[U-Boot] [PATCH v6 00/10] spl: dm: Make it possible for the SPL to pick its own DTB from a FIT
Following the RFC, here is the series implementing the mechanism in a cleaner way. The idea is that the SPL may take advantage of selecting its DTB from a pool of available DTBs. To do that several DTBs are embedded in a compressed FIT image appended at the end of the SPL. The patch is done in such way that this mechanism can easily be extended to other ways of loading the DTBs.
Here are some numbers: +----------+------------+-----------+------------+ | size | size delta | SPL boot | boot time | | (bytes) | (bytes) | time (s) | delta (s) | +---------------------------+----------+------------+-----------+------------+ | 1 DTB | | | | | +---------------------------+----------+------------+-----------+------------+ | reference | 125305 | 0 | 1.389 | 0 | | LZO (dynamic allocation) | 125391 | 86 | 1.381 | -0.008 | +---------------------------+----------+------------+-----------+------------+ | 4 DTBs (DRA7, DRA71, | | | | | | DRA72, DRA72 revC) | | | | | +---------------------------+----------+------------+-----------+------------+ | LZO (dynamic allocation) | 125991 | 686 | 1.39 | 0.001 | | LZO (user defined area) | 125927 | 622 | 1.403 | 0.014 | | GZIP (user defined area) | 133880 | 8575 | 1.421 | 0.032 | | No compression (in place) | 137472 | 12167 | 1.412 | 0.023 | +---------------------------+----------+------------+-----------+------------+
changes since v5: - rebased on top of latest u-boot/master: updated patch #7 as support for SPL_GZIP has been recently added to u-boot/master. - Fixed the wrong ordering of includes in lib/fdtdec.c - changed Kconfig messages to start with an an upper-case
changes since v4: - Updated the documentation. Hopefully it's more intelligible. - renamed SPL_MULTI_DTB_FIT_GZ in SPL_MULTI_DTB_FIT_GZIP - Added a patch to sort the included headers in lib/fdtdec.c - reduced the level of #ifdeffing of the patch
changes since v3: - Added reviewed-by tags - Fixed nits and spelling mistakes reported by Simon G. - updated the help in Kconfig to take in account commit f1896c ("spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LEN")
changes since v2: - rebased on u-boot/master - improved help in Kconfig for the compression options in SPL - improved commit message for patch #1 - Added some comments to describe locate_dtb_in_fit() and fit_find_config_node() - Added a description of the mecanism in a README
changes since v1: - improved help in Kconfig for the SPL_MULTI_DTB_FIT option - Added "reviewed-by" tags
changes since RFC: - split the RFC patch in several patches. - leverage work from Cooper Jr., Franklin (CONFIG_FIT_EMBED) as a big part of the code is similar. Rename CONFIG_FIT_EMBED as CONFIG_MULTI_DTB_FIT to prevent confusion with CONFIG_OF_EMBED. - use the default configuration if no match is provided by board_fit_config_name_match(). note that this is generic not just for this feature. - provide an option to not use dynamic memory allocation. - added a patch related to board detection on omap that's required to take advantage of this feature.
Jean-Jacques Hiblot (10): dts: renamed FIT_EMBED to MULTI_DTB_FIT and moved it to the dts Kconfig fit: use 'const' for the input of fdt_offset() and locate_dtb_in_fit() fit: fixed bug in locate_dtb_in_fit() fit: If no matching config is found in fit_find_config_node(), use the default one lzo: add a function to check the validity of the header gzip: add a function to parse the header lib: allow building lzo for the SPL fdtdec: sort include files spl: dm: Make it possible for the SPL to pick its own DTB from a FIT omap: detect board before spl_early_init()
Makefile | 2 +- arch/arm/mach-omap2/hwinit-common.c | 4 +- board/ti/ks2_evm/board_k2e.c | 2 +- board/ti/ks2_evm/board_k2g.c | 2 +- board/ti/ks2_evm/board_k2hk.c | 2 +- board/ti/ks2_evm/board_k2l.c | 2 +- common/Kconfig | 16 ------ common/Makefile | 2 +- common/boot_fit.c | 6 +-- common/common_fit.c | 20 +++++++ configs/k2e_evm_defconfig | 2 +- configs/k2g_evm_defconfig | 2 +- configs/k2hk_evm_defconfig | 2 +- configs/k2l_evm_defconfig | 2 +- doc/README.multi-dtb-fit | 65 +++++++++++++++++++++++ dts/Kconfig | 103 +++++++++++++++++++++++++++++++++++- include/boot_fit.h | 9 +++- include/common.h | 1 + include/image.h | 13 +++++ include/linux/lzo.h | 3 ++ lib/Kconfig | 5 ++ lib/Makefile | 3 +- lib/fdtdec.c | 98 +++++++++++++++++++++++++++++----- lib/gunzip.c | 15 ++++-- lib/lzo/lzo1x_decompress.c | 21 ++++++-- scripts/Makefile.spl | 35 +++++++++++- 26 files changed, 381 insertions(+), 56 deletions(-) create mode 100644 doc/README.multi-dtb-fit
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing multiple DTBs. Also move the option to the Kconfig dedicated to the DTS options and create a README for this feature.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- Makefile | 2 +- board/ti/ks2_evm/board_k2e.c | 2 +- board/ti/ks2_evm/board_k2g.c | 2 +- board/ti/ks2_evm/board_k2hk.c | 2 +- board/ti/ks2_evm/board_k2l.c | 2 +- common/Kconfig | 16 ---------------- common/Makefile | 2 +- configs/k2e_evm_defconfig | 2 +- configs/k2g_evm_defconfig | 2 +- configs/k2hk_evm_defconfig | 2 +- configs/k2l_evm_defconfig | 2 +- doc/README.multi-dtb-fit | 15 +++++++++++++++ dts/Kconfig | 20 +++++++++++++++++++- lib/fdtdec.c | 2 +- 14 files changed, 45 insertions(+), 28 deletions(-) create mode 100644 doc/README.multi-dtb-fit
diff --git a/Makefile b/Makefile index 8250b34..a099d98 100644 --- a/Makefile +++ b/Makefile @@ -878,7 +878,7 @@ dts/dt.dtb: checkdtc u-boot quiet_cmd_copy = COPY $@ cmd_copy = cp $< $@
-ifeq ($(CONFIG_FIT_EMBED),y) +ifeq ($(CONFIG_MULTI_DTB_FIT),y)
fit-dtb.blob: dts/dt.dtb FORCE $(call if_changed,mkimage) diff --git a/board/ti/ks2_evm/board_k2e.c b/board/ti/ks2_evm/board_k2e.c index 266a66b..6c77d91 100644 --- a/board/ti/ks2_evm/board_k2e.c +++ b/board/ti/ks2_evm/board_k2e.c @@ -166,7 +166,7 @@ int get_num_eth_ports(void) } #endif
-#if defined(CONFIG_FIT_EMBED) +#if defined(CONFIG_MULTI_DTB_FIT) int board_fit_config_name_match(const char *name) { if (!strcmp(name, "keystone-k2e-evm")) diff --git a/board/ti/ks2_evm/board_k2g.c b/board/ti/ks2_evm/board_k2g.c index f1c4ddc..01328f1 100644 --- a/board/ti/ks2_evm/board_k2g.c +++ b/board/ti/ks2_evm/board_k2g.c @@ -217,7 +217,7 @@ int board_mmc_init(bd_t *bis) } #endif
-#if defined(CONFIG_FIT_EMBED) +#if defined(CONFIG_MULTI_DTB_FIT) int board_fit_config_name_match(const char *name) { bool eeprom_read = board_ti_was_eeprom_read(); diff --git a/board/ti/ks2_evm/board_k2hk.c b/board/ti/ks2_evm/board_k2hk.c index c733099..e99e635 100644 --- a/board/ti/ks2_evm/board_k2hk.c +++ b/board/ti/ks2_evm/board_k2hk.c @@ -150,7 +150,7 @@ int board_early_init_f(void) } #endif
-#if defined(CONFIG_FIT_EMBED) +#if defined(CONFIG_MULTI_DTB_FIT) int board_fit_config_name_match(const char *name) { if (!strcmp(name, "keystone-k2hk-evm")) diff --git a/board/ti/ks2_evm/board_k2l.c b/board/ti/ks2_evm/board_k2l.c index 166367b..c65f331 100644 --- a/board/ti/ks2_evm/board_k2l.c +++ b/board/ti/ks2_evm/board_k2l.c @@ -138,7 +138,7 @@ int board_early_init_f(void) } #endif
-#if defined(CONFIG_FIT_EMBED) +#if defined(CONFIG_MULTI_DTB_FIT) int board_fit_config_name_match(const char *name) { if (!strcmp(name, "keystone-k2l-evm")) diff --git a/common/Kconfig b/common/Kconfig index 4d8cae9..972b12b 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -384,22 +384,6 @@ config SYS_STDIO_DEREGISTER
endmenu
-config DTB_RESELECT - bool "Support swapping dtbs at a later point in boot" - depends on FIT_EMBED - help - It is possible during initial boot you may need to use a generic - dtb until you can fully determine the board your running on. This - config allows boards to implement a function at a later point - during boot to switch to the "correct" dtb. - -config FIT_EMBED - bool "Support a FIT image embedded in the U-boot image" - help - This option provides hooks to allow U-boot to parse an - appended FIT image and enable board specific code to then select - the correct DTB to be used. - config DEFAULT_FDT_FILE string "Default fdt file" help diff --git a/common/Makefile b/common/Makefile index 1b56cf9..c3d8d3f 100644 --- a/common/Makefile +++ b/common/Makefile @@ -103,7 +103,7 @@ obj-y += image.o obj-$(CONFIG_ANDROID_BOOT_IMAGE) += image-android.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += image-fdt.o obj-$(CONFIG_$(SPL_TPL_)FIT) += image-fit.o -obj-$(CONFIG_FIT_EMBED) += boot_fit.o common_fit.o +obj-$(CONFIG_$(SPL_)MULTI_DTB_FIT) += boot_fit.o common_fit.o obj-$(CONFIG_$(SPL_TPL_)FIT_SIGNATURE) += image-sig.o obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index fed6add..b6a5282 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DTB_RESELECT=y -CONFIG_FIT_EMBED=y +CONFIG_MULTI_DTB_FIT=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 2b29bf4..9c8b66d 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2g-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DTB_RESELECT=y -CONFIG_FIT_EMBED=y +CONFIG_MULTI_DTB_FIT=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 80546ec..bfb95ab 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DTB_RESELECT=y -CONFIG_FIT_EMBED=y +CONFIG_MULTI_DTB_FIT=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 732c9d2..7ab0d47 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DTB_RESELECT=y -CONFIG_FIT_EMBED=y +CONFIG_MULTI_DTB_FIT=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y diff --git a/doc/README.multi-dtb-fit b/doc/README.multi-dtb-fit new file mode 100644 index 0000000..0d4f068 --- /dev/null +++ b/doc/README.multi-dtb-fit @@ -0,0 +1,15 @@ +MULTI DTB FIT + +The purpose of this feature is to enable u-boot to select its DTB from a FIT +appended at the end of the binary. + +Usually the DTB is selected by the SPL and passed down to U-Boot. But some +platforms don't use the SPL. In this case MULTI_DTB_FIT can used to provide +U-Boot with a choice of DTBs. +The relevant DTBs are packed into a FIT (list provided by CONFIG__OF_LIST). The +FIT is automatically generated at the end of the compilation and appended to +u-boot.bin so that U-Boot can locate it and select the correct DTB from inside +the FIT. +The selection is done using board_fit_config_name_match() (same as what the SPL +uses to select the DTB for U-Boot). The selection happens during fdtdec_setup() +which is called during before relocation by board_init_f(). diff --git a/dts/Kconfig b/dts/Kconfig index b4b7ddc..28a64d4 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -98,7 +98,7 @@ config DEFAULT_DEVICE_TREE
config OF_LIST string "List of device tree files to include for DT control" - depends on SPL_LOAD_FIT || FIT_EMBED + depends on SPL_LOAD_FIT || MULTI_DTB_FIT default DEFAULT_DEVICE_TREE help This option specifies a list of device tree files to use for DT @@ -108,6 +108,24 @@ config OF_LIST device tree files (without the directory or .dtb suffix) separated by <space>.
+ +config DTB_RESELECT + bool "Support swapping dtbs at a later point in boot" + depends on MULTI_DTB_FIT + help + It is possible during initial boot you may need to use a generic + dtb until you can fully determine the board your running on. This + config allows boards to implement a function at a later point + during boot to switch to the "correct" dtb. + +config MULTI_DTB_FIT + bool "Support embedding several DTBs in a FIT image for u-boot" + help + This option provides hooks to allow U-boot to parse an + appended FIT image and enable board specific code to then select + the correct DTB to be used. Use this if you need to support + multiple DTBs but don't use the SPL. + config OF_SPL_REMOVE_PROPS string "List of device tree properties to drop for SPL" depends on SPL_OF_CONTROL diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 107a892..630e040 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1217,7 +1217,7 @@ int fdtdec_setup(void) else gd->fdt_blob = (ulong *)&__bss_end;
-# elif defined CONFIG_FIT_EMBED +# elif defined CONFIG_MULTI_DTB_FIT gd->fdt_blob = locate_dtb_in_fit(&_end);
if (gd->fdt_blob == NULL || gd->fdt_blob <= ((void *)&_end)) {
Those 2 functions don't modify their input, we can mark it const. This prevents compilation warnings when they are provided const input.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- common/boot_fit.c | 4 ++-- include/boot_fit.h | 9 +++++++-- 2 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/common/boot_fit.c b/common/boot_fit.c index 0a72315..ce42931 100644 --- a/common/boot_fit.c +++ b/common/boot_fit.c @@ -13,7 +13,7 @@ #include <image.h> #include <libfdt.h>
-int fdt_offset(void *fit) +static int fdt_offset(const void *fit) { int images, node, fdt_len, fdt_node, fdt_offset; const char *fdt_name; @@ -55,7 +55,7 @@ int fdt_offset(void *fit) return fdt_offset; }
-void *locate_dtb_in_fit(void *fit) +void *locate_dtb_in_fit(const void *fit) { struct image_header *header; int size; diff --git a/include/boot_fit.h b/include/boot_fit.h index b7d2462..e16ae5b 100644 --- a/include/boot_fit.h +++ b/include/boot_fit.h @@ -5,5 +5,10 @@ * SPDX-License-Identifier: GPL-2.0+ */
-int fdt_offset(void *fit); -void *locate_dtb_in_fit(void *fit); +/** + * locate_dtb_in_fit - Find a DTB matching the board in a FIT image + * @fit: pointer to the FIT image + * + * @return a pointer to a matching DTB blob if found, NULL otherwise + */ +void *locate_dtb_in_fit(const void *fit);
If the dtb is the first data of the FIT, the its offset is 0x0. Change the test to '<' instead of '<='
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- common/boot_fit.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/boot_fit.c b/common/boot_fit.c index ce42931..add65c4 100644 --- a/common/boot_fit.c +++ b/common/boot_fit.c @@ -73,7 +73,7 @@ void *locate_dtb_in_fit(const void *fit)
ret = fdt_offset(fit);
- if (ret <= 0) + if (ret < 0) return NULL; else return (void *)fit+size+ret;
If board_fit_config_name_match() doesn't match any configuration node, then use the default one (if provided).
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- common/common_fit.c | 20 ++++++++++++++++++++ include/image.h | 13 +++++++++++++ 2 files changed, 33 insertions(+)
diff --git a/common/common_fit.c b/common/common_fit.c index 5f5f3f9..85b33d8 100644 --- a/common/common_fit.c +++ b/common/common_fit.c @@ -32,6 +32,9 @@ int fit_find_config_node(const void *fdt) { const char *name; int conf, node, len; + const char *dflt_conf_name; + const char *dflt_conf_desc = NULL; + int dflt_conf_node = -ENOENT;
conf = fdt_path_offset(fdt, FIT_CONFS_PATH); if (conf < 0) { @@ -39,6 +42,9 @@ int fit_find_config_node(const void *fdt) conf); return -EINVAL; } + + dflt_conf_name = fdt_getprop(fdt, conf, "default", &len); + for (node = fdt_first_subnode(fdt, conf); node >= 0; node = fdt_next_subnode(fdt, node)) { @@ -50,6 +56,15 @@ int fit_find_config_node(const void *fdt) #endif return -EINVAL; } + + if (dflt_conf_name) { + const char *node_name = fdt_get_name(fdt, node, NULL); + if (strcmp(dflt_conf_name, node_name) == 0) { + dflt_conf_node = node; + dflt_conf_desc = name; + } + } + if (board_fit_config_name_match(name)) continue;
@@ -58,5 +73,10 @@ int fit_find_config_node(const void *fdt) return node; }
+ if (dflt_conf_node != -ENOENT) { + debug("Selecting default config '%s'", dflt_conf_desc); + return dflt_conf_node; + } + return -ENOENT; } diff --git a/include/image.h b/include/image.h index 339f79c..820f010 100644 --- a/include/image.h +++ b/include/image.h @@ -1274,6 +1274,19 @@ void board_fit_image_post_process(void **p_image, size_t *p_size); #define FDT_ERROR ((ulong)(-1))
ulong fdt_getprop_u32(const void *fdt, int node, const char *prop); + +/** + * fit_find_config_node() - Find the node for the best DTB in a FIT image + * + * A FIT image contains one or more DTBs. This function parses the + * configurations described in the FIT images and returns the node of + * the first matching DTB. To check if a DTB matches a board, this function + * calls board_fit_config_name_match(). If no matching DTB is found, it returns + * the node described by the default configuration if it exists. + * + * @fdt: pointer to flat device tree + * @return the node if found, -ve otherwise + */ int fit_find_config_node(const void *fdt);
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- include/linux/lzo.h | 3 +++ lib/lzo/lzo1x_decompress.c | 21 +++++++++++++++++---- 2 files changed, 20 insertions(+), 4 deletions(-)
diff --git a/include/linux/lzo.h b/include/linux/lzo.h index 88687fa..8981d04 100644 --- a/include/linux/lzo.h +++ b/include/linux/lzo.h @@ -31,6 +31,9 @@ int lzo1x_decompress_safe(const unsigned char *src, size_t src_len, int lzop_decompress(const unsigned char *src, size_t src_len, unsigned char *dst, size_t *dst_len);
+/* check if the header is valid (based on magic numbers) */ +bool lzop_is_valid_header(const unsigned char *src); + /* * Return values (< 0 = Error) */ diff --git a/lib/lzo/lzo1x_decompress.c b/lib/lzo/lzo1x_decompress.c index ccc90b8..65fef0b 100644 --- a/lib/lzo/lzo1x_decompress.c +++ b/lib/lzo/lzo1x_decompress.c @@ -30,16 +30,29 @@ static const unsigned char lzop_magic[] = {
#define HEADER_HAS_FILTER 0x00000800L
-static inline const unsigned char *parse_header(const unsigned char *src) + +bool lzop_is_valid_header(const unsigned char *src) { - u16 version; int i; - /* read magic: 9 first bytes */ for (i = 0; i < ARRAY_SIZE(lzop_magic); i++) { if (*src++ != lzop_magic[i]) - return NULL; + return false; } + return true; +} + +static inline const unsigned char *parse_header(const unsigned char *src) +{ + u16 version; + int i; + + if (!lzop_is_valid_header(src)) + return NULL; + + /* skip header */ + src += 9; + /* get version (2bytes), skip library version (2), * 'need to be extracted' version (2) and * method (1) */
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- include/common.h | 1 + lib/gunzip.c | 15 ++++++++++++--- 2 files changed, 13 insertions(+), 3 deletions(-)
diff --git a/include/common.h b/include/common.h index aaed131..36c1ac8 100644 --- a/include/common.h +++ b/include/common.h @@ -624,6 +624,7 @@ ulong usec2ticks (unsigned long usec); ulong ticks2usec (unsigned long ticks);
/* lib/gunzip.c */ +int gzip_parse_header(const unsigned char *src, unsigned long len); int gunzip(void *, int, unsigned char *, unsigned long *); int zunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp, int stoponerr, int offset); diff --git a/lib/gunzip.c b/lib/gunzip.c index 832b306..adb86c7 100644 --- a/lib/gunzip.c +++ b/lib/gunzip.c @@ -42,7 +42,7 @@ void gzfree(void *x, void *addr, unsigned nb) free (addr); }
-int gunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp) +int gzip_parse_header(const unsigned char *src, unsigned long len) { int i, flags;
@@ -63,12 +63,21 @@ int gunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp) ; if ((flags & HEAD_CRC) != 0) i += 2; - if (i >= *lenp) { + if (i >= len) { puts ("Error: gunzip out of data in header\n"); return (-1); } + return i; +} + +int gunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp) +{ + int offset = gzip_parse_header(src, *lenp); + + if (offset < 0) + return offset;
- return zunzip(dst, dstlen, src, lenp, 1, i); + return zunzip(dst, dstlen, src, lenp, 1, offset); }
#ifdef CONFIG_CMD_UNZIP
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- lib/Kconfig | 5 +++++ lib/Makefile | 3 ++- 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/lib/Kconfig b/lib/Kconfig index 628ef8d..49f6133 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -177,6 +177,11 @@ config LZO help This enables support for LZO compression algorithm.r
+config SPL_LZO + bool "Enable LZO decompression support in SPL" + help + This enables support for LZO compression algorithm in the SPL. + config SPL_GZIP bool "Enable gzip decompression support for SPL build" select SPL_ZLIB diff --git a/lib/Makefile b/lib/Makefile index faf4538..87d0d53 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -10,7 +10,6 @@ ifndef CONFIG_SPL_BUILD obj-$(CONFIG_EFI) += efi/ obj-$(CONFIG_EFI_LOADER) += efi_loader/ obj-$(CONFIG_LZMA) += lzma/ -obj-$(CONFIG_LZO) += lzo/ obj-$(CONFIG_BZIP2) += bzip2/ obj-$(CONFIG_TIZEN) += tizen/ obj-$(CONFIG_FIT) += libfdt/ @@ -51,6 +50,8 @@ obj-$(CONFIG_SHA256) += sha256.o
obj-$(CONFIG_$(SPL_)ZLIB) += zlib/ obj-$(CONFIG_$(SPL_)GZIP) += gunzip.o +obj-$(CONFIG_$(SPL_)LZO) += lzo/ +
obj-$(CONFIG_$(SPL_TPL_)SAVEENV) += qsort.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += libfdt/
Sort include files in accordance to U-Boot coding style.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com --- lib/fdtdec.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 630e040..f26d2eb 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -4,16 +4,16 @@ */
#ifndef USE_HOSTCC -#include <boot_fit.h> #include <common.h> +#include <boot_fit.h> #include <dm.h> +#include <dm/of_extra.h> #include <errno.h> -#include <serial.h> -#include <libfdt.h> -#include <fdt_support.h> #include <fdtdec.h> +#include <fdt_support.h> +#include <libfdt.h> +#include <serial.h> #include <asm/sections.h> -#include <dm/of_extra.h> #include <linux/ctype.h>
DECLARE_GLOBAL_DATA_PTR;
Hi Jean-Jacques,
Actually that should go at the end where it is now.
See:
https://www.denx.de/wiki/U-Boot/CodingStyle
1.9.1
Hi Simon,
On 25/09/2017 04:12, Simon Glass wrote:
Hi Jean-Jacques,
See:
Well I wasn't sure if dm/* should go at the end. I thought that maybe asm/*, arch/* and linux/* were 'special' cases. This impression was reinforced because in the example asm/* goes before arch/*, which does not follow the alphabetical order. So before I make the change in the patch, what would be the right place for dm/of_extra.h ? just before #include <linux/ctype.h> ?
Thanks, Jean-Jacques
1.9.1
u-boot can be embedded within a FIT image with multiple DTBs. It then selects at run-time which one is best suited for the platform. Use the same principle here for the SPL: put the DTBs in a FIT image, compress it (LZO, GZIP, or no compression) and append it at the end of the SPL.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com --- doc/README.multi-dtb-fit | 56 ++++++++++++++++++++++++++++-- dts/Kconfig | 83 +++++++++++++++++++++++++++++++++++++++++++++ lib/fdtdec.c | 88 +++++++++++++++++++++++++++++++++++++++++++----- scripts/Makefile.spl | 35 ++++++++++++++++++- 4 files changed, 249 insertions(+), 13 deletions(-)
diff --git a/doc/README.multi-dtb-fit b/doc/README.multi-dtb-fit index 0d4f068..6cc4965 100644 --- a/doc/README.multi-dtb-fit +++ b/doc/README.multi-dtb-fit @@ -1,8 +1,11 @@ -MULTI DTB FIT +MULTI DTB FIT and SPL_MULTI_DTB_FIT
-The purpose of this feature is to enable u-boot to select its DTB from a FIT -appended at the end of the binary. +The purpose of this feature is to enable U-Boot or the SPL to select its DTB +from a FIT appended at the end of the binary. +It comes in two flavors: U-Boot (CONFIG_MULTI_DTB_FIT) and SPL +(CONFIG_SPL_MULTI_DTB_FIT).
+U-Boot flavor: Usually the DTB is selected by the SPL and passed down to U-Boot. But some platforms don't use the SPL. In this case MULTI_DTB_FIT can used to provide U-Boot with a choice of DTBs. @@ -13,3 +16,50 @@ the FIT. The selection is done using board_fit_config_name_match() (same as what the SPL uses to select the DTB for U-Boot). The selection happens during fdtdec_setup() which is called during before relocation by board_init_f(). + +SPL flavor: +the SPL uses only a small subset of the DTB and it usually depends more +on the SOC than on the board. So it's usually fine to include a DTB in the +SPL that doesn't exactly match the board. There are howerver some cases +where it's not possible. In the later case, in order to support multiple +boards (or board revisions) with the same SPL binary, SPL_MULTI_DTB_FIT +can be used. +The relevant DTBs are packed into a FIT. This FIT is automatically generated +at the end of the compilation, compressed and appended to u-boot-spl.bin, so +that SPL can locate it and select the correct DTB from inside the FIT. +CONFIG_SPL__OF_LIST is used to list the relevant DTBs. +The compression stage is optional but reduces the impact on the size of the +SPL. LZO and GZIP compressions are supported. By default, the area where the +FIT is uncompressed is dynamicaly allocated but this behaviour can be changed +for platforms that don't provide a HEAP big enough to contain the uncompressed +FIT. +The SPL uses board_fit_config_name_match() to find the correct DTB within the +FIT (same as what the SPL uses to select the DTB for U-Boot). +Uncompression and selection stages happen in fdtdec_setup() which is called +during the early initialization stage of the SPL (spl_early_init() or +spl_init()) + +Impacts and performances (SPL flavor): +The impact of this option is relatively small. Here are some numbers measured +for a TI DRA72 platform: + + +----------+------------+-----------+------------+ + | size | size delta | SPL boot | boot time | + | (bytes) | (bytes) | time (s) | delta (s) | ++---------------------------+----------+------------+-----------+------------+ +| 1 DTB | | | | | ++---------------------------+----------+------------+-----------+------------+ +| reference | 125305 | 0 | 1.389 | 0 | +| LZO (dynamic allocation) | 125391 | 86 | 1.381 | -0.008 | ++---------------------------+----------+------------+-----------+------------+ +| 4 DTBs (DRA7, DRA71, | | | | | +| DRA72, DRA72 revC) | | | | | ++---------------------------+----------+------------+-----------+------------+ +| LZO (dynamic allocation) | 125991 | 686 | 1.39 | 0.001 | +| LZO (user defined area) | 125927 | 622 | 1.403 | 0.014 | +| GZIP (user defined area) | 133880 | 8575 | 1.421 | 0.032 | +| No compression (in place) | 137472 | 12167 | 1.412 | 0.023 | ++---------------------------+----------+------------+-----------+------------+ + +Note: SPL boot time is the time elapsed between the 'reset' command is entered +and the time when the first U-Boot (not SPL) version string is displayed. diff --git a/dts/Kconfig b/dts/Kconfig index 28a64d4..d754b57 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -126,6 +126,89 @@ config MULTI_DTB_FIT the correct DTB to be used. Use this if you need to support multiple DTBs but don't use the SPL.
+ +config SPL_MULTI_DTB_FIT + depends on SPL_LOAD_FIT && SPL_OF_CONTROL && !SPL_OF_PLATDATA + bool "Support embedding several DTBs in a FIT image for the SPL" + help + This option provides the SPL with the ability to select its own + DTB at runtime from an appended FIT image containing several DTBs. + This allows using the same SPL binary on multiple platforms. + The primary purpose is to handle different versions of + the same platform without tweaking the platform code if the + differences can be expressed in the DTBs (common examples are: bus + capabilities, pad configurations). + +config SPL_OF_LIST + string "List of device tree files to include for DT control in SPL" + depends on SPL_MULTI_DTB_FIT + default OF_LIST + help + This option specifies a list of device tree files to use for DT + control in the SPL. These will be packaged into a FIT. At run-time, + the SPL will select the correct DT to use by examining the + hardware (e.g. reading a board ID value). This is a list of + device tree files (without the directory or .dtb suffix) + separated by <space>. + +choice + prompt "SPL OF LIST compression" + depends on SPL_MULTI_DTB_FIT + default SPL_MULTI_DTB_FIT_LZO + +config SPL_MULTI_DTB_FIT_LZO + bool "LZO" + depends on SYS_MALLOC_F + select SPL_LZO + help + Compress the FIT image containing the DTBs available for the SPL + using LZO compression. (requires lzop on host). + +config SPL_MULTI_DTB_FIT_GZIP + bool "GZIP" + depends on SYS_MALLOC_F + select SPL_GZIP + help + Compress the FIT image containing the DTBs available for the SPL + using GZIP compression. (requires gzip on host) + +config SPL_MULTI_DTB_FIT_NO_COMPRESSION + bool "No compression" + help + Do not compress the FIT image containing the DTBs available for the SPL. + Use this options only if LZO is not available and the DTBs are very small. +endchoice + +choice + prompt "Location of uncompressed DTBs " + depends on (SPL_MULTI_DTB_FIT_GZIP || SPL_MULTI_DTB_FIT_LZO) + +config SPL_MULTI_DTB_FIT_DYN_ALLOC + bool "Dynamically allocate the memory" + depends on SYS_MALLOC_F + default y + +config SPL_MULTI_DTB_FIT_USER_DEFINED_AREA + bool "User-defined location" +endchoice + +config SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ + hex "Size of memory reserved to uncompress the DTBs" + depends on (SPL_MULTI_DTB_FIT_GZIP || SPL_MULTI_DTB_FIT_LZO) + default 0x8000 + help + This is the size of this area where the DTBs are uncompressed. + If this area is dynamically allocated, make sure that + SPL_SYS_MALLOC_F_LEN is big enough to contain it. + +config SPL_MULTI_DTB_FIT_USER_DEF_ADDR + hex "Address of memory where dtbs are uncompressed" + depends on SPL_MULTI_DTB_FIT_USER_DEFINED_AREA + help + the FIT image containing the DTBs is uncompressed in an area defined + at compilation time. This is the address of this area. It must be + aligned on 2-byte boundary. + config OF_SPL_REMOVE_PROPS string "List of device tree properties to drop for SPL" depends on SPL_OF_CONTROL diff --git a/lib/fdtdec.c b/lib/fdtdec.c index f26d2eb..ab916de 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -13,8 +13,10 @@ #include <fdt_support.h> #include <libfdt.h> #include <serial.h> +#include <spl.h> #include <asm/sections.h> #include <linux/ctype.h> +#include <linux/lzo.h>
@@ -1203,9 +1205,66 @@ int fdtdec_setup_memory_banksize(void) } #endif
+#if CONFIG_IS_ENABLED(MULTI_DTB_FIT) +# if CONFIG_IS_ENABLED(MULTI_DTB_FIT_GZIP) ||\ + CONFIG_IS_ENABLED(MULTI_DTB_FIT_LZO) +static int uncompress_blob(const void *src, ulong sz_src, void **dstp) +{ + size_t sz_out = CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ; + ulong sz_in = sz_src; + void *dst; + int rc; + + if (CONFIG_IS_ENABLED(GZIP)) + if (gzip_parse_header(src, sz_in) < 0) + return -1; + if (CONFIG_IS_ENABLED(LZO)) + if (!lzop_is_valid_header(src)) + return -EBADMSG; + + if (CONFIG_IS_ENABLED(MULTI_DTB_FIT_DYN_ALLOC)) { + dst = malloc(sz_out); + if (!dst) { + puts("uncompress_blob: Unable to allocate memory\n"); + return -ENOMEM; + } + } else { +# if CONFIG_IS_ENABLED(MULTI_DTB_FIT_USER_DEFINED_AREA) + dst = (void *)CONFIG_VAL(MULTI_DTB_FIT_USER_DEF_ADDR); +# else + return -ENOTSUPP; +# endif + } + + if (CONFIG_IS_ENABLED(GZIP)) + rc = gunzip(dst, sz_out, (u8 *)src, &sz_in); + else if (CONFIG_IS_ENABLED(LZO)) + rc = lzop_decompress(src, sz_in, dst, &sz_out); + + if (rc < 0) { + /* not a valid compressed blob */ + puts("uncompress_blob: Unable to uncompress\n"); + if (CONFIG_IS_ENABLED(MULTI_DTB_FIT_DYN_ALLOC)) + free(dst); + return -EBADMSG; + } + *dstp = dst; + return 0; +} +# else +static int uncompress_blob(const void *src, ulong sz_src, void **dstp) +{ + return -ENOTSUPP; +} +# endif +#endif + int fdtdec_setup(void) { #if CONFIG_IS_ENABLED(OF_CONTROL) +# if CONFIG_IS_ENABLED(MULTI_DTB_FIT) + void *fdt_blob; +# endif # ifdef CONFIG_OF_EMBED /* Get a pointer to the FDT */ gd->fdt_blob = __dtb_dt_begin; @@ -1216,15 +1275,6 @@ int fdtdec_setup(void) gd->fdt_blob = (ulong *)&_image_binary_end; else gd->fdt_blob = (ulong *)&__bss_end; - -# elif defined CONFIG_MULTI_DTB_FIT - gd->fdt_blob = locate_dtb_in_fit(&_end); - - if (gd->fdt_blob == NULL || gd->fdt_blob <= ((void *)&_end)) { - puts("Failed to find proper dtb in embedded FIT Image\n"); - return -1; - } - # else /* FDT is at end of image */ gd->fdt_blob = (ulong *)&_end; @@ -1243,7 +1293,27 @@ int fdtdec_setup(void) gd->fdt_blob = (void *)env_get_ulong("fdtcontroladdr", 16, (uintptr_t)gd->fdt_blob); # endif + +# if CONFIG_IS_ENABLED(MULTI_DTB_FIT) + /* + *try and uncompress the blob. + * Unfortunately there is no way to know how big the input blob really + * is. So let us set the maximum input size arbitrarily high. 16MB + * ought to be more than enough for packed DTBs. + */ + if (uncompress_blob(gd->fdt_blob, 0x1000000, &fdt_blob) == 0) + gd->fdt_blob = fdt_blob; + + /* + * Check if blob is a FIT images containings DTBs. + * If so, pick the most relevant + */ + fdt_blob = locate_dtb_in_fit(gd->fdt_blob); + if (fdt_blob) + gd->fdt_blob = fdt_blob; +# endif #endif + return fdtdec_prepare_fdt(); }
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index dd8065d..18bd091 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -209,10 +209,21 @@ cmd_cat = cat $(filter-out $(PHONY), $^) > $@ quiet_cmd_copy = COPY $@ cmd_copy = cp $< $@
+ifneq ($(CONFIG_SPL_MULTI_DTB_FIT),y) +FINAL_DTB_CONTAINER = $(obj)/$(SPL_BIN).dtb +else ifeq ($(CONFIG_SPL_MULTI_DTB_FIT_LZO),y) +FINAL_DTB_CONTAINER = $(obj)/$(SPL_BIN).multidtb.fit.lzo +else ifeq ($(CONFIG_SPL_MULTI_DTB_FIT_GZIP),y) +FINAL_DTB_CONTAINER = $(obj)/$(SPL_BIN).multidtb.fit.gz +else +FINAL_DTB_CONTAINER = $(obj)/$(SPL_BIN).multidtb.fit +endif + + ifeq ($(CONFIG_$(SPL_TPL_)OF_CONTROL)$(CONFIG_OF_SEPARATE)$(CONFIG_$(SPL_TPL_)OF_PLATDATA),yy) $(obj)/$(SPL_BIN)-dtb.bin: $(obj)/$(SPL_BIN)-nodtb.bin \ $(if $(CONFIG_SPL_SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ - $(obj)/$(SPL_BIN).dtb FORCE + $(FINAL_DTB_CONTAINER) FORCE $(call if_changed,cat)
$(obj)/$(SPL_BIN).bin: $(obj)/$(SPL_BIN)-dtb.bin FORCE @@ -382,6 +393,28 @@ checkdtoc: tools PHONY += FORCE FORCE:
+PHONY += dtbs +dtbs: + $(Q)$(MAKE) $(build)=dts dtbs + # Declare the contents of the .PHONY variable as phony. We keep that # information in a variable so we can use it in if_changed and friends. .PHONY: $(PHONY) + +SHRUNK_ARCH_DTB = $(patsubst %,$(obj)/dts/%.dtb,$(subst ",,$(CONFIG_SPL_OF_LIST))) +.SECONDEXPANSION: +$(SHRUNK_ARCH_DTB): $$(patsubst $(obj)/dts/%, arch/$(ARCH)/dts/%, $$@) + $(call if_changed,fdtgrep) + +MKIMAGEFLAGS_$(SPL_BIN).multidtb.fit = -f auto -A $(ARCH) -T firmware -C none -O u-boot \ + -n "Multi DTB fit image for $(SPL_BIN)" -E \ + $(patsubst %,-b %,$(SHRUNK_ARCH_DTB)) + +$(obj)/$(SPL_BIN).multidtb.fit: /dev/null $(SHRUNK_ARCH_DTB) FORCE + $(call if_changed,mkimage) + +$(obj)/$(SPL_BIN).multidtb.fit.gz: $(obj)/$(SPL_BIN).multidtb.fit + @gzip -kf9 $< > $@ + +$(obj)/$(SPL_BIN).multidtb.fit.lzo: $(obj)/$(SPL_BIN).multidtb.fit + @lzop -f9 $< > $@
In order to be able to select the right DTB, we need to have identified the board before spl_early_init() is called.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/mach-omap2/hwinit-common.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-omap2/hwinit-common.c b/arch/arm/mach-omap2/hwinit-common.c index 7324d52..56890a0 100644 --- a/arch/arm/mach-omap2/hwinit-common.c +++ b/arch/arm/mach-omap2/hwinit-common.c @@ -165,9 +165,11 @@ void early_system_init(void) * to prevent overwrites. */ save_omap_boot_params(); - spl_early_init(); #endif do_board_detect(); +#ifdef CONFIG_SPL_BUILD + spl_early_init(); +#endif vcores_init(); #ifdef CONFIG_DEBUG_UART_OMAP debug_uart_init();
Jean-Jacques Hiblot
