[U-Boot] [PATCH] ARM: dts: da850-evm: Re-sync with Kernel 5.0
Resync with Kernel 5.0-rc3
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/da850-evm.dts b/arch/arm/dts/da850-evm.dts index a3c9b34672..f04bc3e153 100644 --- a/arch/arm/dts/da850-evm.dts +++ b/arch/arm/dts/da850-evm.dts @@ -94,6 +94,28 @@ regulator-boot-on; };
+ baseboard_3v3: fixedregulator-3v3 { + /* TPS73701DCQ */ + compatible = "regulator-fixed"; + regulator-name = "baseboard_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vbat>; + regulator-always-on; + regulator-boot-on; + }; + + baseboard_1v8: fixedregulator-1v8 { + /* TPS73701DCQ */ + compatible = "regulator-fixed"; + regulator-name = "baseboard_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vbat>; + regulator-always-on; + regulator-boot-on; + }; + backlight_lcd: backlight-regulator { compatible = "regulator-fixed"; regulator-name = "lcd_backlight_pwr"; @@ -105,7 +127,7 @@
sound { compatible = "simple-audio-card"; - simple-audio-card,name = "DA850/OMAP-L138 EVM"; + simple-audio-card,name = "DA850-OMAPL138 EVM"; simple-audio-card,widgets = "Line", "Line In", "Line", "Line Out"; @@ -210,10 +232,9 @@
/* Regulators */ IOVDD-supply = <&vdcdc2_reg>; - /* Derived from VBAT: Baseboard 3.3V / 1.8V */ - AVDD-supply = <&vbat>; - DRVDD-supply = <&vbat>; - DVDD-supply = <&vbat>; + AVDD-supply = <&baseboard_3v3>; + DRVDD-supply = <&baseboard_3v3>; + DVDD-supply = <&baseboard_1v8>; }; tca6416: gpio@20 { compatible = "ti,tca6416";
Adam Ford
