[PATCH 1/2] rockchip: rk3188: Fix the code support for SPL_LED
Fix the build error for the wrong code when CONFIG_SPL_LED is enabled.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/rk3188/rk3188.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c index 1b2f4a4757..222953ab94 100644 --- a/arch/arm/mach-rockchip/rk3188/rk3188.c +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -6,6 +6,7 @@ #include <dm.h> #include <hang.h> #include <init.h> +#include <led.h> #include <log.h> #include <syscon.h> #include <asm/io.h> @@ -105,6 +106,7 @@ int rk_board_late_init(void) }
#ifdef CONFIG_SPL_BUILD +DECLARE_GLOBAL_DATA_PTR; static int setup_led(void) { #ifdef CONFIG_SPL_LED @@ -120,7 +122,7 @@ static int setup_led(void) debug("%s: get=%d\n", __func__, ret); return ret; } - ret = led_set_on(dev, 1); + ret = led_set_state(dev, LEDST_ON); if (ret) return ret; #endif
board/firefly/firefly-rk3288/firefly-rk3288.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/firefly/firefly-rk3288/firefly-rk3288.c b/board/firefly/firefly-rk3288/firefly-rk3288.c index 1965985a0f..bd8a32cf7b 100644 --- a/board/firefly/firefly-rk3288/firefly-rk3288.c +++ b/board/firefly/firefly-rk3288/firefly-rk3288.c @@ -5,9 +5,11 @@
#include <common.h> #include <hang.h> +#include <led.h> #include <log.h>
#ifdef CONFIG_SPL_BUILD +DECLARE_GLOBAL_DATA_PTR; static int setup_led(void) { #ifdef CONFIG_SPL_LED @@ -23,7 +25,7 @@ static int setup_led(void) debug("%s: get=%d\n", __func__, ret); return ret; } - ret = led_set_on(dev, 1); + ret = led_set_state(dev, LEDST_ON); if (ret) return ret; #endif
Kever Yang
