[PATCH 0/5] arm: mvebu: turris_omnia: Fix hangup in debug UART
If proper U-Boot on Turris Omnia tries to print something on debug UART then CPU hangs. Reason is that debug UART in proper U-Boot for Turris Omnia has incorrect configuration of base register. Base register is different in SPL and also in different stages of proper U-Boot.
Fix all these issues. Introduce new arch_very_early_init() ARM function which will be called at very early stage prior initialization of debug UART. Move code which moves internal mvebu registers to this function. And split configuration of DEBUG_UART_BASE into SPL and proper U-Boot to allow setting different values which matches current HW status.
With all these changes, it is possible call "printf" function in Turris Omnia's board_early_init_f() function in both SPL and proper U-Boot.
Pali Rohár (5): arm: Add new config option ARCH_VERY_EARLY_INIT arm: mvebu: Move internal registers in arch_very_early_init() function serial: Add new config option SPL_DEBUG_UART_BASE serial: ns16550: Add support for SPL_DEBUG_UART_BASE arm: mvebu: turris_omnia: Fix DEBUG_UART_BASE
arch/arm/Kconfig | 6 ++++++ arch/arm/lib/crt0.S | 5 +++++ arch/arm/mach-mvebu/Kconfig | 1 + arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/cpu.c | 31 ------------------------------- arch/arm/mach-mvebu/lowlevel.S | 27 +++++++++++++++++++++++++++ configs/turris_omnia_defconfig | 3 ++- drivers/serial/Kconfig | 7 +++++++ drivers/serial/ns16550.c | 4 ++-- 9 files changed, 51 insertions(+), 34 deletions(-) create mode 100644 arch/arm/mach-mvebu/lowlevel.S
When this option is set then ARM _main() function would call arch_very_early_init() function at the beginning. It would be before calling any other functions like debug_uart_init() and also before initializing C runtime environment.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/Kconfig | 6 ++++++ arch/arm/lib/crt0.S | 5 +++++ 2 files changed, 11 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0afec5155b1b..9898c7d68e1b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -401,6 +401,12 @@ config SYS_ARM_CACHE_WRITEALLOC write is performed. endchoice
+config ARCH_VERY_EARLY_INIT + bool + +config SPL_ARCH_VERY_EARLY_INIT + bool + config ARCH_CPU_INIT bool "Enable ARCH_CPU_INIT" help diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index ba312901f331..612a2d5b698e 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -90,6 +90,11 @@ clbss_l:cmp r0, r1 /* while not at end of BSS */
ENTRY(_main)
+/* Call arch_very_early_init before initializing C runtime environment. */ +#if CONFIG_IS_ENABLED(ARCH_VERY_EARLY_INIT) + bl arch_very_early_init +#endif + /* * Set up initial C runtime environment and call board_init_f(0). */
Thanks, Stefan
- bool
- bool
- config ARCH_CPU_INIT bool "Enable ARCH_CPU_INIT" help
ENTRY(_main)
- bl arch_very_early_init
- Set up initial C runtime environment and call board_init_f(0).
Viele Grüße, Stefan Roese
Moving of internal registers from INTREG_BASE_ADDR_REG to SOC_REGS_PHY_BASE needs to be done very early, prior calling any function which may touch internal registers, like debug_uart_init().
So do it earlier in arch_very_early_init() instead of arch_cpu_init().
Movement is done in proper U-Boot, not in SPL. SPL may return to bootrom and bootrom requires internal registers at (old) expected location.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/mach-mvebu/Kconfig | 1 + arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/cpu.c | 31 ------------------------------- arch/arm/mach-mvebu/lowlevel.S | 27 +++++++++++++++++++++++++++ 4 files changed, 29 insertions(+), 31 deletions(-) create mode 100644 arch/arm/mach-mvebu/lowlevel.S
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index a3f273f4f949..98b13d1e336d 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -16,6 +16,7 @@ config ARMADA_32BIT select SUPPORT_SPL select TRANSLATION_OFFSET select SPL_SYS_NO_VECTOR_TABLE if SPL + select ARCH_VERY_EARLY_INIT
config ARMADA_64BIT bool diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 1b451889d242..8bd2246325ca 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -21,6 +21,7 @@ else # CONFIG_ARCH_KIRKWOOD
obj-y = cpu.o obj-y += dram.o +obj-y += lowlevel.o obj-$(CONFIG_DM_RESET) += system-controller.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ARMADA_375) += ../../../drivers/ddr/marvell/axp/xor.o diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 1e893777b292..173d95a760a3 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -413,20 +413,7 @@ static void update_sdram_window_sizes(void) } }
-void mmu_disable(void) -{ - asm volatile( - "mrc p15, 0, r0, c1, c0, 0\n" - "bic r0, #1\n" - "mcr p15, 0, r0, c1, c0, 0\n"); -} - #ifdef CONFIG_ARCH_CPU_INIT -static void set_cbar(u32 addr) -{ - asm("mcr p15, 4, %0, c15, c0" : : "r" (addr)); -} - #define MV_USB_PHY_BASE (MVEBU_AXP_USB_BASE + 0x800) #define MV_USB_PHY_PLL_REG(reg) (MV_USB_PHY_BASE | (((reg) & 0xF) << 2)) #define MV_USB_X3_BASE(addr) (MVEBU_AXP_USB_BASE | BIT(11) | \ @@ -476,24 +463,6 @@ int arch_cpu_init(void) struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE;
- /* - * Only with disabled MMU its possible to switch the base - * register address on Armada 38x. Without this the SDRAM - * located at >= 0x4000.0000 is also not accessible, as its - * still locked to cache. - */ - mmu_disable(); - - /* Linux expects the internal registers to be at 0xf1000000 */ - writel(SOC_REGS_PHY_BASE, INTREG_BASE_ADDR_REG); - set_cbar(SOC_REGS_PHY_BASE + 0xC000); - - /* - * From this stage on, the SoC detection is working. As we have - * configured the internal register base to the value used - * in the macros / defines in the U-Boot header (soc.h). - */ - if (mvebu_soc_family() == MVEBU_SOC_A38X) { /* * To fully release / unlock this area from cache, we need diff --git a/arch/arm/mach-mvebu/lowlevel.S b/arch/arm/mach-mvebu/lowlevel.S new file mode 100644 index 000000000000..2491310eb0c1 --- /dev/null +++ b/arch/arm/mach-mvebu/lowlevel.S @@ -0,0 +1,27 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#include <config.h> +#include <linux/linkage.h> + +ENTRY(arch_very_early_init) +#ifdef CONFIG_ARMADA_38X + /* + * Only with disabled MMU its possible to switch the base + * register address on Armada 38x. Without this the SDRAM + * located at >= 0x4000.0000 is also not accessible, as its + * still locked to cache. + */ + mrc p15, 0, r0, c1, c0, 0 + bic r0, #1 + mcr p15, 0, r0, c1, c0, 0 +#endif + + /* Move internal registers from INTREG_BASE_ADDR_REG to SOC_REGS_PHY_BASE */ + ldr r0, =SOC_REGS_PHY_BASE + ldr r1, =INTREG_BASE_ADDR_REG + str r0, [r1] + add r0, r0, #0xC000 + mcr p15, 4, r0, c15, c0 + + bx lr +ENDPROC(arch_very_early_init)
- asm volatile(
"bic r0, #1\n"
- mmu_disable();
- To fully release / unlock this area from cache, we need
- mrc p15, 0, r0, c1, c0, 0
- bic r0, #1
- mcr p15, 0, r0, c1, c0, 0
You are disabling the MMU here only for CONFIG_ARMADA_38X. In the non-asm version removed above, it's disabled in all cases in arch_cpu_init(). Is this correct? I might be missing something - it's been quite some time, since I worked on this code.
Thanks, Stefan
- /* Move internal registers from INTREG_BASE_ADDR_REG to SOC_REGS_PHY_BASE */
- ldr r0, =SOC_REGS_PHY_BASE
- ldr r1, =INTREG_BASE_ADDR_REG
- str r0, [r1]
- add r0, r0, #0xC000
- mcr p15, 4, r0, c15, c0
- bx lr
- select ARCH_VERY_EARLY_INIT config ARMADA_64BIT bool
diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 1b451889d242..8bd2246325ca 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -21,6 +21,7 @@ else # CONFIG_ARCH_KIRKWOOD obj-y = cpu.o obj-y += dram.o +obj-y += lowlevel.o obj-$(CONFIG_DM_RESET) += system-controller.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ARMADA_375) += ../../../drivers/ddr/marvell/axp/xor.o diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 1e893777b292..173d95a760a3 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -413,20 +413,7 @@ static void update_sdram_window_sizes(void) } } -void mmu_disable(void) -{
- asm volatile(
"bic r0, #1\n"
- mmu_disable();
- bic r0, #1
I'm not sure. I was in impression from that comment that disabling MMU is needed only for A38x. But runtime detection of the board was not possible until registers are relocated to the new location, so code disabling MMU was called always.
So, this change should be tested on some AXP, A370 or A375 board to verify that everything is working correctly.
I tested it only on A385 Turris Omnia.
Thanks, Stefan
- str r0, [r1]
- bx lr
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
- asm volatile(
"bic r0, #1\n"
- mmu_disable();
- bic r0, #1
Okay, understood. I can do some testing on AXP.
Thanks, Stefan
Thanks, Stefan
- str r0, [r1]
- bx lr
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index a3f273f4f949..98b13d1e336d 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -16,6 +16,7 @@ config ARMADA_32BIT select SUPPORT_SPL select TRANSLATION_OFFSET select SPL_SYS_NO_VECTOR_TABLE if SPL + select ARCH_VERY_EARLY_INIT config ARMADA_64BIT bool diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 1b451889d242..8bd2246325ca 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -21,6 +21,7 @@ else # CONFIG_ARCH_KIRKWOOD obj-y = cpu.o obj-y += dram.o +obj-y += lowlevel.o obj-$(CONFIG_DM_RESET) += system-controller.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ARMADA_375) += ../../../drivers/ddr/marvell/axp/xor.o diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 1e893777b292..173d95a760a3 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -413,20 +413,7 @@ static void update_sdram_window_sizes(void) } } -void mmu_disable(void) -{ - asm volatile( - "mrc p15, 0, r0, c1, c0, 0\n" - "bic r0, #1\n" - "mcr p15, 0, r0, c1, c0, 0\n"); -}
#define MV_USB_PHY_BASE (MVEBU_AXP_USB_BASE + 0x800) #define MV_USB_PHY_PLL_REG(reg) (MV_USB_PHY_BASE | (((reg) & 0xF) << 2)) #define MV_USB_X3_BASE(addr) (MVEBU_AXP_USB_BASE | BIT(11) | \ @@ -476,24 +463,6 @@ int arch_cpu_init(void) struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; - /* - * Only with disabled MMU its possible to switch the base - * register address on Armada 38x. Without this the SDRAM - * located at >= 0x4000.0000 is also not accessible, as its - * still locked to cache. - */ - mmu_disable();
Some quick tests on theadorable_debug (AXP) have shown, that it makes no difference, if the MMU is disabled or not AFAICT.
While doing this I noticed though, that kwboot UART booting only worked in roughly 1 out of 2 cases. With no progress after this line:
Sending boot message. Please reboot the target...\
IIRC, this worked more reliable a few weeks ago. Any idea, what might have caused this regression - if I am correct here?
Thanks, Stefan
Thanks, Stefan
Thanks, Stefan
Ok!
There were changes in handling of bootrom boot message. There is option -s which can change default timeout option. And plus there is option -a which sets this timeout option to AXP value.
Default value is 50 and for AXP default value is 1000.
Maybe it is needed to tune AXP value... Try to call with -s option between 50 and 1000...
Thanks, Stefan
Thanks, Stefan
Thanks, Stefan
Hello Stefan! Have you tried to tune kwboot's -s or -a option for AXP board?
Hi Pali,
Thanks for getting back on this. I totally forgot about it.
'-a' makes it actually worse. Zero success with 5 tries. '-s 10' worked 5 out of 5 times. So I'll stick with this version I think.
Thanks, Stefan
On Wednesday 01 June 2022 12:44:01 Stefan Roese wrote:
Hi Pali,
Thanks, Stefan
Ok! So I think that you could change KWBOOT_MSG_RSP_TIMEO_AXP value in tools/kwboot.c to 10 if it works fine for your AXP board. So '-a' option would work better.
Hi Pali,
Thanks, Stefan
Hello! I would like to remind this issue. Could you look at it, so we do not have broken '-a' option in kwboot?
Hi Pali,
Hi Pali,
Thanks, Stefan
Thanks for the reminder. I've checked again and "-a" is not working reliable on my AXP platform (any more?). Using "-s 10" seem to be much better.
So we should either remove this -a option completely or change the define to 10 instead of 1000 IMHO.
Thanks, Stefan
On Friday 19 August 2022 09:30:55 Stefan Roese wrote:
Hi Pali,
Hi Pali,
On Friday 06 May 2022 14:35:55 Stefan Roese wrote: > While doing this I noticed though, that kwboot UART booting only worked > in roughly 1 out of 2 cases. With no progress after this line: > > Sending boot message. Please reboot the target...\ > > IIRC, this worked more reliable a few weeks ago. Any idea, what might > have caused this regression - if I am correct here?
Thanks, Stefan
Thanks, Stefan
Yes, please check also if kwboot is reliable without any -a or -s option on AXP platform. If it works, then remove/deprecate -a option. If it does not work and requires specific -s 10 option, then change KWBOOT_MSG_RSP_TIMEO_AXP macro to 10.
Thanks, Stefan
- asm volatile(
"bic r0, #1\n"
- mmu_disable();
- bic r0, #1
- str r0, [r1]
- bx lr
SPL_DEBUG_UART_BASE is same as DEBUG_UART_BASE, but applies only for SPL.
In some cases base address of UART is different in SPL and proper U-Boot.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/serial/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 26fa498bbbb7..46726d76b162 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -508,6 +508,13 @@ config DEBUG_UART_BASE A default should be provided by your board, but if not you will need to use the correct value here.
+config SPL_DEBUG_UART_BASE + hex "Base address of UART for SPL" + depends on SPL && DEBUG_UART + default DEBUG_UART_BASE + help + This is the base address of your UART for memory-mapped UARTs for SPL. + config DEBUG_UART_CLOCK int "UART input clock" depends on DEBUG_UART
Thanks, Stefan
- hex "Base address of UART for SPL"
- depends on SPL && DEBUG_UART
- default DEBUG_UART_BASE
- help
- config DEBUG_UART_CLOCK int "UART input clock" depends on DEBUG_UART
Use CONFIG_VAL(DEBUG_UART_BASE) instead of CONFIG_DEBUG_UART_BASE, so proper config value (CONFIG_DEBUG_UART_BASE or CONFIG_SPL_DEBUG_UART_BASE) is used based on building target.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/serial/ns16550.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index a4220fd0ae2f..78bfe6281ce3 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -325,7 +325,7 @@ int ns16550_tstc(struct ns16550 *com_port)
static inline void _debug_uart_init(void) { - struct ns16550 *com_port = (struct ns16550 *)CONFIG_DEBUG_UART_BASE; + struct ns16550 *com_port = (struct ns16550 *)CONFIG_VAL(DEBUG_UART_BASE); int baud_divisor;
/* @@ -360,7 +360,7 @@ static inline int NS16550_read_baud_divisor(struct ns16550 *com_port)
static inline void _debug_uart_putc(int ch) { - struct ns16550 *com_port = (struct ns16550 *)CONFIG_DEBUG_UART_BASE; + struct ns16550 *com_port = (struct ns16550 *)CONFIG_VAL(DEBUG_UART_BASE);
while (!(serial_din(&com_port->lsr) & UART_LSR_THRE)) { #ifdef CONFIG_DEBUG_UART_NS16550_CHECK_ENABLED
Thanks, Stefan
Internal registers in SPL are at address 0xd0000000 and in proper U-Boot at address 0xf1000000. UART base address is located in internal registers.
Fix DEBUG_UART_BASE option to correct value for both SPL and proper U-Boot.
This change fixes hangup of proper U-Boot when it is trying to print something via debug UART.
Signed-off-by: Pali Rohár pali@kernel.org --- configs/turris_omnia_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 217e2603fdfb..62c9be29c86b 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -18,7 +18,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-385-turris-omnia" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -93,6 +93,7 @@ CONFIG_PCI_MVEBU=y CONFIG_DM_RTC=y CONFIG_RTC_ARMADA38X=y CONFIG_SCSI=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y
Isn't such a change now needed for all 32bit Armada MVEBU targets?
This is a good question. It should be fixed for all 32bit mvebu targets.
Now I sent additional patch which fixes this for all other 32bit mvebu platforms which have CONFIG_DEBUG_UART_BASE in defconfig file.
Thanks, Stefan
Internal registers for 32-bit mvebu boards in SPL are at address 0xd0000000 and in proper U-Boot at address 0xf1000000.
Fix DEBUG_UART_BASE option for all 32-bit mvebu boards.
Signed-off-by: Pali Rohár pali@kernel.org --- configs/clearfog_defconfig | 3 ++- configs/controlcenterdc_defconfig | 3 ++- configs/db-88f6820-amc_defconfig | 3 ++- configs/db-88f6820-gp_defconfig | 3 ++- configs/db-mv784mp-gp_defconfig | 3 ++- configs/ds414_defconfig | 3 ++- configs/helios4_defconfig | 3 ++- configs/maxbcm_defconfig | 3 ++- configs/theadorable_debug_defconfig | 3 ++- configs/x530_defconfig | 3 ++- 10 files changed, 20 insertions(+), 10 deletions(-)
diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index a7b6508a5c6d..9f744d0caf96 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -13,7 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-388-clearfog" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -66,6 +66,7 @@ CONFIG_MVMDIO=y CONFIG_PCI=y CONFIG_PCI_MVEBU=y CONFIG_SCSI=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index df38b2c54f08..c366db40e6fa 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -16,7 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-38x-controlcenterdc" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -84,6 +84,7 @@ CONFIG_PCI_MVEBU=y CONFIG_SCSI=y CONFIG_SCSI_AHCI_PLAT=y CONFIG_SYS_SCSI_MAX_SCSI_ID=2 +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 9b77b4a5f057..be4ee7913513 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -13,7 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-385-db-88f6820-amc" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=200000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -70,6 +70,7 @@ CONFIG_MII=y CONFIG_MVMDIO=y CONFIG_PCI=y CONFIG_PCI_MVEBU=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index f56d1fbf2530..55ebb57c692e 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -13,7 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-388-gp" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -66,6 +66,7 @@ CONFIG_MVMDIO=y CONFIG_PCI=y CONFIG_PCI_MVEBU=y CONFIG_SCSI=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 5683f118365f..2c1d3b464d85 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -13,7 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-gp" CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -68,6 +68,7 @@ CONFIG_MII=y CONFIG_MVMDIO=y CONFIG_PCI=y CONFIG_PCI_MVEBU=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index a83fe079b3a1..81a767cc0ea8 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -19,7 +19,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-synology-ds414" CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -68,6 +68,7 @@ CONFIG_MII=y CONFIG_MVMDIO=y CONFIG_PCI=y CONFIG_PCI_MVEBU=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index c2130bacb4b4..4dc9e3bc58dd 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -13,7 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-388-helios4" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -67,6 +67,7 @@ CONFIG_MVMDIO=y CONFIG_PCI=y CONFIG_PCI_MVEBU=y CONFIG_SCSI=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 40f79d47ea98..c325dd7cb272 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -13,7 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-maxbcm" CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y @@ -48,6 +48,7 @@ CONFIG_PHY_GIGE=y CONFIG_MVNETA=y CONFIG_MII=y CONFIG_MVMDIO=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 111392d9a941..9e8523d94145 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -14,7 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" CONFIG_SPL_TEXT_BASE=0x40004030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_MEM_TOP_HIDE=0x80000 CONFIG_SYS_LOAD_ADDR=0x800000 @@ -74,6 +74,7 @@ CONFIG_MVMDIO=y CONFIG_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCI_MVEBU=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 77d224942764..860cb2207139 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -14,7 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-385-atl-x530" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_SERIAL=y CONFIG_SPL=y -CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x1000000 CONFIG_ENV_ADDR=0x100000 @@ -72,6 +72,7 @@ CONFIG_PCI_MVEBU=y CONFIG_DM_RTC=y CONFIG_RTC_DS1307=y CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_SPL_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y
Thanks, Stefan
Hi Pali,
This patchset seems to introduce problems on some non-MVEBU platforms like x86, chromebook_coral_defconfig:
drivers/serial/ns16550.c: In function ‘_debug_uart_init’: ././include/linux/kconfig.h:51:32: error: ‘CONFIG_TPL_DEBUG_UART_BASE’ undeclared (first use in this function); did you mean ‘CONFIG_SPL_DEBUG_UART_BASE’? 51 | #define __config_val(pfx, cfg) CONFIG_ ## pfx ## cfg | ^~~~~~~ ././include/linux/kconfig.h:50:32: note: in expansion of macro ‘__config_val’ 50 | #define _config_val(pfx, cfg) __config_val(pfx, cfg) | ^~~~~~~~~~~~ ././include/linux/kconfig.h:49:33: note: in expansion of macro ‘_config_val’ 49 | #define config_val(cfg) _config_val(_CONFIG_PREFIX, cfg) | ^~~~~~~~~~~ ././include/linux/kconfig.h:61:29: note: in expansion of macro ‘config_val’ 61 | #define CONFIG_VAL(option) config_val(option) | ^~~~~~~~~~ drivers/serial/ns16550.c:328:54: note: in expansion of macro ‘CONFIG_VAL’ 328 | struct ns16550 *com_port = (struct ns16550 *)CONFIG_VAL(DEBUG_UART_BASE); | ^~~~~~~~~~ ././include/linux/kconfig.h:51:32: note: each undeclared identifier is reported only once for each function it appears in 51 | #define __config_val(pfx, cfg) CONFIG_ ## pfx ## cfg | ^~~~~~~ ././include/linux/kconfig.h:50:32: note: in expansion of macro ‘__config_val’ 50 | #define _config_val(pfx, cfg) __config_val(pfx, cfg) | ^~~~~~~~~~~~ ././include/linux/kconfig.h:49:33: note: in expansion of macro ‘_config_val’ 49 | #define config_val(cfg) _config_val(_CONFIG_PREFIX, cfg) | ^~~~~~~~~~~ ././include/linux/kconfig.h:61:29: note: in expansion of macro ‘config_val’ 61 | #define CONFIG_VAL(option) config_val(option) | ^~~~~~~~~~ drivers/serial/ns16550.c:328:54: note: in expansion of macro ‘CONFIG_VAL’ 328 | struct ns16550 *com_port = (struct ns16550 *)CONFIG_VAL(DEBUG_UART_BASE); | ^~~~~~~~~~ drivers/serial/ns16550.c: In function ‘_debug_uart_putc’: ././include/linux/kconfig.h:51:32: error: ‘CONFIG_TPL_DEBUG_UART_BASE’ undeclared (first use in this function); did you mean ‘CONFIG_SPL_DEBUG_UART_BASE’? 51 | #define __config_val(pfx, cfg) CONFIG_ ## pfx ## cfg | ^~~~~~~ ././include/linux/kconfig.h:50:32: note: in expansion of macro ‘__config_val’ 50 | #define _config_val(pfx, cfg) __config_val(pfx, cfg) | ^~~~~~~~~~~~ ././include/linux/kconfig.h:49:33: note: in expansion of macro ‘_config_val’ 49 | #define config_val(cfg) _config_val(_CONFIG_PREFIX, cfg) | ^~~~~~~~~~~ ././include/linux/kconfig.h:61:29: note: in expansion of macro ‘config_val’ 61 | #define CONFIG_VAL(option) config_val(option) | ^~~~~~~~~~ drivers/serial/ns16550.c:363:54: note: in expansion of macro ‘CONFIG_VAL’ 363 | struct ns16550 *com_port = (struct ns16550 *)CONFIG_VAL(DEBUG_UART_BASE); | ^~~~~~~~~~ make[3]: *** [scripts/Makefile.build:258: tpl/drivers/serial/ns16550.o] Error 1
Could you please take a look?
Thanks, Stefan
On Monday 16 May 2022 16:52:06 Stefan Roese wrote:
Hi Pali,
Thanks, Stefan
I totally forgot for TPL. Fixed in additional patch "serial: Add new config option TPL_DEBUG_UART_BASE" which I sent recently.
With this patch chromebook_coral_defconfig with x86 compiler builds fine.
TPL_DEBUG_UART_BASE is same as DEBUG_UART_BASE, but applies only for TPL.
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 46726d76b162..f6425a530e57 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -515,6 +515,13 @@ config SPL_DEBUG_UART_BASE help This is the base address of your UART for memory-mapped UARTs for SPL.
+config TPL_DEBUG_UART_BASE + hex "Base address of UART for TPL" + depends on TPL && DEBUG_UART + default DEBUG_UART_BASE + help + This is the base address of your UART for memory-mapped UARTs for TPL. + config DEBUG_UART_CLOCK int "UART input clock" depends on DEBUG_UART
Thanks, Stefan
- hex "Base address of UART for TPL"
- depends on TPL && DEBUG_UART
- help
Applied with the corresponding additional patches to u-boot-marvell/master
Thanks, Stefan
Pali Rohár
Stefan Roese
