[U-Boot] [PATCH v2 0/2] Convert WaRP7 to DM_USB and DM_SERIAL
This series convert the WaRP7 to the following DM: -CONFIG_DM_USB -CONFIG_DM_SERIAL
Change in v2: - Now split in two distinct patches (DM_USB & DM_SERIAL)
Pierre-Jean Texier (2): warp7: Switch to DM Serial warp7: Switch to DM USB
arch/arm/dts/imx7s-warp.dts | 5 +++++ board/warp7/warp7.c | 6 ------ configs/warp7_bl33_defconfig | 3 +++ configs/warp7_defconfig | 3 +++ include/configs/warp7.h | 2 -- 5 files changed, 11 insertions(+), 8 deletions(-)
This commit switches to DM SERIAL for warp7 and warp7_bl33 defconfigs.
Signed-off-by: Pierre-Jean Texier pjtexier@koncepto.io Signed-off-by: Joris Offouga offougajoris@gmail.com ---
Changes in v2: - Split patch - Removed CONFIG_MXC_UART_BASE from config file
arch/arm/dts/imx7s-warp.dts | 4 ++++ configs/warp7_bl33_defconfig | 2 ++ configs/warp7_defconfig | 2 ++ include/configs/warp7.h | 2 -- 4 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/imx7s-warp.dts b/arch/arm/dts/imx7s-warp.dts index d28b7ec..4d87348 100644 --- a/arch/arm/dts/imx7s-warp.dts +++ b/arch/arm/dts/imx7s-warp.dts @@ -21,6 +21,10 @@ mmc0 = &usdhc3; };
+ chosen { + stdout-path = &uart1; + }; + gpio-keys { compatible = "gpio-keys"; pinctrl-0 = <&pinctrl_gpio>; diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index 6eaf152..d34f76b 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -38,6 +38,8 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 28aa06f..ae424ab 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -47,6 +47,8 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y CONFIG_OPTEE=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 043f286..2bbf691 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -24,8 +24,6 @@ #endif #endif
-#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR - /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (35 * SZ_1M)
On Fri, Apr 19, 2019 at 3:35 PM Pierre-Jean Texier pjtexier@koncepto.io wrote:
Reviewed-by: Fabio Estevam festevam@gmail.com
This commit switches to DM SERIAL for warp7 and warp7_bl33 defconfigs. Signed-off-by: Pierre-Jean Texier pjtexier@koncepto.io Signed-off-by: Joris Offouga offougajoris@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
This commit switches to DM USB for warp7 and warp7_bl33 defconfigs.
Changes in v2: - Split patch - Removed unused header file <usb.h>
arch/arm/dts/imx7s-warp.dts | 1 + board/warp7/warp7.c | 6 ------ configs/warp7_bl33_defconfig | 1 + configs/warp7_defconfig | 1 + 4 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/imx7s-warp.dts b/arch/arm/dts/imx7s-warp.dts index 4d87348..db5ef67 100644 --- a/arch/arm/dts/imx7s-warp.dts +++ b/arch/arm/dts/imx7s-warp.dts @@ -19,6 +19,7 @@
aliases { mmc0 = &usdhc3; + usb0 = &usbotg1; };
chosen { diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c index 2882dc9..134a6c9 100644 --- a/board/warp7/warp7.c +++ b/board/warp7/warp7.c @@ -14,7 +14,6 @@ #include <asm/io.h> #include <common.h> #include <asm/arch/crm_regs.h> -#include <usb.h> #include <netdev.h> #include <power/pmic.h> #include <power/pfuze3000_pmic.h> @@ -128,11 +127,6 @@ int checkboard(void) return 0; }
-int board_usb_phy_mode(int port) -{ - return USB_INIT_DEVICE; -} - int board_late_init(void) { struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index d34f76b..300dc38 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -41,6 +41,7 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index ae424ab..cabddad 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -51,6 +51,7 @@ CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_OPTEE=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y
This commit switches to DM USB for warp7 and warp7_bl33 defconfigs. Signed-off-by: Pierre-Jean Texier pjtexier@koncepto.io Signed-off-by: Joris Offouga offougajoris@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
Pierre-Jean Texier
sbabic@denx.de
