[U-Boot] [PATCH] armv8: mmu: fix page table mapping
To page mapping the lowest 2 bits needs to be 0x3. If not fix this, the final lowest 3 bits for page mapping is 0x1 which is marked as reserved.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/cpu/armv8/cache_v8.c | 5 ++++- arch/arm/include/asm/armv8/mmu.h | 1 + 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index adc7e1746f..6548f3c912 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -230,7 +230,10 @@ static void add_map(struct mm_region *map) /* Page fits, create block PTE */ debug("Setting PTE %p to block virt=%llx\n", pte, virt); - *pte = phys | attrs; + if (level == 3) + *pte = phys | attrs | PTE_TYPE_PAGE; + else + *pte = phys | attrs; virt += blocksize; phys += blocksize; size -= blocksize; diff --git a/arch/arm/include/asm/armv8/mmu.h b/arch/arm/include/asm/armv8/mmu.h index 6121aab547..765914c7e2 100644 --- a/arch/arm/include/asm/armv8/mmu.h +++ b/arch/arm/include/asm/armv8/mmu.h @@ -43,6 +43,7 @@ #define PTE_TYPE_MASK (3 << 0) #define PTE_TYPE_FAULT (0 << 0) #define PTE_TYPE_TABLE (3 << 0) +#define PTE_TYPE_PAGE (3 << 0) #define PTE_TYPE_BLOCK (1 << 0) #define PTE_TYPE_VALID (1 << 0)
if (level == 3)
else
This looks familiar. We are lucky not hitting this issue earlier.
Reviewed-by: York Sun york.sun@nxp.com
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: York Sun york.sun@nxp.com
Peng Fan
York Sun
