[U-Boot] [PATCH] fdt: fix out of tree builds with DT support
Fix: FATAL ERROR: Couldn't open "../arch/arm/dts/tegra20.dtsi": No such file or directory
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Simon Glass sjg@chromium.org --- dts/Makefile | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/dts/Makefile b/dts/Makefile index 5792afd..8b13b23 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -36,7 +36,7 @@ $(error Your architecture does not have device tree support enabled. \ Please define CONFIG_ARCH_DEVICE_TREE))
# We preprocess the device tree file provide a useful define -DTS_CPPFLAGS := -DARCH_CPU_DTS="../arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi" +DTS_CPPFLAGS := -DARCH_CPU_DTS="$(SRCTREE)/arch/$(ARCH)/dts/$(CONFIG_ARCH_DEVICE_TREE).dtsi"
all: $(obj).depend $(LIB)
Hi Wolfgang,
With this problem I have been pursuing include paths in dtc, since then we don't need CPP. This feature is now in dtc:
de6b762 dtc: Add -i option to support search paths
I have a patch to use that feature, so I will send it to the list.
-- 1.7.7.6
Dear Simon,
In message CAPnjgZ2eTmxeeFunjY=3tdwHjb9vjExJ7eWCim5LQEU+O3552w@mail.gmail.com you wrote:
Again, I would like to apply this patch, to fix this problem for the DTV versions that are currently in use in all the major distributions.
Hi Wolfgang,
On Thu, Apr 19, 2012 at 11:27 AM, Wolfgang Denk wd@denx.de wrote:
Dear Simon,
Fair enough. I hope that doesn't preclude us from using new features for too long.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Nobody will ever need more than 640k RAM!" -- Bill Gates, 1981 "Windows 95 needs at least 8 MB RAM." -- Bill Gates, 1996 "Nobody will ever need Windows 95." -- logical conclusion
Dear Simon Glass,
In message CAPnjgZ2-kzLW2-WdBk2qmezurJBPzT1vAHnxrf7RHZ_Xfw6YbA@mail.gmail.com you wrote:
Thanks.
Most distributions appear to pick up such changes not too fast, so we may run into issues here and there. I think we should decide this on a case by case base - here it was a trivial change to the existing code that fixed the problem.
On 04/19/2012 12:38 PM, Wolfgang Denk wrote:
Dear Simon Glass,
Thanks.
The kernel deals with this by packaging a copy of dtc (the source) as part of the kernel source tree. Then, it can upgrade to new features as soon as they're needed without any distro dependency.
Hi Stephen,
Dear Simon Glass,
Thanks.
Yes, I noticed that.
Another argument is that U-Boot / Linux shouldn't have anything to do with building device tree files, and therefore the tools are Someone Else's Problem - the flashing / packaging tools should do it.
I don't really have an opinion on this yet. Given the speed that dtc moves at, perhaps this is a problem we can live with for now.
Dear Wolfgang Denk,
Applied, thanks.
Stephen Warren
