[U-Boot] [PATCH v2 0/7] Fixes for previous -dm pull request
It turns out that the 'clang' support in buildman did not actually work, i.e. it failed to build with clang. This is because the U-Boot Makefile overrides the environment variables supplied by buildman. This series fixes that as well as an EFI loader warning that would be introduced by checking log() arguments.
This is sent as a new series on top of dm/master.
Changes in v2: - Use the command line instead of environment for make variables - Drop patches previously applied - Add fixes needed to get clang building running
Simon Glass (7): efi_loader: Add a wchar_t cast in efi_file_open() log: Check printf() arguments buildman: Add support for building with clang travis: Use buildman for building with clang net: Fix error handling in sb_eth_raw_ofdata_to_platdata() buildman: Write the environment out to an 'env' file buildman: Fix tabs in GetWrapper()
.travis.yml | 13 +++------- drivers/net/sandbox-raw.c | 9 ++++--- include/log.h | 3 ++- lib/efi_loader/efi_file.c | 4 ++-- tools/buildman/README | 10 ++++++++ tools/buildman/builderthread.py | 4 ++++ tools/buildman/cmdline.py | 2 ++ tools/buildman/control.py | 2 +- tools/buildman/toolchain.py | 42 ++++++++++++++++++++++++++++----- 9 files changed, 64 insertions(+), 25 deletions(-)
The printf() string here is not actually correct. Add a cast to avoid a warning when checking is enabled.
Changes in v2: None
lib/efi_loader/efi_file.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 128cb0a627..8a4f3a9f40 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -221,8 +221,8 @@ static efi_status_t EFIAPI efi_file_open(struct efi_file_handle *file, struct file_handle *fh = to_fh(file); efi_status_t ret;
- EFI_ENTRY("%p, %p, "%ls", %llx, %llu", file, new_handle, file_name, - open_mode, attributes); + EFI_ENTRY("%p, %p, "%ls", %llx, %llu", file, new_handle, + (wchar_t *)file_name, open_mode, attributes);
/* Check parameters */ if (!file || !new_handle || !file_name) {
Changes in v2: None
Applied to u-boot-dm
Changes in v2: None
Our utf-16 strings are all u16[].
Please, change file_name to be u16* both here and in include/efi_api.h. Then check every caller.
Best regards
Heinrich
Changes in v2: None
Thanks Simon for reporting. I have created a new patch
efi_loader: use u16* for file name https://lists.denx.de/pipermail/u-boot/2019-January/354375.html
Best regards
Heinrich
Changes in v2: None
Great thanks! I'll drop my one.
- Simon
At present logging does not check printf() arguments. Now that all users have been corrected, enable this to prevent further problems.
Changes in v2: None
include/log.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/log.h b/include/log.h index 0f2bc19477..d7f6471006 100644 --- a/include/log.h +++ b/include/log.h @@ -73,7 +73,8 @@ static inline int log_uc_cat(enum uclass_id id) * @return 0 if log record was emitted, -ve on error */ int _log(enum log_category_t cat, enum log_level_t level, const char *file, - int line, const char *func, const char *fmt, ...); + int line, const char *func, const char *fmt, ...) + __attribute__ ((format (__printf__, 6, 7)));
/* Define this at the top of a file to add a prefix to debug messages */ #ifndef pr_fmt
Changes in v2: None
Add a -O option which allows building with clang.
tools/buildman/README | 10 +++++++++ tools/buildman/builderthread.py | 1 + tools/buildman/cmdline.py | 2 ++ tools/buildman/control.py | 2 +- tools/buildman/toolchain.py | 38 +++++++++++++++++++++++++++++---- 5 files changed, 48 insertions(+), 5 deletions(-)
diff --git a/tools/buildman/README b/tools/buildman/README index d688b7cf00..56a99c70a2 100644 --- a/tools/buildman/README +++ b/tools/buildman/README @@ -1046,6 +1046,16 @@ value for 'altbootcmd', but lost one for ' altbootcmd'.
The -U option uses the u-boot.env files which are produced by a build.
+ +Building with clang +=================== + +To build with clang (sandbox only), use the -O option to override the +toolchain. For example: + + buildman -O clang-7 --board sandbox + + Other options =============
diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index b91634f3ab..6b156f152d 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -229,6 +229,7 @@ class BuilderThread(threading.Thread): config_args = ['%s_defconfig' % brd.target] config_out = '' args.extend(self.builder.toolchains.GetMakeArguments(brd)) + args.extend(self.toolchain.MakeArgs())
# If we need to reconfigure, do that now if do_config: diff --git a/tools/buildman/cmdline.py b/tools/buildman/cmdline.py index 93d09ca08d..832a5145d2 100644 --- a/tools/buildman/cmdline.py +++ b/tools/buildman/cmdline.py @@ -74,6 +74,8 @@ def ParseArgs(): parser.add_option('-o', '--output-dir', type='string', dest='output_dir', default='..', help='Directory where all builds happen and buildman has its workspace (default is ../)') + parser.add_option('-O', '--override-toolchain', type='string', + help="Override host toochain to use for sandbox (e.g. 'clang-7')") parser.add_option('-Q', '--quick', action='store_true', default=False, help='Do a rough build, with limited warning resolution') parser.add_option('-p', '--full-path', action='store_true', diff --git a/tools/buildman/control.py b/tools/buildman/control.py index c900211510..27916d3c35 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -141,7 +141,7 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None,
no_toolchains = toolchains is None if no_toolchains: - toolchains = toolchain.Toolchains() + toolchains = toolchain.Toolchains(options.override_toolchain)
if options.fetch_arch: if options.fetch_arch == 'list': diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index c62ce136fa..b3c61827f3 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -54,9 +54,11 @@ class Toolchain: arch: Architecture of toolchain as determined from the first component of the filename. E.g. arm-linux-gcc becomes arm priority: Toolchain priority (0=highest, 20=lowest) + override_toolchain: Toolchain to use for sandbox, overriding the normal + one """ def __init__(self, fname, test, verbose=False, priority=PRIORITY_CALC, - arch=None): + arch=None, override_toolchain=None): """Create a new toolchain object.
Args: @@ -68,6 +70,7 @@ class Toolchain: """ self.gcc = fname self.path = os.path.dirname(fname) + self.override_toolchain = override_toolchain
# Find the CROSS_COMPILE prefix to use for U-Boot. For example, # 'arm-linux-gnueabihf-gcc' turns into 'arm-linux-gnueabihf-'. @@ -81,6 +84,8 @@ class Toolchain: self.arch = arch else: self.arch = self.cross[:pos] if pos != -1 else 'sandbox' + if self.arch == 'sandbox' and override_toolchain: + self.gcc = override_toolchain
env = self.MakeEnvironment(False)
@@ -150,11 +155,18 @@ class Toolchain: Args: full_path: Return the full path in CROSS_COMPILE and don't set PATH + Returns: + Dict containing the environemnt to use. This is based on the current + environment, with changes as needed to CROSS_COMPILE, PATH and + LC_ALL. """ env = dict(os.environ) wrapper = self.GetWrapper()
- if full_path: + if self.override_toolchain: + # We'll use MakeArgs() to provide this + pass + elif full_path: env['CROSS_COMPILE'] = wrapper + os.path.join(self.path, self.cross) else: env['CROSS_COMPILE'] = wrapper + self.cross @@ -164,6 +176,22 @@ class Toolchain:
return env
+ def MakeArgs(self): + """Create the 'make' arguments for a toolchain + + This is only used when the toolchain is being overridden. Since the + U-Boot Makefile sets CC and HOSTCC explicitly we cannot rely on the + environment (and MakeEnvironment()) to override these values. This + function returns the arguments to accomplish this. + + Returns: + List of arguments to pass to 'make' + """ + if self.override_toolchain: + return ['HOSTCC=%s' % self.override_toolchain, + 'CC=%s' % self.override_toolchain] + return [] +
class Toolchains: """Manage a list of toolchains for building U-Boot @@ -180,10 +208,11 @@ class Toolchains: paths: List of paths to check for toolchains (may contain wildcards) """
- def __init__(self): + def __init__(self, override_toolchain=None): self.toolchains = {} self.prefixes = {} self.paths = [] + self.override_toolchain = override_toolchain self._make_flags = dict(bsettings.GetItems('make-flags'))
def GetPathList(self, show_warning=True): @@ -234,7 +263,8 @@ class Toolchains: priority: Priority to use for this toolchain arch: Toolchain architecture, or None if not known """ - toolchain = Toolchain(fname, test, verbose, priority, arch) + toolchain = Toolchain(fname, test, verbose, priority, arch, + self.override_toolchain) add_it = toolchain.ok if toolchain.arch in self.toolchains: add_it = (toolchain.priority <
Now that buildman supports clang, use it.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: None
.travis.yml | 13 +++---------- 1 file changed, 3 insertions(+), 10 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 321fd793a7..fc4d5a1d5c 100644 --- a/.travis.yml +++ b/.travis.yml @@ -109,16 +109,9 @@ script: # # From buildman, exit code 129 means warnings only. If we've been asked to # use clang only do one configuration. - - if [[ "${TOOLCHAIN}" == "clang" ]]; then + - if [[ "${BUILDMAN}" != "" ]]; then ret=0; - make O=../.bm-work/${TEST_PY_BD} HOSTCC=clang-7 CC=clang-7 -j$(nproc) - KCFLAGS=-Werror sandbox_config all || ret=$?; - if [[ $ret -ne 0 ]]; then - exit $ret; - fi; - elif [[ "${BUILDMAN}" != "" ]]; then - ret=0; - tools/buildman/buildman -P -E ${BUILDMAN} || ret=$?; + tools/buildman/buildman -P -E ${BUILDMAN} ${OVERRIDE}|| ret=$?; if [[ $ret -ne 0 && $ret -ne 129 ]]; then tools/buildman/buildman -sdeP ${BUILDMAN}; exit $ret; @@ -351,7 +344,7 @@ matrix: env: - TEST_PY_BD="sandbox" BUILDMAN="^sandbox$" - TOOLCHAIN="clang" + OVERRIDE="clang-7" - name: "test/py sandbox_spl" env: - TEST_PY_BD="sandbox_spl"
Changes in v2: None
At present this stores the error number in an unsigned int so an error is never detected. Use the existing signed variable instead.
Changes in v2: None
drivers/net/sandbox-raw.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/net/sandbox-raw.c b/drivers/net/sandbox-raw.c index 09cc678ebd..7e6625d020 100644 --- a/drivers/net/sandbox-raw.c +++ b/drivers/net/sandbox-raw.c @@ -152,7 +152,6 @@ static int sb_eth_raw_ofdata_to_platdata(struct udevice *dev) struct eth_pdata *pdata = dev_get_platdata(dev); struct eth_sandbox_raw_priv *priv = dev_get_priv(dev); const char *ifname; - u32 local; int ret;
pdata->iobase = dev_read_addr(dev); @@ -173,10 +172,10 @@ static int sb_eth_raw_ofdata_to_platdata(struct udevice *dev) priv->host_ifindex, priv->host_ifname); }
- local = sandbox_eth_raw_os_is_local(priv->host_ifname); - if (local < 0) - return local; - priv->local = local; + ret = sandbox_eth_raw_os_is_local(priv->host_ifname); + if (ret < 0) + return ret; + priv->local = ret;
return 0; }
Sometimes it is useful to see the environment that was used to build U-Boot. Write this out to a file in the build directory.
Changes in v2: None
tools/buildman/builderthread.py | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index 6b156f152d..8a9d47cd5e 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -322,6 +322,9 @@ class BuilderThread(threading.Thread):
# Write out the image and function size information and an objdump env = result.toolchain.MakeEnvironment(self.builder.full_path) + with open(os.path.join(build_dir, 'env'), 'w') as fd: + for var in sorted(env.keys()): + print >>fd, '%s="%s"' % (var, env[var]) lines = [] for fname in ['u-boot', 'spl/u-boot-spl']: cmd = ['%snm' % self.toolchain.cross, '--size-sort', fname]
Changes in v2: None
Applied to u-boot-dm, thanks!
This function has tabs instead of spaces. Fix it.
Changes in v2: - Drop patches previously applied - Add fixes needed to get clang building running
tools/buildman/toolchain.py | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index b3c61827f3..a65737fdf8 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -135,8 +135,8 @@ class Toolchain: def GetWrapper(self, show_warning=True): """Get toolchain wrapper from the setting file. """ - value = '' - for name, value in bsettings.GetItems('toolchain-wrapper'): + value = '' + for name, value in bsettings.GetItems('toolchain-wrapper'): if not value: print "Warning: Wrapper not found" if value:
Joe Hershberger
sjg@google.com
