[U-Boot] [PATCH 0/3] i.mx6q: Add the ethernet function support
This patch add the ethernet function support for i.mx6q/arm2 board.
The patch has been tested ok by: Dirk Behme dirk.behme@de.bosch.com on freescale i.mx6qarm2 board.
Jason Liu (3): i.mx: i.mx6q: Add the enet clock function fec: add the i.mx6q enet driver support i.mx6q: arm2: Add the enet function support
arch/arm/cpu/armv7/mx6/clock.c | 5 ++ board/freescale/mx6qarm2/mx6qarm2.c | 90 +++++++++++++++++++++++++++++++++++ drivers/net/fec_mxc.c | 10 ++++ drivers/net/fec_mxc.h | 7 ++- include/configs/mx6qarm2.h | 13 ++++- 5 files changed, 122 insertions(+), 3 deletions(-)
Cc: Stefano Babic sbabic@denx.de Signed-off-by: Jason Liu jason.hui@linaro.org --- arch/arm/cpu/armv7/mx6/clock.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index b143535..fa3a124 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -285,6 +285,11 @@ u32 imx_get_uartclk(void) return get_uart_clk(); }
+u32 imx_get_fecclk(void) +{ + return decode_pll(PLL_ENET, CONFIG_SYS_MX6_HCLK); +} + unsigned int mxc_get_clock(enum mxc_clock clk) { switch (clk) {
- return decode_pll(PLL_ENET, CONFIG_SYS_MX6_HCLK);
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Cc: Stefano Babic sbabic@denx.de Signed-off-by: Jason Liu jason.hui@linaro.org --- drivers/net/fec_mxc.c | 10 ++++++++++ drivers/net/fec_mxc.h | 7 ++++++- 2 files changed, 16 insertions(+), 1 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index b05a4c0..3affda8 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -384,6 +384,14 @@ static int fec_open(struct eth_device *edev) writel(1 << 2, &fec->eth->x_cntrl); fec->rbd_index = 0;
+#if defined(CONFIG_MX6Q) + /* Enable ENET HW endian SWAP */ + writel(readl(&fec->eth->ecntrl) | FEC_ECNTRL_DBSWAP, + &fec->eth->ecntrl); + /* Enable ENET store and forward mode */ + writel(readl(&fec->eth->x_wmrk) | FEC_X_WMRK_STRFWD, + &fec->eth->x_wmrk); +#endif /* * Enable FEC-Lite controller */ @@ -485,6 +493,8 @@ static int fec_init(struct eth_device *dev, bd_t* bd) rcntrl = PKTSIZE << FEC_RCNTRL_MAX_FL_SHIFT; if (fec->xcv_type == SEVENWIRE) rcntrl |= FEC_RCNTRL_FCE; + else if (fec->xcv_type == RGMII) + rcntrl |= FEC_RCNTRL_RGMII; else if (fec->xcv_type == RMII) rcntrl |= FEC_RCNTRL_RMII; else /* MII mode */ diff --git a/drivers/net/fec_mxc.h b/drivers/net/fec_mxc.h index 8b26645..39337bf 100644 --- a/drivers/net/fec_mxc.h +++ b/drivers/net/fec_mxc.h @@ -196,6 +196,7 @@ struct ethernet_regs { #define FEC_RCNTRL_PROM 0x00000008 #define FEC_RCNTRL_BC_REJ 0x00000010 #define FEC_RCNTRL_FCE 0x00000020 +#define FEC_RCNTRL_RGMII 0x00000040 #define FEC_RCNTRL_RMII 0x00000100
#define FEC_TCNTRL_GTS 0x00000001 @@ -206,6 +207,9 @@ struct ethernet_regs {
#define FEC_ECNTRL_RESET 0x00000001 /* reset the FEC */ #define FEC_ECNTRL_ETHER_EN 0x00000002 /* enable the FEC */ +#define FEC_ECNTRL_DBSWAP 0x00000100 + +#define FEC_X_WMRK_STRFWD 0x00000100
#if defined(CONFIG_MX25) || defined(CONFIG_MX53) /* defines for MIIGSK */ @@ -261,7 +265,8 @@ enum xceiver_type { SEVENWIRE, /* 7-wire */ MII10, /* MII 10Mbps */ MII100, /* MII 100Mbps */ - RMII /* RMII */ + RMII, /* RMII */ + RGMII, /* RGMII */ };
Acked-by : Stefano Babic sbabic@denx.de
This enable the network function on the i.mx6q armadillo2 board(arm2), thus we can use tftp to load image from network.
Cc: Stefano Babic sbabic@denx.de Signed-off-by: Jason Liu jason.hui@linaro.org Tested-by: Dirk Behme dirk.behme@de.bosch.com --- board/freescale/mx6qarm2/mx6qarm2.c | 90 +++++++++++++++++++++++++++++++++++ include/configs/mx6qarm2.h | 13 ++++- 2 files changed, 101 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index 89e0e76..1df063a 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -29,6 +29,8 @@ #include <asm/gpio.h> #include <mmc.h> #include <fsl_esdhc.h> +#include <miiphy.h> +#include <netdev.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -40,6 +42,10 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
+#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + int dram_init(void) { gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); @@ -79,11 +85,35 @@ iomux_v3_cfg_t usdhc4_pads[] = { MX6Q_PAD_SD4_DAT7__USDHC4_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), };
+iomux_v3_cfg_t enet_pads[] = { + MX6Q_PAD_KEY_COL1__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_KEY_COL2__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + + static void setup_iomux_uart(void) { imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads)); }
+static void setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); +} + #ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC3_BASE_ADDR, 1}, @@ -132,9 +162,69 @@ int board_mmc_init(bd_t *bis) } #endif
+#define MII_MMD_ACCESS_CTRL_REG 0xd +#define MII_MMD_ACCESS_ADDR_DATA_REG 0xe +#define MII_DBG_PORT_REG 0x1d +#define MII_DBG_PORT2_REG 0x1e + +int fecmxc_mii_postcall(int phy) +{ + unsigned short val; + + /* + * Due to the i.MX6Q Armadillo2 board HW design,there is + * no 125Mhz clock input from SOC. In order to use RGMII, + * We need enable AR8031 ouput a 125MHz clk from CLK_25M + */ + miiphy_write("FEC", phy, MII_MMD_ACCESS_CTRL_REG, 0x7); + miiphy_write("FEC", phy, MII_MMD_ACCESS_ADDR_DATA_REG, 0x8016); + miiphy_write("FEC", phy, MII_MMD_ACCESS_CTRL_REG, 0x4007); + miiphy_read("FEC", phy, MII_MMD_ACCESS_ADDR_DATA_REG, &val); + val &= 0xffe3; + val |= 0x18; + miiphy_write("FEC", phy, MII_MMD_ACCESS_ADDR_DATA_REG, val); + + /* For the RGMII phy, we need enable tx clock delay */ + miiphy_write("FEC", phy, 0x1d, 0x5); + miiphy_read("FEC", phy, 0x1e, &val); + val |= 0x0100; + miiphy_write("FEC", phy, 0x1e, val); + + miiphy_write("FEC", phy, MII_BMCR, 0xa100); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + struct eth_device *dev; + int ret; + + ret = cpu_eth_init(bis); + if (ret) { + printf("FEC MXC: %s:failed\n", __func__); + return ret; + } + + dev = eth_get_dev_by_name("FEC"); + if (!dev) { + printf("FEC MXC: Unable to get FEC device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + printf("FEC MXC: Unable to register FEC mii postcall\n"); + return ret; + } + + return 0; +} + int board_early_init_f(void) { setup_iomux_uart(); + setup_iomux_enet();
return 0; } diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index a7b363d..3a30679 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -56,6 +56,17 @@ #define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
+#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1 @@ -66,8 +77,6 @@ #include <config_cmd_default.h>
#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS
#define CONFIG_BOOTDELAY 3
Hi Jason,
only a couple of minor issues.
- unsigned short val;
- miiphy_write("FEC", phy, MII_MMD_ACCESS_CTRL_REG, 0x7);
- miiphy_write("FEC", phy, MII_MMD_ACCESS_ADDR_DATA_REG, 0x8016);
- miiphy_write("FEC", phy, MII_MMD_ACCESS_CTRL_REG, 0x4007);
- miiphy_read("FEC", phy, MII_MMD_ACCESS_ADDR_DATA_REG, &val);
- val &= 0xffe3;
- val |= 0x18;
- miiphy_write("FEC", phy, MII_MMD_ACCESS_ADDR_DATA_REG, val);
- /* For the RGMII phy, we need enable tx clock delay */
- miiphy_write("FEC", phy, 0x1d, 0x5);
You define MII_DBG_PORT_REG, but then you do not use it.
- miiphy_read("FEC", phy, 0x1e, &val);
The same here for MII_DBG_PORT2_REG. Can you also defines some constants for the value you are setting (tx clock delay, etc.).
I have not thought this is needed. I see only one controller.
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Stefano Babic Sent: Friday, December 16, 2011 7:30 PM To: Jason Liu Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 3/3] i.mx6q: arm2: Add the enet function support
Hi Jason,
Thanks for the review.
0x8016);
- val &= 0xffe3;
- val |= 0x18;
Yeah, thanks for it. I will use MII_DBG_PORT_REG and MII_DBG_PORT2_REG.
Yes, I think we can remove it.
Best regards, Jason Liu
==== DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de ================================================================= ==== _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Whole series:
Thanks
Dirk
Dirk Behme
Jason Liu
Liu Hui-R64343
Stefano Babic
