[U-Boot] [PATCH] SPI: add support for i.MX51 processor (mxc_spi)
This patch add SPI support to the Freescale's i.MX51 processor and wants to remove some limitation in the mxc_spi driver. At the moment, data transfer > 16 bits are broken and the buffers to be transfered must be word aligned. This limits the usage of other drivers, where any number of aligned/not aligned bytes can be transfered.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/spi/mxc_spi.c | 340 ++++++++++++++++++++++++++++++++++++++++++------- 1 files changed, 293 insertions(+), 47 deletions(-)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index fad9840..84622a3 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -24,6 +24,11 @@ #include <asm/errno.h> #include <asm/io.h>
+#define MXC_CSPIRXDATA 0x00 +#define MXC_CSPITXDATA 0x04 +#define MXC_CSPICTRL 0x08 +#define MXC_CSPIPERIOD_32KHZ (1 << 15) + #ifdef CONFIG_MX27 /* i.MX27 has a completely wrong register layout and register definitions in the * datasheet, the correct one is in the Freescale's Linux driver */ @@ -31,13 +36,9 @@ #error "i.MX27 CSPI not supported due to drastic differences in register definisions" \ "See linux mxc_spi driver from Freescale for details."
-#else - +#elif defined(CONFIG_MX31) #include <asm/arch/mx31.h>
-#define MXC_CSPIRXDATA 0x00 -#define MXC_CSPITXDATA 0x04 -#define MXC_CSPICTRL 0x08 #define MXC_CSPIINT 0x0C #define MXC_CSPIDMA 0x10 #define MXC_CSPISTAT 0x14 @@ -56,21 +57,62 @@ #define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 24) #define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0x1f) << 8) #define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) +#define MXC_CSPICTRL_MAXBITS 0x1f +#define MXC_CSPICTRL_TC (1 << 8) +#define MXC_CSPICTRL_RXOVF (1 << 6)
#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 4
static unsigned long spi_bases[] = { 0x43fa4000, 0x50010000, 0x53f84000, }; +#elif defined(CONFIG_MX51) + +#define MXC_CSPICON 0x0C +#define MXC_CSPIINT 0x10 +#define MXC_CSPIDMA 0x14 +#define MXC_CSPISTAT 0x18 +#define MXC_CSPIPERIOD 0x1C +#define MXC_CSPIRESET 0x00
+#include <asm/arch/imx-regs.h> +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) +#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) +#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPICTRL_TC (1 << 7) +#define MXC_CSPICTRL_RXOVF (1 << 6) + +/* Bit position inside CTRL register to be associated with SS */ +#define MXC_CSPICTRL_CHAN 18 + +/* Bit position inside CON register to be associated with SS */ +#define MXC_CSPICON_POL 4 +#define MXC_CSPICON_PHA 0 +#define MXC_CSPICON_SSPOL 12 + +static unsigned long spi_bases[] = { + CSPI1_BASE_ADDR, + CSPI2_BASE_ADDR, + CSPI3_BASE_ADDR, +}; +#else +#error "Unsupported architecture" #endif
struct mxc_spi_slave { struct spi_slave slave; unsigned long base; u32 ctrl_reg; + u32 cfg_reg; int gpio; };
@@ -89,62 +131,255 @@ static inline void reg_write(unsigned long addr, u32 val) *(volatile unsigned long*)addr = val; }
-static u32 spi_xchg_single(struct spi_slave *slave, u32 data, int bitlen, - unsigned long flags) +void spi_cs_activate(struct spi_slave *slave) { +#ifdef CONFIG_MX31 struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); - unsigned int cfg_reg = reg_read(mxcs->base + MXC_CSPICTRL); - - mxcs->ctrl_reg = (mxcs->ctrl_reg & ~MXC_CSPICTRL_BITCOUNT(31)) | - MXC_CSPICTRL_BITCOUNT(bitlen - 1); + if (mxcs->gpio > 0) + mx31_gpio_set(mxcs->gpio, mxcs->ctrl_reg & MXC_CSPICTRL_SSPOL); +#endif +}
- if (cfg_reg != mxcs->ctrl_reg) - reg_write(mxcs->base + MXC_CSPICTRL, mxcs->ctrl_reg); +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); +#ifdef CONFIG_MX31 + if (mxcs->gpio > 0) + mx31_gpio_set(mxcs->gpio, + !(mxcs->ctrl_reg & MXC_CSPICTRL_SSPOL)); +#endif + reg_write(mxcs->base + MXC_CSPICTRL, 0); +}
- if (mxcs->gpio > 0 && (flags & SPI_XFER_BEGIN)) - mx31_gpio_set(mxcs->gpio, mxcs->ctrl_reg & MXC_CSPICTRL_SSPOL); +static s32 spi_cfg(struct mxc_spi_slave *mxcs, unsigned int cs, unsigned int max_hz, unsigned int mode) +{ + u32 clk_src = mxc_get_clock(MXC_CSPI_CLK); + s32 pre_div = 0, post_div = 0, i, reg_ctrl, reg_config; + u32 ss_pol = 0, sclkpol = 0, sclkpha = 0;
- reg_write(mxcs->base + MXC_CSPITXDATA, data); + if (max_hz == 0) { + printf("Error: desired clock is 0\n"); + return -1; + }
- reg_write(mxcs->base + MXC_CSPICTRL, mxcs->ctrl_reg | MXC_CSPICTRL_XCH); + reg_ctrl = reg_read(mxcs->base + MXC_CSPICTRL);
- while (reg_read(mxcs->base + MXC_CSPICTRL) & MXC_CSPICTRL_XCH) - ; + /* Reset spi */ + reg_write(mxcs->base + MXC_CSPICTRL, 0); + reg_write(mxcs->base + MXC_CSPICTRL, (reg_ctrl | 0x1));
- if (mxcs->gpio > 0 && (flags & SPI_XFER_END)) { - mx31_gpio_set(mxcs->gpio, - !(mxcs->ctrl_reg & MXC_CSPICTRL_SSPOL)); + /* + * The following computation is taken directly from Freescale's code. + */ + if (clk_src > max_hz) { + pre_div = clk_src / max_hz; + if (pre_div > 16) { + post_div = pre_div / 16; + pre_div = 15; + } + if (post_div != 0) { + for (i = 0; i < 16; i++) { + if ((1 << i) >= post_div) + break; + } + if (i == 16) { + printf("Error: no divider can meet the freq: %d\n", + max_hz); + return -1; + } + post_div = i; + } }
- return reg_read(mxcs->base + MXC_CSPIRXDATA); + debug("pre_div = %d, post_div=%d\n", pre_div, post_div); + reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_SELCHAN(3)) | + MXC_CSPICTRL_SELCHAN(cs); + reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_PREDIV(0x0F)) | + MXC_CSPICTRL_PREDIV(pre_div); + reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_POSTDIV(0x0F)) | + MXC_CSPICTRL_POSTDIV(post_div); + + /* always set to master mode */ + reg_ctrl |= 1 << (cs + 4); + + /* We need to disable SPI before changing registers */ + reg_ctrl &= ~MXC_CSPICTRL_EN; + + if (mode & SPI_CS_HIGH) + ss_pol = 1; + + if (!(mode & SPI_CPOL)) + sclkpol = 1; + + if (mode & SPI_CPHA) + sclkpha = 1; + + reg_config = reg_read(mxcs->base + MXC_CSPICON); + + /* + * Configuration register setup + * The MX51 has support different setup for each SS + */ + reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_SSPOL))) | + (ss_pol << (cs + MXC_CSPICON_SSPOL)); + reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_POL))) | + (sclkpol << (cs + MXC_CSPICON_POL)); + reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_PHA))) | + (sclkpha << (cs + MXC_CSPICON_PHA)); + + debug("reg_ctrl = 0x%x\n", reg_ctrl); + reg_write(mxcs->base + MXC_CSPICTRL, reg_ctrl); + debug("reg_config = 0x%x\n", reg_config); + reg_write(mxcs->base + MXC_CSPICON, reg_config); + + /* save config register and control register */ + mxcs->ctrl_reg = reg_ctrl; + mxcs->cfg_reg = reg_config; + + /* clear interrupt reg */ + reg_write(mxcs->base + MXC_CSPIINT, 0); + reg_write(mxcs->base + MXC_CSPISTAT, MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF); + + return 0; }
-int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, +static int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { - int n_blks = (bitlen + 31) / 32; - u32 *out_l, *in_l; - int i; + struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); + int n_bytes = (bitlen + 7) / 8; + int n_blks = (n_bytes + 3) / 4; + int cnt_blk; + u32 tmpdata; + u32 spare_bytes = 0; + int j; + char *pbuf; + + debug("spi_xchg: %d %d %d\n", bitlen, n_bytes, n_blks); + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + mxcs->ctrl_reg = (mxcs->ctrl_reg & + ~MXC_CSPICTRL_BITCOUNT(MXC_CSPICTRL_MAXBITS)) | + MXC_CSPICTRL_BITCOUNT(n_bytes * 8 - 1); + + /* Enable SPI controller */ + reg_write(mxcs->base + MXC_CSPICTRL, mxcs->ctrl_reg | MXC_CSPICTRL_EN); +#ifdef CONFIG_MX51 + reg_write(mxcs->base + MXC_CSPICON, mxcs->cfg_reg); +#endif
- if ((int)dout & 3 || (int)din & 3) { - printf("Error: unaligned buffers in: %p, out: %p\n", din, dout); - return 1; + /* Clear interrupt register */ + reg_write(mxcs->base + MXC_CSPISTAT, MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF); + + for (cnt_blk = 0, pbuf = (char *)dout; cnt_blk < n_blks; cnt_blk++) { + tmpdata = 0; + for (j = 0; j< 4; j++) { + /* + * According to the User Manual, only the n + * least-significant bits in the first word + * will be shifted out. The remaining bits + * in first word will be ignored + */ + if (n_bytes > 0) { + /* + * Check for the first word. If the number of bytes + * is not multiple of a word, only a part of the first + * word is shifted out and must be written in TX FIFO. + * For example, sending 5 bytes means to write a single byte + * first, followed by 4 words. + */ + if ((cnt_blk == 0) && (bitlen % 32) && (j >= ((bitlen % 32) / 8))) { + continue; + } + if (pbuf) { + tmpdata = *pbuf++ | (tmpdata << 8); + } + n_bytes--; + } + } + debug("writing TX FIFO 0x%x\n", tmpdata); + reg_write(mxcs->base + MXC_CSPITXDATA, tmpdata); }
- for (i = 0, in_l = (u32 *)din, out_l = (u32 *)dout; - i < n_blks; - i++, in_l++, out_l++, bitlen -= 32) { - u32 data = spi_xchg_single(slave, *out_l, bitlen, flags); - - /* Check if we're only transfering 8 or 16 bits */ - if (!i) { - if (bitlen < 9) - *(u8 *)din = data; - else if (bitlen < 17) - *(u16 *)din = data; + /* FIFO is written, now starts the transfer setting the XCH bit */ + reg_write(mxcs->base + MXC_CSPICTRL, mxcs->ctrl_reg | + MXC_CSPICTRL_EN | MXC_CSPICTRL_XCH); + + /* Wait until the TC (Transfer completed) bit is set */ + while ((reg_read(mxcs->base + MXC_CSPISTAT) & MXC_CSPICTRL_TC) == 0) + ; + + /* Transfer completed, clear any pending request */ + reg_write(mxcs->base + MXC_CSPISTAT, MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF); + + /* + * Now do the opposite: copy only part of the first word + * if the number of bytes is not multiple of a word size. + */ + n_bytes = (bitlen + 7) / 8; + for (cnt_blk = 0, pbuf = (char *)din; n_bytes > 0; cnt_blk++) { + tmpdata = reg_read(mxcs->base + MXC_CSPIRXDATA); + debug("value_read 0x%x\n", tmpdata); + for (j = 0; j < 4; j++) { + if (n_bytes > 0) { + /* + * If it is the first word, compute how many + * bytes must be copied + */ + if (cnt_blk == 0 ) + spare_bytes = (bitlen % 32) / 8; + + if ((cnt_blk == 0) && (bitlen % 32) && (j >= spare_bytes)) { + continue; + } + if (din) { + *pbuf++ = (tmpdata >> ((3 - spare_bytes - j) * 8)) & 0xFF; + } + n_bytes--; + } } }
+ if (flags & SPI_XFER_END) { + spi_cs_deactivate(slave); + } + + return 0; +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + int n_bytes = (bitlen + 7) / 8; + int n_bits; + int ret; + u32 blk_size; + char *p_outbuf = (char *)dout; + char *p_inbuf = (char *)din; + + if (!slave) + return -1; + + while (n_bytes > 0) { + if (n_bytes < MAX_SPI_BYTES) + blk_size = n_bytes; + else + blk_size = MAX_SPI_BYTES; + + n_bits = blk_size * 8; + + ret = spi_xchg_single(slave, n_bits, dout, din, flags); + if (ret) + return ret; + if (dout) + p_outbuf += blk_size; + if (din) + p_inbuf += blk_size; + n_bytes -= blk_size; + } + return 0; }
@@ -154,8 +389,7 @@ void spi_init(void)
static int decode_cs(struct mxc_spi_slave *mxcs, unsigned int cs) { - int ret; - + int ret = 0; /* * Some SPI devices require active chip-select over multiple * transactions, we achieve this using a GPIO. Still, the SPI @@ -167,11 +401,13 @@ static int decode_cs(struct mxc_spi_slave *mxcs, unsigned int cs) if (cs > 3) { mxcs->gpio = cs >> 8; cs &= 3; +#ifdef CONFIG_MX31 ret = mx31_gpio_direction(mxcs->gpio, MX31_GPIO_DIRECTION_OUT); if (ret) { printf("mxc_spi: cannot setup gpio %d\n", mxcs->gpio); return -EINVAL; } +#endif } else { mxcs->gpio = -1; } @@ -182,7 +418,6 @@ static int decode_cs(struct mxc_spi_slave *mxcs, unsigned int cs) struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { - unsigned int ctrl_reg; struct mxc_spi_slave *mxcs; int ret;
@@ -201,6 +436,19 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
cs = ret;
+ mxcs->slave.bus = bus; + mxcs->slave.cs = cs; + mxcs->base = spi_bases[bus]; + +#ifdef CONFIG_MX51 + /* Can be used for i.MX31 too ? */ + ret = spi_cfg(mxcs, cs, max_hz, mode); + if (ret) { + printf("mxc_spi: cannot setup SPI controller\n"); + free(mxcs); + return NULL; + } +#else ctrl_reg = MXC_CSPICTRL_CHIPSELECT(cs) | MXC_CSPICTRL_BITCOUNT(31) | MXC_CSPICTRL_DATARATE(7) | /* FIXME: calculate data rate */ @@ -214,10 +462,8 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, if (mode & SPI_CS_HIGH) ctrl_reg |= MXC_CSPICTRL_SSPOL;
- mxcs->slave.bus = bus; - mxcs->slave.cs = cs; - mxcs->base = spi_bases[bus]; mxcs->ctrl_reg = ctrl_reg; +#endif
return &mxcs->slave; }
This patch add support for MX51 processor and supports transfer of multiple word in a single transation.
The patch adds support for the MX51 and wants to remove some limitation on the old driver. Actually, the buffer passed to the transfer function must be word-aligne, even if it is required to send a single byte.
drivers/spi/mxc_spi.c | 357 +++++++++++++++++++++++++++++++++++++++++-------- 1 files changed, 301 insertions(+), 56 deletions(-)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 3a45200..b04fadc 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -24,6 +24,11 @@ #include <asm/errno.h> #include <asm/io.h>
-#define MXC_CSPIRXDATA 0x00 -#define MXC_CSPITXDATA 0x04 -#define MXC_CSPICTRL 0x08 #define MXC_CSPIINT 0x0C #define MXC_CSPIDMA 0x10 #define MXC_CSPISTAT 0x14 @@ -56,21 +57,63 @@ #define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 24) #define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0x1f) << 8) #define MXC_CSPICTRL_DATARATE(x) (((x) & 0x7) << 16) +#define MXC_CSPICTRL_MAXBITS 0x1f +#define MXC_CSPICTRL_TC (1 << 8) +#define MXC_CSPICTRL_RXOVF (1 << 6)
+#include <asm/arch/imx-regs.h> +#include <asm/arch/clock.h> +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) +#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) +#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPICTRL_TC (1 << 7) +#define MXC_CSPICTRL_RXOVF (1 << 6) + +/* Bit position inside CTRL register to be associated with SS */ +#define MXC_CSPICTRL_CHAN 18 + +/* Bit position inside CON register to be associated with SS */ +#define MXC_CSPICON_POL 4 +#define MXC_CSPICON_PHA 0 +#define MXC_CSPICON_SSPOL 12 + +static unsigned long spi_bases[] = { + CSPI1_BASE_ADDR, + CSPI2_BASE_ADDR, + CSPI3_BASE_ADDR, +}; +#else +#error "Unsupported architecture" #endif
@@ -89,71 +132,262 @@ static inline void reg_write(unsigned long addr, u32 val) *(volatile unsigned long*)addr = val; }
- if (mxcs->gpio > 0 && (flags & SPI_XFER_BEGIN)) - mx31_gpio_set(mxcs->gpio, mxcs->ctrl_reg & MXC_CSPICTRL_SSPOL); +static s32 spi_cfg(struct mxc_spi_slave *mxcs, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + u32 clk_src = mxc_get_clock(MXC_CSPI_CLK); + s32 pre_div = 0, post_div = 0, i, reg_ctrl, reg_config; + u32 ss_pol = 0, sclkpol = 0, sclkpha = 0;
- if (mxcs->gpio > 0 && (flags & SPI_XFER_END)) { - mx31_gpio_set(mxcs->gpio, - !(mxcs->ctrl_reg & MXC_CSPICTRL_SSPOL)); + /* + * The following computation is taken directly from Freescale's code. + */ + if (clk_src > max_hz) { + pre_div = clk_src / max_hz; + if (pre_div > 16) { + post_div = pre_div / 16; + pre_div = 15; + } + if (post_div != 0) { + for (i = 0; i < 16; i++) { + if ((1 << i) >= post_div) + break; + } + if (i == 16) { + printf("Error: no divider for the freq: %d\n", + max_hz); + return -1; + } + post_div = i; + } }
- return reg_read(mxcs->base + MXC_CSPIRXDATA); + debug("pre_div = %d, post_div=%d\n", pre_div, post_div); + reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_SELCHAN(3)) | + MXC_CSPICTRL_SELCHAN(cs); + reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_PREDIV(0x0F)) | + MXC_CSPICTRL_PREDIV(pre_div); + reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_POSTDIV(0x0F)) | + MXC_CSPICTRL_POSTDIV(post_div); + + /* always set to master mode */ + reg_ctrl |= 1 << (cs + 4); + + /* We need to disable SPI before changing registers */ + reg_ctrl &= ~MXC_CSPICTRL_EN; + + if (mode & SPI_CS_HIGH) + ss_pol = 1; + + if (!(mode & SPI_CPOL)) + sclkpol = 1; + + if (mode & SPI_CPHA) + sclkpha = 1; + + reg_config = reg_read(mxcs->base + MXC_CSPICON); + + /* + * Configuration register setup + * The MX51 has support different setup for each SS + */ + reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_SSPOL))) | + (ss_pol << (cs + MXC_CSPICON_SSPOL)); + reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_POL))) | + (sclkpol << (cs + MXC_CSPICON_POL)); + reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_PHA))) | + (sclkpha << (cs + MXC_CSPICON_PHA)); + + debug("reg_ctrl = 0x%x\n", reg_ctrl); + reg_write(mxcs->base + MXC_CSPICTRL, reg_ctrl); + debug("reg_config = 0x%x\n", reg_config); + reg_write(mxcs->base + MXC_CSPICON, reg_config); + + /* save config register and control register */ + mxcs->ctrl_reg = reg_ctrl; + mxcs->cfg_reg = reg_config; + + /* clear interrupt reg */ + reg_write(mxcs->base + MXC_CSPIINT, 0); + reg_write(mxcs->base + MXC_CSPISTAT, + MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF); + + return 0; }
-int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, - void *din, unsigned long flags) +static int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) { - int n_blks = (bitlen + 31) / 32; - u32 *out_l, *in_l; - int i; + struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); + int n_bytes = (bitlen + 7) / 8; + int n_blks = (n_bytes + 3) / 4; + int cnt_blk; + u32 tmpdata; + u32 spare_bytes = 0; + int j; + char *pbuf; + + debug("spi_xchg: %d %d %d\n", bitlen, n_bytes, n_blks); + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + mxcs->ctrl_reg = (mxcs->ctrl_reg & + ~MXC_CSPICTRL_BITCOUNT(MXC_CSPICTRL_MAXBITS)) | + MXC_CSPICTRL_BITCOUNT(n_bytes * 8 - 1); + + /* Enable SPI controller */ + reg_write(mxcs->base + MXC_CSPICTRL, mxcs->ctrl_reg | MXC_CSPICTRL_EN); +#ifdef CONFIG_MX51 + reg_write(mxcs->base + MXC_CSPICON, mxcs->cfg_reg); +#endif
- if ((int)dout & 3 || (int)din & 3) { - printf("Error: unaligned buffers in: %p, out: %p\n", din, dout); - return 1; + /* Clear interrupt register */ + reg_write(mxcs->base + MXC_CSPISTAT, + MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF); + + for (cnt_blk = 0, pbuf = (char *)dout; cnt_blk < n_blks; cnt_blk++) { + tmpdata = 0; + for (j = 0; j < 4; j++) { + /* + * According to the User Manual, only the n + * least-significant bits in the first word + * will be shifted out. The remaining bits + * in first word will be ignored + */ + if (n_bytes > 0) { + /* + * Check for the first word. If the number of + * bytes is not multiple of a word, only a + * part of the first word is shifted out + * and must be written in TX FIFO. + * For example, sending 5 bytes means to write + * a single byte first, followed by 4 words. + */ + if ((cnt_blk == 0) && (bitlen % 32) && + (j >= ((bitlen % 32) / 8))) { + continue; + } + if (pbuf) + tmpdata = *pbuf++ | (tmpdata << 8); + n_bytes--; + } + } + debug("writing TX FIFO 0x%x\n", tmpdata); + reg_write(mxcs->base + MXC_CSPITXDATA, tmpdata); }
- /* This driver is currently partly broken, alert the user */ - if (bitlen > 16 && (bitlen % 32)) { - printf("Error: SPI transfer with bitlen=%d is broken.\n", - bitlen); - return 1; - } + /* FIFO is written, now starts the transfer setting the XCH bit */ + reg_write(mxcs->base + MXC_CSPICTRL, mxcs->ctrl_reg | + MXC_CSPICTRL_EN | MXC_CSPICTRL_XCH); + + /* Wait until the TC (Transfer completed) bit is set */ + while ((reg_read(mxcs->base + MXC_CSPISTAT) & MXC_CSPICTRL_TC) == 0) + ; + + /* Transfer completed, clear any pending request */ + reg_write(mxcs->base + MXC_CSPISTAT, + MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF);
- for (i = 0, in_l = (u32 *)din, out_l = (u32 *)dout; - i < n_blks; - i++, in_l++, out_l++, bitlen -= 32) { - u32 data = spi_xchg_single(slave, *out_l, bitlen, flags); - - /* Check if we're only transfering 8 or 16 bits */ - if (!i) { - if (bitlen < 9) - *(u8 *)din = data; - else if (bitlen < 17) - *(u16 *)din = data; - else - *in_l = data; + /* + * Now do the opposite: copy only part of the first word + * if the number of bytes is not multiple of a word size. + */ + n_bytes = (bitlen + 7) / 8; + for (cnt_blk = 0, pbuf = (char *)din; n_bytes > 0; cnt_blk++) { + tmpdata = reg_read(mxcs->base + MXC_CSPIRXDATA); + debug("value_read 0x%x\n", tmpdata); + for (j = 0; j < 4; j++) { + if (n_bytes > 0) { + /* + * If it is the first word, compute how many + * bytes must be copied + */ + if (cnt_blk == 0) + spare_bytes = (bitlen % 32) / 8; + + if ((cnt_blk == 0) && (bitlen % 32) && + (j >= spare_bytes)) + continue; + + if (din) + *pbuf++ = (tmpdata >> + ((3 - spare_bytes - j) * 8)) + & 0xFF; + + n_bytes--; + } } }
+ if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + int n_bytes = (bitlen + 7) / 8; + int n_bits; + int ret; + u32 blk_size; + char *p_outbuf = (char *)dout; + char *p_inbuf = (char *)din; + + if (!slave) + return -1; + + while (n_bytes > 0) { + if (n_bytes < MAX_SPI_BYTES) + blk_size = n_bytes; + else + blk_size = MAX_SPI_BYTES; + + n_bits = blk_size * 8; + + ret = spi_xchg_single(slave, n_bits, dout, din, flags); + if (ret) + return ret; + if (dout) + p_outbuf += blk_size; + if (din) + p_inbuf += blk_size; + n_bytes -= blk_size; + } + return 0; }
@@ -163,8 +397,7 @@ void spi_init(void)
static int decode_cs(struct mxc_spi_slave *mxcs, unsigned int cs) { - int ret; - + int ret = 0; /* * Some SPI devices require active chip-select over multiple * transactions, we achieve this using a GPIO. Still, the SPI @@ -176,11 +409,13 @@ static int decode_cs(struct mxc_spi_slave *mxcs, unsigned int cs) if (cs > 3) { mxcs->gpio = cs >> 8; cs &= 3; +#ifdef CONFIG_MX31 ret = mx31_gpio_direction(mxcs->gpio, MX31_GPIO_DIRECTION_OUT); if (ret) { printf("mxc_spi: cannot setup gpio %d\n", mxcs->gpio); return -EINVAL; } +#endif } else { mxcs->gpio = -1; } @@ -191,7 +426,6 @@ static int decode_cs(struct mxc_spi_slave *mxcs, unsigned int cs) struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { - unsigned int ctrl_reg; struct mxc_spi_slave *mxcs; int ret;
@@ -210,6 +444,19 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
cs = ret;
+ mxcs->slave.bus = bus; + mxcs->slave.cs = cs; + mxcs->base = spi_bases[bus]; + +#ifdef CONFIG_MX51 + /* Can be used for i.MX31 too ? */ + ret = spi_cfg(mxcs, cs, max_hz, mode); + if (ret) { + printf("mxc_spi: cannot setup SPI controller\n"); + free(mxcs); + return NULL; + } +#else ctrl_reg = MXC_CSPICTRL_CHIPSELECT(cs) | MXC_CSPICTRL_BITCOUNT(31) | MXC_CSPICTRL_DATARATE(7) | /* FIXME: calculate data rate */ @@ -223,10 +470,8 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, if (mode & SPI_CS_HIGH) ctrl_reg |= MXC_CSPICTRL_SSPOL;
It may be better to split this patch into 1. fixing the old driver 2. adding mx51
Pulling these out and making them common may not be the best thing to do. Located here, it hides the
#ifdef CONFIG_MX27 #elif defined (CONFIG_MX31) #elif defined (CONFIG_MX51) #else #endif
I would prefer if you just kept the copies in the mx31, mx51 locations
- datasheet, the correct one is in the Freescale's Linux driver */
-#else
In 'Add SPI support to mx51evk board' The MAX_SPI_BYTES was defined in the config file. Here it is defined for mx31 generally. You should be consistent. These would be a better place for the mx51 values as you only have to do it once.
Be constistent with mx31 Move the #includes to the first lines after the #elif The other #defines to follow.
Tom
- CSPI1_BASE_ADDR,
- CSPI2_BASE_ADDR,
- CSPI3_BASE_ADDR,
- u32 cfg_reg; int gpio;
- if (mxcs->gpio > 0)
+#endif +}
- struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave);
+#ifdef CONFIG_MX31
- reg_write(mxcs->base + MXC_CSPICTRL, 0);
- u32 clk_src = mxc_get_clock(MXC_CSPI_CLK);
- s32 pre_div = 0, post_div = 0, i, reg_ctrl, reg_config;
- u32 ss_pol = 0, sclkpol = 0, sclkpha = 0;
- if (max_hz == 0) {
return -1;
- reg_ctrl = reg_read(mxcs->base + MXC_CSPICTRL);
- /* Reset spi */
- reg_write(mxcs->base + MXC_CSPICTRL, (reg_ctrl | 0x1));
- if (clk_src > max_hz) {
if (pre_div > 16) {
pre_div = 15;
break;
if (i == 16) {
max_hz);
return -1;
post_div = i;
- debug("pre_div = %d, post_div=%d\n", pre_div, post_div);
- reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_SELCHAN(3)) |
- reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_PREDIV(0x0F)) |
- reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_POSTDIV(0x0F)) |
- /* always set to master mode */
- reg_ctrl |= 1 << (cs + 4);
- /* We need to disable SPI before changing registers */
- reg_ctrl &= ~MXC_CSPICTRL_EN;
- if (mode & SPI_CS_HIGH)
ss_pol = 1;
- if (!(mode & SPI_CPOL))
sclkpol = 1;
- if (mode & SPI_CPHA)
sclkpha = 1;
- reg_config = reg_read(mxcs->base + MXC_CSPICON);
- reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_SSPOL))) |
- reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_POL))) |
- reg_config = (reg_config & ~(1 << (cs + MXC_CSPICON_PHA))) |
- debug("reg_ctrl = 0x%x\n", reg_ctrl);
- reg_write(mxcs->base + MXC_CSPICTRL, reg_ctrl);
- debug("reg_config = 0x%x\n", reg_config);
- reg_write(mxcs->base + MXC_CSPICON, reg_config);
- /* save config register and control register */
- mxcs->ctrl_reg = reg_ctrl;
- mxcs->cfg_reg = reg_config;
- /* clear interrupt reg */
- reg_write(mxcs->base + MXC_CSPIINT, 0);
- reg_write(mxcs->base + MXC_CSPISTAT,
- const void *dout, void *din, unsigned long flags)
- int i;
- int n_bytes = (bitlen + 7) / 8;
- int n_blks = (n_bytes + 3) / 4;
- int cnt_blk;
- u32 tmpdata;
- u32 spare_bytes = 0;
- int j;
- char *pbuf;
- debug("spi_xchg: %d %d %d\n", bitlen, n_bytes, n_blks);
- if (flags & SPI_XFER_BEGIN)
- /* Enable SPI controller */
- reg_write(mxcs->base + MXC_CSPICTRL, mxcs->ctrl_reg | MXC_CSPICTRL_EN);
+#ifdef CONFIG_MX51
- reg_write(mxcs->base + MXC_CSPICON, mxcs->cfg_reg);
return 1;
- /* Clear interrupt register */
- for (cnt_blk = 0, pbuf = (char *)dout; cnt_blk < n_blks; cnt_blk++) {
tmpdata = 0;
if (n_bytes > 0) {
continue;
if (pbuf)
n_bytes--;
}reg_write(mxcs->base + MXC_CSPITXDATA, tmpdata);
bitlen);
return 1;
- /* FIFO is written, now starts the transfer setting the XCH bit */
- /* Wait until the TC (Transfer completed) bit is set */
- while ((reg_read(mxcs->base + MXC_CSPISTAT) & MXC_CSPICTRL_TC) == 0)
- /* Transfer completed, clear any pending request */
i < n_blks;
if (!i) {
if (bitlen < 9)
*(u8 *)din = data;
*(u16 *)din = data;
else
*in_l = data;
if (n_bytes > 0) {
if (cnt_blk == 0)
(j >= spare_bytes))
continue;
if (din)
& 0xFF;
n_bytes--;
- int n_bits;
- int ret;
- u32 blk_size;
- char *p_outbuf = (char *)dout;
- char *p_inbuf = (char *)din;
- if (!slave)
return -1;
- while (n_bytes > 0) {
blk_size = n_bytes;
else
if (ret)
return ret;
if (dout)
if (din)
- int ret;
- int ret = 0; /*
- Some SPI devices require active chip-select over multiple
- transactions, we achieve this using a GPIO. Still, the SPI
cs = ret;
+#ifdef CONFIG_MX51
- /* Can be used for i.MX31 too ? */
- ret = spi_cfg(mxcs, cs, max_hz, mode);
- if (ret) {
free(mxcs);
return NULL;
You are right - I will move them.
That is correct. And the value is not related to a particular board, setting this define in config file is definetely wrong. I will move it.
Ok, thanks.
Stefano
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Stefano Babic Sent: 2010年3月17日 0:22 To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH] SPI: added support for MX51 to mxc_spi
driver */ @@ -31,13 +36,9 @@ #error "i.MX27 CSPI not supported due to drastic differences in register definisions" ¥ "See linux mxc_spi driver from Freescale for details."
-#else
Here hardcode the value in mx31, while in mx51 it use the macro. Which makes Code style not consistent.
- CSPI1_BASE_ADDR,
- CSPI2_BASE_ADDR,
- CSPI3_BASE_ADDR,
See above comments.
Only MX51 use it, MX31 will not use it.
- mxcs->ctrl_reg = (mxcs->ctrl_reg & ‾MXC_CSPICTRL_BITCOUNT(31)) |
MXC_CSPICTRL_SSPOL); +#endif }
+void spi_cs_deactivate(struct spi_slave *slave) {
- struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); #ifdef
+CONFIG_MX31
!(mxcs->ctrl_reg &
MXC_CSPICTRL_SSPOL)); #endif
- reg_write(mxcs->base + MXC_CSPICTRL, 0); }
printf("Error: desired clock is 0¥n");
return -1;
MXC_CSPICTRL_XCH);
- /* Reset spi */
Freescale's code.
if (pre_div > 16) {
pre_div = 15;
break;
if (i == 16) {
the freq: %d¥n",
max_hz);
return -1;
post_div = i;
- debug("pre_div = %d, post_div=%d¥n", pre_div, post_div);
- reg_ctrl = (reg_ctrl & ‾MXC_CSPICTRL_SELCHAN(3)) |
- reg_ctrl = (reg_ctrl & ‾MXC_CSPICTRL_PREDIV(0x0F)) |
- reg_ctrl = (reg_ctrl & ‾MXC_CSPICTRL_POSTDIV(0x0F)) |
- reg_ctrl &= ‾MXC_CSPICTRL_EN;
ss_pol = 1;
sclkpol = 1;
sclkpha = 1;
- reg_config = (reg_config & ‾(1 << (cs + MXC_CSPICON_SSPOL))) |
- reg_config = (reg_config & ‾(1 << (cs + MXC_CSPICON_POL))) |
- reg_config = (reg_config & ‾(1 << (cs + MXC_CSPICON_PHA))) |
- debug("reg_ctrl = 0x%x¥n", reg_ctrl);
- debug("reg_config = 0x%x¥n", reg_config);
The function spi_cfg only used in MX51, will have compile warnings for MX31. Use CONFIG_MX51 to cover it.
- int i;
- int cnt_blk;
- u32 tmpdata;
- int j;
- char *pbuf;
- debug("spi_xchg: %d %d %d¥n", bitlen, n_bytes, n_blks);
‾MXC_CSPICTRL_BITCOUNT(MXC_CSPICTRL_MAXBITS)) |
+MXC_CSPICTRL_EN); #ifdef CONFIG_MX51
- reg_write(mxcs->base + MXC_CSPICON, mxcs->cfg_reg); #endif
%p¥n", din, dout);
return 1;
tmpdata = 0;
if (n_bytes > 0) {
the number of
word, only a
means to write
Comments is wrong, should be "followed by 4 bytes"
continue;
if (pbuf)
tmpdata = *pbuf++ |
(tmpdata << 8);
n_bytes--;
debug("writing TX FIFO 0x%x¥n", tmpdata);
Can use word copy for the left part(cnt_blk !=0) to get high performance.
broken.¥n",
bitlen);
return 1;
XCH bit */
i < n_blks;
bitlen, flags);
if (!i) {
if (bitlen < 9)
*(u8 *)din = data;
*(u16 *)din = data;
else
*in_l = data;
- n_bytes = (bitlen + 7) / 8;
- for (cnt_blk = 0, pbuf = (char *)din; n_bytes > 0; cnt_blk++) {
debug("value_read 0x%x¥n", tmpdata);
if (n_bytes > 0) {
compute how many
if (cnt_blk == 0)
(j >= spare_bytes))
continue;
if (din)
((3 -
The RX path should be logic wrong, spare_bytes not reset to zero and the data got not correct when data is not 4B alignement.
& 0xFF;
n_bytes--;
- int n_bits;
- int ret;
- u32 blk_size;
- if (!slave)
return -1;
blk_size = n_bytes;
else
if (ret)
return ret;
if (dout)
if (din)
- int ret;
- int ret = 0; /*
the SPI @@ -176,11 +409,13 @@ static int decode_cs(struct mxc_spi_slave *mxcs, unsigned int cs) if (cs > 3) { mxcs->gpio = cs >> 8; cs &= 3; +#ifdef CONFIG_MX31 ret = mx31_gpio_direction(mxcs->gpio, MX31_GPIO_DIRECTION_OUT); if (ret) { printf("mxc_spi: cannot setup gpio %d¥n", mxcs->gpio); return -EINVAL; } +#endif } else { mxcs->gpio = -1; } @@ -191,7 +426,6 @@ static int decode_cs(struct mxc_spi_slave *mxcs, unsigned int cs) struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) {
cs = ret;
+#ifdef CONFIG_MX51
- if (ret) {
printf("mxc_spi: cannot setup SPI controller¥n");
free(mxcs);
return NULL;
return &mxcs->slave; } -- 1.6.3.3
yes, agree, the driver already contains a lot of hard-coded values for mx.31 and I changed only according to the mx.51. As I see, in the imx-regs.h for MX.31 several defines are missing, and the drivers define theirselves the values. I will add the defines, at least for spi, to the mx31-regs.h in a separate patch.
- CSPI1_BASE_ADDR,
- CSPI2_BASE_ADDR,
- CSPI3_BASE_ADDR,
See above comments.
Ok, but this is correct. Only the MX31 part should be changed.
However, I need a general structure to support both processors. Agree this register is available only on the MX.51 processor, I can surround the definition with an #ifdef CONFIG_MX51 statement.
Agree, and as reported by Tom, there are other issues regarding the MX.31. I will check all of them globally and I will try to test on a MX.31 board, too.
Agree, it must be changed.
continue;
if (pbuf)
tmpdata = *pbuf++ |
(tmpdata << 8);
n_bytes--;
Not sure, but it could be I have not get the real problem here.
if (din)
((3 -
Thanks, I will recheck the code, surely spare_bytes must be reset to zero.
Regards, Stefano Babic
Liu Hui-R64343
Stefano Babic
Tom
