[U-Boot] [PATCH 2/2] status_led: Kconfig migration
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach uri.mashiach@compulab.co.il --- arch/arm/cpu/arm920t/ep93xx/led.c | 35 ++++++------- arch/powerpc/include/asm/status_led.h | 10 ++-- arch/powerpc/lib/interrupts.c | 6 +-- board/BuS/eb_cpu5282/eb_cpu5282.c | 2 +- board/bf533-stamp/bf533-stamp.c | 28 ++++++---- board/compulab/cm_t335/cm_t335.c | 4 +- board/compulab/cm_t35/cm_t35.c | 4 +- board/compulab/cm_t3517/cm_t3517.c | 4 +- board/corscience/tricorder/led.c | 26 +++++----- board/corscience/tricorder/tricorder.c | 6 +-- board/isee/igep00x0/igep00x0.c | 4 +- board/motionpro/motionpro.c | 45 +++++++++++----- board/olimex/mx23_olinuxino/mx23_olinuxino.c | 6 +-- board/samtec/vining_fpga/socfpga.c | 4 +- board/ti/beagle/Makefile | 2 +- board/ti/beagle/beagle.c | 6 +-- board/ti/beagle/led.c | 14 ++--- cmd/Makefile | 2 +- cmd/ide.c | 2 +- cmd/led.c | 69 ++++++++++++------------- common/board_r.c | 8 +-- configs/TQM823L_defconfig | 7 +++ configs/TQM823M_defconfig | 7 +++ configs/TQM850L_defconfig | 7 +++ configs/TQM850M_defconfig | 7 +++ configs/TQM855L_defconfig | 7 +++ configs/TQM855M_defconfig | 7 +++ configs/TQM860L_defconfig | 7 +++ configs/TQM860M_defconfig | 7 +++ configs/TQM862L_defconfig | 7 +++ configs/TQM862M_defconfig | 7 +++ configs/TQM866M_defconfig | 7 +++ configs/TQM885D_defconfig | 7 +++ configs/cl-som-am57x_defconfig | 5 ++ configs/cm_t335_defconfig | 6 +++ configs/cm_t3517_defconfig | 7 +++ configs/cm_t35_defconfig | 7 +++ configs/eb_cpu5282_defconfig | 6 +++ configs/eb_cpu5282_internal_defconfig | 6 +++ configs/edb9315a_defconfig | 12 +++++ configs/igep0020_defconfig | 7 +++ configs/igep0030_defconfig | 7 +++ configs/motionpro_defconfig | 10 ++++ configs/mx23_olinuxino_defconfig | 8 +++ configs/omap3_beagle_defconfig | 11 ++++ configs/socfpga_vining_fpga_defconfig | 11 ++++ configs/tqma6s_wru4_mmc_defconfig | 20 ++++++++ configs/tricorder_defconfig | 11 ++++ configs/tricorder_flash_defconfig | 11 ++++ configs/v38b_defconfig | 6 +++ drivers/misc/Makefile | 4 +- drivers/misc/gpio_led.c | 26 +++++----- drivers/misc/pca9551_led.c | 2 +- drivers/misc/status_led.c | 76 ++++++++++++++-------------- include/common.h | 2 +- include/configs/PATI.h | 2 - include/configs/TQM823L.h | 6 --- include/configs/TQM823M.h | 6 --- include/configs/TQM850L.h | 2 - include/configs/TQM850M.h | 2 - include/configs/TQM855L.h | 2 - include/configs/TQM855M.h | 2 - include/configs/TQM860L.h | 2 - include/configs/TQM860M.h | 2 - include/configs/TQM862L.h | 2 - include/configs/TQM862M.h | 2 - include/configs/TQM866M.h | 2 - include/configs/TQM885D.h | 2 - include/configs/bf526-ezbrd.h | 16 ------ include/configs/bf533-stamp.h | 16 ------ include/configs/cl-som-am57x.h | 11 ---- include/configs/cm_t335.h | 7 --- include/configs/cm_t35.h | 10 +--- include/configs/cm_t3517.h | 10 +--- include/configs/eb_cpu5282.h | 7 --- include/configs/edb93xx.h | 13 ----- include/configs/motionpro.h | 14 ----- include/configs/mx23_olinuxino.h | 9 ---- include/configs/omap3_beagle.h | 11 ---- include/configs/omap3_igep00x0.h | 8 --- include/configs/socfpga_vining_fpga.h | 16 ------ include/configs/stm32f429-discovery.h | 1 - include/configs/tqma6_wru4.h | 21 -------- include/configs/tricorder.h | 12 ----- include/configs/v38b.h | 2 - include/status_led.h | 59 ++++++++------------- net/bootp.c | 6 +-- net/net.c | 20 ++++---- scripts/config_whitelist.txt | 4 -- 89 files changed, 485 insertions(+), 454 deletions(-)
diff --git a/arch/arm/cpu/arm920t/ep93xx/led.c b/arch/arm/cpu/arm920t/ep93xx/led.c index ecceb98..402fa3a 100644 --- a/arch/arm/cpu/arm920t/ep93xx/led.c +++ b/arch/arm/cpu/arm920t/ep93xx/led.c @@ -9,16 +9,16 @@ #include <config.h> #include <status_led.h>
-static uint8_t saved_state[2] = {STATUS_LED_OFF, STATUS_LED_OFF}; -static uint32_t gpio_pin[2] = {1 << STATUS_LED_GREEN, - 1 << STATUS_LED_RED}; +static uint8_t saved_state[2] = {CONFIG_LED_STATUS_OFF, CONFIG_LED_STATUS_OFF}; +static uint32_t gpio_pin[2] = {1 << CONFIG_LED_STATUS_GREEN, + 1 << CONFIG_LED_STATUS_RED};
static inline void switch_LED_on(uint8_t led) { register struct gpio_regs *gpio = (struct gpio_regs *)GPIO_BASE;
writel(readl(&gpio->pedr) | gpio_pin[led], &gpio->pedr); - saved_state[led] = STATUS_LED_ON; + saved_state[led] = CONFIG_LED_STATUS_ON; }
static inline void switch_LED_off(uint8_t led) @@ -26,27 +26,27 @@ static inline void switch_LED_off(uint8_t led) register struct gpio_regs *gpio = (struct gpio_regs *)GPIO_BASE;
writel(readl(&gpio->pedr) & ~gpio_pin[led], &gpio->pedr); - saved_state[led] = STATUS_LED_OFF; + saved_state[led] = CONFIG_LED_STATUS_OFF; }
void red_led_on(void) { - switch_LED_on(STATUS_LED_RED); + switch_LED_on(CONFIG_LED_STATUS_RED); }
void red_led_off(void) { - switch_LED_off(STATUS_LED_RED); + switch_LED_off(CONFIG_LED_STATUS_RED); }
void green_led_on(void) { - switch_LED_on(STATUS_LED_GREEN); + switch_LED_on(CONFIG_LED_STATUS_GREEN); }
void green_led_off(void) { - switch_LED_off(STATUS_LED_GREEN); + switch_LED_off(CONFIG_LED_STATUS_GREEN); }
void __led_init(led_id_t mask, int state) @@ -56,13 +56,14 @@ void __led_init(led_id_t mask, int state)
void __led_toggle(led_id_t mask) { - if (STATUS_LED_RED == mask) { - if (STATUS_LED_ON == saved_state[STATUS_LED_RED]) + if (CONFIG_LED_STATUS_RED == mask) { + if (CONFIG_LED_STATUS_ON == saved_state[CONFIG_LED_STATUS_RED]) red_led_off(); else red_led_on(); - } else if (STATUS_LED_GREEN == mask) { - if (STATUS_LED_ON == saved_state[STATUS_LED_GREEN]) + } else if (CONFIG_LED_STATUS_GREEN == mask) { + if (CONFIG_LED_STATUS_ON == + saved_state[CONFIG_LED_STATUS_GREEN]) green_led_off(); else green_led_on(); @@ -71,13 +72,13 @@ void __led_toggle(led_id_t mask)
void __led_set(led_id_t mask, int state) { - if (STATUS_LED_RED == mask) { - if (STATUS_LED_ON == state) + if (CONFIG_LED_STATUS_RED == mask) { + if (CONFIG_LED_STATUS_ON == state) red_led_on(); else red_led_off(); - } else if (STATUS_LED_GREEN == mask) { - if (STATUS_LED_ON == state) + } else if (CONFIG_LED_STATUS_GREEN == mask) { + if (CONFIG_LED_STATUS_ON == state) green_led_on(); else green_led_off(); diff --git a/arch/powerpc/include/asm/status_led.h b/arch/powerpc/include/asm/status_led.h index 260a831..1ae1b17 100644 --- a/arch/powerpc/include/asm/status_led.h +++ b/arch/powerpc/include/asm/status_led.h @@ -8,7 +8,7 @@ #define __ASM_STATUS_LED_H__
/* if not overridden */ -#ifndef CONFIG_BOARD_SPECIFIC_LED +#ifndef CONFIG_LED_STATUS_BOARD_SPECIFIC # if defined(CONFIG_8xx) # include <mpc8xx.h> # elif defined(CONFIG_MPC8260) @@ -34,12 +34,12 @@ static inline void __led_init (led_id_t mask, int state) #endif
#if (STATUS_LED_ACTIVE == 0) - if (state == STATUS_LED_ON) + if (state == CONFIG_LED_STATUS_ON) immr->STATUS_LED_DAT &= ~mask; else immr->STATUS_LED_DAT |= mask; #else - if (state == STATUS_LED_ON) + if (state == CONFIG_LED_STATUS_ON) immr->STATUS_LED_DAT |= mask; else immr->STATUS_LED_DAT &= ~mask; @@ -59,12 +59,12 @@ static inline void __led_set (led_id_t mask, int state) volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR;
#if (STATUS_LED_ACTIVE == 0) - if (state == STATUS_LED_ON) + if (state == CONFIG_LED_STATUS_ON) immr->STATUS_LED_DAT &= ~mask; else immr->STATUS_LED_DAT |= mask; #else - if (state == STATUS_LED_ON) + if (state == CONFIG_LED_STATUS_ON) immr->STATUS_LED_DAT |= mask; else immr->STATUS_LED_DAT &= ~mask; diff --git a/arch/powerpc/lib/interrupts.c b/arch/powerpc/lib/interrupts.c index f7cf915..5031357 100644 --- a/arch/powerpc/lib/interrupts.c +++ b/arch/powerpc/lib/interrupts.c @@ -11,7 +11,7 @@ #include <common.h> #include <asm/processor.h> #include <watchdog.h> -#ifdef CONFIG_STATUS_LED +#ifdef CONFIG_LED_STATUS #include <status_led.h> #endif
@@ -112,9 +112,9 @@ void timer_interrupt (struct pt_regs *regs) WATCHDOG_RESET (); #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */
-#ifdef CONFIG_STATUS_LED +#ifdef CONFIG_LED_STATUS status_led_tick (timestamp); -#endif /* CONFIG_STATUS_LED */ +#endif /* CONFIG_LED_STATUS */
#ifdef CONFIG_SHOW_ACTIVITY board_show_activity (timestamp); diff --git a/board/BuS/eb_cpu5282/eb_cpu5282.c b/board/BuS/eb_cpu5282/eb_cpu5282.c index 2164b52..b1740ee 100644 --- a/board/BuS/eb_cpu5282/eb_cpu5282.c +++ b/board/BuS/eb_cpu5282/eb_cpu5282.c @@ -174,7 +174,7 @@ void __led_init(led_id_t mask, int state)
void __led_set(led_id_t mask, int state) { - if (state == STATUS_LED_ON) + if (state == CONFIG_LED_STATUS_ON) MCFGPTA_GPTPORT |= (1 << 3); else MCFGPTA_GPTPORT &= ~(1 << 3); diff --git a/board/bf533-stamp/bf533-stamp.c b/board/bf533-stamp/bf533-stamp.c index eb000a6..185a651 100644 --- a/board/bf533-stamp/bf533-stamp.c +++ b/board/bf533-stamp/bf533-stamp.c @@ -50,8 +50,8 @@ int misc_init_r(void)
#ifdef CONFIG_SHOW_BOOT_PROGRESS
-#define STATUS_LED_OFF 0 -#define STATUS_LED_ON 1 +#define CONFIG_LED_STATUS_OFF 0 +#define CONFIG_LED_STATUS_ON 1
static int gpio_setup;
@@ -76,24 +76,30 @@ void show_boot_progress(int status) { switch (status) { case BOOTSTAGE_ID_CHECK_MAGIC: - stamp_led_set(STATUS_LED_OFF, STATUS_LED_OFF, STATUS_LED_ON); + stamp_led_set(CONFIG_LED_STATUS_OFF, CONFIG_LED_STATUS_OFF, + CONFIG_LED_STATUS_ON); break; case BOOTSTAGE_ID_CHECK_HEADER: - stamp_led_set(STATUS_LED_OFF, STATUS_LED_ON, STATUS_LED_OFF); + stamp_led_set(CONFIG_LED_STATUS_OFF, CONFIG_LED_STATUS_ON, + CONFIG_LED_STATUS_OFF); break; case BOOTSTAGE_ID_CHECK_CHECKSUM: - stamp_led_set(STATUS_LED_OFF, STATUS_LED_ON, STATUS_LED_ON); + stamp_led_set(CONFIG_LED_STATUS_OFF, CONFIG_LED_STATUS_ON, + CONFIG_LED_STATUS_ON); break; case BOOTSTAGE_ID_CHECK_ARCH: - stamp_led_set(STATUS_LED_ON, STATUS_LED_OFF, STATUS_LED_OFF); + stamp_led_set(CONFIG_LED_STATUS_ON, CONFIG_LED_STATUS_OFF, + CONFIG_LED_STATUS_OFF); break; case BOOTSTAGE_ID_CHECK_IMAGETYPE: case BOOTSTAGE_ID_DECOMP_IMAGE: - stamp_led_set(STATUS_LED_ON, STATUS_LED_OFF, STATUS_LED_ON); + stamp_led_set(CONFIG_LED_STATUS_ON, CONFIG_LED_STATUS_OFF, + CONFIG_LED_STATUS_ON); break; case BOOTSTAGE_ID_KERNEL_LOADED: case BOOTSTAGE_ID_CHECK_BOOT_OS: - stamp_led_set(STATUS_LED_ON, STATUS_LED_ON, STATUS_LED_OFF); + stamp_led_set(CONFIG_LED_STATUS_ON, CONFIG_LED_STATUS_ON, + CONFIG_LED_STATUS_OFF); break; case BOOTSTAGE_ID_BOOT_OS_RETURNED: case BOOTSTAGE_ID_RD_MAGIC: @@ -102,10 +108,12 @@ void show_boot_progress(int status) case BOOTSTAGE_ID_RAMDISK: case BOOTSTAGE_ID_NO_RAMDISK: case BOOTSTAGE_ID_RUN_OS: - stamp_led_set(STATUS_LED_OFF, STATUS_LED_OFF, STATUS_LED_OFF); + stamp_led_set(CONFIG_LED_STATUS_OFF, CONFIG_LED_STATUS_OFF, + CONFIG_LED_STATUS_OFF); break; default: - stamp_led_set(STATUS_LED_ON, STATUS_LED_ON, STATUS_LED_ON); + stamp_led_set(CONFIG_LED_STATUS_ON, CONFIG_LED_STATUS_ON, + CONFIG_LED_STATUS_ON); break; } } diff --git a/board/compulab/cm_t335/cm_t335.c b/board/compulab/cm_t335/cm_t335.c index 428aee6..c4506b9 100644 --- a/board/compulab/cm_t335/cm_t335.c +++ b/board/compulab/cm_t335/cm_t335.c @@ -31,8 +31,8 @@ int board_init(void)
gpmc_init();
-#if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) - status_led_set(STATUS_LED_BOOT, STATUS_LED_OFF); +#if defined(CONFIG_LED_STATUS) && defined(CONFIG_LED_STATUS_BOOT_ENABLE) + status_led_set(CONFIG_LED_STATUS_BOOT, CONFIG_LED_STATUS_OFF); #endif return 0; } diff --git a/board/compulab/cm_t35/cm_t35.c b/board/compulab/cm_t35/cm_t35.c index 484651b..ec21955 100644 --- a/board/compulab/cm_t35/cm_t35.c +++ b/board/compulab/cm_t35/cm_t35.c @@ -92,8 +92,8 @@ int board_init(void) /* boot param addr */ gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
-#if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) - status_led_set(STATUS_LED_BOOT, STATUS_LED_ON); +#if defined(CONFIG_LED_STATUS) && defined(CONFIG_LED_STATUS_BOOT_ENABLE) + status_led_set(CONFIG_LED_STATUS_BOOT, CONFIG_LED_STATUS_ON); #endif
return 0; diff --git a/board/compulab/cm_t3517/cm_t3517.c b/board/compulab/cm_t3517/cm_t3517.c index 8aae248..50312b1 100644 --- a/board/compulab/cm_t3517/cm_t3517.c +++ b/board/compulab/cm_t3517/cm_t3517.c @@ -89,8 +89,8 @@ int board_init(void) /* boot param addr */ gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
cm_t3517_musb_init(); diff --git a/board/corscience/tricorder/led.c b/board/corscience/tricorder/led.c index 30f2f50..00ffc00 100644 --- a/board/corscience/tricorder/led.c +++ b/board/corscience/tricorder/led.c @@ -23,16 +23,16 @@ void __led_init(led_id_t mask, int state) void __led_toggle(led_id_t mask) { int toggle_gpio = 0; -#ifdef STATUS_LED_BIT - if (!toggle_gpio && STATUS_LED_BIT & mask) +#ifdef CONFIG_LED_STATUS0 + if (!toggle_gpio && CONFIG_LED_STATUS_BIT & mask) toggle_gpio = TRICORDER_STATUS_LED_GREEN; #endif -#ifdef STATUS_LED_BIT1 - if (!toggle_gpio && STATUS_LED_BIT1 & mask) +#ifdef CONFIG_LED_STATUS1 + if (!toggle_gpio && CONFIG_LED_STATUS_BIT1 & mask) toggle_gpio = TRICORDER_STATUS_LED_YELLOW; #endif -#ifdef STATUS_LED_BIT2 - if (!toggle_gpio && STATUS_LED_BIT2 & mask) { +#ifdef CONFIG_LED_STATUS2 + if (!toggle_gpio && CONFIG_LED_STATUS_BIT2 & mask) { uint8_t val; twl4030_i2c_read_u8(TWL4030_CHIP_LED, TWL4030_LED_LEDEN, &val); @@ -51,23 +51,23 @@ void __led_toggle(led_id_t mask)
void __led_set(led_id_t mask, int state) { -#ifdef STATUS_LED_BIT - if (STATUS_LED_BIT & mask) { +#ifdef CONFIG_LED_STATUS0 + if (CONFIG_LED_STATUS_BIT & mask) { gpio_request(TRICORDER_STATUS_LED_GREEN, ""); gpio_direction_output(TRICORDER_STATUS_LED_GREEN, 0); gpio_set_value(TRICORDER_STATUS_LED_GREEN, state); } #endif -#ifdef STATUS_LED_BIT1 - if (STATUS_LED_BIT1 & mask) { +#ifdef CONFIG_LED_STATUS1 + if (CONFIG_LED_STATUS_BIT1 & mask) { gpio_request(TRICORDER_STATUS_LED_YELLOW, ""); gpio_direction_output(TRICORDER_STATUS_LED_YELLOW, 0); gpio_set_value(TRICORDER_STATUS_LED_YELLOW, state); } #endif -#ifdef STATUS_LED_BIT2 - if (STATUS_LED_BIT2 & mask) { - if (STATUS_LED_OFF == state) +#ifdef CONFIG_LED_STATUS2 + if (CONFIG_LED_STATUS_BIT2 & mask) { + if (CONFIG_LED_STATUS_OFF == state) twl4030_i2c_write_u8(TWL4030_CHIP_LED, TWL4030_LED_LEDEN, 0); else diff --git a/board/corscience/tricorder/tricorder.c b/board/corscience/tricorder/tricorder.c index 0009452..e8260c6 100644 --- a/board/corscience/tricorder/tricorder.c +++ b/board/corscience/tricorder/tricorder.c @@ -120,9 +120,9 @@ int misc_init_r(void) print_hwversion(&eeprom);
twl4030_power_init(); - status_led_set(0, STATUS_LED_ON); - status_led_set(1, STATUS_LED_ON); - status_led_set(2, STATUS_LED_ON); + status_led_set(0, CONFIG_LED_STATUS_ON); + status_led_set(1, CONFIG_LED_STATUS_ON); + status_led_set(2, CONFIG_LED_STATUS_ON);
omap_die_id_display();
diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index ae7959b..e5a8038 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -68,8 +68,8 @@ int board_init(void) /* boot param addr */ gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
return 0; diff --git a/board/motionpro/motionpro.c b/board/motionpro/motionpro.c index dc237c1..7fa81b8 100644 --- a/board/motionpro/motionpro.c +++ b/board/motionpro/motionpro.c @@ -15,9 +15,9 @@ #include <miiphy.h> #include <libfdt.h>
-#if defined(CONFIG_STATUS_LED) +#if defined(CONFIG_LED_STATUS) #include <status_led.h> -#endif /* CONFIG_STATUS_LED */ +#endif /* CONFIG_LED_STATUS */
/* Kollmorgen DPR initialization data */ struct init_elem { @@ -194,27 +194,46 @@ int ft_board_setup(void *blob, bd_t *bd) #endif /* CONFIG_OF_BOARD_SETUP */
-#if defined(CONFIG_STATUS_LED) -void __led_init(led_id_t regaddr, int state) +#if defined(CONFIG_LED_STATUS) +vu_long *regcode_to_regaddr(led_id_t regcode) { - *((vu_long *) regaddr) |= ENABLE_GPIO_OUT; + /* GPT Enable and Mode Select Register address */ + vu_long *reg_translate[] = { + (vu_long *)MPC5XXX_GPT6_ENABLE, + (vu_long *)MPC5XXX_GPT7_ENABLE, + }; + + if (ARRAY_SIZE(reg_translate) <= regcode) + return NULL; + return reg_translate[regcode]; +} + +void __led_init(led_id_t regcode, int state) +{ + vu_long *regaddr = regcode_to_regaddr(regcode); + + *regaddr |= ENABLE_GPIO_OUT;
- if (state == STATUS_LED_ON) + if (state == CONFIG_LED_STATUS_ON) *((vu_long *) regaddr) |= LED_ON; else *((vu_long *) regaddr) &= ~LED_ON; }
-void __led_set(led_id_t regaddr, int state) +void __led_set(led_id_t regcode, int state) { - if (state == STATUS_LED_ON) - *((vu_long *) regaddr) |= LED_ON; + vu_long *regaddr = regcode_to_regaddr(regcode); + + if (state == CONFIG_LED_STATUS_ON) + *regaddr |= LED_ON; else - *((vu_long *) regaddr) &= ~LED_ON; + *regaddr &= ~LED_ON; }
-void __led_toggle(led_id_t regaddr) +void __led_toggle(led_id_t regcode) { - *((vu_long *) regaddr) ^= LED_ON; + vu_long *regaddr = regcode_to_regaddr(regcode); + + *regaddr ^= LED_ON; } -#endif /* CONFIG_STATUS_LED */ +#endif /* CONFIG_LED_STATUS */ diff --git a/board/olimex/mx23_olinuxino/mx23_olinuxino.c b/board/olimex/mx23_olinuxino/mx23_olinuxino.c index 65cbbf1..f05fd0a 100644 --- a/board/olimex/mx23_olinuxino/mx23_olinuxino.c +++ b/board/olimex/mx23_olinuxino/mx23_olinuxino.c @@ -13,7 +13,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> -#ifdef CONFIG_STATUS_LED +#ifdef CONFIG_LED_STATUS #include <status_led.h> #endif
@@ -72,8 +72,8 @@ int board_init(void) /* Adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
-#if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) - status_led_set(STATUS_LED_BOOT, STATUS_LED_STATE); +#if defined(CONFIG_LED_STATUS) && defined(CONFIG_LED_STATUS_BOOT_ENABLE) + status_led_set(CONFIG_LED_STATUS_BOOT, CONFIG_LED_STATUS_STATE); #endif
return 0; diff --git a/board/samtec/vining_fpga/socfpga.c b/board/samtec/vining_fpga/socfpga.c index f3a92b5..f888ecb 100644 --- a/board/samtec/vining_fpga/socfpga.c +++ b/board/samtec/vining_fpga/socfpga.c @@ -21,8 +21,8 @@ int board_late_init(void) const unsigned int usb_nrst_gpio = 35; int ret;
- status_led_set(1, STATUS_LED_ON); - status_led_set(2, STATUS_LED_ON); + status_led_set(1, CONFIG_LED_STATUS_ON); + status_led_set(2, CONFIG_LED_STATUS_ON);
/* Address of boot parameters for ATAG (if ATAG is used) */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; diff --git a/board/ti/beagle/Makefile b/board/ti/beagle/Makefile index 7a858be..41b552a 100644 --- a/board/ti/beagle/Makefile +++ b/board/ti/beagle/Makefile @@ -6,4 +6,4 @@ #
obj-y := beagle.o -obj-$(CONFIG_STATUS_LED) += led.o +obj-$(CONFIG_LED_STATUS) += led.o diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index cfdab3e..178bee5 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -16,7 +16,7 @@ #include <common.h> #include <dm.h> #include <ns16550.h> -#ifdef CONFIG_STATUS_LED +#ifdef CONFIG_LED_STATUS #include <status_led.h> #endif #include <twl4030.h> @@ -95,8 +95,8 @@ int board_init(void) /* boot param addr */ gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
-#if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) - status_led_set (STATUS_LED_BOOT, STATUS_LED_ON); +#if defined(CONFIG_LED_STATUS) && defined(CONFIG_LED_STATUS_BOOT_ENABLE) + status_led_set(CONFIG_LED_STATUS_BOOT, CONFIG_LED_STATUS_ON); #endif
return 0; diff --git a/board/ti/beagle/led.c b/board/ti/beagle/led.c index a913a4c..30b8b93 100644 --- a/board/ti/beagle/led.c +++ b/board/ti/beagle/led.c @@ -15,26 +15,26 @@ #define BEAGLE_LED_USR0 150 #define BEAGLE_LED_USR1 149
-#ifdef STATUS_LED_GREEN +#ifdef CONFIG_LED_STATUS_GREEN void green_led_off(void) { - __led_set (STATUS_LED_GREEN, 0); + __led_set(CONFIG_LED_STATUS_GREEN, 0); }
void green_led_on(void) { - __led_set (STATUS_LED_GREEN, 1); + __led_set(CONFIG_LED_STATUS_GREEN, 1); } #endif
static int get_led_gpio(led_id_t mask) { -#ifdef STATUS_LED_BIT - if (STATUS_LED_BIT & mask) +#ifdef CONFIG_LED_STATUS0 + if (CONFIG_LED_STATUS_BIT & mask) return BEAGLE_LED_USR0; #endif -#ifdef STATUS_LED_BIT1 - if (STATUS_LED_BIT1 & mask) +#ifdef CONFIG_LED_STATUS1 + if (CONFIG_LED_STATUS_BIT1 & mask) return BEAGLE_LED_USR1; #endif
diff --git a/cmd/Makefile b/cmd/Makefile index 34bc544..566fed9 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -78,7 +78,7 @@ obj-$(CONFIG_CMD_ITEST) += itest.o obj-$(CONFIG_CMD_JFFS2) += jffs2.o obj-$(CONFIG_CMD_CRAMFS) += cramfs.o obj-$(CONFIG_CMD_LDRINFO) += ldrinfo.o -obj-$(CONFIG_CMD_LED) += led.o +obj-$(CONFIG_LED_STATUS_CMD) += led.o obj-$(CONFIG_CMD_LICENSE) += license.o obj-y += load.o obj-$(CONFIG_LOGBUFFER) += log.o diff --git a/cmd/ide.c b/cmd/ide.c index c942744..0fd401b 100644 --- a/cmd/ide.c +++ b/cmd/ide.c @@ -25,7 +25,7 @@ #include <ide.h> #include <ata.h>
-#ifdef CONFIG_STATUS_LED +#ifdef CONFIG_LED_STATUS # include <status_led.h> #endif
diff --git a/cmd/led.c b/cmd/led.c index b0f1a61..951a5e2 100644 --- a/cmd/led.c +++ b/cmd/led.c @@ -26,37 +26,38 @@ struct led_tbl_s { typedef struct led_tbl_s led_tbl_t;
static const led_tbl_t led_commands[] = { -#ifdef CONFIG_BOARD_SPECIFIC_LED -#ifdef STATUS_LED_BIT - { "0", STATUS_LED_BIT, NULL, NULL, NULL }, +#ifdef CONFIG_LED_STATUS_BOARD_SPECIFIC +#ifdef CONFIG_LED_STATUS0 + { "0", CONFIG_LED_STATUS_BIT, NULL, NULL, NULL }, #endif -#ifdef STATUS_LED_BIT1 - { "1", STATUS_LED_BIT1, NULL, NULL, NULL }, +#ifdef CONFIG_LED_STATUS1 + { "1", CONFIG_LED_STATUS_BIT1, NULL, NULL, NULL }, #endif -#ifdef STATUS_LED_BIT2 - { "2", STATUS_LED_BIT2, NULL, NULL, NULL }, +#ifdef CONFIG_LED_STATUS2 + { "2", CONFIG_LED_STATUS_BIT2, NULL, NULL, NULL }, #endif -#ifdef STATUS_LED_BIT3 - { "3", STATUS_LED_BIT3, NULL, NULL, NULL }, +#ifdef CONFIG_LED_STATUS3 + { "3", CONFIG_LED_STATUS_BIT3, NULL, NULL, NULL }, #endif -#ifdef STATUS_LED_BIT4 - { "4", STATUS_LED_BIT4, NULL, NULL, NULL }, +#ifdef CONFIG_LED_STATUS4 + { "4", CONFIG_LED_STATUS_BIT4, NULL, NULL, NULL }, #endif -#ifdef STATUS_LED_BIT5 - { "5", STATUS_LED_BIT5, NULL, NULL, NULL }, +#ifdef CONFIG_LED_STATUS5 + { "5", CONFIG_LED_STATUS_BIT5, NULL, NULL, NULL }, #endif #endif -#ifdef STATUS_LED_GREEN - { "green", STATUS_LED_GREEN, green_led_off, green_led_on, NULL }, +#ifdef CONFIG_LED_STATUS_GREEN + { "green", CONFIG_LED_STATUS_GREEN, green_led_off, green_led_on, NULL }, #endif -#ifdef STATUS_LED_YELLOW - { "yellow", STATUS_LED_YELLOW, yellow_led_off, yellow_led_on, NULL }, +#ifdef CONFIG_LED_STATUS_YELLOW + { "yellow", CONFIG_LED_STATUS_YELLOW, yellow_led_off, yellow_led_on, + NULL }, #endif -#ifdef STATUS_LED_RED - { "red", STATUS_LED_RED, red_led_off, red_led_on, NULL }, +#ifdef CONFIG_LED_STATUS_RED + { "red", CONFIG_LED_STATUS_RED, red_led_off, red_led_on, NULL }, #endif -#ifdef STATUS_LED_BLUE - { "blue", STATUS_LED_BLUE, blue_led_off, blue_led_on, NULL }, +#ifdef CONFIG_LED_STATUS_BLUE + { "blue", CONFIG_LED_STATUS_BLUE, blue_led_off, blue_led_on, NULL }, #endif { NULL, 0, NULL, NULL, NULL } }; @@ -110,14 +111,14 @@ int do_led (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) led_commands[i].on(); else __led_set(led_commands[i].mask, - STATUS_LED_ON); + CONFIG_LED_STATUS_ON); break; case LED_OFF: if (led_commands[i].off) led_commands[i].off(); else __led_set(led_commands[i].mask, - STATUS_LED_OFF); + CONFIG_LED_STATUS_OFF); break; case LED_TOGGLE: if (led_commands[i].toggle) @@ -149,36 +150,36 @@ int do_led (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( led, 4, 1, do_led, "[" -#ifdef CONFIG_BOARD_SPECIFIC_LED -#ifdef STATUS_LED_BIT +#ifdef CONFIG_LED_STATUS_BOARD_SPECIFIC +#ifdef CONFIG_LED_STATUS0 "0|" #endif -#ifdef STATUS_LED_BIT1 +#ifdef CONFIG_LED_STATUS1 "1|" #endif -#ifdef STATUS_LED_BIT2 +#ifdef CONFIG_LED_STATUS2 "2|" #endif -#ifdef STATUS_LED_BIT3 +#ifdef CONFIG_LED_STATUS3 "3|" #endif -#ifdef STATUS_LED_BIT4 +#ifdef CONFIG_LED_STATUS4 "4|" #endif -#ifdef STATUS_LED_BIT5 +#ifdef CONFIG_LED_STATUS5 "5|" #endif #endif -#ifdef STATUS_LED_GREEN +#ifdef CONFIG_LED_STATUS_GREEN "green|" #endif -#ifdef STATUS_LED_YELLOW +#ifdef CONFIG_LED_STATUS_YELLOW "yellow|" #endif -#ifdef STATUS_LED_RED +#ifdef CONFIG_LED_STATUS_RED "red|" #endif -#ifdef STATUS_LED_BLUE +#ifdef CONFIG_LED_STATUS_BLUE "blue|" #endif "all] [on|off|toggle|blink] [blink-freq in ms]", diff --git a/common/board_r.c b/common/board_r.c index a373352..46a43b9 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -596,11 +596,11 @@ static int initr_kgdb(void) } #endif
-#if defined(CONFIG_STATUS_LED) +#if defined(CONFIG_LED_STATUS) static int initr_status_led(void) { -#if defined(STATUS_LED_BOOT) - status_led_set(STATUS_LED_BOOT, STATUS_LED_BLINKING); +#if defined(CONFIG_LED_STATUS_BOOT) + status_led_set(CONFIG_LED_STATUS_BOOT, CONFIG_LED_STATUS_BLINKING); #else status_led_init(); #endif @@ -907,7 +907,7 @@ init_fnc_t init_sequence_r[] = { #if defined(CONFIG_MICROBLAZE) || defined(CONFIG_AVR32) || defined(CONFIG_M68K) timer_init, /* initialize timer */ #endif -#if defined(CONFIG_STATUS_LED) +#if defined(CONFIG_LED_STATUS) initr_status_led, #endif /* PPC has a udelay(20) here dating from 2002. Why? */ diff --git a/configs/TQM823L_defconfig b/configs/TQM823L_defconfig index 7081ed6..8645193 100644 --- a/configs/TQM823L_defconfig +++ b/configs/TQM823L_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823M_defconfig b/configs/TQM823M_defconfig index 496dc06..08bf149 100644 --- a/configs/TQM823M_defconfig +++ b/configs/TQM823M_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850L_defconfig b/configs/TQM850L_defconfig index 0f711d1..1b87bcb 100644 --- a/configs/TQM850L_defconfig +++ b/configs/TQM850L_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850M_defconfig b/configs/TQM850M_defconfig index 7a72ce9..15aa30b 100644 --- a/configs/TQM850M_defconfig +++ b/configs/TQM850M_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855L_defconfig b/configs/TQM855L_defconfig index b034a04..aa8b4a0 100644 --- a/configs/TQM855L_defconfig +++ b/configs/TQM855L_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855M_defconfig b/configs/TQM855M_defconfig index 05b4518..3a80d5a 100644 --- a/configs/TQM855M_defconfig +++ b/configs/TQM855M_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860L_defconfig b/configs/TQM860L_defconfig index 5d8a088..8885164 100644 --- a/configs/TQM860L_defconfig +++ b/configs/TQM860L_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860M_defconfig b/configs/TQM860M_defconfig index 023751d..00196f7 100644 --- a/configs/TQM860M_defconfig +++ b/configs/TQM860M_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862L_defconfig b/configs/TQM862L_defconfig index 628d687..1fff2b4 100644 --- a/configs/TQM862L_defconfig +++ b/configs/TQM862L_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862M_defconfig b/configs/TQM862M_defconfig index d1cf91c..afd6d6e 100644 --- a/configs/TQM862M_defconfig +++ b/configs/TQM862M_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM866M_defconfig b/configs/TQM866M_defconfig index e0cf770..cb2c869 100644 --- a/configs/TQM866M_defconfig +++ b/configs/TQM866M_defconfig @@ -10,5 +10,12 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM885D_defconfig b/configs/TQM885D_defconfig index 889de7b..89bc242 100644 --- a/configs/TQM885D_defconfig +++ b/configs/TQM885D_defconfig @@ -13,5 +13,12 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y +CONFIG_LED_STATUS=y +# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index 5d3bc11..6711075 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -23,6 +23,11 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=37 +CONFIG_LED_STATUS_STATE=2 CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index e2c8162..b21631c 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -35,6 +35,12 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=64 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index 115e451..1997e56 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -20,6 +20,13 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=186 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 4d9b203..9d23243 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -22,6 +22,13 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=186 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index 03d8e43..d53c6e8 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -12,4 +12,10 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=8 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 +CONFIG_LED_STATUS_CMD=y # CONFIG_CFB_CONSOLE is not set diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 04d094a..1aed49a 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -11,4 +11,10 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=8 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 +CONFIG_LED_STATUS_CMD=y # CONFIG_CFB_CONSOLE is not set diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index 9e8c6bb..86ae479 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -15,5 +15,17 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=0 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS1=y +CONFIG_LED_STATUS_BIT1=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 +CONFIG_LED_STATUS_RED_ENABLE=y +CONFIG_LED_STATUS_RED=1 +CONFIG_LED_STATUS_GREEN_ENABLE=y +CONFIG_LED_STATUS_GREEN=0 CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 50bb4ac..5fc0340 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -34,6 +34,13 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=27 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 42bd6fc..8acdccc 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -26,6 +26,13 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_UBI=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=16 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/motionpro_defconfig b/configs/motionpro_defconfig index d5c9317..371ee2e 100644 --- a/configs/motionpro_defconfig +++ b/configs/motionpro_defconfig @@ -15,5 +15,15 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=0 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_FREQ=10 +CONFIG_LED_STATUS1=y +CONFIG_LED_STATUS_BIT1=1 +CONFIG_LED_STATUS_FREQ1=10 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index f67bb78..00cff96 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -19,6 +19,14 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=59 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 +CONFIG_LED_STATUS_CMD=y CONFIG_MMC_MXS=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 32626a2..5050a39 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -18,6 +18,17 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS1=y +CONFIG_LED_STATUS_BIT1=2 +CONFIG_LED_STATUS_STATE1=2 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=1 +CONFIG_LED_STATUS_GREEN_ENABLE=y +CONFIG_LED_STATUS_GREEN=2 CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index f01b569..fb9bae4 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -46,6 +46,17 @@ CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS_GPIO=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=48 +CONFIG_LED_STATUS1=y +CONFIG_LED_STATUS_BIT1=53 +CONFIG_LED_STATUS2=y +CONFIG_LED_STATUS_BIT2=54 +CONFIG_LED_STATUS3=y +CONFIG_LED_STATUS_BIT3=65 +CONFIG_LED_STATUS_CMD=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_SPI_FLASH=y diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index e5cfcc6..2902c93 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -28,6 +28,26 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=0 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS1=y +CONFIG_LED_STATUS_BIT1=1 +CONFIG_LED_STATUS_STATE1=2 +CONFIG_LED_STATUS2=y +CONFIG_LED_STATUS_BIT2=2 +CONFIG_LED_STATUS_STATE2=2 +CONFIG_LED_STATUS3=y +CONFIG_LED_STATUS_BIT3=3 +CONFIG_LED_STATUS_STATE3=2 +CONFIG_LED_STATUS4=y +CONFIG_LED_STATUS_BIT4=4 +CONFIG_LED_STATUS_STATE4=2 +CONFIG_LED_STATUS5=y +CONFIG_LED_STATUS_BIT5=5 +CONFIG_LED_STATUS_STATE5=2 +CONFIG_LED_STATUS_CMD=y CONFIG_PCA9551_LED=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 12a6843..9a2e5c6 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -18,6 +18,17 @@ CONFIG_CMD_I2C=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS1=y +CONFIG_LED_STATUS_BIT1=2 +CONFIG_LED_STATUS_STATE1=2 +CONFIG_LED_STATUS2=y +CONFIG_LED_STATUS_BIT2=4 +CONFIG_LED_STATUS_STATE2=2 +CONFIG_LED_STATUS_CMD=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 32c2059..a477091 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -18,6 +18,17 @@ CONFIG_CMD_I2C=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=1 +CONFIG_LED_STATUS_STATE=2 +CONFIG_LED_STATUS1=y +CONFIG_LED_STATUS_BIT1=2 +CONFIG_LED_STATUS_STATE1=2 +CONFIG_LED_STATUS2=y +CONFIG_LED_STATUS_BIT2=4 +CONFIG_LED_STATUS_STATE2=2 +CONFIG_LED_STATUS_CMD=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/v38b_defconfig b/configs/v38b_defconfig index fb198b6..e5dd07a 100644 --- a/configs/v38b_defconfig +++ b/configs/v38b_defconfig @@ -10,6 +10,12 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_LED_STATUS=y +CONFIG_LED_STATUS0=y +CONFIG_LED_STATUS_BIT=16 +CONFIG_LED_STATUS_STATE=1 +CONFIG_LED_STATUS_BOOT_ENABLE=y +CONFIG_LED_STATUS_BOOT=0 # CONFIG_PCI is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 9fbb5a7..e3151ea 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -18,7 +18,7 @@ obj-$(CONFIG_CROS_EC_SANDBOX) += cros_ec_sandbox.o obj-$(CONFIG_CROS_EC_SPI) += cros_ec_spi.o endif obj-$(CONFIG_FSL_IIM) += fsl_iim.o -obj-$(CONFIG_GPIO_LED) += gpio_led.o +obj-$(CONFIG_LED_STATUS_GPIO) += gpio_led.o obj-$(CONFIG_I2C_EEPROM) += i2c_eeprom.o obj-$(CONFIG_FSL_MC9SDZ60) += mc9sdz60.o obj-$(CONFIG_MXC_OCOTP) += mxc_ocotp.o @@ -34,7 +34,7 @@ endif endif obj-$(CONFIG_SMSC_LPC47M) += smsc_lpc47m.o obj-$(CONFIG_SMSC_SIO1007) += smsc_sio1007.o -obj-$(CONFIG_STATUS_LED) += status_led.o +obj-$(CONFIG_LED_STATUS) += status_led.o obj-$(CONFIG_SANDBOX) += swap_case.o ifdef CONFIG_SPL_OF_PLATDATA ifdef CONFIG_SPL_BUILD diff --git a/drivers/misc/gpio_led.c b/drivers/misc/gpio_led.c index 164c30d..b913069 100644 --- a/drivers/misc/gpio_led.c +++ b/drivers/misc/gpio_led.c @@ -17,7 +17,7 @@ static led_id_t gpio_led_inv[] = CONFIG_GPIO_LED_INVERTED_TABLE;
static int gpio_led_gpio_value(led_id_t mask, int state) { - int i, gpio_value = (state == STATUS_LED_ON); + int i, gpio_value = (state == CONFIG_LED_STATUS_ON);
for (i = 0; i < ARRAY_SIZE(gpio_led_inv); i++) { if (gpio_led_inv[i] == mask) @@ -56,51 +56,51 @@ void __led_toggle(led_id_t mask)
/* 'generic' override of colored LED stubs, to use GPIO functions instead */
-#ifdef STATUS_LED_RED +#ifdef CONFIG_LED_STATUS_RED void red_led_on(void) { - __led_set(STATUS_LED_RED, STATUS_LED_ON); + __led_set(CONFIG_LED_STATUS_RED, CONFIG_LED_STATUS_ON); }
void red_led_off(void) { - __led_set(STATUS_LED_RED, STATUS_LED_OFF); + __led_set(CONFIG_LED_STATUS_RED, CONFIG_LED_STATUS_OFF); } #endif
-#ifdef STATUS_LED_GREEN +#ifdef CONFIG_LED_STATUS_GREEN void green_led_on(void) { - __led_set(STATUS_LED_GREEN, STATUS_LED_ON); + __led_set(CONFIG_LED_STATUS_GREEN, CONFIG_LED_STATUS_ON); }
void green_led_off(void) { - __led_set(STATUS_LED_GREEN, STATUS_LED_OFF); + __led_set(CONFIG_LED_STATUS_GREEN, CONFIG_LED_STATUS_OFF); } #endif
-#ifdef STATUS_LED_YELLOW +#ifdef CONFIG_LED_STATUS_YELLOW void yellow_led_on(void) { - __led_set(STATUS_LED_YELLOW, STATUS_LED_ON); + __led_set(CONFIG_LED_STATUS_YELLOW, CONFIG_LED_STATUS_ON); }
void yellow_led_off(void) { - __led_set(STATUS_LED_YELLOW, STATUS_LED_OFF); + __led_set(CONFIG_LED_STATUS_YELLOW, CONFIG_LED_STATUS_OFF); } #endif
-#ifdef STATUS_LED_BLUE +#ifdef CONFIG_LED_STATUS_BLUE void blue_led_on(void) { - __led_set(STATUS_LED_BLUE, STATUS_LED_ON); + __led_set(CONFIG_LED_STATUS_BLUE, CONFIG_LED_STATUS_ON); }
void blue_led_off(void) { - __led_set(STATUS_LED_BLUE, STATUS_LED_OFF); + __led_set(CONFIG_LED_STATUS_BLUE, CONFIG_LED_STATUS_OFF); } #endif
diff --git a/drivers/misc/pca9551_led.c b/drivers/misc/pca9551_led.c index 4da0319..226a31a 100644 --- a/drivers/misc/pca9551_led.c +++ b/drivers/misc/pca9551_led.c @@ -124,7 +124,7 @@ void __led_init(led_id_t id, int state)
void __led_set(led_id_t mask, int state) { - if (state == STATUS_LED_OFF) + if (state == CONFIG_LED_STATUS_OFF) pca9551_led_set_state(mask, PCA9551_LED_STATE_OFF); else pca9551_led_set_state(mask, PCA9551_LED_STATE_ON); diff --git a/drivers/misc/status_led.c b/drivers/misc/status_led.c index 31e8831..3773c85 100644 --- a/drivers/misc/status_led.c +++ b/drivers/misc/status_led.c @@ -27,45 +27,45 @@ typedef struct { } led_dev_t;
led_dev_t led_dev[] = { - { STATUS_LED_BIT, - STATUS_LED_STATE, - STATUS_LED_PERIOD, - 0, - }, -#if defined(STATUS_LED_BIT1) - { STATUS_LED_BIT1, - STATUS_LED_STATE1, - STATUS_LED_PERIOD1, - 0, - }, + { CONFIG_LED_STATUS_BIT, + CONFIG_LED_STATUS_STATE, + LED_STATUS_PERIOD, + 0, + }, +#if defined(CONFIG_LED_STATUS1) + { CONFIG_LED_STATUS_BIT1, + CONFIG_LED_STATUS_STATE1, + LED_STATUS_PERIOD1, + 0, + }, #endif -#if defined(STATUS_LED_BIT2) - { STATUS_LED_BIT2, - STATUS_LED_STATE2, - STATUS_LED_PERIOD2, - 0, - }, +#if defined(CONFIG_LED_STATUS2) + { CONFIG_LED_STATUS_BIT2, + CONFIG_LED_STATUS_STATE2, + LED_STATUS_PERIOD2, + 0, + }, #endif -#if defined(STATUS_LED_BIT3) - { STATUS_LED_BIT3, - STATUS_LED_STATE3, - STATUS_LED_PERIOD3, - 0, - }, +#if defined(CONFIG_LED_STATUS3) + { CONFIG_LED_STATUS_BIT3, + CONFIG_LED_STATUS_STATE3, + LED_STATUS_PERIOD3, + 0, + }, #endif -#if defined(STATUS_LED_BIT4) - { STATUS_LED_BIT4, - STATUS_LED_STATE4, - STATUS_LED_PERIOD4, - 0, - }, +#if defined(CONFIG_LED_STATUS4) + { CONFIG_LED_STATUS_BIT4, + CONFIG_LED_STATUS_STATE4, + LED_STATUS_PERIOD4, + 0, + }, #endif -#if defined(STATUS_LED_BIT5) - { STATUS_LED_BIT5, - STATUS_LED_STATE5, - STATUS_LED_PERIOD5, - 0, - }, +#if defined(CONFIG_LED_STATUS5) + { CONFIG_LED_STATUS_BIT5, + CONFIG_LED_STATUS_STATE5, + LED_STATUS_PERIOD5, + 0, + }, #endif };
@@ -93,7 +93,7 @@ void status_led_tick (ulong timestamp)
for (i = 0, ld = led_dev; i < MAX_LED_DEV; i++, ld++) {
- if (ld->state != STATUS_LED_BLINKING) + if (ld->state != CONFIG_LED_STATUS_BLINKING) continue;
if (++ld->cnt >= ld->period) { @@ -117,9 +117,9 @@ void status_led_set (int led, int state) ld = &led_dev[led];
ld->state = state; - if (state == STATUS_LED_BLINKING) { + if (state == CONFIG_LED_STATUS_BLINKING) { ld->cnt = 0; /* always start with full period */ - state = STATUS_LED_ON; /* always start with LED _ON_ */ + state = CONFIG_LED_STATUS_ON; /* always start with LED _ON_ */ } __led_set (ld->mask, state); } diff --git a/include/common.h b/include/common.h index 695478c..2af555e 100644 --- a/include/common.h +++ b/include/common.h @@ -911,7 +911,7 @@ static inline struct in_addr getenv_ip(char *var)
int pcmcia_init (void);
diff --git a/include/configs/PATI.h b/include/configs/PATI.h index c8d0a58..9589c35 100644 --- a/include/configs/PATI.h +++ b/include/configs/PATI.h @@ -50,8 +50,6 @@
#define CONFIG_WATCHDOG /* turn on platform specific watchdog */
-/*#define CONFIG_STATUS_LED 1 */ /* Enable status led */ - #define CONFIG_LOADS_ECHO 1 /* Echo on for serial download */
/* diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 2fd5fa3..41879f8 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -76,12 +76,6 @@
#undef CONFIG_WATCHDOG /* watchdog disabled */
-#if defined(CONFIG_LCD) -# undef CONFIG_STATUS_LED /* disturbs display */ -#else -# define CONFIG_STATUS_LED 1 /* Status LED enabled */ -#endif /* CONFIG_LCD */ - #undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */
/* diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 11bba09..ad5c922 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -74,12 +74,6 @@
-#ifdef CONFIG_LCD -# undef CONFIG_STATUS_LED /* disturbs display */ -#else -# define CONFIG_STATUS_LED 1 /* Status LED enabled */ -#endif /* CONFIG_LCD */ - #undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */
/* diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 548f1bc..03c7cb9 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -69,8 +69,6 @@
-#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - #undef CONFIG_CAN_DRIVER /* CAN Driver support disabled */
/* diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 582b934..3c716ce 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -69,8 +69,6 @@
/* diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index 814290f..c4c90aa 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -71,8 +71,6 @@
/* diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index 4a657ff..56e2a45 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -71,8 +71,6 @@
/* enable I2C and select the hardware/software driver */ diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index bdfe509..1875609 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -71,8 +71,6 @@
/* diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index ce6b404..15df1da 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -71,8 +71,6 @@
/* diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index 66dbcb6..b3b0722 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -74,8 +74,6 @@
/* diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index 478f16b..45f10e5 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -74,8 +74,6 @@
/* diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 5501622..8f3efec 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -85,8 +85,6 @@
/* enable I2C and select the hardware/software driver */ diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index b246926..d75b25d 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -79,8 +79,6 @@
/* enable I2C and select the hardware/software driver */ diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index d0a364c..7d75e73 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -138,22 +138,6 @@ #define CONFIG_UART_CONSOLE 1
/* define to enable run status via led */ -/* #define CONFIG_STATUS_LED */ -#ifdef CONFIG_STATUS_LED -#define CONFIG_GPIO_LED -#define CONFIG_BOARD_SPECIFIC_LED -/* use LED0 to indicate booting/alive */ -#define STATUS_LED_BOOT 0 -#define STATUS_LED_BIT GPIO_PF8 -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 4) -/* use LED1 to indicate crash */ -#define STATUS_LED_CRASH 1 -#define STATUS_LED_BIT1 GPIO_PG11 -#define STATUS_LED_STATE1 STATUS_LED_ON -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) -/* #define STATUS_LED_BIT2 GPIO_PG12 */ -#endif
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index ec4d93c..afb3ef6 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -186,22 +186,6 @@ /* #define CONFIG_SHOW_BOOT_PROGRESS */
/* define to enable run status via led */ -/* #define CONFIG_STATUS_LED */ -#ifdef CONFIG_STATUS_LED -#define CONFIG_GPIO_LED -#define CONFIG_BOARD_SPECIFIC_LED -/* use LED0 to indicate booting/alive */ -#define STATUS_LED_BOOT 0 -#define STATUS_LED_BIT GPIO_PF2 -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 4) -/* use LED1 to indicate crash */ -#define STATUS_LED_CRASH 1 -#define STATUS_LED_BIT1 GPIO_PF3 -#define STATUS_LED_STATE1 STATUS_LED_ON -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) -/* #define STATUS_LED_BIT2 GPIO_PF4 */ -#endif
/* define to enable splash screen support */
diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index 8297182..6692acc 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -28,17 +28,6 @@ #define CONFIG_MISC_INIT_R #define CONFIG_REVISION_TAG
-/* Status LED */ -#define CONFIG_STATUS_LED /* Status LED enabled */ -#define CONFIG_GPIO_LED -#define CONFIG_BOARD_SPECIFIC_LED -#define GREEN_LED_DEV 0 - /* cl_som_am57x Green LED is GPIO2_5 */ -#define GREEN_LED_GPIO 37 -#define STATUS_LED_BIT GREEN_LED_GPIO -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) - /* PMIC I2C bus number */ #define CONFIG_SYS_SPD_BUS_NUM 3
diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 8f24174..0076e65 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -153,14 +153,7 @@ #define GPIO_PIN(_bank, _pin) ((_bank << 5) + _pin)
/* Status LED */ -#define CONFIG_STATUS_LED -#define CONFIG_GPIO_LED -#define CONFIG_BOARD_SPECIFIC_LED -#define STATUS_LED_BIT GPIO_PIN(2, 0) /* Status LED polarity is inversed, so init it in the "off" state */ -#define STATUS_LED_STATE STATUS_LED_OFF -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BOOT 0
/* EEPROM */ #define CONFIG_CMD_EEPROM diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 0c72443..ab695cb 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -254,20 +254,12 @@ GENERATED_GBL_DATA_SIZE)
/* Status LED */ -#define CONFIG_STATUS_LED /* Status LED enabled */ -#define CONFIG_BOARD_SPECIFIC_LED -#define CONFIG_GPIO_LED #define GREEN_LED_GPIO 186 /* CM-T35 Green LED is GPIO186 */ -#define GREEN_LED_DEV 0 -#define STATUS_LED_BIT GREEN_LED_GPIO -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BOOT GREEN_LED_DEV
#define CONFIG_SPLASHIMAGE_GUARD
/* GPIO banks */ -#ifdef CONFIG_STATUS_LED +#ifdef CONFIG_LED_STATUS #define CONFIG_OMAP3_GPIO_6 /* GPIO186 is in GPIO bank 6 */ #endif
diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 874a889..6ee61d5 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -257,18 +257,10 @@ GENERATED_GBL_DATA_SIZE)
/* Status LED */ -#define CONFIG_STATUS_LED /* Status LED enabled */ -#define CONFIG_BOARD_SPECIFIC_LED -#define CONFIG_GPIO_LED #define GREEN_LED_GPIO 186 /* CM-T3517 Green LED is GPIO186 */ -#define GREEN_LED_DEV 0 -#define STATUS_LED_BIT GREEN_LED_GPIO -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BOOT GREEN_LED_DEV
diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 4a868c5..dc08db6 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -35,13 +35,7 @@
#define CONFIG_HW_WATCHDOG
-#define CONFIG_STATUS_LED -#define CONFIG_BOARD_SPECIFIC_LED #define STATUS_LED_ACTIVE 0 -#define STATUS_LED_BIT 0x0008 /* Timer7 GPIO */ -#define STATUS_LED_BOOT 0 -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_STATE STATUS_LED_OFF
/*----------------------------------------------------------------------* * Configuration for environment * @@ -65,7 +59,6 @@ */ #define CONFIG_CMDLINE_EDITING #define CONFIG_CMD_DATE -#define CONFIG_CMD_LED
#define CONFIG_MCFTMR
diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 9080b9a..9cc62ed 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -102,20 +102,7 @@ #define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0}
/* Status LED */ -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ -#define CONFIG_BOARD_SPECIFIC_LED 1 -#define STATUS_LED_GREEN 0 -#define STATUS_LED_RED 1 -/* Green */ -#define STATUS_LED_BIT STATUS_LED_GREEN -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -/* Red */ -#define STATUS_LED_BIT1 STATUS_LED_RED -#define STATUS_LED_STATE1 STATUS_LED_OFF -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) /* Optional value */ -#define STATUS_LED_BOOT STATUS_LED_BIT
/* Network hardware configuration */ #define CONFIG_DRIVER_EP93XX_MAC diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index 917350f..9b8a7ea 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -283,24 +283,10 @@ /* * Status LED configuration */ -#define CONFIG_STATUS_LED /* Status LED enabled */ -#define CONFIG_BOARD_SPECIFIC_LED
#define ENABLE_GPIO_OUT 0x00000024 #define LED_ON 0x00000010
-#ifndef __ASSEMBLY__ -/* - * In case of Motion-PRO, a LED is identified by its corresponding - * GPT Enable and Mode Select Register. - */ -typedef volatile unsigned long * led_id_t; - -extern void __led_init(led_id_t id, int state); -extern void __led_toggle(led_id_t id); -extern void __led_set(led_id_t id, int state); -#endif /* __ASSEMBLY__ */ - /* * Temperature sensor */ diff --git a/include/configs/mx23_olinuxino.h b/include/configs/mx23_olinuxino.h index 36ff7ce..d05b922 100644 --- a/include/configs/mx23_olinuxino.h +++ b/include/configs/mx23_olinuxino.h @@ -14,8 +14,6 @@ #define CONFIG_SYS_NO_FLASH #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_LED - /* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ @@ -34,13 +32,6 @@ #endif
/* Status LED */ -#define CONFIG_STATUS_LED -#define CONFIG_GPIO_LED -#define CONFIG_BOARD_SPECIFIC_LED -#define STATUS_LED_BOOT 0 -#define STATUS_LED_BIT MX23_PAD_SSP1_DETECT__GPIO_2_1 -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2)
/* USB */ #ifdef CONFIG_CMD_USB diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 9850aa6..c69b325 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -35,16 +35,6 @@ #define CONFIG_ENV_OVERWRITE
/* Status LED */ -#define CONFIG_STATUS_LED 1 -#define CONFIG_BOARD_SPECIFIC_LED 1 -#define STATUS_LED_BIT 0x01 -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT1 0x02 -#define STATUS_LED_STATE1 STATUS_LED_ON -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BOOT STATUS_LED_BIT -#define STATUS_LED_GREEN STATUS_LED_BIT1
/* Enable Multi Bus support for I2C */ #define CONFIG_I2C_MULTI_BUS 1 @@ -88,7 +78,6 @@ "4m(kernel),-(fs)"
#define CONFIG_CMD_NAND /* NAND support */ -#define CONFIG_CMD_LED /* LED support */
#define CONFIG_VIDEO_OMAP3 /* DSS Support */
diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index e6d7db0..ac0df3e 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -30,19 +30,11 @@ /* Status LED available for IGEP0020 and IGEP0030 but not IGEP0032 */ #if (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0020) || \ (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0030) -#define CONFIG_STATUS_LED -#define CONFIG_BOARD_SPECIFIC_LED -#define CONFIG_GPIO_LED #if (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0020) #define RED_LED_GPIO 27 #elif (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0030) #define RED_LED_GPIO 16 #endif -#define RED_LED_DEV 0 -#define STATUS_LED_BIT RED_LED_GPIO -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BOOT RED_LED_DEV #endif
/* GPIO banks */ diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index c5555e6..eef664e 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -15,7 +15,6 @@ #define CONFIG_HW_WATCHDOG
#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_LED
/* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on VINING_FPGA */ @@ -43,21 +42,6 @@ * 2 ... Bottom Green * 3 ... Bottom Red */ -#define CONFIG_STATUS_LED -#define CONFIG_GPIO_LED -#define CONFIG_BOARD_SPECIFIC_LED -#define STATUS_LED_BIT 48 -#define STATUS_LED_STATE STATUS_LED_OFF -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT1 53 -#define STATUS_LED_STATE1 STATUS_LED_OFF -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT2 54 -#define STATUS_LED_STATE2 STATUS_LED_OFF -#define STATUS_LED_PERIOD2 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT3 65 -#define STATUS_LED_STATE3 STATUS_LED_OFF -#define STATUS_LED_PERIOD3 (CONFIG_SYS_HZ / 2)
/* Ethernet on SoC (EMAC) */ #if defined(CONFIG_CMD_NET) diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index f05c1aa..6b35641 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -42,7 +42,6 @@ #define CONFIG_ENV_SECT_SIZE (128 << 10) #define CONFIG_ENV_SIZE (8 << 10)
-#define CONFIG_BOARD_SPECIFIC_LED #define CONFIG_RED_LED 110 #define CONFIG_GREEN_LED 109
diff --git a/include/configs/tqma6_wru4.h b/include/configs/tqma6_wru4.h index 96f15cd..a378406 100644 --- a/include/configs/tqma6_wru4.h +++ b/include/configs/tqma6_wru4.h @@ -37,27 +37,6 @@ #define CONFIG_CMD_DATE
/* LED */ -#define CONFIG_CMD_LED -#define CONFIG_STATUS_LED -#define CONFIG_BOARD_SPECIFIC_LED -#define STATUS_LED_BIT 0 -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT1 1 -#define STATUS_LED_STATE1 STATUS_LED_ON -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT2 2 -#define STATUS_LED_STATE2 STATUS_LED_ON -#define STATUS_LED_PERIOD2 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT3 3 -#define STATUS_LED_STATE3 STATUS_LED_ON -#define STATUS_LED_PERIOD3 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT4 4 -#define STATUS_LED_STATE4 STATUS_LED_ON -#define STATUS_LED_PERIOD4 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT5 5 -#define STATUS_LED_STATE5 STATUS_LED_ON -#define STATUS_LED_PERIOD5 (CONFIG_SYS_HZ / 2)
/* Bootcounter */ #define CONFIG_BOOTCOUNT_LIMIT diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index a300f38..a961e5c 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -60,18 +60,6 @@ #define CONFIG_OMAP3_GPIO_2 /* GPIO32..63 are in GPIO bank 2 */
/* LED support */ -#define CONFIG_STATUS_LED -#define CONFIG_BOARD_SPECIFIC_LED -#define CONFIG_CMD_LED /* LED command */ -#define STATUS_LED_BIT (1 << 0) -#define STATUS_LED_STATE STATUS_LED_ON -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT1 (1 << 1) -#define STATUS_LED_STATE1 STATUS_LED_ON -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) -#define STATUS_LED_BIT2 (1 << 2) -#define STATUS_LED_STATE2 STATUS_LED_ON -#define STATUS_LED_PERIOD2 (CONFIG_SYS_HZ / 2)
/* NS16550 Configuration */ #define CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 229c242..7d01323 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -291,8 +291,6 @@ /* * Status LED */ -#define CONFIG_STATUS_LED /* Status LED enabled */ -#define CONFIG_BOARD_SPECIFIC_LED /* version has board specific leds */
#define CONFIG_SYS_LED_BASE MPC5XXX_GPT7_ENABLE /* Timer 7 GPIO */ #ifndef __ASSEMBLY__ diff --git a/include/status_led.h b/include/status_led.h index 396ea88..f838f36 100644 --- a/include/status_led.h +++ b/include/status_led.h @@ -17,11 +17,24 @@ #ifndef _STATUS_LED_H_ #define _STATUS_LED_H_
-#ifdef CONFIG_STATUS_LED - -#define STATUS_LED_OFF 0 -#define STATUS_LED_BLINKING 1 -#define STATUS_LED_ON 2 +#ifdef CONFIG_LED_STATUS + +#define LED_STATUS_PERIOD (CONFIG_SYS_HZ / CONFIG_LED_STATUS_FREQ) +#ifdef CONFIG_LED_STATUS1 +#define LED_STATUS_PERIOD1 (CONFIG_SYS_HZ / CONFIG_LED_STATUS_FREQ1) +#endif /* CONFIG_LED_STATUS1 */ +#ifdef CONFIG_LED_STATUS2 +#define LED_STATUS_PERIOD2 (CONFIG_SYS_HZ / CONFIG_LED_STATUS_FREQ2) +#endif /* CONFIG_LED_STATUS2 */ +#ifdef CONFIG_LED_STATUS3 +#define LED_STATUS_PERIOD3 (CONFIG_SYS_HZ / CONFIG_LED_STATUS_FREQ3) +#endif /* CONFIG_LED_STATUS3 */ +#ifdef CONFIG_LED_STATUS4 +#define LED_STATUS_PERIOD4 (CONFIG_SYS_HZ / CONFIG_LED_STATUS_FREQ4) +#endif /* CONFIG_LED_STATUS4 */ +#ifdef CONFIG_LED_STATUS5 +#define LED_STATUS_PERIOD5 (CONFIG_SYS_HZ / CONFIG_LED_STATUS_FREQ5) +#endif /* CONFIG_LED_STATUS5 */
void status_led_init(void); void status_led_tick (unsigned long timestamp); @@ -34,14 +47,8 @@ void status_led_set (int led, int state); # define STATUS_LED_ODR im_cpm.cp_pbodr # define STATUS_LED_DAT im_cpm.cp_pbdat
-# define STATUS_LED_BIT 0x00000001 -# define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -# define STATUS_LED_STATE STATUS_LED_BLINKING - # define STATUS_LED_ACTIVE 1 /* LED on for bit == 1 */
-# define STATUS_LED_BOOT 0 /* LED 0 used for boot status */ - /***** MVS v1 **********************************************************/ #elif (defined(CONFIG_MVS) && CONFIG_MVS < 2) # define STATUS_LED_PAR im_ioport.iop_pdpar @@ -49,17 +56,10 @@ void status_led_set (int led, int state); # undef STATUS_LED_ODR # define STATUS_LED_DAT im_ioport.iop_pddat
-# define STATUS_LED_BOOT 0 /* LED 0 used for boot status */ - /***** Someone else defines these *************************************/ #elif defined(STATUS_LED_PAR) - /* * ADVICE: Define in your board configuration file rather than * filling this file up with lots of custom board stuff. @@ -67,26 +67,9 @@ void status_led_set (int led, int state);
#elif defined(CONFIG_V38B)
-# define STATUS_LED_BIT 0x0010 /* Timer7 GPIO */ -# define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -# define STATUS_LED_STATE STATUS_LED_BLINKING - # define STATUS_LED_ACTIVE 0 /* LED on for bit == 0 */ -# define STATUS_LED_BOOT 0 /* LED 0 used for boot status */ - -#elif defined(CONFIG_MOTIONPRO) - -#define STATUS_LED_BIT ((vu_long *) MPC5XXX_GPT6_ENABLE) -#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 10) -#define STATUS_LED_STATE STATUS_LED_BLINKING - -#define STATUS_LED_BIT1 ((vu_long *) MPC5XXX_GPT7_ENABLE) -#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 10) -#define STATUS_LED_STATE1 STATUS_LED_OFF - -#define STATUS_LED_BOOT 0 /* LED 0 used for boot status */
-#elif defined(CONFIG_BOARD_SPECIFIC_LED) +#elif defined(CONFIG_LED_STATUS_BOARD_SPECIFIC) /* led_id_t is unsigned long mask */ typedef unsigned long led_id_t;
@@ -99,11 +82,11 @@ void __led_blink(led_id_t mask, int freq); #endif /************************************************************************/
-#ifndef CONFIG_BOARD_SPECIFIC_LED +#ifndef CONFIG_LED_STATUS_BOARD_SPECIFIC # include <asm/status_led.h> #endif
/* * Coloured LEDs API diff --git a/net/bootp.c b/net/bootp.c index 42e14ed..be8f710 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -15,7 +15,7 @@ #include <net/tftp.h> #include "bootp.h" #include "nfs.h" -#ifdef CONFIG_STATUS_LED +#ifdef CONFIG_LED_STATUS #include <status_led.h> #endif #ifdef CONFIG_BOOTP_RANDOM_DELAY @@ -359,8 +359,8 @@ static void bootp_handler(uchar *pkt, unsigned dest, struct in_addr sip, /* * Got a good BOOTP reply. Copy the data into our variables. */ -#if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT) - status_led_set(STATUS_LED_BOOT, STATUS_LED_OFF); +#if defined(CONFIG_LED_STATUS) && defined(CONFIG_LED_STATUS_BOOT_ENABLE) + status_led_set(CONFIG_LED_STATUS_BOOT, CONFIG_LED_STATUS_OFF); #endif
store_net_params(bp); /* Store net parameters from reply */ diff --git a/net/net.c b/net/net.c index 671d45d..6e67877 100644 --- a/net/net.c +++ b/net/net.c @@ -88,7 +88,7 @@ #include <errno.h> #include <net.h> #include <net/tftp.h> -#if defined(CONFIG_STATUS_LED) +#if defined(CONFIG_LED_STATUS) #include <miiphy.h> #include <status_led.h> #endif @@ -518,15 +518,15 @@ restart:
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) #if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) && \ - defined(CONFIG_STATUS_LED) && \ - defined(STATUS_LED_RED) + defined(CONFIG_LED_STATUS) && \ + defined(CONFIG_LED_STATUS_RED) /* * Echo the inverted link state to the fault LED. */ if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) - status_led_set(STATUS_LED_RED, STATUS_LED_OFF); + status_led_set(CONFIG_LED_STATUS_RED, CONFIG_LED_STATUS_OFF); else - status_led_set(STATUS_LED_RED, STATUS_LED_ON); + status_led_set(CONFIG_LED_STATUS_RED, CONFIG_LED_STATUS_ON); #endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ #endif /* CONFIG_MII, ... */ #ifdef CONFIG_USB_KEYBOARD @@ -583,16 +583,18 @@ restart:
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) #if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) && \ - defined(CONFIG_STATUS_LED) && \ - defined(STATUS_LED_RED) + defined(CONFIG_LED_STATUS) && \ + defined(CONFIG_LED_STATUS_RED) /* * Echo the inverted link state to the fault LED. */ if (miiphy_link(eth_get_dev()->name, CONFIG_SYS_FAULT_MII_ADDR)) - status_led_set(STATUS_LED_RED, STATUS_LED_OFF); + status_led_set(CONFIG_LED_STATUS_RED, + CONFIG_LED_STATUS_OFF); else - status_led_set(STATUS_LED_RED, STATUS_LED_ON); + status_led_set(CONFIG_LED_STATUS_RED, + CONFIG_LED_STATUS_ON); #endif /* CONFIG_SYS_FAULT_ECHO_LINK_DOWN, ... */ #endif /* CONFIG_MII, ... */ debug_cond(DEBUG_INT_STATE, "--- net_loop timeout\n"); diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 12c7878..3ea1c85 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -333,7 +333,6 @@ CONFIG_BOARD_POSTCLK_INIT CONFIG_BOARD_RESET CONFIG_BOARD_REVISION_TAG CONFIG_BOARD_SIZE_LIMIT -CONFIG_BOARD_SPECIFIC_LED CONFIG_BOARD_TAURUS CONFIG_BOARD_TYPES CONFIG_BOOGER @@ -537,7 +536,6 @@ CONFIG_CMD_IRQ CONFIG_CMD_JFFS2 CONFIG_CMD_KGDB CONFIG_CMD_LDRINFO -CONFIG_CMD_LED CONFIG_CMD_LOADY CONFIG_CMD_LZMADEC CONFIG_CMD_MAX6957 @@ -1319,7 +1317,6 @@ CONFIG_GPCS_PHY3_ADDR CONFIG_GPCS_PHY_ADDR CONFIG_GPIO CONFIG_GPIO_ENABLE_SPI_FLASH -CONFIG_GPIO_LED CONFIG_GPIO_LED_INVERTED_TABLE CONFIG_GPIO_LED_STUBS CONFIG_GREEN_LED @@ -3097,7 +3094,6 @@ CONFIG_STAMP_CF CONFIG_STANDALONE_LOAD_ADDR CONFIG_STATIC_BOARD_REV CONFIG_STATIC_RELA -CONFIG_STATUS_LED CONFIG_STD_DEVICES_SETTINGS CONFIG_STK52XX CONFIG_STK52XX_REV100
On Thu, Jan 19, 2017 at 10:51:45AM +0200, Uri Mashiach wrote:
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach uri.mashiach@compulab.co.il
Note: This exposes and fixes a problem on 'motionpro' where code was being discarded that was needed for LEDs to be fully functional. So the platform grows by ~237 bytes, but that's a bugfix.
Uri Mashiach
