[U-Boot] [PATCH] autoconf.mk.dep: use target cflags, not host
The current autoconf.mk.dep rule uses the host cflags when executing the target compiler (which includes target header files). We don't want to mix the target compiler and host compiler flags, so change it to CFLAGS. Otherwise we get things like -pedantic which the U-Boot source code does not build with.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- Makefile | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/Makefile b/Makefile index 5db2e0e..385b4fe 100644 --- a/Makefile +++ b/Makefile @@ -503,7 +503,7 @@ $(obj)include/autoconf.mk.dep: $(obj)include/config.h include/common.h @$(XECHO) Generating $@ ; \ set -e ; \ : Generate the dependancies ; \ - $(CC) -x c -DDO_DEPS_ONLY -M $(HOSTCFLAGS) $(CPPFLAGS) \ + $(CC) -x c -DDO_DEPS_ONLY -M $(CFLAGS) $(CPPFLAGS) \ -MQ $(obj)include/autoconf.mk include/common.h > $@
$(obj)include/autoconf.mk: $(obj)include/config.h
Dear Mike Frysinger,
Applied, thanks.
Mike Frysinger
