[U-Boot] [STATUS] v2010.09-rc2 is out / "next" branch available
Hello everybody:
* U-Boot v2010.09-rc2 was released on Sun, 19 Sep 2010.
* Release "v2010.09" is scheduled in 18 days - on September 28, 2010.
For details please see http://www.denx.de/wiki/U-Boot/ReleaseCycle
Please help testing, and check if all your relevant patches have been included.
We also have a new "next" branch now, which should be used as base for any new stuff scheduled to be added for the next release (v2010.12).
Please NOTE: due to some issues with the ARM relocation patches I had no choice but to rebase the "next" branch; sorry if this is causing inconveniences.
Also NOTE: the relocation support that was added to the ARM architecture (which brings it more in sync with the Power Architecture, so there is hope we can merge some more [now] common code) requires to adapt basicly all ARM boards. The changes are relatively simple and straightforward, but require in-depth understanding of the actual hardware - and testing, of course.
This is why the patches provided by Heiko cannot include all boards - this is a task to be performeed by the respective board maintainers. To make the task highly visible, compilation for this boards will actually _break_. See the commit message for commit f1d2b313 "ARM: add relocation support" and doc/README.arm-relocation for further information (including adapting boards and debugging).
Boards that have not been adapted after some time (maximum 2 releases) are considered to be unmaintained and dead and will be removed.
Dear Mike Frysinger,
In message 201009201447.34016.vapier@gentoo.org you wrote:
Please help testing
Blackfin looks sane
Thanks.
could you merge this change: 29.07.2010 [PATCH v2] cmd_mmc: use common usage function
Will do. Thanks for the reminder.
Am 19.09.2010 20:02, schrieb Wolfgang Denk:
Hello everybody:
I've checked the boards eb_cpux9k2 and EB+MCF-EV123, both work with rc2
regards Jens Scharsig
Hi Wolfgang
On 2010-09-19 20:02, Wolfgang Denk wrote:
Hello everybody:
The i.MX31 Litekit board boots Linux from tftp nicely with rc2. Haven't tried NAND or NOR flash functionality.
Regards, Magnus
Jens Scharsig
Magnus Lilja
Mike Frysinger
