[U-Boot] [PATCH] ARM: rmobile: Fix SD divider settings on Gen3
On RCar M3 and on RCar H3 newer than and not including ES1.0, the SD clock must be divided by 4 rather than 2 because a hardware workaround present only in the H3 ES1.0 has been removed from these chips. U-Boot currently only supports M3 and H3 ES 2.0 and newer, so configure the SD pre-divider to 4 to prevent SD instability.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/salvator-x/salvator-x.c | 8 ++++---- board/renesas/ulcb/ulcb.c | 8 ++++---- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/board/renesas/salvator-x/salvator-x.c b/board/renesas/salvator-x/salvator-x.c index 2695de5dbf..e260117802 100644 --- a/board/renesas/salvator-x/salvator-x.c +++ b/board/renesas/salvator-x/salvator-x.c @@ -74,10 +74,10 @@ int board_early_init_f(void) /* SDHI0, 3 */ mstp_clrbits_le32(MSTPSR3, SMSTPCR3, SD0_MSTP314 | SD3_MSTP311);
- writel(0, SD0CKCR); - writel(0, SD1CKCR); - writel(0, SD2CKCR); - writel(0, SD3CKCR); + writel(1, SD0CKCR); + writel(1, SD1CKCR); + writel(1, SD2CKCR); + writel(1, SD3CKCR);
#if defined(CONFIG_SYS_I2C) && defined(CONFIG_SYS_I2C_SH) /* DVFS for reset */ diff --git a/board/renesas/ulcb/ulcb.c b/board/renesas/ulcb/ulcb.c index 2b6cc612c8..dc23228f4f 100644 --- a/board/renesas/ulcb/ulcb.c +++ b/board/renesas/ulcb/ulcb.c @@ -72,10 +72,10 @@ int board_early_init_f(void) /* SDHI0 */ mstp_clrbits_le32(MSTPSR3, SMSTPCR3, SD0_MSTP314);
