[U-Boot] [PATCH v1] colibri_imx7: boot kernel in secure mode
NXP downstream kernel uses legacy method to enable other cores, which requires kernel to run in a security mode (althought upstream kernel uses PSCI for this).
As we're using NXP kernel in our BSPs, lets enable this by default.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
include/configs/colibri_imx7.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 40173b18fa..5408577661 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -164,7 +164,8 @@ "${board}/flash_blk.img && source ${loadaddr}\0" \ "setup=setenv setupargs " \ "console=tty1 console=${console}" \ - ",${baudrate}n8 ${memargs} consoleblank=0\0" \ + ",${baudrate}n8 ${memargs} consoleblank=0; " \ + "setenv bootm_boot_mode sec\0" \ "setupdate=run setsdupdate || run setusbupdate || run setethupdate\0" \ "setusbupdate=usb start && setenv interface usb && " \ "fatload ${interface} 0:1 ${loadaddr} " \
Reviewed-by: Philippe Schenker philippe.schenker@toradex.com Tested-by: Philippe Schenker philippe.schenker@toradex.com
"setupdate=run setsdupdate || run setusbupdate || run setethupdate\0" \ "setusbupdate=usb start && setenv interface usb && " \ "fatload ${interface} 0:1 ${loadaddr} " \"setenv bootm_boot_mode sec\0" \
How does enabling both cores work in upstream kernel? It looks like PSCI does not work in secure mode using mainline 4.19 LTS kernel. Any hints? Until this is resolved booting in secure mode per default IMHO is not a good option.
Best regards
Tobias
Best regards
Tobias
Hi Tobias,
I just tried it again and it works also with 4.19 LTS and 'bootm_boot_mode sec' on my side.
Hi Tobias,
On Wed, Jul 10, 2019 at 3:35 PM Tobias Junghans tobias.junghans@veyon.io wrote:
Best regards
Tobias
I'm afraid you're right. Just after a bit of time researching and discussing with Stefan, seems that we need to introduce two different wrappers for booting the mainline kernel and downstream NXP kernel.
* NXP kernel has legacy code to enable all cores, which works only when running in secure mode. * Mainline kernel, as you said before, does use PSCI for this, which is provided by U-boot (which adds proper psci nodes to the linux dtb on-fly before transferring control to the linux kernel entry point). When we try to load it in secure mode, it continues running on the same Secure PL1, and communication using SMC calling convention doesn't make sense at this case.
Hi Igor,
thanks for your comments! Is there any solution, patch or workaround I can try to power on the 2nd CPU core in secure mode with mainline kernel?
Thanks and best regards
Tobias
- NXP kernel has legacy code to enable all cores, which works only when
- Mainline kernel, as you said before, does use PSCI for this, which
Subject: Re: [U-Boot] [PATCH v1] colibri_imx7: boot kernel in secure mode
Hi Igor,
The upstream maintainer rejected the legacy method for i.MX7, so in upstream psci was used, with psci, the kernel is booted in non-secure mode.
Regards, Peng.
Tobias
On 2019-07-23 15:29, Tobias Junghans wrote:
Hi Igor,
I am afraid that is not possible since without PSCI mainline simply lacks the code how to enable the secondary CPU. You cannot use PSCI and stay in secure mode.
Anyway, why would you want to boot in secure mode anyway? With non-secure mode your CPU has more features, e.g. you can actually use virtualization feature (HYP). You do not have that in secure mode.
Booting in non-secure mode is the proper way(tm) to boot on this CPU.
That CAAM issue is unfortunate. But I think it is possible to enable CAAM access in non-secure mode by making sure to write the proper registers while being still in secure mode.
-- Stefan
Tobias
Please ignore my Reviewed-by and Tested-by. I Tested it on downstream which works fine but on mainline only one core comes up by design. I wasn't aware of that.
Philippe
I think I mentioned it internally, but just to be clear: I do not agree with this patch.
Upstream U-Boot should be able to boot upstream Linux. I'd rather prefer to carry that patch in our downstream fork (or set the bootm_boot_mode environment in our boot script).
-- Stefan
Hi Stefan
Totally agree with you here, BTW, seems that Stefano has applied by mistake to u-boot-imx fcc79eee14("colibri_imx7_emmc: enable CONFIG_ARMV7_BOOT_SEC_DEFAULT"), although I've asked to ignore it.
Probably will send another patch that reverts this.
-- Stefan
On 24/07/19 14:19, Igor Opaniuk wrote:
Hi Stefan
Sorry for this - I have taken a look and I drop this one but I took fcc79eee14. Should I simply revert it on u-boot-imx (you do not need to send a patch, then)?
Regards, Stefano
-- Stefan
Hi Stefano,
Hi Stefan
kernel
Yes, please revert this patch, as it brakes boot of the mainline kernel. Thanks!
Regards, Stefano
-- Stefan
setethupdate\0" \
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
participants (6)
Igor Opaniuk
Peng Fan
Philippe Schenker
Stefan Agner
Stefano Babic
Tobias Junghans
