[U-Boot] [PATCH] serial: zynq: Use global baudrate instead of hardcoded one
This change enables to change baudrate on command line.
drivers/serial/serial_zynq.c | 18 +----------------- 1 file changed, 1 insertion(+), 17 deletions(-)
diff --git a/drivers/serial/serial_zynq.c b/drivers/serial/serial_zynq.c index 1ff27d5f4889..74c449663bc7 100644 --- a/drivers/serial/serial_zynq.c +++ b/drivers/serial/serial_zynq.c @@ -42,29 +42,13 @@ static struct uart_zynq *uart_zynq_ports[2] = { [1] = (struct uart_zynq *)ZYNQ_SERIAL_BASEADDR1, };
-#if !defined(CONFIG_ZYNQ_SERIAL_BAUDRATE0) -# define CONFIG_ZYNQ_SERIAL_BAUDRATE0 CONFIG_BAUDRATE -#endif -#if !defined(CONFIG_ZYNQ_SERIAL_BAUDRATE1) -# define CONFIG_ZYNQ_SERIAL_BAUDRATE1 CONFIG_BAUDRATE -#endif - -struct uart_zynq_params { - u32 baudrate; -}; - -static struct uart_zynq_params uart_zynq_ports_param[2] = { - [0].baudrate = CONFIG_ZYNQ_SERIAL_BAUDRATE0, - [1].baudrate = CONFIG_ZYNQ_SERIAL_BAUDRATE1, -}; - /* Set up the baud rate in gd struct */ static void uart_zynq_serial_setbrg(const int port) { /* Calculation results. */ unsigned int calc_bauderror, bdiv, bgen; unsigned long calc_baud = 0; - unsigned long baud = uart_zynq_ports_param[port].baudrate; + unsigned long baud = gd->baudrate; unsigned long clock = get_uart_clk(port); struct uart_zynq *regs = uart_zynq_ports[port];
-- 1.8.2.3
Michal Simek
