[U-Boot] [PATCH v11] mmc: atmel_sdhci: Convert to the driver model support
Convert the driver to the driver model while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Heiko Schocher hs@denx.de ---
Changes in v11: - Due the removal of unnecessary arguments for sdhci_setup_cfg(), change accordingly.
Changes in v10: - Add Reviewed-by tag.
Changes in v9: - Add Reviewed-by tag.
Changes in v8: - Make atmel_sdhci_get_clk() to get clock device. - Use ulong type for gck_rate. - Remove meaningless type casting before dev->name.
Changes in v7: - Add support for using driver model for block devices and MMC operations. - Change clk_client.h -> clk.h to adapt to clk API conversion.
Changes in v6: - Remove unnecessary white space. - Use sdhci_read(), instead of readl(). - Remove the local variables min_clk.
Changes in v5: - Add Reviewed-by tag.
Changes in v4: - Update the clk API based on [PATCH] clk: convert API to match reset/mailbox fstyle (http://patchwork.ozlabs.org/patch/625342/). - Remove check on dev_get_parent() return. - Fixed the return value, such as -ENODEV->-EINVAL.
Changes in v3: - Remove the redundant log print.
Changes in v2: - Add clock support, include enabling peripheral clock and generated clock. - Retain the existing legacy code to support boards which have not converted to driver model.
drivers/mmc/Kconfig | 10 ++++ drivers/mmc/atmel_sdhci.c | 123 ++++++++++++++++++++++++++++++++++++++++++++++ include/sdhci.h | 2 + 3 files changed, 135 insertions(+)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index dc8f2b6..3616dee 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -34,6 +34,16 @@ config MSM_SDHCI SD 3.0 specifications. Both SD and eMMC devices are supported. Card-detect gpios are not supported.
+config ATMEL_SDHCI + bool "Atmel SDHCI controller support" + depends on DM_MMC && BLK && DM_MMC_OPS && ARCH_AT91 + help + This enables support for the Atmel SDHCI controller, which supports + the embedded MultiMedia Card (e.MMC) Specification V4.51, the SD + Memory Card Specification V3.0, and the SDIO V3.0 specification. + It is compliant with the SD Host Controller Standard V3.0 + specification. + config ROCKCHIP_DWMMC bool "Rockchip SD/MMC controller support" depends on DM_MMC && OF_CONTROL diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index 24b68b6..dd6bd33 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -6,12 +6,15 @@ */
#include <common.h> +#include <clk.h> +#include <dm.h> #include <malloc.h> #include <sdhci.h> #include <asm/arch/clk.h>
#define ATMEL_SDHC_MIN_FREQ 400000
+#ifndef CONFIG_DM_MMC int atmel_sdhci_init(void *regbase, u32 id) { struct sdhci_host *host; @@ -38,3 +41,123 @@ int atmel_sdhci_init(void *regbase, u32 id)
return 0; } + +#else + +DECLARE_GLOBAL_DATA_PTR; + +struct atmel_sdhci_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + +static int atmel_sdhci_get_clk(struct udevice *dev, int index, struct clk *clk) +{ + struct udevice *dev_clk; + int periph, ret; + + ret = clk_get_by_index(dev, index, clk); + if (ret) + return ret; + + periph = fdtdec_get_uint(gd->fdt_blob, clk->dev->of_offset, "reg", -1); + if (periph < 0) + return -EINVAL; + + dev_clk = dev_get_parent(clk->dev); + ret = clk_request(dev_clk, clk); + if (ret) + return ret; + + clk->id = periph; + + return 0; +} + +static int atmel_sdhci_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct atmel_sdhci_plat *plat = dev_get_platdata(dev); + struct sdhci_host *host = dev_get_priv(dev); + u32 max_clk; + u32 caps, caps_1; + u32 clk_base, clk_mul; + ulong gck_rate; + struct clk clk; + int ret; + + ret = atmel_sdhci_get_clk(dev, 0, &clk); + if (ret) + return ret; + + ret = clk_enable(&clk); + if (ret) + return ret; + + host->name = dev->name; + host->ioaddr = (void *)dev_get_addr(dev); + + host->quirks = 0; + host->bus_width = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "bus-width", 4); + + caps = sdhci_readl(host, SDHCI_CAPABILITIES); + clk_base = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; + caps_1 = sdhci_readl(host, SDHCI_CAPABILITIES_1); + clk_mul = (caps_1 & SDHCI_CLOCK_MUL_MASK) >> SDHCI_CLOCK_MUL_SHIFT; + gck_rate = clk_base * 1000000 * (clk_mul + 1); + + ret = atmel_sdhci_get_clk(dev, 1, &clk); + if (ret) + return ret; + + ret = clk_set_rate(&clk, gck_rate); + if (ret) + return ret; + + max_clk = clk_get_rate(&clk); + if (!max_clk) + return -EINVAL; + + ret = sdhci_setup_cfg(&plat->cfg, host, max_clk, ATMEL_SDHC_MIN_FREQ); + if (ret) + return ret; + + host->mmc = &plat->mmc; + host->mmc->dev = dev; + host->mmc->priv = host; + upriv->mmc = host->mmc; + + clk_free(&clk); + + return sdhci_probe(dev); +} + +static int atmel_sdhci_bind(struct udevice *dev) +{ + struct atmel_sdhci_plat *plat = dev_get_platdata(dev); + int ret; + + ret = sdhci_bind(dev, &plat->mmc, &plat->cfg); + if (ret) + return ret; + + return 0; +} + +static const struct udevice_id atmel_sdhci_ids[] = { + { .compatible = "atmel,sama5d2-sdhci" }, + { } +}; + +U_BOOT_DRIVER(atmel_sdhci_drv) = { + .name = "atmel_sdhci", + .id = UCLASS_MMC, + .of_match = atmel_sdhci_ids, + .ops = &sdhci_ops, + .bind = atmel_sdhci_bind, + .probe = atmel_sdhci_probe, + .priv_auto_alloc_size = sizeof(struct sdhci_host), + .platdata_auto_alloc_size = sizeof(struct atmel_sdhci_plat), +}; +#endif diff --git a/include/sdhci.h b/include/sdhci.h index fcef4dc..6844c73 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -166,6 +166,8 @@ #define SDHCI_CAN_64BIT 0x10000000
#define SDHCI_CAPABILITIES_1 0x44 +#define SDHCI_CLOCK_MUL_MASK 0x00FF0000 +#define SDHCI_CLOCK_MUL_SHIFT 16
#define SDHCI_MAX_CURRENT 0x48
If others are ok, I will pick this patch to u-boot-mmc.
Best Regards, Jaehoon Chung
Changes in v11:
Changes in v10:
Changes in v9:
Changes in v8:
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+config ATMEL_SDHCI
- bool "Atmel SDHCI controller support"
- depends on DM_MMC && BLK && DM_MMC_OPS && ARCH_AT91
- help
specification.
return 0; }
+#else
- struct mmc_config cfg;
- struct mmc mmc;
- struct udevice *dev_clk;
- int periph, ret;
- ret = clk_get_by_index(dev, index, clk);
- if (ret)
return ret;
- periph = fdtdec_get_uint(gd->fdt_blob, clk->dev->of_offset, "reg", -1);
- if (periph < 0)
return -EINVAL;
- dev_clk = dev_get_parent(clk->dev);
- ret = clk_request(dev_clk, clk);
- if (ret)
return ret;
- clk->id = periph;
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct atmel_sdhci_plat *plat = dev_get_platdata(dev);
- struct sdhci_host *host = dev_get_priv(dev);
- u32 max_clk;
- u32 caps, caps_1;
- u32 clk_base, clk_mul;
- ulong gck_rate;
- struct clk clk;
- int ret;
- ret = atmel_sdhci_get_clk(dev, 0, &clk);
- if (ret)
return ret;
- ret = clk_enable(&clk);
- if (ret)
return ret;
- host->name = dev->name;
- host->ioaddr = (void *)dev_get_addr(dev);
- host->quirks = 0;
- host->bus_width = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
"bus-width", 4);
- caps = sdhci_readl(host, SDHCI_CAPABILITIES);
- clk_base = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT;
- caps_1 = sdhci_readl(host, SDHCI_CAPABILITIES_1);
- clk_mul = (caps_1 & SDHCI_CLOCK_MUL_MASK) >> SDHCI_CLOCK_MUL_SHIFT;
- gck_rate = clk_base * 1000000 * (clk_mul + 1);
- ret = atmel_sdhci_get_clk(dev, 1, &clk);
- if (ret)
return ret;
- ret = clk_set_rate(&clk, gck_rate);
- if (ret)
return ret;
- max_clk = clk_get_rate(&clk);
- if (!max_clk)
return -EINVAL;
- ret = sdhci_setup_cfg(&plat->cfg, host, max_clk, ATMEL_SDHC_MIN_FREQ);
- if (ret)
return ret;
- host->mmc = &plat->mmc;
- host->mmc->dev = dev;
- host->mmc->priv = host;
- upriv->mmc = host->mmc;
- clk_free(&clk);
- return sdhci_probe(dev);
- int ret;
- ret = sdhci_bind(dev, &plat->mmc, &plat->cfg);
- if (ret)
return ret;
- { .compatible = "atmel,sama5d2-sdhci" },
- .name = "atmel_sdhci",
- .id = UCLASS_MMC,
- .of_match = atmel_sdhci_ids,
- .ops = &sdhci_ops,
- .bind = atmel_sdhci_bind,
- .probe = atmel_sdhci_probe,
- .priv_auto_alloc_size = sizeof(struct sdhci_host),
- .platdata_auto_alloc_size = sizeof(struct atmel_sdhci_plat),
Hi Wenyou,
Applied on u-boot-mmc. Thanks!
Changes in v11:
Changes in v10:
Changes in v9:
Changes in v8:
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+config ATMEL_SDHCI
- help
specification.
return 0; }
+#else
- struct mmc mmc;
- int periph, ret;
- if (ret)
return ret;
- if (periph < 0)
return -EINVAL;
- if (ret)
return ret;
- clk->id = periph;
- u32 max_clk;
- u32 caps, caps_1;
- ulong gck_rate;
- struct clk clk;
- int ret;
- if (ret)
return ret;
- if (ret)
return ret;
- host->quirks = 0;
"bus-width", 4);
- if (ret)
return ret;
- if (ret)
return ret;
- if (!max_clk)
return -EINVAL;
- if (ret)
return ret;
- clk_free(&clk);
- int ret;
- if (ret)
return ret;
- .id = UCLASS_MMC,
Dear Wenyou Yang,
Wenyou Yang wenyou.yang@atmel.com writes:
Changes in v11:
Changes in v10:
Changes in v9:
Changes in v8:
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Jaehoon Chung
Wenyou Yang
