x/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ + +obj-y += clk-data.o +obj-y += dev-data.o diff --git a/arch/arm/mach-k3/am62x/clk-data.c b/arch/arm/mach-k3/am62x/clk-data.c new file mode 100644 index 0000000000..c0881778fe --- /dev/null +++ b/arch/arm/mach-k3/am62x/clk-data.c @@ -0,0 +1,366 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * AM62X specific clock platform data + * + * This file is auto generated. Please do not hand edit and report any issues + * to Dave Gerlach d-gerlach@ti.com. + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <linux/clk-provider.h> +#include "k3-clk.h" + +static const char * const gluelogic_hfosc0_clkout_parents[] = { + NULL, + NULL, + "osc_24_mhz", + "osc_25_mhz", + "osc_26_mhz", + NULL, +}; + +static const char * const main_emmcsd0_io_clklb_sel_out0_parents[] = { + "board_0_mmc0_clklb_out", + "board_0_mmc0_clk_out", +}; + +static const char * const main_emmcsd1_io_clklb_sel_out0_parents[] = { + "board_0_mmc1_clklb_out", + "board_0_mmc1_clk_out", +}; + +static const char * const main_ospi_loopback_clk_sel_out0_parents[] = { + "board_0_ospi0_dqs_out", + "board_0_ospi0_lbclko_out", +}; + +static const char * const main_usb0_refclk_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "postdiv4_16ff_main_0_hsdivout8_clk", +}; + +static const char * const main_usb1_refclk_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "postdiv4_16ff_main_0_hsdivout8_clk", +}; + +static const char * const sam62_pll_ctrl_wrap_main_0_sysclkout_clk_parents[] = { + "gluelogic_hfosc0_clkout", + "hsdiv4_16fft_main_0_hsdivout0_clk", +}; + +static const char * const sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk_parents[] = { + "gluelogic_hfosc0_clkout", + "hsdiv4_16fft_mcu_0_hsdivout0_clk", +}; + +static const char * const clkout0_ctrl_out0_parents[] = { + "hsdiv4_16fft_main_2_hsdivout1_clk", + "hsdiv4_16fft_main_2_hsdivout1_clk", +}; + +static const char * const clk_32k_rc_sel_out0_parents[] = { + "gluelogic_rcosc_clk_1p0v_97p65k", + "hsdiv0_16fft_mcu_32khz_gen_0_hsdivout0_clk", + "clk_32k_rc_sel_div_clkout", + "gluelogic_lfosc0_clkout", +}; + +static const char * const main_cp_gemac_cpts_clk_sel_out0_parents[] = { + "postdiv4_16ff_main_2_hsdivout5_clk", + "postdiv4_16ff_main_0_hsdivout6_clk", + "board_0_cp_gemac_cpts0_rft_clk_out", + NULL, + "board_0_mcu_ext_refclk0_out", + "board_0_ext_refclk1_out", + "sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk", + "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk", +}; + +static const char * const main_emmcsd0_refclk_sel_out0_parents[] = { + "postdiv4_16ff_main_0_hsdivout5_clk", + "hsdiv4_16fft_main_2_hsdivout2_clk", +}; + +static const char * const main_emmcsd1_refclk_sel_out0_parents[] = { + "postdiv4_16ff_main_0_hsdivout5_clk", + "hsdiv4_16fft_main_2_hsdivout2_clk", +}; + +static const char * const main_gtcclk_sel_out0_parents[] = { + "postdiv4_16ff_main_2_hsdivout5_clk", + "postdiv4_16ff_main_0_hsdivout6_clk", + "board_0_cp_gemac_cpts0_rft_clk_out", + NULL, + "board_0_mcu_ext_refclk0_out", + "board_0_ext_refclk1_out", + "sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk", + "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk", +}; + +static const char * const main_ospi_ref_clk_sel_out0_parents[] = { + "hsdiv4_16fft_main_0_hsdivout1_clk", + "postdiv1_16fft_main_1_hsdivout5_clk", +}; + +static const char * const wkup_clkout_sel_out0_parents[] = { + "gluelogic_hfosc0_clkout", + "gluelogic_lfosc0_clkout", + "hsdiv4_16fft_main_0_hsdivout2_clk", + "hsdiv4_16fft_main_1_hsdivout2_clk", + "postdiv4_16ff_main_2_hsdivout9_clk", + "clk_32k_rc_sel_out0", + "gluelogic_rcosc_clkout", + "gluelogic_hfosc0_clkout", +}; + +static const char * const wkup_clksel_out0_parents[] = { + "hsdiv1_16fft_main_15_hsdivout0_clk", + "hsdiv4_16fft_mcu_0_hsdivout0_clk", +}; + +static const char * const main_usart0_fclk_sel_out0_parents[] = { + "usart_programmable_clock_divider_out0", + "hsdiv4_16fft_main_1_hsdivout1_clk", +}; + +static const struct clk_data clk_list[] = { + CLK_FIXED_RATE("osc_26_mhz", 26000000, 0), + CLK_FIXED_RATE("osc_25_mhz", 25000000, 0), + CLK_FIXED_RATE("osc_24_mhz", 24000000, 0), + CLK_MUX("gluelogic_hfosc0_clkout", gluelogic_hfosc0_clkout_parents, 6, 0x43000030, 0, 3, 0), + CLK_FIXED_RATE("gluelogic_rcosc_clkout", 12500000, 0), + CLK_FIXED_RATE("gluelogic_rcosc_clk_1p0v_97p65k", 97656, 0), + CLK_FIXED_RATE("board_0_cp_gemac_cpts0_rft_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_ddr0_ck0_out", 0, 0), + CLK_FIXED_RATE("board_0_ext_refclk1_out", 0, 0), + CLK_FIXED_RATE("board_0_i2c0_scl_out", 0, 0), + CLK_FIXED_RATE("board_0_mcu_ext_refclk0_out", 0, 0), + CLK_FIXED_RATE("board_0_mmc0_clklb_out", 0, 0), + CLK_FIXED_RATE("board_0_mmc0_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_mmc1_clklb_out", 0, 0), + CLK_FIXED_RATE("board_0_mmc1_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_ospi0_dqs_out", 0, 0), + CLK_FIXED_RATE("board_0_ospi0_lbclko_out", 0, 0), + CLK_FIXED_RATE("board_0_rgmii1_rxc_out", 0, 0), + CLK_FIXED_RATE("board_0_rgmii1_txc_out", 0, 0), + CLK_FIXED_RATE("board_0_rgmii2_rxc_out", 0, 0), + CLK_FIXED_RATE("board_0_rgmii2_txc_out", 0, 0), + CLK_FIXED_RATE("board_0_rmii1_ref_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_rmii2_ref_clk_out", 0, 0), + CLK_FIXED_RATE("board_0_tck_out", 0, 0), + CLK_FIXED_RATE("cpsw_3guss_main_0_mdio_mdclk_o", 0, 0), + CLK_FIXED_RATE("cpsw_3guss_main_0_rgmii1_txc_o", 0, 0), + CLK_FIXED_RATE("cpsw_3guss_main_0_rgmii2_txc_o", 0, 0), + CLK_FIXED_RATE("emmcsd4ss_main_0_emmcsdss_io_clk_o", 0, 0), + CLK_FIXED_RATE("emmcsd8ss_main_0_emmcsdss_io_clk_o", 0, 0), + CLK_FIXED_RATE("fss_ul_main_0_ospi_0_ospi_oclk_clk", 0, 0), + CLK_DIV("hsdiv0_16fft_mcu_32khz_gen_0_hsdivout0_clk", "gluelogic_hfosc0_clkout", 0x4508030, 0, 7, 0, 0), + CLK_FIXED_RATE("mshsi2c_main_0_porscl", 0, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_0_foutvcop_clk", "gluelogic_hfosc0_clkout", 0x680000, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680038, 16, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_DIV("pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk_subdiv", 0x680038, 24, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_PLL("pllfracf_ssmod_16fft_main_1_foutvcop_clk", "gluelogic_hfosc0_clkout", 0x681000, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681038, 16, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_DIV("pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk_subdiv", 0x681038, 24, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_PLL("pllfracf_ssmod_16fft_main_12_foutvcop_clk", "gluelogic_hfosc0_clkout", 0x68c000, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_15_foutvcop_clk", "gluelogic_hfosc0_clkout", 0x68f000, 0), + CLK_PLL("pllfracf_ssmod_16fft_main_2_foutvcop_clk", "gluelogic_hfosc0_clkout", 0x682000, 0), + CLK_DIV("pllfracf_ssmod_16fft_main_2_foutpostdiv_clk_subdiv", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682038, 16, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_DIV("pllfracf_ssmod_16fft_main_2_foutpostdiv_clk", "pllfracf_ssmod_16fft_main_2_foutpostdiv_clk_subdiv", 0x682038, 24, 3, 0, CLK_DIVIDER_ONE_BASED), + CLK_PLL("pllfracf_ssmod_16fft_main_8_foutvcop_clk", "gluelogic_hfosc0_clkout", 0x688000, 0), + CLK_PLL("pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", "gluelogic_hfosc0_clkout", 0x4040000, 0), + CLK_DIV("postdiv1_16fft_main_1_hsdivout5_clk", "pllfracf_ssmod_16fft_main_1_foutpostdiv_clk", 0x681094, 0, 7, 0, 0), + CLK_DIV("postdiv4_16ff_main_0_hsdivout5_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", 0x680094, 0, 7, 0, 0), + CLK_DIV("postdiv4_16ff_main_0_hsdivout6_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", 0x680098, 0, 7, 0, 0), + CLK_DIV("postdiv4_16ff_main_0_hsdivout8_clk", "pllfracf_ssmod_16fft_main_0_foutpostdiv_clk", 0x6800a0, 0, 7, 0, 0), + CLK_DIV("postdiv4_16ff_main_2_hsdivout5_clk", "pllfracf_ssmod_16fft_main_2_foutpostdiv_clk", 0x682094, 0, 7, 0, 0), + CLK_DIV("postdiv4_16ff_main_2_hsdivout8_clk", "pllfracf_ssmod_16fft_main_2_foutpostdiv_clk", 0x6820a0, 0, 7, 0, 0), + CLK_DIV("postdiv4_16ff_main_2_hsdivout9_clk", "pllfracf_ssmod_16fft_main_2_foutpostdiv_clk", 0x6820a4, 0, 7, 0, 0), + CLK_MUX("main_emmcsd0_io_clklb_sel_out0", main_emmcsd0_io_clklb_sel_out0_parents, 2, 0x108160, 16, 1, 0), + CLK_MUX("main_emmcsd1_io_clklb_sel_out0", main_emmcsd1_io_clklb_sel_out0_parents, 2, 0x108168, 16, 1, 0), + CLK_MUX("main_ospi_loopback_clk_sel_out0", main_ospi_loopback_clk_sel_out0_parents, 2, 0x108500, 4, 1, 0), + CLK_MUX("main_usb0_refclk_sel_out0", main_usb0_refclk_sel_out0_parents, 2, 0x43008190, 0, 1, 0), + CLK_MUX("main_usb1_refclk_sel_out0", main_usb1_refclk_sel_out0_parents, 2, 0x43008194, 0, 1, 0), + CLK_DIV("hsdiv0_16fft_main_12_hsdivout0_clk", "pllfracf_ssmod_16fft_main_12_foutvcop_clk", 0x68c080, 0, 7, 0, 0), + CLK_DIV("hsdiv0_16fft_main_8_hsdivout0_clk", "pllfracf_ssmod_16fft_main_8_foutvcop_clk", 0x688080, 0, 7, 0, 0), + CLK_DIV("hsdiv1_16fft_main_15_hsdivout0_clk", "pllfracf_ssmod_16fft_main_15_foutvcop_clk", 0x68f080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout0_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680080, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout1_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout2_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout3_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x68008c, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_0_hsdivout4_clk", "pllfracf_ssmod_16fft_main_0_foutvcop_clk", 0x680090, 0, 7, 0, 0), + CLK_DIV_DEFFREQ("hsdiv4_16fft_main_1_hsdivout0_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681080, 0, 7, 0, 0, 192000000), + CLK_DIV("hsdiv4_16fft_main_1_hsdivout1_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_1_hsdivout2_clk", "pllfracf_ssmod_16fft_main_1_foutvcop_clk", 0x681088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout1_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682084, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_main_2_hsdivout2_clk", "pllfracf_ssmod_16fft_main_2_foutvcop_clk", 0x682088, 0, 7, 0, 0), + CLK_DIV("hsdiv4_16fft_mcu_0_hsdivout0_clk", "pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", 0x4040080, 0, 7, 0, 0), + CLK_MUX_PLLCTRL("sam62_pll_ctrl_wrap_main_0_sysclkout_clk", sam62_pll_ctrl_wrap_main_0_sysclkout_clk_parents, 2, 0x410000, 0), + CLK_DIV("sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk", "sam62_pll_ctrl_wrap_main_0_sysclkout_clk", 0x410118, 0, 5, 0, 0), + CLK_MUX_PLLCTRL("sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk", sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk_parents, 2, 0x4020000, 0), + CLK_DIV("sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk", "sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk", 0x4020118, 0, 5, 0, 0), + CLK_MUX("clkout0_ctrl_out0", clkout0_ctrl_out0_parents, 2, 0x108010, 0, 1, 0), + CLK_MUX("clk_32k_rc_sel_out0", clk_32k_rc_sel_out0_parents, 4, 0x4508058, 0, 2, 0), + CLK_MUX("main_cp_gemac_cpts_clk_sel_out0", main_cp_gemac_cpts_clk_sel_out0_parents, 8, 0x108140, 0, 3, 0), + CLK_MUX("main_emmcsd0_refclk_sel_out0", main_emmcsd0_refclk_sel_out0_parents, 2, 0x108160, 0, 1, 0), + CLK_MUX("main_emmcsd1_refclk_sel_out0", main_emmcsd1_refclk_sel_out0_parents, 2, 0x108168, 0, 1, 0), + CLK_MUX("main_gtcclk_sel_out0", main_gtcclk_sel_out0_parents, 8, 0x43008030, 0, 3, 0), + CLK_MUX("main_ospi_ref_clk_sel_out0", main_ospi_ref_clk_sel_out0_parents, 2, 0x108500, 0, 1, 0), + CLK_DIV_DEFFREQ("usart_programmable_clock_divider_out0", "hsdiv4_16fft_main_1_hsdivout0_clk", 0x108240, 0, 2, 0, 0, 48000000), + CLK_MUX("wkup_clkout_sel_out0", wkup_clkout_sel_out0_parents, 8, 0x43008020, 0, 3, 0), + CLK_MUX("wkup_clksel_out0", wkup_clksel_out0_parents, 2, 0x43008010, 0, 1, 0), + CLK_MUX("main_usart0_fclk_sel_out0", main_usart0_fclk_sel_out0_parents, 2, 0x108280, 0, 1, 0), + CLK_DIV("hsdiv4_16fft_mcu_0_hsdivout1_clk", "pllfracf_ssmod_16fft_mcu_0_foutvcop_clk", 0x4040084, 0, 7, 0, 0), + CLK_FIXED_RATE("mshsi2c_wkup_0_porscl", 0, 0), + CLK_DIV("sam62_pll_ctrl_wrap_main_0_chip_div24_clk_clk", "sam62_pll_ctrl_wrap_main_0_sysclkout_clk", 0x41011c, 0, 5, 0, 0), + CLK_DIV("sam62_pll_ctrl_wrap_mcu_0_chip_div24_clk_clk", "sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk", 0x402011c, 0, 5, 0, 0), +}; + +static const struct dev_clk soc_dev_clk_data[] = { + DEV_CLK(13, 0, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(13, 3, "main_cp_gemac_cpts_clk_sel_out0"), + DEV_CLK(13, 4, "postdiv4_16ff_main_2_hsdivout5_clk"), + DEV_CLK(13, 5, "postdiv4_16ff_main_0_hsdivout6_clk"), + DEV_CLK(13, 6, "board_0_cp_gemac_cpts0_rft_clk_out"), + DEV_CLK(13, 8, "board_0_mcu_ext_refclk0_out"), + DEV_CLK(13, 9, "board_0_ext_refclk1_out"), + DEV_CLK(13, 10, "sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk"), + DEV_CLK(13, 11, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(13, 13, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 14, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 15, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 16, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 17, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 19, "board_0_rgmii1_rxc_out"), + DEV_CLK(13, 20, "board_0_rgmii1_txc_out"), + DEV_CLK(13, 22, "board_0_rgmii2_rxc_out"), + DEV_CLK(13, 23, "board_0_rgmii2_txc_out"), + DEV_CLK(13, 25, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 26, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 27, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(13, 28, "board_0_rmii1_ref_clk_out"), + DEV_CLK(13, 29, "board_0_rmii2_ref_clk_out"), + DEV_CLK(16, 0, "hsdiv4_16fft_main_0_hsdivout1_clk"), + DEV_CLK(16, 1, "hsdiv4_16fft_main_0_hsdivout2_clk"), + DEV_CLK(16, 2, "hsdiv4_16fft_main_0_hsdivout3_clk"), + DEV_CLK(16, 3, "hsdiv4_16fft_main_0_hsdivout4_clk"), + DEV_CLK(16, 4, "gluelogic_hfosc0_clkout"), + DEV_CLK(16, 5, "board_0_ext_refclk1_out"), + DEV_CLK(16, 6, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(16, 7, "postdiv4_16ff_main_2_hsdivout8_clk"), + DEV_CLK(16, 8, "gluelogic_hfosc0_clkout"), + DEV_CLK(16, 9, "board_0_ext_refclk1_out"), + DEV_CLK(16, 10, "gluelogic_rcosc_clkout"), + DEV_CLK(16, 11, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(16, 12, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(57, 0, "main_emmcsd0_io_clklb_sel_out0"), + DEV_CLK(57, 1, "board_0_mmc0_clklb_out"), + DEV_CLK(57, 2, "board_0_mmc0_clk_out"), + DEV_CLK(57, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(57, 6, "main_emmcsd0_refclk_sel_out0"), + DEV_CLK(57, 7, "postdiv4_16ff_main_0_hsdivout5_clk"), + DEV_CLK(57, 8, "hsdiv4_16fft_main_2_hsdivout2_clk"), + DEV_CLK(58, 0, "main_emmcsd1_io_clklb_sel_out0"), + DEV_CLK(58, 1, "board_0_mmc1_clklb_out"), + DEV_CLK(58, 2, "board_0_mmc1_clk_out"), + DEV_CLK(58, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(58, 6, "main_emmcsd1_refclk_sel_out0"), + DEV_CLK(58, 7, "postdiv4_16ff_main_0_hsdivout5_clk"), + DEV_CLK(58, 8, "hsdiv4_16fft_main_2_hsdivout2_clk"), + DEV_CLK(61, 0, "main_gtcclk_sel_out0"), + DEV_CLK(61, 1, "postdiv4_16ff_main_2_hsdivout5_clk"), + DEV_CLK(61, 2, "postdiv4_16ff_main_0_hsdivout6_clk"), + DEV_CLK(61, 3, "board_0_cp_gemac_cpts0_rft_clk_out"), + DEV_CLK(61, 5, "board_0_mcu_ext_refclk0_out"), + DEV_CLK(61, 6, "board_0_ext_refclk1_out"), + DEV_CLK(61, 7, "sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk"), + DEV_CLK(61, 8, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(61, 9, "wkup_clksel_out0"), + DEV_CLK(61, 10, "hsdiv1_16fft_main_15_hsdivout0_clk"), + DEV_CLK(61, 11, "hsdiv4_16fft_mcu_0_hsdivout0_clk"), + DEV_CLK(75, 0, "board_0_ospi0_dqs_out"), + DEV_CLK(75, 1, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(75, 2, "main_ospi_loopback_clk_sel_out0"), + DEV_CLK(75, 3, "board_0_ospi0_dqs_out"), + DEV_CLK(75, 4, "board_0_ospi0_lbclko_out"), + DEV_CLK(75, 6, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(75, 7, "main_ospi_ref_clk_sel_out0"), + DEV_CLK(75, 8, "hsdiv4_16fft_main_0_hsdivout1_clk"), + DEV_CLK(75, 9, "postdiv1_16fft_main_1_hsdivout5_clk"), + DEV_CLK(77, 0, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(95, 0, "gluelogic_rcosc_clkout"), + DEV_CLK(95, 1, "gluelogic_hfosc0_clkout"), + DEV_CLK(95, 2, "wkup_clksel_out0"), + DEV_CLK(95, 3, "hsdiv1_16fft_main_15_hsdivout0_clk"), + DEV_CLK(95, 4, "hsdiv4_16fft_mcu_0_hsdivout0_clk"), + DEV_CLK(102, 0, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(102, 1, "board_0_i2c0_scl_out"), + DEV_CLK(102, 2, "hsdiv4_16fft_main_1_hsdivout0_clk"), + DEV_CLK(107, 0, "wkup_clksel_out0"), + DEV_CLK(107, 1, "hsdiv1_16fft_main_15_hsdivout0_clk"), + DEV_CLK(107, 2, "hsdiv4_16fft_mcu_0_hsdivout0_clk"), + DEV_CLK(107, 3, "mshsi2c_wkup_0_porscl"), + DEV_CLK(107, 4, "hsdiv4_16fft_mcu_0_hsdivout1_clk"), + DEV_CLK(135, 0, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(136, 0, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(140, 0, "sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk"), + DEV_CLK(140, 1, "sam62_pll_ctrl_wrap_mcu_0_chip_div1_clk_clk"), + DEV_CLK(146, 0, "main_usart0_fclk_sel_out0"), + DEV_CLK(146, 1, "usart_programmable_clock_divider_out0"), + DEV_CLK(146, 2, "hsdiv4_16fft_main_1_hsdivout1_clk"), + DEV_CLK(146, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(157, 20, "clkout0_ctrl_out0"), + DEV_CLK(157, 21, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(157, 22, "hsdiv4_16fft_main_2_hsdivout1_clk"), + DEV_CLK(157, 24, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(157, 25, "board_0_ddr0_ck0_out"), + DEV_CLK(157, 40, "mshsi2c_main_0_porscl"), + DEV_CLK(157, 77, "sam62_pll_ctrl_wrap_mcu_0_sysclkout_clk"), + DEV_CLK(157, 82, "cpsw_3guss_main_0_mdio_mdclk_o"), + DEV_CLK(157, 83, "emmcsd8ss_main_0_emmcsdss_io_clk_o"), + DEV_CLK(157, 87, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), + DEV_CLK(157, 89, "emmcsd4ss_main_0_emmcsdss_io_clk_o"), + DEV_CLK(157, 129, "fss_ul_main_0_ospi_0_ospi_oclk_clk"), + DEV_CLK(157, 132, "cpsw_3guss_main_0_rgmii1_txc_o"), + DEV_CLK(157, 135, "cpsw_3guss_main_0_rgmii2_txc_o"), + DEV_CLK(157, 145, "sam62_pll_ctrl_wrap_main_0_sysclkout_clk"), + DEV_CLK(157, 158, "wkup_clkout_sel_out0"), + DEV_CLK(157, 159, "gluelogic_hfosc0_clkout"), + DEV_CLK(157, 160, "gluelogic_lfosc0_clkout"), + DEV_CLK(157, 161, "hsdiv4_16fft_main_0_hsdivout2_clk"), + DEV_CLK(157, 162, "hsdiv4_16fft_main_1_hsdivout2_clk"), + DEV_CLK(157, 163, "postdiv4_16ff_main_2_hsdivout9_clk"), + DEV_CLK(157, 164, "clk_32k_rc_sel_out0"), + DEV_CLK(157, 165, "gluelogic_rcosc_clkout"), + DEV_CLK(157, 166, "gluelogic_hfosc0_clkout"), + DEV_CLK(161, 0, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(161, 1, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(161, 2, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(161, 3, "main_usb0_refclk_sel_out0"), + DEV_CLK(161, 4, "gluelogic_hfosc0_clkout"), + DEV_CLK(161, 5, "postdiv4_16ff_main_0_hsdivout8_clk"), + DEV_CLK(161, 10, "board_0_tck_out"), + DEV_CLK(162, 0, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(162, 1, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(162, 2, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(162, 3, "main_usb1_refclk_sel_out0"), + DEV_CLK(162, 4, "gluelogic_hfosc0_clkout"), + DEV_CLK(162, 5, "postdiv4_16ff_main_0_hsdivout8_clk"), + DEV_CLK(162, 10, "board_0_tck_out"), + DEV_CLK(166, 3, "hsdiv0_16fft_main_8_hsdivout0_clk"), + DEV_CLK(166, 5, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(169, 0, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(169, 1, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), + DEV_CLK(170, 0, "hsdiv0_16fft_main_12_hsdivout0_clk"), + DEV_CLK(170, 1, "board_0_tck_out"), + DEV_CLK(170, 2, "sam62_pll_ctrl_wrap_main_0_chip_div1_clk_clk"), +}; + +const struct ti_k3_clk_platdata am62x_clk_platdata = { + .clk_list = clk_list, + .clk_list_cnt = 90, + .soc_dev_clk_data = soc_dev_clk_data, + .soc_dev_clk_data_cnt = 137, +}; diff --git a/arch/arm/mach-k3/am62x/dev-data.c b/arch/arm/mach-k3/am62x/dev-data.c new file mode 100644 index 0000000000..616d0650b9 --- /dev/null +++ b/arch/arm/mach-k3/am62x/dev-data.c @@ -0,0 +1,78 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * AM62X specific device platform data + * + * This file is auto generated. Please do not hand edit and report any issues + * to Dave Gerlach d-gerlach@ti.com. + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-dev.h" + +static struct ti_psc soc_psc_list[] = { + [0] = PSC(0, 0x04000000), + [1] = PSC(1, 0x00400000), +}; + +static struct ti_pd soc_pd_list[] = { + [0] = PSC_PD(0, &soc_psc_list[1], NULL), + [1] = PSC_PD(2, &soc_psc_list[1], &soc_pd_list[0]), + [2] = PSC_PD(3, &soc_psc_list[1], &soc_pd_list[0]), + [3] = PSC_PD(4, &soc_psc_list[1], &soc_pd_list[2]), + [4] = PSC_PD(5, &soc_psc_list[1], &soc_pd_list[2]), +}; + +static struct ti_lpsc soc_lpsc_list[] = { + [0] = PSC_LPSC(0, &soc_psc_list[1], &soc_pd_list[0], NULL), + [1] = PSC_LPSC(9, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[11]), + [2] = PSC_LPSC(10, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[1]), + [3] = PSC_LPSC(11, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[2]), + [4] = PSC_LPSC(12, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[8]), + [5] = PSC_LPSC(13, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[9]), + [6] = PSC_LPSC(20, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[11]), + [7] = PSC_LPSC(21, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[11]), + [8] = PSC_LPSC(23, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[11]), + [9] = PSC_LPSC(24, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[11]), + [10] = PSC_LPSC(28, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[11]), + [11] = PSC_LPSC(34, &soc_psc_list[1], &soc_pd_list[0], &soc_lpsc_list[11]), + [12] = PSC_LPSC(41, &soc_psc_list[1], &soc_pd_list[1], &soc_lpsc_list[11]), + [13] = PSC_LPSC(42, &soc_psc_list[1], &soc_pd_list[2], &soc_lpsc_list[11]), + [14] = PSC_LPSC(45, &soc_psc_list[1], &soc_pd_list[3], &soc_lpsc_list[13]), + [15] = PSC_LPSC(46, &soc_psc_list[1], &soc_pd_list[4], &soc_lpsc_list[13]), +}; + +static struct ti_dev soc_dev_list[] = { + PSC_DEV(16, &soc_lpsc_list[0]), + PSC_DEV(77, &soc_lpsc_list[0]), + PSC_DEV(61, &soc_lpsc_list[0]), + PSC_DEV(95, &soc_lpsc_list[0]), + PSC_DEV(107, &soc_lpsc_list[0]), + PSC_DEV(170, &soc_lpsc_list[1]), + PSC_DEV(177, &soc_lpsc_list[2]), + PSC_DEV(55, &soc_lpsc_list[3]), + PSC_DEV(178, &soc_lpsc_list[4]), + PSC_DEV(179, &soc_lpsc_list[5]), + PSC_DEV(57, &soc_lpsc_list[6]), + PSC_DEV(58, &soc_lpsc_list[7]), + PSC_DEV(161, &soc_lpsc_list[8]), + PSC_DEV(162, &soc_lpsc_list[9]), + PSC_DEV(75, &soc_lpsc_list[10]), + PSC_DEV(102, &soc_lpsc_list[11]), + PSC_DEV(146, &soc_lpsc_list[11]), + PSC_DEV(13, &soc_lpsc_list[12]), + PSC_DEV(166, &soc_lpsc_list[13]), + PSC_DEV(135, &soc_lpsc_list[14]), + PSC_DEV(136, &soc_lpsc_list[15]), +}; + +const struct ti_k3_pd_platdata am62x_pd_platdata = { + .psc = soc_psc_list, + .pd = soc_pd_list, + .lpsc = soc_lpsc_list, + .devs = soc_dev_list, + .num_psc = 2, + .num_pd = 5, + .num_lpsc = 16, + .num_devs = 21, +}; diff --git a/drivers/clk/ti/clk-k3.c b/drivers/clk/ti/clk-k3.c index 74beb4d8eb..0dd65934b3 100644 --- a/drivers/clk/ti/clk-k3.c +++ b/drivers/clk/ti/clk-k3.c @@ -73,6 +73,12 @@ static const struct soc_attr ti_k3_soc_clk_data[] = { .family = "J721S2", .data = &j721s2_clk_platdata, }, +#endif +#ifdef CONFIG_SOC_K3_AM625 + { + .family = "AM62X", + .data = &am62x_clk_platdata, + }, #endif { /* sentinel */ } }; diff --git a/drivers/power/domain/ti-power-domain.c b/drivers/power/domain/ti-power-domain.c index 292fff0dfb..a7f64d04f5 100644 --- a/drivers/power/domain/ti-power-domain.c +++ b/drivers/power/domain/ti-power-domain.c @@ -86,6 +86,12 @@ static const struct soc_attr ti_k3_soc_pd_data[] = { .family = "J721S2", .data = &j721s2_pd_platdata, }, +#endif +#ifdef CONFIG_SOC_K3_AM625 + { + .family = "AM62X", + .data = &am62x_pd_platdata, + }, #endif { /* sentinel */ } }; diff --git a/include/k3-clk.h b/include/k3-clk.h index 31292b59f2..371f077c44 100644 --- a/include/k3-clk.h +++ b/include/k3-clk.h @@ -174,6 +174,7 @@ struct ti_k3_clk_platdata { extern const struct ti_k3_clk_platdata j721e_clk_platdata; extern const struct ti_k3_clk_platdata j7200_clk_platdata; extern const struct ti_k3_clk_platdata j721s2_clk_platdata; +extern const struct ti_k3_clk_platdata am62x_clk_platdata;
struct clk *clk_register_ti_pll(const char *name, const char *parent_name, void __iomem *reg); diff --git a/include/k3-dev.h b/include/k3-dev.h index b46b8c3aab..87e873b9ce 100644 --- a/include/k3-dev.h +++ b/include/k3-dev.h @@ -78,6 +78,7 @@ struct ti_k3_pd_platdata { extern const struct ti_k3_pd_platdata j721e_pd_platdata; extern const struct ti_k3_pd_platdata j7200_pd_platdata; extern const struct ti_k3_pd_platdata j721s2_pd_platdata; +extern const struct ti_k3_pd_platdata am62x_pd_platdata;
u8 ti_pd_state(struct ti_pd *pd); u8 lpsc_get_state(struct ti_lpsc *lpsc);
Add PSIL data for AM62x SoC.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/dma/ti/Makefile | 1 + drivers/dma/ti/k3-psil-am62.c | 50 +++++++++++++++++++++++++++++++++++ drivers/dma/ti/k3-psil-priv.h | 1 + drivers/dma/ti/k3-psil.c | 2 ++ 4 files changed, 54 insertions(+) create mode 100644 drivers/dma/ti/k3-psil-am62.c
diff --git a/drivers/dma/ti/Makefile b/drivers/dma/ti/Makefile index 6a4f4f1365..56f348700d 100644 --- a/drivers/dma/ti/Makefile +++ b/drivers/dma/ti/Makefile @@ -7,3 +7,4 @@ k3-psil-data-$(CONFIG_SOC_K3_AM6) += k3-psil-am654.o k3-psil-data-$(CONFIG_SOC_K3_J721E) += k3-psil-j721e.o k3-psil-data-$(CONFIG_SOC_K3_J721S2) += k3-psil-j721s2.o k3-psil-data-$(CONFIG_SOC_K3_AM642) += k3-psil-am64.o +k3-psil-data-$(CONFIG_SOC_K3_AM625) += k3-psil-am62.o diff --git a/drivers/dma/ti/k3-psil-am62.c b/drivers/dma/ti/k3-psil-am62.c new file mode 100644 index 0000000000..9527da4cac --- /dev/null +++ b/drivers/dma/ti/k3-psil-am62.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com + */ + +#include <linux/kernel.h> + +#include "k3-psil-priv.h" + +#define PSIL_ETHERNET(x, ch, flow_base, flow_cnt) \ + { \ + .thread_id = x, \ + .ep_config = { \ + .ep_type = PSIL_EP_NATIVE, \ + .pkt_mode = 1, \ + .needs_epib = 1, \ + .psd_size = 16, \ + .mapped_channel_id = ch, \ + .flow_start = flow_base, \ + .flow_num = flow_cnt, \ + .default_flow_id = flow_base, \ + }, \ + } + +/* PSI-L source thread IDs, used for RX (DMA_DEV_TO_MEM) */ +static struct psil_ep am62_src_ep_map[] = { + /* CPSW3G */ + PSIL_ETHERNET(0x4600, 19, 19, 16), +}; + +/* PSI-L destination thread IDs, used for TX (DMA_MEM_TO_DEV) */ +static struct psil_ep am62_dst_ep_map[] = { + /* CPSW3G */ + PSIL_ETHERNET(0xc600, 19, 19, 8), + PSIL_ETHERNET(0xc601, 20, 27, 8), + PSIL_ETHERNET(0xc602, 21, 35, 8), + PSIL_ETHERNET(0xc603, 22, 43, 8), + PSIL_ETHERNET(0xc604, 23, 51, 8), + PSIL_ETHERNET(0xc605, 24, 59, 8), + PSIL_ETHERNET(0xc606, 25, 67, 8), + PSIL_ETHERNET(0xc607, 26, 75, 8), +}; + +struct psil_ep_map am62_ep_map = { + .name = "am62", + .src = am62_src_ep_map, + .src_count = ARRAY_SIZE(am62_src_ep_map), + .dst = am62_dst_ep_map, + .dst_count = ARRAY_SIZE(am62_dst_ep_map), +}; diff --git a/drivers/dma/ti/k3-psil-priv.h b/drivers/dma/ti/k3-psil-priv.h index 77acaf2139..28078c6bd8 100644 --- a/drivers/dma/ti/k3-psil-priv.h +++ b/drivers/dma/ti/k3-psil-priv.h @@ -41,5 +41,6 @@ extern struct psil_ep_map am654_ep_map; extern struct psil_ep_map j721e_ep_map; extern struct psil_ep_map j721s2_ep_map; extern struct psil_ep_map am64_ep_map; +extern struct psil_ep_map am62_ep_map;
#endif /* K3_PSIL_PRIV_H_ */ diff --git a/drivers/dma/ti/k3-psil.c b/drivers/dma/ti/k3-psil.c index 8b2129d4f5..f1330bf4b0 100644 --- a/drivers/dma/ti/k3-psil.c +++ b/drivers/dma/ti/k3-psil.c @@ -24,6 +24,8 @@ struct psil_endpoint_config *psil_get_ep_config(u32 thread_id) soc_ep_map = &j721s2_ep_map; else if (IS_ENABLED(CONFIG_SOC_K3_AM642)) soc_ep_map = &am64_ep_map; + else if (IS_ENABLED(CONFIG_SOC_K3_AM625)) + soc_ep_map = &am62_ep_map; }
if (thread_id & K3_PSIL_DST_THREAD_ID_OFFSET && soc_ep_map->dst) {
Add range of DMA channels available for R5 SPL usage before DM firmware is loaded.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/firmware/ti_sci_static_data.h | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/firmware/ti_sci_static_data.h b/drivers/firmware/ti_sci_static_data.h index e6a3b66c03..8529ef2900 100644 --- a/drivers/firmware/ti_sci_static_data.h +++ b/drivers/firmware/ti_sci_static_data.h @@ -118,6 +118,19 @@ static struct ti_sci_resource_static_data rm_static_data[] = { }; #endif /* CONFIG_TARGET_J721S2_R5_EVM */
+#if IS_ENABLED(CONFIG_SOC_K3_AM625) +static struct ti_sci_resource_static_data rm_static_data[] = { + /* BC channels */ + { + .dev_id = 26, + .subtype = 32, + .range_start = 18, + .range_num = 2, + }, + { }, +}; +#endif /* CONFIG_SOC_K3_AM625 */ + #else static struct ti_sci_resource_static_data rm_static_data[] = { { },
Introduce the basic AM62 SoC description dtsi files describing most peripherals as per kernel dts.
Signed-off-by: Gowtham Tammana g-tammana@ti.com Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- arch/arm/dts/k3-am62-ddr.dtsi | 11 + arch/arm/dts/k3-am62-main.dtsi | 533 +++++++++++++++++++++++++++++++ arch/arm/dts/k3-am62-mcu.dtsi | 56 ++++ arch/arm/dts/k3-am62-wakeup.dtsi | 41 +++ arch/arm/dts/k3-am62.dtsi | 105 ++++++ arch/arm/dts/k3-am625.dtsi | 103 ++++++ 6 files changed, 849 insertions(+) create mode 100644 arch/arm/dts/k3-am62-ddr.dtsi create mode 100644 arch/arm/dts/k3-am62-main.dtsi create mode 100644 arch/arm/dts/k3-am62-mcu.dtsi create mode 100644 arch/arm/dts/k3-am62-wakeup.dtsi create mode 100644 arch/arm/dts/k3-am62.dtsi create mode 100644 arch/arm/dts/k3-am625.dtsi
diff --git a/arch/arm/dts/k3-am62-ddr.dtsi b/arch/arm/dts/k3-am62-ddr.dtsi new file mode 100644 index 0000000000..0a8ced8f38 --- /dev/null +++ b/arch/arm/dts/k3-am62-ddr.dtsi @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-am64-ddr.dtsi" +&memorycontroller { + power-domains = <&k3_pds 170 TI_SCI_PD_SHARED>, + <&k3_pds 55 TI_SCI_PD_SHARED>; + clocks = <&k3_clks 170 0>, <&k3_clks 16 4>; +}; diff --git a/arch/arm/dts/k3-am62-main.dtsi b/arch/arm/dts/k3-am62-main.dtsi new file mode 100644 index 0000000000..4b6ba98dd0 --- /dev/null +++ b/arch/arm/dts/k3-am62-main.dtsi @@ -0,0 +1,533 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for AM625 SoC Family Main Domain peripherals + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +&cbass_main { + oc_sram: sram@70000000 { + compatible = "mmio-sram"; + reg = <0x00 0x70000000 0x00 0x10000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x70000000 0x10000>; + }; + + gic500: interrupt-controller@1800000 { + compatible = "arm,gic-v3"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ + <0x00 0x01880000 0x00 0xc0000>, /* GICR */ + <0x00 0x01880000 0x00 0xc0000>, /* GICR */ + <0x01 0x00000000 0x00 0x2000>, /* GICC */ + <0x01 0x00010000 0x00 0x1000>, /* GICH */ + <0x01 0x00020000 0x00 0x2000>; /* GICV */ + /* + * vcpumntirq: + * virtual CPU interface maintenance interrupt + */ + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + + gic_its: msi-controller@1820000 { + compatible = "arm,gic-v3-its"; + reg = <0x00 0x01820000 0x00 0x10000>; + socionext,synquacer-pre-its = <0x1000000 0x400000>; + msi-controller; + #msi-cells = <1>; + }; + }; + + main_conf: syscon@100000 { + compatible = "syscon", "simple-mfd"; + reg = <0x00 0x00100000 0x00 0x20000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x00100000 0x20000>; + + phy_gmii_sel: phy@4044 { + compatible = "ti,am654-phy-gmii-sel"; + reg = <0x4044 0x8>; + #phy-cells = <1>; + }; + }; + + dmss: bus@48000000 { + compatible = "simple-mfd"; + #address-cells = <2>; + #size-cells = <2>; + dma-ranges; + ranges = <0x00 0x48000000 0x00 0x48000000 0x00 0x06400000>; + + ti,sci-dev-id = <25>; + + secure_proxy_main: mailbox@4d000000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "target_data", "rt", "scfg"; + reg = <0x00 0x4d000000 0x00 0x80000>, + <0x00 0x4a600000 0x00 0x80000>, + <0x00 0x4a400000 0x00 0x80000>; + interrupt-names = "rx_012"; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + }; + + inta_main_dmss: interrupt-controller@48000000 { + compatible = "ti,sci-inta"; + reg = <0x00 0x48000000 0x00 0x100000>; + #interrupt-cells = <0>; + interrupt-controller; + interrupt-parent = <&gic500>; + msi-controller; + ti,sci = <&dmsc>; + ti,sci-dev-id = <28>; + ti,interrupt-ranges = <4 68 36>; + ti,unmapped-event-sources = <&main_bcdma>, <&main_pktdma>; + }; + + main_bcdma: dma-controller@485c0100 { + compatible = "ti,am64-dmss-bcdma"; + reg = <0x00 0x485c0100 0x00 0x100>, + <0x00 0x4c000000 0x00 0x20000>, + <0x00 0x4a820000 0x00 0x20000>, + <0x00 0x4aa40000 0x00 0x20000>, + <0x00 0x4bc00000 0x00 0x100000>; + reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt"; + msi-parent = <&inta_main_dmss>; + #dma-cells = <3>; + + ti,sci = <&dmsc>; + ti,sci-dev-id = <26>; + ti,sci-rm-range-bchan = <0x20>; /* BLOCK_COPY_CHAN */ + ti,sci-rm-range-rchan = <0x21>; /* SPLIT_TR_RX_CHAN */ + ti,sci-rm-range-tchan = <0x22>; /* SPLIT_TR_TX_CHAN */ + }; + + main_pktdma: dma-controller@485c0000 { + compatible = "ti,am64-dmss-pktdma"; + reg = <0x00 0x485c0000 0x00 0x100>, + <0x00 0x4a800000 0x00 0x20000>, + <0x00 0x4aa00000 0x00 0x40000>, + <0x00 0x4b800000 0x00 0x400000>; + reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt"; + msi-parent = <&inta_main_dmss>; + #dma-cells = <2>; + + ti,sci = <&dmsc>; + ti,sci-dev-id = <30>; + ti,sci-rm-range-tchan = <0x23>, /* UNMAPPED_TX_CHAN */ + <0x24>, /* CPSW_TX_CHAN */ + <0x25>, /* SAUL_TX_0_CHAN */ + <0x26>; /* SAUL_TX_1_CHAN */ + ti,sci-rm-range-tflow = <0x10>, /* RING_UNMAPPED_TX_CHAN */ + <0x11>, /* RING_CPSW_TX_CHAN */ + <0x12>, /* RING_SAUL_TX_0_CHAN */ + <0x13>; /* RING_SAUL_TX_1_CHAN */ + ti,sci-rm-range-rchan = <0x29>, /* UNMAPPED_RX_CHAN */ + <0x2b>, /* CPSW_RX_CHAN */ + <0x2d>, /* SAUL_RX_0_CHAN */ + <0x2f>, /* SAUL_RX_1_CHAN */ + <0x31>, /* SAUL_RX_2_CHAN */ + <0x33>; /* SAUL_RX_3_CHAN */ + ti,sci-rm-range-rflow = <0x2a>, /* FLOW_UNMAPPED_RX_CHAN */ + <0x2c>, /* FLOW_CPSW_RX_CHAN */ + <0x2e>, /* FLOW_SAUL_RX_0/1_CHAN */ + <0x32>; /* FLOW_SAUL_RX_2/3_CHAN */ + }; + }; + + dmsc: system-controller@44043000 { + compatible = "ti,k2g-sci"; + ti,host-id = <12>; + mbox-names = "rx", "tx"; + mboxes= <&secure_proxy_main 12>, + <&secure_proxy_main 13>; + reg-names = "debug_messages"; + reg = <0x00 0x44043000 0x00 0xfe0>; + + k3_pds: power-controller { + compatible = "ti,sci-pm-domain"; + #power-domain-cells = <2>; + }; + + k3_clks: clock-controller { + compatible = "ti,k2g-sci-clk"; + #clock-cells = <2>; + }; + + k3_reset: reset-controller { + compatible = "ti,sci-reset"; + #reset-cells = <2>; + }; + }; + + main_pmx0: pinctrl@f4000 { + compatible = "pinctrl-single"; + reg = <0x00 0xf4000 0x00 0x2ac>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + main_uart0: serial@2800000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x02800000 0x00 0x100>; + interrupts = <GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 146 0>; + clock-names = "fclk"; + }; + + main_uart1: serial@2810000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x02810000 0x00 0x100>; + interrupts = <GIC_SPI 179 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 152 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 152 0>; + clock-names = "fclk"; + }; + + main_uart2: serial@2820000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x02820000 0x00 0x100>; + interrupts = <GIC_SPI 180 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 153 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 153 0>; + clock-names = "fclk"; + }; + + main_uart3: serial@2830000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x02830000 0x00 0x100>; + interrupts = <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 154 0>; + clock-names = "fclk"; + }; + + main_uart4: serial@2840000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x02840000 0x00 0x100>; + interrupts = <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 155 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 155 0>; + clock-names = "fclk"; + }; + + main_uart5: serial@2850000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x02850000 0x00 0x100>; + interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 156 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 156 0>; + clock-names = "fclk"; + }; + + main_uart6: serial@2860000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x02860000 0x00 0x100>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 158 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 158 0>; + clock-names = "fclk"; + }; + + main_i2c0: i2c@20000000 { + compatible = "ti,am64-i2c", "ti,omap4-i2c"; + reg = <0x00 0x20000000 0x00 0x100>; + interrupts = <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 102 2>; + clock-names = "fck"; + }; + + main_i2c1: i2c@20010000 { + compatible = "ti,am64-i2c", "ti,omap4-i2c"; + reg = <0x00 0x20010000 0x00 0x100>; + interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 103 2>; + clock-names = "fck"; + }; + + main_i2c2: i2c@20020000 { + compatible = "ti,am64-i2c", "ti,omap4-i2c"; + reg = <0x00 0x20020000 0x00 0x100>; + interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 104 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 104 2>; + clock-names = "fck"; + }; + + main_i2c3: i2c@20030000 { + compatible = "ti,am64-i2c", "ti,omap4-i2c"; + reg = <0x00 0x20030000 0x00 0x100>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 105 2>; + clock-names = "fck"; + }; + + main_spi0: spi@20100000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x20100000 0x00 0x400>; + interrupts = <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 172 0>; + }; + + main_spi1: spi@20110000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x20110000 0x00 0x400>; + interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 142 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 173 0>; + }; + + main_spi2: spi@20120000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x20120000 0x00 0x400>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 143 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 174 0>; + }; + + main_gpio_intr: interrupt-controller@a00000 { + compatible = "ti,sci-intr"; + reg = <0x00 0x00a00000 0x00 0x800>; + ti,intr-trigger-type = <1>; + interrupt-controller; + interrupt-parent = <&gic500>; + #interrupt-cells = <1>; + ti,sci = <&dmsc>; + ti,sci-dev-id = <3>; + ti,interrupt-ranges = <0 32 16>; + }; + + main_gpio0: gpio@600000 { + compatible = "ti,am64-gpio", "ti,keystone-gpio"; + reg = <0x0 0x00600000 0x0 0x100>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&main_gpio_intr>; + interrupts = <190>, <191>, <192>, + <193>, <194>, <195>; + interrupt-controller; + #interrupt-cells = <2>; + ti,ngpio = <87>; + ti,davinci-gpio-unbanked = <0>; + power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 77 0>; + clock-names = "gpio"; + }; + + main_gpio1: gpio@601000 { + compatible = "ti,am64-gpio", "ti,keystone-gpio"; + reg = <0x0 0x00601000 0x0 0x100>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&main_gpio_intr>; + interrupts = <180>, <181>, <182>, + <183>, <184>, <185>; + interrupt-controller; + #interrupt-cells = <2>; + ti,ngpio = <88>; + ti,davinci-gpio-unbanked = <0>; + power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 78 0>; + clock-names = "gpio"; + }; + + sdhci0: mmc@fa10000 { + compatible = "ti,am62-sdhci"; + reg = <0x00 0x0fa10000 0x00 0x1000>, <0x00 0x0fa18000 0x00 0x400>; + interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 57 5>, <&k3_clks 57 6>; + clock-names = "clk_ahb", "clk_xin"; + assigned-clocks = <&k3_clks 57 6>; + assigned-clock-parents = <&k3_clks 57 8>; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + ti,trm-icp = <0x2>; + bus-width = <8>; + ti,clkbuf-sel = <0x7>; + ti,otap-del-sel-legacy = <0x0>; + ti,otap-del-sel-mmc-hs = <0x0>; + ti,otap-del-sel-ddr52 = <0x9>; + ti,otap-del-sel-hs200 = <0x6>; + }; + + sdhci1: mmc@fa00000 { + compatible = "ti,am62-sdhci"; + reg = <0x00 0x0fa00000 0x00 0x1000>, <0x00 0x0fa08000 0x00 0x400>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 58 5>, <&k3_clks 58 6>; + clock-names = "clk_ahb", "clk_xin"; + ti,trm-icp = <0x2>; + ti,otap-del-sel-legacy = <0x0>; + ti,otap-del-sel-sd-hs = <0x0>; + ti,otap-del-sel-sdr12 = <0xf>; + ti,otap-del-sel-sdr25 = <0xf>; + ti,otap-del-sel-sdr50 = <0xc>; + ti,otap-del-sel-sdr104 = <0x6>; + ti,otap-del-sel-ddr50 = <0x9>; + ti,itap-del-sel-legacy = <0x0>; + ti,itap-del-sel-sd-hs = <0x0>; + ti,itap-del-sel-sdr12 = <0x0>; + ti,itap-del-sel-sdr25 = <0x0>; + ti,clkbuf-sel = <0x7>; + bus-width = <4>; + }; + + sdhci2: mmc@fa20000 { + compatible = "ti,am62-sdhci"; + reg = <0x00 0x0fa20000 0x00 0x1000>, <0x00 0x0fa28000 0x00 0x400>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 184 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 184 5>, <&k3_clks 184 6>; + clock-names = "clk_ahb", "clk_xin"; + ti,trm-icp = <0x2>; + ti,otap-del-sel-legacy = <0x0>; + ti,otap-del-sel-sd-hs = <0x0>; + ti,otap-del-sel-sdr12 = <0xf>; + ti,otap-del-sel-sdr25 = <0xf>; + ti,otap-del-sel-sdr50 = <0xc>; + ti,otap-del-sel-sdr104 = <0x6>; + ti,otap-del-sel-ddr50 = <0x9>; + ti,itap-del-sel-legacy = <0x0>; + ti,itap-del-sel-sd-hs = <0x0>; + ti,itap-del-sel-sdr12 = <0x0>; + ti,itap-del-sel-sdr25 = <0x0>; + ti,clkbuf-sel = <0x7>; + }; + + fss: bus@fc00000 { + compatible = "simple-bus"; + reg = <0x00 0x0fc00000 0x00 0x70000>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + ospi0: spi@fc40000 { + compatible = "ti,am654-ospi", "cdns,qspi-nor"; + reg = <0x00 0x0fc40000 0x00 0x100>, + <0x05 0x00000000 0x01 0x00000000>; + interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; + cdns,fifo-depth = <256>; + cdns,fifo-width = <4>; + cdns,trigger-address = <0x0>; + clocks = <&k3_clks 75 7>; + assigned-clocks = <&k3_clks 75 7>; + assigned-clock-parents = <&k3_clks 75 8>; + assigned-clock-rates = <166666666>; + power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + cpsw3g: ethernet@8000000 { + compatible = "ti,am642-cpsw-nuss"; + #address-cells = <2>; + #size-cells = <2>; + reg = <0x00 0x08000000 0x00 0x200000>; + reg-names = "cpsw_nuss"; + ranges = <0x00 0x00 0x00 0x08000000 0x00 0x200000>; + clocks = <&k3_clks 13 0>; + assigned-clocks = <&k3_clks 13 3>; + assigned-clock-parents = <&k3_clks 13 11>; + clock-names = "fck"; + power-domains = <&k3_pds 13 TI_SCI_PD_EXCLUSIVE>; + + dmas = <&main_pktdma 0xc600 15>, + <&main_pktdma 0xc601 15>, + <&main_pktdma 0xc602 15>, + <&main_pktdma 0xc603 15>, + <&main_pktdma 0xc604 15>, + <&main_pktdma 0xc605 15>, + <&main_pktdma 0xc606 15>, + <&main_pktdma 0xc607 15>, + <&main_pktdma 0x4600 15>; + dma-names = "tx0", "tx1", "tx2", "tx3", "tx4", "tx5", "tx6", + "tx7", "rx"; + + ethernet-ports { + #address-cells = <1>; + #size-cells = <0>; + + cpsw_port1: port@1 { + reg = <1>; + ti,mac-only; + label = "port1"; + phys = <&phy_gmii_sel 1>; + mac-address = [00 00 00 00 00 00]; + ti,syscon-efuse = <&wkup_conf 0x200>; + }; + + cpsw_port2: port@2 { + reg = <2>; + ti,mac-only; + label = "port2"; + phys = <&phy_gmii_sel 2>; + mac-address = [00 00 00 00 00 00]; + }; + }; + + cpsw3g_mdio: mdio@f00 { + compatible = "ti,cpsw-mdio","ti,davinci_mdio"; + reg = <0x00 0xf00 0x00 0x100>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&k3_clks 13 0>; + clock-names = "fck"; + bus_freq = <1000000>; + }; + + cpts@3d000 { + compatible = "ti,j721e-cpts"; + reg = <0x00 0x3d000 0x00 0x400>; + clocks = <&k3_clks 13 1>; + clock-names = "cpts"; + interrupts-extended = <&gic500 GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "cpts"; + ti,cpts-ext-ts-inputs = <4>; + ti,cpts-periodic-outputs = <2>; + }; + }; + + hwspinlock: spinlock@2a000000 { + compatible = "ti,am64-hwspinlock"; + reg = <0x00 0x2a000000 0x00 0x1000>; + #hwlock-cells = <1>; + }; + + mailbox0_cluster0: mailbox@29000000 { + compatible = "ti,am64-mailbox"; + reg = <0x00 0x29000000 0x00 0x200>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + #mbox-cells = <1>; + ti,mbox-num-users = <4>; + ti,mbox-num-fifos = <16>; + }; +}; diff --git a/arch/arm/dts/k3-am62-mcu.dtsi b/arch/arm/dts/k3-am62-mcu.dtsi new file mode 100644 index 0000000000..d103824c96 --- /dev/null +++ b/arch/arm/dts/k3-am62-mcu.dtsi @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for AM625 SoC Family MCU Domain peripherals + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +&cbass_mcu { + mcu_pmx0: pinctrl@4084000 { + compatible = "pinctrl-single"; + reg = <0x00 0x04084000 0x00 0x88>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + mcu_uart0: serial@4a00000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x04a00000 0x00 0x100>; + interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 149 0>; + clock-names = "fclk"; + }; + + mcu_i2c0: i2c@4900000 { + compatible = "ti,am64-i2c", "ti,omap4-i2c"; + reg = <0x00 0x04900000 0x00 0x100>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 106 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 106 2>; + clock-names = "fck"; + }; + + mcu_spi0: spi@4b00000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x04b00000 0x00 0x400>; + interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 147 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 147 0>; + }; + + mcu_spi1: spi@4b10000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x04b10000 0x00 0x400>; + interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 148 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 148 0>; + }; +}; diff --git a/arch/arm/dts/k3-am62-wakeup.dtsi b/arch/arm/dts/k3-am62-wakeup.dtsi new file mode 100644 index 0000000000..4090134676 --- /dev/null +++ b/arch/arm/dts/k3-am62-wakeup.dtsi @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for AM625 SoC Family Wakeup Domain peripherals + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +&cbass_wakeup { + wkup_conf: syscon@43000000 { + compatible = "syscon", "simple-mfd"; + reg = <0x00 0x43000000 0x00 0x20000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x43000000 0x20000>; + + chipid: chipid@14 { + compatible = "ti,am654-chipid"; + reg = <0x14 0x4>; + }; + }; + + wkup_uart0: serial@2b300000 { + compatible = "ti,am64-uart", "ti,am654-uart"; + reg = <0x00 0x2b300000 0x00 0x100>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 114 0>; + clock-names = "fclk"; + }; + + wkup_i2c0: i2c@2b200000 { + compatible = "ti,am64-i2c", "ti,omap4-i2c"; + reg = <0x00 0x02b200000 0x00 0x100>; + interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 107 4>; + clock-names = "fck"; + }; +}; diff --git a/arch/arm/dts/k3-am62.dtsi b/arch/arm/dts/k3-am62.dtsi new file mode 100644 index 0000000000..bc2997b185 --- /dev/null +++ b/arch/arm/dts/k3-am62.dtsi @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for AM62 SoC Family + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/pinctrl/k3.h> +#include <dt-bindings/soc/ti,sci_pm_domain.h> + +/ { + model = "Texas Instruments K3 AM625 SoC"; + compatible = "ti,am625"; + interrupt-parent = <&gic500>; + #address-cells = <2>; + #size-cells = <2>; + + chosen { }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + + psci: psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + }; + + a53_timer0: timer-cl0-cpu0 { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */ + <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */ + <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */ + <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */ + }; + + pmu: pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>; + }; + + cbass_main: bus@f0000 { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + + ranges = <0x00 0x000f0000 0x00 0x000f0000 0x00 0x00030000>, /* Main MMRs */ + <0x00 0x00420000 0x00 0x00420000 0x00 0x00001000>, /* ESM0 */ + <0x00 0x00600000 0x00 0x00600000 0x00 0x00001100>, /* GPIO */ + <0x00 0x00703000 0x00 0x00703000 0x00 0x00000200>, /* USB0 debug trace */ + <0x00 0x0070c000 0x00 0x0070c000 0x00 0x00000200>, /* USB1 debug trace */ + <0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* Timesync router */ + <0x00 0x01000000 0x00 0x01000000 0x00 0x01b28400>, /* First peripheral window */ + <0x00 0x08000000 0x00 0x08000000 0x00 0x00200000>, /* Main CPSW */ + <0x00 0x0e000000 0x00 0x0e000000 0x00 0x01d20000>, /* Second peripheral window */ + <0x00 0x0fd00000 0x00 0x0fd00000 0x00 0x00020000>, /* GPU */ + <0x00 0x20000000 0x00 0x20000000 0x00 0x0a008000>, /* Third peripheral window */ + <0x00 0x30040000 0x00 0x30040000 0x00 0x00080000>, /* PRUSS-M */ + <0x00 0x30101000 0x00 0x30101000 0x00 0x00010100>, /* CSI window */ + <0x00 0x30200000 0x00 0x30200000 0x00 0x00010000>, /* DSS */ + <0x00 0x31000000 0x00 0x31000000 0x00 0x00050000>, /* USB0 DWC3 Core window */ + <0x00 0x31100000 0x00 0x31100000 0x00 0x00050000>, /* USB1 DWC3 Core window */ + <0x00 0x43600000 0x00 0x43600000 0x00 0x00010000>, /* SA3 sproxy data */ + <0x00 0x44043000 0x00 0x44043000 0x00 0x00000fe0>, /* TI SCI DEBUG */ + <0x00 0x44860000 0x00 0x44860000 0x00 0x00040000>, /* SA3 sproxy config */ + <0x00 0x48000000 0x00 0x48000000 0x00 0x06400000>, /* DMSS */ + <0x00 0x60000000 0x00 0x60000000 0x00 0x08000000>, /* FSS0 DAT1 */ + <0x00 0x70000000 0x00 0x70000000 0x00 0x00010000>, /* OCSRAM */ + <0x01 0x00000000 0x01 0x00000000 0x00 0x00310000>, /* A53 PERIPHBASE */ + <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS0 DAT3 */ + + /* MCU Domain Range */ + <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>, + + /* Wakeup Domain Range */ + <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, + <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>; + + cbass_mcu: bus@4000000 { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>; /* Peripheral window */ + }; + + cbass_wakeup: bus@2b000000 { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, /* Peripheral Window */ + <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>; + }; + }; +}; + +/* Now include the peripherals for each bus segments */ +#include "k3-am62-main.dtsi" +#include "k3-am62-mcu.dtsi" +#include "k3-am62-wakeup.dtsi" diff --git a/arch/arm/dts/k3-am625.dtsi b/arch/arm/dts/k3-am625.dtsi new file mode 100644 index 0000000000..887f31c23f --- /dev/null +++ b/arch/arm/dts/k3-am625.dtsi @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for AM625 SoC family in Quad core configuration + * + * TRM: https://www.ti.com/lit/pdf/spruiv7 + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-am62.dtsi" + +/ { + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu-map { + cluster0: cluster0 { + core0 { + cpu = <&cpu0>; + }; + + core1 { + cpu = <&cpu1>; + }; + + core2 { + cpu = <&cpu2>; + }; + + core3 { + cpu = <&cpu3>; + }; + }; + }; + + cpu0: cpu@0 { + compatible = "arm,cortex-a53"; + reg = <0x000>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0x8000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_0>; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a53"; + reg = <0x001>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0x8000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_0>; + }; + + cpu2: cpu@2 { + compatible = "arm,cortex-a53"; + reg = <0x002>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0x8000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_0>; + }; + + cpu3: cpu@3 { + compatible = "arm,cortex-a53"; + reg = <0x003>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0x8000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_0>; + }; + }; + + L2_0: l2-cache0 { + compatible = "cache"; + cache-level = <2>; + cache-size = <0x40000>; + cache-line-size = <64>; + cache-sets = <512>; + }; +};
Add basic support for AM62 SK. This has 2GB DDR. Note that stack for R5 SPL is in OCRAM @ 0x7000ffff so that is away from BSS and does not step on BSS section
Add only the bare minimum required to support UART and SD.
Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- arch/arm/mach-k3/Kconfig | 1 + board/ti/am62x/Kconfig | 59 ++++++++++++++++++++++++++++++++++++++++ board/ti/am62x/Makefile | 8 ++++++ board/ti/am62x/evm.c | 39 ++++++++++++++++++++++++++ 4 files changed, 107 insertions(+) create mode 100644 board/ti/am62x/Kconfig create mode 100644 board/ti/am62x/Makefile create mode 100644 board/ti/am62x/evm.c
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index 0dc4f44fdd..57f693e9a1 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -178,6 +178,7 @@ config K3_DM_FW
source "board/ti/am65x/Kconfig" source "board/ti/am64x/Kconfig" +source "board/ti/am62x/Kconfig" source "board/ti/j721e/Kconfig" source "board/siemens/iot2050/Kconfig" source "board/ti/j721s2/Kconfig" diff --git a/board/ti/am62x/Kconfig b/board/ti/am62x/Kconfig new file mode 100644 index 0000000000..87fed44df1 --- /dev/null +++ b/board/ti/am62x/Kconfig @@ -0,0 +1,59 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ +# Suman Anna s-anna@ti.com + +choice + prompt "TI K3 AM62x based boards" + optional + +config TARGET_AM625_A53_EVM + bool "TI K3 based AM625 EVM running on A53" + select ARM64 + select SOC_K3_AM625 + +config TARGET_AM625_R5_EVM + bool "TI K3 based AM625 EVM running on R5" + select CPU_V7R + select SYS_THUMB_BUILD + select K3_LOAD_SYSFW + select SOC_K3_AM625 + select RAM + select SPL_RAM + select K3_DDRSS + imply SYS_K3_SPL_ATF + +endchoice + +if TARGET_AM625_A53_EVM + +config SYS_BOARD + default "am62x" + +config SYS_VENDOR + default "ti" + +config SYS_CONFIG_NAME + default "am62x_evm" + +source "board/ti/common/Kconfig" + +endif + +if TARGET_AM625_R5_EVM + +config SYS_BOARD + default "am62x" + +config SYS_VENDOR + default "ti" + +config SYS_CONFIG_NAME + default "am62x_evm" + +config SPL_LDSCRIPT + default "arch/arm/mach-omap2/u-boot-spl.lds" + +source "board/ti/common/Kconfig" + +endif diff --git a/board/ti/am62x/Makefile b/board/ti/am62x/Makefile new file mode 100644 index 0000000000..f4c35edffa --- /dev/null +++ b/board/ti/am62x/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ +# Suman Anna s-anna@ti.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += evm.o diff --git a/board/ti/am62x/evm.c b/board/ti/am62x/evm.c new file mode 100644 index 0000000000..4dd5e64299 --- /dev/null +++ b/board/ti/am62x/evm.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Board specific initialization for AM62x platforms + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + * Suman Anna s-anna@ti.com + * + */ + +#include <asm/io.h> +#include <spl.h> +#include <fdt_support.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <env.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->ram_size = 0x80000000; + + return 0; +} + +int dram_init_banksize(void) +{ + /* Bank 0 declares the memory available in the DDR low region */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = 0x80000000; + gd->ram_size = 0x80000000; + + return 0; +}
AM62 StarterKit (SK) board is a low cost, small form factor board designed for TI’s AM625 SoC. It supports the following interfaces: * 2 GB DDR4 RAM * x2 Gigabit Ethernet interfaces capable of working in Switch and MAC mode * x1 HDMI Port with audio + x1 OLDI/LVDS Display interface for Dual Display * x1 Headphone Jack * x1 USB2.0 Hub with two Type A host and x1 USB Type-C DRP Port * x1 UHS-1 capable µSD card slot * 2.4/5 GHz WLAN + Bluetooth 4.2 through WL1837 * 512 Mbit OSPI flash * x4 UART through UART-USB bridge * XDS110 for onboard JTAG debug using USB * Temperature sensors, user push buttons and LEDs * 40-pin User Expansion Connector * 24-pin header for peripherals in MCU island (I2C, UART, SPI, IO) * 20-pin header for Programmable Realtime Unit (PRU) IO pins * 15-pin CSI header
Add basic support for AM62-SK.
To keep the changes to minimum. Only UART And SD are supported at the moment. This should serve as good example for adding new board support based on AM62x SoC
Schematics: https://www.ti.com/lit/zip/sprr448
Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Dave Gerlach d-gerlach@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- arch/arm/dts/Makefile | 3 + arch/arm/dts/k3-am625-r5-sk.dts | 140 ++ arch/arm/dts/k3-am625-sk-u-boot.dtsi | 100 + arch/arm/dts/k3-am625-sk.dts | 150 ++ arch/arm/dts/k3-am62x-sk-ddr4-1600MTs.dtsi | 2189 ++++++++++++++++++++ 5 files changed, 2582 insertions(+) create mode 100644 arch/arm/dts/k3-am625-r5-sk.dts create mode 100644 arch/arm/dts/k3-am625-sk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-sk.dts create mode 100644 arch/arm/dts/k3-am62x-sk-ddr4-1600MTs.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3ca980aae0..d1df5ae196 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1177,6 +1177,9 @@ dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \ k3-am642-sk.dtb \ k3-am642-r5-sk.dtb
+dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \ + k3-am625-r5-sk.dtb + dtb-$(CONFIG_ARCH_MEDIATEK) += \ mt7622-rfb.dtb \ mt7623a-unielec-u7623-02-emmc.dtb \ diff --git a/arch/arm/dts/k3-am625-r5-sk.dts b/arch/arm/dts/k3-am625-r5-sk.dts new file mode 100644 index 0000000000..2691af40a1 --- /dev/null +++ b/arch/arm/dts/k3-am625-r5-sk.dts @@ -0,0 +1,140 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * AM625 SK dts file for R5 SPL + * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-am625-sk.dts" +#include "k3-am62x-sk-ddr4-1600MTs.dtsi" +#include "k3-am62-ddr.dtsi" + +#include "k3-am625-sk-u-boot.dtsi" + +/ { + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a53_0; + serial0 = &wkup_uart0; + serial3 = &main_uart1; + }; + + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &timer1; + }; + + memory@80000000 { + device_type = "memory"; + /* 2G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>; + + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ + alignment = <0x1000>; + no-map; + }; + }; + + a53_0: a53@0 { + compatible = "ti,am654-rproc"; + reg = <0x00 0x00a90000 0x00 0x10>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 135 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 135 0>; + clocks = <&k3_clks 61 0>; + assigned-clocks = <&k3_clks 61 0>, <&k3_clks 135 0>; + assigned-clock-parents = <&k3_clks 61 2>; + assigned-clock-rates = <200000000>, <1200000000>; + ti,sci = <&dmsc>; + ti,sci-proc-id = <32>; + ti,sci-host-id = <10>; + u-boot,dm-spl; + }; + + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + ti,host-id = <36>; + ti,secure-host; + mbox-names = "rx", "tx"; + mboxes= <&secure_proxy_main 22>, + <&secure_proxy_main 23>; + u-boot,dm-spl; + }; +}; + +&dmsc { + mboxes= <&secure_proxy_main 0>, + <&secure_proxy_main 1>, + <&secure_proxy_main 0>; + mbox-names = "rx", "tx", "notify"; + ti,host-id = <35>; + ti,secure-host; +}; + +&cbass_main { + sa3_secproxy: secproxy@44880000 { + u-boot,dm-spl; + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "rt", "scfg", "target_data"; + reg = <0x00 0x44880000 0x00 0x20000>, + <0x0 0x44860000 0x0 0x20000>, + <0x0 0x43600000 0x0 0x10000>; + }; + + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&secure_proxy_main 1>, <&secure_proxy_main 0>, <&sa3_secproxy 0>; + mbox-names = "tx", "rx", "boot_notify"; + u-boot,dm-spl; + }; +}; + +&mcu_pmx0 { + u-boot,dm-spl; + wkup_uart0_pins_default: wkup-uart0-pins-default { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6) WKUP_UART0_CTSn */ + AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4) WKUP_UART0_RTSn */ + AM62X_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (B4) WKUP_UART0_RXD */ + AM62X_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (C5) WKUP_UART0_TXD */ + >; + u-boot,dm-spl; + }; +}; + +&main_pmx0 { + u-boot,dm-spl; + main_uart1_pins_default: main-uart1-pins-default { + pinctrl-single,pins = < + AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19) MCASP0_AXR3.UART1_CTSn */ + AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19) MCASP0_AXR2.UART1_RTSn */ + AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19) MCASP0_AFSR.UART1_RXD */ + AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */ + >; + u-boot,dm-spl; + }; +}; + +/* WKUP UART0 is used for DM firmware logs */ +&wkup_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; + status = "okay"; + u-boot,dm-spl; +}; + +/* Main UART1 is used for TIFS firmware logs */ +&main_uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart1_pins_default>; + status = "okay"; + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi new file mode 100644 index 0000000000..e1971ecdfe --- /dev/null +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Common AM625 SK dts file for SPLs + * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &timer1; + }; + + aliases { + mmc1 = &sdhci1; + }; +}; + +&cbass_main{ + u-boot,dm-spl; + + timer1: timer@2400000 { + compatible = "ti,omap5430-timer"; + reg = <0x00 0x2400000 0x00 0x80>; + ti,timer-alwon; + clock-frequency = <25000000>; + u-boot,dm-spl; + }; +}; + +&dmss { + u-boot,dm-spl; +}; + +&secure_proxy_main { + u-boot,dm-spl; +}; + +&dmsc { + u-boot,dm-spl; +}; + +&k3_pds { + u-boot,dm-spl; +}; + +&k3_clks { + u-boot,dm-spl; +}; + +&k3_reset { + u-boot,dm-spl; +}; + +&wkup_conf { + u-boot,dm-spl; +}; + +&chipid { + u-boot,dm-spl; +}; + +&main_pmx0 { + u-boot,dm-spl; +}; + +&main_uart0 { + u-boot,dm-spl; +}; + +&main_uart0_pins_default { + u-boot,dm-spl; +}; + +&main_uart1 { + u-boot,dm-spl; +}; + +&cbass_mcu { + u-boot,dm-spl; +}; + +&cbass_wakeup { + u-boot,dm-spl; +}; + +&mcu_pmx0 { + u-boot,dm-spl; +}; + +&wkup_uart0 { + u-boot,dm-spl; +}; + +&sdhci1 { + u-boot,dm-spl; +}; + +&main_mmc1_pins_default { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts new file mode 100644 index 0000000000..76b06ea239 --- /dev/null +++ b/arch/arm/dts/k3-am625-sk.dts @@ -0,0 +1,150 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * AM625 SK: https://www.ti.com/lit/zip/sprr448 + * + * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; + +#include <dt-bindings/leds/common.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/net/ti-dp83867.h> +#include "k3-am625.dtsi" + +/ { + compatible = "ti,am625-sk", "ti,am625"; + model = "Texas Instruments AM625 SK"; + + aliases { + serial2 = &main_uart0; + mmc1 = &sdhci1; + }; + + chosen { + stdout-path = "serial2:115200n8"; + bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; + }; + + memory@80000000 { + device_type = "memory"; + /* 2G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>; + + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_tfa_ddr: tfa@9e780000 { + reg = <0x00 0x9e780000 0x00 0x80000>; + alignment = <0x1000>; + no-map; + }; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ + alignment = <0x1000>; + no-map; + }; + + wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { + compatible = "shared-dma-pool"; + reg = <0x00 0x9db00000 0x00 0xc00000>; + no-map; + }; + }; +}; + +&main_pmx0 { + main_uart0_pins_default: main-uart0-pins-default { + pinctrl-single,pins = < + AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */ + AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ + >; + }; + + main_mmc1_pins_default: main-mmc1-pins-default { + pinctrl-single,pins = < + AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ + AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ + AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ + AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ + AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ + AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ + AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17) MMC1_SDCD */ + >; + }; +}; + +&wkup_uart0 { + /* WKUP UART0 is used by DM firmware */ + status = "reserved"; +}; + +&mcu_uart0 { + status = "disabled"; +}; + +&main_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; +}; + +&main_uart1 { + /* Main UART1 is used by TIFS firmware */ + status = "reserved"; +}; + +&main_uart2 { + status = "disabled"; +}; + +&main_uart3 { + status = "disabled"; +}; + +&main_uart4 { + status = "disabled"; +}; + +&main_uart5 { + status = "disabled"; +}; + +&main_uart6 { + status = "disabled"; +}; + +&mcu_i2c0 { + status = "disabled"; +}; + +&wkup_i2c0 { + status = "disabled"; +}; + +&main_i2c0 { + status = "disabled"; +}; + +&main_i2c1 { + status = "disabled"; +}; + +&main_i2c2 { + status = "disabled"; +}; + +&main_i2c3 { + status = "disabled"; +}; + +&sdhci1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc1_pins_default>; + ti,driver-strength-ohm = <50>; + disable-wp; +}; diff --git a/arch/arm/dts/k3-am62x-sk-ddr4-1600MTs.dtsi b/arch/arm/dts/k3-am62x-sk-ddr4-1600MTs.dtsi new file mode 100644 index 0000000000..d92e3ce048 --- /dev/null +++ b/arch/arm/dts/k3-am62x-sk-ddr4-1600MTs.dtsi @@ -0,0 +1,2189 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * This file was generated with the + * AM62x SysConfig DDR Subsystem Register Configuration Tool v0.08.60 + * Wed Mar 16 2022 17:41:20 GMT-0500 (Central Daylight Time) + * DDR Type: DDR4 + * Frequency = 800MHz (1600MTs) + * Density: 16Gb + * Number of Ranks: 1 + */ + +#define DDRSS_PLL_FHS_CNT 6 +#define DDRSS_PLL_FREQUENCY_1 400000000 +#define DDRSS_PLL_FREQUENCY_2 400000000 + +#define DDRSS_CTL_0_DATA 0x00000A00 +#define DDRSS_CTL_1_DATA 0x00000000 +#define DDRSS_CTL_2_DATA 0x00000000 +#define DDRSS_CTL_3_DATA 0x00000000 +#define DDRSS_CTL_4_DATA 0x00000000 +#define DDRSS_CTL_5_DATA 0x00000000 +#define DDRSS_CTL_6_DATA 0x00000000 +#define DDRSS_CTL_7_DATA 0x000890B8 +#define DDRSS_CTL_8_DATA 0x00000000 +#define DDRSS_CTL_9_DATA 0x00000000 +#define DDRSS_CTL_10_DATA 0x00000000 +#define DDRSS_CTL_11_DATA 0x000890B8 +#define DDRSS_CTL_12_DATA 0x00000000 +#define DDRSS_CTL_13_DATA 0x00000000 +#define DDRSS_CTL_14_DATA 0x00000000 +#define DDRSS_CTL_15_DATA 0x000890B8 +#define DDRSS_CTL_16_DATA 0x00000000 +#define DDRSS_CTL_17_DATA 0x00000000 +#define DDRSS_CTL_18_DATA 0x00000000 +#define DDRSS_CTL_19_DATA 0x01010100 +#define DDRSS_CTL_20_DATA 0x01000100 +#define DDRSS_CTL_21_DATA 0x01000110 +#define DDRSS_CTL_22_DATA 0x02010002 +#define DDRSS_CTL_23_DATA 0x00027100 +#define DDRSS_CTL_24_DATA 0x00061A80 +#define DDRSS_CTL_25_DATA 0x02550255 +#define DDRSS_CTL_26_DATA 0x00000255 +#define DDRSS_CTL_27_DATA 0x00000000 +#define DDRSS_CTL_28_DATA 0x00000000 +#define DDRSS_CTL_29_DATA 0x00000000 +#define DDRSS_CTL_30_DATA 0x00000000 +#define DDRSS_CTL_31_DATA 0x00000000 +#define DDRSS_CTL_32_DATA 0x00000000 +#define DDRSS_CTL_33_DATA 0x00000000 +#define DDRSS_CTL_34_DATA 0x00000000 +#define DDRSS_CTL_35_DATA 0x00000000 +#define DDRSS_CTL_36_DATA 0x00000000 +#define DDRSS_CTL_37_DATA 0x00000000 +#define DDRSS_CTL_38_DATA 0x0400091C +#define DDRSS_CTL_39_DATA 0x1C1C1C1C +#define DDRSS_CTL_40_DATA 0x0400091C +#define DDRSS_CTL_41_DATA 0x1C1C1C1C +#define DDRSS_CTL_42_DATA 0x0400091C +#define DDRSS_CTL_43_DATA 0x1C1C1C1C +#define DDRSS_CTL_44_DATA 0x05050404 +#define DDRSS_CTL_45_DATA 0x00002706 +#define DDRSS_CTL_46_DATA 0x0602001D +#define DDRSS_CTL_47_DATA 0x05001D0B +#define DDRSS_CTL_48_DATA 0x00270605 +#define DDRSS_CTL_49_DATA 0x0602001D +#define DDRSS_CTL_50_DATA 0x05001D0B +#define DDRSS_CTL_51_DATA 0x00270605 +#define DDRSS_CTL_52_DATA 0x0602001D +#define DDRSS_CTL_53_DATA 0x07001D0B +#define DDRSS_CTL_54_DATA 0x00180807 +#define DDRSS_CTL_55_DATA 0x0400DB60 +#define DDRSS_CTL_56_DATA 0x07070009 +#define DDRSS_CTL_57_DATA 0x00001808 +#define DDRSS_CTL_58_DATA 0x0400DB60 +#define DDRSS_CTL_59_DATA 0x07070009 +#define DDRSS_CTL_60_DATA 0x00001808 +#define DDRSS_CTL_61_DATA 0x0400DB60 +#define DDRSS_CTL_62_DATA 0x03000009 +#define DDRSS_CTL_63_DATA 0x0D0C0002 +#define DDRSS_CTL_64_DATA 0x0D0C0D0C +#define DDRSS_CTL_65_DATA 0x01010000 +#define DDRSS_CTL_66_DATA 0x03191919 +#define DDRSS_CTL_67_DATA 0x0B0B0B0B +#define DDRSS_CTL_68_DATA 0x00000B0B +#define DDRSS_CTL_69_DATA 0x00000101 +#define DDRSS_CTL_70_DATA 0x00000000 +#define DDRSS_CTL_71_DATA 0x01000000 +#define DDRSS_CTL_72_DATA 0x01180803 +#define DDRSS_CTL_73_DATA 0x00001860 +#define DDRSS_CTL_74_DATA 0x00000118 +#define DDRSS_CTL_75_DATA 0x00001860 +#define DDRSS_CTL_76_DATA 0x00000118 +#define DDRSS_CTL_77_DATA 0x00001860 +#define DDRSS_CTL_78_DATA 0x00000005 +#define DDRSS_CTL_79_DATA 0x00000000 +#define DDRSS_CTL_80_DATA 0x00000000 +#define DDRSS_CTL_81_DATA 0x00000000 +#define DDRSS_CTL_82_DATA 0x00000000 +#define DDRSS_CTL_83_DATA 0x00000000 +#define DDRSS_CTL_84_DATA 0x00000000 +#define DDRSS_CTL_85_DATA 0x00000000 +#define DDRSS_CTL_86_DATA 0x00000000 +#define DDRSS_CTL_87_DATA 0x00090009 +#define DDRSS_CTL_88_DATA 0x00000009 +#define DDRSS_CTL_89_DATA 0x00000000 +#define DDRSS_CTL_90_DATA 0x00000000 +#define DDRSS_CTL_91_DATA 0x00000000 +#define DDRSS_CTL_92_DATA 0x00000000 +#define DDRSS_CTL_93_DATA 0x00000000 +#define DDRSS_CTL_94_DATA 0x00010001 +#define DDRSS_CTL_95_DATA 0x00025501 +#define DDRSS_CTL_96_DATA 0x02550120 +#define DDRSS_CTL_97_DATA 0x02550120 +#define DDRSS_CTL_98_DATA 0x01200120 +#define DDRSS_CTL_99_DATA 0x01200120 +#define DDRSS_CTL_100_DATA 0x00000000 +#define DDRSS_CTL_101_DATA 0x00000000 +#define DDRSS_CTL_102_DATA 0x00000000 +#define DDRSS_CTL_103_DATA 0x00000000 +#define DDRSS_CTL_104_DATA 0x00000000 +#define DDRSS_CTL_105_DATA 0x00000000 +#define DDRSS_CTL_106_DATA 0x03010000 +#define DDRSS_CTL_107_DATA 0x00010000 +#define DDRSS_CTL_108_DATA 0x00000000 +#define DDRSS_CTL_109_DATA 0x01000000 +#define DDRSS_CTL_110_DATA 0x80104002 +#define DDRSS_CTL_111_DATA 0x00040003 +#define DDRSS_CTL_112_DATA 0x00040005 +#define DDRSS_CTL_113_DATA 0x00030000 +#define DDRSS_CTL_114_DATA 0x00050004 +#define DDRSS_CTL_115_DATA 0x00000004 +#define DDRSS_CTL_116_DATA 0x00040003 +#define DDRSS_CTL_117_DATA 0x00040005 +#define DDRSS_CTL_118_DATA 0x00000000 +#define DDRSS_CTL_119_DATA 0x00061800 +#define DDRSS_CTL_120_DATA 0x00061800 +#define DDRSS_CTL_121_DATA 0x00061800 +#define DDRSS_CTL_122_DATA 0x00061800 +#define DDRSS_CTL_123_DATA 0x00061800 +#define DDRSS_CTL_124_DATA 0x00000000 +#define DDRSS_CTL_125_DATA 0x0000AAA0 +#define DDRSS_CTL_126_DATA 0x00061800 +#define DDRSS_CTL_127_DATA 0x00061800 +#define DDRSS_CTL_128_DATA 0x00061800 +#define DDRSS_CTL_129_DATA 0x00061800 +#define DDRSS_CTL_130_DATA 0x00061800 +#define DDRSS_CTL_131_DATA 0x00000000 +#define DDRSS_CTL_132_DATA 0x0000AAA0 +#define DDRSS_CTL_133_DATA 0x00061800 +#define DDRSS_CTL_134_DATA 0x00061800 +#define DDRSS_CTL_135_DATA 0x00061800 +#define DDRSS_CTL_136_DATA 0x00061800 +#define DDRSS_CTL_137_DATA 0x00061800 +#define DDRSS_CTL_138_DATA 0x00000000 +#define DDRSS_CTL_139_DATA 0x0000AAA0 +#define DDRSS_CTL_140_DATA 0x00000000 +#define DDRSS_CTL_141_DATA 0x00000000 +#define DDRSS_CTL_142_DATA 0x00000000 +#define DDRSS_CTL_143_DATA 0x00000000 +#define DDRSS_CTL_144_DATA 0x00000000 +#define DDRSS_CTL_145_DATA 0x00000000 +#define DDRSS_CTL_146_DATA 0x00000000 +#define DDRSS_CTL_147_DATA 0x00000000 +#define DDRSS_CTL_148_DATA 0x00000000 +#define DDRSS_CTL_149_DATA 0x00000000 +#define DDRSS_CTL_150_DATA 0x00000000 +#define DDRSS_CTL_151_DATA 0x00000000 +#define DDRSS_CTL_152_DATA 0x00000000 +#define DDRSS_CTL_153_DATA 0x00000000 +#define DDRSS_CTL_154_DATA 0x00000000 +#define DDRSS_CTL_155_DATA 0x00000000 +#define DDRSS_CTL_156_DATA 0x080C0000 +#define DDRSS_CTL_157_DATA 0x080C080C +#define DDRSS_CTL_158_DATA 0x08000000 +#define DDRSS_CTL_159_DATA 0x00000808 +#define DDRSS_CTL_160_DATA 0x000E0000 +#define DDRSS_CTL_161_DATA 0x00080808 +#define DDRSS_CTL_162_DATA 0x0E000000 +#define DDRSS_CTL_163_DATA 0x08080800 +#define DDRSS_CTL_164_DATA 0x00000000 +#define DDRSS_CTL_165_DATA 0x0000080E +#define DDRSS_CTL_166_DATA 0x00040003 +#define DDRSS_CTL_167_DATA 0x00000007 +#define DDRSS_CTL_168_DATA 0x00000000 +#define DDRSS_CTL_169_DATA 0x00000000 +#define DDRSS_CTL_170_DATA 0x00000000 +#define DDRSS_CTL_171_DATA 0x00000000 +#define DDRSS_CTL_172_DATA 0x00000000 +#define DDRSS_CTL_173_DATA 0x00000000 +#define DDRSS_CTL_174_DATA 0x01000000 +#define DDRSS_CTL_175_DATA 0x00000000 +#define DDRSS_CTL_176_DATA 0x00001500 +#define DDRSS_CTL_177_DATA 0x0000100E +#define DDRSS_CTL_178_DATA 0x00000000 +#define DDRSS_CTL_179_DATA 0x00000000 +#define DDRSS_CTL_180_DATA 0x00000001 +#define DDRSS_CTL_181_DATA 0x00000002 +#define DDRSS_CTL_182_DATA 0x00000C00 +#define DDRSS_CTL_183_DATA 0x00001000 +#define DDRSS_CTL_184_DATA 0x00000C00 +#define DDRSS_CTL_185_DATA 0x00001000 +#define DDRSS_CTL_186_DATA 0x00000C00 +#define DDRSS_CTL_187_DATA 0x00001000 +#define DDRSS_CTL_188_DATA 0x00000000 +#define DDRSS_CTL_189_DATA 0x00000000 +#define DDRSS_CTL_190_DATA 0x00000000 +#define DDRSS_CTL_191_DATA 0x00000000 +#define DDRSS_CTL_192_DATA 0x00000000 +#define DDRSS_CTL_193_DATA 0x00000000 +#define DDRSS_CTL_194_DATA 0x00000000 +#define DDRSS_CTL_195_DATA 0x00000000 +#define DDRSS_CTL_196_DATA 0x00000000 +#define DDRSS_CTL_197_DATA 0x00000000 +#define DDRSS_CTL_198_DATA 0x00000000 +#define DDRSS_CTL_199_DATA 0x00000000 +#define DDRSS_CTL_200_DATA 0x00000000 +#define DDRSS_CTL_201_DATA 0x00000000 +#define DDRSS_CTL_202_DATA 0x00000000 +#define DDRSS_CTL_203_DATA 0x00000000 +#define DDRSS_CTL_204_DATA 0x00042400 +#define DDRSS_CTL_205_DATA 0x00000301 +#define DDRSS_CTL_206_DATA 0x00000000 +#define DDRSS_CTL_207_DATA 0x00000424 +#define DDRSS_CTL_208_DATA 0x00000301 +#define DDRSS_CTL_209_DATA 0x00000000 +#define DDRSS_CTL_210_DATA 0x00000424 +#define DDRSS_CTL_211_DATA 0x00000301 +#define DDRSS_CTL_212_DATA 0x00000000 +#define DDRSS_CTL_213_DATA 0x00000424 +#define DDRSS_CTL_214_DATA 0x00000301 +#define DDRSS_CTL_215_DATA 0x00000000 +#define DDRSS_CTL_216_DATA 0x00000424 +#define DDRSS_CTL_217_DATA 0x00000301 +#define DDRSS_CTL_218_DATA 0x00000000 +#define DDRSS_CTL_219_DATA 0x00000424 +#define DDRSS_CTL_220_DATA 0x00000301 +#define DDRSS_CTL_221_DATA 0x00000000 +#define DDRSS_CTL_222_DATA 0x00000000 +#define DDRSS_CTL_223_DATA 0x00000000 +#define DDRSS_CTL_224_DATA 0x00000000 +#define DDRSS_CTL_225_DATA 0x00000000 +#define DDRSS_CTL_226_DATA 0x00000000 +#define DDRSS_CTL_227_DATA 0x00000000 +#define DDRSS_CTL_228_DATA 0x00000000 +#define DDRSS_CTL_229_DATA 0x00000000 +#define DDRSS_CTL_230_DATA 0x00000000 +#define DDRSS_CTL_231_DATA 0x00000000 +#define DDRSS_CTL_232_DATA 0x00000000 +#define DDRSS_CTL_233_DATA 0x00000000 +#define DDRSS_CTL_234_DATA 0x00000000 +#define DDRSS_CTL_235_DATA 0x00000000 +#define DDRSS_CTL_236_DATA 0x00001401 +#define DDRSS_CTL_237_DATA 0x00001401 +#define DDRSS_CTL_238_DATA 0x00001401 +#define DDRSS_CTL_239_DATA 0x00001401 +#define DDRSS_CTL_240_DATA 0x00001401 +#define DDRSS_CTL_241_DATA 0x00001401 +#define DDRSS_CTL_242_DATA 0x00000493 +#define DDRSS_CTL_243_DATA 0x00000493 +#define DDRSS_CTL_244_DATA 0x00000493 +#define DDRSS_CTL_245_DATA 0x00000493 +#define DDRSS_CTL_246_DATA 0x00000493 +#define DDRSS_CTL_247_DATA 0x00000493 +#define DDRSS_CTL_248_DATA 0x00000000 +#define DDRSS_CTL_249_DATA 0x00000000 +#define DDRSS_CTL_250_DATA 0x00000000 +#define DDRSS_CTL_251_DATA 0x00000000 +#define DDRSS_CTL_252_DATA 0x00000000 +#define DDRSS_CTL_253_DATA 0x00000000 +#define DDRSS_CTL_254_DATA 0x00000000 +#define DDRSS_CTL_255_DATA 0x00000000 +#define DDRSS_CTL_256_DATA 0x00000000 +#define DDRSS_CTL_257_DATA 0x00000000 +#define DDRSS_CTL_258_DATA 0x00000000 +#define DDRSS_CTL_259_DATA 0x00000000 +#define DDRSS_CTL_260_DATA 0x00000000 +#define DDRSS_CTL_261_DATA 0x00000000 +#define DDRSS_CTL_262_DATA 0x00000000 +#define DDRSS_CTL_263_DATA 0x00000000 +#define DDRSS_CTL_264_DATA 0x00000000 +#define DDRSS_CTL_265_DATA 0x00000000 +#define DDRSS_CTL_266_DATA 0x00000000 +#define DDRSS_CTL_267_DATA 0x00000000 +#define DDRSS_CTL_268_DATA 0x00000000 +#define DDRSS_CTL_269_DATA 0x00000000 +#define DDRSS_CTL_270_DATA 0x00000000 +#define DDRSS_CTL_271_DATA 0x00000000 +#define DDRSS_CTL_272_DATA 0x00000000 +#define DDRSS_CTL_273_DATA 0x00000000 +#define DDRSS_CTL_274_DATA 0x00000000 +#define DDRSS_CTL_275_DATA 0x00000000 +#define DDRSS_CTL_276_DATA 0x00000000 +#define DDRSS_CTL_277_DATA 0x00010000 +#define DDRSS_CTL_278_DATA 0x00000000 +#define DDRSS_CTL_279_DATA 0x00000000 +#define DDRSS_CTL_280_DATA 0x00000000 +#define DDRSS_CTL_281_DATA 0x00000101 +#define DDRSS_CTL_282_DATA 0x00000000 +#define DDRSS_CTL_283_DATA 0x00000000 +#define DDRSS_CTL_284_DATA 0x00000000 +#define DDRSS_CTL_285_DATA 0x00000000 +#define DDRSS_CTL_286_DATA 0x00000000 +#define DDRSS_CTL_287_DATA 0x00000000 +#define DDRSS_CTL_288_DATA 0x00000000 +#define DDRSS_CTL_289_DATA 0x00000000 +#define DDRSS_CTL_290_DATA 0x0C181511 +#define DDRSS_CTL_291_DATA 0x00000304 +#define DDRSS_CTL_292_DATA 0x00000000 +#define DDRSS_CTL_293_DATA 0x00000000 +#define DDRSS_CTL_294_DATA 0x00000000 +#define DDRSS_CTL_295_DATA 0x00000000 +#define DDRSS_CTL_296_DATA 0x00000000 +#define DDRSS_CTL_297_DATA 0x00000000 +#define DDRSS_CTL_298_DATA 0x00000000 +#define DDRSS_CTL_299_DATA 0x00000000 +#define DDRSS_CTL_300_DATA 0x00000000 +#define DDRSS_CTL_301_DATA 0x00000000 +#define DDRSS_CTL_302_DATA 0x00000000 +#define DDRSS_CTL_303_DATA 0x00000000 +#define DDRSS_CTL_304_DATA 0x00000000 +#define DDRSS_CTL_305_DATA 0x00040000 +#define DDRSS_CTL_306_DATA 0x00800200 +#define DDRSS_CTL_307_DATA 0x00000000 +#define DDRSS_CTL_308_DATA 0x02000400 +#define DDRSS_CTL_309_DATA 0x00000080 +#define DDRSS_CTL_310_DATA 0x00040000 +#define DDRSS_CTL_311_DATA 0x00800200 +#define DDRSS_CTL_312_DATA 0x00000000 +#define DDRSS_CTL_313_DATA 0x00000000 +#define DDRSS_CTL_314_DATA 0x00000000 +#define DDRSS_CTL_315_DATA 0x00000100 +#define DDRSS_CTL_316_DATA 0x01010000 +#define DDRSS_CTL_317_DATA 0x00000000 +#define DDRSS_CTL_318_DATA 0x3FFF0000 +#define DDRSS_CTL_319_DATA 0x000FFF00 +#define DDRSS_CTL_320_DATA 0xFFFFFFFF +#define DDRSS_CTL_321_DATA 0x000FFF00 +#define DDRSS_CTL_322_DATA 0x0A000000 +#define DDRSS_CTL_323_DATA 0x0001FFFF +#define DDRSS_CTL_324_DATA 0x01010101 +#define DDRSS_CTL_325_DATA 0x01010101 +#define DDRSS_CTL_326_DATA 0x00000118 +#define DDRSS_CTL_327_DATA 0x00000C01 +#define DDRSS_CTL_328_DATA 0x00000000 +#define DDRSS_CTL_329_DATA 0x00000000 +#define DDRSS_CTL_330_DATA 0x00000000 +#define DDRSS_CTL_331_DATA 0x01000000 +#define DDRSS_CTL_332_DATA 0x00000100 +#define DDRSS_CTL_333_DATA 0x00010000 +#define DDRSS_CTL_334_DATA 0x00000000 +#define DDRSS_CTL_335_DATA 0x00000000 +#define DDRSS_CTL_336_DATA 0x00000000 +#define DDRSS_CTL_337_DATA 0x00000000 +#define DDRSS_CTL_338_DATA 0x00000000 +#define DDRSS_CTL_339_DATA 0x00000000 +#define DDRSS_CTL_340_DATA 0x00000000 +#define DDRSS_CTL_341_DATA 0x00000000 +#define DDRSS_CTL_342_DATA 0x00000000 +#define DDRSS_CTL_343_DATA 0x00000000 +#define DDRSS_CTL_344_DATA 0x00000000 +#define DDRSS_CTL_345_DATA 0x00000000 +#define DDRSS_CTL_346_DATA 0x00000000 +#define DDRSS_CTL_347_DATA 0x00000000 +#define DDRSS_CTL_348_DATA 0x00000000 +#define DDRSS_CTL_349_DATA 0x00000000 +#define DDRSS_CTL_350_DATA 0x00000000 +#define DDRSS_CTL_351_DATA 0x00000000 +#define DDRSS_CTL_352_DATA 0x00000000 +#define DDRSS_CTL_353_DATA 0x00000000 +#define DDRSS_CTL_354_DATA 0x00000000 +#define DDRSS_CTL_355_DATA 0x00000000 +#define DDRSS_CTL_356_DATA 0x00000000 +#define DDRSS_CTL_357_DATA 0x00000000 +#define DDRSS_CTL_358_DATA 0x00000000 +#define DDRSS_CTL_359_DATA 0x00000000 +#define DDRSS_CTL_360_DATA 0x00000000 +#define DDRSS_CTL_361_DATA 0x00000000 +#define DDRSS_CTL_362_DATA 0x00000000 +#define DDRSS_CTL_363_DATA 0x00000000 +#define DDRSS_CTL_364_DATA 0x00000000 +#define DDRSS_CTL_365_DATA 0x00000000 +#define DDRSS_CTL_366_DATA 0x00000000 +#define DDRSS_CTL_367_DATA 0x00000000 +#define DDRSS_CTL_368_DATA 0x00000000 +#define DDRSS_CTL_369_DATA 0x00000000 +#define DDRSS_CTL_370_DATA 0x0C000000 +#define DDRSS_CTL_371_DATA 0x060C0606 +#define DDRSS_CTL_372_DATA 0x06060C06 +#define DDRSS_CTL_373_DATA 0x00010101 +#define DDRSS_CTL_374_DATA 0x02000000 +#define DDRSS_CTL_375_DATA 0x05020101 +#define DDRSS_CTL_376_DATA 0x00000505 +#define DDRSS_CTL_377_DATA 0x02020200 +#define DDRSS_CTL_378_DATA 0x02020202 +#define DDRSS_CTL_379_DATA 0x02020202 +#define DDRSS_CTL_380_DATA 0x02020202 +#define DDRSS_CTL_381_DATA 0x00000000 +#define DDRSS_CTL_382_DATA 0x00000000 +#define DDRSS_CTL_383_DATA 0x04000100 +#define DDRSS_CTL_384_DATA 0x1E000004 +#define DDRSS_CTL_385_DATA 0x000030C0 +#define DDRSS_CTL_386_DATA 0x00000200 +#define DDRSS_CTL_387_DATA 0x00000200 +#define DDRSS_CTL_388_DATA 0x00000200 +#define DDRSS_CTL_389_DATA 0x00000200 +#define DDRSS_CTL_390_DATA 0x0000DB60 +#define DDRSS_CTL_391_DATA 0x0001E780 +#define DDRSS_CTL_392_DATA 0x0C0D0302 +#define DDRSS_CTL_393_DATA 0x001E090A +#define DDRSS_CTL_394_DATA 0x000030C0 +#define DDRSS_CTL_395_DATA 0x00000200 +#define DDRSS_CTL_396_DATA 0x00000200 +#define DDRSS_CTL_397_DATA 0x00000200 +#define DDRSS_CTL_398_DATA 0x00000200 +#define DDRSS_CTL_399_DATA 0x0000DB60 +#define DDRSS_CTL_400_DATA 0x0001E780 +#define DDRSS_CTL_401_DATA 0x0C0D0302 +#define DDRSS_CTL_402_DATA 0x001E090A +#define DDRSS_CTL_403_DATA 0x000030C0 +#define DDRSS_CTL_404_DATA 0x00000200 +#define DDRSS_CTL_405_DATA 0x00000200 +#define DDRSS_CTL_406_DATA 0x00000200 +#define DDRSS_CTL_407_DATA 0x00000200 +#define DDRSS_CTL_408_DATA 0x0000DB60 +#define DDRSS_CTL_409_DATA 0x0001E780 +#define DDRSS_CTL_410_DATA 0x0C0D0302 +#define DDRSS_CTL_411_DATA 0x0000090A +#define DDRSS_CTL_412_DATA 0x00000000 +#define DDRSS_CTL_413_DATA 0x0302000A +#define DDRSS_CTL_414_DATA 0x01000500 +#define DDRSS_CTL_415_DATA 0x01010001 +#define DDRSS_CTL_416_DATA 0x00010001 +#define DDRSS_CTL_417_DATA 0x01010001 +#define DDRSS_CTL_418_DATA 0x02010000 +#define DDRSS_CTL_419_DATA 0x00000200 +#define DDRSS_CTL_420_DATA 0x02000201 +#define DDRSS_CTL_421_DATA 0x00000000 +#define DDRSS_CTL_422_DATA 0x00202020 +#define DDRSS_PI_0_DATA 0x00000A00 +#define DDRSS_PI_1_DATA 0x00000000 +#define DDRSS_PI_2_DATA 0x00000000 +#define DDRSS_PI_3_DATA 0x01000000 +#define DDRSS_PI_4_DATA 0x00000001 +#define DDRSS_PI_5_DATA 0x00010064 +#define DDRSS_PI_6_DATA 0x00000000 +#define DDRSS_PI_7_DATA 0x00000000 +#define DDRSS_PI_8_DATA 0x00000000 +#define DDRSS_PI_9_DATA 0x00000000 +#define DDRSS_PI_10_DATA 0x00000000 +#define DDRSS_PI_11_DATA 0x00000000 +#define DDRSS_PI_12_DATA 0x00000000 +#define DDRSS_PI_13_DATA 0x00010001 +#define DDRSS_PI_14_DATA 0x00000000 +#define DDRSS_PI_15_DATA 0x00010001 +#define DDRSS_PI_16_DATA 0x00000005 +#define DDRSS_PI_17_DATA 0x00000000 +#define DDRSS_PI_18_DATA 0x00000000 +#define DDRSS_PI_19_DATA 0x00000000 +#define DDRSS_PI_20_DATA 0x00000000 +#define DDRSS_PI_21_DATA 0x00000000 +#define DDRSS_PI_22_DATA 0x00000000 +#define DDRSS_PI_23_DATA 0x00000000 +#define DDRSS_PI_24_DATA 0x280D0001 +#define DDRSS_PI_25_DATA 0x00000000 +#define DDRSS_PI_26_DATA 0x00010000 +#define DDRSS_PI_27_DATA 0x00003200 +#define DDRSS_PI_28_DATA 0x00000000 +#define DDRSS_PI_29_DATA 0x00000000 +#define DDRSS_PI_30_DATA 0x00060602 +#define DDRSS_PI_31_DATA 0x00000000 +#define DDRSS_PI_32_DATA 0x00000000 +#define DDRSS_PI_33_DATA 0x00000000 +#define DDRSS_PI_34_DATA 0x00000001 +#define DDRSS_PI_35_DATA 0x00000055 +#define DDRSS_PI_36_DATA 0x000000AA +#define DDRSS_PI_37_DATA 0x000000AD +#define DDRSS_PI_38_DATA 0x00000052 +#define DDRSS_PI_39_DATA 0x0000006A +#define DDRSS_PI_40_DATA 0x00000095 +#define DDRSS_PI_41_DATA 0x00000095 +#define DDRSS_PI_42_DATA 0x000000AD +#define DDRSS_PI_43_DATA 0x00000000 +#define DDRSS_PI_44_DATA 0x00000000 +#define DDRSS_PI_45_DATA 0x00010100 +#define DDRSS_PI_46_DATA 0x00000014 +#define DDRSS_PI_47_DATA 0x000007D0 +#define DDRSS_PI_48_DATA 0x00000300 +#define DDRSS_PI_49_DATA 0x00000000 +#define DDRSS_PI_50_DATA 0x00000000 +#define DDRSS_PI_51_DATA 0x01000000 +#define DDRSS_PI_52_DATA 0x00010101 +#define DDRSS_PI_53_DATA 0x01000000 +#define DDRSS_PI_54_DATA 0x00000000 +#define DDRSS_PI_55_DATA 0x00010000 +#define DDRSS_PI_56_DATA 0x00000000 +#define DDRSS_PI_57_DATA 0x00000000 +#define DDRSS_PI_58_DATA 0x00000000 +#define DDRSS_PI_59_DATA 0x00000000 +#define DDRSS_PI_60_DATA 0x00001400 +#define DDRSS_PI_61_DATA 0x00000000 +#define DDRSS_PI_62_DATA 0x01000000 +#define DDRSS_PI_63_DATA 0x00000404 +#define DDRSS_PI_64_DATA 0x00000001 +#define DDRSS_PI_65_DATA 0x0001010E +#define DDRSS_PI_66_DATA 0x02040100 +#define DDRSS_PI_67_DATA 0x00010000 +#define DDRSS_PI_68_DATA 0x00000034 +#define DDRSS_PI_69_DATA 0x00000000 +#define DDRSS_PI_70_DATA 0x00000000 +#define DDRSS_PI_71_DATA 0x00000000 +#define DDRSS_PI_72_DATA 0x00000000 +#define DDRSS_PI_73_DATA 0x00000000 +#define DDRSS_PI_74_DATA 0x00000000 +#define DDRSS_PI_75_DATA 0x00000005 +#define DDRSS_PI_76_DATA 0x01000000 +#define DDRSS_PI_77_DATA 0x04000100 +#define DDRSS_PI_78_DATA 0x00020000 +#define DDRSS_PI_79_DATA 0x00010002 +#define DDRSS_PI_80_DATA 0x00000001 +#define DDRSS_PI_81_DATA 0x00020001 +#define DDRSS_PI_82_DATA 0x00020002 +#define DDRSS_PI_83_DATA 0x00000000 +#define DDRSS_PI_84_DATA 0x00000000 +#define DDRSS_PI_85_DATA 0x00000000 +#define DDRSS_PI_86_DATA 0x00000000 +#define DDRSS_PI_87_DATA 0x00000000 +#define DDRSS_PI_88_DATA 0x00000000 +#define DDRSS_PI_89_DATA 0x00000000 +#define DDRSS_PI_90_DATA 0x00000000 +#define DDRSS_PI_91_DATA 0x00000300 +#define DDRSS_PI_92_DATA 0x0A090B0C +#define DDRSS_PI_93_DATA 0x04060708 +#define DDRSS_PI_94_DATA 0x01000005 +#define DDRSS_PI_95_DATA 0x00000800 +#define DDRSS_PI_96_DATA 0x00000000 +#define DDRSS_PI_97_DATA 0x00010008 +#define DDRSS_PI_98_DATA 0x00000000 +#define DDRSS_PI_99_DATA 0x0000AA00 +#define DDRSS_PI_100_DATA 0x00000000 +#define DDRSS_PI_101_DATA 0x00010000 +#define DDRSS_PI_102_DATA 0x00000000 +#define DDRSS_PI_103_DATA 0x00000000 +#define DDRSS_PI_104_DATA 0x00000000 +#define DDRSS_PI_105_DATA 0x00000000 +#define DDRSS_PI_106_DATA 0x00000000 +#define DDRSS_PI_107_DATA 0x00000000 +#define DDRSS_PI_108_DATA 0x00000000 +#define DDRSS_PI_109_DATA 0x00000000 +#define DDRSS_PI_110_DATA 0x00000000 +#define DDRSS_PI_111_DATA 0x00000000 +#define DDRSS_PI_112_DATA 0x00000000 +#define DDRSS_PI_113_DATA 0x00000000 +#define DDRSS_PI_114_DATA 0x00000000 +#define DDRSS_PI_115_DATA 0x00000000 +#define DDRSS_PI_116_DATA 0x00000000 +#define DDRSS_PI_117_DATA 0x00000000 +#define DDRSS_PI_118_DATA 0x00000000 +#define DDRSS_PI_119_DATA 0x00000000 +#define DDRSS_PI_120_DATA 0x00000000 +#define DDRSS_PI_121_DATA 0x00000000 +#define DDRSS_PI_122_DATA 0x00000000 +#define DDRSS_PI_123_DATA 0x00000000 +#define DDRSS_PI_124_DATA 0x00000008 +#define DDRSS_PI_125_DATA 0x00000000 +#define DDRSS_PI_126_DATA 0x00000000 +#define DDRSS_PI_127_DATA 0x00000000 +#define DDRSS_PI_128_DATA 0x00000000 +#define DDRSS_PI_129_DATA 0x00000000 +#define DDRSS_PI_130_DATA 0x00000000 +#define DDRSS_PI_131_DATA 0x00000000 +#define DDRSS_PI_132_DATA 0x00000000 +#define DDRSS_PI_133_DATA 0x00010100 +#define DDRSS_PI_134_DATA 0x00000000 +#define DDRSS_PI_135_DATA 0x00000000 +#define DDRSS_PI_136_DATA 0x00027100 +#define DDRSS_PI_137_DATA 0x00061A80 +#define DDRSS_PI_138_DATA 0x00000100 +#define DDRSS_PI_139_DATA 0x00000000 +#define DDRSS_PI_140_DATA 0x00000000 +#define DDRSS_PI_141_DATA 0x00000000 +#define DDRSS_PI_142_DATA 0x00000000 +#define DDRSS_PI_143_DATA 0x00000000 +#define DDRSS_PI_144_DATA 0x01000000 +#define DDRSS_PI_145_DATA 0x00010003 +#define DDRSS_PI_146_DATA 0x02000101 +#define DDRSS_PI_147_DATA 0x01030001 +#define DDRSS_PI_148_DATA 0x00010400 +#define DDRSS_PI_149_DATA 0x06000105 +#define DDRSS_PI_150_DATA 0x01070001 +#define DDRSS_PI_151_DATA 0x00000000 +#define DDRSS_PI_152_DATA 0x00000000 +#define DDRSS_PI_153_DATA 0x00000000 +#define DDRSS_PI_154_DATA 0x00010000 +#define DDRSS_PI_155_DATA 0x00000000 +#define DDRSS_PI_156_DATA 0x00000000 +#define DDRSS_PI_157_DATA 0x00000000 +#define DDRSS_PI_158_DATA 0x00000000 +#define DDRSS_PI_159_DATA 0x00010000 +#define DDRSS_PI_160_DATA 0x00000004 +#define DDRSS_PI_161_DATA 0x00000000 +#define DDRSS_PI_162_DATA 0x00000000 +#define DDRSS_PI_163_DATA 0x00000000 +#define DDRSS_PI_164_DATA 0x00007800 +#define DDRSS_PI_165_DATA 0x00780078 +#define DDRSS_PI_166_DATA 0x00141414 +#define DDRSS_PI_167_DATA 0x0000003A +#define DDRSS_PI_168_DATA 0x0000003A +#define DDRSS_PI_169_DATA 0x0004003A +#define DDRSS_PI_170_DATA 0x04000400 +#define DDRSS_PI_171_DATA 0xC8040009 +#define DDRSS_PI_172_DATA 0x0400091C +#define DDRSS_PI_173_DATA 0x00091CC8 +#define DDRSS_PI_174_DATA 0x001CC804 +#define DDRSS_PI_175_DATA 0x00000118 +#define DDRSS_PI_176_DATA 0x00001860 +#define DDRSS_PI_177_DATA 0x00000118 +#define DDRSS_PI_178_DATA 0x00001860 +#define DDRSS_PI_179_DATA 0x00000118 +#define DDRSS_PI_180_DATA 0x04001860 +#define DDRSS_PI_181_DATA 0x01010404 +#define DDRSS_PI_182_DATA 0x00001901 +#define DDRSS_PI_183_DATA 0x00190019 +#define DDRSS_PI_184_DATA 0x010C010C +#define DDRSS_PI_185_DATA 0x0000010C +#define DDRSS_PI_186_DATA 0x00000000 +#define DDRSS_PI_187_DATA 0x05000000 +#define DDRSS_PI_188_DATA 0x01010505 +#define DDRSS_PI_189_DATA 0x01010101 +#define DDRSS_PI_190_DATA 0x00181818 +#define DDRSS_PI_191_DATA 0x00000000 +#define DDRSS_PI_192_DATA 0x00000000 +#define DDRSS_PI_193_DATA 0x0D000000 +#define DDRSS_PI_194_DATA 0x0A0A0D0D +#define DDRSS_PI_195_DATA 0x0303030A +#define DDRSS_PI_196_DATA 0x00000000 +#define DDRSS_PI_197_DATA 0x00000000 +#define DDRSS_PI_198_DATA 0x00000000 +#define DDRSS_PI_199_DATA 0x00000000 +#define DDRSS_PI_200_DATA 0x00000000 +#define DDRSS_PI_201_DATA 0x00000000 +#define DDRSS_PI_202_DATA 0x00000000 +#define DDRSS_PI_203_DATA 0x00000000 +#define DDRSS_PI_204_DATA 0x00000000 +#define DDRSS_PI_205_DATA 0x00000000 +#define DDRSS_PI_206_DATA 0x00000000 +#define DDRSS_PI_207_DATA 0x00000000 +#define DDRSS_PI_208_DATA 0x00000000 +#define DDRSS_PI_209_DATA 0x0D090000 +#define DDRSS_PI_210_DATA 0x0D09000D +#define DDRSS_PI_211_DATA 0x0D09000D +#define DDRSS_PI_212_DATA 0x0000000D +#define DDRSS_PI_213_DATA 0x00000000 +#define DDRSS_PI_214_DATA 0x00000000 +#define DDRSS_PI_215_DATA 0x00000000 +#define DDRSS_PI_216_DATA 0x00000000 +#define DDRSS_PI_217_DATA 0x16000000 +#define DDRSS_PI_218_DATA 0x001600C8 +#define DDRSS_PI_219_DATA 0x001600C8 +#define DDRSS_PI_220_DATA 0x010100C8 +#define DDRSS_PI_221_DATA 0x00001B01 +#define DDRSS_PI_222_DATA 0x1F0F0053 +#define DDRSS_PI_223_DATA 0x05000001 +#define DDRSS_PI_224_DATA 0x001B0A0D +#define DDRSS_PI_225_DATA 0x1F0F0053 +#define DDRSS_PI_226_DATA 0x05000001 +#define DDRSS_PI_227_DATA 0x001B0A0D +#define DDRSS_PI_228_DATA 0x1F0F0053 +#define DDRSS_PI_229_DATA 0x05000001 +#define DDRSS_PI_230_DATA 0x00010A0D +#define DDRSS_PI_231_DATA 0x0C0B0700 +#define DDRSS_PI_232_DATA 0x000D0605 +#define DDRSS_PI_233_DATA 0x0000C570 +#define DDRSS_PI_234_DATA 0x0000001D +#define DDRSS_PI_235_DATA 0x180A0800 +#define DDRSS_PI_236_DATA 0x0B071C1C +#define DDRSS_PI_237_DATA 0x0D06050C +#define DDRSS_PI_238_DATA 0x0000C570 +#define DDRSS_PI_239_DATA 0x0000001D +#define DDRSS_PI_240_DATA 0x180A0800 +#define DDRSS_PI_241_DATA 0x0B071C1C +#define DDRSS_PI_242_DATA 0x0D06050C +#define DDRSS_PI_243_DATA 0x0000C570 +#define DDRSS_PI_244_DATA 0x0000001D +#define DDRSS_PI_245_DATA 0x180A0800 +#define DDRSS_PI_246_DATA 0x00001C1C +#define DDRSS_PI_247_DATA 0x000030C0 +#define DDRSS_PI_248_DATA 0x0001E780 +#define DDRSS_PI_249_DATA 0x000030C0 +#define DDRSS_PI_250_DATA 0x0001E780 +#define DDRSS_PI_251_DATA 0x000030C0 +#define DDRSS_PI_252_DATA 0x0001E780 +#define DDRSS_PI_253_DATA 0x02550255 +#define DDRSS_PI_254_DATA 0x03030255 +#define DDRSS_PI_255_DATA 0x00025503 +#define DDRSS_PI_256_DATA 0x02550255 +#define DDRSS_PI_257_DATA 0x0C080C08 +#define DDRSS_PI_258_DATA 0x00000C08 +#define DDRSS_PI_259_DATA 0x000890B8 +#define DDRSS_PI_260_DATA 0x00000000 +#define DDRSS_PI_261_DATA 0x00000000 +#define DDRSS_PI_262_DATA 0x00000000 +#define DDRSS_PI_263_DATA 0x00000120 +#define DDRSS_PI_264_DATA 0x000890B8 +#define DDRSS_PI_265_DATA 0x00000000 +#define DDRSS_PI_266_DATA 0x00000000 +#define DDRSS_PI_267_DATA 0x00000000 +#define DDRSS_PI_268_DATA 0x00000120 +#define DDRSS_PI_269_DATA 0x000890B8 +#define DDRSS_PI_270_DATA 0x00000000 +#define DDRSS_PI_271_DATA 0x00000000 +#define DDRSS_PI_272_DATA 0x00000000 +#define DDRSS_PI_273_DATA 0x02000120 +#define DDRSS_PI_274_DATA 0x00000080 +#define DDRSS_PI_275_DATA 0x00020000 +#define DDRSS_PI_276_DATA 0x00000080 +#define DDRSS_PI_277_DATA 0x00020000 +#define DDRSS_PI_278_DATA 0x00000080 +#define DDRSS_PI_279_DATA 0x00000000 +#define DDRSS_PI_280_DATA 0x00000000 +#define DDRSS_PI_281_DATA 0x00040404 +#define DDRSS_PI_282_DATA 0x00000000 +#define DDRSS_PI_283_DATA 0x02010102 +#define DDRSS_PI_284_DATA 0x67676767 +#define DDRSS_PI_285_DATA 0x00000202 +#define DDRSS_PI_286_DATA 0x00000000 +#define DDRSS_PI_287_DATA 0x00000000 +#define DDRSS_PI_288_DATA 0x00000000 +#define DDRSS_PI_289_DATA 0x00000000 +#define DDRSS_PI_290_DATA 0x00000000 +#define DDRSS_PI_291_DATA 0x0D100F00 +#define DDRSS_PI_292_DATA 0x0003020E +#define DDRSS_PI_293_DATA 0x00000001 +#define DDRSS_PI_294_DATA 0x01000000 +#define DDRSS_PI_295_DATA 0x00020201 +#define DDRSS_PI_296_DATA 0x00000000 +#define DDRSS_PI_297_DATA 0x00000424 +#define DDRSS_PI_298_DATA 0x00000301 +#define DDRSS_PI_299_DATA 0x00000000 +#define DDRSS_PI_300_DATA 0x00000000 +#define DDRSS_PI_301_DATA 0x00000000 +#define DDRSS_PI_302_DATA 0x00001401 +#define DDRSS_PI_303_DATA 0x00000493 +#define DDRSS_PI_304_DATA 0x00000000 +#define DDRSS_PI_305_DATA 0x00000424 +#define DDRSS_PI_306_DATA 0x00000301 +#define DDRSS_PI_307_DATA 0x00000000 +#define DDRSS_PI_308_DATA 0x00000000 +#define DDRSS_PI_309_DATA 0x00000000 +#define DDRSS_PI_310_DATA 0x00001401 +#define DDRSS_PI_311_DATA 0x00000493 +#define DDRSS_PI_312_DATA 0x00000000 +#define DDRSS_PI_313_DATA 0x00000424 +#define DDRSS_PI_314_DATA 0x00000301 +#define DDRSS_PI_315_DATA 0x00000000 +#define DDRSS_PI_316_DATA 0x00000000 +#define DDRSS_PI_317_DATA 0x00000000 +#define DDRSS_PI_318_DATA 0x00001401 +#define DDRSS_PI_319_DATA 0x00000493 +#define DDRSS_PI_320_DATA 0x00000000 +#define DDRSS_PI_321_DATA 0x00000424 +#define DDRSS_PI_322_DATA 0x00000301 +#define DDRSS_PI_323_DATA 0x00000000 +#define DDRSS_PI_324_DATA 0x00000000 +#define DDRSS_PI_325_DATA 0x00000000 +#define DDRSS_PI_326_DATA 0x00001401 +#define DDRSS_PI_327_DATA 0x00000493 +#define DDRSS_PI_328_DATA 0x00000000 +#define DDRSS_PI_329_DATA 0x00000424 +#define DDRSS_PI_330_DATA 0x00000301 +#define DDRSS_PI_331_DATA 0x00000000 +#define DDRSS_PI_332_DATA 0x00000000 +#define DDRSS_PI_333_DATA 0x00000000 +#define DDRSS_PI_334_DATA 0x00001401 +#define DDRSS_PI_335_DATA 0x00000493 +#define DDRSS_PI_336_DATA 0x00000000 +#define DDRSS_PI_337_DATA 0x00000424 +#define DDRSS_PI_338_DATA 0x00000301 +#define DDRSS_PI_339_DATA 0x00000000 +#define DDRSS_PI_340_DATA 0x00000000 +#define DDRSS_PI_341_DATA 0x00000000 +#define DDRSS_PI_342_DATA 0x00001401 +#define DDRSS_PI_343_DATA 0x00000493 +#define DDRSS_PI_344_DATA 0x00000000 +#define DDRSS_PHY_0_DATA 0x04C00000 +#define DDRSS_PHY_1_DATA 0x00000000 +#define DDRSS_PHY_2_DATA 0x00000200 +#define DDRSS_PHY_3_DATA 0x00000000 +#define DDRSS_PHY_4_DATA 0x00000000 +#define DDRSS_PHY_5_DATA 0x00000000 +#define DDRSS_PHY_6_DATA 0x00000000 +#define DDRSS_PHY_7_DATA 0x00000000 +#define DDRSS_PHY_8_DATA 0x00000001 +#define DDRSS_PHY_9_DATA 0x00000000 +#define DDRSS_PHY_10_DATA 0x00000000 +#define DDRSS_PHY_11_DATA 0x010101FF +#define DDRSS_PHY_12_DATA 0x00010000 +#define DDRSS_PHY_13_DATA 0x00C00004 +#define DDRSS_PHY_14_DATA 0x00CC0008 +#define DDRSS_PHY_15_DATA 0x00660201 +#define DDRSS_PHY_16_DATA 0x00000000 +#define DDRSS_PHY_17_DATA 0x00000000 +#define DDRSS_PHY_18_DATA 0x00000000 +#define DDRSS_PHY_19_DATA 0x0000AAAA +#define DDRSS_PHY_20_DATA 0x00005555 +#define DDRSS_PHY_21_DATA 0x0000B5B5 +#define DDRSS_PHY_22_DATA 0x00004A4A +#define DDRSS_PHY_23_DATA 0x00005656 +#define DDRSS_PHY_24_DATA 0x0000A9A9 +#define DDRSS_PHY_25_DATA 0x0000B7B7 +#define DDRSS_PHY_26_DATA 0x00004848 +#define DDRSS_PHY_27_DATA 0x00000000 +#define DDRSS_PHY_28_DATA 0x00000000 +#define DDRSS_PHY_29_DATA 0x08000000 +#define DDRSS_PHY_30_DATA 0x0F000008 +#define DDRSS_PHY_31_DATA 0x00000F0F +#define DDRSS_PHY_32_DATA 0x00E4E400 +#define DDRSS_PHY_33_DATA 0x00070820 +#define DDRSS_PHY_34_DATA 0x000C0020 +#define DDRSS_PHY_35_DATA 0x00062000 +#define DDRSS_PHY_36_DATA 0x00000000 +#define DDRSS_PHY_37_DATA 0x55555555 +#define DDRSS_PHY_38_DATA 0xAAAAAAAA +#define DDRSS_PHY_39_DATA 0x55555555 +#define DDRSS_PHY_40_DATA 0xAAAAAAAA +#define DDRSS_PHY_41_DATA 0x00005555 +#define DDRSS_PHY_42_DATA 0x01000100 +#define DDRSS_PHY_43_DATA 0x00800180 +#define DDRSS_PHY_44_DATA 0x00000000 +#define DDRSS_PHY_45_DATA 0x00000000 +#define DDRSS_PHY_46_DATA 0x00000000 +#define DDRSS_PHY_47_DATA 0x00000000 +#define DDRSS_PHY_48_DATA 0x00000000 +#define DDRSS_PHY_49_DATA 0x00000000 +#define DDRSS_PHY_50_DATA 0x00000000 +#define DDRSS_PHY_51_DATA 0x00000000 +#define DDRSS_PHY_52_DATA 0x00000000 +#define DDRSS_PHY_53_DATA 0x00000000 +#define DDRSS_PHY_54_DATA 0x00000000 +#define DDRSS_PHY_55_DATA 0x00000000 +#define DDRSS_PHY_56_DATA 0x00000000 +#define DDRSS_PHY_57_DATA 0x00000000 +#define DDRSS_PHY_58_DATA 0x00000000 +#define DDRSS_PHY_59_DATA 0x00000000 +#define DDRSS_PHY_60_DATA 0x00000000 +#define DDRSS_PHY_61_DATA 0x00000000 +#define DDRSS_PHY_62_DATA 0x00000000 +#define DDRSS_PHY_63_DATA 0x00000000 +#define DDRSS_PHY_64_DATA 0x00000000 +#define DDRSS_PHY_65_DATA 0x00000004 +#define DDRSS_PHY_66_DATA 0x00000000 +#define DDRSS_PHY_67_DATA 0x00000000 +#define DDRSS_PHY_68_DATA 0x00000000 +#define DDRSS_PHY_69_DATA 0x00000000 +#define DDRSS_PHY_70_DATA 0x00000000 +#define DDRSS_PHY_71_DATA 0x00000000 +#define DDRSS_PHY_72_DATA 0x041F07FF +#define DDRSS_PHY_73_DATA 0x00000000 +#define DDRSS_PHY_74_DATA 0x01CCB001 +#define DDRSS_PHY_75_DATA 0x2000CCB0 +#define DDRSS_PHY_76_DATA 0x20000140 +#define DDRSS_PHY_77_DATA 0x07FF0200 +#define DDRSS_PHY_78_DATA 0x0000DD01 +#define DDRSS_PHY_79_DATA 0x10100303 +#define DDRSS_PHY_80_DATA 0x10101010 +#define DDRSS_PHY_81_DATA 0x10101010 +#define DDRSS_PHY_82_DATA 0x00021010 +#define DDRSS_PHY_83_DATA 0x00100010 +#define DDRSS_PHY_84_DATA 0x00100010 +#define DDRSS_PHY_85_DATA 0x00100010 +#define DDRSS_PHY_86_DATA 0x00100010 +#define DDRSS_PHY_87_DATA 0x02020010 +#define DDRSS_PHY_88_DATA 0x51515041 +#define DDRSS_PHY_89_DATA 0x31804000 +#define DDRSS_PHY_90_DATA 0x04BF0340 +#define DDRSS_PHY_91_DATA 0x01008080 +#define DDRSS_PHY_92_DATA 0x04050001 +#define DDRSS_PHY_93_DATA 0x00000504 +#define DDRSS_PHY_94_DATA 0x42100010 +#define DDRSS_PHY_95_DATA 0x010C053E +#define DDRSS_PHY_96_DATA 0x000F0C14 +#define DDRSS_PHY_97_DATA 0x01000140 +#define DDRSS_PHY_98_DATA 0x007A0120 +#define DDRSS_PHY_99_DATA 0x00000C00 +#define DDRSS_PHY_100_DATA 0x000001CC +#define DDRSS_PHY_101_DATA 0x20100200 +#define DDRSS_PHY_102_DATA 0x00000005 +#define DDRSS_PHY_103_DATA 0x76543210 +#define DDRSS_PHY_104_DATA 0x00000008 +#define DDRSS_PHY_105_DATA 0x02800280 +#define DDRSS_PHY_106_DATA 0x02800280 +#define DDRSS_PHY_107_DATA 0x02800280 +#define DDRSS_PHY_108_DATA 0x02800280 +#define DDRSS_PHY_109_DATA 0x00000280 +#define DDRSS_PHY_110_DATA 0x00008000 +#define DDRSS_PHY_111_DATA 0x00800080 +#define DDRSS_PHY_112_DATA 0x00800080 +#define DDRSS_PHY_113_DATA 0x00800080 +#define DDRSS_PHY_114_DATA 0x00800080 +#define DDRSS_PHY_115_DATA 0x00800080 +#define DDRSS_PHY_116_DATA 0x00800080 +#define DDRSS_PHY_117_DATA 0x00800080 +#define DDRSS_PHY_118_DATA 0x00800080 +#define DDRSS_PHY_119_DATA 0x01000080 +#define DDRSS_PHY_120_DATA 0x01A00000 +#define DDRSS_PHY_121_DATA 0x00000000 +#define DDRSS_PHY_122_DATA 0x00000000 +#define DDRSS_PHY_123_DATA 0x00080200 +#define DDRSS_PHY_124_DATA 0x00000000 +#define DDRSS_PHY_125_DATA 0x00000000 +#define DDRSS_PHY_126_DATA 0x00000000 +#define DDRSS_PHY_127_DATA 0x00000000 +#define DDRSS_PHY_128_DATA 0x00000000 +#define DDRSS_PHY_129_DATA 0x00000000 +#define DDRSS_PHY_130_DATA 0x00000000 +#define DDRSS_PHY_131_DATA 0x00000000 +#define DDRSS_PHY_132_DATA 0x00000000 +#define DDRSS_PHY_133_DATA 0x00000000 +#define DDRSS_PHY_134_DATA 0x00000000 +#define DDRSS_PHY_135_DATA 0x00000000 +#define DDRSS_PHY_136_DATA 0x00000000 +#define DDRSS_PHY_137_DATA 0x00000000 +#define DDRSS_PHY_138_DATA 0x00000000 +#define DDRSS_PHY_139_DATA 0x00000000 +#define DDRSS_PHY_140_DATA 0x00000000 +#define DDRSS_PHY_141_DATA 0x00000000 +#define DDRSS_PHY_142_DATA 0x00000000 +#define DDRSS_PHY_143_DATA 0x00000000 +#define DDRSS_PHY_144_DATA 0x00000000 +#define DDRSS_PHY_145_DATA 0x00000000 +#define DDRSS_PHY_146_DATA 0x00000000 +#define DDRSS_PHY_147_DATA 0x00000000 +#define DDRSS_PHY_148_DATA 0x00000000 +#define DDRSS_PHY_149_DATA 0x00000000 +#define DDRSS_PHY_150_DATA 0x00000000 +#define DDRSS_PHY_151_DATA 0x00000000 +#define DDRSS_PHY_152_DATA 0x00000000 +#define DDRSS_PHY_153_DATA 0x00000000 +#define DDRSS_PHY_154_DATA 0x00000000 +#define DDRSS_PHY_155_DATA 0x00000000 +#define DDRSS_PHY_156_DATA 0x00000000 +#define DDRSS_PHY_157_DATA 0x00000000 +#define DDRSS_PHY_158_DATA 0x00000000 +#define DDRSS_PHY_159_DATA 0x00000000 +#define DDRSS_PHY_160_DATA 0x00000000 +#define DDRSS_PHY_161_DATA 0x00000000 +#define DDRSS_PHY_162_DATA 0x00000000 +#define DDRSS_PHY_163_DATA 0x00000000 +#define DDRSS_PHY_164_DATA 0x00000000 +#define DDRSS_PHY_165_DATA 0x00000000 +#define DDRSS_PHY_166_DATA 0x00000000 +#define DDRSS_PHY_167_DATA 0x00000000 +#define DDRSS_PHY_168_DATA 0x00000000 +#define DDRSS_PHY_169_DATA 0x00000000 +#define DDRSS_PHY_170_DATA 0x00000000 +#define DDRSS_PHY_171_DATA 0x00000000 +#define DDRSS_PHY_172_DATA 0x00000000 +#define DDRSS_PHY_173_DATA 0x00000000 +#define DDRSS_PHY_174_DATA 0x00000000 +#define DDRSS_PHY_175_DATA 0x00000000 +#define DDRSS_PHY_176_DATA 0x00000000 +#define DDRSS_PHY_177_DATA 0x00000000 +#define DDRSS_PHY_178_DATA 0x00000000 +#define DDRSS_PHY_179_DATA 0x00000000 +#define DDRSS_PHY_180_DATA 0x00000000 +#define DDRSS_PHY_181_DATA 0x00000000 +#define DDRSS_PHY_182_DATA 0x00000000 +#define DDRSS_PHY_183_DATA 0x00000000 +#define DDRSS_PHY_184_DATA 0x00000000 +#define DDRSS_PHY_185_DATA 0x00000000 +#define DDRSS_PHY_186_DATA 0x00000000 +#define DDRSS_PHY_187_DATA 0x00000000 +#define DDRSS_PHY_188_DATA 0x00000000 +#define DDRSS_PHY_189_DATA 0x00000000 +#define DDRSS_PHY_190_DATA 0x00000000 +#define DDRSS_PHY_191_DATA 0x00000000 +#define DDRSS_PHY_192_DATA 0x00000000 +#define DDRSS_PHY_193_DATA 0x00000000 +#define DDRSS_PHY_194_DATA 0x00000000 +#define DDRSS_PHY_195_DATA 0x00000000 +#define DDRSS_PHY_196_DATA 0x00000000 +#define DDRSS_PHY_197_DATA 0x00000000 +#define DDRSS_PHY_198_DATA 0x00000000 +#define DDRSS_PHY_199_DATA 0x00000000 +#define DDRSS_PHY_200_DATA 0x00000000 +#define DDRSS_PHY_201_DATA 0x00000000 +#define DDRSS_PHY_202_DATA 0x00000000 +#define DDRSS_PHY_203_DATA 0x00000000 +#define DDRSS_PHY_204_DATA 0x00000000 +#define DDRSS_PHY_205_DATA 0x00000000 +#define DDRSS_PHY_206_DATA 0x00000000 +#define DDRSS_PHY_207_DATA 0x00000000 +#define DDRSS_PHY_208_DATA 0x00000000 +#define DDRSS_PHY_209_DATA 0x00000000 +#define DDRSS_PHY_210_DATA 0x00000000 +#define DDRSS_PHY_211_DATA 0x00000000 +#define DDRSS_PHY_212_DATA 0x00000000 +#define DDRSS_PHY_213_DATA 0x00000000 +#define DDRSS_PHY_214_DATA 0x00000000 +#define DDRSS_PHY_215_DATA 0x00000000 +#define DDRSS_PHY_216_DATA 0x00000000 +#define DDRSS_PHY_217_DATA 0x00000000 +#define DDRSS_PHY_218_DATA 0x00000000 +#define DDRSS_PHY_219_DATA 0x00000000 +#define DDRSS_PHY_220_DATA 0x00000000 +#define DDRSS_PHY_221_DATA 0x00000000 +#define DDRSS_PHY_222_DATA 0x00000000 +#define DDRSS_PHY_223_DATA 0x00000000 +#define DDRSS_PHY_224_DATA 0x00000000 +#define DDRSS_PHY_225_DATA 0x00000000 +#define DDRSS_PHY_226_DATA 0x00000000 +#define DDRSS_PHY_227_DATA 0x00000000 +#define DDRSS_PHY_228_DATA 0x00000000 +#define DDRSS_PHY_229_DATA 0x00000000 +#define DDRSS_PHY_230_DATA 0x00000000 +#define DDRSS_PHY_231_DATA 0x00000000 +#define DDRSS_PHY_232_DATA 0x00000000 +#define DDRSS_PHY_233_DATA 0x00000000 +#define DDRSS_PHY_234_DATA 0x00000000 +#define DDRSS_PHY_235_DATA 0x00000000 +#define DDRSS_PHY_236_DATA 0x00000000 +#define DDRSS_PHY_237_DATA 0x00000000 +#define DDRSS_PHY_238_DATA 0x00000000 +#define DDRSS_PHY_239_DATA 0x00000000 +#define DDRSS_PHY_240_DATA 0x00000000 +#define DDRSS_PHY_241_DATA 0x00000000 +#define DDRSS_PHY_242_DATA 0x00000000 +#define DDRSS_PHY_243_DATA 0x00000000 +#define DDRSS_PHY_244_DATA 0x00000000 +#define DDRSS_PHY_245_DATA 0x00000000 +#define DDRSS_PHY_246_DATA 0x00000000 +#define DDRSS_PHY_247_DATA 0x00000000 +#define DDRSS_PHY_248_DATA 0x00000000 +#define DDRSS_PHY_249_DATA 0x00000000 +#define DDRSS_PHY_250_DATA 0x00000000 +#define DDRSS_PHY_251_DATA 0x00000000 +#define DDRSS_PHY_252_DATA 0x00000000 +#define DDRSS_PHY_253_DATA 0x00000000 +#define DDRSS_PHY_254_DATA 0x00000000 +#define DDRSS_PHY_255_DATA 0x00000000 +#define DDRSS_PHY_256_DATA 0x04C00000 +#define DDRSS_PHY_257_DATA 0x00000000 +#define DDRSS_PHY_258_DATA 0x00000200 +#define DDRSS_PHY_259_DATA 0x00000000 +#define DDRSS_PHY_260_DATA 0x00000000 +#define DDRSS_PHY_261_DATA 0x00000000 +#define DDRSS_PHY_262_DATA 0x00000000 +#define DDRSS_PHY_263_DATA 0x00000000 +#define DDRSS_PHY_264_DATA 0x00000001 +#define DDRSS_PHY_265_DATA 0x00000000 +#define DDRSS_PHY_266_DATA 0x00000000 +#define DDRSS_PHY_267_DATA 0x010101FF +#define DDRSS_PHY_268_DATA 0x00010000 +#define DDRSS_PHY_269_DATA 0x00C00004 +#define DDRSS_PHY_270_DATA 0x00CC0008 +#define DDRSS_PHY_271_DATA 0x00660201 +#define DDRSS_PHY_272_DATA 0x00000000 +#define DDRSS_PHY_273_DATA 0x00000000 +#define DDRSS_PHY_274_DATA 0x00000000 +#define DDRSS_PHY_275_DATA 0x0000AAAA +#define DDRSS_PHY_276_DATA 0x00005555 +#define DDRSS_PHY_277_DATA 0x0000B5B5 +#define DDRSS_PHY_278_DATA 0x00004A4A +#define DDRSS_PHY_279_DATA 0x00005656 +#define DDRSS_PHY_280_DATA 0x0000A9A9 +#define DDRSS_PHY_281_DATA 0x0000B7B7 +#define DDRSS_PHY_282_DATA 0x00004848 +#define DDRSS_PHY_283_DATA 0x00000000 +#define DDRSS_PHY_284_DATA 0x00000000 +#define DDRSS_PHY_285_DATA 0x08000000 +#define DDRSS_PHY_286_DATA 0x0F000008 +#define DDRSS_PHY_287_DATA 0x00000F0F +#define DDRSS_PHY_288_DATA 0x00E4E400 +#define DDRSS_PHY_289_DATA 0x00070820 +#define DDRSS_PHY_290_DATA 0x000C0020 +#define DDRSS_PHY_291_DATA 0x00062000 +#define DDRSS_PHY_292_DATA 0x00000000 +#define DDRSS_PHY_293_DATA 0x55555555 +#define DDRSS_PHY_294_DATA 0xAAAAAAAA +#define DDRSS_PHY_295_DATA 0x55555555 +#define DDRSS_PHY_296_DATA 0xAAAAAAAA +#define DDRSS_PHY_297_DATA 0x00005555 +#define DDRSS_PHY_298_DATA 0x01000100 +#define DDRSS_PHY_299_DATA 0x00800180 +#define DDRSS_PHY_300_DATA 0x00000000 +#define DDRSS_PHY_301_DATA 0x00000000 +#define DDRSS_PHY_302_DATA 0x00000000 +#define DDRSS_PHY_303_DATA 0x00000000 +#define DDRSS_PHY_304_DATA 0x00000000 +#define DDRSS_PHY_305_DATA 0x00000000 +#define DDRSS_PHY_306_DATA 0x00000000 +#define DDRSS_PHY_307_DATA 0x00000000 +#define DDRSS_PHY_308_DATA 0x00000000 +#define DDRSS_PHY_309_DATA 0x00000000 +#define DDRSS_PHY_310_DATA 0x00000000 +#define DDRSS_PHY_311_DATA 0x00000000 +#define DDRSS_PHY_312_DATA 0x00000000 +#define DDRSS_PHY_313_DATA 0x00000000 +#define DDRSS_PHY_314_DATA 0x00000000 +#define DDRSS_PHY_315_DATA 0x00000000 +#define DDRSS_PHY_316_DATA 0x00000000 +#define DDRSS_PHY_317_DATA 0x00000000 +#define DDRSS_PHY_318_DATA 0x00000000 +#define DDRSS_PHY_319_DATA 0x00000000 +#define DDRSS_PHY_320_DATA 0x00000000 +#define DDRSS_PHY_321_DATA 0x00000004 +#define DDRSS_PHY_322_DATA 0x00000000 +#define DDRSS_PHY_323_DATA 0x00000000 +#define DDRSS_PHY_324_DATA 0x00000000 +#define DDRSS_PHY_325_DATA 0x00000000 +#define DDRSS_PHY_326_DATA 0x00000000 +#define DDRSS_PHY_327_DATA 0x00000000 +#define DDRSS_PHY_328_DATA 0x041F07FF +#define DDRSS_PHY_329_DATA 0x00000000 +#define DDRSS_PHY_330_DATA 0x01CCB001 +#define DDRSS_PHY_331_DATA 0x2000CCB0 +#define DDRSS_PHY_332_DATA 0x20000140 +#define DDRSS_PHY_333_DATA 0x07FF0200 +#define DDRSS_PHY_334_DATA 0x0000DD01 +#define DDRSS_PHY_335_DATA 0x10100303 +#define DDRSS_PHY_336_DATA 0x10101010 +#define DDRSS_PHY_337_DATA 0x10101010 +#define DDRSS_PHY_338_DATA 0x00021010 +#define DDRSS_PHY_339_DATA 0x00100010 +#define DDRSS_PHY_340_DATA 0x00100010 +#define DDRSS_PHY_341_DATA 0x00100010 +#define DDRSS_PHY_342_DATA 0x00100010 +#define DDRSS_PHY_343_DATA 0x02020010 +#define DDRSS_PHY_344_DATA 0x51515041 +#define DDRSS_PHY_345_DATA 0x31804000 +#define DDRSS_PHY_346_DATA 0x04BF0340 +#define DDRSS_PHY_347_DATA 0x01008080 +#define DDRSS_PHY_348_DATA 0x04050001 +#define DDRSS_PHY_349_DATA 0x00000504 +#define DDRSS_PHY_350_DATA 0x42100010 +#define DDRSS_PHY_351_DATA 0x010C053E +#define DDRSS_PHY_352_DATA 0x000F0C14 +#define DDRSS_PHY_353_DATA 0x01000140 +#define DDRSS_PHY_354_DATA 0x007A0120 +#define DDRSS_PHY_355_DATA 0x00000C00 +#define DDRSS_PHY_356_DATA 0x000001CC +#define DDRSS_PHY_357_DATA 0x20100200 +#define DDRSS_PHY_358_DATA 0x00000005 +#define DDRSS_PHY_359_DATA 0x76543210 +#define DDRSS_PHY_360_DATA 0x00000008 +#define DDRSS_PHY_361_DATA 0x02800280 +#define DDRSS_PHY_362_DATA 0x02800280 +#define DDRSS_PHY_363_DATA 0x02800280 +#define DDRSS_PHY_364_DATA 0x02800280 +#define DDRSS_PHY_365_DATA 0x00000280 +#define DDRSS_PHY_366_DATA 0x00008000 +#define DDRSS_PHY_367_DATA 0x00800080 +#define DDRSS_PHY_368_DATA 0x00800080 +#define DDRSS_PHY_369_DATA 0x00800080 +#define DDRSS_PHY_370_DATA 0x00800080 +#define DDRSS_PHY_371_DATA 0x00800080 +#define DDRSS_PHY_372_DATA 0x00800080 +#define DDRSS_PHY_373_DATA 0x00800080 +#define DDRSS_PHY_374_DATA 0x00800080 +#define DDRSS_PHY_375_DATA 0x01000080 +#define DDRSS_PHY_376_DATA 0x01A00000 +#define DDRSS_PHY_377_DATA 0x00000000 +#define DDRSS_PHY_378_DATA 0x00000000 +#define DDRSS_PHY_379_DATA 0x00080200 +#define DDRSS_PHY_380_DATA 0x00000000 +#define DDRSS_PHY_381_DATA 0x00000000 +#define DDRSS_PHY_382_DATA 0x00000000 +#define DDRSS_PHY_383_DATA 0x00000000 +#define DDRSS_PHY_384_DATA 0x00000000 +#define DDRSS_PHY_385_DATA 0x00000000 +#define DDRSS_PHY_386_DATA 0x00000000 +#define DDRSS_PHY_387_DATA 0x00000000 +#define DDRSS_PHY_388_DATA 0x00000000 +#define DDRSS_PHY_389_DATA 0x00000000 +#define DDRSS_PHY_390_DATA 0x00000000 +#define DDRSS_PHY_391_DATA 0x00000000 +#define DDRSS_PHY_392_DATA 0x00000000 +#define DDRSS_PHY_393_DATA 0x00000000 +#define DDRSS_PHY_394_DATA 0x00000000 +#define DDRSS_PHY_395_DATA 0x00000000 +#define DDRSS_PHY_396_DATA 0x00000000 +#define DDRSS_PHY_397_DATA 0x00000000 +#define DDRSS_PHY_398_DATA 0x00000000 +#define DDRSS_PHY_399_DATA 0x00000000 +#define DDRSS_PHY_400_DATA 0x00000000 +#define DDRSS_PHY_401_DATA 0x00000000 +#define DDRSS_PHY_402_DATA 0x00000000 +#define DDRSS_PHY_403_DATA 0x00000000 +#define DDRSS_PHY_404_DATA 0x00000000 +#define DDRSS_PHY_405_DATA 0x00000000 +#define DDRSS_PHY_406_DATA 0x00000000 +#define DDRSS_PHY_407_DATA 0x00000000 +#define DDRSS_PHY_408_DATA 0x00000000 +#define DDRSS_PHY_409_DATA 0x00000000 +#define DDRSS_PHY_410_DATA 0x00000000 +#define DDRSS_PHY_411_DATA 0x00000000 +#define DDRSS_PHY_412_DATA 0x00000000 +#define DDRSS_PHY_413_DATA 0x00000000 +#define DDRSS_PHY_414_DATA 0x00000000 +#define DDRSS_PHY_415_DATA 0x00000000 +#define DDRSS_PHY_416_DATA 0x00000000 +#define DDRSS_PHY_417_DATA 0x00000000 +#define DDRSS_PHY_418_DATA 0x00000000 +#define DDRSS_PHY_419_DATA 0x00000000 +#define DDRSS_PHY_420_DATA 0x00000000 +#define DDRSS_PHY_421_DATA 0x00000000 +#define DDRSS_PHY_422_DATA 0x00000000 +#define DDRSS_PHY_423_DATA 0x00000000 +#define DDRSS_PHY_424_DATA 0x00000000 +#define DDRSS_PHY_425_DATA 0x00000000 +#define DDRSS_PHY_426_DATA 0x00000000 +#define DDRSS_PHY_427_DATA 0x00000000 +#define DDRSS_PHY_428_DATA 0x00000000 +#define DDRSS_PHY_429_DATA 0x00000000 +#define DDRSS_PHY_430_DATA 0x00000000 +#define DDRSS_PHY_431_DATA 0x00000000 +#define DDRSS_PHY_432_DATA 0x00000000 +#define DDRSS_PHY_433_DATA 0x00000000 +#define DDRSS_PHY_434_DATA 0x00000000 +#define DDRSS_PHY_435_DATA 0x00000000 +#define DDRSS_PHY_436_DATA 0x00000000 +#define DDRSS_PHY_437_DATA 0x00000000 +#define DDRSS_PHY_438_DATA 0x00000000 +#define DDRSS_PHY_439_DATA 0x00000000 +#define DDRSS_PHY_440_DATA 0x00000000 +#define DDRSS_PHY_441_DATA 0x00000000 +#define DDRSS_PHY_442_DATA 0x00000000 +#define DDRSS_PHY_443_DATA 0x00000000 +#define DDRSS_PHY_444_DATA 0x00000000 +#define DDRSS_PHY_445_DATA 0x00000000 +#define DDRSS_PHY_446_DATA 0x00000000 +#define DDRSS_PHY_447_DATA 0x00000000 +#define DDRSS_PHY_448_DATA 0x00000000 +#define DDRSS_PHY_449_DATA 0x00000000 +#define DDRSS_PHY_450_DATA 0x00000000 +#define DDRSS_PHY_451_DATA 0x00000000 +#define DDRSS_PHY_452_DATA 0x00000000 +#define DDRSS_PHY_453_DATA 0x00000000 +#define DDRSS_PHY_454_DATA 0x00000000 +#define DDRSS_PHY_455_DATA 0x00000000 +#define DDRSS_PHY_456_DATA 0x00000000 +#define DDRSS_PHY_457_DATA 0x00000000 +#define DDRSS_PHY_458_DATA 0x00000000 +#define DDRSS_PHY_459_DATA 0x00000000 +#define DDRSS_PHY_460_DATA 0x00000000 +#define DDRSS_PHY_461_DATA 0x00000000 +#define DDRSS_PHY_462_DATA 0x00000000 +#define DDRSS_PHY_463_DATA 0x00000000 +#define DDRSS_PHY_464_DATA 0x00000000 +#define DDRSS_PHY_465_DATA 0x00000000 +#define DDRSS_PHY_466_DATA 0x00000000 +#define DDRSS_PHY_467_DATA 0x00000000 +#define DDRSS_PHY_468_DATA 0x00000000 +#define DDRSS_PHY_469_DATA 0x00000000 +#define DDRSS_PHY_470_DATA 0x00000000 +#define DDRSS_PHY_471_DATA 0x00000000 +#define DDRSS_PHY_472_DATA 0x00000000 +#define DDRSS_PHY_473_DATA 0x00000000 +#define DDRSS_PHY_474_DATA 0x00000000 +#define DDRSS_PHY_475_DATA 0x00000000 +#define DDRSS_PHY_476_DATA 0x00000000 +#define DDRSS_PHY_477_DATA 0x00000000 +#define DDRSS_PHY_478_DATA 0x00000000 +#define DDRSS_PHY_479_DATA 0x00000000 +#define DDRSS_PHY_480_DATA 0x00000000 +#define DDRSS_PHY_481_DATA 0x00000000 +#define DDRSS_PHY_482_DATA 0x00000000 +#define DDRSS_PHY_483_DATA 0x00000000 +#define DDRSS_PHY_484_DATA 0x00000000 +#define DDRSS_PHY_485_DATA 0x00000000 +#define DDRSS_PHY_486_DATA 0x00000000 +#define DDRSS_PHY_487_DATA 0x00000000 +#define DDRSS_PHY_488_DATA 0x00000000 +#define DDRSS_PHY_489_DATA 0x00000000 +#define DDRSS_PHY_490_DATA 0x00000000 +#define DDRSS_PHY_491_DATA 0x00000000 +#define DDRSS_PHY_492_DATA 0x00000000 +#define DDRSS_PHY_493_DATA 0x00000000 +#define DDRSS_PHY_494_DATA 0x00000000 +#define DDRSS_PHY_495_DATA 0x00000000 +#define DDRSS_PHY_496_DATA 0x00000000 +#define DDRSS_PHY_497_DATA 0x00000000 +#define DDRSS_PHY_498_DATA 0x00000000 +#define DDRSS_PHY_499_DATA 0x00000000 +#define DDRSS_PHY_500_DATA 0x00000000 +#define DDRSS_PHY_501_DATA 0x00000000 +#define DDRSS_PHY_502_DATA 0x00000000 +#define DDRSS_PHY_503_DATA 0x00000000 +#define DDRSS_PHY_504_DATA 0x00000000 +#define DDRSS_PHY_505_DATA 0x00000000 +#define DDRSS_PHY_506_DATA 0x00000000 +#define DDRSS_PHY_507_DATA 0x00000000 +#define DDRSS_PHY_508_DATA 0x00000000 +#define DDRSS_PHY_509_DATA 0x00000000 +#define DDRSS_PHY_510_DATA 0x00000000 +#define DDRSS_PHY_511_DATA 0x00000000 +#define DDRSS_PHY_512_DATA 0x00000100 +#define DDRSS_PHY_513_DATA 0x00000000 +#define DDRSS_PHY_514_DATA 0x00000000 +#define DDRSS_PHY_515_DATA 0x00000000 +#define DDRSS_PHY_516_DATA 0x00000000 +#define DDRSS_PHY_517_DATA 0x00000100 +#define DDRSS_PHY_518_DATA 0x00000000 +#define DDRSS_PHY_519_DATA 0x00000000 +#define DDRSS_PHY_520_DATA 0x00000000 +#define DDRSS_PHY_521_DATA 0x00000000 +#define DDRSS_PHY_522_DATA 0x00000000 +#define DDRSS_PHY_523_DATA 0x00000000 +#define DDRSS_PHY_524_DATA 0x00000000 +#define DDRSS_PHY_525_DATA 0x00DCBA98 +#define DDRSS_PHY_526_DATA 0x00000000 +#define DDRSS_PHY_527_DATA 0x00000000 +#define DDRSS_PHY_528_DATA 0x00000000 +#define DDRSS_PHY_529_DATA 0x00000000 +#define DDRSS_PHY_530_DATA 0x00000000 +#define DDRSS_PHY_531_DATA 0x00000000 +#define DDRSS_PHY_532_DATA 0x00000000 +#define DDRSS_PHY_533_DATA 0x00000000 +#define DDRSS_PHY_534_DATA 0x00000000 +#define DDRSS_PHY_535_DATA 0x00000000 +#define DDRSS_PHY_536_DATA 0x00000000 +#define DDRSS_PHY_537_DATA 0x00000000 +#define DDRSS_PHY_538_DATA 0x00000000 +#define DDRSS_PHY_539_DATA 0x00000000 +#define DDRSS_PHY_540_DATA 0x0A418820 +#define DDRSS_PHY_541_DATA 0x103F0000 +#define DDRSS_PHY_542_DATA 0x000F0100 +#define DDRSS_PHY_543_DATA 0x0000000F +#define DDRSS_PHY_544_DATA 0x020002CC +#define DDRSS_PHY_545_DATA 0x00030000 +#define DDRSS_PHY_546_DATA 0x00000300 +#define DDRSS_PHY_547_DATA 0x00000300 +#define DDRSS_PHY_548_DATA 0x00000300 +#define DDRSS_PHY_549_DATA 0x00000300 +#define DDRSS_PHY_550_DATA 0x00000300 +#define DDRSS_PHY_551_DATA 0x42080010 +#define DDRSS_PHY_552_DATA 0x0000003E +#define DDRSS_PHY_553_DATA 0x00000000 +#define DDRSS_PHY_554_DATA 0x00000000 +#define DDRSS_PHY_555_DATA 0x00000000 +#define DDRSS_PHY_556_DATA 0x00000000 +#define DDRSS_PHY_557_DATA 0x00000000 +#define DDRSS_PHY_558_DATA 0x00000000 +#define DDRSS_PHY_559_DATA 0x00000000 +#define DDRSS_PHY_560_DATA 0x00000000 +#define DDRSS_PHY_561_DATA 0x00000000 +#define DDRSS_PHY_562_DATA 0x00000000 +#define DDRSS_PHY_563_DATA 0x00000000 +#define DDRSS_PHY_564_DATA 0x00000000 +#define DDRSS_PHY_565_DATA 0x00000000 +#define DDRSS_PHY_566_DATA 0x00000000 +#define DDRSS_PHY_567_DATA 0x00000000 +#define DDRSS_PHY_568_DATA 0x00000000 +#define DDRSS_PHY_569_DATA 0x00000000 +#define DDRSS_PHY_570_DATA 0x00000000 +#define DDRSS_PHY_571_DATA 0x00000000 +#define DDRSS_PHY_572_DATA 0x00000000 +#define DDRSS_PHY_573_DATA 0x00000000 +#define DDRSS_PHY_574_DATA 0x00000000 +#define DDRSS_PHY_575_DATA 0x00000000 +#define DDRSS_PHY_576_DATA 0x00000000 +#define DDRSS_PHY_577_DATA 0x00000000 +#define DDRSS_PHY_578_DATA 0x00000000 +#define DDRSS_PHY_579_DATA 0x00000000 +#define DDRSS_PHY_580_DATA 0x00000000 +#define DDRSS_PHY_581_DATA 0x00000000 +#define DDRSS_PHY_582_DATA 0x00000000 +#define DDRSS_PHY_583_DATA 0x00000000 +#define DDRSS_PHY_584_DATA 0x00000000 +#define DDRSS_PHY_585_DATA 0x00000000 +#define DDRSS_PHY_586_DATA 0x00000000 +#define DDRSS_PHY_587_DATA 0x00000000 +#define DDRSS_PHY_588_DATA 0x00000000 +#define DDRSS_PHY_589_DATA 0x00000000 +#define DDRSS_PHY_590_DATA 0x00000000 +#define DDRSS_PHY_591_DATA 0x00000000 +#define DDRSS_PHY_592_DATA 0x00000000 +#define DDRSS_PHY_593_DATA 0x00000000 +#define DDRSS_PHY_594_DATA 0x00000000 +#define DDRSS_PHY_595_DATA 0x00000000 +#define DDRSS_PHY_596_DATA 0x00000000 +#define DDRSS_PHY_597_DATA 0x00000000 +#define DDRSS_PHY_598_DATA 0x00000000 +#define DDRSS_PHY_599_DATA 0x00000000 +#define DDRSS_PHY_600_DATA 0x00000000 +#define DDRSS_PHY_601_DATA 0x00000000 +#define DDRSS_PHY_602_DATA 0x00000000 +#define DDRSS_PHY_603_DATA 0x00000000 +#define DDRSS_PHY_604_DATA 0x00000000 +#define DDRSS_PHY_605_DATA 0x00000000 +#define DDRSS_PHY_606_DATA 0x00000000 +#define DDRSS_PHY_607_DATA 0x00000000 +#define DDRSS_PHY_608_DATA 0x00000000 +#define DDRSS_PHY_609_DATA 0x00000000 +#define DDRSS_PHY_610_DATA 0x00000000 +#define DDRSS_PHY_611_DATA 0x00000000 +#define DDRSS_PHY_612_DATA 0x00000000 +#define DDRSS_PHY_613_DATA 0x00000000 +#define DDRSS_PHY_614_DATA 0x00000000 +#define DDRSS_PHY_615_DATA 0x00000000 +#define DDRSS_PHY_616_DATA 0x00000000 +#define DDRSS_PHY_617_DATA 0x00000000 +#define DDRSS_PHY_618_DATA 0x00000000 +#define DDRSS_PHY_619_DATA 0x00000000 +#define DDRSS_PHY_620_DATA 0x00000000 +#define DDRSS_PHY_621_DATA 0x00000000 +#define DDRSS_PHY_622_DATA 0x00000000 +#define DDRSS_PHY_623_DATA 0x00000000 +#define DDRSS_PHY_624_DATA 0x00000000 +#define DDRSS_PHY_625_DATA 0x00000000 +#define DDRSS_PHY_626_DATA 0x00000000 +#define DDRSS_PHY_627_DATA 0x00000000 +#define DDRSS_PHY_628_DATA 0x00000000 +#define DDRSS_PHY_629_DATA 0x00000000 +#define DDRSS_PHY_630_DATA 0x00000000 +#define DDRSS_PHY_631_DATA 0x00000000 +#define DDRSS_PHY_632_DATA 0x00000000 +#define DDRSS_PHY_633_DATA 0x00000000 +#define DDRSS_PHY_634_DATA 0x00000000 +#define DDRSS_PHY_635_DATA 0x00000000 +#define DDRSS_PHY_636_DATA 0x00000000 +#define DDRSS_PHY_637_DATA 0x00000000 +#define DDRSS_PHY_638_DATA 0x00000000 +#define DDRSS_PHY_639_DATA 0x00000000 +#define DDRSS_PHY_640_DATA 0x00000000 +#define DDRSS_PHY_641_DATA 0x00000000 +#define DDRSS_PHY_642_DATA 0x00000000 +#define DDRSS_PHY_643_DATA 0x00000000 +#define DDRSS_PHY_644_DATA 0x00000000 +#define DDRSS_PHY_645_DATA 0x00000000 +#define DDRSS_PHY_646_DATA 0x00000000 +#define DDRSS_PHY_647_DATA 0x00000000 +#define DDRSS_PHY_648_DATA 0x00000000 +#define DDRSS_PHY_649_DATA 0x00000000 +#define DDRSS_PHY_650_DATA 0x00000000 +#define DDRSS_PHY_651_DATA 0x00000000 +#define DDRSS_PHY_652_DATA 0x00000000 +#define DDRSS_PHY_653_DATA 0x00000000 +#define DDRSS_PHY_654_DATA 0x00000000 +#define DDRSS_PHY_655_DATA 0x00000000 +#define DDRSS_PHY_656_DATA 0x00000000 +#define DDRSS_PHY_657_DATA 0x00000000 +#define DDRSS_PHY_658_DATA 0x00000000 +#define DDRSS_PHY_659_DATA 0x00000000 +#define DDRSS_PHY_660_DATA 0x00000000 +#define DDRSS_PHY_661_DATA 0x00000000 +#define DDRSS_PHY_662_DATA 0x00000000 +#define DDRSS_PHY_663_DATA 0x00000000 +#define DDRSS_PHY_664_DATA 0x00000000 +#define DDRSS_PHY_665_DATA 0x00000000 +#define DDRSS_PHY_666_DATA 0x00000000 +#define DDRSS_PHY_667_DATA 0x00000000 +#define DDRSS_PHY_668_DATA 0x00000000 +#define DDRSS_PHY_669_DATA 0x00000000 +#define DDRSS_PHY_670_DATA 0x00000000 +#define DDRSS_PHY_671_DATA 0x00000000 +#define DDRSS_PHY_672_DATA 0x00000000 +#define DDRSS_PHY_673_DATA 0x00000000 +#define DDRSS_PHY_674_DATA 0x00000000 +#define DDRSS_PHY_675_DATA 0x00000000 +#define DDRSS_PHY_676_DATA 0x00000000 +#define DDRSS_PHY_677_DATA 0x00000000 +#define DDRSS_PHY_678_DATA 0x00000000 +#define DDRSS_PHY_679_DATA 0x00000000 +#define DDRSS_PHY_680_DATA 0x00000000 +#define DDRSS_PHY_681_DATA 0x00000000 +#define DDRSS_PHY_682_DATA 0x00000000 +#define DDRSS_PHY_683_DATA 0x00000000 +#define DDRSS_PHY_684_DATA 0x00000000 +#define DDRSS_PHY_685_DATA 0x00000000 +#define DDRSS_PHY_686_DATA 0x00000000 +#define DDRSS_PHY_687_DATA 0x00000000 +#define DDRSS_PHY_688_DATA 0x00000000 +#define DDRSS_PHY_689_DATA 0x00000000 +#define DDRSS_PHY_690_DATA 0x00000000 +#define DDRSS_PHY_691_DATA 0x00000000 +#define DDRSS_PHY_692_DATA 0x00000000 +#define DDRSS_PHY_693_DATA 0x00000000 +#define DDRSS_PHY_694_DATA 0x00000000 +#define DDRSS_PHY_695_DATA 0x00000000 +#define DDRSS_PHY_696_DATA 0x00000000 +#define DDRSS_PHY_697_DATA 0x00000000 +#define DDRSS_PHY_698_DATA 0x00000000 +#define DDRSS_PHY_699_DATA 0x00000000 +#define DDRSS_PHY_700_DATA 0x00000000 +#define DDRSS_PHY_701_DATA 0x00000000 +#define DDRSS_PHY_702_DATA 0x00000000 +#define DDRSS_PHY_703_DATA 0x00000000 +#define DDRSS_PHY_704_DATA 0x00000000 +#define DDRSS_PHY_705_DATA 0x00000000 +#define DDRSS_PHY_706_DATA 0x00000000 +#define DDRSS_PHY_707_DATA 0x00000000 +#define DDRSS_PHY_708_DATA 0x00000000 +#define DDRSS_PHY_709_DATA 0x00000000 +#define DDRSS_PHY_710_DATA 0x00000000 +#define DDRSS_PHY_711_DATA 0x00000000 +#define DDRSS_PHY_712_DATA 0x00000000 +#define DDRSS_PHY_713_DATA 0x00000000 +#define DDRSS_PHY_714_DATA 0x00000000 +#define DDRSS_PHY_715_DATA 0x00000000 +#define DDRSS_PHY_716_DATA 0x00000000 +#define DDRSS_PHY_717_DATA 0x00000000 +#define DDRSS_PHY_718_DATA 0x00000000 +#define DDRSS_PHY_719_DATA 0x00000000 +#define DDRSS_PHY_720_DATA 0x00000000 +#define DDRSS_PHY_721_DATA 0x00000000 +#define DDRSS_PHY_722_DATA 0x00000000 +#define DDRSS_PHY_723_DATA 0x00000000 +#define DDRSS_PHY_724_DATA 0x00000000 +#define DDRSS_PHY_725_DATA 0x00000000 +#define DDRSS_PHY_726_DATA 0x00000000 +#define DDRSS_PHY_727_DATA 0x00000000 +#define DDRSS_PHY_728_DATA 0x00000000 +#define DDRSS_PHY_729_DATA 0x00000000 +#define DDRSS_PHY_730_DATA 0x00000000 +#define DDRSS_PHY_731_DATA 0x00000000 +#define DDRSS_PHY_732_DATA 0x00000000 +#define DDRSS_PHY_733_DATA 0x00000000 +#define DDRSS_PHY_734_DATA 0x00000000 +#define DDRSS_PHY_735_DATA 0x00000000 +#define DDRSS_PHY_736_DATA 0x00000000 +#define DDRSS_PHY_737_DATA 0x00000000 +#define DDRSS_PHY_738_DATA 0x00000000 +#define DDRSS_PHY_739_DATA 0x00000000 +#define DDRSS_PHY_740_DATA 0x00000000 +#define DDRSS_PHY_741_DATA 0x00000000 +#define DDRSS_PHY_742_DATA 0x00000000 +#define DDRSS_PHY_743_DATA 0x00000000 +#define DDRSS_PHY_744_DATA 0x00000000 +#define DDRSS_PHY_745_DATA 0x00000000 +#define DDRSS_PHY_746_DATA 0x00000000 +#define DDRSS_PHY_747_DATA 0x00000000 +#define DDRSS_PHY_748_DATA 0x00000000 +#define DDRSS_PHY_749_DATA 0x00000000 +#define DDRSS_PHY_750_DATA 0x00000000 +#define DDRSS_PHY_751_DATA 0x00000000 +#define DDRSS_PHY_752_DATA 0x00000000 +#define DDRSS_PHY_753_DATA 0x00000000 +#define DDRSS_PHY_754_DATA 0x00000000 +#define DDRSS_PHY_755_DATA 0x00000000 +#define DDRSS_PHY_756_DATA 0x00000000 +#define DDRSS_PHY_757_DATA 0x00000000 +#define DDRSS_PHY_758_DATA 0x00000000 +#define DDRSS_PHY_759_DATA 0x00000000 +#define DDRSS_PHY_760_DATA 0x00000000 +#define DDRSS_PHY_761_DATA 0x00000000 +#define DDRSS_PHY_762_DATA 0x00000000 +#define DDRSS_PHY_763_DATA 0x00000000 +#define DDRSS_PHY_764_DATA 0x00000000 +#define DDRSS_PHY_765_DATA 0x00000000 +#define DDRSS_PHY_766_DATA 0x00000000 +#define DDRSS_PHY_767_DATA 0x00000000 +#define DDRSS_PHY_768_DATA 0x00000100 +#define DDRSS_PHY_769_DATA 0x00000000 +#define DDRSS_PHY_770_DATA 0x00000000 +#define DDRSS_PHY_771_DATA 0x00000000 +#define DDRSS_PHY_772_DATA 0x00000000 +#define DDRSS_PHY_773_DATA 0x00000100 +#define DDRSS_PHY_774_DATA 0x00000000 +#define DDRSS_PHY_775_DATA 0x00000000 +#define DDRSS_PHY_776_DATA 0x00000000 +#define DDRSS_PHY_777_DATA 0x00000000 +#define DDRSS_PHY_778_DATA 0x00000000 +#define DDRSS_PHY_779_DATA 0x00000000 +#define DDRSS_PHY_780_DATA 0x00000000 +#define DDRSS_PHY_781_DATA 0x00DCBA98 +#define DDRSS_PHY_782_DATA 0x00000000 +#define DDRSS_PHY_783_DATA 0x00000000 +#define DDRSS_PHY_784_DATA 0x00000000 +#define DDRSS_PHY_785_DATA 0x00000000 +#define DDRSS_PHY_786_DATA 0x00000000 +#define DDRSS_PHY_787_DATA 0x00000000 +#define DDRSS_PHY_788_DATA 0x00000000 +#define DDRSS_PHY_789_DATA 0x00000000 +#define DDRSS_PHY_790_DATA 0x00000000 +#define DDRSS_PHY_791_DATA 0x00000000 +#define DDRSS_PHY_792_DATA 0x00000000 +#define DDRSS_PHY_793_DATA 0x00000000 +#define DDRSS_PHY_794_DATA 0x00000000 +#define DDRSS_PHY_795_DATA 0x00000000 +#define DDRSS_PHY_796_DATA 0x16A4A0E6 +#define DDRSS_PHY_797_DATA 0x103F0000 +#define DDRSS_PHY_798_DATA 0x000F0000 +#define DDRSS_PHY_799_DATA 0x0000000F +#define DDRSS_PHY_800_DATA 0x020002CC +#define DDRSS_PHY_801_DATA 0x00030000 +#define DDRSS_PHY_802_DATA 0x00000300 +#define DDRSS_PHY_803_DATA 0x00000300 +#define DDRSS_PHY_804_DATA 0x00000300 +#define DDRSS_PHY_805_DATA 0x00000300 +#define DDRSS_PHY_806_DATA 0x00000300 +#define DDRSS_PHY_807_DATA 0x42080010 +#define DDRSS_PHY_808_DATA 0x0000003E +#define DDRSS_PHY_809_DATA 0x00000000 +#define DDRSS_PHY_810_DATA 0x00000000 +#define DDRSS_PHY_811_DATA 0x00000000 +#define DDRSS_PHY_812_DATA 0x00000000 +#define DDRSS_PHY_813_DATA 0x00000000 +#define DDRSS_PHY_814_DATA 0x00000000 +#define DDRSS_PHY_815_DATA 0x00000000 +#define DDRSS_PHY_816_DATA 0x00000000 +#define DDRSS_PHY_817_DATA 0x00000000 +#define DDRSS_PHY_818_DATA 0x00000000 +#define DDRSS_PHY_819_DATA 0x00000000 +#define DDRSS_PHY_820_DATA 0x00000000 +#define DDRSS_PHY_821_DATA 0x00000000 +#define DDRSS_PHY_822_DATA 0x00000000 +#define DDRSS_PHY_823_DATA 0x00000000 +#define DDRSS_PHY_824_DATA 0x00000000 +#define DDRSS_PHY_825_DATA 0x00000000 +#define DDRSS_PHY_826_DATA 0x00000000 +#define DDRSS_PHY_827_DATA 0x00000000 +#define DDRSS_PHY_828_DATA 0x00000000 +#define DDRSS_PHY_829_DATA 0x00000000 +#define DDRSS_PHY_830_DATA 0x00000000 +#define DDRSS_PHY_831_DATA 0x00000000 +#define DDRSS_PHY_832_DATA 0x00000000 +#define DDRSS_PHY_833_DATA 0x00000000 +#define DDRSS_PHY_834_DATA 0x00000000 +#define DDRSS_PHY_835_DATA 0x00000000 +#define DDRSS_PHY_836_DATA 0x00000000 +#define DDRSS_PHY_837_DATA 0x00000000 +#define DDRSS_PHY_838_DATA 0x00000000 +#define DDRSS_PHY_839_DATA 0x00000000 +#define DDRSS_PHY_840_DATA 0x00000000 +#define DDRSS_PHY_841_DATA 0x00000000 +#define DDRSS_PHY_842_DATA 0x00000000 +#define DDRSS_PHY_843_DATA 0x00000000 +#define DDRSS_PHY_844_DATA 0x00000000 +#define DDRSS_PHY_845_DATA 0x00000000 +#define DDRSS_PHY_846_DATA 0x00000000 +#define DDRSS_PHY_847_DATA 0x00000000 +#define DDRSS_PHY_848_DATA 0x00000000 +#define DDRSS_PHY_849_DATA 0x00000000 +#define DDRSS_PHY_850_DATA 0x00000000 +#define DDRSS_PHY_851_DATA 0x00000000 +#define DDRSS_PHY_852_DATA 0x00000000 +#define DDRSS_PHY_853_DATA 0x00000000 +#define DDRSS_PHY_854_DATA 0x00000000 +#define DDRSS_PHY_855_DATA 0x00000000 +#define DDRSS_PHY_856_DATA 0x00000000 +#define DDRSS_PHY_857_DATA 0x00000000 +#define DDRSS_PHY_858_DATA 0x00000000 +#define DDRSS_PHY_859_DATA 0x00000000 +#define DDRSS_PHY_860_DATA 0x00000000 +#define DDRSS_PHY_861_DATA 0x00000000 +#define DDRSS_PHY_862_DATA 0x00000000 +#define DDRSS_PHY_863_DATA 0x00000000 +#define DDRSS_PHY_864_DATA 0x00000000 +#define DDRSS_PHY_865_DATA 0x00000000 +#define DDRSS_PHY_866_DATA 0x00000000 +#define DDRSS_PHY_867_DATA 0x00000000 +#define DDRSS_PHY_868_DATA 0x00000000 +#define DDRSS_PHY_869_DATA 0x00000000 +#define DDRSS_PHY_870_DATA 0x00000000 +#define DDRSS_PHY_871_DATA 0x00000000 +#define DDRSS_PHY_872_DATA 0x00000000 +#define DDRSS_PHY_873_DATA 0x00000000 +#define DDRSS_PHY_874_DATA 0x00000000 +#define DDRSS_PHY_875_DATA 0x00000000 +#define DDRSS_PHY_876_DATA 0x00000000 +#define DDRSS_PHY_877_DATA 0x00000000 +#define DDRSS_PHY_878_DATA 0x00000000 +#define DDRSS_PHY_879_DATA 0x00000000 +#define DDRSS_PHY_880_DATA 0x00000000 +#define DDRSS_PHY_881_DATA 0x00000000 +#define DDRSS_PHY_882_DATA 0x00000000 +#define DDRSS_PHY_883_DATA 0x00000000 +#define DDRSS_PHY_884_DATA 0x00000000 +#define DDRSS_PHY_885_DATA 0x00000000 +#define DDRSS_PHY_886_DATA 0x00000000 +#define DDRSS_PHY_887_DATA 0x00000000 +#define DDRSS_PHY_888_DATA 0x00000000 +#define DDRSS_PHY_889_DATA 0x00000000 +#define DDRSS_PHY_890_DATA 0x00000000 +#define DDRSS_PHY_891_DATA 0x00000000 +#define DDRSS_PHY_892_DATA 0x00000000 +#define DDRSS_PHY_893_DATA 0x00000000 +#define DDRSS_PHY_894_DATA 0x00000000 +#define DDRSS_PHY_895_DATA 0x00000000 +#define DDRSS_PHY_896_DATA 0x00000000 +#define DDRSS_PHY_897_DATA 0x00000000 +#define DDRSS_PHY_898_DATA 0x00000000 +#define DDRSS_PHY_899_DATA 0x00000000 +#define DDRSS_PHY_900_DATA 0x00000000 +#define DDRSS_PHY_901_DATA 0x00000000 +#define DDRSS_PHY_902_DATA 0x00000000 +#define DDRSS_PHY_903_DATA 0x00000000 +#define DDRSS_PHY_904_DATA 0x00000000 +#define DDRSS_PHY_905_DATA 0x00000000 +#define DDRSS_PHY_906_DATA 0x00000000 +#define DDRSS_PHY_907_DATA 0x00000000 +#define DDRSS_PHY_908_DATA 0x00000000 +#define DDRSS_PHY_909_DATA 0x00000000 +#define DDRSS_PHY_910_DATA 0x00000000 +#define DDRSS_PHY_911_DATA 0x00000000 +#define DDRSS_PHY_912_DATA 0x00000000 +#define DDRSS_PHY_913_DATA 0x00000000 +#define DDRSS_PHY_914_DATA 0x00000000 +#define DDRSS_PHY_915_DATA 0x00000000 +#define DDRSS_PHY_916_DATA 0x00000000 +#define DDRSS_PHY_917_DATA 0x00000000 +#define DDRSS_PHY_918_DATA 0x00000000 +#define DDRSS_PHY_919_DATA 0x00000000 +#define DDRSS_PHY_920_DATA 0x00000000 +#define DDRSS_PHY_921_DATA 0x00000000 +#define DDRSS_PHY_922_DATA 0x00000000 +#define DDRSS_PHY_923_DATA 0x00000000 +#define DDRSS_PHY_924_DATA 0x00000000 +#define DDRSS_PHY_925_DATA 0x00000000 +#define DDRSS_PHY_926_DATA 0x00000000 +#define DDRSS_PHY_927_DATA 0x00000000 +#define DDRSS_PHY_928_DATA 0x00000000 +#define DDRSS_PHY_929_DATA 0x00000000 +#define DDRSS_PHY_930_DATA 0x00000000 +#define DDRSS_PHY_931_DATA 0x00000000 +#define DDRSS_PHY_932_DATA 0x00000000 +#define DDRSS_PHY_933_DATA 0x00000000 +#define DDRSS_PHY_934_DATA 0x00000000 +#define DDRSS_PHY_935_DATA 0x00000000 +#define DDRSS_PHY_936_DATA 0x00000000 +#define DDRSS_PHY_937_DATA 0x00000000 +#define DDRSS_PHY_938_DATA 0x00000000 +#define DDRSS_PHY_939_DATA 0x00000000 +#define DDRSS_PHY_940_DATA 0x00000000 +#define DDRSS_PHY_941_DATA 0x00000000 +#define DDRSS_PHY_942_DATA 0x00000000 +#define DDRSS_PHY_943_DATA 0x00000000 +#define DDRSS_PHY_944_DATA 0x00000000 +#define DDRSS_PHY_945_DATA 0x00000000 +#define DDRSS_PHY_946_DATA 0x00000000 +#define DDRSS_PHY_947_DATA 0x00000000 +#define DDRSS_PHY_948_DATA 0x00000000 +#define DDRSS_PHY_949_DATA 0x00000000 +#define DDRSS_PHY_950_DATA 0x00000000 +#define DDRSS_PHY_951_DATA 0x00000000 +#define DDRSS_PHY_952_DATA 0x00000000 +#define DDRSS_PHY_953_DATA 0x00000000 +#define DDRSS_PHY_954_DATA 0x00000000 +#define DDRSS_PHY_955_DATA 0x00000000 +#define DDRSS_PHY_956_DATA 0x00000000 +#define DDRSS_PHY_957_DATA 0x00000000 +#define DDRSS_PHY_958_DATA 0x00000000 +#define DDRSS_PHY_959_DATA 0x00000000 +#define DDRSS_PHY_960_DATA 0x00000000 +#define DDRSS_PHY_961_DATA 0x00000000 +#define DDRSS_PHY_962_DATA 0x00000000 +#define DDRSS_PHY_963_DATA 0x00000000 +#define DDRSS_PHY_964_DATA 0x00000000 +#define DDRSS_PHY_965_DATA 0x00000000 +#define DDRSS_PHY_966_DATA 0x00000000 +#define DDRSS_PHY_967_DATA 0x00000000 +#define DDRSS_PHY_968_DATA 0x00000000 +#define DDRSS_PHY_969_DATA 0x00000000 +#define DDRSS_PHY_970_DATA 0x00000000 +#define DDRSS_PHY_971_DATA 0x00000000 +#define DDRSS_PHY_972_DATA 0x00000000 +#define DDRSS_PHY_973_DATA 0x00000000 +#define DDRSS_PHY_974_DATA 0x00000000 +#define DDRSS_PHY_975_DATA 0x00000000 +#define DDRSS_PHY_976_DATA 0x00000000 +#define DDRSS_PHY_977_DATA 0x00000000 +#define DDRSS_PHY_978_DATA 0x00000000 +#define DDRSS_PHY_979_DATA 0x00000000 +#define DDRSS_PHY_980_DATA 0x00000000 +#define DDRSS_PHY_981_DATA 0x00000000 +#define DDRSS_PHY_982_DATA 0x00000000 +#define DDRSS_PHY_983_DATA 0x00000000 +#define DDRSS_PHY_984_DATA 0x00000000 +#define DDRSS_PHY_985_DATA 0x00000000 +#define DDRSS_PHY_986_DATA 0x00000000 +#define DDRSS_PHY_987_DATA 0x00000000 +#define DDRSS_PHY_988_DATA 0x00000000 +#define DDRSS_PHY_989_DATA 0x00000000 +#define DDRSS_PHY_990_DATA 0x00000000 +#define DDRSS_PHY_991_DATA 0x00000000 +#define DDRSS_PHY_992_DATA 0x00000000 +#define DDRSS_PHY_993_DATA 0x00000000 +#define DDRSS_PHY_994_DATA 0x00000000 +#define DDRSS_PHY_995_DATA 0x00000000 +#define DDRSS_PHY_996_DATA 0x00000000 +#define DDRSS_PHY_997_DATA 0x00000000 +#define DDRSS_PHY_998_DATA 0x00000000 +#define DDRSS_PHY_999_DATA 0x00000000 +#define DDRSS_PHY_1000_DATA 0x00000000 +#define DDRSS_PHY_1001_DATA 0x00000000 +#define DDRSS_PHY_1002_DATA 0x00000000 +#define DDRSS_PHY_1003_DATA 0x00000000 +#define DDRSS_PHY_1004_DATA 0x00000000 +#define DDRSS_PHY_1005_DATA 0x00000000 +#define DDRSS_PHY_1006_DATA 0x00000000 +#define DDRSS_PHY_1007_DATA 0x00000000 +#define DDRSS_PHY_1008_DATA 0x00000000 +#define DDRSS_PHY_1009_DATA 0x00000000 +#define DDRSS_PHY_1010_DATA 0x00000000 +#define DDRSS_PHY_1011_DATA 0x00000000 +#define DDRSS_PHY_1012_DATA 0x00000000 +#define DDRSS_PHY_1013_DATA 0x00000000 +#define DDRSS_PHY_1014_DATA 0x00000000 +#define DDRSS_PHY_1015_DATA 0x00000000 +#define DDRSS_PHY_1016_DATA 0x00000000 +#define DDRSS_PHY_1017_DATA 0x00000000 +#define DDRSS_PHY_1018_DATA 0x00000000 +#define DDRSS_PHY_1019_DATA 0x00000000 +#define DDRSS_PHY_1020_DATA 0x00000000 +#define DDRSS_PHY_1021_DATA 0x00000000 +#define DDRSS_PHY_1022_DATA 0x00000000 +#define DDRSS_PHY_1023_DATA 0x00000000 +#define DDRSS_PHY_1024_DATA 0x00000100 +#define DDRSS_PHY_1025_DATA 0x00000000 +#define DDRSS_PHY_1026_DATA 0x00000000 +#define DDRSS_PHY_1027_DATA 0x00000000 +#define DDRSS_PHY_1028_DATA 0x00000000 +#define DDRSS_PHY_1029_DATA 0x00000100 +#define DDRSS_PHY_1030_DATA 0x00000000 +#define DDRSS_PHY_1031_DATA 0x00000000 +#define DDRSS_PHY_1032_DATA 0x00000000 +#define DDRSS_PHY_1033_DATA 0x00000000 +#define DDRSS_PHY_1034_DATA 0x00000000 +#define DDRSS_PHY_1035_DATA 0x00000000 +#define DDRSS_PHY_1036_DATA 0x00000000 +#define DDRSS_PHY_1037_DATA 0x00DCBA98 +#define DDRSS_PHY_1038_DATA 0x00000000 +#define DDRSS_PHY_1039_DATA 0x00000000 +#define DDRSS_PHY_1040_DATA 0x00000000 +#define DDRSS_PHY_1041_DATA 0x00000000 +#define DDRSS_PHY_1042_DATA 0x00000000 +#define DDRSS_PHY_1043_DATA 0x00000000 +#define DDRSS_PHY_1044_DATA 0x00000000 +#define DDRSS_PHY_1045_DATA 0x00000000 +#define DDRSS_PHY_1046_DATA 0x00000000 +#define DDRSS_PHY_1047_DATA 0x00000000 +#define DDRSS_PHY_1048_DATA 0x00000000 +#define DDRSS_PHY_1049_DATA 0x00000000 +#define DDRSS_PHY_1050_DATA 0x00000000 +#define DDRSS_PHY_1051_DATA 0x00000000 +#define DDRSS_PHY_1052_DATA 0x2307B9AC +#define DDRSS_PHY_1053_DATA 0x10030000 +#define DDRSS_PHY_1054_DATA 0x000F0000 +#define DDRSS_PHY_1055_DATA 0x0000000F +#define DDRSS_PHY_1056_DATA 0x020002CC +#define DDRSS_PHY_1057_DATA 0x00030000 +#define DDRSS_PHY_1058_DATA 0x00000300 +#define DDRSS_PHY_1059_DATA 0x00000300 +#define DDRSS_PHY_1060_DATA 0x00000300 +#define DDRSS_PHY_1061_DATA 0x00000300 +#define DDRSS_PHY_1062_DATA 0x00000300 +#define DDRSS_PHY_1063_DATA 0x42080010 +#define DDRSS_PHY_1064_DATA 0x0000003E +#define DDRSS_PHY_1065_DATA 0x00000000 +#define DDRSS_PHY_1066_DATA 0x00000000 +#define DDRSS_PHY_1067_DATA 0x00000000 +#define DDRSS_PHY_1068_DATA 0x00000000 +#define DDRSS_PHY_1069_DATA 0x00000000 +#define DDRSS_PHY_1070_DATA 0x00000000 +#define DDRSS_PHY_1071_DATA 0x00000000 +#define DDRSS_PHY_1072_DATA 0x00000000 +#define DDRSS_PHY_1073_DATA 0x00000000 +#define DDRSS_PHY_1074_DATA 0x00000000 +#define DDRSS_PHY_1075_DATA 0x00000000 +#define DDRSS_PHY_1076_DATA 0x00000000 +#define DDRSS_PHY_1077_DATA 0x00000000 +#define DDRSS_PHY_1078_DATA 0x00000000 +#define DDRSS_PHY_1079_DATA 0x00000000 +#define DDRSS_PHY_1080_DATA 0x00000000 +#define DDRSS_PHY_1081_DATA 0x00000000 +#define DDRSS_PHY_1082_DATA 0x00000000 +#define DDRSS_PHY_1083_DATA 0x00000000 +#define DDRSS_PHY_1084_DATA 0x00000000 +#define DDRSS_PHY_1085_DATA 0x00000000 +#define DDRSS_PHY_1086_DATA 0x00000000 +#define DDRSS_PHY_1087_DATA 0x00000000 +#define DDRSS_PHY_1088_DATA 0x00000000 +#define DDRSS_PHY_1089_DATA 0x00000000 +#define DDRSS_PHY_1090_DATA 0x00000000 +#define DDRSS_PHY_1091_DATA 0x00000000 +#define DDRSS_PHY_1092_DATA 0x00000000 +#define DDRSS_PHY_1093_DATA 0x00000000 +#define DDRSS_PHY_1094_DATA 0x00000000 +#define DDRSS_PHY_1095_DATA 0x00000000 +#define DDRSS_PHY_1096_DATA 0x00000000 +#define DDRSS_PHY_1097_DATA 0x00000000 +#define DDRSS_PHY_1098_DATA 0x00000000 +#define DDRSS_PHY_1099_DATA 0x00000000 +#define DDRSS_PHY_1100_DATA 0x00000000 +#define DDRSS_PHY_1101_DATA 0x00000000 +#define DDRSS_PHY_1102_DATA 0x00000000 +#define DDRSS_PHY_1103_DATA 0x00000000 +#define DDRSS_PHY_1104_DATA 0x00000000 +#define DDRSS_PHY_1105_DATA 0x00000000 +#define DDRSS_PHY_1106_DATA 0x00000000 +#define DDRSS_PHY_1107_DATA 0x00000000 +#define DDRSS_PHY_1108_DATA 0x00000000 +#define DDRSS_PHY_1109_DATA 0x00000000 +#define DDRSS_PHY_1110_DATA 0x00000000 +#define DDRSS_PHY_1111_DATA 0x00000000 +#define DDRSS_PHY_1112_DATA 0x00000000 +#define DDRSS_PHY_1113_DATA 0x00000000 +#define DDRSS_PHY_1114_DATA 0x00000000 +#define DDRSS_PHY_1115_DATA 0x00000000 +#define DDRSS_PHY_1116_DATA 0x00000000 +#define DDRSS_PHY_1117_DATA 0x00000000 +#define DDRSS_PHY_1118_DATA 0x00000000 +#define DDRSS_PHY_1119_DATA 0x00000000 +#define DDRSS_PHY_1120_DATA 0x00000000 +#define DDRSS_PHY_1121_DATA 0x00000000 +#define DDRSS_PHY_1122_DATA 0x00000000 +#define DDRSS_PHY_1123_DATA 0x00000000 +#define DDRSS_PHY_1124_DATA 0x00000000 +#define DDRSS_PHY_1125_DATA 0x00000000 +#define DDRSS_PHY_1126_DATA 0x00000000 +#define DDRSS_PHY_1127_DATA 0x00000000 +#define DDRSS_PHY_1128_DATA 0x00000000 +#define DDRSS_PHY_1129_DATA 0x00000000 +#define DDRSS_PHY_1130_DATA 0x00000000 +#define DDRSS_PHY_1131_DATA 0x00000000 +#define DDRSS_PHY_1132_DATA 0x00000000 +#define DDRSS_PHY_1133_DATA 0x00000000 +#define DDRSS_PHY_1134_DATA 0x00000000 +#define DDRSS_PHY_1135_DATA 0x00000000 +#define DDRSS_PHY_1136_DATA 0x00000000 +#define DDRSS_PHY_1137_DATA 0x00000000 +#define DDRSS_PHY_1138_DATA 0x00000000 +#define DDRSS_PHY_1139_DATA 0x00000000 +#define DDRSS_PHY_1140_DATA 0x00000000 +#define DDRSS_PHY_1141_DATA 0x00000000 +#define DDRSS_PHY_1142_DATA 0x00000000 +#define DDRSS_PHY_1143_DATA 0x00000000 +#define DDRSS_PHY_1144_DATA 0x00000000 +#define DDRSS_PHY_1145_DATA 0x00000000 +#define DDRSS_PHY_1146_DATA 0x00000000 +#define DDRSS_PHY_1147_DATA 0x00000000 +#define DDRSS_PHY_1148_DATA 0x00000000 +#define DDRSS_PHY_1149_DATA 0x00000000 +#define DDRSS_PHY_1150_DATA 0x00000000 +#define DDRSS_PHY_1151_DATA 0x00000000 +#define DDRSS_PHY_1152_DATA 0x00000000 +#define DDRSS_PHY_1153_DATA 0x00000000 +#define DDRSS_PHY_1154_DATA 0x00000000 +#define DDRSS_PHY_1155_DATA 0x00000000 +#define DDRSS_PHY_1156_DATA 0x00000000 +#define DDRSS_PHY_1157_DATA 0x00000000 +#define DDRSS_PHY_1158_DATA 0x00000000 +#define DDRSS_PHY_1159_DATA 0x00000000 +#define DDRSS_PHY_1160_DATA 0x00000000 +#define DDRSS_PHY_1161_DATA 0x00000000 +#define DDRSS_PHY_1162_DATA 0x00000000 +#define DDRSS_PHY_1163_DATA 0x00000000 +#define DDRSS_PHY_1164_DATA 0x00000000 +#define DDRSS_PHY_1165_DATA 0x00000000 +#define DDRSS_PHY_1166_DATA 0x00000000 +#define DDRSS_PHY_1167_DATA 0x00000000 +#define DDRSS_PHY_1168_DATA 0x00000000 +#define DDRSS_PHY_1169_DATA 0x00000000 +#define DDRSS_PHY_1170_DATA 0x00000000 +#define DDRSS_PHY_1171_DATA 0x00000000 +#define DDRSS_PHY_1172_DATA 0x00000000 +#define DDRSS_PHY_1173_DATA 0x00000000 +#define DDRSS_PHY_1174_DATA 0x00000000 +#define DDRSS_PHY_1175_DATA 0x00000000 +#define DDRSS_PHY_1176_DATA 0x00000000 +#define DDRSS_PHY_1177_DATA 0x00000000 +#define DDRSS_PHY_1178_DATA 0x00000000 +#define DDRSS_PHY_1179_DATA 0x00000000 +#define DDRSS_PHY_1180_DATA 0x00000000 +#define DDRSS_PHY_1181_DATA 0x00000000 +#define DDRSS_PHY_1182_DATA 0x00000000 +#define DDRSS_PHY_1183_DATA 0x00000000 +#define DDRSS_PHY_1184_DATA 0x00000000 +#define DDRSS_PHY_1185_DATA 0x00000000 +#define DDRSS_PHY_1186_DATA 0x00000000 +#define DDRSS_PHY_1187_DATA 0x00000000 +#define DDRSS_PHY_1188_DATA 0x00000000 +#define DDRSS_PHY_1189_DATA 0x00000000 +#define DDRSS_PHY_1190_DATA 0x00000000 +#define DDRSS_PHY_1191_DATA 0x00000000 +#define DDRSS_PHY_1192_DATA 0x00000000 +#define DDRSS_PHY_1193_DATA 0x00000000 +#define DDRSS_PHY_1194_DATA 0x00000000 +#define DDRSS_PHY_1195_DATA 0x00000000 +#define DDRSS_PHY_1196_DATA 0x00000000 +#define DDRSS_PHY_1197_DATA 0x00000000 +#define DDRSS_PHY_1198_DATA 0x00000000 +#define DDRSS_PHY_1199_DATA 0x00000000 +#define DDRSS_PHY_1200_DATA 0x00000000 +#define DDRSS_PHY_1201_DATA 0x00000000 +#define DDRSS_PHY_1202_DATA 0x00000000 +#define DDRSS_PHY_1203_DATA 0x00000000 +#define DDRSS_PHY_1204_DATA 0x00000000 +#define DDRSS_PHY_1205_DATA 0x00000000 +#define DDRSS_PHY_1206_DATA 0x00000000 +#define DDRSS_PHY_1207_DATA 0x00000000 +#define DDRSS_PHY_1208_DATA 0x00000000 +#define DDRSS_PHY_1209_DATA 0x00000000 +#define DDRSS_PHY_1210_DATA 0x00000000 +#define DDRSS_PHY_1211_DATA 0x00000000 +#define DDRSS_PHY_1212_DATA 0x00000000 +#define DDRSS_PHY_1213_DATA 0x00000000 +#define DDRSS_PHY_1214_DATA 0x00000000 +#define DDRSS_PHY_1215_DATA 0x00000000 +#define DDRSS_PHY_1216_DATA 0x00000000 +#define DDRSS_PHY_1217_DATA 0x00000000 +#define DDRSS_PHY_1218_DATA 0x00000000 +#define DDRSS_PHY_1219_DATA 0x00000000 +#define DDRSS_PHY_1220_DATA 0x00000000 +#define DDRSS_PHY_1221_DATA 0x00000000 +#define DDRSS_PHY_1222_DATA 0x00000000 +#define DDRSS_PHY_1223_DATA 0x00000000 +#define DDRSS_PHY_1224_DATA 0x00000000 +#define DDRSS_PHY_1225_DATA 0x00000000 +#define DDRSS_PHY_1226_DATA 0x00000000 +#define DDRSS_PHY_1227_DATA 0x00000000 +#define DDRSS_PHY_1228_DATA 0x00000000 +#define DDRSS_PHY_1229_DATA 0x00000000 +#define DDRSS_PHY_1230_DATA 0x00000000 +#define DDRSS_PHY_1231_DATA 0x00000000 +#define DDRSS_PHY_1232_DATA 0x00000000 +#define DDRSS_PHY_1233_DATA 0x00000000 +#define DDRSS_PHY_1234_DATA 0x00000000 +#define DDRSS_PHY_1235_DATA 0x00000000 +#define DDRSS_PHY_1236_DATA 0x00000000 +#define DDRSS_PHY_1237_DATA 0x00000000 +#define DDRSS_PHY_1238_DATA 0x00000000 +#define DDRSS_PHY_1239_DATA 0x00000000 +#define DDRSS_PHY_1240_DATA 0x00000000 +#define DDRSS_PHY_1241_DATA 0x00000000 +#define DDRSS_PHY_1242_DATA 0x00000000 +#define DDRSS_PHY_1243_DATA 0x00000000 +#define DDRSS_PHY_1244_DATA 0x00000000 +#define DDRSS_PHY_1245_DATA 0x00000000 +#define DDRSS_PHY_1246_DATA 0x00000000 +#define DDRSS_PHY_1247_DATA 0x00000000 +#define DDRSS_PHY_1248_DATA 0x00000000 +#define DDRSS_PHY_1249_DATA 0x00000000 +#define DDRSS_PHY_1250_DATA 0x00000000 +#define DDRSS_PHY_1251_DATA 0x00000000 +#define DDRSS_PHY_1252_DATA 0x00000000 +#define DDRSS_PHY_1253_DATA 0x00000000 +#define DDRSS_PHY_1254_DATA 0x00000000 +#define DDRSS_PHY_1255_DATA 0x00000000 +#define DDRSS_PHY_1256_DATA 0x00000000 +#define DDRSS_PHY_1257_DATA 0x00000000 +#define DDRSS_PHY_1258_DATA 0x00000000 +#define DDRSS_PHY_1259_DATA 0x00000000 +#define DDRSS_PHY_1260_DATA 0x00000000 +#define DDRSS_PHY_1261_DATA 0x00000000 +#define DDRSS_PHY_1262_DATA 0x00000000 +#define DDRSS_PHY_1263_DATA 0x00000000 +#define DDRSS_PHY_1264_DATA 0x00000000 +#define DDRSS_PHY_1265_DATA 0x00000000 +#define DDRSS_PHY_1266_DATA 0x00000000 +#define DDRSS_PHY_1267_DATA 0x00000000 +#define DDRSS_PHY_1268_DATA 0x00000000 +#define DDRSS_PHY_1269_DATA 0x00000000 +#define DDRSS_PHY_1270_DATA 0x00000000 +#define DDRSS_PHY_1271_DATA 0x00000000 +#define DDRSS_PHY_1272_DATA 0x00000000 +#define DDRSS_PHY_1273_DATA 0x00000000 +#define DDRSS_PHY_1274_DATA 0x00000000 +#define DDRSS_PHY_1275_DATA 0x00000000 +#define DDRSS_PHY_1276_DATA 0x00000000 +#define DDRSS_PHY_1277_DATA 0x00000000 +#define DDRSS_PHY_1278_DATA 0x00000000 +#define DDRSS_PHY_1279_DATA 0x00000000 +#define DDRSS_PHY_1280_DATA 0x00000000 +#define DDRSS_PHY_1281_DATA 0x00000100 +#define DDRSS_PHY_1282_DATA 0x00000000 +#define DDRSS_PHY_1283_DATA 0x00000000 +#define DDRSS_PHY_1284_DATA 0x00000000 +#define DDRSS_PHY_1285_DATA 0x00000000 +#define DDRSS_PHY_1286_DATA 0x00050000 +#define DDRSS_PHY_1287_DATA 0x04000100 +#define DDRSS_PHY_1288_DATA 0x00000055 +#define DDRSS_PHY_1289_DATA 0x00000000 +#define DDRSS_PHY_1290_DATA 0x00000000 +#define DDRSS_PHY_1291_DATA 0x00000000 +#define DDRSS_PHY_1292_DATA 0x00000000 +#define DDRSS_PHY_1293_DATA 0x01002000 +#define DDRSS_PHY_1294_DATA 0x00004001 +#define DDRSS_PHY_1295_DATA 0x00020028 +#define DDRSS_PHY_1296_DATA 0x00010100 +#define DDRSS_PHY_1297_DATA 0x00000001 +#define DDRSS_PHY_1298_DATA 0x00000000 +#define DDRSS_PHY_1299_DATA 0x0F0F0E06 +#define DDRSS_PHY_1300_DATA 0x00010101 +#define DDRSS_PHY_1301_DATA 0x010F0004 +#define DDRSS_PHY_1302_DATA 0x00000000 +#define DDRSS_PHY_1303_DATA 0x00000000 +#define DDRSS_PHY_1304_DATA 0x00000064 +#define DDRSS_PHY_1305_DATA 0x00000000 +#define DDRSS_PHY_1306_DATA 0x00000000 +#define DDRSS_PHY_1307_DATA 0x01020103 +#define DDRSS_PHY_1308_DATA 0x0F020102 +#define DDRSS_PHY_1309_DATA 0x03030303 +#define DDRSS_PHY_1310_DATA 0x03030303 +#define DDRSS_PHY_1311_DATA 0x00040000 +#define DDRSS_PHY_1312_DATA 0x00005201 +#define DDRSS_PHY_1313_DATA 0x00000000 +#define DDRSS_PHY_1314_DATA 0x00000000 +#define DDRSS_PHY_1315_DATA 0x00000000 +#define DDRSS_PHY_1316_DATA 0x00000000 +#define DDRSS_PHY_1317_DATA 0x00000000 +#define DDRSS_PHY_1318_DATA 0x00000000 +#define DDRSS_PHY_1319_DATA 0x07070001 +#define DDRSS_PHY_1320_DATA 0x00005400 +#define DDRSS_PHY_1321_DATA 0x000040A2 +#define DDRSS_PHY_1322_DATA 0x00024410 +#define DDRSS_PHY_1323_DATA 0x00004410 +#define DDRSS_PHY_1324_DATA 0x00004410 +#define DDRSS_PHY_1325_DATA 0x00004410 +#define DDRSS_PHY_1326_DATA 0x00004410 +#define DDRSS_PHY_1327_DATA 0x00004410 +#define DDRSS_PHY_1328_DATA 0x00004410 +#define DDRSS_PHY_1329_DATA 0x00004410 +#define DDRSS_PHY_1330_DATA 0x00004410 +#define DDRSS_PHY_1331_DATA 0x00004410 +#define DDRSS_PHY_1332_DATA 0x00000000 +#define DDRSS_PHY_1333_DATA 0x00000046 +#define DDRSS_PHY_1334_DATA 0x00000400 +#define DDRSS_PHY_1335_DATA 0x00000008 +#define DDRSS_PHY_1336_DATA 0x00000000 +#define DDRSS_PHY_1337_DATA 0x00000000 +#define DDRSS_PHY_1338_DATA 0x00000000 +#define DDRSS_PHY_1339_DATA 0x00000000 +#define DDRSS_PHY_1340_DATA 0x00000000 +#define DDRSS_PHY_1341_DATA 0x03000000 +#define DDRSS_PHY_1342_DATA 0x00000000 +#define DDRSS_PHY_1343_DATA 0x00000000 +#define DDRSS_PHY_1344_DATA 0x00000000 +#define DDRSS_PHY_1345_DATA 0x04102006 +#define DDRSS_PHY_1346_DATA 0x00041020 +#define DDRSS_PHY_1347_DATA 0x01C98C98 +#define DDRSS_PHY_1348_DATA 0x3F400000 +#define DDRSS_PHY_1349_DATA 0x3F3F1F3F +#define DDRSS_PHY_1350_DATA 0x0000001F +#define DDRSS_PHY_1351_DATA 0x00000000 +#define DDRSS_PHY_1352_DATA 0x00000000 +#define DDRSS_PHY_1353_DATA 0x00000000 +#define DDRSS_PHY_1354_DATA 0x00000001 +#define DDRSS_PHY_1355_DATA 0x00000000 +#define DDRSS_PHY_1356_DATA 0x00000000 +#define DDRSS_PHY_1357_DATA 0x00000000 +#define DDRSS_PHY_1358_DATA 0x00000000 +#define DDRSS_PHY_1359_DATA 0x76543210 +#define DDRSS_PHY_1360_DATA 0x00000098 +#define DDRSS_PHY_1361_DATA 0x00000000 +#define DDRSS_PHY_1362_DATA 0x00000000 +#define DDRSS_PHY_1363_DATA 0x00000000 +#define DDRSS_PHY_1364_DATA 0x00040700 +#define DDRSS_PHY_1365_DATA 0x00000000 +#define DDRSS_PHY_1366_DATA 0x00000000 +#define DDRSS_PHY_1367_DATA 0x00000000 +#define DDRSS_PHY_1368_DATA 0x00000002 +#define DDRSS_PHY_1369_DATA 0x00000100 +#define DDRSS_PHY_1370_DATA 0x00000000 +#define DDRSS_PHY_1371_DATA 0x0001F7C0 +#define DDRSS_PHY_1372_DATA 0x00020002 +#define DDRSS_PHY_1373_DATA 0x00000000 +#define DDRSS_PHY_1374_DATA 0x00001142 +#define DDRSS_PHY_1375_DATA 0x03020400 +#define DDRSS_PHY_1376_DATA 0x00000080 +#define DDRSS_PHY_1377_DATA 0x03900390 +#define DDRSS_PHY_1378_DATA 0x03900390 +#define DDRSS_PHY_1379_DATA 0x03900390 +#define DDRSS_PHY_1380_DATA 0x03900390 +#define DDRSS_PHY_1381_DATA 0x03900390 +#define DDRSS_PHY_1382_DATA 0x03900390 +#define DDRSS_PHY_1383_DATA 0x00000300 +#define DDRSS_PHY_1384_DATA 0x00000300 +#define DDRSS_PHY_1385_DATA 0x00000300 +#define DDRSS_PHY_1386_DATA 0x00000300 +#define DDRSS_PHY_1387_DATA 0x31823FC7 +#define DDRSS_PHY_1388_DATA 0x00000000 +#define DDRSS_PHY_1389_DATA 0x0C000D3F +#define DDRSS_PHY_1390_DATA 0x30000D3F +#define DDRSS_PHY_1391_DATA 0x300D3F11 +#define DDRSS_PHY_1392_DATA 0x01990000 +#define DDRSS_PHY_1393_DATA 0x000D3FCC +#define DDRSS_PHY_1394_DATA 0x00000C11 +#define DDRSS_PHY_1395_DATA 0x300D3F11 +#define DDRSS_PHY_1396_DATA 0x01990000 +#define DDRSS_PHY_1397_DATA 0x300C3F11 +#define DDRSS_PHY_1398_DATA 0x01990000 +#define DDRSS_PHY_1399_DATA 0x300C3F11 +#define DDRSS_PHY_1400_DATA 0x01990000 +#define DDRSS_PHY_1401_DATA 0x300D3F11 +#define DDRSS_PHY_1402_DATA 0x01990000 +#define DDRSS_PHY_1403_DATA 0x300D3F11 +#define DDRSS_PHY_1404_DATA 0x01990000 +#define DDRSS_PHY_1405_DATA 0x20040004
Add am62x_evm_r5_defconfig for R5 SPL and am62x_evm_a53_defconfig for A53 SPL and U-Boot support.
To keep the changes to minimum. Only UART And SD boot related configs are included. This should serve as good starting point for new board bringup with AM62x.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- board/ti/am62x/MAINTAINERS | 8 +++ configs/am62x_evm_a53_defconfig | 71 +++++++++++++++++++++ configs/am62x_evm_r5_defconfig | 91 +++++++++++++++++++++++++++ include/configs/am62x_evm.h | 106 ++++++++++++++++++++++++++++++++ 4 files changed, 276 insertions(+) create mode 100644 board/ti/am62x/MAINTAINERS create mode 100644 configs/am62x_evm_a53_defconfig create mode 100644 configs/am62x_evm_r5_defconfig create mode 100644 include/configs/am62x_evm.h
diff --git a/board/ti/am62x/MAINTAINERS b/board/ti/am62x/MAINTAINERS new file mode 100644 index 0000000000..105e741995 --- /dev/null +++ b/board/ti/am62x/MAINTAINERS @@ -0,0 +1,8 @@ +AM62x BOARD +M: Dave Gerlach d-gerlach@ti.com +M: Tom Rini trini@konsulko.com +S: Maintained +F: board/ti/am62x/ +F: include/configs/am62x_evm.h +F: configs/am62x_evm_r5_defconfig +F: configs/am62x_evm_a53_defconfig diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig new file mode 100644 index 0000000000..fd18fbd890 --- /dev/null +++ b/configs/am62x_evm_a53_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SOC_K3_AM625=y +CONFIG_K3_ATF_LOAD_ADDR=0x9e780000 +CONFIG_TARGET_AM625_A53_EVM=y +CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-sk" +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_CMD_MMC=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_TI_SCI=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_DM_RESET=y +CONFIG_RESET_TI_SCI=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_TI_SCI=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/am62x_evm_r5_defconfig b/configs/am62x_evm_r5_defconfig new file mode 100644 index 0000000000..0e1b2ef13e --- /dev/null +++ b/configs/am62x_evm_r5_defconfig @@ -0,0 +1,91 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x9000 +CONFIG_SOC_K3_AM625=y +CONFIG_TARGET_AM625_R5_EVM=y +CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y +CONFIG_SPL_TEXT_BASE=0x43c00000 +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_SIZE_LIMIT=0x40000 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-r5-sk" +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_EARLY_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_REMOTEPROC=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_REMOTEPROC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_SPL_CLK_CCF=y +CONFIG_SPL_CLK_K3=y +CONFIG_SPL_CLK_K3_PLL=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DA8XX_GPIO=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_GENERIC is not set +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_DM_RESET=y +CONFIG_RESET_TI_SCI=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_LIB_RATIONAL=y +CONFIG_SPL_LIB_RATIONAL=y diff --git a/include/configs/am62x_evm.h b/include/configs/am62x_evm.h new file mode 100644 index 0000000000..fec6fd303e --- /dev/null +++ b/include/configs/am62x_evm.h @@ -0,0 +1,106 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration header file for K3 AM625 SoC family + * + * Copyright (C) 2020-2022 Texas Instruments Incorporated - https://www.ti.com/ + * Suman Anna s-anna@ti.com + */ + +#ifndef __CONFIG_AM625_EVM_H +#define __CONFIG_AM625_EVM_H + +#include <linux/sizes.h> +#include <config_distro_bootcmd.h> +#include <environment/ti/mmc.h> + +/* DDR Configuration */ +#define CONFIG_SYS_SDRAM_BASE1 0x880000000 + +#ifdef CONFIG_SYS_K3_SPL_ATF +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "tispl.bin" +#endif + +#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE +#if defined(CONFIG_TARGET_AM625_A53_EVM) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + SZ_4M) +#else +/* + * Maximum size in memory allocated to the SPL BSS. Keep it as tight as + * possible (to allow the build to go through), as this directly affects + * our memory footprint. The less we use for BSS the more we have available + * for everything else. + */ +#define CONFIG_SPL_BSS_MAX_SIZE 0x5000 +/* + * Link BSS to be within SPL in a dedicated region located near the top of + * the MCU SRAM, this way making it available also before relocation. Note + * that we are not using the actual top of the MCU SRAM as there is a memory + * location allocated for Device Manager data and some memory filled in by + * the boot ROM that we want to read out without any interference from the + * C context. + */ +#define CONFIG_SPL_BSS_START_ADDR (0x43c3c800 -\ + CONFIG_SPL_BSS_MAX_SIZE) +/* Set the stack right below the SPL BSS section */ +#define CONFIG_SYS_INIT_SP_ADDR 0x7000ffff +/* Configure R5 SPL post-relocation malloc pool in DDR */ +#define CONFIG_SYS_SPL_MALLOC_START 0x84000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_16M +#endif + +#define PARTS_DEFAULT \ + /* Linux partitions */ \ + "name=rootfs,start=0,size=-,uuid=${uuid_gpt_rootfs}\0" + +/* U-Boot general configuration */ +#define EXTRA_ENV_AM625_BOARD_SETTINGS \ + "default_device_tree=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "findfdt=" \ + "setenv name_fdt ${default_device_tree};" \ + "setenv fdtfile ${name_fdt}\0" \ + "name_kern=Image\0" \ + "console=ttyS2,115200n8\0" \ + "args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 " \ + "${mtdparts}\0" \ + "run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}\0" + +/* U-Boot MMC-specific configuration */ +#define EXTRA_ENV_AM625_BOARD_SETTINGS_MMC \ + "boot=mmc\0" \ + "mmcdev=1\0" \ + "bootpart=1:2\0" \ + "bootdir=/boot\0" \ + "rd_spec=-\0" \ + "init_mmc=run args_all args_mmc\0" \ + "get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}\0" \ + "get_overlay_mmc=" \ + "fdt address ${fdtaddr};" \ + "fdt resize 0x100000;" \ + "for overlay in $name_overlays;" \ + "do;" \ + "load mmc ${bootpart} ${dtboaddr} ${bootdir}/${overlay} && " \ + "fdt apply ${dtboaddr};" \ + "done;\0" \ + "get_kern_mmc=load mmc ${bootpart} ${loadaddr} " \ + "${bootdir}/${name_kern}\0" \ + "get_fit_mmc=load mmc ${bootpart} ${addr_fit} " \ + "${bootdir}/${name_fit}\0" \ + "partitions=" PARTS_DEFAULT + +/* Incorporate settings into the U-Boot environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + DEFAULT_LINUX_BOOT_ENV \ + DEFAULT_MMC_TI_ARGS \ + EXTRA_ENV_AM625_BOARD_SETTINGS \ + EXTRA_ENV_AM625_BOARD_SETTINGS_MMC + +/* Now for the remaining common defines */ +#include <configs/ti_armv7_common.h> + +/* MMC ENV related defines */ +#ifdef CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 1 +#endif + +#endif /* __CONFIG_AM625_EVM_H */
Add info of boot flow and build steps for AM62x SK.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- doc/board/ti/am62x_sk.rst | 231 ++++++++++++++++++++++++++++++++++++++ doc/board/ti/index.rst | 1 + 2 files changed, 232 insertions(+) create mode 100644 doc/board/ti/am62x_sk.rst
diff --git a/doc/board/ti/am62x_sk.rst b/doc/board/ti/am62x_sk.rst new file mode 100644 index 0000000000..4e68c2018a --- /dev/null +++ b/doc/board/ti/am62x_sk.rst @@ -0,0 +1,231 @@ +.. SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +.. sectionauthor:: Vignesh Raghavendra vigneshr@ti.com + +Texas Instruments AM62 Platforms +================================ + +Introduction: +------------- +The AM62 SoC family is the follow on AM335x built on the K3 Multicore +SoC architecture platform, providing ultra-low-power modes, dual +display, multi-sensor edge compute, security and other BOM-saving +integrations. The AM62 SoC targets a broad market to enable +applications such as Industrial HMI, PLC/CNC/Robot control, Medical +Equipment, Building Automation, Appliances and more. + +Some highlights of this SoC are: + +* Quad-Cortex-A53s (running up to 1.4GHz) in a single cluster. + Pin-to-pin compatible options for single and quad core are available. +* Cortex-M4F for general-purpose or safety usage. +* Dual display support, providing 24-bit RBG parallel interface and + OLDI/LVDS-4 Lane x2, up to 200MHz pixel clock support for 2K display + resolution. +* Selectable GPU support, up to 8GFLOPS, providing better user experience + in 3D graphic display case and Android. +* PRU(Programmable Realtime Unit) support for customized programmable + interfaces/IOs. +* Integrated Giga-bit Ethernet switch supporting up to a total of two + external ports (TSN capable). +* 9xUARTs, 5xSPI, 6xI2C, 2xUSB2, 3xCAN-FD, 3x eMMC and SD, GPMC for + NAND/FPGA connection, OSPI memory controller, 3xMcASP for audio, + 1x CSI-RX-4L for Camera, eCAP/eQEP, ePWM, among other peripherals. +* Dedicated Centralized System Controller for Security, Power, and + Resource Management. +* Multiple low power modes support, ex: Deep sleep, Standby, MCU-only, + enabling battery powered system design. + +More details can be found in the Technical Reference Manual: +https://www.ti.com/lit/pdf/spruiv7 + +Boot Flow: +---------- +Below is the pictorial representation of boot flow: + +.. code-block:: text + + +------------------------------------------------------------------------+ + | TIFS | Main R5 | A53 | + +------------------------------------------------------------------------+ + | +--------+ | | | + | | Reset | | | | + | +--------+ | | | + | : | | | + | +--------+ | +-----------+ | | + | | *ROM* |----------|-->| Reset rls | | | + | +--------+ | +-----------+ | | + | | | | : | | + | | ROM | | : | | + | |services| | : | | + | | | | +-------------+ | | + | | | | | *R5 ROM* | | | + | | | | +-------------+ | | + | | |<---------|---|Load and auth| | | + | | | | | tiboot3.bin | | | + | +--------+ | +-------------+ | | + | | |<---------|---| Load sysfw | | | + | | | | | part to TIFS| | | + | | | | | core | | | + | | | | +-------------+ | | + | | | | : | | + | | | | : | | + | | | | : | | + | | | | +-------------+ | | + | | | | | *R5 SPL* | | | + | | | | +-------------+ | | + | | | | | DDR | | | + | | | | | config | | | + | | | | +-------------+ | | + | | | | | Load | | | + | | | | | tispl.bin | | | + | | | | +-------------+ | | + | | | | | Load R5 | | | + | | | | | firmware | | | + | | | | +-------------+ | | + | | |<---------|---| Start A53 | | | + | | | | | and jump to | | | + | | | | | DM fw image | | | + | | | | +-------------+ | | + | | | | | +-----------+ | + | | |----------|-----------------------|---->| Reset rls | | + | | | | | +-----------+ | + | | TIFS | | | : | + | |Services| | | +-----------+ | + | | |<---------|-----------------------|---->|*ATF/OPTEE*| | + | | | | | +-----------+ | + | | | | | : | + | | | | | +-----------+ | + | | |<---------|-----------------------|---->| *A53 SPL* | | + | | | | | +-----------+ | + | | | | | | Load | | + | | | | | | u-boot.img| | + | | | | | +-----------+ | + | | | | | : | + | | | | | +-----------+ | + | | |<---------|-----------------------|---->| *U-Boot* | | + | | | | | +-----------+ | + | | | | | | prompt | | + | | |----------|-----------------------|-----+-----------+-----| + | +--------+ | | | + | | | | + +------------------------------------------------------------------------+ + +- Here TIFS acts as master and provides all the critical services. R5/A53 + requests TIFS to get these services done as shown in the above diagram. + +Sources: +-------- +1. SYSFW: + Tree: git://git.ti.com/k3-image-gen/k3-image-gen.git + Branch: master + +2. ATF: + Tree: https://github.com/ARM-software/arm-trusted-firmware.git + Branch: master + +3. OPTEE: + Tree: https://github.com/OP-TEE/optee_os.git + Branch: master + +4. U-Boot: + Tree: https://source.denx.de/u-boot/u-boot + Branch: master + +5. TI Linux Firmware: + Tree: git://git.ti.com/processor-firmware/ti-linux-firmware.git + Branch: ti-linux-firmware + +Build procedure: +---------------- +1. ATF: + +.. code-block:: text + + $ make CROSS_COMPILE=aarch64-none-linux-gnu- ARCH=aarch64 PLAT=k3 TARGET_BOARD=lite SPD=opteed + +2. OPTEE: + +.. code-block:: text + + $ make PLATFORM=k3 CFG_ARM64_core=y CROSS_COMPILE=arm-none-linux-gnueabihf- CROSS_COMPILE64=aarch64-none-linux-gnu- + +3. U-Boot: + +* 3.1 R5: + +.. code-block:: text + + $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- am62x_evm_r5_defconfig O=/tmp/r5 + $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- O=/tmp/r5 + $ cd <k3-image-gen> + $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- SOC=am62x SBL=/tmp/r5/spl/u-boot-spl.bin SYSFW_PATH=<path to ti-linux-firmware>/ti-sysfw/ti-fs-firmware-am62x-gp.bin + +Use the tiboot3.bin generated from last command + +* 3.2 A53: + +.. code-block:: text + + $ make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- am62x_evm_a53_defconfig O=/tmp/a53 + $ make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- ATF=<path to ATF dir>/build/k3/lite/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<path to ti-linux-firmware>/ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f O=/tmp/a53 + +Target Images +-------------- +Copy the below images to an SD card and boot: + - tiboot3.bin from step 3.1 + - tispl.bin, u-boot.img from 3.2 + +Image formats: +-------------- + +- tiboot3.bin: + +.. code-block:: text + + +-----------------------+ + | X.509 | + | Certificate | + | +-------------------+ | + | | | | + | | R5 | | + | | u-boot-spl.bin | | + | | | | + | +-------------------+ | + | | | | + | |TIFS with board cfg| | + | | | | + | +-------------------+ | + | | | | + | | | | + | | FIT header | | + | | +---------------+ | | + | | | | | | + | | | DTB 1...N | | | + | | +---------------+ | | + | +-------------------+ | + +-----------------------+ + +- tispl.bin + +.. code-block:: text + + +-----------------------+ + | | + | FIT HEADER | + | +-------------------+ | + | | | | + | | A53 ATF | | + | +-------------------+ | + | | | | + | | A53 OPTEE | | + | +-------------------+ | + | | | | + | | R5 DM FW | | + | +-------------------+ | + | | | | + | | A53 SPL | | + | +-------------------+ | + | | | | + | | SPL DTB 1...N | | + | +-------------------+ | + +-----------------------+ diff --git a/doc/board/ti/index.rst b/doc/board/ti/index.rst index 014a097178..250d9242e8 100644 --- a/doc/board/ti/index.rst +++ b/doc/board/ti/index.rst @@ -8,3 +8,4 @@ Texas Instruments
am335x_evm j721e_evm + am62x_sk
Hi Vignesh!
On May 25, 2022 thus sayeth Vignesh Raghavendra:
Reviewed-by: Bryan Brattlof bb@ti.com
Looks good to me!
~Bryan
Bryan Brattlof
Jaehoon Chung
Vignesh Raghavendra
