[U-Boot-Users] [PATCH] (Resubmit) ADD ARM AMBA PL031 RTC Support
This patch adds support to arm amba pl031 rtc chip.
User needs to define 3 variables in board config to make use of this driver & needs to call rtc_init in order to start rtc.
#define CONFIG_RTC_PL031 1 /* use ARM AMBA PL031 RTC */ #define CFG_RTC_PL031_BASE 0x101e8000 /* RTC Registers Base Address */
and
#define CONFIG_CMD_DATE
Call rtc_init from <board>.c to start the rtc as below
#if defined(CONFIG_RTC_PL031) && defined(CONFIG_CMD_DATE) rtc_init(); #endif
Comments are welcome.
Also,
I used below command to generate the diff. It says that 31 files have changed in this directory whereas only 1 files is changed and 1 file is added. Kindly help me to correct the same. Right now i have manually changed it in the patch file.
$ git-diff -p --summary --stat u-boot-1.3.3/drivers/rtc/ uboot/drivers/rtc/
Regards Gururaja
Signed off by: Gururaja Hebbar gururajakr@sanyo.co.in
- Add support to the ARM AMBA PL031 RTC Chip. - remove the call to rtc_init from lib_arm/board.c boot sequence as per wd advice. - check for pl031 rtc initialization. Initialize if it hasnt yet.
{u-boot-1.3.3 => uboot}/drivers/rtc/Makefile | 1 + /dev/null => uboot/drivers/rtc/rtc_pl031.c | 121 +++++++++++++++++++++ 2 files changed, 122 insertions(+), 0 deletions(-) create mode 100644 uboot/drivers/rtc/rtc_pl031.c
diff --git a/u-boot-1.3.3/drivers/rtc/Makefile b/uboot/drivers/rtc/Makefile index 2e0c118..f888a31 100644 --- a/u-boot-1.3.3/drivers/rtc/Makefile +++ b/uboot/drivers/rtc/Makefile @@ -56,6 +56,7 @@ COBJS-y += rs5c372.o COBJS-y += rx8025.o COBJS-y += s3c24x0_rtc.o COBJS-y += x1205.o +COBJS-y += rtc_pl031.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/dev/null b/uboot/drivers/rtc/rtc_pl031.c new file mode 100644 index 0000000..77b550b --- /dev/null +++ b/uboot/drivers/rtc/rtc_pl031.c @@ -0,0 +1,121 @@ +/* + * (C) Copyright 2008 + * Gururaja Hebbar Sanyo LSI (www.sanyo.co.in) gururajakr@sanyo.co.in + * + * reference linux-2.6.20.6/drivers/rtc/rtc-pl031.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <rtc.h> + +#if defined(CONFIG_RTC_PL031) && defined(CONFIG_CMD_DATE) + +#ifndef CFG_RTC_PL031_BASE +#error CFG_RTC_PL031_BASE is not defined! +#endif + +/* + * Register definitions + */ +#define RTC_DR 0x00 /* Data read register */ +#define RTC_MR 0x04 /* Match register */ +#define RTC_LR 0x08 /* Data load register */ +#define RTC_CR 0x0c /* Control register */ +#define RTC_IMSC 0x10 /* Interrupt mask and set register */ +#define RTC_RIS 0x14 /* Raw interrupt status register */ +#define RTC_MIS 0x18 /* Masked interrupt status register */ +#define RTC_ICR 0x1c /* Interrupt clear register */ + +#define RTC_CR_MIE (1 << 0) + +#define RTC_WRITE_REG(addr, val) (*(volatile unsigned int *)(CFG_RTC_PL031_BASE + (addr)) = (val)) +#define RTC_READ_REG(addr) (*(volatile unsigned int *)(CFG_RTC_PL031_BASE + (addr))) + +static int pl031_initted = 0; + +/* Enable RTC Start in Control register*/ +void rtc_init(void) +{ + RTC_WRITE_REG(RTC_CR,RTC_CR_MIE); + + pl031_initted = 1; +} + +/* + * Reset the RTC. We set the date back to 1970-01-01. + */ +void rtc_reset(void) +{ + RTC_WRITE_REG(RTC_LR,0x00); + if(!pl031_initted) + rtc_init(); +} + +/* + * Set the RTC +*/ +void rtc_set(struct rtc_time *tmp) +{ + unsigned long tim; + + if(!pl031_initted) + rtc_init(); + + if (tmp == NULL) { + puts("Error setting the date/time\n"); + return; + } + + /* Calculate number of seconds this incoming time represents */ + tim = mktime(tmp->tm_year, tmp->tm_mon, tmp->tm_mday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + RTC_WRITE_REG(RTC_LR,tim); +} + +/* + * Get the current time from the RTC + */ +int rtc_get(struct rtc_time *tmp) +{ + ulong tim; + + if(!pl031_initted) + rtc_init(); + + if (tmp == NULL) { + puts("Error getting the date/time\n"); + return -1; + } + + tim = RTC_READ_REG(RTC_DR); + + to_tm (tim, tmp); + + debug ( "Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + return 0; +} + +#endif
First your patch is line wrapped by your mailler. Secondly please be care ful of the 80 chars limits and the whitespace.
Are you going to add a board which will use it?
Best Regards, J.
From: Jean-Christophe PLAGNIOL-VILLARD Subject: Re: [U-Boot-Users] [PATCH] (Resubmit) ADD ARM AMBA PL031
RTCSupport
Hello
That's why i had also attached the respective patch file. that i generated using git-diff command.
Regarding the white space, i am little confused abt this as i couldn't find it in my patch. can u please let me know where it exists.
Right now i am using it on arm Versatile board. Should i send a patch to that also
Regards Gururaja
Hi j,
Could you please reply so that i can submit a reformatted patch if required.
Also,
Regards Gururaja
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/dev/null b/uboot/drivers/rtc/rtc_pl031.c new file mode 100644 index 0000000..77b550b --- /dev/null +++ b/uboot/drivers/rtc/rtc_pl031.c @@ -0,0 +1,121 @@ +/* + * (C) Copyright 2008 + * Gururaja Hebbar gururajakr@sanyo.co.in + * + * reference linux-2.6.20.6/drivers/rtc/rtc-pl031.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <rtc.h> + +#if defined(CONFIG_RTC_PL031) && defined(CONFIG_CMD_DATE) + +#ifndef CFG_RTC_PL031_BASE +#error CFG_RTC_PL031_BASE is not defined! +#endif + +/* + * Register definitions + */ +#define RTC_DR 0x00 /* Data read register */ +#define RTC_MR 0x04 /* Match register */ +#define RTC_LR 0x08 /* Data load register */ +#define RTC_CR 0x0c /* Control register */ +#define RTC_IMSC 0x10 /* Interrupt mask and set register */ +#define RTC_RIS 0x14 /* Raw interrupt status register */ +#define RTC_MIS 0x18 /* Masked interrupt status register */ +#define RTC_ICR 0x1c /* Interrupt clear register */ + +#define RTC_CR_MIE (1 << 0) + +#define RTC_WRITE_REG(addr, val) (*(volatile unsigned int *)(CFG_RTC_PL031_BASE + (addr)) = (val)) +#define RTC_READ_REG(addr) (*(volatile unsigned int *)(CFG_RTC_PL031_BASE + (addr))) + +static int pl031_initted = 0; + +/* Enable RTC Start in Control register*/ +void rtc_init(void) +{ + RTC_WRITE_REG(RTC_CR,RTC_CR_MIE); + + pl031_initted = 1; +} + +/* + * Reset the RTC. We set the date back to 1970-01-01. + */ +void rtc_reset(void) +{ + RTC_WRITE_REG(RTC_LR,0x00); + if(!pl031_initted) + rtc_init(); +} + +/* + * Set the RTC +*/ +void rtc_set(struct rtc_time *tmp) +{ + unsigned long tim; + + if(!pl031_initted) + rtc_init(); + + if (tmp == NULL) { + puts("Error setting the date/time\n"); + return; + } + + /* Calculate number of seconds this incoming time represents */ + tim = mktime(tmp->tm_year, tmp->tm_mon, tmp->tm_mday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + RTC_WRITE_REG(RTC_LR,tim); +} + +/* + * Get the current time from the RTC + */ +int rtc_get(struct rtc_time *tmp) +{ + ulong tim; + + if(!pl031_initted) + rtc_init(); + + if (tmp == NULL) { + puts("Error getting the date/time\n"); + return -1; + } + + tim = RTC_READ_REG(RTC_DR); + + to_tm (tim, tmp); + + debug ( "Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + return 0; +} + +#endif
- RTC_WRITE_REG(RTC_CR,RTC_CR_MIE);
please replace by RTC_WRITE_REG(RTC_CR, RTC_CR_MIE);
^^^^^ please remove this whitescpace
- pl031_initted = 1;
- Reset the RTC. We set the date back to 1970-01-01.
- RTC_WRITE_REG(RTC_LR,0x00);
please replace by RTC_WRITE_REG(RTC_LR, 0x00);
- if(!pl031_initted)
rtc_init();
- Set the RTC
- unsigned long tim;
rtc_init();
- if (tmp == NULL) {
return;
- /* Calculate number of seconds this incoming time represents */
- tim = mktime(tmp->tm_year, tmp->tm_mon, tmp->tm_mday,
- RTC_WRITE_REG(RTC_LR,tim);
- Get the current time from the RTC
- ulong tim;
rtc_init();
return -1;
- tim = RTC_READ_REG(RTC_DR);
- to_tm (tim, tmp);
- debug ( "Get DATE: %4d-%02d-%02d (wday=%d) TIME:
%2d:%02d:%02d\n",
Gururaja Hebbar K R
