[U-Boot] [PATCH] board: dra71: Fix selection of OPPs
As per the DM[1] Dated June 2016–Revised February 2017, Table 5-3, DRA71 supports the following OPPs for various voltage domains:
VDD_MPU: OPP_NOM VDD_CORE: OPP_NOM VDD_GPU: OPP_NOM VDD_DSPEVE: OPP_NOM, OPP_HIGH VDD_IVA: OPP_NOM, OPP_HIGH
This patch add support for selection of the above OPPs instead of using OPP_NOM for all voltage domains.
[1] http://www.ti.com/lit/ds/symlink/dra718.pdf
Reported-by: Vishal Mahaveer vishalm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/dra7xx/evm.c | 29 +++++++++++++++++++++++------ 1 file changed, 23 insertions(+), 6 deletions(-)
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index ae2d59da43..0984475d3b 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -456,27 +456,44 @@ int get_voltrail_opp(int rail_offset) { int opp;
- /* - * DRA71x supports only OPP_NOM. - */ - if (board_is_dra71x_evm()) - return OPP_NOM; - switch (rail_offset) { case VOLT_MPU: opp = DRA7_MPU_OPP; + /* DRA71x supports only OPP_NOM for MPU */ + if (board_is_dra71x_evm()) + opp = OPP_NOM; break; case VOLT_CORE: opp = DRA7_CORE_OPP; + /* DRA71x supports only OPP_NOM for CORE */ + if (board_is_dra71x_evm()) + opp = OPP_NOM; break; case VOLT_GPU: opp = DRA7_GPU_OPP; + /* DRA71x supports only OPP_NOM for GPU */ + if (board_is_dra71x_evm()) + opp = OPP_NOM; break; case VOLT_EVE: opp = DRA7_DSPEVE_OPP; + /* + * DRA71x does not support OPP_OD for EVE. + * If OPP_OD is selected by menuconfig, fallback + * to OPP_NOM. + */ + if (board_is_dra71x_evm() && opp == OPP_OD) + opp = OPP_NOM; break; case VOLT_IVA: opp = DRA7_IVA_OPP; + /* + * DRA71x does not support OPP_OD for IVA. + * If OPP_OD is selected by menuconfig, fallback + * to OPP_NOM. + */ + if (board_is_dra71x_evm() && opp == OPP_OD) + opp = OPP_NOM; break; default: opp = OPP_NOM;
Reported-by: Vishal Mahaveer vishalm@ti.com Signed-off-by: Suman Anna s-anna@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - Updated efuse reg bits for OPP_HIGH as pointed out by Suman.
board/ti/dra7xx/evm.c | 33 +++++++++++++++++++++++++++------ 1 file changed, 27 insertions(+), 6 deletions(-)
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index ae2d59da43..ed0bc181cf 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -438,14 +438,18 @@ struct vcores_data dra718_volts = { * and are powered by BUCK1 of LP873X PMIC */ .eve.value[OPP_NOM] = VDD_EVE_DRA7_NOM, + .eve.value[OPP_HIGH] = VDD_EVE_DRA7_HIGH, .eve.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_DSPEVE_NOM, + .eve.efuse.reg[OPP_HIGH] = STD_FUSE_OPP_VMIN_DSPEVE_HIGH, .eve.efuse.reg_bits = DRA752_EFUSE_REGBITS, .eve.addr = LP873X_REG_ADDR_BUCK1, .eve.pmic = &lp8733, .eve.abb_tx_done_mask = OMAP_ABB_EVE_TXDONE_MASK,
.iva.value[OPP_NOM] = VDD_IVA_DRA7_NOM, + .iva.value[OPP_HIGH] = VDD_IVA_DRA7_HIGH, .iva.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_IVA_NOM, + .iva.efuse.reg[OPP_HIGH] = STD_FUSE_OPP_VMIN_IVA_HIGH, .iva.efuse.reg_bits = DRA752_EFUSE_REGBITS, .iva.addr = LP873X_REG_ADDR_BUCK1, .iva.pmic = &lp8733, @@ -456,27 +460,44 @@ int get_voltrail_opp(int rail_offset) { int opp;
Just posted v2 of this patch as fixing efuse reg bits for OPP_HIGH as pointed out by Suman.
Thanks and regards, Lokesh
return OPP_NOM;
break; case VOLT_CORE: opp = DRA7_CORE_OPP;opp = OPP_NOM;
break; case VOLT_GPU: opp = DRA7_GPU_OPP;opp = OPP_NOM;
break; case VOLT_EVE: opp = DRA7_DSPEVE_OPP;opp = OPP_NOM;
* to OPP_NOM.
break; case VOLT_IVA: opp = DRA7_IVA_OPP;opp = OPP_NOM;
* to OPP_NOM.
break; default: opp = OPP_NOM;opp = OPP_NOM;
Lokesh Vutla
