[U-Boot] [PATCH] omap3_logic: Cleanup and remove redundant defines make bootz easier
From 3af52a1a6d71ac3d78e0dec56da2fd8eb07a91d1 Mon Sep 17 00:00:00 2001
From: Adam Ford aford173@gmail.com Date: Wed, 4 Nov 2015 17:13:15 -0600 Subject: [PATCH] omap3_logic: Cleanup and remove redundant defines make bootz easier
Some unnecesary includes still exist from the initial conversion to ti_omap3_common.h
Add some boot scripts to allow for other boot options and unify some environmental variable names with other omap3 devices.
Signed-off-by: Adam Ford aford173@gmail.com --- include/configs/omap3_logic.h | 125 +++++++++++++++++++----------------------- 1 file changed, 57 insertions(+), 68 deletions(-)
diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index ecd5615..ce06dd3 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -19,7 +19,8 @@ #define CONFIG_SYS_TEXT_BASE 0x80400000
#include <configs/ti_omap3_common.h> -#define CONFIG_OMAP3_LOGIC /* working with Logic OMAP boards */ + + /* * Display CPU and Board information */ @@ -27,29 +28,23 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
-/* Clock Defines */ -#define V_OSCK 26000000 /* Clock output from T2 */ -#define V_SCLK (V_OSCK >> 1) - #define CONFIG_MISC_INIT_R /* misc_init_r dumps the die id */ - #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_REVISION_TAG - #define CONFIG_CMDLINE_EDITING /* cmd line edit/history */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check keypress w/no delay */
-/* - * Size of malloc() pool - */ + #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ /* Sector */ /* * Hardware drivers */
+#define CONFIG_USB_OMAP3 + /* * select serial console configuration */ @@ -58,58 +53,46 @@ #define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 #define CONFIG_SERIAL1 1 /* UART1 on OMAP Logic boards */
-/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ - 115200} -#define CONFIG_GENERIC_MMC -#define CONFIG_MMC -#define CONFIG_OMAP_HSMMC -#define CONFIG_DOS_PARTITION
/* commands to include */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_MTDPARTS #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ -#define MTDIDS_DEFAULT "nand0=omap2-nand.0" -#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:512k(x-loader),"\ - "1920k(u-boot),128k(u-boot-env),"\ - "4m(kernel),-(fs)" - -#define CONFIG_CMD_I2C /* I2C serial bus support */ -#define CONFIG_CMD_MMC /* MMC support */ -#define CONFIG_CMD_NAND /* NAND support */ +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:512k(x-loader),"\ + "1920k(u-boot),128k(u-boot-env),"\ + "4m(kernel),-(fs)" + #define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */ #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP
-#define CONFIG_SYS_NO_FLASH +#define CONFIG_YAFFS2
/* * I2C */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_OMAP24_I2C_SPEED 100000 -#define CONFIG_SYS_OMAP24_I2C_SLAVE 1 #define CONFIG_SYS_I2C_OMAP34XX +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM AT24C64 */ +#define EXPANSION_EEPROM_I2C_BUS 2 /* I2C Bus for AT24C64 */ +#define CONFIG_OMAP3_LOGIC_USE_NEW_PRODUCT_ID
/* * TWL4030 */ - +#define CONFIG_TWL4030_PWM
/* * Board NAND Info. */ +#define CONFIG_CMD_NAND #define CONFIG_SYS_NAND_BASE NAND_BASE #define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */
- #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ #define CONFIG_SYS_NAND_BUSWIDTH_16BIT @@ -144,10 +127,13 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x81000000\0" \ - "bootfile=uImage\0" \ + "uimage=uImage\0" \ + "zimage=zImage\0" \ "mtdids=" MTDIDS_DEFAULT "\0" \ "mtdparts=" MTDPARTS_DEFAULT "\0" \ "mmcdev=0\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext3 rootwait\0" \ "autoboot=mmc dev ${mmcdev}; if mmc rescan; then " \ "if run loadbootscript; then " \ "run bootscript; " \ @@ -165,34 +151,60 @@ "setenv bootargs ${bootargs} omapfb.vrfb=y " \ "omapfb.rotate=${rotation}; " \ "fi\0" \ - "otherbootargs=ignore_loglevel early_printk no_console_suspend\0" \ + "optargs=ignore_loglevel early_printk no_console_suspend\0" \ "addmtdparts=setenv bootargs ${bootargs} ${mtdparts}\0" \ "common_bootargs=setenv bootargs ${bootargs} display=${display} " \ - "${otherbootargs};" \ + "${optargss};" \ "run addmtdparts; " \ "run vrfb_arg\0" \ "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ "bootscript=echo 'Running bootscript from mmc ...'; " \ "source ${loadaddr}\0" \ - "loaduimage=mmc rescan ${mmcdev}; " \ - "fatload mmc ${mmcdev} ${loadaddr} ${bootfile}\0" \ + "loaduimage=mmc rescan; " \ + "fatload mmc ${mmcdev} ${loadaddr} ${uimage}\0" \ + "loadzimage=mmc rescan; " \ + "fatload mmc ${mmcdev} ${loadaddr} ${zimage}\0" \ "ramdisksize=64000\0" \ "ramdiskaddr=0x82000000\0" \ "ramdiskimage=rootfs.ext2.gz.uboot\0" \ + "loadramdisk=mmc rescan; " \ + "fatload mmc ${mmcdev} ${ramdiskaddr} ${ramdiskimage}\0" \ "ramargs=run setconsole; setenv bootargs console=${console} " \ "root=/dev/ram rw ramdisk_size=${ramdisksize}\0" \ - "mmcramboot=echo 'Booting kernel from mmc w/ramdisk...'; " \ + "mmcargs=run setconsole; setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "fdtaddr=0x86000000\0" \ + "loadfdtimage=mmc rescan; " \ + "fatload mmc ${mmcdev} ${fdtaddr} ${fdtimage}\0" \ + "mmcbootz=echo Booting with DT from mmc${mmcdev} ...; " \ + "run mmcargs; " \ + "run common_bootargs; " \ + "run dump_bootargs; " \ + "run loadzimage; " \ + "run loadfdtimage; "\ + "bootz ${loadaddr} - ${fdtaddr}\0" \ + "mmcramboot=echo 'Booting uImage kernel from mmc w/ramdisk...'; " \ "run ramargs; " \ "run common_bootargs; " \ "run dump_bootargs; " \ "run loaduimage; " \ - "fatload mmc ${mmcdev} ${ramdiskaddr} ${ramdiskimage}; "\ + "run loadramdisk; "\ "bootm ${loadaddr} ${ramdiskaddr}\0" \ - "ramboot=echo 'Booting kernel/ramdisk rootfs from tftp...'; " \ + "mmcrambootz=echo 'Booting zImage kernel from mmc w/ramdisk...'; " \ + "run ramargs; " \ + "run common_bootargs; " \ + "run dump_bootargs; " \ + "run loadzimage; " \ + "run loadramdisk; "\ + "run loadfdtimage; "\ + "bootz ${loadaddr} ${ramdiskaddr} ${fdtaddr}\0; " \ + "tftpboot=echo 'Booting kernel/ramdisk rootfs from tftp...'; " \ "run ramargs; " \ "run common_bootargs; " \ "run dump_bootargs; " \ - "tftpboot ${loadaddr} ${bootfile}; "\ + "tftpboot ${loadaddr} ${uimage}; "\ "tftpboot ${ramdiskaddr} ${ramdiskimage}; "\ "bootm ${loadaddr} ${ramdiskaddr}\0"
@@ -203,13 +215,6 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) -
/* memtest works on */ #define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) @@ -217,26 +222,10 @@ 0x01F00000) /* 31MB */
/* - * OMAP3 has 12 GP timers, they can be driven by the system clock - * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). - * This rate is divided by a local divisor. - */ -#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ - -/* - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ -#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 -#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 - -/* * FLASH and environment organization */
/* **** PISMO SUPPORT *** */ -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
#if defined(CONFIG_CMD_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE
This looks fine so:
But the whitespace got ruined, please resubmit as v2, thanks!
Adam Ford
