[U-Boot] [PATCH] PPC4xx: Remove quad100hd board
The quad100hd has been unmaintained and dead ever since it's been added some 6 years ago. Remove it.
Also update README.scrapyard and insert some commit IDs for removed boards.
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Stefan Roese sr@denx.de Cc: Gary Jennejohn gljennjohn@googlemail.com --- board/quad100hd/Makefile | 8 -- board/quad100hd/nand.c | 53 --------- board/quad100hd/quad100hd.c | 73 ------------ boards.cfg | 1 - doc/README.scrapyard | 21 ++-- include/configs/quad100hd.h | 281 -------------------------------------------- 6 files changed, 12 insertions(+), 425 deletions(-) delete mode 100644 board/quad100hd/Makefile delete mode 100644 board/quad100hd/nand.c delete mode 100644 board/quad100hd/quad100hd.c delete mode 100644 include/configs/quad100hd.h
diff --git a/board/quad100hd/Makefile b/board/quad100hd/Makefile deleted file mode 100644 index b65e5ad..0000000 --- a/board/quad100hd/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2007 -# Stefan Roese, DENX Software Engineering, sr@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = quad100hd.o nand.o diff --git a/board/quad100hd/nand.c b/board/quad100hd/nand.c deleted file mode 100644 index 47bbb6b..0000000 --- a/board/quad100hd/nand.c +++ /dev/null @@ -1,53 +0,0 @@ -/* - * (C) Copyright 2008 - * Gary Jennejohn, DENX Software Engineering GmbH, garyj@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <config.h> -#if defined(CONFIG_CMD_NAND) -#include <asm/ppc4xx-gpio.h> -#include <asm/io.h> -#include <nand.h> - -/* - * hardware specific access to control-lines - */ -static void quad100hd_hwcontrol(struct mtd_info *mtd, - int cmd, unsigned int ctrl) -{ - struct nand_chip *this = mtd->priv; - - if (ctrl & NAND_CTRL_CHANGE) { - gpio_write_bit(CONFIG_SYS_NAND_CLE, !!(ctrl & NAND_CLE)); - gpio_write_bit(CONFIG_SYS_NAND_ALE, !!(ctrl & NAND_ALE)); - gpio_write_bit(CONFIG_SYS_NAND_CE, !(ctrl & NAND_NCE)); - } - - if (cmd != NAND_CMD_NONE) - writeb(cmd, this->IO_ADDR_W); -} - -static int quad100hd_nand_ready(struct mtd_info *mtd) -{ - return gpio_read_in_bit(CONFIG_SYS_NAND_RDY); -} - -/* - * Main initialization routine - */ -int board_nand_init(struct nand_chip *nand) -{ - /* Set address of hardware control function */ - nand->cmd_ctrl = quad100hd_hwcontrol; - nand->dev_ready = quad100hd_nand_ready; - nand->ecc.mode = NAND_ECC_SOFT; - /* 15 us command delay time */ - nand->chip_delay = 20; - - /* Return happy */ - return 0; -} -#endif /* CONFIG_CMD_NAND */ diff --git a/board/quad100hd/quad100hd.c b/board/quad100hd/quad100hd.c deleted file mode 100644 index bb14ca7..0000000 --- a/board/quad100hd/quad100hd.c +++ /dev/null @@ -1,73 +0,0 @@ -/* - * (C) Copyright 2008 - * Gary Jennejohn, DENX Software Engineering GmbH, garyj@denx.de. - * - * Based in part on board/icecube/icecube.c from PPCBoot - * (C) Copyright 2003 Intrinsyc Software - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <malloc.h> -#include <environment.h> -#include <logbuff.h> -#include <post.h> - -#include <asm/processor.h> -#include <asm/io.h> -#include <asm/ppc4xx-gpio.h> - -DECLARE_GLOBAL_DATA_PTR; - -int board_early_init_f(void) -{ - /* taken from PPCBoot */ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - mtdcr(UIC0ER, 0x00000000); /* disable all ints */ - mtdcr(UIC0CR, 0x00000000); - mtdcr(UIC0PR, 0xFFFF7FFE); /* set int polarities */ - mtdcr(UIC0TR, 0x00000000); /* set int trigger levels */ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - mtdcr(UIC0VCR, 0x00000001); /* set vect base=0,INT0 highest priority */ - - mtdcr(CPC0_SRR, 0x00040000); /* Hold PCI bridge in reset */ - - return 0; -} - -/* - * Check Board Identity: - */ -int checkboard(void) -{ - char buf[64]; - int i = getenv_f("serial#", buf, sizeof(buf)); -#ifdef DISPLAY_BOARD_INFO - sys_info_t sysinfo; -#endif - - puts("Board: Quad100hd"); - - if (i > 0) { - puts(", serial# "); - puts(buf); - } - putc('\n'); - -#ifdef DISPLAY_BOARD_INFO - /* taken from ppcboot */ - get_sys_info(&sysinfo); - - printf("\tVCO: %lu MHz\n", sysinfo.freqVCOMhz); - printf("\tCPU: %lu MHz\n", sysinfo.freqProcessor / 1000000); - printf("\tPLB: %lu MHz\n", sysinfo.freqPLB / 1000000); - printf("\tOPB: %lu MHz\n", sysinfo.freqOPB / 1000000); - printf("\tEPB: %lu MHz\n", sysinfo.freqPLB / (sysinfo.pllExtBusDiv * - 1000000)); - printf("\tPCI: %lu MHz\n", sysinfo.freqPCI / 1000000); -#endif - - return 0; -} diff --git a/boards.cfg b/boards.cfg index 81e28ba..4297b98 100644 --- a/boards.cfg +++ b/boards.cfg @@ -1096,7 +1096,6 @@ Active powerpc ppc4xx - - - Active powerpc ppc4xx - - - korat - Larry Johnson lrj@acm.org Active powerpc ppc4xx - - - lwmon5 - Stefan Roese sr@denx.de Active powerpc ppc4xx - - - pcs440ep - Stefan Roese sr@denx.de -Active powerpc ppc4xx - - - quad100hd - Gary Jennejohn garyj@denx.de Active powerpc ppc4xx - - - sbc405 - - Active powerpc ppc4xx - - - sc3 - Heiko Schocher hs@denx.de Active powerpc ppc4xx - - - t3corp - Stefan Roese sr@denx.de diff --git a/doc/README.scrapyard b/doc/README.scrapyard index f9742e7..49cb4ca 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -11,15 +11,18 @@ easily if here is something they might want to dig for...
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= -lubbock arm pxa - 2014-04-04 Kyle Harris kharris@nexus-tech.net -MOUSSE powerpc mpc824x - 2014-04-04 -rsdproto powerpc mpc8260 - 2014-04-04 -RPXsuper powerpc mpc8260 - 2014-04-04 -RPXClassic powerpc mpc8xx - 2014-04-04 -RPXlite powerpc mpc8xx - 2014-04-04 -genietv powerpc mpc8xx - 2014-04-04 -mbx8xx powerpc mpc8xx - 2014-04-04 -nx823 powerpc mpc8xx - 2014-04-04 +quad100hd powerpc ppc405ep - - Gary Jennejohn gljennjohn@googlemail.com +lubbock arm pxa 36bf57b 2014-04-18 Kyle Harris kharris@nexus-tech.net +EVB64260 powerpc mpc824x bb3aef9 2014-04-18 +MOUSSE powerpc mpc824x 03f2ecc 2014-04-18 +rsdproto powerpc mpc8260 8b043e6 2014-04-18 +RPXsuper powerpc mpc8260 0ebf5f5 2014-04-18 +RPXClassic powerpc mpc8xx 4fb3925 2014-04-18 +RPXlite powerpc mpc8xx 4fb3925 2014-04-18 +FADS powerpc mpc8xx aa6e1e4 2014-04-18 +genietv powerpc mpc8xx b8a49bd 2014-04-18 +mbx8xx powerpc mpc8xx d6b11fd 2014-04-18 +nx823 powerpc mpc8xx a146e8b 2014-04-18 idmr m68k mcf52x2 ba650e9b 2014-01-28 M5271EVB m68k mcf52x2 ba650e9b 2014-01-28 dvl_host arm ixp e317de6b 2014-01-28 Michael Schwingen michael@schwingen.org diff --git a/include/configs/quad100hd.h b/include/configs/quad100hd.h deleted file mode 100644 index e91e805..0000000 --- a/include/configs/quad100hd.h +++ /dev/null @@ -1,281 +0,0 @@ -/* - * (C) Copyright 2008 - * Gary Jennejohn, DENX Software Engineering GmbH, garyj@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/************************************************************************ - * quad100hd.h - configuration for Quad100hd board - ***********************************************************************/ -#ifndef __CONFIG_H -#define __CONFIG_H - -/*----------------------------------------------------------------------- - * High Level Configuration Options - *----------------------------------------------------------------------*/ -#define CONFIG_QUAD100HD 1 /* Board is Quad100hd */ -#define CONFIG_405EP 1 /* Specifc 405EP support*/ - -#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 - -#define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */ - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */ - -#define PLLMR0_DEFAULT PLLMR0_266_133_66 /* no PCI */ -#define PLLMR1_DEFAULT PLLMR1_266_133_66 /* no PCI */ - -/* the environment is in the EEPROM by default */ -#define CONFIG_ENV_IS_IN_EEPROM -#undef CONFIG_ENV_IS_IN_FLASH - -#define CONFIG_PPC4xx_EMAC -#define CONFIG_HAS_ETH1 1 -#define CONFIG_MII 1 /* MII PHY management */ -#define CONFIG_PHY_ADDR 0x01 /* PHY address */ -#define CONFIG_SYS_RX_ETH_BUFFER 16 /* Number of ethernet rx buffers & descriptors */ -#define CONFIG_PHY_RESET 1 -#define CONFIG_PHY_RESET_DELAY 300 /* PHY RESET recovery delay */ - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_ASKENV -#undef CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP -#undef CONFIG_CMD_DIAG -#define CONFIG_CMD_EEPROM -#undef CONFIG_CMD_ELF -#define CONFIG_CMD_I2C -#undef CONFIG_CMD_IRQ -#define CONFIG_CMD_JFFS2 -#undef CONFIG_CMD_MII -#define CONFIG_CMD_NAND -#undef CONFIG_CMD_PING -#define CONFIG_CMD_REGINFO - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/*----------------------------------------------------------------------- - * SDRAM - *----------------------------------------------------------------------*/ -/* - * SDRAM configuration (please see cpu/ppc/sdram.[ch]) - */ -#define CONFIG_SDRAM_BANK0 1 - -/* FIX! SDRAM timings used in datasheet */ -#define CONFIG_SYS_SDRAM_CL 3 /* CAS latency */ -#define CONFIG_SYS_SDRAM_tRP 20 /* PRECHARGE command period */ -#define CONFIG_SYS_SDRAM_tRC 66 /* ACTIVE-to-ACTIVE command period */ -#define CONFIG_SYS_SDRAM_tRCD 20 /* ACTIVE-to-READ delay */ -#define CONFIG_SYS_SDRAM_tRFC 66 /* Auto refresh period */ - -/* - * JFFS2 - */ -#define CONFIG_SYS_JFFS2_FIRST_BANK 0 -#ifdef CONFIG_SYS_KERNEL_IN_JFFS2 -#define CONFIG_SYS_JFFS2_FIRST_SECTOR 0 /* JFFS starts at block 0 */ -#else /* kernel not in JFFS */ -#define CONFIG_SYS_JFFS2_FIRST_SECTOR 8 /* block 0-7 is kernel (1MB = 8 sectors) */ -#endif -#define CONFIG_SYS_JFFS2_NUM_BANKS 1 - -/*----------------------------------------------------------------------- - * Serial Port - *----------------------------------------------------------------------*/ -#define CONFIG_CONS_INDEX 1 /* Use UART0 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() -#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ -#define CONFIG_SYS_BASE_BAUD 691200 -#define CONFIG_BAUDRATE 115200 - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400} - -/*----------------------------------------------------------------------- - * Miscellaneous configurable options - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_info (bd_t) */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_LOOPW 1 /* enable loopw command */ -#define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ -#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - -/*----------------------------------------------------------------------- - * I2C - *----------------------------------------------------------------------*/ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* base address */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* bytes of address */ - -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* 8 byte write page size */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CONFIG_SYS_EEPROM_SIZE 0x2000 - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFC00000 -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */ -#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_TEXT_BASE) - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ -#define CONFIG_FLASH_CFI_DRIVER - -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ -#define CONFIG_SYS_FLASH_INCREMENT 0 /* there is only one bank */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ -#define CONFIG_SYS_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */ - -#ifdef CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ -/* the environment is located before u-boot */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_TEXT_BASE - CONFIG_ENV_SECT_SIZE) - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SECT_SIZE) -#endif - -#ifdef CONFIG_ENV_IS_IN_EEPROM -#define CONFIG_ENV_SIZE 0x400 /* Size of Environment vars */ -#define CONFIG_ENV_OFFSET 0x00000000 -#define CONFIG_SYS_ENABLE_CRC_16 1 /* Intrinsyc formatting used crc16 */ -#endif - -/* partly from PPCBoot */ -/* NAND */ -#define CONFIG_NAND -#ifdef CONFIG_NAND -#define CONFIG_SYS_NAND_BASE 0x60000000 -#define CONFIG_SYS_NAND_CS 10 /* our CS is GPIO10 */ -#define CONFIG_SYS_NAND_RDY 23 /* our RDY is GPIO23 */ -#define CONFIG_SYS_NAND_CE 24 /* our CE is GPIO24 */ -#define CONFIG_SYS_NAND_CLE 31 /* our CLE is GPIO31 */ -#define CONFIG_SYS_NAND_ALE 30 /* our ALE is GPIO30 */ -#define CONFIG_SYS_MAX_NAND_DEVICE 1 - -#endif - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in data cache) - */ -/* use on chip memory (OCM) for temperary stack until sdram is tested */ -/* see ./arch/powerpc/cpu/ppc4xx/start.S */ -#define CONFIG_SYS_TEMP_STACK_OCM 1 - -/* On Chip Memory location */ -#define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 -#define CONFIG_SYS_OCM_DATA_SIZE 0x1000 -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of OCM */ -#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * External Bus Controller (EBC) Setup - * Taken from PPCBoot board/icecube/icecube.h - */ - -/* see ./arch/powerpc/cpu/ppc4xx/cpu_init.c ./cpu/ppc4xx/ndfc.c */ -#define CONFIG_SYS_EBC_PB0AP 0x04002480 -/* AMD NOR flash - this corresponds to FLASH_BASE so may be correct */ -#define CONFIG_SYS_EBC_PB0CR 0xFFC5A000 -#define CONFIG_SYS_EBC_PB1AP 0x04005480 -#define CONFIG_SYS_EBC_PB1CR 0x60018000 -#define CONFIG_SYS_EBC_PB2AP 0x00000000 -#define CONFIG_SYS_EBC_PB2CR 0x00000000 -#define CONFIG_SYS_EBC_PB3AP 0x00000000 -#define CONFIG_SYS_EBC_PB3CR 0x00000000 -#define CONFIG_SYS_EBC_PB4AP 0x00000000 -#define CONFIG_SYS_EBC_PB4CR 0x00000000 - -/*----------------------------------------------------------------------- - * Definitions for GPIO setup (PPC405EP specific) - * - * Taken in part from PPCBoot board/icecube/icecube.h - */ -/* see ./arch/powerpc/cpu/ppc4xx/cpu_init.c ./cpu/ppc4xx/start.S */ -#define CONFIG_SYS_GPIO0_OSRL 0x55555550 -#define CONFIG_SYS_GPIO0_OSRH 0x00000110 -#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 -#define CONFIG_SYS_GPIO0_ISR1H 0x15555445 -#define CONFIG_SYS_GPIO0_TSRL 0x00000000 -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 -#define CONFIG_SYS_GPIO0_TCR 0xFFFF8097 -#define CONFIG_SYS_GPIO0_ODR 0x00000000 - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#endif - -/* ENVIRONMENT VARS */ - -#define CONFIG_IPADDR 192.168.1.67 -#define CONFIG_SERVERIP 192.168.1.50 -#define CONFIG_GATEWAYIP 192.168.1.1 -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_LOADADDR 300000 -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 - -#endif /* __CONFIG_H */
Dear Tom,
Umm... I have neither seen a pull request nor an ACK from Stefan. Should we not wait for the custodians to pick this up?
On Mon, Jun 02, 2014 at 05:52:56PM +0200, Wolfgang Denk wrote:
Dear Tom,
Given that Masahiro had his series depend on it and it seemed rather unlikey to be rejected by Stefan, I grabbed it keep things rolling.
