[U-Boot] [PATCH v2 16/16] sf: Add Flag status register polling support
Flag status register polling is required for micron 512Mb flash devices onwards, for performing erase/program operations.
Like polling for WIP(Write-In-Progress) bit in read status register, spi_flash_cmd_wait_ready will poll for PEC(Program-Erase-Control) bit in flag status register.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v2: - none
drivers/mtd/spi/spi_flash.c | 15 ++++++++++++--- drivers/mtd/spi/spi_flash_internal.h | 3 +++ 2 files changed, 15 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 527423d..8cd2988 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -195,25 +195,34 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) unsigned long timebase; int ret; u8 status; + u8 check_status = 0x0; u8 poll_bit = STATUS_WIP; u8 cmd = CMD_READ_STATUS;
+ if ((flash->idcode0 == 0x20) && + (flash->size >= SPI_FLASH_512MB_STMIC)) { + poll_bit = STATUS_PEC; + check_status = poll_bit; + cmd = CMD_FLAG_STATUS; + } + timebase = get_timer(0); do { WATCHDOG_RESET();
ret = spi_flash_read_common(flash, &cmd, 1, &status, 1); if (ret < 0) { - debug("SF: fail to read read status register\n"); + debug("SF: fail to read %s status register\n", + cmd == CMD_READ_STATUS ? "read" : "flag"); return ret; }
- if ((status & poll_bit) == 0) + if ((status & poll_bit) == check_status) break;
} while (get_timer(timebase) < timeout);
- if ((status & poll_bit) == 0) + if ((status & poll_bit) == check_status) return 0;
/* Timed out */ diff --git a/drivers/mtd/spi/spi_flash_internal.h b/drivers/mtd/spi/spi_flash_internal.h index ac4530f..cb7a505 100644 --- a/drivers/mtd/spi/spi_flash_internal.h +++ b/drivers/mtd/spi/spi_flash_internal.h @@ -13,6 +13,7 @@ #define SPI_FLASH_SECTOR_ERASE_TIMEOUT (10 * CONFIG_SYS_HZ)
#define SPI_FLASH_16MB_BOUN 0x1000000 +#define SPI_FLASH_512MB_STMIC 0x4000000
/* Common commands */ #define CMD_READ_ID 0x9f @@ -24,6 +25,7 @@ #define CMD_PAGE_PROGRAM 0x02 #define CMD_WRITE_DISABLE 0x04 #define CMD_READ_STATUS 0x05 +#define CMD_FLAG_STATUS 0x70 #define CMD_WRITE_ENABLE 0x06 #define CMD_ERASE_4K 0x20 #define CMD_ERASE_32K 0x52 @@ -38,6 +40,7 @@
/* Common status */ #define STATUS_WIP 0x01 +#define STATUS_PEC 0x80
/* Send a single-byte command to the device and read the response */ int spi_flash_cmd(struct spi_slave *spi, u8 cmd, void *response, size_t len);
Hi Simon,
Please let know your comments.
I have changed the logic, but removed spi_flash_cmd_poll_bit() use poll code on spi_flash_cmd_wait_ready() as no other call for spi_flash_cmd_poll_bit() this.
And also for read_status the check_status i assigned as 0,earlier it has direct 0 (w/o check_status variable).
To add the support for flag status on the same code, i define this check_status. I don't see any coding functionality change for now, compared to before.
-- Thanks, Jagan.
On Fri, May 31, 2013 at 6:22 PM, Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com wrote:
timebase = get_timer(0); do { WATCHDOG_RESET(); ret = spi_flash_read_common(flash, &cmd, 1, &status, 1); if (ret < 0) {
if ((status & poll_bit) == check_status) break; } while (get_timer(timebase) < timeout);
if ((status & poll_bit) == check_status) return 0; /* Timed out */
/* Send a single-byte command to the device and read the response */ int spi_flash_cmd(struct spi_slave *spi, u8 cmd, void *response, size_t len); -- 1.8.3
Hi Jagan,
On Sat, Jun 8, 2013 at 1:32 AM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Simon,
This is not the right patch, but in one of them you remove spi_flash_cmd_poll_bit(), so that it no longer works the same way. You will get lots of individual SPI transactions on the bus instead of a single one that reads the status byte continuously.
Do we need to change this?
-- Thanks, Jagan.
"flag");
return ret; }
len);
-- 1.8.3
Hi Simon,
On Sat, Jun 8, 2013 at 8:02 PM, Simon Glass sjg@chromium.org wrote:
Hi Jagan,
Hi Simon,
I couldn't understand you clearly.
Earlier all erase/write they were calling spi_flash_cmd_wait_ready with flash, timeout values. spi_flash_cmd_wait_ready() is intern call to spi_flash_cmd_poll_bit() with CMD_READ_STATUS and STATUS_WIP.
In my changes I have removed spi_flash_cmd_poll_bit() as there is no other caller except spi_flash_cmd_wait_ready() so all polling stuff on spi_flash_cmd_wait_ready() means, still erase/program can call spi_flash_cmd_wait_ready() with flash, timeout and CMD_READ_STATUS and STAUS_WIP were use directly used on spi_flash_cmd_wait_ready() instead of passing through spi_flash_cmd_poll_bit().
Any wrong here, please comment.
Thanks, Jagan.
-- Thanks, Jagan.
register\n");
Hi Jagan,
On Sat, Jun 8, 2013 at 7:44 AM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Simon,
Hi Jagan,
wrote:
Hi Simon,
will
one
You have changed the implementation of spi_flash_cmd_wait_ready() so that instead of polling for the bit within a single SPI transaction (CS staying asserted) you are now doing multiple transactions.
The old code for spi_flash_cmd_wait_ready() ended up with an algorithm like this, when you look inside the nested functions:
spi_claim_bus(spi); ret = spi_xfer(spi, cmd_len * 8, cmd, NULL, SPI_XFER_BEGIN); do { ret = spi_xfer(spi, 8, NULL, &status, 0); ... } spi_xfer(spi, 0, NULL, NULL, SPI_XFER_END); spi_release_bus(spi);
The new code is:
do { spi_claim_bus(spi); ret = spi_xfer(spi, cmd_len * 8, cmd, NULL, SPI_XFER_BEGIN); ret = spi_xfer(spi, data_len * 8, data_out, data_in, SPI_XFER_END); spi_release_bus(spi); ... } while (...)
Can you see the difference? The bus clain and SPI_XFER_BEGIN/END is now inside the loop.
Is there a reason why this change is needed? Does updating the bank address not work with the old code?
It is find to move the spi_flash_cmd_poll_bit() function into spi_flash_cmd_wait_ready() - I am not worried about that. I am only worried about your change of algorithm as above.
Thanks, Jagan.
-- Thanks, Jagan.
1);
if (ret < 0) {
register\n");
size_t
len);
1.8.3
Hi Simon,
On Sun, Jun 9, 2013 at 7:43 PM, Simon Glass sjg@chromium.org wrote:
Hi Jagan,
Hi Simon,
Hi Jagan,
Hi Simon,
The new code is:
Understand, i thought as we do _END transfer in old code as well. It could be fine to go with using common function as it will do _BEGIN and _END.
What could be the problem you see if we do _BEGIN and _END on loop...?
It doesn't effect with banking.
Thanks, Jagan.
Thanks, Jagan.
-- Thanks, Jagan.
1); if (ret < 0) {
register\n");
register\n",
Hi Simon,
On Sun, Jun 9, 2013 at 9:36 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Simon,
Hi Jagan,
Hi Simon,
Hi Jagan,
Hi Simon,
The new code is:
Thanks, Jagan.
Thanks, Jagan.
-- Thanks, Jagan.
1); if (ret < 0) {
register\n");
register\n",
May be I will explore much for this, update the changes later. and i will remains the code as before as of now.
Do you have any more comments on this series. I will going to send v3 and planning to apply.
-- Thanks, Jagan.
Hi Jagan,
On Mon, Jun 10, 2013 at 8:27 AM, Jagan Teki jagannadh.teki@gmail.comwrote:
Hi Simon,
Hi Simon,
Hi Jagan,
wrote:
Hi Simon,
Hi Jagan,
On Sat, Jun 8, 2013 at 1:32 AM, Jagan Teki <jagannadh.teki@gmail.com
wrote:
Hi Simon,
You
single
that
staying
like
The new code is:
SPI_XFER_END);
and _END.
address
Thanks, Jagan.
worried
Thanks, Jagan.
-- Thanks, Jagan.
On Fri, May 31, 2013 at 6:22 PM, Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com wrote: > Flag status register polling is required for micron 512Mb flash > devices onwards, for performing erase/program operations. > > Like polling for WIP(Write-In-Progress) bit in read status
register,
> spi_flash_cmd_wait_ready will poll for PEC(Program-Erase-Control) > bit in flag status register. > > Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com > --- > Changes for v2: > - none > > drivers/mtd/spi/spi_flash.c | 15 ++++++++++++--- > drivers/mtd/spi/spi_flash_internal.h | 3 +++ > 2 files changed, 15 insertions(+), 3 deletions(-) > > diff --git a/drivers/mtd/spi/spi_flash.c > b/drivers/mtd/spi/spi_flash.c > index 527423d..8cd2988 100644 > --- a/drivers/mtd/spi/spi_flash.c > +++ b/drivers/mtd/spi/spi_flash.c > @@ -195,25 +195,34 @@ int spi_flash_cmd_wait_ready(struct
spi_flash
> *flash, unsigned long timeout) > unsigned long timebase; > int ret; > u8 status; > + u8 check_status = 0x0; > u8 poll_bit = STATUS_WIP; > u8 cmd = CMD_READ_STATUS; > > + if ((flash->idcode0 == 0x20) && > + (flash->size >= SPI_FLASH_512MB_STMIC)) { > + poll_bit = STATUS_PEC; > + check_status = poll_bit; > + cmd = CMD_FLAG_STATUS; > + } > + > timebase = get_timer(0); > do { > WATCHDOG_RESET(); > > ret = spi_flash_read_common(flash, &cmd, 1,
&status,
> 1); > if (ret < 0) { > - debug("SF: fail to read read status > register\n"); > + debug("SF: fail to read %s status > register\n", > + cmd == CMD_READ_STATUS ? "read" : > "flag"); > return ret; > } > > - if ((status & poll_bit) == 0) > + if ((status & poll_bit) == check_status) > break; > > } while (get_timer(timebase) < timeout); > > - if ((status & poll_bit) == 0) > + if ((status & poll_bit) == check_status) > return 0; > > /* Timed out */ > diff --git a/drivers/mtd/spi/spi_flash_internal.h > b/drivers/mtd/spi/spi_flash_internal.h > index ac4530f..cb7a505 100644 > --- a/drivers/mtd/spi/spi_flash_internal.h > +++ b/drivers/mtd/spi/spi_flash_internal.h > @@ -13,6 +13,7 @@ > #define SPI_FLASH_SECTOR_ERASE_TIMEOUT (10 * CONFIG_SYS_HZ) > > #define SPI_FLASH_16MB_BOUN 0x1000000 > +#define SPI_FLASH_512MB_STMIC 0x4000000 > > /* Common commands */ > #define CMD_READ_ID 0x9f > @@ -24,6 +25,7 @@ > #define CMD_PAGE_PROGRAM 0x02 > #define CMD_WRITE_DISABLE 0x04 > #define CMD_READ_STATUS 0x05 > +#define CMD_FLAG_STATUS 0x70 > #define CMD_WRITE_ENABLE 0x06 > #define CMD_ERASE_4K 0x20 > #define CMD_ERASE_32K 0x52 > @@ -38,6 +40,7 @@ > > /* Common status */ > #define STATUS_WIP 0x01 > +#define STATUS_PEC 0x80 > > /* Send a single-byte command to the device and read the
response */
> int spi_flash_cmd(struct spi_slave *spi, u8 cmd, void *response, > size_t > len); > -- > 1.8.3
Do you mean you will keep the old status-reading algorithm, or change to your new one?
I don't have any other comments.
-- Thanks, Jagan.
On Tue, Jun 11, 2013 at 2:01 AM, Simon Glass sjg@chromium.org wrote:
Hi Jagan,
On Mon, Jun 10, 2013 at 8:27 AM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Simon,
Hi Simon,
Hi Jagan,
Hi Simon,
Hi Jagan,
On Sat, Jun 8, 2013 at 1:32 AM, Jagan Teki jagannadh.teki@gmail.com wrote: > > Hi Simon, > > Please let know your comments. > > I have changed the logic, but removed spi_flash_cmd_poll_bit() use > poll code on spi_flash_cmd_wait_ready() > as no other call for spi_flash_cmd_poll_bit() this. > > And also for read_status the check_status i assigned as 0,earlier > it > has direct 0 (w/o check_status variable). > > To add the support for flag status on the same code, i define this > check_status. > I don't see any coding functionality change for now, compared to > before.
The new code is:
Thanks, Jagan.
Thanks, Jagan.
> > > -- > Thanks, > Jagan. > > On Fri, May 31, 2013 at 6:22 PM, Jagannadha Sutradharudu Teki > jagannadha.sutradharudu-teki@xilinx.com wrote: > > Flag status register polling is required for micron 512Mb flash > > devices onwards, for performing erase/program operations. > > > > Like polling for WIP(Write-In-Progress) bit in read status > > register, > > spi_flash_cmd_wait_ready will poll for PEC(Program-Erase-Control) > > bit in flag status register. > > > > Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com > > --- > > Changes for v2: > > - none > > > > drivers/mtd/spi/spi_flash.c | 15 ++++++++++++--- > > drivers/mtd/spi/spi_flash_internal.h | 3 +++ > > 2 files changed, 15 insertions(+), 3 deletions(-) > > > > diff --git a/drivers/mtd/spi/spi_flash.c > > b/drivers/mtd/spi/spi_flash.c > > index 527423d..8cd2988 100644 > > --- a/drivers/mtd/spi/spi_flash.c > > +++ b/drivers/mtd/spi/spi_flash.c > > @@ -195,25 +195,34 @@ int spi_flash_cmd_wait_ready(struct > > spi_flash > > *flash, unsigned long timeout) > > unsigned long timebase; > > int ret; > > u8 status; > > + u8 check_status = 0x0; > > u8 poll_bit = STATUS_WIP; > > u8 cmd = CMD_READ_STATUS; > > > > + if ((flash->idcode0 == 0x20) && > > + (flash->size >= SPI_FLASH_512MB_STMIC)) { > > + poll_bit = STATUS_PEC; > > + check_status = poll_bit; > > + cmd = CMD_FLAG_STATUS; > > + } > > + > > timebase = get_timer(0); > > do { > > WATCHDOG_RESET(); > > > > ret = spi_flash_read_common(flash, &cmd, 1, > > &status, > > 1); > > if (ret < 0) { > > - debug("SF: fail to read read status > > register\n"); > > + debug("SF: fail to read %s status > > register\n", > > + cmd == CMD_READ_STATUS ? "read" : > > "flag"); > > return ret; > > } > > > > - if ((status & poll_bit) == 0) > > + if ((status & poll_bit) == check_status) > > break; > > > > } while (get_timer(timebase) < timeout); > > > > - if ((status & poll_bit) == 0) > > + if ((status & poll_bit) == check_status) > > return 0; > > > > /* Timed out */ > > diff --git a/drivers/mtd/spi/spi_flash_internal.h > > b/drivers/mtd/spi/spi_flash_internal.h > > index ac4530f..cb7a505 100644 > > --- a/drivers/mtd/spi/spi_flash_internal.h > > +++ b/drivers/mtd/spi/spi_flash_internal.h > > @@ -13,6 +13,7 @@ > > #define SPI_FLASH_SECTOR_ERASE_TIMEOUT (10 * CONFIG_SYS_HZ) > > > > #define SPI_FLASH_16MB_BOUN 0x1000000 > > +#define SPI_FLASH_512MB_STMIC 0x4000000 > > > > /* Common commands */ > > #define CMD_READ_ID 0x9f > > @@ -24,6 +25,7 @@ > > #define CMD_PAGE_PROGRAM 0x02 > > #define CMD_WRITE_DISABLE 0x04 > > #define CMD_READ_STATUS 0x05 > > +#define CMD_FLAG_STATUS 0x70 > > #define CMD_WRITE_ENABLE 0x06 > > #define CMD_ERASE_4K 0x20 > > #define CMD_ERASE_32K 0x52 > > @@ -38,6 +40,7 @@ > > > > /* Common status */ > > #define STATUS_WIP 0x01 > > +#define STATUS_PEC 0x80 > > > > /* Send a single-byte command to the device and read the > > response */ > > int spi_flash_cmd(struct spi_slave *spi, u8 cmd, void *response, > > size_t > > len); > > -- > > 1.8.3 >
Will keep the old status-read algo.
-- Thanks, Jagan.
-- Thanks, Jagan.
Jagan Teki
