[U-Boot] [PATCH 0/3] armv8: fsl-layerscape: Add LS1046A SoC support
The LS1046A processor is built on the QorIQ LS series architecture combining four ARM A72 processor cores with DPAA 1.0 support.
[PATCH 1/3] armv8: fsl-layerscape: Add A72 core detection [PATCH 2/3] armv8/fsl_lsch2: Add LS1046A SoC support [PATCH 3/3] armv8/ls1046a: Add Fman support
Regards, Qianyu
Signed-off-by: Alison Wang alison.wang@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 8062106..b810d01 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -558,7 +558,8 @@ int print_cpuinfo(void) printf("CPU%d(%s):%-4s MHz ", core, type == TY_ITYP_VER_A7 ? "A7 " : (type == TY_ITYP_VER_A53 ? "A53" : - (type == TY_ITYP_VER_A57 ? "A57" : " ")), + (type == TY_ITYP_VER_A57 ? "A57" : + (type == TY_ITYP_VER_A72 ? "A72" : " "))), strmhz(buf, sysinfo.freq_processor[core])); } printf("\n Bus: %-4s MHz ", diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 8b8a7c1..cbb252c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -94,6 +94,7 @@ #define TY_ITYP_VER_A7 0x1 #define TY_ITYP_VER_A53 0x2 #define TY_ITYP_VER_A57 0x3 +#define TY_ITYP_VER_A72 0x4
#define TP_CLUSTER_EOC 0xc0000000 /* end of clusters */ #define TP_CLUSTER_INIT_MASK 0x0000003f /* initiator mask */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 3ad46eb..4d54ab2 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -156,6 +156,7 @@ #define TY_ITYP_VER_A7 0x1 #define TY_ITYP_VER_A53 0x2 #define TY_ITYP_VER_A57 0x3 +#define TY_ITYP_VER_A72 0x4
#define TP_CLUSTER_EOC 0x80000000 /* end of clusters */ #define TP_CLUSTER_INIT_MASK 0x0000003f /* initiator mask */
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Gong Qianyu Sent: Thursday, June 30, 2016 3:31 PM To: york sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Zhiqiang Hou zhiqiang.hou@nxp.com; Huan Wang alison.wang@nxp.com; Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com Subject: [U-Boot] [PATCH 1/3] armv8: fsl-layerscape: Add A72 core detection
Please avoid patches without any description.
-prabhakar
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com Signed-off-by: Mihai Bantea mihai.bantea@freescale.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index eb2cbc3..4df467d 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -32,3 +32,7 @@ endif ifneq ($(CONFIG_LS1012A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1012a_serdes.o endif + +ifneq ($(CONFIG_LS1046A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o +endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c index fe3444a..f73092a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c @@ -13,6 +13,9 @@ #ifdef CONFIG_SYS_FSL_SRDS_1 static u8 serdes1_prtcl_map[SERDES_PRCTL_COUNT]; #endif +#ifdef CONFIG_SYS_FSL_SRDS_2 +static u8 serdes2_prtcl_map[SERDES_PRCTL_COUNT]; +#endif
int is_serdes_configured(enum srds_prtcl device) { @@ -21,6 +24,9 @@ int is_serdes_configured(enum srds_prtcl device) #ifdef CONFIG_SYS_FSL_SRDS_1 ret |= serdes1_prtcl_map[device]; #endif +#ifdef CONFIG_SYS_FSL_SRDS_2 + ret |= serdes2_prtcl_map[device]; +#endif
return !!ret; } @@ -38,6 +44,12 @@ int serdes_get_first_lane(u32 sd, enum srds_prtcl device) cfg >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; break; #endif +#ifdef CONFIG_SYS_FSL_SRDS_2 + case FSL_SRDS_2: + cfg &= FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_MASK; + cfg >>= FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_SHIFT; + break; +#endif default: printf("invalid SerDes%d\n", sd); break; @@ -114,4 +126,11 @@ void fsl_serdes_init(void) FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT, serdes1_prtcl_map); #endif +#ifdef CONFIG_SYS_FSL_SRDS_2 + serdes_init(FSL_SRDS_2, + CONFIG_SYS_FSL_SERDES_ADDR, + FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_MASK, + FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_SHIFT, + serdes2_prtcl_map); +#endif } diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index d0dc58d..8922197 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -107,6 +107,12 @@ void get_sys_info(struct sys_info *sys_info) case 3: sys_info->freq_fman[0] = freq_c_pll[0] / 3; break; + case 4: + sys_info->freq_fman[0] = freq_c_pll[0] / 4; + break; + case 5: + sys_info->freq_fman[0] = sys_info->freq_systembus; + break; case 6: sys_info->freq_fman[0] = freq_c_pll[1] / 2; break; @@ -124,8 +130,23 @@ void get_sys_info(struct sys_info *sys_info) #ifdef CONFIG_FSL_ESDHC #ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK rcw_tmp = in_be32(&gur->rcwsr[15]); - rcw_tmp = (rcw_tmp & HWA_CGA_M2_CLK_SEL) >> HWA_CGA_M2_CLK_SHIFT; - sys_info->freq_sdhc = freq_c_pll[1] / rcw_tmp; + switch ((rcw_tmp & HWA_CGA_M2_CLK_SEL) >> HWA_CGA_M2_CLK_SHIFT) { + case 1: + sys_info->freq_sdhc = freq_c_pll[1]; + break; + case 2: + sys_info->freq_sdhc = freq_c_pll[1] / 2; + break; + case 3: + sys_info->freq_sdhc = freq_c_pll[1] / 3; + break; + case 6: + sys_info->freq_sdhc = freq_c_pll[0] / 2; + break; + default: + printf("Error: Unknown ESDHC clock select!\n"); + break; + } #else sys_info->freq_sdhc = sys_info->freq_systembus; #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c new file mode 100644 index 0000000..1da6b71 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c @@ -0,0 +1,99 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/immap_lsch2.h> + +struct serdes_config { + u32 protocol; + u8 lanes[SRDS_MAX_LANES]; +}; + +static struct serdes_config serdes1_cfg_tbl[] = { + /* SerDes 1 */ + {0x3333, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {0x1133, {XFI_FM1_MAC9, XFI_FM1_MAC10, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {0x1333, {XFI_FM1_MAC9, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {0x2333, {SGMII_2500_FM1_DTSEC9, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {0x2233, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0x1040, {XFI_FM1_MAC9, NONE, QSGMII_FM1_A, NONE} }, + {0x2040, {SGMII_2500_FM1_DTSEC9, NONE, QSGMII_FM1_A, NONE} }, + {0x1163, {XFI_FM1_MAC9, XFI_FM1_MAC10, PCIE1, SGMII_FM1_DTSEC6} }, + {0x2263, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10, PCIE1, + SGMII_FM1_DTSEC6} }, + {0x3363, {SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6, PCIE1, + SGMII_FM1_DTSEC6} }, + {0x2223, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10, + SGMII_2500_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {} +}; + +static struct serdes_config serdes2_cfg_tbl[] = { + /* SerDes 2 */ + {0x8888, {PCIE1, PCIE1, PCIE1, PCIE1} }, + {0x5559, {PCIE1, PCIE2, PCIE3, SATA1} }, + {0x5577, {PCIE1, PCIE2, PCIE3, PCIE3} }, + {0x5506, {PCIE1, PCIE2, NONE, PCIE3} }, + {0x0506, {NONE, PCIE2, NONE, PCIE3} }, + {0x0559, {NONE, PCIE2, PCIE3, SATA1} }, + {0x5A59, {PCIE1, SGMII_FM1_DTSEC2, PCIE3, SATA1} }, + {0x5A06, {PCIE1, SGMII_FM1_DTSEC2, NONE, PCIE3} }, + {} +}; + +static struct serdes_config *serdes_cfg_tbl[] = { + serdes1_cfg_tbl, + serdes2_cfg_tbl, +}; + +enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) +{ + struct serdes_config *ptr; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + while (ptr->protocol) { + if (ptr->protocol == cfg) + return ptr->lanes[lane]; + ptr++; + } + + return 0; +} + +int is_serdes_prtcl_valid(int serdes, u32 prtcl) +{ + int i; + struct serdes_config *ptr; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + while (ptr->protocol) { + if (ptr->protocol == prtcl) + break; + ptr++; + } + + if (!ptr->protocol) + return 0; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (ptr->lanes[i] != NONE) + return 1; + } + + return 0; +} diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 44fe0c0..85e21fc 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -229,6 +229,52 @@ #define CONFIG_SYS_FSL_SRDS_1 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" #define CONFIG_SYS_FSL_SEC_BE +#elif defined(CONFIG_LS1046A) +#define CONFIG_MAX_CPUS 4 +#define CONFIG_SYS_CACHELINE_SIZE 64 +#define CONFIG_SYS_FMAN_V3 +#define CONFIG_SYS_NUM_FMAN 1 +#define CONFIG_SYS_NUM_FM1_DTSEC 8 +#define CONFIG_SYS_NUM_FM1_10GEC 2 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0x01000000 +#define CONFIG_SYS_FSL_SEC_COMPAT 5 +#define CONFIG_SYS_FSL_OCRAM_BASE 0x10000000 /* initial RAM */ +#define CONFIG_SYS_FSL_OCRAM_SIZE 0x200000 /* 2 MiB */ +#define CONFIG_SYS_FSL_DDR_BE +#define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) +#define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE + +#define CONFIG_SYS_FSL_CCSR_GUR_BE +#define CONFIG_SYS_FSL_CCSR_SCFG_BE +#define CONFIG_SYS_FSL_IFC_BE +#define CONFIG_SYS_FSL_ESDHC_BE +#define CONFIG_SYS_FSL_WDOG_BE +#define CONFIG_SYS_FSL_DSPI_BE +#define CONFIG_SYS_FSL_QSPI_BE +#define CONFIG_SYS_FSL_PEX_LUT_BE + +#define SRDS_MAX_LANES 4 +#define CONFIG_SYS_FSL_SRDS_1 +#define CONFIG_SYS_FSL_SRDS_2 + +#define CONFIG_SYS_FSL_SFP_VER_3_2 +#define CONFIG_SYS_FSL_SNVS_LE +#define CONFIG_SYS_FSL_SEC_BE +#define CONFIG_SYS_FSL_SFP_BE +#define CONFIG_SYS_FSL_SRK_LE +#define CONFIG_KEY_REVOCATION + +/* SMMU Defintions */ +#define SMMU_BASE 0x09000000 + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0x01410000 +#define GICC_BASE 0x01420000 + +#define CONFIG_SYS_FSL_ERRATUM_A009929 +#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #else #error SoC not defined #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index 197b0eb..b9a3c19 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -13,6 +13,7 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LS2045A, LS2045A, 4), CPU_TYPE_ENTRY(LS1043A, LS1043A, 4), CPU_TYPE_ENTRY(LS1023A, LS1023A, 2), + CPU_TYPE_ENTRY(LS1046A, LS1046A, 4), CPU_TYPE_ENTRY(LS2040A, LS2040A, 4), CPU_TYPE_ENTRY(LS1012A, LS1012A, 1), }; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h index 487cba8..bd8494a 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h @@ -140,6 +140,7 @@ enum srds_prtcl {
enum srds { FSL_SRDS_1 = 0, + FSL_SRDS_2 = 1, };
#endif @@ -150,7 +151,7 @@ int serdes_get_first_lane(u32 sd, enum srds_prtcl device); enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane); int is_serdes_prtcl_valid(int serdes, u32 prtcl);
-#ifdef CONFIG_LS1043A +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A) const char *serdes_clock_to_string(u32 clock); int get_serdes_protocol(void); #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index cbb252c..05f497c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -228,6 +228,8 @@ struct ccsr_gur { #define FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_MASK 0x3f #define FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK 0xffff0000 #define FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT 16 +#define FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_MASK 0x0000ffff +#define FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_SHIFT 0 #define RCW_SB_EN_REG_INDEX 7 #define RCW_SB_EN_MASK 0x00200000
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 39e8c7a..5ea6205 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -44,6 +44,7 @@ struct cpu_type { #define SVR_LS1012A 0x870400 #define SVR_LS1043A 0x879200 #define SVR_LS1023A 0x879208 +#define SVR_LS1046A 0x870704 #define SVR_LS2045A 0x870120 #define SVR_LS2080A 0x870110 #define SVR_LS2085A 0x870100
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Gong Qianyu Sent: Thursday, June 30, 2016 3:31 PM To: york sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Mihai Bantea mihai.bantea@freescale.com; Zhiqiang Hou zhiqiang.hou@nxp.com; Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com Subject: [U-Boot] [PATCH 2/3] armv8/fsl_lsch2: Add LS1046A SoC support
Please add SoC details in arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc
Strange missing list of file modified :)
+ifneq ($(CONFIG_LS1046A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c index fe3444a..f73092a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c @@ -13,6 +13,9 @@ #ifdef CONFIG_SYS_FSL_SRDS_1 static u8 serdes1_prtcl_map[SERDES_PRCTL_COUNT]; #endif +#ifdef CONFIG_SYS_FSL_SRDS_2 +static u8 serdes2_prtcl_map[SERDES_PRCTL_COUNT]; +#endif
- ret |= serdes2_prtcl_map[device];
- case FSL_SRDS_2:
break;
- serdes_init(FSL_SRDS_2,
serdes2_prtcl_map);
+#endif }
Ideally this should be separate patch. Like Adding support of SerDes2
- case 4:
break;
- case 5:
case 6: sys_info->freq_fman[0] = freq_c_pll[1] / 2; break;break;
- switch ((rcw_tmp & HWA_CGA_M2_CLK_SEL) >>
- case 1:
break;
- case 2:
break;
- case 3:
break;
- case 6:
break;
- default:
break;
- Copyright 2016 Freescale Semiconductor, Inc.
- u32 protocol;
- u8 lanes[SRDS_MAX_LANES];
- /* SerDes 1 */
- {0x3333, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC10,
SGMII_FM1_DTSEC5,
- {0x1133, {XFI_FM1_MAC9, XFI_FM1_MAC10, SGMII_FM1_DTSEC5,
- {0x1333, {XFI_FM1_MAC9, SGMII_FM1_DTSEC10,
SGMII_FM1_DTSEC5,
- {0x2333, {SGMII_2500_FM1_DTSEC9, SGMII_FM1_DTSEC10,
SGMII_FM1_DTSEC5,
- {0x2233, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10,
- {0x1040, {XFI_FM1_MAC9, NONE, QSGMII_FM1_A, NONE} },
- {0x2040, {SGMII_2500_FM1_DTSEC9, NONE, QSGMII_FM1_A, NONE}
- {0x1163, {XFI_FM1_MAC9, XFI_FM1_MAC10, PCIE1,
- {0x2263, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10,
PCIE1,
- {0x3363, {SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6, PCIE1,
- {0x2223, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10,
- /* SerDes 2 */
- {0x8888, {PCIE1, PCIE1, PCIE1, PCIE1} },
- {0x5559, {PCIE1, PCIE2, PCIE3, SATA1} },
- {0x5577, {PCIE1, PCIE2, PCIE3, PCIE3} },
- {0x5506, {PCIE1, PCIE2, NONE, PCIE3} },
- {0x0506, {NONE, PCIE2, NONE, PCIE3} },
- {0x0559, {NONE, PCIE2, PCIE3, SATA1} },
- {0x5A59, {PCIE1, SGMII_FM1_DTSEC2, PCIE3, SATA1} },
- {0x5A06, {PCIE1, SGMII_FM1_DTSEC2, NONE, PCIE3} },
- serdes1_cfg_tbl,
- serdes2_cfg_tbl,
+enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) {
- struct serdes_config *ptr;
- if (serdes >= ARRAY_SIZE(serdes_cfg_tbl))
- ptr = serdes_cfg_tbl[serdes];
- while (ptr->protocol) {
ptr++;
+int is_serdes_prtcl_valid(int serdes, u32 prtcl) {
- int i;
break;
ptr++;
- if (!ptr->protocol)
- for (i = 0; i < SRDS_MAX_LANES; i++) {
return 1;
Does LS1046 support IFC?
Is this errata confirmed for this SoC?
- CPU_TYPE_ENTRY(LS1046A, LS1046A, 4),
If possible, please add other personality also.
- FSL_SRDS_2 = 1,
Please try to use chassis specific define
const char *serdes_clock_to_string(u32 clock); int get_serdes_protocol(void); #endif diff --git a/arch/arm/include/asm/arch- fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl- layerscape/immap_lsch2.h index cbb252c..05f497c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -228,6 +228,8 @@ struct ccsr_gur { #define FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_MASK 0x3f #define FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK 0xffff0000 #define FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT 16 +#define FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_MASK 0x0000ffff +#define FSL_CHASSIS2_RCWSR4_SRDS2_PRTCL_SHIFT 0 #define RCW_SB_EN_REG_INDEX 7 #define RCW_SB_EN_MASK 0x00200000
--prabhakar
Hi Prabhakar,
-----Original Message----- From: Prabhakar Kushwaha Sent: Thursday, June 30, 2016 6:30 PM To: Qianyu Gong qianyu.gong@nxp.com; york sun york.sun@nxp.com; u- boot@lists.denx.de Cc: Mihai Bantea mihai.bantea@freescale.com; Zhiqiang Hou zhiqiang.hou@nxp.com; Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com Subject: RE: [U-Boot] [PATCH 2/3] armv8/fsl_lsch2: Add LS1046A SoC support
Ok.
- case FSL_SRDS_2:
break;
serdes2_prtcl_map);
+#endif }
Ok.
- case 4:
break;
- case 5:
- case 1:
break;
- case 2:
break;
- case 3:
break;
- case 6:
break;
- default:
break;
- u32 protocol;
- /* SerDes 1 */
SGMII_FM1_DTSEC5,
SGMII_FM1_DTSEC5,
SGMII_FM1_DTSEC5,
PCIE1,
- /* SerDes 2 */
- serdes1_cfg_tbl,
- serdes2_cfg_tbl,
ptr++;
- int i;
break;
ptr++;
return 1;
Yes.
+#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0x01000000 +#define CONFIG_SYS_FSL_SEC_COMPAT 5 +#define CONFIG_SYS_FSL_OCRAM_BASE 0x10000000 /* initial RAM */ +#define CONFIG_SYS_FSL_OCRAM_SIZE 0x200000 /* 2 MiB */ +#define CONFIG_SYS_FSL_DDR_BE +#define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define +CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
Not yet. I'll remove it.
- FSL_SRDS_2 = 1,
OK. I'll add LS1026A.
Thanks, Qianyu
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com
diff --git a/drivers/net/fm/Makefile b/drivers/net/fm/Makefile index 493cdc6..344fbe2 100644 --- a/drivers/net/fm/Makefile +++ b/drivers/net/fm/Makefile @@ -39,3 +39,4 @@ obj-$(CONFIG_PPC_T4080) += t4240.o obj-$(CONFIG_PPC_B4420) += b4860.o obj-$(CONFIG_PPC_B4860) += b4860.o obj-$(CONFIG_LS1043A) += ls1043.o +obj-$(CONFIG_LS1046A) += ls1046.o diff --git a/drivers/net/fm/ls1046.c b/drivers/net/fm/ls1046.c new file mode 100644 index 0000000..bf55554 --- /dev/null +++ b/drivers/net/fm/ls1046.c @@ -0,0 +1,123 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <phy.h> +#include <fm_eth.h> +#include <asm/io.h> +#include <asm/arch/fsl_serdes.h> + +#define FSL_CHASSIS2_RCWSR13_EC1 0xe0000000 /* bits 416..418 */ +#define FSL_CHASSIS2_RCWSR13_EC1_DTSEC3_RGMII 0x00000000 +#define FSL_CHASSIS2_RCWSR13_EC1_GPIO 0x20000000 +#define FSL_CHASSIS2_RCWSR13_EC1_FTM 0xa0000000 +#define FSL_CHASSIS2_RCWSR13_EC2 0x1c000000 /* bits 419..421 */ +#define FSL_CHASSIS2_RCWSR13_EC2_DTSEC4_RGMII 0x00000000 +#define FSL_CHASSIS2_RCWSR13_EC2_GPIO 0x04000000 +#define FSL_CHASSIS2_RCWSR13_EC2_1588 0x08000000 +#define FSL_CHASSIS2_RCWSR13_EC2_FTM 0x14000000 + +u32 port_to_devdisr[] = { + [FM1_DTSEC1] = FSL_CHASSIS2_DEVDISR2_DTSEC1_1, + [FM1_DTSEC2] = FSL_CHASSIS2_DEVDISR2_DTSEC1_2, + [FM1_DTSEC3] = FSL_CHASSIS2_DEVDISR2_DTSEC1_3, + [FM1_DTSEC4] = FSL_CHASSIS2_DEVDISR2_DTSEC1_4, + [FM1_DTSEC5] = FSL_CHASSIS2_DEVDISR2_DTSEC1_5, + [FM1_DTSEC6] = FSL_CHASSIS2_DEVDISR2_DTSEC1_6, + [FM1_DTSEC9] = FSL_CHASSIS2_DEVDISR2_DTSEC1_9, + [FM1_DTSEC10] = FSL_CHASSIS2_DEVDISR2_DTSEC1_10, + [FM1_10GEC1] = FSL_CHASSIS2_DEVDISR2_10GEC1_1, + [FM1_10GEC2] = FSL_CHASSIS2_DEVDISR2_10GEC1_2, + [FM1_10GEC3] = FSL_CHASSIS2_DEVDISR2_10GEC1_3, + [FM1_10GEC4] = FSL_CHASSIS2_DEVDISR2_10GEC1_4, +}; + +static int is_device_disabled(enum fm_port port) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 devdisr2 = in_be32(&gur->devdisr2); + + return port_to_devdisr[port] & devdisr2; +} + +void fman_disable_port(enum fm_port port) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + + setbits_be32(&gur->devdisr2, port_to_devdisr[port]); +} + +phy_interface_t fman_port_enet_if(enum fm_port port) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 rcwsr13 = in_be32(&gur->rcwsr[13]); + + if (is_device_disabled(port)) + return PHY_INTERFACE_MODE_NONE; + + if ((port == FM1_10GEC1) && (is_serdes_configured(XFI_FM1_MAC9))) + return PHY_INTERFACE_MODE_XGMII; + + if ((port == FM1_DTSEC9) && (is_serdes_configured(XFI_FM1_MAC9))) + return PHY_INTERFACE_MODE_NONE; + + if ((port == FM1_10GEC2) && (is_serdes_configured(XFI_FM1_MAC10))) + return PHY_INTERFACE_MODE_XGMII; + + if ((port == FM1_DTSEC10) && (is_serdes_configured(XFI_FM1_MAC10))) + return PHY_INTERFACE_MODE_NONE; + + if (port == FM1_DTSEC3) + if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC1) == + FSL_CHASSIS2_RCWSR13_EC1_DTSEC3_RGMII) + return PHY_INTERFACE_MODE_RGMII; + + if (port == FM1_DTSEC4) + if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC2) == + FSL_CHASSIS2_RCWSR13_EC2_DTSEC4_RGMII) + return PHY_INTERFACE_MODE_RGMII; + + /* handle SGMII, only MAC 2/5/6/9/10 available */ + switch (port) { + case FM1_DTSEC2: + case FM1_DTSEC5: + case FM1_DTSEC6: + case FM1_DTSEC9: + case FM1_DTSEC10: + if (is_serdes_configured(SGMII_FM1_DTSEC2 + port - FM1_DTSEC2)) + return PHY_INTERFACE_MODE_SGMII; + break; + default: + break; + } + + /* handle 2.5G SGMII, only MAC 5/9/10 available */ + switch (port) { + case FM1_DTSEC5: + case FM1_DTSEC9: + case FM1_DTSEC10: + if (is_serdes_configured(SGMII_2500_FM1_DTSEC5 + + port - FM1_DTSEC5)) + return PHY_INTERFACE_MODE_SGMII_2500; + break; + default: + break; + } + + /* handle QSGMII, only MAC 1/5/6/10 available */ + switch (port) { + case FM1_DTSEC1: + case FM1_DTSEC5: + case FM1_DTSEC6: + case FM1_DTSEC10: + if (is_serdes_configured(QSGMII_FM1_A)) + return PHY_INTERFACE_MODE_QSGMII; + break; + default: + break; + } + + return PHY_INTERFACE_MODE_NONE; +}
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Gong Qianyu Sent: Thursday, June 30, 2016 3:31 PM To: york sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Zhiqiang Hou zhiqiang.hou@nxp.com; Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com Subject: [U-Boot] [PATCH 3/3] armv8/ls1046a: Add Fman support
Missing description.
This patch should be merged with previous patch.
--prabhakar
Hi Prabhakar,
-----Original Message----- From: Prabhakar Kushwaha Sent: Thursday, June 30, 2016 6:32 PM To: Qianyu Gong qianyu.gong@nxp.com; york sun york.sun@nxp.com; u- boot@lists.denx.de Cc: Zhiqiang Hou zhiqiang.hou@nxp.com; Wenbin Song wenbin.song@nxp.com; Mingkai Hu mingkai.hu@nxp.com Subject: RE: [U-Boot] [PATCH 3/3] armv8/ls1046a: Add Fman support
--prabhakar
In fact this patch has just done modifications in driver code. So not proper to be merged with SoC patch. I think the title is confusing and will modify it.
Regards, Qianyu
Gong Qianyu
Prabhakar Kushwaha
Qianyu Gong
