[PATCH] dtoc: Update fdt tests to use test_util
Use the common functions to run tests and report results. Ensure that the result code indicates success or failure.
tools/dtoc/test_fdt.py | 27 ++++++++++----------------- 1 file changed, 10 insertions(+), 17 deletions(-)
diff --git a/tools/dtoc/test_fdt.py b/tools/dtoc/test_fdt.py index 914ed6aed59..3859af8d032 100755 --- a/tools/dtoc/test_fdt.py +++ b/tools/dtoc/test_fdt.py @@ -780,25 +780,17 @@ def RunTests(args): Args: args: List of positional args provided to fdt. This can hold a test name to execute (as in 'fdt -t testFdt', for example) + + Returns: + Return code, 0 on success """ result = unittest.TestResult() - sys.argv = [sys.argv[0]] test_name = args and args[0] or None - for module in (TestFdt, TestNode, TestProp, TestFdtUtil): - if test_name: - try: - suite = unittest.TestLoader().loadTestsFromName(test_name, module) - except AttributeError: - continue - else: - suite = unittest.TestLoader().loadTestsFromTestCase(module) - suite.run(result) - - print(result) - for _, err in result.errors: - print(err) - for _, err in result.failures: - print(err) + test_util.run_test_suites( + result, False, False, False, None, test_name, None, + [TestFdt, TestNode, TestProp, TestFdtUtil]) + + return test_util.report_result('fdt', test_name, result)
if __name__ != '__main__': sys.exit(1) @@ -816,6 +808,7 @@ parser.add_option('-T', '--test-coverage', action='store_true',
# Run our meagre tests if options.test: - RunTests(args) + ret_code = RunTests(args) + sys.exit(ret_code) elif options.test_coverage: RunTestCoverage()
Reviewed-by: Alper Nebi Yasak alpernebiyasak@gmail.com
- Returns:
""" result = unittest.TestResult()Return code, 0 on success
if test_name:
try:
continue
else:
suite.run(result)
- print(result)
print(err)
print(err)
- test_util.run_test_suites(
These would look better in the kwarg=value format.
- return test_util.report_result('fdt', test_name, result)
- RunTests(args)
- ret_code = RunTests(args)
Pylint complains this "constant" isn't uppercased. (I don't particularly care, I just noticed it when running pylint for my test report format series.)
- sys.exit(ret_code)
Applied to u-boot-dm, thanks!
Alper Nebi Yasak
